[U-Boot-Users] Newbie needing help with IBM 440 GX (OCOTEA)
I recently downloaded and setup u-boot, to create the u-boot.bin file I used did the following
make distclean make OCOTEA_config make all
I then updated the flash, and booted and I get the following ...
U-Boot 1.1.1 (Apr 26 2004 - 15:15:40)
IBM PowerPC 440 GX Rev. B Board: IBM 440GX Evaluation Board VCO: 1066 MHz CPU: 533 MHz PLB: 152 MHz OPB: 76 MHz EPB: 76 MHz I2C: ready DRAM: I2c read: failed 4 I2c read: failed 4 256 MB FLASH: 5 MB *** Warning - bad CRC, using default environment
PCI: Bus Dev VenId DevId Class Int 00 01 1000 0020 0100 00 00 01 1000 0020 0100 00 00 03 100b 0033 0000 00 In: serial Out: serial Err: serial KGDB: kgdb ready ready Net: ppc_440x_eth0 BEDBUG:ready =>
this is where my problems start! I have no response to anything typed on the keyboard
any help would be appreciated, I hope this has not been covered elsewhere, but I could not find it.
Thanks in advance
Daren
_________________________________________________________________ Find a cheaper internet access deal - choose one to suit you. http://www.msn.co.uk/internetaccess
In message BAY2-F163f7zeOmVjDd0002c3e2@hotmail.com you wrote:
BEDBUG:ready =>
Did you try the obvious, like disabling flow control in your terminal emulation program, or enabling it if it was off?
Daren Hayward
