[U-Boot] [PATCH] spl: net: Add FIT image support over network boot
FIT support in the net boot case is much like the RAM boot case in that we load our image to "load_addr" and pass a dummy read function into "spl_load_simple_fit()". As the load address is no longer hard-coded to the final execution address, RAW image loading will rely on "load_addr" pointing to the execution address as they should have before.
Signed-off-by: Andrew F. Davis afd@ti.com --- common/spl/spl_net.c | 30 +++++++++++++++++++++++++++--- 1 file changed, 27 insertions(+), 3 deletions(-)
diff --git a/common/spl/spl_net.c b/common/spl/spl_net.c index 0fba0172ea..b7a4a89198 100644 --- a/common/spl/spl_net.c +++ b/common/spl/spl_net.c @@ -11,19 +11,29 @@ #include <errno.h> #include <spl.h> #include <net.h> +#include <libfdt.h>
DECLARE_GLOBAL_DATA_PTR;
+static ulong spl_net_load_read(struct spl_load_info *load, ulong sector, + ulong count, void *buf) +{ + debug("%s: sector %lx, count %lx, buf %lx\n", + __func__, sector, count, (ulong)buf); + memcpy(buf, (void *)(load_addr + sector), count); + return count; +} + #if defined(CONFIG_SPL_ETH_SUPPORT) || defined(CONFIG_SPL_USBETH_SUPPORT) static int spl_net_load_image(struct spl_image_info *spl_image, struct spl_boot_device *bootdev) { + struct image_header *header = (struct image_header *)load_addr; int rv;
env_init(); env_relocate(); setenv("autoload", "yes"); - load_addr = CONFIG_SYS_TEXT_BASE - sizeof(struct image_header); rv = eth_initialize(); if (rv == 0) { printf("No Ethernet devices found\n"); @@ -36,8 +46,22 @@ static int spl_net_load_image(struct spl_image_info *spl_image, printf("Problem booting with BOOTP\n"); return rv; } - return spl_parse_image_header(spl_image, - (struct image_header *)load_addr); + + if (IS_ENABLED(CONFIG_SPL_LOAD_FIT) && + image_get_magic(header) == FDT_MAGIC) { + struct spl_load_info load; + + debug("Found FIT\n"); + load.bl_len = 1; + load.read = spl_net_load_read; + rv = spl_load_simple_fit(spl_image, &load, 0, header); + } else { + debug("Legacy image\n"); + + rv = spl_parse_image_header(spl_image, header); + } + + return rv; } #endif
- debug("%s: sector %lx, count %lx, buf %lx\n",
- memcpy(buf, (void *)(load_addr + sector), count);
- return count;
You may have to move above function within below #if block as spl_net_load_read() is used only by spl_net_load_image().
- if (IS_ENABLED(CONFIG_SPL_LOAD_FIT) &&
load.bl_len = 1;
- } else {
- return rv;
} #endif
- return count;
Good catch, will move.
Thanks, Andrew
load.bl_len = 1;
- } else {
- return rv;
} #endif
- return count;
- struct image_header *header = (struct image_header *)load_addr;
Just wondering what is the default load_addr or who sets load_addr before doing tftp? have you verified both FIT and not FIT case?
Thanks and regards, Lokesh
- return count;
The default is set to CONFIG_SYS_LOAD_ADDR, this is where the other SPL loaders put the image, spl_net was the odd case before this patch.
The Legacy image, like FIT encodes the relocation address, RAW images would have never worked with netboot due to the hard-coded shift to compensate for the legacy image header.
Andrew
Andrew F. Davis
Lokesh Vutla
Vignesh R
