[PATCH v2 00/21] FWU: Migrate FWU metadata to version 2
The following patches migrate the FWU metadata access code to version 2 of the structure. This is based on the structure definition as defined in the latest rev of the FWU Multi Bank Update specification [1].
Since the version 1 of the structure has currently been adopted on a couple of platforms, it was decided to have a clean migration of the metadata to version 2 only, instead of supporting both the versions of the structure. Also, based on consultations with the main author of the specification, it is expected that any further changes in the structure would be minor tweaks, and not be significant. Hence a migration to version 2.
Similar migration is also being done in TF-A, including migrating the ST platform port to support version 2 of the metadata structure [2].
@Michal, I tested the metadata for the two image per bank case, and it works fine on the ST board. Kindly test this on your board as well.
@Kojima-san, Please help in testing the version 2 on your board. Thanks.
[1] - https://developer.arm.com/documentation/den0118/latest/ [2] - https://review.trustedfirmware.org/q/topic:%22topics/fwu_metadata_v2_migrati...
Changes since V1:
* Do not define flexible array members inside the structures. * Access the image information related fields in the metadata using the helper functions defined in an earlier patch. * Access fwu_fw_store_desc structure using pointer arithmetic.
Sughosh Ganu (21): configs: fwu: remove FWU configs for metadata V2 migration fwu: metadata: migrate to version 2 of the structure drivers: fwu: add the size parameter to the metadata access API's fwu: add helper functions for getting image description offsets fwu: make changes to support version 2 of FWU metadata fwu: add some API's for metadata version 2 access drivers: fwu: mtd: allocate buffer for image info dynamically drivers: fwu: allocate memory for metadata copies fwu: add a function to put a bank in Trial State capsule: accept a bank on a successful update fwu: mtd: modify the DFU API's to align with metadata version 2 efi_firmware: fwu: do not read FWU metadata on sandbox efi_firmware: fwu: get the number of FWU banks at runtime cmd: fwu: align the command with metadata version 2 test: fwu: align the FWU metadata access test with version 2 fwu: remove the config symbols for number of banks and images tools: mkfwumdata: migrate to metadata version 2 tools: mkfwumdata: add logic to append vendor data to the FWU metadata tools: mkfwumdata: fix the size parameter to the fwrite call configs: fwu: re-enable FWU configs doc: fwu: make changes for supporting FWU Metadata version 2
arch/sandbox/Kconfig | 6 - board/armltd/corstone1000/corstone1000.c | 2 +- cmd/fwu_mdata.c | 45 ++- configs/synquacer_developerbox_defconfig | 1 - doc/board/socionext/developerbox.rst | 9 +- doc/develop/uefi/fwu_updates.rst | 12 +- doc/usage/cmd/fwu_mdata.rst | 12 +- drivers/fwu-mdata/fwu-mdata-uclass.c | 10 +- drivers/fwu-mdata/gpt_blk.c | 27 +- drivers/fwu-mdata/raw_mtd.c | 85 +++-- include/fwu.h | 139 +++++++- include/fwu_mdata.h | 56 +++- lib/efi_loader/efi_capsule.c | 12 +- lib/efi_loader/efi_firmware.c | 20 +- lib/fwu_updates/Kconfig | 11 - lib/fwu_updates/fwu.c | 401 +++++++++++++++++++---- lib/fwu_updates/fwu_mtd.c | 81 +++-- test/dm/fwu_mdata.c | 56 ++-- test/dm/fwu_mdata_disk_image.h | 124 +++---- tools/mkfwumdata.c | 132 ++++++-- 20 files changed, 924 insertions(+), 317 deletions(-)
The FWU metadata is to be migrated to version 2. Disable the FWU feature on platforms that enable it for the migration.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org ---
Changes since V1: None
configs/corstone1000_defconfig | 2 -- configs/sandbox64_defconfig | 1 - configs/synquacer_developerbox_defconfig | 4 ---- 3 files changed, 7 deletions(-)
diff --git a/configs/corstone1000_defconfig b/configs/corstone1000_defconfig index a86ac12732..c26a621175 100644 --- a/configs/corstone1000_defconfig +++ b/configs/corstone1000_defconfig @@ -25,7 +25,6 @@ CONFIG_BOARD_LATE_INIT=y CONFIG_SYS_PROMPT="corstone1000# " CONFIG_SYS_MAXARGS=64 # CONFIG_CMD_CONSOLE is not set -CONFIG_CMD_FWU_METADATA=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_XIMG is not set CONFIG_CMD_GPT=y @@ -68,4 +67,3 @@ CONFIG_FFA_SHARED_MM_BUF_OFFSET=0 CONFIG_FFA_SHARED_MM_BUF_ADDR=0x02000000 CONFIG_EFI_CAPSULE_ON_DISK=y CONFIG_EFI_IGNORE_OSINDICATIONS=y -CONFIG_FWU_MULTI_BANK_UPDATE=y diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index d101cca6a7..2863f9b189 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -273,7 +273,6 @@ CONFIG_EFI_CAPSULE_ON_DISK=y CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y CONFIG_EFI_SECURE_BOOT=y CONFIG_TEST_FDTDEC=y -CONFIG_FWU_MULTI_BANK_UPDATE=y CONFIG_UNIT_TEST=y CONFIG_UT_TIME=y CONFIG_UT_DM=y diff --git a/configs/synquacer_developerbox_defconfig b/configs/synquacer_developerbox_defconfig index 2a0407de40..616d410074 100644 --- a/configs/synquacer_developerbox_defconfig +++ b/configs/synquacer_developerbox_defconfig @@ -11,14 +11,12 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="synquacer-sc2a11-developerbox" CONFIG_SYS_LOAD_ADDR=0x80000000 CONFIG_TARGET_DEVELOPERBOX=y -CONFIG_FWU_NUM_IMAGES_PER_BANK=1 CONFIG_AHCI=y CONFIG_FIT=y CONFIG_SYS_BOOTM_LEN=0x800000 CONFIG_BOOTSTAGE_STASH_SIZE=4096 CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=128 -CONFIG_CMD_FWU_METADATA=y CONFIG_CMD_IMLS=y CONFIG_CMD_ERASEENV=y CONFIG_CMD_NVEDIT_EFI=y @@ -53,7 +51,6 @@ CONFIG_DFU_TFTP=y CONFIG_DFU_MTD=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y -CONFIG_FWU_MDATA_MTD=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_SYNQUACER=y CONFIG_MMC_SDHCI=y @@ -96,4 +93,3 @@ CONFIG_EFI_RUNTIME_UPDATE_CAPSULE=y CONFIG_EFI_CAPSULE_ON_DISK=y CONFIG_EFI_IGNORE_OSINDICATIONS=y CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y -CONFIG_FWU_MULTI_BANK_UPDATE=y
The latest version of the FWU specification [1] has changes to the metadata structure. This is version 2 of the structure.
Primary changes include - bank_state field in the top level structure - Total metadata size in the top level structure - Image description structures now optional - Number of banks and images per bank values part of the structure
Migrate to the version 2 of the metadata structure.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org ---
Changes since V1: * Do not define flexible array members inside the structures.
include/fwu_mdata.h | 56 +++++++++++++++++++++++++++++++++------------ 1 file changed, 42 insertions(+), 14 deletions(-)
diff --git a/include/fwu_mdata.h b/include/fwu_mdata.h index 56189e2f40..9008bbc93f 100644 --- a/include/fwu_mdata.h +++ b/include/fwu_mdata.h @@ -11,7 +11,7 @@
/** * struct fwu_image_bank_info - firmware image information - * @image_uuid: Guid value of the image in this bank + * @image_guid: Guid value of the image in this bank * @accepted: Acceptance status of the image * @reserved: Reserved * @@ -20,15 +20,15 @@ * acceptance status */ struct fwu_image_bank_info { - efi_guid_t image_uuid; + efi_guid_t image_guid; uint32_t accepted; uint32_t reserved; } __packed;
/** * struct fwu_image_entry - information for a particular type of image - * @image_type_uuid: Guid value for identifying the image type - * @location_uuid: Guid of the storage volume where the image is located + * @image_type_guid: Guid value for identifying the image type + * @location_guid: Guid of the storage volume where the image is located * @img_bank_info: Array containing properties of images * * This structure contains information on various types of updatable @@ -36,9 +36,30 @@ struct fwu_image_bank_info { * information per bank. */ struct fwu_image_entry { - efi_guid_t image_type_uuid; - efi_guid_t location_uuid; - struct fwu_image_bank_info img_bank_info[CONFIG_FWU_NUM_BANKS]; + efi_guid_t image_type_guid; + efi_guid_t location_guid; + // struct fwu_image_bank_info img_bank_info[]; +} __packed; + +/** + * struct fwu_fw_desc_store - FWU updatable image information + * @num_banks: Number of firmware banks + * num_images: Number of images per bank + * @img_entry_size: The size of the img_entry array + * @bank_info_entry_size: The size of the img_bank_info array + * @img_entry: Array of image entries each giving information on a image + * + * This image descriptor structure contains information on the number of + * updatable banks and images per bank. It also gives the total sizes of + * the fwu_image_entry and fwu_image_bank_info arrays. + */ +struct fwu_fw_store_desc { + uint8_t num_banks; + uint8_t reserved; + uint16_t num_images; + uint16_t img_entry_size; + uint16_t bank_info_entry_size; + // struct fwu_image_entry img_entry[]; } __packed;
/** @@ -48,21 +69,28 @@ struct fwu_image_entry { * @active_index: Index of the bank currently used for booting images * @previous_active_inde: Index of the bank used before the current bank * being used for booting - * @img_entry: Array of information on various firmware images that can - * be updated + * @metadata_size: Size of the entire metadata structure, including the + * image descriptors + * @desc_offset: The offset from the start of this structure where the + * image descriptor structure starts. 0 if absent + * @bank_state: State of each bank, valid, invalid or accepted + * @fw_desc: The structure describing the FWU updatable images * - * This structure is used to store all the needed information for performing + * This is the top level structure used to store all information for performing * multi bank updates on the platform. This contains info on the bank being - * used to boot along with the information needed for identification of - * individual images + * used to boot along with the information on state of individual banks. */ struct fwu_mdata { uint32_t crc32; uint32_t version; uint32_t active_index; uint32_t previous_active_index; - - struct fwu_image_entry img_entry[CONFIG_FWU_NUM_IMAGES_PER_BANK]; + uint32_t metadata_size; + uint16_t desc_offset; + uint16_t reserved1; + uint8_t bank_state[4]; + uint32_t reserved2; + // struct fwu_fw_store_desc fw_desc[]; } __packed;
#endif /* _FWU_MDATA_H_ */
In version 2 of the metadata structure, the size of the structure cannot be determined statically at build time. The structure is now broken into the top level structure which contains a field indicating the total size of the structure.
Add a size parameter to the metadata access API functions to indicate the number of bytes to be accessed. This is then used to either read the entire structure, or only the top level structure.
drivers/fwu-mdata/fwu-mdata-uclass.c | 10 ++++++---- drivers/fwu-mdata/gpt_blk.c | 23 +++++++++++++---------- drivers/fwu-mdata/raw_mtd.c | 10 ++++++---- include/fwu.h | 14 ++++++++++---- 4 files changed, 35 insertions(+), 22 deletions(-)
diff --git a/drivers/fwu-mdata/fwu-mdata-uclass.c b/drivers/fwu-mdata/fwu-mdata-uclass.c index 0a8edaaa41..145479bab0 100644 --- a/drivers/fwu-mdata/fwu-mdata-uclass.c +++ b/drivers/fwu-mdata/fwu-mdata-uclass.c @@ -20,7 +20,8 @@ * * Return: 0 if OK, -ve on error */ -int fwu_read_mdata(struct udevice *dev, struct fwu_mdata *mdata, bool primary) +int fwu_read_mdata(struct udevice *dev, struct fwu_mdata *mdata, bool primary, + uint32_t size) { const struct fwu_mdata_ops *ops = device_get_ops(dev);
@@ -29,7 +30,7 @@ int fwu_read_mdata(struct udevice *dev, struct fwu_mdata *mdata, bool primary) return -ENOSYS; }
- return ops->read_mdata(dev, mdata, primary); + return ops->read_mdata(dev, mdata, primary, size); }
/** @@ -37,7 +38,8 @@ int fwu_read_mdata(struct udevice *dev, struct fwu_mdata *mdata, bool primary) * * Return: 0 if OK, -ve on error */ -int fwu_write_mdata(struct udevice *dev, struct fwu_mdata *mdata, bool primary) +int fwu_write_mdata(struct udevice *dev, struct fwu_mdata *mdata, bool primary, + uint32_t size) { const struct fwu_mdata_ops *ops = device_get_ops(dev);
@@ -46,7 +48,7 @@ int fwu_write_mdata(struct udevice *dev, struct fwu_mdata *mdata, bool primary) return -ENOSYS; }
- return ops->write_mdata(dev, mdata, primary); + return ops->write_mdata(dev, mdata, primary, size); }
UCLASS_DRIVER(fwu_mdata) = { diff --git a/drivers/fwu-mdata/gpt_blk.c b/drivers/fwu-mdata/gpt_blk.c index c7284916c4..97eac3611f 100644 --- a/drivers/fwu-mdata/gpt_blk.c +++ b/drivers/fwu-mdata/gpt_blk.c @@ -81,15 +81,14 @@ static int gpt_get_mdata_disk_part(struct blk_desc *desc, return -ENOENT; }
-static int gpt_read_write_mdata(struct blk_desc *desc, - struct fwu_mdata *mdata, - u8 access, u32 part_num) +static int gpt_read_write_mdata(struct blk_desc *desc, struct fwu_mdata *mdata, + u8 access, u32 part_num, u32 size) { int ret; u32 len, blk_start, blkcnt; struct disk_partition info;
- ALLOC_CACHE_ALIGN_BUFFER_PAD(struct fwu_mdata, mdata_aligned, 1, + ALLOC_CACHE_ALIGN_BUFFER_PAD(u8, mdata_aligned, size, desc->blksz);
if (!mdata) @@ -101,7 +100,7 @@ static int gpt_read_write_mdata(struct blk_desc *desc, return -ENOENT; }
- len = sizeof(*mdata); + len = size; blkcnt = BLOCK_CNT(len, desc); if (blkcnt > info.size) { log_debug("Block count exceeds FWU metadata partition size\n"); @@ -114,7 +113,7 @@ static int gpt_read_write_mdata(struct blk_desc *desc, log_debug("Error reading FWU metadata from the device\n"); return -EIO; } - memcpy(mdata, mdata_aligned, sizeof(struct fwu_mdata)); + memcpy(mdata, mdata_aligned, size); } else { if (blk_dwrite(desc, blk_start, blkcnt, mdata) != blkcnt) { log_debug("Error writing FWU metadata to the device\n"); @@ -164,7 +163,7 @@ static int fwu_mdata_gpt_blk_probe(struct udevice *dev) }
static int fwu_gpt_read_mdata(struct udevice *dev, struct fwu_mdata *mdata, - bool primary) + bool primary, u32 size) { struct fwu_mdata_gpt_blk_priv *priv = dev_get_priv(dev); struct blk_desc *desc = dev_get_uclass_plat(priv->blk_dev); @@ -177,11 +176,13 @@ static int fwu_gpt_read_mdata(struct udevice *dev, struct fwu_mdata *mdata, }
return gpt_read_write_mdata(desc, mdata, MDATA_READ, - primary ? g_mdata_part[0] : g_mdata_part[1]); + primary ? + g_mdata_part[0] : g_mdata_part[1], + size); }
static int fwu_gpt_write_mdata(struct udevice *dev, struct fwu_mdata *mdata, - bool primary) + bool primary, u32 size) { struct fwu_mdata_gpt_blk_priv *priv = dev_get_priv(dev); struct blk_desc *desc = dev_get_uclass_plat(priv->blk_dev); @@ -194,7 +195,9 @@ static int fwu_gpt_write_mdata(struct udevice *dev, struct fwu_mdata *mdata, }
return gpt_read_write_mdata(desc, mdata, MDATA_WRITE, - primary ? g_mdata_part[0] : g_mdata_part[1]); + primary ? + g_mdata_part[0] : g_mdata_part[1], + size); }
static const struct fwu_mdata_ops fwu_gpt_blk_ops = { diff --git a/drivers/fwu-mdata/raw_mtd.c b/drivers/fwu-mdata/raw_mtd.c index 17e4517973..9f3f1dc213 100644 --- a/drivers/fwu-mdata/raw_mtd.c +++ b/drivers/fwu-mdata/raw_mtd.c @@ -97,22 +97,24 @@ lock: return ret; }
-static int fwu_mtd_read_mdata(struct udevice *dev, struct fwu_mdata *mdata, bool primary) +static int fwu_mtd_read_mdata(struct udevice *dev, struct fwu_mdata *mdata, + bool primary, u32 size) { struct fwu_mdata_mtd_priv *mtd_priv = dev_get_priv(dev); struct mtd_info *mtd = mtd_priv->mtd; u32 offs = primary ? mtd_priv->pri_offset : mtd_priv->sec_offset;
- return mtd_io_data(mtd, offs, sizeof(struct fwu_mdata), mdata, FWU_MTD_READ); + return mtd_io_data(mtd, offs, size, mdata, FWU_MTD_READ); }
-static int fwu_mtd_write_mdata(struct udevice *dev, struct fwu_mdata *mdata, bool primary) +static int fwu_mtd_write_mdata(struct udevice *dev, struct fwu_mdata *mdata, + bool primary, u32 size) { struct fwu_mdata_mtd_priv *mtd_priv = dev_get_priv(dev); struct mtd_info *mtd = mtd_priv->mtd; u32 offs = primary ? mtd_priv->pri_offset : mtd_priv->sec_offset;
- return mtd_io_data(mtd, offs, sizeof(struct fwu_mdata), mdata, FWU_MTD_WRITE); + return mtd_io_data(mtd, offs, size, mdata, FWU_MTD_WRITE); }
static int flash_partition_offset(struct udevice *dev, const char *part_name, fdt_addr_t *offset) diff --git a/include/fwu.h b/include/fwu.h index eb5638f4f3..1815bd0064 100644 --- a/include/fwu.h +++ b/include/fwu.h @@ -32,20 +32,24 @@ struct fwu_mdata_ops { * @dev: FWU metadata device * @mdata: Output FWU mdata read * @primary: If primary or secondary copy of metadata is to be read + * @size: Size in bytes of the metadata to be read * * Return: 0 if OK, -ve on error */ - int (*read_mdata)(struct udevice *dev, struct fwu_mdata *mdata, bool primary); + int (*read_mdata)(struct udevice *dev, struct fwu_mdata *mdata, + bool primary, uint32_t size);
/** * write_mdata() - Write the given FWU metadata copy * @dev: FWU metadata device * @mdata: Copy of the FWU metadata to write * @primary: If primary or secondary copy of metadata is to be written + * @size: Size in bytes of the metadata to be written * * Return: 0 if OK, -ve on error */ - int (*write_mdata)(struct udevice *dev, struct fwu_mdata *mdata, bool primary); + int (*write_mdata)(struct udevice *dev, struct fwu_mdata *mdata, + bool primary, uint32_t size); };
#define FWU_MDATA_VERSION 0x1 @@ -80,12 +84,14 @@ struct fwu_mdata_ops { /** * fwu_read_mdata() - Wrapper around fwu_mdata_ops.read_mdata() */ -int fwu_read_mdata(struct udevice *dev, struct fwu_mdata *mdata, bool primary); +int fwu_read_mdata(struct udevice *dev, struct fwu_mdata *mdata, + bool primary, uint32_t size);
/** * fwu_write_mdata() - Wrapper around fwu_mdata_ops.write_mdata() */ -int fwu_write_mdata(struct udevice *dev, struct fwu_mdata *mdata, bool primary); +int fwu_write_mdata(struct udevice *dev, struct fwu_mdata *mdata, + bool primary, uint32_t size);
/** * fwu_get_mdata() - Read, verify and return the FWU metadata
With migration of the FWU metadata structure to version 2, the size of the structure is not determined at build time, but at run time.
This means, that the offsets for the structures describing firmware images which are part of the FWU metadata(struct fwu_fw_store_desc, struct fwu_image_entry and struct fwu_image_bank_info) need to be computed at runtime. Add helper functions to get addresses of these structures.
Changes since V1: * New patch needed based on comments from Ilias on the earlier version.
include/fwu.h | 45 +++++++++++++++++++++++++++++++++ lib/fwu_updates/fwu.c | 58 +++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 103 insertions(+)
diff --git a/include/fwu.h b/include/fwu.h index 1815bd0064..7de462548c 100644 --- a/include/fwu.h +++ b/include/fwu.h @@ -8,6 +8,7 @@
#include <blk.h> #include <efi.h> +#include <fwu_mdata.h> #include <mtd.h> #include <uuid.h>
@@ -81,6 +82,50 @@ struct fwu_mdata_ops { EFI_GUID(0x0c996046, 0xbcc0, 0x4d04, 0x85, 0xec, \ 0xe1, 0xfc, 0xed, 0xf1, 0xc6, 0xf8)
+ +/** + * fwu_get_fw_desc() - Return pointer to firmware descriptor store struct + * @mdata: Pointer to the FWU metadata + * + * Returns pointer to the firmware store descriptor of the FWU metadata + * containing information on updatable images. + * + * Return: Pointer to the struct fwu_fw_store_desc + */ +static inline struct fwu_fw_store_desc *fwu_get_fw_desc(struct fwu_mdata *mdata) +{ + return (struct fwu_fw_store_desc *)((u8 *)mdata + sizeof(*mdata)); +} + +/** + * fwu_img_entry_offset() - Get pointer to struct fwu_image_entry + * @mdata: Pointer to the FWU metadata + * @idx: Image index for which pointer is to be returned + * + * Fetches pointer to am array element of type struct fwu_image_entry. + * This returns back a pointer to a structure which is providing + * information on a updatable image. + * + * Return: Pointer to an array element of type struct fwu_image_entry + * + */ +struct fwu_image_entry *fwu_img_entry_offset(struct fwu_mdata *mdata, u16 idx); + +/** + * fwu_img_bank_info_offset() - Get pointer to struct fwu_image_bank_info + * @mdata: Pointer to the FWU metadata + * @idx: Image index for which information is needed + * @bank: Bank for which pointer is to be returned + * + * Fetches pointer to an array element of type struct fwu_image_bank_info + * for a given image. This returns back a pointer to a structure which + * is providing information for a given bank for a particular image. + * + * Return: Pointer to an array element of type fwu_image_bank_info + * + */ +struct fwu_image_bank_info *fwu_img_bank_info_offset(struct fwu_mdata *mdata, + u16 idx, u8 bank); /** * fwu_read_mdata() - Wrapper around fwu_mdata_ops.read_mdata() */ diff --git a/lib/fwu_updates/fwu.c b/lib/fwu_updates/fwu.c index 86518108c2..5f1182a764 100644 --- a/lib/fwu_updates/fwu.c +++ b/lib/fwu_updates/fwu.c @@ -141,6 +141,64 @@ static int fwu_get_image_type_id(u8 image_index, efi_guid_t *image_type_id) return -ENOENT; }
+/** + * fwu_img_entry_offset() - Get pointer to struct fwu_image_entry + * @mdata: Pointer to the FWU metadata + * @idx: Image index for which pointer is to be returned + * + * Fetches pointer to am array element of type struct fwu_image_entry. + * This returns back a pointer to a structure which is providing + * information on a updatable image. + * + * Return: Pointer to an array element of type struct fwu_image_entry + * + */ +struct fwu_image_entry *fwu_img_entry_offset(struct fwu_mdata *mdata, u16 idx) +{ + u8 num_banks; + size_t offset; + + num_banks = fwu_get_fw_desc(mdata)->num_banks; + + offset = sizeof(struct fwu_mdata) + + sizeof(struct fwu_fw_store_desc) + + (sizeof(struct fwu_image_entry) + + sizeof(struct fwu_image_bank_info) * num_banks) * idx; + + return (struct fwu_image_entry *)((char *)mdata + offset); +} + +/** + * fwu_img_bank_info_offset() - Get pointer to struct fwu_image_bank_info + * @mdata: Pointer to the FWU metadata + * @idx: Image index for which information is needed + * @bank: Bank for which pointer is to be returned + * + * Fetches pointer to an array element of type struct fwu_image_bank_info + * for a given image. This returns back a pointer to a structure which + * is providing information for a given bank for a particular image. + * + * Return: Pointer to an array element of type fwu_image_bank_info + * + */ +struct fwu_image_bank_info *fwu_img_bank_info_offset(struct fwu_mdata *mdata, + u16 idx, u8 bank) +{ + u8 num_banks; + size_t offset; + + num_banks = fwu_get_fw_desc(mdata)->num_banks; + + offset = sizeof(struct fwu_mdata) + + sizeof(struct fwu_fw_store_desc) + + (sizeof(struct fwu_image_entry) + + sizeof(struct fwu_image_bank_info) * num_banks) * idx + + sizeof(struct fwu_image_entry) + + sizeof(struct fwu_image_bank_info) * bank; + + return (struct fwu_image_bank_info *)((char *)mdata + offset); +} + /** * fwu_sync_mdata() - Update given meta-data partition(s) with the copy provided * @mdata: FWU metadata structure
Make changes to the FWU library functions which are used to access the metadata structure to support version 2 of the metadata.
At a broad level, the following are the changes made - Use a pointer g_mdata instead of a variable, and allocate space for it at runtime. - Obtain the number of banks and number of images per bank from the metadata at runtime, instead of using config values. - Obtain the pointers to the fwu_image_entry and fwu_image_bank_info structures at runtime by pointer arithmetic using the helper functions. - Get the size of the metadata from the metadata structure, instead of using build-time value.
Changes since V1: * Use the helper functions from the previous patch to access the image information in the metadata.
include/fwu.h | 6 +- lib/fwu_updates/fwu.c | 145 +++++++++++++++++++++++++++--------------- 2 files changed, 98 insertions(+), 53 deletions(-)
diff --git a/include/fwu.h b/include/fwu.h index 7de462548c..8f2492bb7e 100644 --- a/include/fwu.h +++ b/include/fwu.h @@ -53,9 +53,13 @@ struct fwu_mdata_ops { bool primary, uint32_t size); };
-#define FWU_MDATA_VERSION 0x1 +#define FWU_MDATA_VERSION 0x2 #define FWU_IMAGE_ACCEPTED 0x1
+#define FWU_BANK_INVALID 0xFF +#define FWU_BANK_VALID 0xFE +#define FWU_BANK_ACCEPTED 0xFC + /* * GUID value defined in the FWU specification for identification * of the FWU metadata partition. diff --git a/lib/fwu_updates/fwu.c b/lib/fwu_updates/fwu.c index 5f1182a764..2da19c9003 100644 --- a/lib/fwu_updates/fwu.c +++ b/lib/fwu_updates/fwu.c @@ -17,7 +17,7 @@
#include <u-boot/crc.h>
-static struct fwu_mdata g_mdata; /* = {0} makes uninit crc32 always invalid */ +static struct fwu_mdata *g_mdata; static struct udevice *g_dev; static u8 in_trial; static u8 boottime_check; @@ -108,21 +108,9 @@ out:
static int in_trial_state(struct fwu_mdata *mdata) { - u32 i, active_bank; - struct fwu_image_entry *img_entry; - struct fwu_image_bank_info *img_bank_info; - - active_bank = mdata->active_index; - img_entry = &mdata->img_entry[0]; - for (i = 0; i < CONFIG_FWU_NUM_IMAGES_PER_BANK; i++) { - img_bank_info = &img_entry[i].img_bank_info[active_bank]; - if (!img_bank_info->accepted) { - log_info("System booting in Trial State\n"); - return 1; - } - } + u32 active_bank = mdata->active_index;
- return 0; + return mdata->bank_state[active_bank] == FWU_BANK_VALID ? 1 : 0; }
static int fwu_get_image_type_id(u8 image_index, efi_guid_t *image_type_id) @@ -208,8 +196,9 @@ struct fwu_image_bank_info *fwu_img_bank_info_offset(struct fwu_mdata *mdata, */ static int fwu_sync_mdata(struct fwu_mdata *mdata, int part) { - void *buf = &mdata->version; int err; + uint32_t mdata_size; + void *buf = &mdata->version;
if (part == BOTH_PARTS) { err = fwu_sync_mdata(mdata, SECONDARY_PART); @@ -223,9 +212,10 @@ static int fwu_sync_mdata(struct fwu_mdata *mdata, int part) * and put the updated value in the FWU metadata crc32 * field */ - mdata->crc32 = crc32(0, buf, sizeof(*mdata) - sizeof(u32)); + mdata_size = mdata->metadata_size; + mdata->crc32 = crc32(0, buf, mdata_size - sizeof(u32));
- err = fwu_write_mdata(g_dev, mdata, part == PRIMARY_PART); + err = fwu_write_mdata(g_dev, mdata, part == PRIMARY_PART, mdata_size); if (err) { log_err("Unable to write %s mdata\n", part == PRIMARY_PART ? "primary" : "secondary"); @@ -233,7 +223,7 @@ static int fwu_sync_mdata(struct fwu_mdata *mdata, int part) }
/* update the cached copy of meta-data */ - memcpy(&g_mdata, mdata, sizeof(struct fwu_mdata)); + memcpy(g_mdata, mdata, mdata_size);
return 0; } @@ -241,8 +231,12 @@ static int fwu_sync_mdata(struct fwu_mdata *mdata, int part) static inline int mdata_crc_check(struct fwu_mdata *mdata) { void *buf = &mdata->version; - u32 calc_crc32 = crc32(0, buf, sizeof(*mdata) - sizeof(u32)); + u32 calc_crc32;
+ if (!mdata->metadata_size) + return -EINVAL; + + calc_crc32 = crc32(0, buf, mdata->metadata_size - sizeof(u32)); return calc_crc32 == mdata->crc32 ? 0 : -EINVAL; }
@@ -259,27 +253,32 @@ static inline int mdata_crc_check(struct fwu_mdata *mdata) int fwu_get_mdata(struct fwu_mdata *mdata) { int err; + uint32_t mdata_size; bool parts_ok[2] = { false }; - struct fwu_mdata s, *parts_mdata[2]; + struct fwu_mdata *parts_mdata[2]; + + err = fwu_get_mdata_size(&mdata_size); + if (err) + return err;
- parts_mdata[0] = &g_mdata; - parts_mdata[1] = &s; + parts_mdata[0] = g_mdata; + parts_mdata[1] = (struct fwu_mdata *)((char *)g_mdata + mdata_size);
/* if mdata already read and ready */ - err = mdata_crc_check(parts_mdata[0]); - if (!err) + if (!mdata_crc_check(parts_mdata[0])) goto ret_mdata; - /* else read, verify and, if needed, fix mdata */
+ /* else read, verify and, if needed, fix mdata */ for (int i = 0; i < 2; i++) { parts_ok[i] = false; - err = fwu_read_mdata(g_dev, parts_mdata[i], !i); + err = fwu_read_mdata(g_dev, parts_mdata[i], !i, mdata_size); if (!err) { err = mdata_crc_check(parts_mdata[i]); if (!err) parts_ok[i] = true; else - log_debug("mdata : %s crc32 failed\n", i ? "secondary" : "primary"); + log_debug("mdata : %s crc32 failed\n", + i ? "secondary" : "primary"); } }
@@ -288,7 +287,8 @@ int fwu_get_mdata(struct fwu_mdata *mdata) * Before returning, check that both the * FWU metadata copies are the same. */ - err = memcmp(parts_mdata[0], parts_mdata[1], sizeof(struct fwu_mdata)); + err = memcmp(parts_mdata[0], parts_mdata[1], + mdata_size); if (!err) goto ret_mdata;
@@ -305,7 +305,8 @@ int fwu_get_mdata(struct fwu_mdata *mdata) if (parts_ok[i]) continue;
- memcpy(parts_mdata[i], parts_mdata[1 - i], sizeof(struct fwu_mdata)); + memcpy(parts_mdata[i], parts_mdata[1 - i], + mdata_size); err = fwu_sync_mdata(parts_mdata[i], i ? SECONDARY_PART : PRIMARY_PART); if (err) { log_debug("mdata : %s write failed\n", i ? "secondary" : "primary"); @@ -315,7 +316,7 @@ int fwu_get_mdata(struct fwu_mdata *mdata)
ret_mdata: if (!err && mdata) - memcpy(mdata, parts_mdata[0], sizeof(struct fwu_mdata)); + memcpy(mdata, parts_mdata[0], mdata_size);
return err; } @@ -333,14 +334,19 @@ ret_mdata: int fwu_get_active_index(uint *active_idx) { int ret = 0; - struct fwu_mdata *mdata = &g_mdata; + u8 num_banks; + struct fwu_mdata *mdata = g_mdata; + + if (!mdata) + return -EINVAL;
/* * Found the FWU metadata partition, now read the active_index * value */ *active_idx = mdata->active_index; - if (*active_idx >= CONFIG_FWU_NUM_BANKS) { + num_banks = fwu_get_fw_desc(mdata)->num_banks; + if (*active_idx >= num_banks) { log_debug("Active index value read is incorrect\n"); ret = -EINVAL; } @@ -360,9 +366,14 @@ int fwu_get_active_index(uint *active_idx) int fwu_set_active_index(uint active_idx) { int ret; - struct fwu_mdata *mdata = &g_mdata; + u8 num_banks; + struct fwu_mdata *mdata = g_mdata;
- if (active_idx >= CONFIG_FWU_NUM_BANKS) { + if (!mdata) + return -EINVAL; + + num_banks = fwu_get_fw_desc(mdata)->num_banks; + if (active_idx >= num_banks) { log_debug("Invalid active index value\n"); return -EINVAL; } @@ -402,12 +413,16 @@ int fwu_set_active_index(uint active_idx) int fwu_get_dfu_alt_num(u8 image_index, u8 *alt_num) { int ret, i; + u16 num_images; uint update_bank; efi_guid_t *image_guid, image_type_id; - struct fwu_mdata *mdata = &g_mdata; + struct fwu_mdata *mdata = g_mdata; struct fwu_image_entry *img_entry; struct fwu_image_bank_info *img_bank_info;
+ if (!mdata) + return -EINVAL; + ret = fwu_plat_get_update_index(&update_bank); if (ret) { log_debug("Failed to get the FWU update bank\n"); @@ -423,15 +438,20 @@ int fwu_get_dfu_alt_num(u8 image_index, u8 *alt_num)
ret = -EINVAL; /* - * The FWU metadata has been read. Now get the image_uuid for the + * The FWU metadata has been read. Now get the image_guid for the * image with the update_bank. */ - for (i = 0; i < CONFIG_FWU_NUM_IMAGES_PER_BANK; i++) { - if (!guidcmp(&image_type_id, - &mdata->img_entry[i].image_type_uuid)) { - img_entry = &mdata->img_entry[i]; - img_bank_info = &img_entry->img_bank_info[update_bank]; - image_guid = &img_bank_info->image_uuid; + num_images = fwu_get_fw_desc(mdata)->num_images; + for (i = 0; i < num_images; i++) { + img_entry = fwu_img_entry_offset(mdata, i); + if (img_entry && + !guidcmp(&image_type_id, &img_entry->image_type_guid)) { + img_bank_info = fwu_img_bank_info_offset(mdata, i, + update_bank); + if (!img_bank_info) + return -EINVAL; + + image_guid = &img_bank_info->image_guid; ret = fwu_plat_get_alt_num(g_dev, image_guid, alt_num); if (ret) log_debug("alt_num not found for partition with GUID %pUs\n", @@ -465,7 +485,10 @@ int fwu_revert_boot_index(void) { int ret; u32 cur_active_index; - struct fwu_mdata *mdata = &g_mdata; + struct fwu_mdata *mdata = g_mdata; + + if (!mdata) + return -EINVAL;
/* * Swap the active index and previous_active_index fields @@ -506,14 +529,24 @@ int fwu_revert_boot_index(void) static int fwu_clrset_image_accept(efi_guid_t *img_type_id, u32 bank, u8 action) { int ret, i; - struct fwu_mdata *mdata = &g_mdata; + u16 num_images; + struct fwu_mdata *mdata = g_mdata; struct fwu_image_entry *img_entry; struct fwu_image_bank_info *img_bank_info;
- img_entry = &mdata->img_entry[0]; - for (i = 0; i < CONFIG_FWU_NUM_IMAGES_PER_BANK; i++) { - if (!guidcmp(&img_entry[i].image_type_uuid, img_type_id)) { - img_bank_info = &img_entry[i].img_bank_info[bank]; + if (!mdata) + return -EINVAL; + + num_images = fwu_get_fw_desc(mdata)->num_images; + for (i = 0; i < num_images; i++) { + img_entry = fwu_img_entry_offset(mdata, i); + if (img_entry && + !guidcmp(&img_entry->image_type_guid, img_type_id)) { + img_bank_info = fwu_img_bank_info_offset(mdata, i, + bank); + if (!img_bank_info) + return -ENOENT; + if (action == IMAGE_ACCEPT_SET) img_bank_info->accepted |= FWU_IMAGE_ACCEPTED; else @@ -587,12 +620,18 @@ __weak int fwu_plat_get_update_index(uint *update_idx) { int ret; u32 active_idx; + u8 num_banks; + struct fwu_mdata *mdata = g_mdata; + + if (!mdata) + return -EINVAL;
ret = fwu_get_active_index(&active_idx); if (ret < 0) return -1;
- *update_idx = (active_idx + 1) % CONFIG_FWU_NUM_BANKS; + num_banks = fwu_get_fw_desc(mdata)->num_banks; + *update_idx = (active_idx + 1) % num_banks;
return ret; } @@ -671,6 +710,7 @@ int fwu_trial_state_ctr_start(void) static int fwu_boottime_checks(void) { int ret; + u8 num_banks; u32 boot_idx, active_idx;
ret = uclass_first_device_err(UCLASS_FWU_MDATA, &g_dev); @@ -701,7 +741,8 @@ static int fwu_boottime_checks(void) * update the active_index. */ fwu_plat_get_bootidx(&boot_idx); - if (boot_idx >= CONFIG_FWU_NUM_BANKS) { + num_banks = fwu_get_fw_desc(g_mdata)->num_banks; + if (boot_idx >= num_banks) { log_err("Received incorrect value of boot_index\n"); return 0; } @@ -723,7 +764,7 @@ static int fwu_boottime_checks(void) if (efi_init_obj_list() != EFI_SUCCESS) return 0;
- in_trial = in_trial_state(&g_mdata); + in_trial = in_trial_state(g_mdata); if (!in_trial || (ret = fwu_trial_count_update()) > 0) ret = trial_counter_update(NULL);
There are certain fields added in version 2 of the FWU metadata structure. Also, information like number of banks and number of images per bank are also part of the metadata structure. Add functions to access fields of the version 2 of the metadata structure.
include/fwu.h | 53 ++++++++++++++++ lib/fwu_updates/fwu.c | 144 ++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 197 insertions(+)
diff --git a/include/fwu.h b/include/fwu.h index 8f2492bb7e..ce8c98921a 100644 --- a/include/fwu.h +++ b/include/fwu.h @@ -153,6 +153,26 @@ int fwu_write_mdata(struct udevice *dev, struct fwu_mdata *mdata, */ int fwu_get_mdata(struct fwu_mdata *mdata);
+/** + * fwu_mdata_copies_allocate() - Allocate memory for metadata + * + * Allocate memory for storing both the copies of the FWU metadata. The + * copies are then used as a cache for storing FWU metadata contents. + * + * Return: 0 if OK, -ve on error + */ +int fwu_mdata_copies_allocate(void); + +/** + * fwu_get_mdata_size() - Get the FWU metadata size + * + * Get the size of the FWU metadata from the structure. This is later used + * to allocate memory for the structure. + * + * Return: 0 if OK, -ve on error + */ +int fwu_get_mdata_size(uint32_t *mdata_size); + /** * fwu_get_active_index() - Get active_index from the FWU metadata * @active_idxp: active_index value to be read @@ -202,6 +222,18 @@ int fwu_get_dfu_alt_num(u8 image_index, u8 *alt_num); */ int fwu_revert_boot_index(void);
+/** + * fwu_bank_state_update() - Check and update the bank_state of the metadata + * @update_index: Bank for which the bank_state needs to be updated + * + * Check that all the images for the given bank have been accepted, and if + * they are, set the status of the bank to Accepted in the bank_state field + * of the metadata. + * + * Return: 0 if OK, -ve on error + */ +int fwu_bank_state_update(uint update_index); + /** * fwu_accept_image() - Set the Acceptance bit for the image * @img_type_id: GUID of the image type for which the accepted bit is to be @@ -335,4 +367,25 @@ int fwu_gen_alt_info_from_mtd(char *buf, size_t len, struct mtd_info *mtd); */ int fwu_mtd_get_alt_num(efi_guid_t *image_guid, u8 *alt_num, const char *mtd_dev);
+/** + * fwu_get_banks_images() - Get the number of banks and images from the metadata + * @nbanks: Number of banks + * @nimages: Number of images per bank + * + * Get the values of number of banks and number of images per bank from the + * metadata. + * + * Return: 0 if OK, -ve on error + */ +int fwu_get_banks_images(u8 *nbanks, u16 *nimages); + +/** + * fwu_get_dev() - Return the FWU metadata device + * + * Return the pointer to the FWU metadata device. + * + * Return: Pointer to the FWU metadata dev + */ +__maybe_unused struct udevice *fwu_get_dev(void); + #endif /* _FWU_H_ */ diff --git a/lib/fwu_updates/fwu.c b/lib/fwu_updates/fwu.c index 2da19c9003..587ca779d3 100644 --- a/lib/fwu_updates/fwu.c +++ b/lib/fwu_updates/fwu.c @@ -240,6 +240,114 @@ static inline int mdata_crc_check(struct fwu_mdata *mdata) return calc_crc32 == mdata->crc32 ? 0 : -EINVAL; }
+/** + * fwu_mdata_copies_allocate() - Allocate memory for metadata + * + * Allocate memory for storing both the copies of the FWU metadata. The + * copies are then used as a cache for storing FWU metadata contents. + * + * Return: 0 if OK, -ve on error + */ +int fwu_mdata_copies_allocate(void) +{ + int err; + uint32_t mdata_size; + + if (g_mdata) + return 0; + + err = fwu_get_mdata_size(&mdata_size); + if (err) + return err; + + /* + * Now allocate the total memory that would be needed for both + * the copies. + */ + g_mdata = calloc(2, mdata_size); + if (!g_mdata) { + log_err("Unable to allocate space for FWU metadata\n"); + return -ENOMEM; + } + + return 0; +} + +/** + * fwu_get_mdata_size() - Get the FWU metadata size + * + * Get the size of the FWU metadata from the structure. This is later used + * to allocate memory for the structure. + * + * Return: 0 if OK, -ve on error + */ +int fwu_get_mdata_size(uint32_t *mdata_size) +{ + int err = 0; + struct fwu_mdata mdata = { 0 }; + + if (g_mdata && !mdata_crc_check(g_mdata)) { + *mdata_size = g_mdata->metadata_size; + return 0; + } + + err = fwu_read_mdata(g_dev, &mdata, 1, sizeof(struct fwu_mdata)); + if (err) { + log_err("FWU metadata read failed\n"); + return err; + } + + if (mdata.version != 0x2) { + log_err("FWU metadata version %u. Expected value of 2\n", + mdata.version); + return -EINVAL; + } + + *mdata_size = mdata.metadata_size; + if (!*mdata_size) + return -EINVAL; + + return 0; +} + +/** + * fwu_get_dev() - Return the FWU metadata device + * + * Return the pointer to the FWU metadata device. + * + * Return: Pointer to the FWU metadata dev + */ +__maybe_unused struct udevice *fwu_get_dev(void) +{ + return g_dev; +} + +/** + * fwu_get_banks_images() - Get the number of banks and images from the metadata + * @nbanks: Number of banks + * @nimages: Number of images per bank + * + * Get the values of number of banks and number of images per bank from the + * metadata. + * + * Return: 0 if OK, -ve on error + */ +int fwu_get_banks_images(u8 *nbanks, u16 *nimages) +{ + int ret; + + if (mdata_crc_check(g_mdata)) { + ret = fwu_get_mdata(NULL); + if (ret) + return ret; + } + + *nbanks = fwu_get_fw_desc(g_mdata)->num_banks; + *nimages = fwu_get_fw_desc(g_mdata)->num_images; + + return 0; +} + /** * fwu_get_mdata() - Read, verify and return the FWU metadata * @mdata: Output FWU metadata read or NULL @@ -564,6 +672,42 @@ out: return ret; }
+/** + * fwu_bank_state_update() - Check and update the bank_state of the metadata + * @update_index: Bank for which the bank_state needs to be updated + * + * Check that all the images for the given bank have been accepted, and if + * they are, set the status of the bank to Accepted in the bank_state field + * of the metadata. + * + * Return: 0 if OK, -ve on error + */ +int fwu_bank_state_update(uint update_index) +{ + int ret = 0, i; + u16 num_images; + struct fwu_mdata *mdata = g_mdata; + struct fwu_image_bank_info *img_bank_info; + + if (!mdata) + return -EINVAL; + + num_images = fwu_get_fw_desc(mdata)->num_images; + for (i = 0; i < num_images; i++) { + img_bank_info = fwu_img_bank_info_offset(g_mdata, i, + update_index); + if (!(img_bank_info->accepted & FWU_IMAGE_ACCEPTED)) + return 0; + } + + mdata->bank_state[update_index] = FWU_BANK_ACCEPTED; + ret = fwu_sync_mdata(mdata, BOTH_PARTS); + if (ret) + log_err("Unable to set bank_state for bank %u\n", update_index); + + return ret; +} + /** * fwu_accept_image() - Set the Acceptance bit for the image * @img_type_id: GUID of the image type for which the accepted bit is to be
The FWU metadata access driver for MTD partitioned devices currently uses a statically allocated array for storing the updatable image information. This array depends on the number of banks and images per bank. With migration of the FWU metadata to version 2, these parameters are now obtained at runtime from the metadata.
Make changes to the FWU metadata access driver for MTD devices to allocate memory for the image information dynamically in the driver's probe function, after having obtained the number of banks and images per bank by reading the metadata. Move the image information as part of the driver's private structure, instead of using a global variable.
drivers/fwu-mdata/raw_mtd.c | 71 ++++++++++++++++++++++++------------- include/fwu.h | 9 +++++ 2 files changed, 55 insertions(+), 25 deletions(-)
diff --git a/drivers/fwu-mdata/raw_mtd.c b/drivers/fwu-mdata/raw_mtd.c index 9f3f1dc213..da36094644 100644 --- a/drivers/fwu-mdata/raw_mtd.c +++ b/drivers/fwu-mdata/raw_mtd.c @@ -12,22 +12,11 @@ #include <linux/errno.h> #include <linux/types.h>
-/* Internal helper structure to move data around */ -struct fwu_mdata_mtd_priv { - struct mtd_info *mtd; - char pri_label[50]; - char sec_label[50]; - u32 pri_offset; - u32 sec_offset; -}; - enum fwu_mtd_op { FWU_MTD_READ, FWU_MTD_WRITE, };
-extern struct fwu_mtd_image_info fwu_mtd_images[]; - static bool mtd_is_aligned_with_block_size(struct mtd_info *mtd, u64 size) { return !do_div(size, mtd->erasesize); @@ -134,7 +123,7 @@ static int flash_partition_offset(struct udevice *dev, const char *part_name, fd return (int)size; }
-static int fwu_mdata_mtd_of_to_plat(struct udevice *dev) +static int get_fwu_mdata_dev(struct udevice *dev) { struct fwu_mdata_mtd_priv *mtd_priv = dev_get_priv(dev); const fdt32_t *phandle_p = NULL; @@ -144,8 +133,6 @@ static int fwu_mdata_mtd_of_to_plat(struct udevice *dev) fdt_addr_t offset; int ret, size; u32 phandle; - ofnode bank; - int off_img;
/* Find the FWU mdata storage device */ phandle_p = ofnode_get_property(dev_ofnode(dev), @@ -199,8 +186,28 @@ static int fwu_mdata_mtd_of_to_plat(struct udevice *dev) return ret; mtd_priv->sec_offset = offset;
- off_img = 0; + return 0; +} + +static int fwu_mtd_image_info_populate(struct udevice *dev, u8 nbanks, + u16 nimages) +{ + struct fwu_mtd_image_info *mtd_images; + struct fwu_mdata_mtd_priv *mtd_priv = dev_get_priv(dev); + struct udevice *mtd_dev = mtd_priv->mtd->dev; + fdt_addr_t offset; + ofnode bank; + int off_img; + u32 total_images;
+ total_images = nbanks * nimages; + mtd_priv->fwu_mtd_images = malloc(sizeof(struct fwu_mtd_image_info) * + total_images); + if (!mtd_priv->fwu_mtd_images) + return -ENOMEM; + + off_img = 0; + mtd_images = mtd_priv->fwu_mtd_images; ofnode_for_each_subnode(bank, dev_ofnode(dev)) { int bank_num, bank_offset, bank_size; const char *bank_name; @@ -219,8 +226,7 @@ static int fwu_mdata_mtd_of_to_plat(struct udevice *dev) int image_num, image_offset, image_size; const char *uuid;
- if (off_img == CONFIG_FWU_NUM_BANKS * - CONFIG_FWU_NUM_IMAGES_PER_BANK) { + if (off_img == total_images) { log_err("DT provides more images than configured!\n"); break; } @@ -230,11 +236,11 @@ static int fwu_mdata_mtd_of_to_plat(struct udevice *dev) ofnode_read_u32(image, "offset", &image_offset); ofnode_read_u32(image, "size", &image_size);
- fwu_mtd_images[off_img].start = bank_offset + image_offset; - fwu_mtd_images[off_img].size = image_size; - fwu_mtd_images[off_img].bank_num = bank_num; - fwu_mtd_images[off_img].image_num = image_num; - strcpy(fwu_mtd_images[off_img].uuidbuf, uuid); + mtd_images[off_img].start = bank_offset + image_offset; + mtd_images[off_img].size = image_size; + mtd_images[off_img].bank_num = bank_num; + mtd_images[off_img].image_num = image_num; + strcpy(mtd_images[off_img].uuidbuf, uuid); log_debug("\tImage%d: %s @0x%x\n\n", image_num, uuid, bank_offset + image_offset); off_img++; @@ -246,8 +252,24 @@ static int fwu_mdata_mtd_of_to_plat(struct udevice *dev)
static int fwu_mdata_mtd_probe(struct udevice *dev) { - /* Ensure the metadata can be read. */ - return fwu_get_mdata(NULL); + u8 nbanks; + u16 nimages; + int ret; + + ret = get_fwu_mdata_dev(dev); + if (ret) + return ret; + + /* Read the metadata to get number of banks and images */ + ret = fwu_get_banks_images(&nbanks, &nimages); + if (ret) + return ret; + + ret = fwu_mtd_image_info_populate(dev, nbanks, nimages); + if (ret) + return ret; + + return 0; }
static struct fwu_mdata_ops fwu_mtd_ops = { @@ -266,6 +288,5 @@ U_BOOT_DRIVER(fwu_mdata_mtd) = { .of_match = fwu_mdata_ids, .ops = &fwu_mtd_ops, .probe = fwu_mdata_mtd_probe, - .of_to_plat = fwu_mdata_mtd_of_to_plat, .priv_auto = sizeof(struct fwu_mdata_mtd_priv), }; diff --git a/include/fwu.h b/include/fwu.h index ce8c98921a..109ceb2610 100644 --- a/include/fwu.h +++ b/include/fwu.h @@ -27,6 +27,15 @@ struct fwu_mtd_image_info { char uuidbuf[UUID_STR_LEN + 1]; };
+struct fwu_mdata_mtd_priv { + struct mtd_info *mtd; + char pri_label[50]; + char sec_label[50]; + u32 pri_offset; + u32 sec_offset; + struct fwu_mtd_image_info *fwu_mtd_images; +}; + struct fwu_mdata_ops { /** * read_mdata() - Populate the asked FWU metadata copy
With migration of the FWU metadata access code to version 2, the size of the metadata is obtained at runtime. Allocate memory for both the metadata copies from the driver's probe function.
drivers/fwu-mdata/gpt_blk.c | 4 ++++ drivers/fwu-mdata/raw_mtd.c | 4 ++++ 2 files changed, 8 insertions(+)
diff --git a/drivers/fwu-mdata/gpt_blk.c b/drivers/fwu-mdata/gpt_blk.c index 97eac3611f..c2cb7ef7c3 100644 --- a/drivers/fwu-mdata/gpt_blk.c +++ b/drivers/fwu-mdata/gpt_blk.c @@ -159,6 +159,10 @@ static int fwu_mdata_gpt_blk_probe(struct udevice *dev)
priv->blk_dev = mdata_dev;
+ ret = fwu_mdata_copies_allocate(); + if (ret) + return ret; + return 0; }
diff --git a/drivers/fwu-mdata/raw_mtd.c b/drivers/fwu-mdata/raw_mtd.c index da36094644..d91518bf0a 100644 --- a/drivers/fwu-mdata/raw_mtd.c +++ b/drivers/fwu-mdata/raw_mtd.c @@ -260,6 +260,10 @@ static int fwu_mdata_mtd_probe(struct udevice *dev) if (ret) return ret;
+ ret = fwu_mdata_copies_allocate(); + if (ret) + return ret; + /* Read the metadata to get number of banks and images */ ret = fwu_get_banks_images(&nbanks, &nimages); if (ret)
The version 2 of the FWU metadata has a field in the top level structure, called bank_state. This is used to keep the state a given bank is in, either of valid(for trial state), invalid, or accepted.
Update this field when putting the platform in Trial State, in addition to starting the TrialStateCtr variable by calling the fwu_trial_state_start() function.
include/fwu.h | 12 +++++--- lib/efi_loader/efi_capsule.c | 2 +- lib/fwu_updates/fwu.c | 54 ++++++++++++++++++++++++++++++------ 3 files changed, 54 insertions(+), 14 deletions(-)
diff --git a/include/fwu.h b/include/fwu.h index 109ceb2610..1c6a5fcda9 100644 --- a/include/fwu.h +++ b/include/fwu.h @@ -342,15 +342,19 @@ u8 fwu_update_checks_pass(void); u8 fwu_empty_capsule_checks_pass(void);
/** - * fwu_trial_state_ctr_start() - Start the Trial State counter + * fwu_trial_state_start() - Put the platform in Trial State + * @update_index: Bank number to which images have been updated * - * Start the counter to identify the platform booting in the - * Trial State. The counter is implemented as an EFI variable. + * Put the platform in Trial State by starting the counter to + * identify the platform booting in the Trial State. The + * counter is implemented as an EFI variable. Secondly, set + * the bank_state in the metadata for the updated bank to Valid + * state. * * Return: 0 if OK, -ve on error * */ -int fwu_trial_state_ctr_start(void); +int fwu_trial_state_start(uint update_index);
/** * fwu_gen_alt_info_from_mtd() - Parse dfu_alt_info from metadata in mtd diff --git a/lib/efi_loader/efi_capsule.c b/lib/efi_loader/efi_capsule.c index de0d49ebeb..0e6a38b441 100644 --- a/lib/efi_loader/efi_capsule.c +++ b/lib/efi_loader/efi_capsule.c @@ -522,7 +522,7 @@ static __maybe_unused efi_status_t fwu_post_update_process(bool fw_accept_os) } else { log_debug("Successfully updated the active_index\n"); if (fw_accept_os) { - status = fwu_trial_state_ctr_start(); + status = fwu_trial_state_start(update_index); if (status < 0) ret = EFI_DEVICE_ERROR; } diff --git a/lib/fwu_updates/fwu.c b/lib/fwu_updates/fwu.c index 587ca779d3..a58c42bee2 100644 --- a/lib/fwu_updates/fwu.c +++ b/lib/fwu_updates/fwu.c @@ -672,6 +672,36 @@ out: return ret; }
+static int fwu_trial_state_ctr_start(void) +{ + int ret; + u16 trial_state_ctr; + + printf("%s: starting the TrialStateCtr\n", __func__); + trial_state_ctr = 0; + ret = trial_counter_update(&trial_state_ctr); + if (ret) + log_err("Unable to initialise TrialStateCtr\n"); + + return ret; +} + +static int fwu_set_bank_state_trial(uint update_index) +{ + int ret; + struct fwu_mdata *mdata = g_mdata; + + mdata->bank_state[update_index] = FWU_BANK_VALID; + + ret = fwu_sync_mdata(mdata, BOTH_PARTS); + if (ret) { + log_err("Unable to set bank_state for %d bank\n", update_index); + return ret; + } + + return 0; +} + /** * fwu_bank_state_update() - Check and update the bank_state of the metadata * @update_index: Bank for which the bank_state needs to be updated @@ -830,25 +860,31 @@ u8 fwu_empty_capsule_checks_pass(void) }
/** - * fwu_trial_state_ctr_start() - Start the Trial State counter + * fwu_trial_state_start() - Put the platform in Trial State + * @update_index: Bank number to which images have been updated * - * Start the counter to identify the platform booting in the - * Trial State. The counter is implemented as an EFI variable. + * Put the platform in Trial State by starting the counter to + * identify the platform booting in the Trial State. The + * counter is implemented as an EFI variable. Secondly, set + * the bank_state in the metadata for the updated bank to Valid + * state. * * Return: 0 if OK, -ve on error * */ -int fwu_trial_state_ctr_start(void) +int fwu_trial_state_start(uint update_index) { int ret; - u16 trial_state_ctr;
- trial_state_ctr = 0; - ret = trial_counter_update(&trial_state_ctr); + ret = fwu_trial_state_ctr_start(); if (ret) - log_err("Unable to initialise TrialStateCtr\n"); + return ret;
- return ret; + ret = fwu_set_bank_state_trial(update_index); + if (ret) + return ret; + + return 0; }
The version 2 of the FWU metadata maintains a bank_state field per bank, which keeps an aggregate status of the bank. A bank can either be in a valid, invalid, or accepted state.
Update the bank_state field of the metadata once the update has gone through successfully(when skipping Trial State), or once the images in the bank have been accepted.
lib/efi_loader/efi_capsule.c | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/lib/efi_loader/efi_capsule.c b/lib/efi_loader/efi_capsule.c index 0e6a38b441..422bb11162 100644 --- a/lib/efi_loader/efi_capsule.c +++ b/lib/efi_loader/efi_capsule.c @@ -480,6 +480,12 @@ static __maybe_unused efi_status_t fwu_empty_capsule_process( if (ret != EFI_SUCCESS) log_err("Unable to set the Accept bit for the image %pUs\n", image_guid); + + status = fwu_bank_state_update(active_idx); + ret = fwu_to_efi_error(status); + if (ret != EFI_SUCCESS) + log_err("Unable to update the bank_state for bank %u\n", + active_idx); }
return ret; @@ -525,6 +531,10 @@ static __maybe_unused efi_status_t fwu_post_update_process(bool fw_accept_os) status = fwu_trial_state_start(update_index); if (status < 0) ret = EFI_DEVICE_ERROR; + } else { + status = fwu_bank_state_update(update_index); + if (status < 0) + ret = EFI_DEVICE_ERROR; } }
Make changes to the functions used for generating the DFU's alt variable so that they are aligned with changes to the metadata version 2.
These changes include getting the number of banks and images per bank at runtime from the metadata, as well as accessing the updatable image information from the FWU MTD driver's private structure.
lib/fwu_updates/fwu_mtd.c | 81 +++++++++++++++++++++++++++++---------- 1 file changed, 61 insertions(+), 20 deletions(-)
diff --git a/lib/fwu_updates/fwu_mtd.c b/lib/fwu_updates/fwu_mtd.c index 69cd3d7001..50ff0d692d 100644 --- a/lib/fwu_updates/fwu_mtd.c +++ b/lib/fwu_updates/fwu_mtd.c @@ -15,16 +15,51 @@
#include <dm/ofnode.h>
-struct fwu_mtd_image_info -fwu_mtd_images[CONFIG_FWU_NUM_BANKS * CONFIG_FWU_NUM_IMAGES_PER_BANK]; +static struct fwu_mdata *mdata; + +static int read_mdata(void) +{ + int ret = 0; + u32 mdata_size; + + ret = fwu_get_mdata_size(&mdata_size); + if (ret) + return ret; + + mdata = malloc(mdata_size); + if (!mdata) + return -ENOMEM; + + ret = fwu_get_mdata(mdata); + if (ret < 0) { + log_err("Failed to get the FWU mdata\n"); + free(mdata); + mdata = NULL; + } + + return ret; +}
static struct fwu_mtd_image_info *mtd_img_by_uuid(const char *uuidbuf) { - int num_images = ARRAY_SIZE(fwu_mtd_images); + u8 nbanks; + u16 nimages; + int num_images, ret; + struct fwu_mdata_mtd_priv *mtd_priv = dev_get_priv(fwu_get_dev()); + struct fwu_mtd_image_info *image_info = mtd_priv->fwu_mtd_images; + + if (!image_info) + return NULL; + + ret = fwu_get_banks_images(&nbanks, &nimages); + if (ret) + return NULL; + + num_images = nbanks * nimages;
for (int i = 0; i < num_images; i++) - if (!strcmp(uuidbuf, fwu_mtd_images[i].uuidbuf)) - return &fwu_mtd_images[i]; + if (!strcmp(uuidbuf, image_info[i].uuidbuf)) + return &image_info[i];
return NULL; } @@ -107,8 +142,9 @@ __weak int fwu_plat_get_alt_num(struct udevice *dev, efi_guid_t *image_id, return fwu_mtd_get_alt_num(image_id, alt_num, "nor1"); }
-static int gen_image_alt_info(char *buf, size_t len, int sidx, - struct fwu_image_entry *img, struct mtd_info *mtd) +static int gen_image_alt_info(char *buf, size_t len, int idx, + struct fwu_image_entry *img, + struct mtd_info *mtd, uint8_t num_banks) { char *p = buf, *end = buf + len; int i; @@ -123,15 +159,15 @@ static int gen_image_alt_info(char *buf, size_t len, int sidx, * List the image banks in the FWU mdata and search the corresponding * partition based on partition's uuid. */ - for (i = 0; i < CONFIG_FWU_NUM_BANKS; i++) { + for (i = 0; i < num_banks; i++) { struct fwu_mtd_image_info *mtd_img_info; struct fwu_image_bank_info *bank; char uuidbuf[UUID_STR_LEN + 1]; u32 offset, size;
/* Query a partition by image UUID */ - bank = &img->img_bank_info[i]; - uuid_bin_to_str(bank->image_uuid.b, uuidbuf, UUID_STR_FORMAT_STD); + bank = fwu_img_bank_info_offset(mdata, idx, i); + uuid_bin_to_str(bank->image_guid.b, uuidbuf, UUID_STR_FORMAT_STD);
mtd_img_info = mtd_img_by_uuid(uuidbuf); if (!mtd_img_info) { @@ -150,7 +186,7 @@ static int gen_image_alt_info(char *buf, size_t len, int sidx, } }
- if (i == CONFIG_FWU_NUM_BANKS) + if (i == num_banks) return 0;
return -ENOENT; @@ -158,24 +194,29 @@ static int gen_image_alt_info(char *buf, size_t len, int sidx,
int fwu_gen_alt_info_from_mtd(char *buf, size_t len, struct mtd_info *mtd) { - struct fwu_mdata mdata; + u8 num_banks; + u16 num_images; int i, l, ret; + struct fwu_image_entry *img_entry;
- ret = fwu_get_mdata(&mdata); - if (ret < 0) { - log_err("Failed to get the FWU mdata.\n"); - return ret; + if (!mdata) { + ret = read_mdata(); + if (ret) + return ret; }
- for (i = 0; i < CONFIG_FWU_NUM_IMAGES_PER_BANK; i++) { - ret = gen_image_alt_info(buf, len, i * CONFIG_FWU_NUM_BANKS, - &mdata.img_entry[i], mtd); + num_banks = fwu_get_fw_desc(mdata)->num_banks; + num_images = fwu_get_fw_desc(mdata)->num_images; + for (i = 0; i < num_images; i++) { + img_entry = fwu_img_entry_offset(mdata, i); + ret = gen_image_alt_info(buf, len, i, + img_entry, mtd, num_banks); if (ret) break;
l = strlen(buf); /* Replace the last ';' with '&' if there is another image. */ - if (i != CONFIG_FWU_NUM_IMAGES_PER_BANK - 1 && l) { + if (i != num_images - 1 && l) { buf[l] = '&'; buf++; }
The FWU metadata is being read for populating the firmware image's version information. The sandbox platform does not have the FWU metadata on any of it's storage devices. Skip attempting to read the FWU metadata on the sandbox platform.
lib/efi_loader/efi_firmware.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/lib/efi_loader/efi_firmware.c b/lib/efi_loader/efi_firmware.c index ba5aba098c..c742e23268 100644 --- a/lib/efi_loader/efi_firmware.c +++ b/lib/efi_loader/efi_firmware.c @@ -223,7 +223,8 @@ void efi_firmware_fill_version_info(struct efi_firmware_image_descriptor *image_ /* get the fw_version */ efi_create_indexed_name(varname, sizeof(varname), "FmpState", fw_array->image_index); - if (IS_ENABLED(CONFIG_FWU_MULTI_BANK_UPDATE)) { + if (!IS_ENABLED(CONFIG_SANDBOX) && + IS_ENABLED(CONFIG_FWU_MULTI_BANK_UPDATE)) { ret = fwu_get_active_index(&active_index); if (ret) return; @@ -391,7 +392,8 @@ efi_status_t efi_firmware_set_fmp_state_var(struct fmp_state *state, u8 image_in efi_create_indexed_name(varname, sizeof(varname), "FmpState", image_index);
- if (IS_ENABLED(CONFIG_FWU_MULTI_BANK_UPDATE)) { + if (!IS_ENABLED(CONFIG_SANDBOX) && + IS_ENABLED(CONFIG_FWU_MULTI_BANK_UPDATE)) { ret = fwu_plat_get_update_index(&update_bank); if (ret) return EFI_INVALID_PARAMETER;
With the migration of the FWU metadata to version 2, the number of banks are now obtained at runtime, instead of the config symbols. Make use of the API to get the number of banks in the versioning functions.
lib/efi_loader/efi_firmware.c | 14 ++++++++++---- 1 file changed, 10 insertions(+), 4 deletions(-)
diff --git a/lib/efi_loader/efi_firmware.c b/lib/efi_loader/efi_firmware.c index c742e23268..26d2916ee1 100644 --- a/lib/efi_loader/efi_firmware.c +++ b/lib/efi_loader/efi_firmware.c @@ -207,7 +207,8 @@ void efi_firmware_fill_version_info(struct efi_firmware_image_descriptor *image_ u16 varname[13]; /* u"FmpStateXXXX" */ efi_status_t ret; efi_uintn_t size, expected_size; - uint num_banks = 1; + u8 num_banks = 1; + u16 __maybe_unused num_images; uint active_index = 0; struct fmp_state *var_state;
@@ -229,7 +230,9 @@ void efi_firmware_fill_version_info(struct efi_firmware_image_descriptor *image_ if (ret) return;
- num_banks = CONFIG_FWU_NUM_BANKS; + ret = fwu_get_banks_images(&num_banks, &num_images); + if (ret) + return; }
size = num_banks * sizeof(*var_state); @@ -379,7 +382,8 @@ efi_status_t efi_firmware_set_fmp_state_var(struct fmp_state *state, u8 image_in { u16 varname[13]; /* u"FmpStateXXXX" */ efi_status_t ret; - uint num_banks = 1; + u8 num_banks = 1; + u16 __maybe_unused num_images; uint update_bank = 0; efi_uintn_t size; efi_guid_t *image_type_id; @@ -398,7 +402,9 @@ efi_status_t efi_firmware_set_fmp_state_var(struct fmp_state *state, u8 image_in if (ret) return EFI_INVALID_PARAMETER;
- num_banks = CONFIG_FWU_NUM_BANKS; + ret = fwu_get_banks_images(&num_banks, &num_images); + if (ret) + return EFI_INVALID_PARAMETER; }
Make changes to the fwu_mdata_read command to have it align with the metadata version 2.
cmd/fwu_mdata.c | 45 +++++++++++++++++++++++++++++++++++---------- 1 file changed, 35 insertions(+), 10 deletions(-)
diff --git a/cmd/fwu_mdata.c b/cmd/fwu_mdata.c index 5ecda455df..6d5ed7a187 100644 --- a/cmd/fwu_mdata.c +++ b/cmd/fwu_mdata.c @@ -16,6 +16,8 @@ static void print_mdata(struct fwu_mdata *mdata) { int i, j; + uint8_t num_banks; + uint16_t num_images; struct fwu_image_entry *img_entry; struct fwu_image_bank_info *img_info;
@@ -25,15 +27,22 @@ static void print_mdata(struct fwu_mdata *mdata) printf("active_index: %#x\n", mdata->active_index); printf("previous_active_index: %#x\n", mdata->previous_active_index);
+ num_banks = fwu_get_fw_desc(mdata)->num_banks; + num_images = fwu_get_fw_desc(mdata)->num_images; + + for (i = 0; i < 4; i++) + printf("bank_state[%d]: %#x\n", i, mdata->bank_state[i]); + printf("\tImage Info\n"); - for (i = 0; i < CONFIG_FWU_NUM_IMAGES_PER_BANK; i++) { - img_entry = &mdata->img_entry[i]; + + for (i = 0; i < num_images; i++) { + img_entry = fwu_img_entry_offset(mdata, i); printf("\nImage Type Guid: %pUL\n", - &img_entry->image_type_uuid); - printf("Location Guid: %pUL\n", &img_entry->location_uuid); - for (j = 0; j < CONFIG_FWU_NUM_BANKS; j++) { - img_info = &img_entry->img_bank_info[j]; - printf("Image Guid: %pUL\n", &img_info->image_uuid); + &img_entry->image_type_guid); + printf("Location Guid: %pUL\n", &img_entry->location_guid); + for (j = 0; j < num_banks; j++) { + img_info = fwu_img_bank_info_offset(mdata, i, j); + printf("Image Guid: %pUL\n", &img_info->image_guid); printf("Image Acceptance: %s\n", img_info->accepted == 0x1 ? "yes" : "no"); } @@ -43,19 +52,35 @@ static void print_mdata(struct fwu_mdata *mdata) int do_fwu_mdata_read(struct cmd_tbl *cmdtp, int flag, int argc, char * const argv[]) { + uint32_t mdata_size; + struct fwu_mdata *mdata = NULL; int ret = CMD_RET_SUCCESS, res; - struct fwu_mdata mdata;
- res = fwu_get_mdata(&mdata); + res = fwu_get_mdata_size(&mdata_size); + if (res) { + log_err("Unable to get FWU metadata size\n"); + ret = CMD_RET_FAILURE; + goto out; + } + + mdata = malloc(mdata_size); + if (!mdata) { + log_err("Unable to allocate memory for FWU metadata\n"); + ret = CMD_RET_FAILURE; + goto out; + } + + res = fwu_get_mdata(mdata); if (res < 0) { log_err("Unable to get valid FWU metadata\n"); ret = CMD_RET_FAILURE; goto out; }
- print_mdata(&mdata); + print_mdata(mdata);
out: + free(mdata); return ret; }
With the FWU metadata support having been migrated to version 2, make corresponding changes to the test for accessing the FWU metadata.
test/dm/fwu_mdata.c | 56 ++++++++------- test/dm/fwu_mdata_disk_image.h | 124 ++++++++++++++------------------- 2 files changed, 83 insertions(+), 97 deletions(-)
diff --git a/test/dm/fwu_mdata.c b/test/dm/fwu_mdata.c index 52018f610f..cbeceaee93 100644 --- a/test/dm/fwu_mdata.c +++ b/test/dm/fwu_mdata.c @@ -88,10 +88,15 @@ static int write_mmc_blk_device(struct unit_test_state *uts) return 0; }
-static int dm_test_fwu_mdata_read(struct unit_test_state *uts) +static int fwu_mdata_access_setup(struct unit_test_state *uts, + struct fwu_mdata **mdata) { + u32 mdata_size; struct udevice *dev; - struct fwu_mdata mdata = { 0 }; + + ut_assertok(setup_blk_device(uts)); + ut_assertok(populate_mmc_disk_image(uts)); + ut_assertok(write_mmc_blk_device(uts));
/* * Trigger lib/fwu_updates/fwu.c fwu_boottime_checks() @@ -100,13 +105,24 @@ static int dm_test_fwu_mdata_read(struct unit_test_state *uts) event_notify_null(EVT_MAIN_LOOP);
ut_assertok(uclass_first_device_err(UCLASS_FWU_MDATA, &dev)); - ut_assertok(setup_blk_device(uts)); - ut_assertok(populate_mmc_disk_image(uts)); - ut_assertok(write_mmc_blk_device(uts));
- ut_assertok(fwu_get_mdata(&mdata)); + ut_assertok(fwu_get_mdata_size(&mdata_size));
- ut_asserteq(mdata.version, 0x1); + *mdata = malloc(mdata_size); + ut_assertnonnull(*mdata); + + return 0; +} + +static int dm_test_fwu_mdata_read(struct unit_test_state *uts) +{ + struct fwu_mdata *mdata = NULL; + + fwu_mdata_access_setup(uts, &mdata); + + ut_assertok(fwu_get_mdata(mdata)); + + ut_asserteq(mdata->version, 0x2);
return 0; } @@ -114,29 +130,21 @@ DM_TEST(dm_test_fwu_mdata_read, UT_TESTF_SCAN_FDT);
static int dm_test_fwu_mdata_write(struct unit_test_state *uts) { + u8 num_banks; u32 active_idx; - struct udevice *dev; - struct fwu_mdata mdata = { 0 }; - - /* - * Trigger lib/fwu_updates/fwu.c fwu_boottime_checks() - * to populate g_dev global pointer in that library. - */ - event_notify_null(EVT_MAIN_LOOP); + struct fwu_mdata *mdata = NULL;
- ut_assertok(setup_blk_device(uts)); - ut_assertok(populate_mmc_disk_image(uts)); - ut_assertok(write_mmc_blk_device(uts)); - - ut_assertok(uclass_first_device_err(UCLASS_FWU_MDATA, &dev)); + fwu_mdata_access_setup(uts, &mdata);
- ut_assertok(fwu_get_mdata(&mdata)); + ut_assertok(fwu_get_mdata(mdata)); + num_banks = fwu_get_fw_desc(mdata)->num_banks; + ut_asserteq(2, num_banks);
- active_idx = (mdata.active_index + 1) % CONFIG_FWU_NUM_BANKS; + active_idx = (mdata->active_index + 1) % num_banks; ut_assertok(fwu_set_active_index(active_idx));
- ut_assertok(fwu_get_mdata(&mdata)); - ut_asserteq(mdata.active_index, active_idx); + ut_assertok(fwu_get_mdata(mdata)); + ut_asserteq(mdata->active_index, active_idx);
return 0; } diff --git a/test/dm/fwu_mdata_disk_image.h b/test/dm/fwu_mdata_disk_image.h index b9803417c8..b15b06b9de 100644 --- a/test/dm/fwu_mdata_disk_image.h +++ b/test/dm/fwu_mdata_disk_image.h @@ -6,107 +6,85 @@ */
#define FWU_MDATA_DISK_IMG { 0x00010000, { \ - {0x000001c0, "\x02\x00\xee\x02\x02\x00\x01\x00"}, /* ........ */ \ + {0x000001c0, "\x02\x00\xee\xff\xff\xff\x01\x00"}, /* ........ */ \ {0x000001c8, "\x00\x00\x7f\x00\x00\x00\x00\x00"}, /* ........ */ \ {0x000001f8, "\x00\x00\x00\x00\x00\x00\x55\xaa"}, /* ......U. */ \ {0x00000200, "\x45\x46\x49\x20\x50\x41\x52\x54"}, /* EFI PART */ \ {0x00000208, "\x00\x00\x01\x00\x5c\x00\x00\x00"}, /* ....... */ \ - {0x00000210, "\xa6\xf6\x92\x20\x00\x00\x00\x00"}, /* ... .... */ \ + {0x00000210, "\x52\x5f\x3a\xa1\x00\x00\x00\x00"}, /* R_:..... */ \ {0x00000218, "\x01\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \ {0x00000220, "\x7f\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \ {0x00000228, "\x22\x00\x00\x00\x00\x00\x00\x00"}, /* "....... */ \ {0x00000230, "\x5e\x00\x00\x00\x00\x00\x00\x00"}, /* ^....... */ \ - {0x00000238, "\xde\x99\xa2\x7e\x46\x34\xeb\x47"}, /* ...~F4.G */ \ - {0x00000240, "\x87\xf6\x4f\x75\xe8\xd5\x7d\xc7"}, /* ..Ou..}. */ \ + {0x00000238, "\xf5\xf3\x9d\xb9\x92\xdd\x48\x60"}, /* ......H` */ \ + {0x00000240, "\x9a\x04\xe5\x2b\x11\xcb\x42\x61"}, /* ...+..Ba */ \ {0x00000248, "\x02\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \ {0x00000250, "\x80\x00\x00\x00\x80\x00\x00\x00"}, /* ........ */ \ - {0x00000258, "\x2a\x64\x03\x83\x00\x00\x00\x00"}, /* .d...... */ \ + {0x00000258, "\xc4\x80\x68\xad\x00\x00\x00\x00"}, /* ..h..... */ \ {0x00000400, "\xa0\x84\x7a\x8a\x87\x83\xf6\x40"}, /* ..z....@ */ \ {0x00000408, "\xab\x41\xa8\xb9\xa5\xa6\x0d\x23"}, /* .A.....# */ \ - {0x00000410, "\x3d\x6c\xb9\xaa\x20\xb2\x18\x4c"}, /* =l.. ..L */ \ - {0x00000418, "\xbc\x87\x1c\x9f\xe0\x35\x9b\x73"}, /* .....5.s */ \ + {0x00000410, "\x02\xa0\xf1\x31\xc0\x4c\x42\xd1"}, /* ...1.LB. */ \ + {0x00000418, "\xbd\x0b\xa0\xa3\xd9\xe8\x4b\x64"}, /* ......Kd */ \ {0x00000420, "\x22\x00\x00\x00\x00\x00\x00\x00"}, /* "....... */ \ - {0x00000428, "\x31\x00\x00\x00\x00\x00\x00\x00"}, /* 1....... */ \ - {0x00000438, "\x55\x00\x6e\x00\x6b\x00\x6e\x00"}, /* U.n.k.n. */ \ - {0x00000440, "\x6f\x00\x77\x00\x6e\x00\x00\x00"}, /* o.w.n... */ \ + {0x00000428, "\x23\x00\x00\x00\x00\x00\x00\x00"}, /* #....... */ \ {0x00000480, "\xa0\x84\x7a\x8a\x87\x83\xf6\x40"}, /* ..z....@ */ \ {0x00000488, "\xab\x41\xa8\xb9\xa5\xa6\x0d\x23"}, /* .A.....# */ \ - {0x00000490, "\x57\x24\xf6\xe6\x0b\x6f\x66\x4e"}, /* W$...ofN */ \ - {0x00000498, "\xb3\xd5\x99\x50\xa5\xc6\x4e\xc1"}, /* ...P..N. */ \ - {0x000004a0, "\x32\x00\x00\x00\x00\x00\x00\x00"}, /* 2....... */ \ - {0x000004a8, "\x41\x00\x00\x00\x00\x00\x00\x00"}, /* A....... */ \ - {0x000004b8, "\x55\x00\x6e\x00\x6b\x00\x6e\x00"}, /* U.n.k.n. */ \ - {0x000004c0, "\x6f\x00\x77\x00\x6e\x00\x00\x00"}, /* o.w.n... */ \ - {0x00004400, "\x4e\xd5\x3f\x43\x01\x00\x00\x00"}, /* N.?C.... */ \ + {0x00000490, "\x55\x2e\xe8\x5c\x7f\x10\x4b\xe7"}, /* U....K. */ \ + {0x00000498, "\xb1\xb8\x3a\x84\xb7\x63\x1d\xcd"}, /* ..:..c.. */ \ + {0x000004a0, "\x24\x00\x00\x00\x00\x00\x00\x00"}, /* $....... */ \ + {0x000004a8, "\x25\x00\x00\x00\x00\x00\x00\x00"}, /* %....... */ \ + {0x00004400, "\x71\x30\xcf\xf7\x02\x00\x00\x00"}, /* q0...... */ \ {0x00004408, "\x00\x00\x00\x00\x01\x00\x00\x00"}, /* ........ */ \ - {0x00004410, "\x52\xcf\xd7\x09\x20\x07\x10\x47"}, /* R... ..G */ \ - {0x00004418, "\x91\xd1\x08\x46\x9b\x7f\xe9\xc8"}, /* ...F.... */ \ - {0x00004420, "\xeb\x2b\x27\x49\xd8\x8d\xdf\x46"}, /* .+'I...F */ \ - {0x00004428, "\x8d\x75\x35\x6c\x65\xef\xf4\x17"}, /* .u5le... */ \ - {0x00004430, "\x86\x7a\x05\x10\xf1\xda\x93\x4f"}, /* .z.....O */ \ - {0x00004438, "\xba\x7f\xb1\x95\xf7\xfa\x41\x70"}, /* ......Ap */ \ - {0x00004440, "\x01\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \ - {0x00004448, "\x3e\xed\x62\xdb\x37\x62\xb4\x4f"}, /* >.b.7b.O */ \ - {0x00004450, "\x80\xc4\x1b\x74\xd8\x46\xa8\xe7"}, /* ...t.F.. */ \ + {0x00004410, "\x78\x00\x00\x00\x20\x00\x00\x00"}, /* x... ... */ \ + {0x00004418, "\xfc\xfc\xff\xff\x00\x00\x00\x00"}, /* ........ */ \ + {0x00004420, "\x02\x00\x01\x00\x50\x00\x18\x00"}, /* ....P... */ \ + {0x00004428, "\x83\xdf\xd5\x19\xb0\x11\x7b\x45"}, /* ......{E */ \ + {0x00004430, "\xbe\x2c\x75\x59\xc1\x31\x42\xa5"}, /* .,uY.1B. */ \ + {0x00004438, "\x17\xc7\xa9\x08\x4a\xb0\x6b\x45"}, /* ....J.kE */ \ + {0x00004440, "\x8c\x82\x6f\x8e\x19\x39\xc5\x8b"}, /* ..o..9.. */ \ + {0x00004448, "\xcc\x28\x74\xd5\x9a\xbb\xe0\x42"}, /* .(t....B */ \ + {0x00004450, "\xaa\x36\x3f\x5a\x13\x20\x59\xc7"}, /* .6?Z. Y. */ \ {0x00004458, "\x01\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \ - {0x00004460, "\xf5\x21\x70\x5a\xf2\xfe\xb4\x48"}, /* .!pZ...H */ \ - {0x00004468, "\xaa\xba\x83\x2e\x77\x74\x18\xc0"}, /* ....wt.. */ \ - {0x00004470, "\xeb\x2b\x27\x49\xd8\x8d\xdf\x46"}, /* .+'I...F */ \ - {0x00004478, "\x8d\x75\x35\x6c\x65\xef\xf4\x17"}, /* .u5le... */ \ - {0x00004480, "\x3b\x0e\xd2\x0b\x9f\xab\x86\x49"}, /* ;......I */ \ - {0x00004488, "\xb7\x90\x8d\xf3\x9c\x9c\xa3\x82"}, /* ........ */ \ - {0x00004490, "\x01\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \ - {0x00004498, "\x6d\xe4\x25\x0e\x15\xb6\xd3\x4c"}, /* m.%....L */ \ - {0x000044a0, "\x94\xda\x51\x79\x8f\xb1\x9e\xb1"}, /* ..Qy.... */ \ - {0x000044a8, "\x01\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \ - {0x00006400, "\x4e\xd5\x3f\x43\x01\x00\x00\x00"}, /* N.?C.... */ \ - {0x00006408, "\x00\x00\x00\x00\x01\x00\x00\x00"}, /* ........ */ \ - {0x00006410, "\x52\xcf\xd7\x09\x20\x07\x10\x47"}, /* R... ..G */ \ - {0x00006418, "\x91\xd1\x08\x46\x9b\x7f\xe9\xc8"}, /* ...F.... */ \ - {0x00006420, "\xeb\x2b\x27\x49\xd8\x8d\xdf\x46"}, /* .+'I...F */ \ - {0x00006428, "\x8d\x75\x35\x6c\x65\xef\xf4\x17"}, /* .u5le... */ \ - {0x00006430, "\x86\x7a\x05\x10\xf1\xda\x93\x4f"}, /* .z.....O */ \ - {0x00006438, "\xba\x7f\xb1\x95\xf7\xfa\x41\x70"}, /* ......Ap */ \ - {0x00006440, "\x01\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \ - {0x00006448, "\x3e\xed\x62\xdb\x37\x62\xb4\x4f"}, /* >.b.7b.O */ \ - {0x00006450, "\x80\xc4\x1b\x74\xd8\x46\xa8\xe7"}, /* ...t.F.. */ \ - {0x00006458, "\x01\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \ - {0x00006460, "\xf5\x21\x70\x5a\xf2\xfe\xb4\x48"}, /* .!pZ...H */ \ - {0x00006468, "\xaa\xba\x83\x2e\x77\x74\x18\xc0"}, /* ....wt.. */ \ - {0x00006470, "\xeb\x2b\x27\x49\xd8\x8d\xdf\x46"}, /* .+'I...F */ \ - {0x00006478, "\x8d\x75\x35\x6c\x65\xef\xf4\x17"}, /* .u5le... */ \ - {0x00006480, "\x3b\x0e\xd2\x0b\x9f\xab\x86\x49"}, /* ;......I */ \ - {0x00006488, "\xb7\x90\x8d\xf3\x9c\x9c\xa3\x82"}, /* ........ */ \ - {0x00006490, "\x01\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \ - {0x00006498, "\x6d\xe4\x25\x0e\x15\xb6\xd3\x4c"}, /* m.%....L */ \ - {0x000064a0, "\x94\xda\x51\x79\x8f\xb1\x9e\xb1"}, /* ..Qy.... */ \ - {0x000064a8, "\x01\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \ + {0x00004460, "\x6d\x7d\xe3\x2b\x81\x82\x38\x49"}, /* m}.+..8I */ \ + {0x00004468, "\xbd\x7b\x9a\x5b\xbf\x80\x86\x9f"}, /* .{.[.... */ \ + {0x00004470, "\x01\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \ + {0x00004800, "\x71\x30\xcf\xf7\x02\x00\x00\x00"}, /* q0...... */ \ + {0x00004808, "\x00\x00\x00\x00\x01\x00\x00\x00"}, /* ........ */ \ + {0x00004810, "\x78\x00\x00\x00\x20\x00\x00\x00"}, /* x... ... */ \ + {0x00004818, "\xfc\xfc\xff\xff\x00\x00\x00\x00"}, /* ........ */ \ + {0x00004820, "\x02\x00\x01\x00\x50\x00\x18\x00"}, /* ....P... */ \ + {0x00004828, "\x83\xdf\xd5\x19\xb0\x11\x7b\x45"}, /* ......{E */ \ + {0x00004830, "\xbe\x2c\x75\x59\xc1\x31\x42\xa5"}, /* .,uY.1B. */ \ + {0x00004838, "\x17\xc7\xa9\x08\x4a\xb0\x6b\x45"}, /* ....J.kE */ \ + {0x00004840, "\x8c\x82\x6f\x8e\x19\x39\xc5\x8b"}, /* ..o..9.. */ \ + {0x00004848, "\xcc\x28\x74\xd5\x9a\xbb\xe0\x42"}, /* .(t....B */ \ + {0x00004850, "\xaa\x36\x3f\x5a\x13\x20\x59\xc7"}, /* .6?Z. Y. */ \ + {0x00004858, "\x01\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \ + {0x00004860, "\x6d\x7d\xe3\x2b\x81\x82\x38\x49"}, /* m}.+..8I */ \ + {0x00004868, "\xbd\x7b\x9a\x5b\xbf\x80\x86\x9f"}, /* .{.[.... */ \ + {0x00004870, "\x01\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \ {0x0000be00, "\xa0\x84\x7a\x8a\x87\x83\xf6\x40"}, /* ..z....@ */ \ {0x0000be08, "\xab\x41\xa8\xb9\xa5\xa6\x0d\x23"}, /* .A.....# */ \ - {0x0000be10, "\x3d\x6c\xb9\xaa\x20\xb2\x18\x4c"}, /* =l.. ..L */ \ - {0x0000be18, "\xbc\x87\x1c\x9f\xe0\x35\x9b\x73"}, /* .....5.s */ \ + {0x0000be10, "\x02\xa0\xf1\x31\xc0\x4c\x42\xd1"}, /* ...1.LB. */ \ + {0x0000be18, "\xbd\x0b\xa0\xa3\xd9\xe8\x4b\x64"}, /* ......Kd */ \ {0x0000be20, "\x22\x00\x00\x00\x00\x00\x00\x00"}, /* "....... */ \ - {0x0000be28, "\x31\x00\x00\x00\x00\x00\x00\x00"}, /* 1....... */ \ - {0x0000be38, "\x55\x00\x6e\x00\x6b\x00\x6e\x00"}, /* U.n.k.n. */ \ - {0x0000be40, "\x6f\x00\x77\x00\x6e\x00\x00\x00"}, /* o.w.n... */ \ + {0x0000be28, "\x23\x00\x00\x00\x00\x00\x00\x00"}, /* #....... */ \ {0x0000be80, "\xa0\x84\x7a\x8a\x87\x83\xf6\x40"}, /* ..z....@ */ \ {0x0000be88, "\xab\x41\xa8\xb9\xa5\xa6\x0d\x23"}, /* .A.....# */ \ - {0x0000be90, "\x57\x24\xf6\xe6\x0b\x6f\x66\x4e"}, /* W$...ofN */ \ - {0x0000be98, "\xb3\xd5\x99\x50\xa5\xc6\x4e\xc1"}, /* ...P..N. */ \ - {0x0000bea0, "\x32\x00\x00\x00\x00\x00\x00\x00"}, /* 2....... */ \ - {0x0000bea8, "\x41\x00\x00\x00\x00\x00\x00\x00"}, /* A....... */ \ - {0x0000beb8, "\x55\x00\x6e\x00\x6b\x00\x6e\x00"}, /* U.n.k.n. */ \ - {0x0000bec0, "\x6f\x00\x77\x00\x6e\x00\x00\x00"}, /* o.w.n... */ \ + {0x0000be90, "\x55\x2e\xe8\x5c\x7f\x10\x4b\xe7"}, /* U....K. */ \ + {0x0000be98, "\xb1\xb8\x3a\x84\xb7\x63\x1d\xcd"}, /* ..:..c.. */ \ + {0x0000bea0, "\x24\x00\x00\x00\x00\x00\x00\x00"}, /* $....... */ \ + {0x0000bea8, "\x25\x00\x00\x00\x00\x00\x00\x00"}, /* %....... */ \ {0x0000fe00, "\x45\x46\x49\x20\x50\x41\x52\x54"}, /* EFI PART */ \ {0x0000fe08, "\x00\x00\x01\x00\x5c\x00\x00\x00"}, /* ....... */ \ - {0x0000fe10, "\xa2\xce\x23\xfc\x00\x00\x00\x00"}, /* ..#..... */ \ + {0x0000fe10, "\x56\x67\x8b\x7d\x00\x00\x00\x00"}, /* Vg.}.... */ \ {0x0000fe18, "\x7f\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \ {0x0000fe20, "\x01\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \ {0x0000fe28, "\x22\x00\x00\x00\x00\x00\x00\x00"}, /* "....... */ \ {0x0000fe30, "\x5e\x00\x00\x00\x00\x00\x00\x00"}, /* ^....... */ \ - {0x0000fe38, "\xde\x99\xa2\x7e\x46\x34\xeb\x47"}, /* ...~F4.G */ \ - {0x0000fe40, "\x87\xf6\x4f\x75\xe8\xd5\x7d\xc7"}, /* ..Ou..}. */ \ + {0x0000fe38, "\xf5\xf3\x9d\xb9\x92\xdd\x48\x60"}, /* ......H` */ \ + {0x0000fe40, "\x9a\x04\xe5\x2b\x11\xcb\x42\x61"}, /* ...+..Ba */ \ {0x0000fe48, "\x5f\x00\x00\x00\x00\x00\x00\x00"}, /* _....... */ \ {0x0000fe50, "\x80\x00\x00\x00\x80\x00\x00\x00"}, /* ........ */ \ - {0x0000fe58, "\x2a\x64\x03\x83\x00\x00\x00\x00"}, /* .d...... */ \ + {0x0000fe58, "\xc4\x80\x68\xad\x00\x00\x00\x00"}, /* ..h..... */ \ {0, NULL} } }
With the migration to the FWU metadata version 2 structure, the values of number of banks and number of images per bank are now obtained from the metadata at runtime. Remove the now superfluous config symbols.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org ---
Changes since V1: None
arch/sandbox/Kconfig | 6 ------ board/armltd/corstone1000/corstone1000.c | 2 +- lib/fwu_updates/Kconfig | 11 ----------- 3 files changed, 1 insertion(+), 18 deletions(-)
diff --git a/arch/sandbox/Kconfig b/arch/sandbox/Kconfig index 0ce77de2fc..29013a5673 100644 --- a/arch/sandbox/Kconfig +++ b/arch/sandbox/Kconfig @@ -79,9 +79,3 @@ config SYS_FDT_LOAD_ADDR See `doc/arch/sandbox.rst` for more information.
endmenu - -config FWU_NUM_BANKS - default 2 - -config FWU_NUM_IMAGES_PER_BANK - default 2 diff --git a/board/armltd/corstone1000/corstone1000.c b/board/armltd/corstone1000/corstone1000.c index 01c80aaf9d..15de738154 100644 --- a/board/armltd/corstone1000/corstone1000.c +++ b/board/armltd/corstone1000/corstone1000.c @@ -109,7 +109,7 @@ void fwu_plat_get_bootidx(uint *boot_idx) */ ret = fwu_get_active_index(boot_idx); if (ret < 0) { - *boot_idx = CONFIG_FWU_NUM_BANKS; + *boot_idx = 0; log_err("corstone1000: failed to read active index\n"); } } diff --git a/lib/fwu_updates/Kconfig b/lib/fwu_updates/Kconfig index d35247d0e5..6bb94f88d3 100644 --- a/lib/fwu_updates/Kconfig +++ b/lib/fwu_updates/Kconfig @@ -12,17 +12,6 @@ menuconfig FWU_MULTI_BANK_UPDATE
if FWU_MULTI_BANK_UPDATE
-config FWU_NUM_BANKS - int "Number of Banks defined by the platform" - help - Define the number of banks of firmware images on a platform - -config FWU_NUM_IMAGES_PER_BANK - int "Number of firmware images per bank" - help - Define the number of firmware images per bank. This value - should be the same for all the banks. - config FWU_TRIAL_STATE_CNT int "Number of times system boots in Trial State" default 3
Migrate the metadata generation tool to generate the version 2 metadata.
Changes since V1: * Compute location of struct fwu_fw_store_desc using pointer arithmetic.
tools/mkfwumdata.c | 45 ++++++++++++++++++++++++++++++++++----------- 1 file changed, 34 insertions(+), 11 deletions(-)
diff --git a/tools/mkfwumdata.c b/tools/mkfwumdata.c index 9732a8ddc5..fb847e3a78 100644 --- a/tools/mkfwumdata.c +++ b/tools/mkfwumdata.c @@ -14,12 +14,13 @@ #include <unistd.h> #include <uuid/uuid.h>
-/* This will dynamically allocate the fwu_mdata */ -#define CONFIG_FWU_NUM_BANKS 0 -#define CONFIG_FWU_NUM_IMAGES_PER_BANK 0 - /* Since we can not include fwu.h, redefine version here. */ -#define FWU_MDATA_VERSION 1 +#define FWU_MDATA_VERSION 2 + +#define MAX_BANKS 4 + +#define BANK_INVALID 0xFF +#define BANK_ACCEPTED 0xFC
typedef uint8_t u8; typedef int16_t s16; @@ -29,8 +30,6 @@ typedef uint64_t u64;
-/* TODO: Endianness conversion may be required for some arch. */ - static const char *opts_short = "b:i:a:p:gh";
static struct option options[] = { @@ -48,7 +47,7 @@ static void print_usage(void) fprintf(stderr, "Usage: mkfwumdata [options] <UUIDs list> <output file>\n"); fprintf(stderr, "Options:\n" "\t-i, --images <num> Number of images (mandatory)\n" - "\t-b, --banks <num> Number of banks (mandatory)\n" + "\t-b, --banks <num> Number of banks(1-4) (mandatory)\n" "\t-a, --active-bank <num> Active bank (default=0)\n" "\t-p, --previous-bank <num> Previous active bank (default=active_bank - 1)\n" "\t-g, --guid Use GUID instead of UUID\n" @@ -85,6 +84,7 @@ static struct fwu_mdata_object *fwu_alloc_mdata(size_t images, size_t banks) return NULL;
mobj->size = sizeof(struct fwu_mdata) + + sizeof(struct fwu_fw_store_desc) + (sizeof(struct fwu_image_entry) + sizeof(struct fwu_image_bank_info) * banks) * images; mobj->images = images; @@ -105,6 +105,7 @@ fwu_get_image(struct fwu_mdata_object *mobj, size_t idx) size_t offset;
offset = sizeof(struct fwu_mdata) + + sizeof(struct fwu_fw_store_desc) + (sizeof(struct fwu_image_entry) + sizeof(struct fwu_image_bank_info) * mobj->banks) * idx;
@@ -117,6 +118,7 @@ fwu_get_bank(struct fwu_mdata_object *mobj, size_t img_idx, size_t bnk_idx) size_t offset;
offset = sizeof(struct fwu_mdata) + + sizeof(struct fwu_fw_store_desc) + (sizeof(struct fwu_image_entry) + sizeof(struct fwu_image_bank_info) * mobj->banks) * img_idx + sizeof(struct fwu_image_entry) + @@ -188,7 +190,7 @@ fwu_parse_fill_image_uuid(struct fwu_mdata_object *mobj, return -EINVAL;
if (strcmp(uuid, "0") && - uuid_guid_parse(uuid, (unsigned char *)&image->location_uuid) < 0) + uuid_guid_parse(uuid, (unsigned char *)&image->location_guid) < 0) return -EINVAL;
/* Image type UUID */ @@ -196,7 +198,7 @@ fwu_parse_fill_image_uuid(struct fwu_mdata_object *mobj, if (!uuid) return -EINVAL;
- if (uuid_guid_parse(uuid, (unsigned char *)&image->image_type_uuid) < 0) + if (uuid_guid_parse(uuid, (unsigned char *)&image->image_type_guid) < 0) return -EINVAL;
/* Fill bank image-UUID */ @@ -210,7 +212,7 @@ fwu_parse_fill_image_uuid(struct fwu_mdata_object *mobj, return -EINVAL;
if (strcmp(uuid, "0") && - uuid_guid_parse(uuid, (unsigned char *)&bank->image_uuid) < 0) + uuid_guid_parse(uuid, (unsigned char *)&bank->image_guid) < 0) return -EINVAL; } return 0; @@ -220,11 +222,26 @@ fwu_parse_fill_image_uuid(struct fwu_mdata_object *mobj, static int fwu_parse_fill_uuids(struct fwu_mdata_object *mobj, char *uuids[]) { struct fwu_mdata *mdata = mobj->mdata; + struct fwu_fw_store_desc *fw_desc; int i, ret;
mdata->version = FWU_MDATA_VERSION; mdata->active_index = active_bank; mdata->previous_active_index = previous_bank; + mdata->metadata_size = mobj->size; + mdata->desc_offset = sizeof(struct fwu_mdata); + + for (i = 0; i < MAX_BANKS; i++) + mdata->bank_state[i] = i < mobj->banks ? + BANK_ACCEPTED : BANK_INVALID; + + fw_desc = (struct fwu_fw_store_desc *)((u8 *)mdata + sizeof(*mdata)); + fw_desc->num_banks = mobj->banks; + fw_desc->num_images = mobj->images; + fw_desc->img_entry_size = sizeof(struct fwu_image_entry) + + (sizeof(struct fwu_image_bank_info) * mobj->banks); + fw_desc->bank_info_entry_size = + sizeof(struct fwu_image_bank_info);
for (i = 0; i < mobj->images; i++) { ret = fwu_parse_fill_image_uuid(mobj, i, uuids[i]); @@ -313,6 +330,12 @@ int main(int argc, char *argv[]) return -EINVAL; }
+ if (banks > MAX_BANKS) { + fprintf(stderr, "Error: The number of banks must not be more than %u.\n", + MAX_BANKS); + return -EINVAL; + } + /* This command takes UUIDs * images and output file. */ if (optind + images + 1 != argc) { fprintf(stderr, "Error: UUID list or output file is not specified or too much.\n");
Changes since V1:
I think in previous version only active bank was accepted not others. I don't think it is wrong behavior but please consider to select it too. I was just surprised to see both banks in that state.
Thanks, Michal
hi Michal,
Changes since V1:
In the current version as well, we do accept all the images, for all banks. This is happening in the fwu_parse_fill_image_uuid() function, where on line 207 we are setting the accepted field to 1 for all banks for a given image.
-sughosh
The version 2 of the FWU metadata allows for appending opaque vendor specific data to the metadata structure. Add support for appending this data to the metadata. The vendor specific data needs to be provided through a file, passed through a command-line parameter.
Changes since V1: New patch
tools/mkfwumdata.c | 85 +++++++++++++++++++++++++++++++++++++++++----- 1 file changed, 77 insertions(+), 8 deletions(-)
diff --git a/tools/mkfwumdata.c b/tools/mkfwumdata.c index fb847e3a78..ab07623e25 100644 --- a/tools/mkfwumdata.c +++ b/tools/mkfwumdata.c @@ -12,6 +12,8 @@ #include <string.h> #include <u-boot/crc.h> #include <unistd.h> +#include <sys/types.h> +#include <sys/stat.h> #include <uuid/uuid.h>
/* Since we can not include fwu.h, redefine version here. */ @@ -30,7 +32,7 @@ typedef uint64_t u64;
#include <fwu_mdata.h>
-static const char *opts_short = "b:i:a:p:gh"; +static const char *opts_short = "b:i:a:p:v:gh";
static struct option options[] = { {"banks", required_argument, NULL, 'b'}, @@ -38,6 +40,7 @@ static struct option options[] = { {"guid", required_argument, NULL, 'g'}, {"active-bank", required_argument, NULL, 'a'}, {"previous-bank", required_argument, NULL, 'p'}, + {"vendor-file", required_argument, NULL, 'v'}, {"help", no_argument, NULL, 'h'}, {NULL, 0, NULL, 0}, }; @@ -51,6 +54,7 @@ static void print_usage(void) "\t-a, --active-bank <num> Active bank (default=0)\n" "\t-p, --previous-bank <num> Previous active bank (default=active_bank - 1)\n" "\t-g, --guid Use GUID instead of UUID\n" + "\t-v, --vendor-file Vendor data file to append to the metadata\n" "\t-h, --help print a help message\n" ); fprintf(stderr, " UUIDs list syntax:\n" @@ -69,13 +73,16 @@ struct fwu_mdata_object { size_t images; size_t banks; size_t size; + size_t vsize; + void *vbuf; struct fwu_mdata *mdata; };
static int previous_bank, active_bank; static bool __use_guid;
-static struct fwu_mdata_object *fwu_alloc_mdata(size_t images, size_t banks) +static struct fwu_mdata_object *fwu_alloc_mdata(size_t images, size_t banks, + size_t vendor_size) { struct fwu_mdata_object *mobj;
@@ -87,16 +94,28 @@ static struct fwu_mdata_object *fwu_alloc_mdata(size_t images, size_t banks) sizeof(struct fwu_fw_store_desc) + (sizeof(struct fwu_image_entry) + sizeof(struct fwu_image_bank_info) * banks) * images; + + mobj->size += vendor_size; + mobj->vsize = vendor_size; mobj->images = images; mobj->banks = banks;
mobj->mdata = calloc(1, mobj->size); - if (!mobj->mdata) { - free(mobj); - return NULL; + if (!mobj->mdata) + goto alloc_err; + + if (vendor_size) { + mobj->vbuf = calloc(1, mobj->vsize); + if (!mobj->vbuf) + goto alloc_err; }
return mobj; + +alloc_err: + free(mobj->mdata); + free(mobj); + return NULL; }
static struct fwu_image_entry * @@ -223,6 +242,7 @@ static int fwu_parse_fill_uuids(struct fwu_mdata_object *mobj, char *uuids[]) { struct fwu_mdata *mdata = mobj->mdata; struct fwu_fw_store_desc *fw_desc; + char *vdata; int i, ret;
mdata->version = FWU_MDATA_VERSION; @@ -249,23 +269,65 @@ static int fwu_parse_fill_uuids(struct fwu_mdata_object *mobj, char *uuids[]) return ret; }
+ if (mobj->vsize) { + vdata = (char *)mobj->mdata + (mobj->size - mobj->vsize); + memcpy(vdata, mobj->vbuf, mobj->vsize); + } + mdata->crc32 = crc32(0, (const unsigned char *)&mdata->version, mobj->size - sizeof(uint32_t));
return 0; }
+static int fwu_read_vendor_data(struct fwu_mdata_object *mobj, + const char *vendor_file) +{ + int ret = 0; + FILE *vfile = NULL; + + vfile = fopen(vendor_file, "r"); + if (!vfile) { + ret = -1; + goto out; + } + + if (fread(mobj->vbuf, 1, mobj->vsize, vfile) != mobj->vsize) + ret = -1; + +out: + fclose(vfile); + return ret; +} + static int -fwu_make_mdata(size_t images, size_t banks, char *uuids[], char *output) +fwu_make_mdata(size_t images, size_t banks, const char *vendor_file, + char *uuids[], char *output) { struct fwu_mdata_object *mobj; FILE *file; + struct stat sbuf; + size_t vendor_size = 0; int ret;
- mobj = fwu_alloc_mdata(images, banks); + if (vendor_file) { + ret = stat(vendor_file, &sbuf); + if (ret) + return -errno; + + vendor_size = sbuf.st_size; + } + + mobj = fwu_alloc_mdata(images, banks, vendor_size); if (!mobj) return -ENOMEM;
+ if (vendor_file) { + ret = fwu_read_vendor_data(mobj, vendor_file); + if (ret) + goto done_make; + } + ret = fwu_parse_fill_uuids(mobj, uuids); if (ret < 0) goto done_make; @@ -286,6 +348,7 @@ fwu_make_mdata(size_t images, size_t banks, char *uuids[], char *output)
done_make: free(mobj->mdata); + free(mobj->vbuf); free(mobj);
return ret; @@ -295,11 +358,13 @@ int main(int argc, char *argv[]) { unsigned long banks = 0, images = 0; int c, ret; + const char *vendor_file;
/* Explicitly initialize defaults */ active_bank = 0; __use_guid = false; previous_bank = INT_MAX; + vendor_file = NULL;
do { c = getopt_long(argc, argv, opts_short, options, NULL); @@ -322,6 +387,9 @@ int main(int argc, char *argv[]) case 'a': active_bank = strtoul(optarg, NULL, 0); break; + case 'v': + vendor_file = optarg; + break; } } while (c != -1);
@@ -348,7 +416,8 @@ int main(int argc, char *argv[]) previous_bank = active_bank > 0 ? active_bank - 1 : banks - 1; }
- ret = fwu_make_mdata(images, banks, argv + optind, argv[argc - 1]); + ret = fwu_make_mdata(images, banks, vendor_file, argv + optind, + argv[argc - 1]); if (ret < 0) fprintf(stderr, "Error: Failed to parse and write image: %s\n", strerror(-ret));
- {"vendor-file", required_argument, NULL, 'v'}, {"help", no_argument, NULL, 'h'}, {NULL, 0, NULL, 0}, };
"\t-h, --help print a help message\n" ); fprintf(stderr, " UUIDs list syntax:\n""\t-v, --vendor-file Vendor data file to append to the metadata\n"
size_t vsize;
{ struct fwu_mdata_object *mobj;size_t vendor_size)
free(mobj);
return NULL;
if (!mobj->mdata)
goto alloc_err;
if (vendor_size) {
if (!mobj->vbuf)
goto alloc_err;
return mobj;
+alloc_err:
free(mobj->mdata);
free(mobj);
return NULL; }
if (mobj->vsize) {
return 0; }
- int ret = 0;
- FILE *vfile = NULL;
- vfile = fopen(vendor_file, "r");
- if (!vfile) {
ret = -1;
goto out;
- if (fread(mobj->vbuf, 1, mobj->vsize, vfile) != mobj->vsize)
ret = -1;
+out:
- fclose(vfile);
- return ret;
- static int
{ struct fwu_mdata_object *mobj; FILE *file;char *uuids[], char *output)
- struct stat sbuf;
- size_t vendor_size = 0; int ret;
if (vendor_file) {
if (ret)
return -errno;
if (vendor_file) {
if (ret)
goto done_make;
return ret;
vendor_file = NULL;
case 'v':
} } while (c != -1);break;
- ret = fwu_make_mdata(images, banks, vendor_file, argv + optind,
if (ret < 0) fprintf(stderr, "Error: Failed to parse and write image: %s\n", strerror(-ret));argv[argc - 1]);
Tested-by: Michal Simek michal.simek@amd.com
Thanks, Michal
The fwrite call returns the number of bytes transferred as part of the write only when the size parameter is 1. Pass the size parameter to the library call as 1 so that the correct number of bytes transferred are returned.
Fixes: fdd56bfd3ad ("tools: Add mkfwumdata tool for FWU metadata image") Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org ---
tools/mkfwumdata.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/mkfwumdata.c b/tools/mkfwumdata.c index ab07623e25..426d221ac7 100644 --- a/tools/mkfwumdata.c +++ b/tools/mkfwumdata.c @@ -338,7 +338,7 @@ fwu_make_mdata(size_t images, size_t banks, const char *vendor_file, goto done_make; }
- ret = fwrite(mobj->mdata, mobj->size, 1, file); + ret = fwrite(mobj->mdata, 1, mobj->size, file); if (ret != mobj->size) ret = -errno; else
Now that the migration to the FWU metadata version 2 is complete, the feature can be re-enabled on platforms which had it enabled.
configs/corstone1000_defconfig | 2 ++ configs/sandbox64_defconfig | 1 + configs/synquacer_developerbox_defconfig | 3 +++ 3 files changed, 6 insertions(+)
diff --git a/configs/corstone1000_defconfig b/configs/corstone1000_defconfig index c26a621175..a86ac12732 100644 --- a/configs/corstone1000_defconfig +++ b/configs/corstone1000_defconfig @@ -25,6 +25,7 @@ CONFIG_BOARD_LATE_INIT=y CONFIG_SYS_PROMPT="corstone1000# " CONFIG_SYS_MAXARGS=64 # CONFIG_CMD_CONSOLE is not set +CONFIG_CMD_FWU_METADATA=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_XIMG is not set CONFIG_CMD_GPT=y @@ -67,3 +68,4 @@ CONFIG_FFA_SHARED_MM_BUF_OFFSET=0 CONFIG_FFA_SHARED_MM_BUF_ADDR=0x02000000 CONFIG_EFI_CAPSULE_ON_DISK=y CONFIG_EFI_IGNORE_OSINDICATIONS=y +CONFIG_FWU_MULTI_BANK_UPDATE=y diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index 2863f9b189..d101cca6a7 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -273,6 +273,7 @@ CONFIG_EFI_CAPSULE_ON_DISK=y CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y CONFIG_EFI_SECURE_BOOT=y CONFIG_TEST_FDTDEC=y +CONFIG_FWU_MULTI_BANK_UPDATE=y CONFIG_UNIT_TEST=y CONFIG_UT_TIME=y CONFIG_UT_DM=y diff --git a/configs/synquacer_developerbox_defconfig b/configs/synquacer_developerbox_defconfig index 616d410074..1bb55be0a7 100644 --- a/configs/synquacer_developerbox_defconfig +++ b/configs/synquacer_developerbox_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_BOOTM_LEN=0x800000 CONFIG_BOOTSTAGE_STASH_SIZE=4096 CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=128 +CONFIG_CMD_FWU_METADATA=y CONFIG_CMD_IMLS=y CONFIG_CMD_ERASEENV=y CONFIG_CMD_NVEDIT_EFI=y @@ -51,6 +52,7 @@ CONFIG_DFU_TFTP=y CONFIG_DFU_MTD=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y +CONFIG_FWU_MDATA_MTD=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_SYNQUACER=y CONFIG_MMC_SDHCI=y @@ -93,3 +95,4 @@ CONFIG_EFI_RUNTIME_UPDATE_CAPSULE=y CONFIG_EFI_CAPSULE_ON_DISK=y CONFIG_EFI_IGNORE_OSINDICATIONS=y CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y +CONFIG_FWU_MULTI_BANK_UPDATE=y
Make changes to the FWU documentation to reflect the changes made with migration of the FWU metadata to version 2.
doc/board/socionext/developerbox.rst | 9 +++------ doc/develop/uefi/fwu_updates.rst | 12 +++++------- doc/usage/cmd/fwu_mdata.rst | 12 ++++++++---- 3 files changed, 16 insertions(+), 17 deletions(-)
diff --git a/doc/board/socionext/developerbox.rst b/doc/board/socionext/developerbox.rst index 46712c379b..d8c1bb4986 100644 --- a/doc/board/socionext/developerbox.rst +++ b/doc/board/socionext/developerbox.rst @@ -113,8 +113,6 @@ configs/synquacer_developerbox_defconfig enables default FWU configuration :: CONFIG_FWU_MULTI_BANK_UPDATE=y CONFIG_FWU_MDATA=y CONFIG_FWU_MDATA_MTD=y - CONFIG_FWU_NUM_BANKS=2 - CONFIG_FWU_NUM_IMAGES_PER_BANK=1 CONFIG_CMD_FWU_METADATA=y
And build it:: @@ -126,10 +124,9 @@ And build it:: make -j `noproc` cd ../
-By default, the CONFIG_FWU_NUM_BANKS and CONFIG_FWU_NUM_IMAGES_PER_BANKS are -set to 2 and 1 respectively. This uses FIP (Firmware Image Package) type image -which contains TF-A, U-Boot and OP-TEE (the OP-TEE is optional). -You can use fiptool to compose the FIP image from those firmware images. +This uses FIP (Firmware Image Package) type image which contains TF-A, +U-Boot and OP-TEE (the OP-TEE is optional). You can use fiptool to +compose the FIP image from those firmware images.
Rebuild SCP firmware -------------------- diff --git a/doc/develop/uefi/fwu_updates.rst b/doc/develop/uefi/fwu_updates.rst index e4709d82b4..7911c954d9 100644 --- a/doc/develop/uefi/fwu_updates.rst +++ b/doc/develop/uefi/fwu_updates.rst @@ -43,8 +43,6 @@ The feature can be enabled by specifying the following configs:: CONFIG_FWU_MULTI_BANK_UPDATE=y CONFIG_FWU_MDATA=y CONFIG_FWU_MDATA_GPT_BLK=y - CONFIG_FWU_NUM_BANKS=<val> - CONFIG_FWU_NUM_IMAGES_PER_BANK=<val>
in the .config file
@@ -94,12 +92,12 @@ of. Each GPT partition entry in the GPT header has two GUIDs:: * UniquePartitionGUID
The PartitionTypeGUID value should correspond to the -``image_type_uuid`` field of the FWU metadata. This field is used to +``image_type_guid`` field of the FWU metadata. This field is used to identify a given type of updatable firmware image, e.g. U-Boot, OP-TEE, FIP etc. This GUID should also be used for specifying the `--guid` parameter when generating the capsule.
-The UniquePartitionGUID value should correspond to the ``image_uuid`` +The UniquePartitionGUID value should correspond to the ``image_guid`` field in the FWU metadata. This GUID is used to identify images of a given image type in different banks.
@@ -108,8 +106,8 @@ metadata partitions. This would be the PartitionTypeGUID for the metadata partitions. Similarly, the UEFI specification defines the ESP GUID to be be used.
-When generating the metadata, the ``image_type_uuid`` and the -``image_uuid`` values should match the *PartitionTypeGUID* and the +When generating the metadata, the ``image_type_guid`` and the +``image_guid`` values should match the *PartitionTypeGUID* and the *UniquePartitionGUID* values respectively.
Performing the Update @@ -181,5 +179,5 @@ empty capsule would be:: Links -----
-* [1] https://developer.arm.com/documentation/den0118/a/ - FWU Specification +* [1] https://developer.arm.com/documentation/den0118/ - FWU Specification * [2] https://git.codelinaro.org/linaro/dependable-boot/mbfw/uploads/6f7ddfe3be24e... - Dependable Boot Specification diff --git a/doc/usage/cmd/fwu_mdata.rst b/doc/usage/cmd/fwu_mdata.rst index f1bf08fde1..1804422b33 100644 --- a/doc/usage/cmd/fwu_mdata.rst +++ b/doc/usage/cmd/fwu_mdata.rst @@ -26,10 +26,14 @@ The output may look like:
=> fwu_mdata_read FWU Metadata - crc32: 0xec4fb997 - version: 0x1 - active_index: 0x0 - previous_active_index: 0x1 + crc32: 0x13c330 + version: 0x2 + active_index: 0x1 + previous_active_index: 0x0 + bank_state[0]: 0xfc + bank_state[1]: 0xfc + bank_state[2]: 0xff + bank_state[3]: 0xff Image Info
Image Type Guid: 19D5DF83-11B0-457B-BE2C-7559C13142A5
Hello Sughosh,
Sorry for this very late reply especially since I have a quite negative feedback on the proposed changes.
I don't think FWU metadata version 1 should be removed from U-Boot support. There are existing immutable boot agent relying on format v1, starting from the Synquacer boards based on SCP-firmware v2.11 [1] onward (at least up to latest v2.13 tag) and the stm32mp1 platforms based on TF-A v2.7 [2] onward (at least up to latest tag v2.10). These platforms should be able to update there EFI firmware hence needing the update agent (U-Boot) to support format v1.
With the proposed series, the new format v2 contains the same information the previous mdata v1 based implementation did (apart that some info where built-in whereas v2 describe them from the mdata storage area). Could it be possible the implementation support both, using for example a internal structure fed from either format v1 or v2 content read from the storage, and used to update the mdata v1 or v2 format storage layout?
[1] https://gitlab.arm.com/firmware/SCP-firmware/-/blob/v2.11.0/product/synquace... [2] https://review.trustedfirmware.org/plugins/gitiles/TF-A/trusted-firmware-a/+...
Best regards, Etienne
The following patches migrate the FWU metadata access code to version 2 of the structure. This is based on the structure definition as defined in the latest rev of the FWU Multi Bank Update specification [1].
Since the version 1 of the structure has currently been adopted on a couple of platforms, it was decided to have a clean migration of the metadata to version 2 only, instead of supporting both the versions of the structure. Also, based on consultations with the main author of the specification, it is expected that any further changes in the structure would be minor tweaks, and not be significant. Hence a migration to version 2.
Similar migration is also being done in TF-A, including migrating the ST platform port to support version 2 of the metadata structure [2].
@Michal, I tested the metadata for the two image per bank case, and it works fine on the ST board. Kindly test this on your board as well.
@Kojima-san, Please help in testing the version 2 on your board. Thanks.
[1] - https://developer.arm.com/documentation/den0118/latest/ [2] - https://review.trustedfirmware.org/q/topic:%22topics/fwu_metadata_v2_migrati...
Changes since V1:
- Do not define flexible array members inside the structures.
- Access the image information related fields in the metadata using the helper functions defined in an earlier patch.
- Access fwu_fw_store_desc structure using pointer arithmetic.
(snip)
hi Etienne,
On Tue, 20 Feb 2024 at 15:14, Etienne CARRIERE - foss etienne.carriere@foss.st.com wrote:
Hello Sughosh,
Currently, we have two platforms which are using the feature with the Update Agent in U-Boot, one being the ST boards, and the Synquacer platform from Socionext. Support is going to be added to the Xilinx boards, but they are interested in v2 only. Before I started working on this migration, I had written to the stakeholders in early December about their thoughts on this change. I had also written to you about this, but since you did not respond, I took it as an implicit acceptance for the change. Socionext had responded saying that they are fine with the migration to v2 only support in U-Boot. You are also aware that I am making changes in TF-A to migrate support to v2 only, and that includes the ST boards as well. So, will it not be better to migrate both TF-A and U-Boot to v2 only support?
Since you are proposing supporting both the versions in U-Boot, I want to check with you if there are ST platforms in the field which have version 1 support? If not, I think it will be cleaner to support only v2, and use that version in both TF-A and U-Boot henceforth. I had checked with Jose, who is the author of the spec and he had mentioned that he does not foresee any major change in the metadata structure henceforth. Which is another reason why it was deemed suitable to migrate to v2 instead of supporting both versions.
This is software, so we can definitely support it. But the question is whether we really need to support v1 as well? If the feature has not been deployed in the field yet, I would say a clean migration is better.
-sughosh
Changes since V1:
(snip)
Michal Simek
Sughosh Ganu
