[U-Boot] [PATCH] pico-imx7d: Increase the CONFIG_ENV_OFFSET size
The environment size has grown in such a way that it corrupts the main U-Boot image after a "saveenv" causing a U-Boot hang.
Fix this problem by increasing the CONFIG_ENV_OFFSET size.
Signed-off-by: Fabio Estevam festevam@gmail.com --- include/configs/pico-imx7d.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/pico-imx7d.h b/include/configs/pico-imx7d.h index 2bc42a0..120111d 100644 --- a/include/configs/pico-imx7d.h +++ b/include/configs/pico-imx7d.h @@ -134,7 +134,7 @@ /* FLASH and environment organization */ #define CONFIG_ENV_SIZE SZ_8K
-#define CONFIG_ENV_OFFSET (8 * SZ_64K) +#define CONFIG_ENV_OFFSET (12 * SZ_64K) #define CONFIG_SYS_FSL_USDHC_NUM 2
#define CONFIG_SYS_MMC_ENV_DEV 0
Environment ? You mean code, I suppose. Size is stil 8kb.
Regards, Stefano
Hi Stefano,
Yes, it is the U-Boot image that has grown and overlaps with the environment region.
I have reworded the commit log in v2.
Thanks
Dear Fabio,
Sorry, I can't understand this change.
The size written to flash should never exceed CONFIG_ENV_SIZE; if it does, then there is some serious bug in the code, which I tend to doubt.
And when the environment grows, it would make it necessary to raise CONFIG_ENV_SIZE first - changing the CONFIG_ENV_OFFSET has nothing to do with this per se.
Can you please explain which phenomenon you see, and hos this change is supposed to work?
Hi Wolfgang,
On 30/11/18 14:05, Wolfgang Denk wrote:
Dear Fabio,
This was V1. It is not the size of the environment, it is U-Boot that grows and has overflow into the environment, leading to corruption by the first saveenv.
Nevertheless, the initial offset (0x80000) was quite optimistic with current bootloader size - u-boot binary for i.MX is often > 512KB.
No.
Best regards, Stefano
Fabio Estevam
Stefano Babic
