[U-Boot] Can not erase first 2 sectors on flash
Hello
I have a platform modify from powerpc 405EP(Taihu evb). I try to port u-boot from Taihu evb by using "taihu_config".
There are 4M+4M flash on the board, but I found that I can not erase flash from ff800000--ff803fff.I had try "protect off all" and "erase all", but still don't work.
just like this : => era ff800000 ff803fff
.. done Erased 2 sectors => md ff800000 ff800000: 27051956 682e4eec 4c070a61 00168502 '..Vh.N.L..a.... ff800010: 00000000 00000000 ad640a83 05070201 .........d...... ff800020: 4c696e75 782d322e 362e3332 2e330000 Linux-2.6.32.3.. ff800030: 00000000 00000000 00000000 00000000 ................ ff800040: 1f8b0808 600a074c 0203766d 6c696e75 ....`..L..vmlinu ff800050: 782e6269 6e2e3136 39363100 e45b0f70 x.bin.16961..[.p ff800060: 14559aff 7a7a0213 08cb0881 0d24988e .U..zz.......$..
"erase" command works every where on flash besides "ff800000--ff803fff" Thus I can still erase "ff800000--ff803fff" by using a JTAG. Is there anything wrong in my config(in attachment) ?
This is my flinfo ================================================================================== Bank # 1: CFI conformant FLASH (16 x 16) Size: 4 MB in 71 Sectors AMD Standard command set, Manufacturer ID: 0xC2, Device ID: 0x22A8 Erase timeout: 16384 ms, write timeout: 1 ms
Sector Start Addresses: FFC00000 FFC02000 FFC04000 FFC06000 FFC08000 FFC0A000 FFC0C000 FFC0E000 FFC10000 FFC20000 FFC30000 FFC40000 FFC50000 FFC60000 FFC70000 FFC80000 FFC90000 FFCA0000 FFCB0000 FFCC0000 FFCD0000 FFCE0000 FFCF0000 FFD00000 FFD10000 FFD20000 FFD30000 FFD40000 FFD50000 FFD60000 FFD70000 FFD80000 FFD90000 FFDA0000 FFDB0000 FFDC0000 FFDD0000 FFDE0000 FFDF0000 FFE00000 FFE10000 FFE20000 FFE30000 FFE40000 FFE50000 FFE60000 FFE70000 FFE80000 FFE90000 FFEA0000 FFEB0000 FFEC0000 FFED0000 FFEE0000 FFEF0000 FFF00000 FFF10000 FFF20000 FFF30000 FFF40000 FFF50000 FFF60000 FFF70000 FFF80000 FFF90000 FFFA0000 RO FFFB0000 RO FFFC0000 RO FFFD0000 RO FFFE0000 RO FFFF0000 RO
Bank # 2: CFI conformant FLASH (16 x 16) Size: 4 MB in 71 Sectors AMD Standard command set, Manufacturer ID: 0xC2, Device ID: 0x22A8 Erase timeout: 16384 ms, write timeout: 1 ms
Sector Start Addresses: FF800000 FF802000 FF804000 FF806000 FF808000 FF80A000 FF80C000 FF80E000 FF810000 FF820000 FF830000 FF840000 FF850000 FF860000 FF870000 FF880000 FF890000 FF8A0000 FF8B0000 FF8C0000 FF8D0000 FF8E0000 FF8F0000 FF900000 FF910000 FF920000 FF930000 FF940000 FF950000 FF960000 FF970000 FF980000 FF990000 FF9A0000 FF9B0000 FF9C0000 FF9D0000 FF9E0000 FF9F0000 FFA00000 FFA10000 FFA20000 FFA30000 FFA40000 FFA50000 FFA60000 FFA70000 FFA80000 FFA90000 FFAA0000 FFAB0000 FFAC0000 FFAD0000 FFAE0000 FFAF0000 FFB00000 FFB10000 FFB20000 FFB30000 FFB40000 FFB50000 FFB60000 FFB70000 FFB80000 FFB90000 FFBA0000 FFBB0000 FFBC0000 FFBD0000 FFBE0000 FFBF0000 ==================================================================================
This is my config file: http://www.cs.nctu.edu.tw/~chenpc/taihu.h
Chen Wen
