[U-Boot] [PATCH] EXYNOS5: Add L2 Cache Support.
This patch set adds L2 Cache Support to EXYNOS.
Signed-off-by: Arun Mankuzhi arun.m@samsung.com Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- arch/arm/cpu/armv7/exynos/soc.c | 37 +++++++++++++++++++++++++++++++++++++ 1 files changed, 37 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/soc.c b/arch/arm/cpu/armv7/exynos/soc.c index ab65b8d..676a388 100644 --- a/arch/arm/cpu/armv7/exynos/soc.c +++ b/arch/arm/cpu/armv7/exynos/soc.c @@ -23,6 +23,14 @@
#include <common.h> #include <asm/io.h> +#include <asm/system.h> + +enum l2_cache_params { + CACHE_TAG_RAM_SETUP = (1<<9), + CACHE_DATA_RAM_SETUP = (1<<5), + CACHE_TAG_RAM_LATENCY = (2<<6), + CACHE_DATA_RAM_LATENCY = (2<<0) +};
void reset_cpu(ulong addr) { @@ -36,3 +44,32 @@ void enable_caches(void) dcache_enable(); } #endif + +#ifndef CONFIG_SYS_L2CACHE_OFF +/* + * Set L2 cache parameters + */ +static void exynos5_set_l2cache_params(void) +{ + unsigned int val = 0; + + asm volatile("mrc p15, 1, %0, c9, c0, 2\n" : "=r"(val)); + + val |= CACHE_TAG_RAM_SETUP | + CACHE_DATA_RAM_SETUP | + CACHE_TAG_RAM_LATENCY | + CACHE_DATA_RAM_LATENCY; + + asm volatile("mcr p15, 1, %0, c9, c0, 2\n" : : "r"(val)); +} + +/* + * Sets L2 cache related parameters before enabling data cache + */ +void v7_outer_cache_enable(void) +{ + if (cpu_is_exynos5()) + exynos5_set_l2cache_params(); +} +#endif +
On Thu, Nov 29, 2012 at 10:29 PM, Rajeshwari Shinde rajeshwari.s@samsung.com wrote:
- Set L2 cache parameters
- Sets L2 cache related parameters before enabling data cache
+} +#endif
-- 1.7.4.4
BTW I am assuming this is v2? It looks like it.
Hi Simon,
Yes it is a V2 patch. Sorry I missed the add the same will submitting the patch.
Regards, Rajeshwari Shinde.
Regards, Simon _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hi Minkyu Kang,
Please do let me know if any comments regarding this patch.
+} +#endif
-- 1.7.4.4
Hi Minkyu,
Please do let me know if any comments for same.
Regards, Rajeshwari Shinde. On Thu, Dec 27, 2012 at 11:29 AM, Rajeshwari Birje rajeshwari.birje@gmail.com wrote:
Minkyu Kang,
Sorry! too late.
appiled to u-boot-samsung.
Thanks, Minkyu Kang.
Minkyu Kang
Rajeshwari Birje
Rajeshwari Shinde
