Hello Tom,
Please pull tag u-boot-at91-2024.07-a , the first set of at91 features for the next cycle 2024.07 .
This feature set includes a new board named sama7g54 Curiosity.
Thanks, Eugen
The following changes since commit 20a0ce574d6642e0dfe651467159039fac48cc4f:
Merge tag 'v2024.04-rc4' into next (2024-03-11 15:27:20 -0400)
https://source.denx.de/u-boot/custodians/u-boot-at91.git tags/u-boot-at91-2024.07-a
for you to fetch changes up to a7ba3bf65db264c02a774a59e8febc2ecb095f68:
configs: at91: sama7g54_curiosity: Add initial default configs (2024-03-13 13:35:16 +0200)
---------------------------------------------------------------- First set of u-boot-at91 features for the 2024.07 cycle
---------------------------------------------------------------- Mihai Sain (4): ARM: dts: at91: sama7g5: Add flexcom 10 node ARM: dts: at91: sama7g54_curiosity: Add initial device tree of the board board: at91: sama7g54_curiosity: Add initial board support configs: at91: sama7g54_curiosity: Add initial default configs
arch/arm/dts/Makefile | 3 + arch/arm/dts/at91-sama7g54_curiosity-u-boot.dtsi | 59 +++++ arch/arm/dts/at91-sama7g54_curiosity.dts | 242 +++++++++++++++++++++ arch/arm/dts/sama7g5.dtsi | 24 ++ arch/arm/mach-at91/Kconfig | 10 + board/atmel/sama7g54_curiosity/Kconfig | 15 ++ board/atmel/sama7g54_curiosity/MAINTAINERS | 9 + board/atmel/sama7g54_curiosity/Makefile | 7 + .../atmel/sama7g54_curiosity/sama7g54_curiosity.c | 36 +++ configs/sama7g54_curiosity_mmc_defconfig | 123 +++++++++++ configs/sama7g54_curiosity_nandflash_defconfig | 122 +++++++++++ configs/sama7g54_curiosity_qspiflash_defconfig | 122 +++++++++++ include/configs/sama7g54_curiosity.h | 17 ++ 13 files changed, 789 insertions(+) create mode 100644 arch/arm/dts/at91-sama7g54_curiosity-u-boot.dtsi create mode 100644 arch/arm/dts/at91-sama7g54_curiosity.dts create mode 100644 board/atmel/sama7g54_curiosity/Kconfig create mode 100644 board/atmel/sama7g54_curiosity/MAINTAINERS create mode 100644 board/atmel/sama7g54_curiosity/Makefile create mode 100644 board/atmel/sama7g54_curiosity/sama7g54_curiosity.c create mode 100644 configs/sama7g54_curiosity_mmc_defconfig create mode 100644 configs/sama7g54_curiosity_nandflash_defconfig create mode 100644 configs/sama7g54_curiosity_qspiflash_defconfig create mode 100644 include/configs/sama7g54_curiosity.h
On Mon, Mar 25, 2024 at 09:45:44AM +0200, Eugen Hristev wrote:
Hello Tom,
Thanks, Eugen
Eugen Hristev
