[PATCH 1/2] ARM: dts: sm32mp15: remove shmem for scmi-optee
Since OP-TEE commit 89ba3422ee80 ("plat-stm32mp1: scmi_server: default use OP-TEE shared memory"), integrated in OP-TEE 3.22.0-rc1 the default configuration for STM32MP15x SoCs changes, CFG_STM32MP1_SCMI_SHM_SYSRAM is disabled by default and the OP-TEE SMCI server uses ithe OP-TEE native shared memory registered by clients.
To be compatible by default with this configuration and the next OP-TEE version, this patch removes the SHMEM in the SCMI configuration and the associated reserved memory in the last 4KByte page of SRAM, in the STM32MP15 device tree.
Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
arch/arm/dts/stm32mp15-scmi.dtsi | 16 ---------------- 1 file changed, 16 deletions(-)
diff --git a/arch/arm/dts/stm32mp15-scmi.dtsi b/arch/arm/dts/stm32mp15-scmi.dtsi index 543f24c2f4f6..ad2584213d99 100644 --- a/arch/arm/dts/stm32mp15-scmi.dtsi +++ b/arch/arm/dts/stm32mp15-scmi.dtsi @@ -16,7 +16,6 @@ #address-cells = <1>; #size-cells = <0>; linaro,optee-channel-id = <0>; - shmem = <&scmi_shm>;
scmi_clk: protocol@14 { reg = <0x14>; @@ -60,21 +59,6 @@ }; }; }; - - soc { - scmi_sram: sram@2ffff000 { - compatible = "mmio-sram"; - reg = <0x2ffff000 0x1000>; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0x2ffff000 0x1000>; - - scmi_shm: scmi-sram@0 { - compatible = "arm,scmi-shmem"; - reg = <0 0x80>; - }; - }; - }; };
®11 {
CFG_STM32MP1_SCMI_SHM_SYSRAM will be disabled by default for STM32MP13x SoCs in next OP-TEE version and the OP-TEE SMCI server uses the OP-TEE native shared memory registered by clients.
To be compatible by default with this configuration this patch removes the shared memory in the SCMI configuration and the associated reserved memory in SRAM.
arch/arm/dts/stm32mp13-u-boot.dtsi | 8 -------- arch/arm/dts/stm32mp131.dtsi | 14 -------------- 2 files changed, 22 deletions(-)
diff --git a/arch/arm/dts/stm32mp13-u-boot.dtsi b/arch/arm/dts/stm32mp13-u-boot.dtsi index 726cd1a7e479..aa5cfc6e41d5 100644 --- a/arch/arm/dts/stm32mp13-u-boot.dtsi +++ b/arch/arm/dts/stm32mp13-u-boot.dtsi @@ -108,14 +108,6 @@ bootph-all; };
-&scmi_shm { - bootph-all; -}; - -&scmi_sram { - bootph-all; -}; - &syscfg { bootph-all; }; diff --git a/arch/arm/dts/stm32mp131.dtsi b/arch/arm/dts/stm32mp131.dtsi index d94ba2547267..f1810c9eb704 100644 --- a/arch/arm/dts/stm32mp131.dtsi +++ b/arch/arm/dts/stm32mp131.dtsi @@ -40,7 +40,6 @@ #address-cells = <1>; #size-cells = <0>; linaro,optee-channel-id = <0>; - shmem = <&scmi_shm>;
scmi_clk: protocol@14 { reg = <0x14>; @@ -106,19 +105,6 @@ interrupt-parent = <&intc>; ranges;
- scmi_sram: sram@2ffff000 { - compatible = "mmio-sram"; - reg = <0x2ffff000 0x1000>; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0x2ffff000 0x1000>; - - scmi_shm: scmi-sram@0 { - compatible = "arm,scmi-shmem"; - reg = <0 0x80>; - }; - }; - timers2: timer@40000000 { #address-cells = <1>; #size-cells = <0>;
-&scmi_shm {
- bootph-all;
-&scmi_sram {
- bootph-all;
shmem = <&scmi_shm>; scmi_clk: protocol@14 { reg = <0x14>;
#size-cells = <1>;
reg = <0 0x80>;
Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com
Thanks Patrice
-&scmi_shm {
- bootph-all;
-&scmi_sram {
- bootph-all;
#size-cells = <1>;
reg = <0 0x80>;
Applied on stm32-master
Thanks Patrice
- soc {
#size-cells = <1>;
reg = <0 0x80>;
®11 {
Thanks Patrice
- soc {
#size-cells = <1>;
reg = <0 0x80>;
®11 {
Thanks Patrice
Patrice CHOTARD
Patrick Delaunay
