[PATCH v2 1/3] ARM: dts: stm32: Duplicate cpu0-opp-table node into stm32mp15-u-boot.dtsi
The cpu0-opp-table {} node does not exist in upstream Linux stm32mp151.dtsi file, in order to enable conversion to OF_UPSTREAM, duplicate the node from current U-Boot stm32mp151.dtsi into stm32mp15-u-boot.dtsi. This makes STM32 DTs buildable even with OF_UPSTREAM enabled. No functional change, since the current U-Boot stm32mp151.dtsi already contains the cpu0-opp-table {} node, stm32mp15-u-boot.dtsi is applied at the end, and does not bring in any new content.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: Patrice Chotard patrice.chotard@foss.st.com Cc: Patrick Delaunay patrick.delaunay@foss.st.com Cc: Sean Anderson seanga2@gmail.com Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com Cc: u-boot@dh-electronics.com Cc: u-boot@lists.denx.de Cc: uboot-stm32@st-md-mailman.stormreply.com --- V2: No change --- arch/arm/dts/stm32mp15-u-boot.dtsi | 30 ++++++++++++++++++++++-------- 1 file changed, 22 insertions(+), 8 deletions(-)
diff --git a/arch/arm/dts/stm32mp15-u-boot.dtsi b/arch/arm/dts/stm32mp15-u-boot.dtsi index fe56f05616a..66d4c40c6a8 100644 --- a/arch/arm/dts/stm32mp15-u-boot.dtsi +++ b/arch/arm/dts/stm32mp15-u-boot.dtsi @@ -56,6 +56,24 @@ status = "okay"; }; }; + + cpu0_opp_table: cpu0-opp-table { + compatible = "operating-points-v2"; + opp-shared; + bootph-pre-ram; + opp-650000000 { + bootph-pre-ram; + opp-hz = /bits/ 64 <650000000>; + opp-microvolt = <1200000>; + opp-supported-hw = <0x1>; + }; + opp-800000000 { + bootph-pre-ram; + opp-hz = /bits/ 64 <800000000>; + opp-microvolt = <1350000>; + opp-supported-hw = <0x2>; + }; + }; };
&bsec { @@ -82,14 +100,10 @@ bootph-all; };
-&cpu0_opp_table { - bootph-pre-ram; - opp-650000000 { - bootph-pre-ram; - }; - opp-800000000 { - bootph-pre-ram; - }; +&cpu0 { + nvmem-cells = <&part_number_otp>; + nvmem-cell-names = "part_number"; + operating-points-v2 = <&cpu0_opp_table>; };
&gpioa {
Enable OF_UPSTREAM to use upstream DT and add st/ prefix to the DEFAULT_DEVICE_TREE. And thereby directly build DTB from dts/upstream/src/ including *-u-boot.dtsi from arch/$(ARCH)/dts/ directory.
The previous setup used generic SoC prefix like stm32mp15xx-dhco* for generic DTs which could be used on any STM32MP15xx DHSOM variant. The new setup uses specific SoC prefix stm32mp157c-dhco* to match Linux DT names. Since the hardware present on STM32MP153 and STM32MP157 is not enabled in the board configuration and not supported by U-Boot except for the DSI host, using the existing Linux DTs poses no issue even on plain STM32MP151A based SoMs.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: Patrice Chotard patrice.chotard@foss.st.com Cc: Patrick Delaunay patrick.delaunay@foss.st.com Cc: Sean Anderson seanga2@gmail.com Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com Cc: u-boot@dh-electronics.com Cc: u-boot@lists.denx.de Cc: uboot-stm32@st-md-mailman.stormreply.com --- V2: - Drop arch/arm/dts/Makefile entries - Convert stm32mp135f-dhcom-dhsbc --- arch/arm/dts/Makefile | 9 +- arch/arm/dts/stm32mp135f-dhcor-dhsbc.dts | 383 ------------ ...> stm32mp151a-dhcor-testbench-u-boot.dtsi} | 0 ...si => stm32mp153c-dhcom-drc02-u-boot.dtsi} | 0 ...stm32mp153c-dhcor-drc-compact-u-boot.dtsi} | 0 ...> stm32mp157a-dhcor-avenger96-u-boot.dtsi} | 0 ...tsi => stm32mp157c-dhcom-pdk2-u-boot.dtsi} | 0 ... => stm32mp157c-dhcom-picoitx-u-boot.dtsi} | 0 arch/arm/dts/stm32mp15xx-dhcom-drc02.dts | 17 - arch/arm/dts/stm32mp15xx-dhcom-drc02.dtsi | 169 ------ arch/arm/dts/stm32mp15xx-dhcom-pdk2.dts | 17 - arch/arm/dts/stm32mp15xx-dhcom-pdk2.dtsi | 329 ----------- arch/arm/dts/stm32mp15xx-dhcom-picoitx.dts | 17 - arch/arm/dts/stm32mp15xx-dhcom-picoitx.dtsi | 151 ----- arch/arm/dts/stm32mp15xx-dhcom-som.dtsi | 544 ------------------ arch/arm/dts/stm32mp15xx-dhcor-avenger96.dts | 20 - arch/arm/dts/stm32mp15xx-dhcor-avenger96.dtsi | 437 -------------- .../arm/dts/stm32mp15xx-dhcor-drc-compact.dts | 18 - .../dts/stm32mp15xx-dhcor-drc-compact.dtsi | 326 ----------- arch/arm/dts/stm32mp15xx-dhcor-io1v8.dtsi | 28 - arch/arm/dts/stm32mp15xx-dhcor-som.dtsi | 221 ------- arch/arm/dts/stm32mp15xx-dhcor-testbench.dts | 180 ------ .../dh_stm32mp1/u-boot-dhcom.its | 18 +- .../dh_stm32mp1/u-boot-dhcor.its | 12 +- configs/stm32mp13_dhcor_defconfig | 3 +- configs/stm32mp15_dhcom_basic_defconfig | 5 +- configs/stm32mp15_dhcor_basic_defconfig | 5 +- 27 files changed, 24 insertions(+), 2885 deletions(-) delete mode 100644 arch/arm/dts/stm32mp135f-dhcor-dhsbc.dts rename arch/arm/dts/{stm32mp15xx-dhcor-testbench-u-boot.dtsi => stm32mp151a-dhcor-testbench-u-boot.dtsi} (100%) rename arch/arm/dts/{stm32mp15xx-dhcom-drc02-u-boot.dtsi => stm32mp153c-dhcom-drc02-u-boot.dtsi} (100%) rename arch/arm/dts/{stm32mp15xx-dhcor-drc-compact-u-boot.dtsi => stm32mp153c-dhcor-drc-compact-u-boot.dtsi} (100%) rename arch/arm/dts/{stm32mp15xx-dhcor-avenger96-u-boot.dtsi => stm32mp157a-dhcor-avenger96-u-boot.dtsi} (100%) rename arch/arm/dts/{stm32mp15xx-dhcom-pdk2-u-boot.dtsi => stm32mp157c-dhcom-pdk2-u-boot.dtsi} (100%) rename arch/arm/dts/{stm32mp15xx-dhcom-picoitx-u-boot.dtsi => stm32mp157c-dhcom-picoitx-u-boot.dtsi} (100%) delete mode 100644 arch/arm/dts/stm32mp15xx-dhcom-drc02.dts delete mode 100644 arch/arm/dts/stm32mp15xx-dhcom-drc02.dtsi delete mode 100644 arch/arm/dts/stm32mp15xx-dhcom-pdk2.dts delete mode 100644 arch/arm/dts/stm32mp15xx-dhcom-pdk2.dtsi delete mode 100644 arch/arm/dts/stm32mp15xx-dhcom-picoitx.dts delete mode 100644 arch/arm/dts/stm32mp15xx-dhcom-picoitx.dtsi delete mode 100644 arch/arm/dts/stm32mp15xx-dhcom-som.dtsi delete mode 100644 arch/arm/dts/stm32mp15xx-dhcor-avenger96.dts delete mode 100644 arch/arm/dts/stm32mp15xx-dhcor-avenger96.dtsi delete mode 100644 arch/arm/dts/stm32mp15xx-dhcor-drc-compact.dts delete mode 100644 arch/arm/dts/stm32mp15xx-dhcor-drc-compact.dtsi delete mode 100644 arch/arm/dts/stm32mp15xx-dhcor-io1v8.dtsi delete mode 100644 arch/arm/dts/stm32mp15xx-dhcor-som.dtsi delete mode 100644 arch/arm/dts/stm32mp15xx-dhcor-testbench.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index d46f0bda1a8..46452d92345 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1148,7 +1148,6 @@ dtb-$(CONFIG_ASPEED_AST2600) += \ dtb-$(CONFIG_ARCH_STI) += stih410-b2260.dtb
dtb-$(CONFIG_STM32MP13X) += \ - stm32mp135f-dhcor-dhsbc.dtb \ stm32mp135f-dk.dtb
dtb-$(CONFIG_STM32MP15X) += \ @@ -1164,13 +1163,7 @@ dtb-$(CONFIG_STM32MP15X) += \ stm32mp157c-ed1-scmi.dtb \ stm32mp157c-ev1.dtb \ stm32mp157c-ev1-scmi.dtb \ - stm32mp157c-odyssey.dtb \ - stm32mp15xx-dhcom-drc02.dtb \ - stm32mp15xx-dhcom-pdk2.dtb \ - stm32mp15xx-dhcom-picoitx.dtb \ - stm32mp15xx-dhcor-avenger96.dtb \ - stm32mp15xx-dhcor-drc-compact.dtb \ - stm32mp15xx-dhcor-testbench.dtb + stm32mp157c-odyssey.dtb
dtb-$(CONFIG_STM32MP25X) += \ stm32mp257f-ev1.dtb diff --git a/arch/arm/dts/stm32mp135f-dhcor-dhsbc.dts b/arch/arm/dts/stm32mp135f-dhcor-dhsbc.dts deleted file mode 100644 index fc1c48ad56d..00000000000 --- a/arch/arm/dts/stm32mp135f-dhcor-dhsbc.dts +++ /dev/null @@ -1,383 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) -/* - * Copyright (C) 2024 Marek Vasut marex@denx.de - * - * DHCOR STM32MP13 variant: - * DHCR-STM32MP135F-C100-R051-EE-F0409-SPI4-RTC-WBT-I-01LG - * DHCOR PCB number: 718-100 or newer - * DHSBC PCB number: 719-100 or newer - */ - -/dts-v1/; - -#include <dt-bindings/regulator/st,stm32mp13-regulator.h> -#include "stm32mp135.dtsi" -#include "stm32mp13xf.dtsi" -#include "stm32mp13xx-dhcor-som.dtsi" - -/ { - model = "DH electronics STM32MP135F DHCOR DHSBC"; - compatible = "dh,stm32mp135f-dhcor-dhsbc", - "dh,stm32mp135f-dhcor-som", - "st,stm32mp135"; - - aliases { - ethernet0 = ð1; - ethernet1 = ð2; - serial2 = &usart1; - serial3 = &usart2; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; -}; - -&adc_1 { - pinctrl-names = "default"; - pinctrl-0 = <&adc1_pins_a &adc1_usb_cc_pins_b>; - vdda-supply = <&vdd_adc>; - vref-supply = <&vdd_adc>; - status = "okay"; - - adc1: adc@0 { - status = "okay"; - - /* - * Type-C USB_PWR_CC1 & USB_PWR_CC2 on in2 & in11. - * Use at least 5 * RC time, e.g. 5 * (Rp + Rd) * C: - * 5 * (5.1 + 47kOhms) * 5pF => 1.3us. - * Use arbitrary margin here (e.g. 5us). - * - * The pinmux pins must be set as ANALOG, use datasheet - * DS13483 Table 7. STM32MP135C/F ball definitions to - * find out which 'pin name' maps to which 'additional - * functions', which lists the mapping between pin and - * ADC channel. In this case, PA5 maps to ADC1_INP2 and - * PF13 maps to ADC1_INP11 . - */ - channel@2 { - reg = <2>; - st,min-sample-time-ns = <5000>; - }; - - channel@11 { - reg = <11>; - st,min-sample-time-ns = <5000>; - }; - - /* Expansion connector: INP12:pin29 */ - channel@12 { - reg = <12>; - st,min-sample-time-ns = <5000>; - }; - }; -}; - -ð1 { - status = "okay"; - pinctrl-0 = <ð1_rgmii_pins_a>; - pinctrl-1 = <ð1_rgmii_sleep_pins_a>; - pinctrl-names = "default", "sleep"; - phy-mode = "rgmii-id"; - phy-handle = <ðphy1>; - st,ext-phyclk; - nvmem-cells = <ðernet_mac1_address>; - nvmem-cell-names = "mac-address"; - - mdio1 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "snps,dwmac-mdio"; - - ethphy1: ethernet-phy@1 { - /* RTL8211F */ - compatible = "ethernet-phy-id001c.c916", - "ethernet-phy-ieee802.3-c22"; - interrupt-parent = <&gpiog>; - interrupts = <12 IRQ_TYPE_LEVEL_LOW>; - reg = <1>; - reset-assert-us = <15000>; - reset-deassert-us = <55000>; - reset-gpios = <&gpioa 11 GPIO_ACTIVE_LOW>; - }; - }; -}; - -ð2 { - status = "okay"; - pinctrl-0 = <ð2_rgmii_pins_a>; - pinctrl-1 = <ð2_rgmii_sleep_pins_a>; - pinctrl-names = "default", "sleep"; - phy-mode = "rgmii-id"; - phy-handle = <ðphy2>; - st,ext-phyclk; - nvmem-cells = <ðernet_mac2_address>; - nvmem-cell-names = "mac-address"; - - mdio1 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "snps,dwmac-mdio"; - - ethphy2: ethernet-phy@1 { - /* RTL8211F */ - compatible = "ethernet-phy-id001c.c916", - "ethernet-phy-ieee802.3-c22"; - interrupt-parent = <&gpiog>; - interrupts = <15 IRQ_TYPE_LEVEL_LOW>; - reg = <1>; - reset-assert-us = <15000>; - reset-deassert-us = <55000>; - reset-gpios = <&gpiog 8 GPIO_ACTIVE_LOW>; - }; - }; -}; - -&gpioa { - gpio-line-names = "", "", "", "", - "", "DHSBC_USB_PWR_CC1", "", "", - "", "", "", "DHSBC_nETH1_RST", - "", "DHCOR_HW-CODING_0", "", ""; -}; - -&gpiob { - gpio-line-names = "", "", "", "", - "", "", "", "DHCOR_BT_HOST_WAKE", - "", "", "", "", - "", "DHSBC_nTPM_CS", "", ""; -}; - -&gpioc { - gpio-line-names = "", "", "", "DHSBC_USB_5V_MEAS", - "", "", "", "", - "", "", "", "", - "", "", "", ""; -}; - -&gpiod { - gpio-line-names = "", "", "", "", - "", "DHCOR_RAM-CODING_0", "", "", - "", "DHCOR_RAM-CODING_1", "", "", - "", "", "", ""; -}; - -&gpioe { - gpio-line-names = "", "", "", "", - "", "", "", "", - "", "DHSBC_nTPM_RST", "", "", - "DHSBC_nTPM_PIRQ", "", "DHCOR_WL_HOST_WAKE", ""; -}; - -&gpiof { - gpio-line-names = "", "", "DHSBC_USB_PWR_nFLT", "", - "", "", "", "", - "", "", "", "", - "DHCOR_WL_REG_ON", "DHSBC_USB_PWR_CC2", "", ""; -}; - -&gpiog { - gpio-line-names = "", "", "", "", - "", "", "", "", - "DHSBC_nETH2_RST", "DHCOR_BT_DEV_WAKE", "", "", - "DHSBC_ETH1_INTB", "", "", "DHSBC_ETH2_INTB"; -}; - -&gpioi { - gpio-line-names = "DHCOR_RTC_nINT", "DHCOR_HW-CODING_1", - "DHCOR_BT_REG_ON", "DHCOR_PMIC_nINT", - "DHSBC_BOOT0", "DHSBC_BOOT1", - "DHSBC_BOOT2", "DHSBC_USB-C_DATA_VBUS"; -}; - -&i2c1 { /* Expansion connector: SDA:pin27 SCL:pin28 */ - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&i2c1_pins_a>; - pinctrl-1 = <&i2c1_sleep_pins_a>; - i2c-scl-rising-time-ns = <96>; - i2c-scl-falling-time-ns = <3>; - clock-frequency = <400000>; - status = "okay"; - /* spare dmas for other usage */ - /delete-property/dmas; - /delete-property/dma-names; -}; - -&i2c5 { /* Expansion connector: SDA:pin3 SCL:pin5 */ - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&i2c5_pins_b>; - pinctrl-1 = <&i2c5_sleep_pins_b>; - i2c-scl-rising-time-ns = <96>; - i2c-scl-falling-time-ns = <3>; - clock-frequency = <400000>; - status = "okay"; - /* spare dmas for other usage */ - /delete-property/dmas; - /delete-property/dma-names; -}; - -&m_can1 { /* Expansion connector: TX:pin16 RX:pin18 */ - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&m_can1_pins_a>; - pinctrl-1 = <&m_can1_sleep_pins_a>; - status = "okay"; -}; - -&m_can2 { /* Expansion connector: TX:pin22 RX:pin26 */ - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&m_can2_pins_a>; - pinctrl-1 = <&m_can2_sleep_pins_a>; - status = "okay"; -}; - -&pwr_regulators { - vdd-supply = <&vdd>; - vdd_3v3_usbfs-supply = <&vdd_usb>; - status = "okay"; -}; - -&sai1 { /* Expansion connector: SCK-A:pin12 FS-A:pin35 SD-A:pin38 SD-B:pin40 */ - clocks = <&rcc SAI1>, <&rcc PLL3_Q>, <&rcc PLL3_R>; - clock-names = "pclk", "x8k", "x11k"; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&sai1a_pins_a &sai1b_pins_a>; - pinctrl-1 = <&sai1a_sleep_pins_a &sai1b_sleep_pins_a>; -}; - -&scmi_voltd { - status = "disabled"; -}; - -&spi2 { - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&spi2_pins_a>; - pinctrl-1 = <&spi2_sleep_pins_a>; - cs-gpios = <&gpiob 13 0>; - status = "okay"; - - st33htph: tpm@0 { - compatible = "st,st33htpm-spi", "tcg,tpm_tis-spi"; - reg = <0>; - spi-max-frequency = <24000000>; - }; -}; - -&spi3 { /* Expansion connector: MOSI:pin19 MISO:pin21 SCK:pin22 nCS:pin24 */ - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&spi3_pins_a>; - pinctrl-1 = <&spi3_sleep_pins_a>; - cs-gpios = <&gpiof 3 0>; - status = "disabled"; -}; - -&timers5 { /* Expansion connector: CH3:pin31 */ - /delete-property/dmas; - /delete-property/dma-names; - status = "okay"; - - pwm { - pinctrl-0 = <&pwm5_pins_a>; - pinctrl-1 = <&pwm5_sleep_pins_a>; - pinctrl-names = "default", "sleep"; - status = "okay"; - }; - timer@4 { - status = "okay"; - }; -}; - -&timers13 { /* Expansion connector: CH1:pin32 */ - /delete-property/dmas; - /delete-property/dma-names; - status = "okay"; - - pwm { - pinctrl-0 = <&pwm13_pins_a>; - pinctrl-1 = <&pwm13_sleep_pins_a>; - pinctrl-names = "default", "sleep"; - status = "okay"; - }; - timer@12 { - status = "okay"; - }; -}; - -&usart1 { /* Expansion connector: RX:pin33 TX:pin37 */ - pinctrl-names = "default", "sleep", "idle"; - pinctrl-0 = <&usart1_pins_b>; - pinctrl-1 = <&usart1_sleep_pins_b>; - pinctrl-2 = <&usart1_idle_pins_b>; - status = "okay"; -}; - -&usart2 { /* Expansion connector: RX:pin10 TX:pin8 RTS:pin11 CTS:pin36 */ - pinctrl-names = "default", "sleep", "idle"; - pinctrl-0 = <&usart2_pins_b>; - pinctrl-1 = <&usart2_sleep_pins_b>; - pinctrl-2 = <&usart2_idle_pins_b>; - uart-has-rtscts; - status = "okay"; -}; - -&usbh_ehci { - phys = <&usbphyc_port0>; - status = "okay"; -}; - -&usbh_ohci { - phys = <&usbphyc_port0>; - status = "okay"; -}; - -&usbotg_hs { - dr_mode = "peripheral"; - phys = <&usbphyc_port1 0>; - phy-names = "usb2-phy"; - usb33d-supply = <&usb33>; - status = "okay"; -}; - -&usbphyc { - status = "okay"; - vdda1v1-supply = <®11>; - vdda1v8-supply = <®18>; -}; - -&usbphyc_port0 { - phy-supply = <&vdd_usb>; - st,current-boost-microamp = <1000>; - st,decrease-hs-slew-rate; - st,tune-hs-dc-level = <2>; - st,enable-hs-rftime-reduction; - st,trim-hs-current = <11>; - st,trim-hs-impedance = <2>; - st,tune-squelch-level = <1>; - st,enable-hs-rx-gain-eq; - st,no-hs-ftime-ctrl; - st,no-lsfs-sc; - connector { - compatible = "usb-a-connector"; - vbus-supply = <&vbus_sw>; - }; -}; - -&usbphyc_port1 { - phy-supply = <&vdd_usb>; - st,current-boost-microamp = <1000>; - st,decrease-hs-slew-rate; - st,tune-hs-dc-level = <2>; - st,enable-hs-rftime-reduction; - st,trim-hs-current = <11>; - st,trim-hs-impedance = <2>; - st,tune-squelch-level = <1>; - st,enable-hs-rx-gain-eq; - st,no-hs-ftime-ctrl; - st,no-lsfs-sc; - connector { - compatible = "gpio-usb-b-connector", "usb-b-connector"; - vbus-gpios = <&gpioi 7 GPIO_ACTIVE_HIGH>; - label = "Type-C"; - self-powered; - type = "micro"; - }; -}; diff --git a/arch/arm/dts/stm32mp15xx-dhcor-testbench-u-boot.dtsi b/arch/arm/dts/stm32mp151a-dhcor-testbench-u-boot.dtsi similarity index 100% rename from arch/arm/dts/stm32mp15xx-dhcor-testbench-u-boot.dtsi rename to arch/arm/dts/stm32mp151a-dhcor-testbench-u-boot.dtsi diff --git a/arch/arm/dts/stm32mp15xx-dhcom-drc02-u-boot.dtsi b/arch/arm/dts/stm32mp153c-dhcom-drc02-u-boot.dtsi similarity index 100% rename from arch/arm/dts/stm32mp15xx-dhcom-drc02-u-boot.dtsi rename to arch/arm/dts/stm32mp153c-dhcom-drc02-u-boot.dtsi diff --git a/arch/arm/dts/stm32mp15xx-dhcor-drc-compact-u-boot.dtsi b/arch/arm/dts/stm32mp153c-dhcor-drc-compact-u-boot.dtsi similarity index 100% rename from arch/arm/dts/stm32mp15xx-dhcor-drc-compact-u-boot.dtsi rename to arch/arm/dts/stm32mp153c-dhcor-drc-compact-u-boot.dtsi diff --git a/arch/arm/dts/stm32mp15xx-dhcor-avenger96-u-boot.dtsi b/arch/arm/dts/stm32mp157a-dhcor-avenger96-u-boot.dtsi similarity index 100% rename from arch/arm/dts/stm32mp15xx-dhcor-avenger96-u-boot.dtsi rename to arch/arm/dts/stm32mp157a-dhcor-avenger96-u-boot.dtsi diff --git a/arch/arm/dts/stm32mp15xx-dhcom-pdk2-u-boot.dtsi b/arch/arm/dts/stm32mp157c-dhcom-pdk2-u-boot.dtsi similarity index 100% rename from arch/arm/dts/stm32mp15xx-dhcom-pdk2-u-boot.dtsi rename to arch/arm/dts/stm32mp157c-dhcom-pdk2-u-boot.dtsi diff --git a/arch/arm/dts/stm32mp15xx-dhcom-picoitx-u-boot.dtsi b/arch/arm/dts/stm32mp157c-dhcom-picoitx-u-boot.dtsi similarity index 100% rename from arch/arm/dts/stm32mp15xx-dhcom-picoitx-u-boot.dtsi rename to arch/arm/dts/stm32mp157c-dhcom-picoitx-u-boot.dtsi diff --git a/arch/arm/dts/stm32mp15xx-dhcom-drc02.dts b/arch/arm/dts/stm32mp15xx-dhcom-drc02.dts deleted file mode 100644 index 90625bf6b60..00000000000 --- a/arch/arm/dts/stm32mp15xx-dhcom-drc02.dts +++ /dev/null @@ -1,17 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause -/* - * Copyright (C) 2020 Marek Vasut marex@denx.de - */ -/dts-v1/; - -#include "stm32mp151.dtsi" -#include "stm32mp15xc.dtsi" -#include "stm32mp15xx-dhcom-som.dtsi" -#include "stm32mp15xx-dhcom-drc02.dtsi" - -/ { - model = "DH Electronics STM32MP15xx DHCOM DRC02"; - compatible = "dh,stm32mp15xx-dhcom-drc02", - "dh,stm32mp15xx-dhcom-som", - "st,stm32mp1xx"; -}; diff --git a/arch/arm/dts/stm32mp15xx-dhcom-drc02.dtsi b/arch/arm/dts/stm32mp15xx-dhcom-drc02.dtsi deleted file mode 100644 index 35b1034aa3c..00000000000 --- a/arch/arm/dts/stm32mp15xx-dhcom-drc02.dtsi +++ /dev/null @@ -1,169 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause -/* - * Copyright (C) 2020 Marek Vasut marex@denx.de - */ - -#include <dt-bindings/input/input.h> -#include <dt-bindings/pwm/pwm.h> - -/ { - aliases { - serial0 = &uart4; - serial1 = &usart3; - serial2 = &uart8; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; -}; - -&adc { - status = "disabled"; -}; - -&dac { - status = "disabled"; -}; - -&gpiob { - /* - * NOTE: On DRC02, the RS485_RX_En is controlled by a separate - * GPIO line, however the STM32 UART driver assumes RX happens - * during TX anyway and that it only controls drive enable DE - * line. Hence, the RX is always enabled here. - */ - rs485-rx-en-hog { - gpio-hog; - gpios = <8 0>; - output-low; - line-name = "rs485-rx-en"; - }; -}; - -&gpiod { - gpio-line-names = "", "", "", "", - "", "", "DHCOM-B", "", - "", "", "", "DRC02-Out1", - "DRC02-Out2", "", "", ""; -}; - -&gpioi { - gpio-line-names = "DRC02-In1", "DHCOM-O", "DHCOM-H", "DHCOM-I", - "DHCOM-R", "DHCOM-M", "", "", - "DRC02-In2", "", "", "", - "", "", "", ""; - - /* - * NOTE: The USB Hub on the DRC02 needs a reset signal to be - * pulled high in order to be detected by the USB Controller. - * This signal should be handled by USB power sequencing in - * order to reset the Hub when USB bus is powered down, but - * so far there is no such functionality. - */ - usb-hub-hog { - gpio-hog; - gpios = <2 0>; - output-high; - line-name = "usb-hub-reset"; - }; -}; - -&i2c2 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c2_pins_a>; - i2c-scl-rising-time-ns = <185>; - i2c-scl-falling-time-ns = <20>; - status = "okay"; - /* spare dmas for other usage */ - /delete-property/dmas; - /delete-property/dma-names; - status = "okay"; - - eeprom@50 { - compatible = "atmel,24c04"; - reg = <0x50>; - pagesize = <16>; - }; -}; - -&i2c4 { - touchscreen@49 { - status = "disabled"; - }; -}; - -&i2c5 { /* TP7/TP8 */ - pinctrl-names = "default"; - pinctrl-0 = <&i2c5_pins_a>; - i2c-scl-rising-time-ns = <185>; - i2c-scl-falling-time-ns = <20>; - status = "okay"; - /* spare dmas for other usage */ - /delete-property/dmas; - /delete-property/dma-names; -}; - -&sdmmc3 { - /* - * On DRC02, the SoM does not have SDIO WiFi. The pins - * are used for on-board microSD slot instead. - */ - /delete-property/broken-cd; - cd-gpios = <&gpioi 10 GPIO_ACTIVE_HIGH>; - disable-wp; -}; - -&spi1 { - pinctrl-names = "default"; - pinctrl-0 = <&spi1_pins_a>; - cs-gpios = <&gpioz 3 0>; - /* Use PIO for the display */ - /delete-property/dmas; - /delete-property/dma-names; - status = "disabled"; /* Enable once there is display driver */ - /* - * Note: PF3/GPIO_A , PD6/GPIO_B , PG0/GPIO_C , PC6/GPIO_E are - * also connected to the display board connector. - */ -}; - -&usart3 { - pinctrl-names = "default"; - pinctrl-0 = <&usart3_pins_a>; - /delete-property/dmas; - /delete-property/dma-names; - status = "okay"; -}; - -/* - * Note: PI3 is UART1_RTS and PI5 is UART1_CTS on DRC02 (uart4 of STM32MP1), - * however the STM32MP1 pinmux cannot map them to UART4 . - */ - -&uart8 { /* RS485 */ - linux,rs485-enabled-at-boot-time; - pinctrl-names = "default"; - pinctrl-0 = <&uart8_pins_a>; - rts-gpios = <&gpioe 6 GPIO_ACTIVE_HIGH>; - /delete-property/dmas; - /delete-property/dma-names; - status = "okay"; -}; - -&usbh_ehci { - phys = <&usbphyc_port0>; - status = "okay"; -}; - -&usbphyc { - status = "okay"; -}; - -&usbphyc_port0 { - phy-supply = <&vdd_usb>; -}; - -&usbphyc_port1 { - phy-supply = <&vdd_usb>; -}; diff --git a/arch/arm/dts/stm32mp15xx-dhcom-pdk2.dts b/arch/arm/dts/stm32mp15xx-dhcom-pdk2.dts deleted file mode 100644 index b2e450aa13b..00000000000 --- a/arch/arm/dts/stm32mp15xx-dhcom-pdk2.dts +++ /dev/null @@ -1,17 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause -/* - * Copyright (C) 2019 Marek Vasut marex@denx.de - */ -/dts-v1/; - -#include "stm32mp151.dtsi" -#include "stm32mp15xc.dtsi" -#include "stm32mp15xx-dhcom-som.dtsi" -#include "stm32mp15xx-dhcom-pdk2.dtsi" - -/ { - model = "STMicroelectronics STM32MP15xx DHCOM Premium Developer Kit (2)"; - compatible = "dh,stm32mp15xx-dhcom-pdk2", - "dh,stm32mp15xx-dhcom-som", - "st,stm32mp15x"; -}; diff --git a/arch/arm/dts/stm32mp15xx-dhcom-pdk2.dtsi b/arch/arm/dts/stm32mp15xx-dhcom-pdk2.dtsi deleted file mode 100644 index 5f586f02406..00000000000 --- a/arch/arm/dts/stm32mp15xx-dhcom-pdk2.dtsi +++ /dev/null @@ -1,329 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause -/* - * Copyright (C) 2019-2020 Marek Vasut marex@denx.de - */ - -#include <dt-bindings/input/input.h> -#include <dt-bindings/pwm/pwm.h> - -/ { - aliases { - serial0 = &uart4; - serial1 = &usart3; - serial2 = &uart8; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - clk_ext_audio_codec: clock-codec { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <24000000>; - }; - - display_bl: display-bl { - compatible = "pwm-backlight"; - pwms = <&pwm2 3 500000 PWM_POLARITY_INVERTED>; - brightness-levels = <0 16 22 30 40 55 75 102 138 188 255>; - default-brightness-level = <8>; - enable-gpios = <&gpioi 0 GPIO_ACTIVE_HIGH>; - power-supply = <®_panel_bl>; - status = "okay"; - }; - - gpio-keys-polled { - compatible = "gpio-keys-polled"; - poll-interval = <20>; - - /* - * The EXTi IRQ line 3 is shared with ethernet, - * so mark this as polled GPIO key. - */ - button-0 { - label = "TA1-GPIO-A"; - linux,code = <KEY_A>; - gpios = <&gpiof 3 GPIO_ACTIVE_LOW>; - }; - - /* - * The EXTi IRQ line 6 is shared with touchscreen, - * so mark this as polled GPIO key. - */ - button-1 { - label = "TA2-GPIO-B"; - linux,code = <KEY_B>; - gpios = <&gpiod 6 GPIO_ACTIVE_LOW>; - }; - - /* - * The EXTi IRQ line 0 is shared with PMIC, - * so mark this as polled GPIO key. - */ - button-2 { - label = "TA3-GPIO-C"; - linux,code = <KEY_C>; - gpios = <&gpiog 0 GPIO_ACTIVE_LOW>; - }; - }; - - gpio-keys { - compatible = "gpio-keys"; - - button-3 { - label = "TA4-GPIO-D"; - linux,code = <KEY_D>; - gpios = <&gpiod 12 GPIO_ACTIVE_LOW>; - wakeup-source; - }; - }; - - led { - compatible = "gpio-leds"; - - led-0 { - label = "green:led5"; - gpios = <&gpioc 6 GPIO_ACTIVE_HIGH>; - default-state = "off"; - status = "disabled"; - }; - - led-1 { - label = "green:led6"; - gpios = <&gpiod 11 GPIO_ACTIVE_HIGH>; - default-state = "off"; - }; - - led-2 { - label = "green:led7"; - gpios = <&gpioi 2 GPIO_ACTIVE_HIGH>; - default-state = "off"; - }; - - led-3 { - label = "green:led8"; - gpios = <&gpioi 3 GPIO_ACTIVE_HIGH>; - default-state = "off"; - }; - }; - - panel { - compatible = "edt,etm0700g0edh6"; - backlight = <&display_bl>; - power-supply = <®_panel_bl>; - - port { - lcd_panel_in: endpoint { - remote-endpoint = <&lcd_display_out>; - }; - }; - }; - - reg_panel_bl: regulator-panel-bl { - compatible = "regulator-fixed"; - regulator-name = "panel_backlight"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <®_panel_supply>; - }; - - reg_panel_supply: regulator-panel-supply { - compatible = "regulator-fixed"; - regulator-name = "panel_supply"; - regulator-min-microvolt = <24000000>; - regulator-max-microvolt = <24000000>; - }; - - sound { - compatible = "audio-graph-card"; - routing = - "MIC_IN", "Capture", - "Capture", "Mic Bias", - "Playback", "HP_OUT"; - dais = <&sai2a_port &sai2b_port>; - status = "okay"; - }; -}; - -&cec { - pinctrl-names = "default"; - pinctrl-0 = <&cec_pins_a>; - status = "okay"; -}; - -&i2c2 { /* Header X22 */ - pinctrl-names = "default"; - pinctrl-0 = <&i2c2_pins_a>; - i2c-scl-rising-time-ns = <185>; - i2c-scl-falling-time-ns = <20>; - status = "okay"; - /* spare dmas for other usage */ - /delete-property/dmas; - /delete-property/dma-names; - status = "okay"; -}; - -&i2c5 { /* Header X21 */ - pinctrl-names = "default"; - pinctrl-0 = <&i2c5_pins_a>; - i2c-scl-rising-time-ns = <185>; - i2c-scl-falling-time-ns = <20>; - status = "okay"; - /* spare dmas for other usage */ - /delete-property/dmas; - /delete-property/dma-names; - - sgtl5000: codec@a { - compatible = "fsl,sgtl5000"; - reg = <0x0a>; - #sound-dai-cells = <0>; - clocks = <&clk_ext_audio_codec>; - VDDA-supply = <&v3v3>; - VDDIO-supply = <&vdd>; - - sgtl5000_port: port { - #address-cells = <1>; - #size-cells = <0>; - - sgtl5000_tx_endpoint: endpoint@0 { - reg = <0>; - remote-endpoint = <&sai2a_endpoint>; - frame-master = <&sgtl5000_tx_endpoint>; - bitclock-master = <&sgtl5000_tx_endpoint>; - }; - - sgtl5000_rx_endpoint: endpoint@1 { - reg = <1>; - remote-endpoint = <&sai2b_endpoint>; - frame-master = <&sgtl5000_rx_endpoint>; - bitclock-master = <&sgtl5000_rx_endpoint>; - }; - }; - - }; - - touchscreen@38 { - compatible = "edt,edt-ft5406"; - reg = <0x38>; - interrupt-parent = <&gpioc>; - interrupts = <6 IRQ_TYPE_EDGE_FALLING>; /* GPIO E */ - }; -}; - -<dc { - pinctrl-names = "default", "sleep"; - pinctrl-0 = <<dc_pins_b>; - pinctrl-1 = <<dc_sleep_pins_b>; - status = "okay"; - - port { - lcd_display_out: endpoint { - remote-endpoint = <&lcd_panel_in>; - }; - }; -}; - -&sai2 { - clocks = <&rcc SAI2>, <&rcc PLL3_Q>, <&rcc PLL3_R>; - clock-names = "pclk", "x8k", "x11k"; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&sai2a_pins_b &sai2b_pins_b>; - pinctrl-1 = <&sai2a_sleep_pins_b &sai2b_sleep_pins_b>; - status = "okay"; - - sai2a: audio-controller@4400b004 { - #clock-cells = <0>; - dma-names = "tx"; - clocks = <&rcc SAI2_K>; - clock-names = "sai_ck"; - status = "okay"; - - sai2a_port: port { - sai2a_endpoint: endpoint { - remote-endpoint = <&sgtl5000_tx_endpoint>; - format = "i2s"; - mclk-fs = <512>; - dai-tdm-slot-num = <2>; - dai-tdm-slot-width = <16>; - }; - }; - }; - - sai2b: audio-controller@4400b024 { - dma-names = "rx"; - st,sync = <&sai2a 2>; - clocks = <&rcc SAI2_K>, <&sai2a>; - clock-names = "sai_ck", "MCLK"; - status = "okay"; - - sai2b_port: port { - sai2b_endpoint: endpoint { - remote-endpoint = <&sgtl5000_rx_endpoint>; - format = "i2s"; - mclk-fs = <512>; - dai-tdm-slot-num = <2>; - dai-tdm-slot-width = <16>; - }; - }; - }; -}; - -&timers2 { - /* spare dmas for other usage (un-delete to enable pwm capture) */ - /delete-property/dmas; - /delete-property/dma-names; - status = "okay"; - pwm2: pwm { - pinctrl-0 = <&pwm2_pins_a>; - pinctrl-names = "default"; - status = "okay"; - }; - timer@1 { - status = "okay"; - }; -}; - -&usart3 { - pinctrl-names = "default"; - pinctrl-0 = <&usart3_pins_a>; - /delete-property/dmas; - /delete-property/dma-names; - status = "okay"; -}; - -&uart8 { - pinctrl-names = "default"; - pinctrl-0 = <&uart8_pins_a &uart8_rtscts_pins_a>; - uart-has-rtscts; - /delete-property/dmas; - /delete-property/dma-names; - status = "okay"; -}; - -&usbh_ehci { - phys = <&usbphyc_port0>; - status = "okay"; -}; - -&usbotg_hs { - dr_mode = "otg"; - pinctrl-0 = <&usbotg_hs_pins_a>; - pinctrl-names = "default"; - phy-names = "usb2-phy"; - phys = <&usbphyc_port1 0>; - vbus-supply = <&vbus_otg>; - status = "okay"; -}; - -&usbphyc { - status = "okay"; -}; - -&usbphyc_port0 { - phy-supply = <&vdd_usb>; -}; - -&usbphyc_port1 { - phy-supply = <&vdd_usb>; -}; diff --git a/arch/arm/dts/stm32mp15xx-dhcom-picoitx.dts b/arch/arm/dts/stm32mp15xx-dhcom-picoitx.dts deleted file mode 100644 index 3e908102f61..00000000000 --- a/arch/arm/dts/stm32mp15xx-dhcom-picoitx.dts +++ /dev/null @@ -1,17 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause -/* - * Copyright (C) 2020 Marek Vasut marex@denx.de - */ -/dts-v1/; - -#include "stm32mp157.dtsi" -#include "stm32mp15xc.dtsi" -#include "stm32mp15xx-dhcom-som.dtsi" -#include "stm32mp15xx-dhcom-picoitx.dtsi" - -/ { - model = "DH Electronics STM32MP15xx DHCOM PicoITX"; - compatible = "dh,stm32mp15xx-dhcom-picoitx", - "dh,stm32mp15xx-dhcom-som", - "st,stm32mp1xx"; -}; diff --git a/arch/arm/dts/stm32mp15xx-dhcom-picoitx.dtsi b/arch/arm/dts/stm32mp15xx-dhcom-picoitx.dtsi deleted file mode 100644 index abc595350e7..00000000000 --- a/arch/arm/dts/stm32mp15xx-dhcom-picoitx.dtsi +++ /dev/null @@ -1,151 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause -/* - * Copyright (C) 2020 Marek Vasut marex@denx.de - */ - -#include <dt-bindings/input/input.h> -#include <dt-bindings/pwm/pwm.h> - -/ { - aliases { - serial0 = &uart4; - serial1 = &usart3; - serial2 = &uart8; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - led { - compatible = "gpio-leds"; - - led-0 { - label = "yellow:led"; - gpios = <&gpioi 3 GPIO_ACTIVE_HIGH>; - default-state = "off"; - }; - }; -}; - -&adc { - status = "disabled"; -}; - -&dac { - status = "disabled"; -}; - -&fmc { - status = "disabled"; -}; - -&gpioa { - /* - * NOTE: The USB Port on the PicoITX needs a PWR_EN signal to enable - * port power. This signal should be handled by USB power sequencing - * in order to turn on port power when USB bus is powered up, but so - * far there is no such functionality. - */ - usb-port-power-hog { - gpio-hog; - gpios = <13 0>; - output-low; - line-name = "usb-port-power"; - }; -}; - -&gpioc { - gpio-line-names = "", "", "", "", - "", "", "PicoITX-In1", "", - "", "", "", "", - "", "", "", ""; -}; - -&gpiod { - gpio-line-names = "", "", "", "", - "", "", "DHCOM-B", "", - "", "", "", "PicoITX-Out1", - "PicoITX-Out2", "", "", ""; -}; - -&gpiog { - gpio-line-names = "PicoITX-In2", "", "", "", - "", "", "", "", - "DHCOM-L", "", "", "", - "", "", "", ""; -}; - -&i2c2 { /* On board-to-board connector (optional) */ - pinctrl-names = "default"; - pinctrl-0 = <&i2c2_pins_a>; - i2c-scl-rising-time-ns = <185>; - i2c-scl-falling-time-ns = <20>; - status = "okay"; - /* spare dmas for other usage */ - /delete-property/dmas; - /delete-property/dma-names; -}; - -&i2c5 { /* On board-to-board connector */ - pinctrl-names = "default"; - pinctrl-0 = <&i2c5_pins_a>; - i2c-scl-rising-time-ns = <185>; - i2c-scl-falling-time-ns = <20>; - status = "okay"; - /* spare dmas for other usage */ - /delete-property/dmas; - /delete-property/dma-names; -}; - -&ksz8851 { - status = "disabled"; -}; - -&usart3 { - pinctrl-names = "default"; - pinctrl-0 = <&usart3_pins_a>; - /delete-property/dmas; - /delete-property/dma-names; - status = "okay"; -}; - -&uart8 { - pinctrl-names = "default"; - pinctrl-0 = <&uart8_pins_a &uart8_rtscts_pins_a>; - /delete-property/dmas; - /delete-property/dma-names; - status = "okay"; -}; - -&usbh_ehci { - phys = <&usbphyc_port0>; - status = "okay"; -}; - -&usbh_ohci { - phys = <&usbphyc_port0>; - status = "okay"; -}; - -&usbotg_hs { - dr_mode = "otg"; - pinctrl-0 = <&usbotg_hs_pins_a>; - pinctrl-names = "default"; - phy-names = "usb2-phy"; - phys = <&usbphyc_port1 0>; - vbus-supply = <&vbus_otg>; - status = "okay"; -}; - -&usbphyc { - status = "okay"; -}; - -&usbphyc_port0 { - phy-supply = <&vdd_usb>; -}; - -&usbphyc_port1 { - phy-supply = <&vdd_usb>; -}; diff --git a/arch/arm/dts/stm32mp15xx-dhcom-som.dtsi b/arch/arm/dts/stm32mp15xx-dhcom-som.dtsi deleted file mode 100644 index d3b85a8764d..00000000000 --- a/arch/arm/dts/stm32mp15xx-dhcom-som.dtsi +++ /dev/null @@ -1,544 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) -/* - * Copyright (C) 2019-2020 Marek Vasut marex@denx.de - */ - -#include "stm32mp15-pinctrl.dtsi" -#include "stm32mp15xxaa-pinctrl.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/mfd/st,stpmic1.h> - -/ { - aliases { - ethernet0 = ðernet0; - ethernet1 = &ksz8851; - rtc0 = &hwrtc; - rtc1 = &rtc; - }; - - memory@c0000000 { - device_type = "memory"; - reg = <0xC0000000 0x40000000>; - }; - - reserved-memory { - #address-cells = <1>; - #size-cells = <1>; - ranges; - - mcuram2: mcuram2@10000000 { - compatible = "shared-dma-pool"; - reg = <0x10000000 0x40000>; - no-map; - }; - - vdev0vring0: vdev0vring0@10040000 { - compatible = "shared-dma-pool"; - reg = <0x10040000 0x1000>; - no-map; - }; - - vdev0vring1: vdev0vring1@10041000 { - compatible = "shared-dma-pool"; - reg = <0x10041000 0x1000>; - no-map; - }; - - vdev0buffer: vdev0buffer@10042000 { - compatible = "shared-dma-pool"; - reg = <0x10042000 0x4000>; - no-map; - }; - - mcuram: mcuram@30000000 { - compatible = "shared-dma-pool"; - reg = <0x30000000 0x40000>; - no-map; - }; - - retram: retram@38000000 { - compatible = "shared-dma-pool"; - reg = <0x38000000 0x10000>; - no-map; - }; - }; - - ethernet_vio: vioregulator { - compatible = "regulator-fixed"; - regulator-name = "vio"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - gpio = <&gpiog 3 GPIO_ACTIVE_LOW>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vdd>; - }; -}; - -&adc { - vdd-supply = <&vdd>; - vdda-supply = <&vdda>; - vref-supply = <&vdda>; - status = "okay"; - - adc1: adc@0 { - st,min-sample-time-nsecs = <5000>; - st,adc-channels = <0>; - status = "okay"; - }; - - adc2: adc@100 { - st,adc-channels = <1>; - st,min-sample-time-nsecs = <5000>; - status = "okay"; - }; -}; - -&crc1 { - status = "okay"; -}; - -&dac { - pinctrl-names = "default"; - pinctrl-0 = <&dac_ch1_pins_a &dac_ch2_pins_a>; - vref-supply = <&vdda>; - status = "okay"; - - dac1: dac@1 { - status = "okay"; - }; - dac2: dac@2 { - status = "okay"; - }; -}; - -&dts { - status = "okay"; -}; - -ðernet0 { - status = "okay"; - pinctrl-0 = <ðernet0_rmii_pins_c &mco2_pins_a>; - pinctrl-1 = <ðernet0_rmii_sleep_pins_c &mco2_sleep_pins_a>; - pinctrl-names = "default", "sleep"; - phy-mode = "rmii"; - max-speed = <100>; - phy-handle = <&phy0>; - - mdio0 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "snps,dwmac-mdio"; - - phy0: ethernet-phy@1 { - reg = <1>; - /* LAN8710Ai */ - compatible = "ethernet-phy-id0007.c0f0", - "ethernet-phy-ieee802.3-c22"; - clocks = <&rcc CK_MCO2>; - reset-gpios = <&gpioh 3 GPIO_ACTIVE_LOW>; - reset-assert-us = <500>; - reset-deassert-us = <500>; - smsc,disable-energy-detect; - interrupt-parent = <&gpioi>; - interrupts = <11 IRQ_TYPE_LEVEL_LOW>; - }; - }; -}; - -&fmc { - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&fmc_pins_b>; - pinctrl-1 = <&fmc_sleep_pins_b>; - status = "okay"; - - ksz8851: ethernet@1,0 { - compatible = "micrel,ks8851-mll"; - reg = <1 0x0 0x2>, <1 0x2 0x20000>; - interrupt-parent = <&gpioc>; - interrupts = <3 IRQ_TYPE_LEVEL_LOW>; - bank-width = <2>; - - /* Timing values are in nS */ - st,fmc2-ebi-cs-mux-enable; - st,fmc2-ebi-cs-transaction-type = <4>; - st,fmc2-ebi-cs-buswidth = <16>; - st,fmc2-ebi-cs-address-setup-ns = <5>; - st,fmc2-ebi-cs-address-hold-ns = <5>; - st,fmc2-ebi-cs-bus-turnaround-ns = <5>; - st,fmc2-ebi-cs-data-setup-ns = <45>; - st,fmc2-ebi-cs-data-hold-ns = <1>; - st,fmc2-ebi-cs-write-address-setup-ns = <5>; - st,fmc2-ebi-cs-write-address-hold-ns = <5>; - st,fmc2-ebi-cs-write-bus-turnaround-ns = <5>; - st,fmc2-ebi-cs-write-data-setup-ns = <45>; - st,fmc2-ebi-cs-write-data-hold-ns = <1>; - }; -}; - -&gpioa { - gpio-line-names = "", "", "", "", - "", "", "DHCOM-K", "", - "", "", "", "", - "", "", "", ""; -}; - -&gpiob { - gpio-line-names = "", "", "", "", - "", "", "", "", - "DHCOM-Q", "", "", "", - "", "", "", ""; -}; - -&gpioc { - gpio-line-names = "", "", "", "", - "", "", "DHCOM-E", "", - "", "", "", "", - "", "", "", ""; -}; - -&gpiod { - gpio-line-names = "", "", "", "", - "", "", "DHCOM-B", "", - "", "", "", "DHCOM-F", - "DHCOM-D", "", "", ""; -}; - -&gpioe { - gpio-line-names = "", "", "", "", - "", "", "DHCOM-P", "", - "", "", "", "", - "", "", "", ""; -}; - -&gpiof { - gpio-line-names = "", "", "", "DHCOM-A", - "", "", "", "", - "", "", "", "", - "", "", "", ""; -}; - -&gpiog { - gpio-line-names = "DHCOM-C", "", "", "", - "", "", "", "", - "DHCOM-L", "", "", "", - "", "", "", ""; -}; - -&gpioh { - gpio-line-names = "", "", "", "", - "", "", "", "DHCOM-N", - "DHCOM-J", "DHCOM-W", "DHCOM-V", "DHCOM-U", - "DHCOM-T", "", "DHCOM-S", ""; -}; - -&gpioi { - gpio-line-names = "DHCOM-G", "DHCOM-O", "DHCOM-H", "DHCOM-I", - "DHCOM-R", "DHCOM-M", "", "", - "", "", "", "", - "", "", "", ""; -}; - -&i2c4 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c4_pins_a>; - i2c-scl-rising-time-ns = <185>; - i2c-scl-falling-time-ns = <20>; - status = "okay"; - /* spare dmas for other usage */ - /delete-property/dmas; - /delete-property/dma-names; - - hwrtc: rtc@32 { - compatible = "microcrystal,rv8803"; - reg = <0x32>; - }; - - pmic: stpmic@33 { - compatible = "st,stpmic1"; - reg = <0x33>; - interrupts-extended = <&gpioa 0 IRQ_TYPE_EDGE_FALLING>; - interrupt-controller; - #interrupt-cells = <2>; - status = "okay"; - - regulators { - compatible = "st,stpmic1-regulators"; - ldo1-supply = <&v3v3>; - ldo2-supply = <&v3v3>; - ldo3-supply = <&vdd_ddr>; - ldo5-supply = <&v3v3>; - ldo6-supply = <&v3v3>; - pwr_sw1-supply = <&bst_out>; - pwr_sw2-supply = <&bst_out>; - - vddcore: buck1 { - regulator-name = "vddcore"; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1350000>; - regulator-always-on; - regulator-initial-mode = <0>; - regulator-over-current-protection; - }; - - vdd_ddr: buck2 { - regulator-name = "vdd_ddr"; - regulator-min-microvolt = <1350000>; - regulator-max-microvolt = <1350000>; - regulator-always-on; - regulator-initial-mode = <0>; - regulator-over-current-protection; - }; - - vdd: buck3 { - regulator-name = "vdd"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - st,mask-reset; - regulator-initial-mode = <0>; - regulator-over-current-protection; - }; - - v3v3: buck4 { - regulator-name = "v3v3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - regulator-over-current-protection; - regulator-initial-mode = <0>; - }; - - vdda: ldo1 { - regulator-name = "vdda"; - regulator-always-on; - regulator-min-microvolt = <2900000>; - regulator-max-microvolt = <2900000>; - interrupts = <IT_CURLIM_LDO1 0>; - }; - - v2v8: ldo2 { - regulator-name = "v2v8"; - regulator-min-microvolt = <2800000>; - regulator-max-microvolt = <2800000>; - interrupts = <IT_CURLIM_LDO2 0>; - }; - - vtt_ddr: ldo3 { - regulator-name = "vtt_ddr"; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <750000>; - regulator-always-on; - regulator-over-current-protection; - }; - - vdd_usb: ldo4 { - regulator-name = "vdd_usb"; - interrupts = <IT_CURLIM_LDO4 0>; - }; - - vdd_sd: ldo5 { - regulator-name = "vdd_sd"; - regulator-min-microvolt = <2900000>; - regulator-max-microvolt = <2900000>; - interrupts = <IT_CURLIM_LDO5 0>; - regulator-boot-on; - }; - - v1v8: ldo6 { - regulator-name = "v1v8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - interrupts = <IT_CURLIM_LDO6 0>; - }; - - vref_ddr: vref_ddr { - regulator-name = "vref_ddr"; - regulator-always-on; - }; - - bst_out: boost { - regulator-name = "bst_out"; - interrupts = <IT_OCP_BOOST 0>; - }; - - vbus_otg: pwr_sw1 { - regulator-name = "vbus_otg"; - interrupts = <IT_OCP_OTG 0>; - }; - - vbus_sw: pwr_sw2 { - regulator-name = "vbus_sw"; - interrupts = <IT_OCP_SWOUT 0>; - regulator-active-discharge = <1>; - }; - }; - - onkey { - compatible = "st,stpmic1-onkey"; - interrupts = <IT_PONKEY_F 0>, <IT_PONKEY_R 0>; - interrupt-names = "onkey-falling", "onkey-rising"; - power-off-time-sec = <10>; - status = "okay"; - }; - - watchdog { - compatible = "st,stpmic1-wdt"; - status = "disabled"; - }; - }; - - touchscreen@49 { - compatible = "ti,tsc2004"; - reg = <0x49>; - vio-supply = <&v3v3>; - interrupts-extended = <&gpioh 15 IRQ_TYPE_EDGE_FALLING>; - }; - - eeprom@50 { - compatible = "atmel,24c02"; - reg = <0x50>; - pagesize = <16>; - }; -}; - -&ipcc { - status = "okay"; -}; - -&iwdg2 { - timeout-sec = <32>; - status = "okay"; -}; - -&m4_rproc { - memory-region = <&retram>, <&mcuram>, <&mcuram2>, <&vdev0vring0>, - <&vdev0vring1>, <&vdev0buffer>; - mboxes = <&ipcc 0>, <&ipcc 1>, <&ipcc 2>; - mbox-names = "vq0", "vq1", "shutdown"; - interrupt-parent = <&exti>; - interrupts = <68 1>; - status = "okay"; -}; - -&pwr_regulators { - vdd-supply = <&vdd>; - vdd_3v3_usbfs-supply = <&vdd_usb>; -}; - -&qspi { - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&qspi_clk_pins_a - &qspi_bk1_pins_a - &qspi_cs1_pins_a>; - pinctrl-1 = <&qspi_clk_sleep_pins_a - &qspi_bk1_sleep_pins_a - &qspi_cs1_sleep_pins_a>; - reg = <0x58003000 0x1000>, <0x70000000 0x4000000>; - #address-cells = <1>; - #size-cells = <0>; - status = "okay"; - - flash0: flash@0 { - compatible = "jedec,spi-nor"; - reg = <0>; - spi-rx-bus-width = <4>; - spi-max-frequency = <108000000>; - #address-cells = <1>; - #size-cells = <1>; - }; -}; - -&rcc { - /* Connect MCO2 output to ETH_RX_CLK input via pad-pad connection */ - clocks = <&rcc CK_MCO2>; - clock-names = "ETH_RX_CLK/ETH_REF_CLK"; - - /* - * Set PLL4P output to 100 MHz to supply SDMMC with faster clock, - * set MCO2 output to 50 MHz to supply ETHRX clock with PLL4P/2, - * so that MCO2 behaves as a divider for the ETHRX clock here. - */ - assigned-clocks = <&rcc CK_MCO2>, <&rcc PLL4_P>; - assigned-clock-parents = <&rcc PLL4_P>; - assigned-clock-rates = <50000000>, <100000000>; -}; - -&rng1 { - status = "okay"; -}; - -&rtc { - status = "okay"; -}; - -&sdmmc1 { - pinctrl-names = "default", "opendrain", "sleep", "init"; - pinctrl-0 = <&sdmmc1_b4_pins_a &sdmmc1_dir_pins_a>; - pinctrl-1 = <&sdmmc1_b4_od_pins_a &sdmmc1_dir_pins_a>; - pinctrl-2 = <&sdmmc1_b4_sleep_pins_a &sdmmc1_dir_sleep_pins_a>; - pinctrl-3 = <&sdmmc1_b4_init_pins_a &sdmmc1_dir_init_pins_a>; - cd-gpios = <&gpiog 1 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>; - disable-wp; - st,sig-dir; - st,neg-edge; - st,use-ckin; - st,cmd-gpios = <&gpiod 2 0>; - st,ck-gpios = <&gpioc 12 0>; - st,ckin-gpios = <&gpioe 4 0>; - bus-width = <4>; - vmmc-supply = <&vdd_sd>; - status = "okay"; -}; - -&sdmmc1_b4_pins_a { - /* - * SD bus pull-up resistors: - * - optional on SoMs with SD voltage translator - * - mandatory on SoMs without SD voltage translator - */ - pins1 { - bias-pull-up; - }; - pins2 { - bias-pull-up; - }; -}; - -&sdmmc2 { - pinctrl-names = "default", "opendrain", "sleep"; - pinctrl-0 = <&sdmmc2_b4_pins_a &sdmmc2_d47_pins_a>; - pinctrl-1 = <&sdmmc2_b4_od_pins_a &sdmmc2_d47_pins_a>; - pinctrl-2 = <&sdmmc2_b4_sleep_pins_a &sdmmc2_d47_sleep_pins_a>; - non-removable; - no-sd; - no-sdio; - st,neg-edge; - bus-width = <8>; - vmmc-supply = <&v3v3>; - vqmmc-supply = <&v3v3>; - mmc-ddr-3_3v; - status = "okay"; -}; - -&sdmmc3 { - pinctrl-names = "default", "opendrain", "sleep"; - pinctrl-0 = <&sdmmc3_b4_pins_a>; - pinctrl-1 = <&sdmmc3_b4_od_pins_a>; - pinctrl-2 = <&sdmmc3_b4_sleep_pins_a>; - broken-cd; - st,neg-edge; - bus-width = <4>; - vmmc-supply = <&v3v3>; - vqmmc-supply = <&v3v3>; - mmc-ddr-3_3v; - status = "okay"; -}; - -&uart4 { - pinctrl-names = "default"; - pinctrl-0 = <&uart4_pins_a>; - /delete-property/dmas; - /delete-property/dma-names; - status = "okay"; -}; diff --git a/arch/arm/dts/stm32mp15xx-dhcor-avenger96.dts b/arch/arm/dts/stm32mp15xx-dhcor-avenger96.dts deleted file mode 100644 index dd8fcecbca5..00000000000 --- a/arch/arm/dts/stm32mp15xx-dhcor-avenger96.dts +++ /dev/null @@ -1,20 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0 OR BSD-3-Clause) -/* - * Copyright (C) Linaro Ltd 2019 - All Rights Reserved - * Author: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org - * Copyright (C) 2020 Marek Vasut marex@denx.de - */ - -/dts-v1/; - -#include "stm32mp151.dtsi" -#include "stm32mp15xc.dtsi" -#include "stm32mp15xx-dhcor-som.dtsi" -#include "stm32mp15xx-dhcor-avenger96.dtsi" - -/ { - model = "Arrow Electronics STM32MP15xx Avenger96 board"; - compatible = "arrow,stm32mp15xx-avenger96", - "dh,stm32mp15xx-dhcor-som", - "st,stm32mp15x"; -}; diff --git a/arch/arm/dts/stm32mp15xx-dhcor-avenger96.dtsi b/arch/arm/dts/stm32mp15xx-dhcor-avenger96.dtsi deleted file mode 100644 index 61e17f44ce8..00000000000 --- a/arch/arm/dts/stm32mp15xx-dhcor-avenger96.dtsi +++ /dev/null @@ -1,437 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0 OR BSD-3-Clause) -/* - * Copyright (C) Linaro Ltd 2019 - All Rights Reserved - * Author: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org - * Copyright (C) 2020 Marek Vasut marex@denx.de - */ - -/* Avenger96 uses DHCOR SoM configured for 1V8 IO operation */ -#include "stm32mp15xx-dhcor-io1v8.dtsi" - -/ { - aliases { - ethernet0 = ðernet0; - mmc0 = &sdmmc1; - serial0 = &uart4; - serial1 = &uart7; - serial2 = &usart2; - spi0 = &qspi; - }; - - /* XTal Q1 */ - cec_clock: clk-cec-fixed { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <24000000>; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - hdmi-out { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_con: endpoint { - remote-endpoint = <&adv7513_out>; - }; - }; - }; - - led { - compatible = "gpio-leds"; - led1 { - label = "green:user0"; - gpios = <&gpioz 7 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "heartbeat"; - default-state = "off"; - }; - - led2 { - label = "green:user1"; - gpios = <&gpiof 3 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "mmc0"; - default-state = "off"; - }; - - led3 { - label = "green:user2"; - gpios = <&gpiog 0 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "mmc1"; - default-state = "off"; - }; - - led4 { - label = "green:user3"; - gpios = <&gpiog 1 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "none"; - default-state = "off"; - panic-indicator; - }; - }; - - sd_switch: regulator-sd_switch { - compatible = "regulator-gpio"; - regulator-name = "sd_switch"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <2900000>; - regulator-type = "voltage"; - regulator-always-on; - - gpios = <&gpioi 5 GPIO_ACTIVE_HIGH>; - gpios-states = <0>; - states = <1800000 0x1>, - <2900000 0x0>; - }; - - sound { - compatible = "audio-graph-card"; - label = "STM32MP1-AV96-HDMI"; - dais = <&sai2a_port>; - status = "okay"; - }; - - wlan_pwr: regulator-wlan { - compatible = "regulator-fixed"; - - regulator-name = "wl-reg"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - gpios = <&gpioz 3 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; -}; - -&adc { - pinctrl-names = "default"; - pinctrl-0 = <&adc12_ain_pins_b>; - vdd-supply = <&vdd>; - vdda-supply = <&vdda>; - vref-supply = <&vdda>; - status = "okay"; - - adc1: adc@0 { - st,adc-channels = <0 1 6>; - st,min-sample-time-nsecs = <5000>; - status = "okay"; - }; - - adc2: adc@100 { - st,adc-channels = <0 1 2>; - st,min-sample-time-nsecs = <5000>; - status = "okay"; - }; -}; - -ðernet0 { - status = "okay"; - pinctrl-0 = <ðernet0_rgmii_pins_c>; - pinctrl-1 = <ðernet0_rgmii_sleep_pins_c>; - pinctrl-names = "default", "sleep"; - phy-mode = "rgmii"; - max-speed = <1000>; - phy-handle = <&phy0>; - - mdio0 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "snps,dwmac-mdio"; - reset-gpios = <&gpioz 2 GPIO_ACTIVE_LOW>; - reset-delay-us = <1000>; - - phy0: ethernet-phy@7 { - reg = <7>; - - rxc-skew-ps = <1500>; - rxdv-skew-ps = <540>; - rxd0-skew-ps = <420>; - rxd1-skew-ps = <420>; - rxd2-skew-ps = <420>; - rxd3-skew-ps = <420>; - - txc-skew-ps = <1440>; - txen-skew-ps = <540>; - txd0-skew-ps = <420>; - txd1-skew-ps = <420>; - txd2-skew-ps = <420>; - txd3-skew-ps = <420>; - }; - }; -}; - -&gpioa { - gpio-line-names = "", "", "", "", - "", "", "", "", - "", "", "", "AV96-K", - "AV96-I", "", "AV96-A", ""; -}; - -&gpiob { - gpio-line-names = "", "", "", "", - "", "AV96-J", "", "", - "", "", "", "AV96-B", - "", "AV96-L", "", ""; -}; - -&gpioc { - gpio-line-names = "", "", "", "AV96-C", - "", "", "", "", - "", "", "", "", - "", "", "", ""; -}; - -&gpiod { - gpio-line-names = "", "", "", "", - "", "", "", "", - "AV96-D", "", "", "", - "", "", "AV96-E", "AV96-F"; -}; - -&gpiof { - gpio-line-names = "", "", "", "", - "", "", "", "", - "", "", "", "", - "AV96-G", "AV96-H", "", ""; -}; - -&i2c1 { /* X6 I2C1 */ - pinctrl-names = "default"; - pinctrl-0 = <&i2c1_pins_b>; - i2c-scl-rising-time-ns = <185>; - i2c-scl-falling-time-ns = <20>; - status = "okay"; - /delete-property/dmas; - /delete-property/dma-names; -}; - -&i2c2 { /* X6 I2C2 */ - pinctrl-names = "default"; - pinctrl-0 = <&i2c2_pins_c>; - i2c-scl-rising-time-ns = <185>; - i2c-scl-falling-time-ns = <20>; - status = "okay"; - /delete-property/dmas; - /delete-property/dma-names; -}; - -&i2c4 { - hdmi-transmitter@3d { - compatible = "adi,adv7513"; - reg = <0x3d>, <0x4d>, <0x2d>, <0x5d>; - reg-names = "main", "edid", "cec", "packet"; - clocks = <&cec_clock>; - clock-names = "cec"; - - avdd-supply = <&v3v3>; - dvdd-supply = <&v3v3>; - pvdd-supply = <&v3v3>; - dvdd-3v-supply = <&v3v3>; - bgvdd-supply = <&v3v3>; - - interrupts = <9 IRQ_TYPE_EDGE_FALLING>; - interrupt-parent = <&gpiog>; - - status = "okay"; - - adi,input-depth = <8>; - adi,input-colorspace = "rgb"; - adi,input-clock = "1x"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - adv7513_in: endpoint { - remote-endpoint = <<dc_ep0_out>; - }; - }; - - port@1 { - reg = <1>; - adv7513_out: endpoint { - remote-endpoint = <&hdmi_con>; - }; - }; - - port@2 { - reg = <2>; - adv7513_i2s0: endpoint { - remote-endpoint = <&sai2a_endpoint>; - }; - }; - }; - }; -}; - -<dc { - pinctrl-names = "default", "sleep"; - pinctrl-0 = <<dc_pins_d>; - pinctrl-1 = <<dc_sleep_pins_d>; - status = "okay"; - - port { - #address-cells = <1>; - #size-cells = <0>; - - ltdc_ep0_out: endpoint@0 { - reg = <0>; - remote-endpoint = <&adv7513_in>; - }; - }; -}; - -&sai2 { - clocks = <&rcc SAI2>, <&rcc PLL3_Q>, <&rcc PLL3_R>; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&sai2a_pins_c>; - pinctrl-1 = <&sai2a_sleep_pins_c>; - clock-names = "pclk", "x8k", "x11k"; - status = "okay"; - - sai2a: audio-controller@4400b004 { - #clock-cells = <0>; - dma-names = "tx"; - clocks = <&rcc SAI2_K>; - clock-names = "sai_ck"; - status = "okay"; - - sai2a_port: port { - sai2a_endpoint: endpoint { - remote-endpoint = <&adv7513_i2s0>; - format = "i2s"; - mclk-fs = <256>; - }; - }; - }; -}; - -&sdmmc1 { - pinctrl-names = "default", "opendrain", "sleep"; - pinctrl-0 = <&sdmmc1_b4_pins_a &sdmmc1_dir_pins_b>; - pinctrl-1 = <&sdmmc1_b4_od_pins_a &sdmmc1_dir_pins_b>; - pinctrl-2 = <&sdmmc1_b4_sleep_pins_a &sdmmc1_dir_sleep_pins_b>; - cd-gpios = <&gpioi 8 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>; - disable-wp; - st,sig-dir; - st,neg-edge; - st,use-ckin; - bus-width = <4>; - vmmc-supply = <&vdd_sd>; - vqmmc-supply = <&sd_switch>; - status = "okay"; -}; - -&sdmmc2 { - pinctrl-names = "default", "opendrain", "sleep"; - pinctrl-0 = <&sdmmc2_b4_pins_a &sdmmc2_d47_pins_c>; - pinctrl-1 = <&sdmmc2_b4_od_pins_a &sdmmc2_d47_pins_c>; - pinctrl-2 = <&sdmmc2_b4_sleep_pins_a &sdmmc2_d47_sleep_pins_c>; - bus-width = <8>; - mmc-ddr-1_8v; - no-sd; - no-sdio; - non-removable; - st,neg-edge; - vmmc-supply = <&v3v3>; - vqmmc-supply = <&vdd_io>; - status = "okay"; -}; - -&sdmmc3 { - pinctrl-names = "default", "opendrain", "sleep"; - pinctrl-0 = <&sdmmc3_b4_pins_b>; - pinctrl-1 = <&sdmmc3_b4_od_pins_b>; - pinctrl-2 = <&sdmmc3_b4_sleep_pins_b>; - broken-cd; - non-removable; - st,neg-edge; - bus-width = <4>; - vmmc-supply = <&wlan_pwr>; - status = "okay"; - - #address-cells = <1>; - #size-cells = <0>; - brcmf: bcrmf@1 { - reg = <1>; - compatible = "brcm,bcm4329-fmac"; - }; -}; - -&spi2 { - pinctrl-names = "default"; - pinctrl-0 = <&spi2_pins_a>; - cs-gpios = <&gpioi 0 0>; - status = "disabled"; - /delete-property/dmas; - /delete-property/dma-names; -}; - -&uart4 { - /* On Low speed expansion header */ - label = "LS-UART1"; - pinctrl-names = "default"; - pinctrl-0 = <&uart4_pins_b>; - /delete-property/dmas; - /delete-property/dma-names; - status = "okay"; -}; - -&uart7 { - /* On Low speed expansion header */ - label = "LS-UART0"; - pinctrl-names = "default"; - pinctrl-0 = <&uart7_pins_a>; - uart-has-rtscts; - /delete-property/dmas; - /delete-property/dma-names; - status = "okay"; -}; - -/* Bluetooth */ -&usart2 { - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&usart2_pins_a>; - pinctrl-1 = <&usart2_sleep_pins_a>; - st,hw-flow-ctrl; - /delete-property/dmas; - /delete-property/dma-names; - status = "okay"; - - bluetooth { - compatible = "brcm,bcm43438-bt"; - max-speed = <3000000>; - shutdown-gpios = <&gpioz 6 GPIO_ACTIVE_HIGH>; - }; -}; - -&usbh_ehci { - phys = <&usbphyc_port0>; - phy-names = "usb"; - status = "okay"; -}; - -&usbotg_hs { - pinctrl-0 = <&usbotg_hs_pins_a>; - pinctrl-names = "default"; - phy-names = "usb2-phy"; - phys = <&usbphyc_port1 0>; - status = "okay"; - vbus-supply = <&vbus_otg>; -}; - -&usbphyc { - status = "okay"; -}; - -&usbphyc_port0 { - phy-supply = <&vdd_usb>; -}; - -&usbphyc_port1 { - phy-supply = <&vdd_usb>; -}; diff --git a/arch/arm/dts/stm32mp15xx-dhcor-drc-compact.dts b/arch/arm/dts/stm32mp15xx-dhcor-drc-compact.dts deleted file mode 100644 index c1f99c1685e..00000000000 --- a/arch/arm/dts/stm32mp15xx-dhcor-drc-compact.dts +++ /dev/null @@ -1,18 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0 OR BSD-3-Clause) -/* - * Copyright (C) 2022 Marek Vasut marex@denx.de - */ - -/dts-v1/; - -#include "stm32mp151.dtsi" -#include "stm32mp15xc.dtsi" -#include "stm32mp15xx-dhcor-som.dtsi" -#include "stm32mp15xx-dhcor-drc-compact.dtsi" - -/ { - model = "DH electronics STM32MP15xx DHCOR DRC Compact"; - compatible = "dh,stm32mp15xx-dhcor-drc-compact", - "dh,stm32mp15xx-dhcor-som", - "st,stm32mp1xx"; -}; diff --git a/arch/arm/dts/stm32mp15xx-dhcor-drc-compact.dtsi b/arch/arm/dts/stm32mp15xx-dhcor-drc-compact.dtsi deleted file mode 100644 index bedccf0f00a..00000000000 --- a/arch/arm/dts/stm32mp15xx-dhcor-drc-compact.dtsi +++ /dev/null @@ -1,326 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0 OR BSD-3-Clause) -/* - * Copyright (C) 2022 Marek Vasut marex@denx.de - */ - -/ { - aliases { - ethernet0 = ðernet0; - ethernet1 = &ksz8851; - mmc0 = &sdmmc1; - rtc0 = &hwrtc; - rtc1 = &rtc; - serial0 = &uart4; - serial1 = &uart8; - serial2 = &usart3; - serial3 = &uart5; - spi0 = &qspi; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - led { - compatible = "gpio-leds"; - led1 { - label = "yellow:user0"; - gpios = <&gpioz 6 GPIO_ACTIVE_LOW>; - default-state = "off"; - }; - - led2 { - label = "red:user1"; - gpios = <&gpioz 3 GPIO_ACTIVE_LOW>; - default-state = "off"; - }; - }; - - ethernet_vio: vioregulator { - compatible = "regulator-fixed"; - regulator-name = "vio"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - gpio = <&gpioh 2 GPIO_ACTIVE_LOW>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vdd>; - }; -}; - -&adc { /* X11 ADC inputs */ - pinctrl-names = "default"; - pinctrl-0 = <&adc12_ain_pins_b>; - vdd-supply = <&vdd>; - vdda-supply = <&vdda>; - vref-supply = <&vdda>; - status = "okay"; - - adc1: adc@0 { - st,adc-channels = <0 1 6>; - st,min-sample-time-nsecs = <5000>; - status = "okay"; - }; - - adc2: adc@100 { - st,adc-channels = <0 1 2>; - st,min-sample-time-nsecs = <5000>; - status = "okay"; - }; -}; - -ðernet0 { - status = "okay"; - pinctrl-0 = <ðernet0_rgmii_pins_c>; - pinctrl-1 = <ðernet0_rgmii_sleep_pins_c>; - pinctrl-names = "default", "sleep"; - phy-mode = "rgmii"; - max-speed = <1000>; - phy-handle = <&phy0>; - - mdio0 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "snps,dwmac-mdio"; - reset-gpios = <&gpioz 2 GPIO_ACTIVE_LOW>; - reset-delay-us = <1000>; - reset-post-delay-us = <1000>; - - phy0: ethernet-phy@7 { - reg = <7>; - - rxc-skew-ps = <1500>; - rxdv-skew-ps = <540>; - rxd0-skew-ps = <420>; - rxd1-skew-ps = <420>; - rxd2-skew-ps = <420>; - rxd3-skew-ps = <420>; - - txc-skew-ps = <1440>; - txen-skew-ps = <540>; - txd0-skew-ps = <420>; - txd1-skew-ps = <420>; - txd2-skew-ps = <420>; - txd3-skew-ps = <420>; - }; - }; -}; - -&fmc { - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&fmc_pins_b>; - pinctrl-1 = <&fmc_sleep_pins_b>; - status = "okay"; - - ksz8851: ethernet@1,0 { - compatible = "micrel,ks8851-mll"; - reg = <1 0x0 0x2>, <1 0x2 0x20000>; - interrupt-parent = <&gpioc>; - interrupts = <3 IRQ_TYPE_LEVEL_LOW>; - bank-width = <2>; - - /* Timing values are in nS */ - st,fmc2-ebi-cs-mux-enable; - st,fmc2-ebi-cs-transaction-type = <4>; - st,fmc2-ebi-cs-buswidth = <16>; - st,fmc2-ebi-cs-address-setup-ns = <5>; - st,fmc2-ebi-cs-address-hold-ns = <5>; - st,fmc2-ebi-cs-bus-turnaround-ns = <5>; - st,fmc2-ebi-cs-data-setup-ns = <45>; - st,fmc2-ebi-cs-data-hold-ns = <1>; - st,fmc2-ebi-cs-write-address-setup-ns = <5>; - st,fmc2-ebi-cs-write-address-hold-ns = <5>; - st,fmc2-ebi-cs-write-bus-turnaround-ns = <5>; - st,fmc2-ebi-cs-write-data-setup-ns = <45>; - st,fmc2-ebi-cs-write-data-hold-ns = <1>; - }; -}; - -&gpioa { - gpio-line-names = "", "", "", "", - "DRCC-VAR2", "", "", "", - "", "", "", "", - "", "", "", ""; -}; - -&gpioe { - gpio-line-names = "", "", "", "", - "", "DRCC-GPIO0", "", "", - "", "", "", "", - "", "", "", ""; -}; - -&gpiog { - gpio-line-names = "", "", "", "", - "", "", "", "", - "", "", "", "", - "DRCC-GPIO5", "", "", ""; -}; - -&gpioh { - gpio-line-names = "", "", "", "DRCC-HW2", - "DRCC-GPIO4", "", "", "", - "DRCC-HW1", "DRCC-HW0", "", "DRCC-VAR1", - "DRCC-VAR0", "", "", "DRCC-GPIO6"; -}; - -&gpioi { - gpio-line-names = "", "", "", "", - "", "", "", "DRCC-GPIO2", - "", "DRCC-GPIO1", "", "", - "", "", "", ""; -}; - -&i2c1 { /* X11 I2C1 */ - pinctrl-names = "default"; - pinctrl-0 = <&i2c1_pins_b>; - i2c-scl-rising-time-ns = <185>; - i2c-scl-falling-time-ns = <20>; - status = "okay"; - /delete-property/dmas; - /delete-property/dma-names; -}; - -&i2c4 { - hwrtc: rtc@32 { - compatible = "microcrystal,rv8803"; - reg = <0x32>; - }; - - eeprom@50 { - compatible = "atmel,24c04"; - reg = <0x50>; - pagesize = <16>; - }; -}; - -&sdmmc1 { /* MicroSD */ - pinctrl-names = "default", "opendrain", "sleep"; - pinctrl-0 = <&sdmmc1_b4_pins_a>; - pinctrl-1 = <&sdmmc1_b4_od_pins_a>; - pinctrl-2 = <&sdmmc1_b4_sleep_pins_a>; - cd-gpios = <&gpioi 8 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>; - disable-wp; - st,neg-edge; - bus-width = <4>; - vmmc-supply = <&vdd>; - vqmmc-supply = <&vdd>; - status = "okay"; -}; - -&sdmmc2 { /* eMMC */ - pinctrl-names = "default", "opendrain", "sleep"; - pinctrl-0 = <&sdmmc2_b4_pins_a &sdmmc2_d47_pins_c>; - pinctrl-1 = <&sdmmc2_b4_od_pins_a &sdmmc2_d47_pins_c>; - pinctrl-2 = <&sdmmc2_b4_sleep_pins_a &sdmmc2_d47_sleep_pins_c>; - bus-width = <8>; - no-sd; - no-sdio; - non-removable; - st,neg-edge; - vmmc-supply = <&v3v3>; - vqmmc-supply = <&vdd>; - status = "okay"; -}; - -&sdmmc3 { /* SDIO Wi-Fi */ - pinctrl-names = "default", "opendrain", "sleep"; - pinctrl-0 = <&sdmmc3_b4_pins_a>; - pinctrl-1 = <&sdmmc3_b4_od_pins_a>; - pinctrl-2 = <&sdmmc3_b4_sleep_pins_a>; - broken-cd; - bus-width = <4>; - mmc-ddr-3_3v; - st,neg-edge; - vmmc-supply = <&v3v3>; - vqmmc-supply = <&v3v3>; - status = "okay"; -}; - -&spi2 { /* X11 SPI */ - pinctrl-names = "default"; - pinctrl-0 = <&spi2_pins_b>; - cs-gpios = <&gpioi 0 0>; - status = "disabled"; - /delete-property/dmas; - /delete-property/dma-names; -}; - -&uart4 { - label = "UART0"; - pinctrl-names = "default"; - pinctrl-0 = <&uart4_pins_d>; - /delete-property/dmas; - /delete-property/dma-names; - status = "okay"; -}; - -&uart5 { /* X11 UART */ - label = "X11-UART5"; - pinctrl-names = "default"; - pinctrl-0 = <&uart5_pins_a>; - /delete-property/dmas; - /delete-property/dma-names; - status = "okay"; -}; - -&uart8 { - label = "RS485-1"; - pinctrl-names = "default"; - pinctrl-0 = <&uart8_pins_a &uart8_rtscts_pins_a>; - uart-has-rtscts; - /delete-property/dmas; - /delete-property/dma-names; - status = "okay"; -}; - -&usart3 { /* RS485 or RS232 */ - label = "RS485-2"; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&usart3_pins_e>; - pinctrl-1 = <&usart3_sleep_pins_e>; - uart-has-rtscts; - /delete-property/dmas; - /delete-property/dma-names; - status = "okay"; -}; - -&usbh_ehci { - phys = <&usbphyc_port0>; - status = "okay"; -}; - -&usbh_ohci { - phys = <&usbphyc_port0>; - status = "okay"; -}; - -&usbotg_hs { - dr_mode = "otg"; - pinctrl-0 = <&usbotg_hs_pins_a>; - pinctrl-names = "default"; - phy-names = "usb2-phy"; - phys = <&usbphyc_port1 0>; - vbus-supply = <&vbus_otg>; - status = "okay"; -}; - -&usbphyc { - status = "okay"; -}; - -&usbphyc_port0 { - phy-supply = <&vdd_usb>; - vdda1v1-supply = <®11>; - vdda1v8-supply = <®18>; - connector { - compatible = "usb-a-connector"; - vbus-supply = <&vbus_sw>; - }; -}; - -&usbphyc_port1 { - phy-supply = <&vdd_usb>; - vdda1v1-supply = <®11>; - vdda1v8-supply = <®18>; -}; diff --git a/arch/arm/dts/stm32mp15xx-dhcor-io1v8.dtsi b/arch/arm/dts/stm32mp15xx-dhcor-io1v8.dtsi deleted file mode 100644 index e20917824bf..00000000000 --- a/arch/arm/dts/stm32mp15xx-dhcor-io1v8.dtsi +++ /dev/null @@ -1,28 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0 OR BSD-3-Clause) -/* - * Copyright (C) Linaro Ltd 2019 - All Rights Reserved - * Author: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org - * Copyright (C) 2020 Marek Vasut marex@denx.de - */ - -/ { - /* Enpirion EP3A8LQI U2 on the DHCOR */ - vdd_io: regulator-buck-io { - compatible = "regulator-fixed"; - regulator-name = "buck-io"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vdd>; - }; -}; - -&vdd { - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <2900000>; -}; - -&pwr_regulators { - vdd-supply = <&vdd_io>; -}; diff --git a/arch/arm/dts/stm32mp15xx-dhcor-som.dtsi b/arch/arm/dts/stm32mp15xx-dhcor-som.dtsi deleted file mode 100644 index f36eec1b4ac..00000000000 --- a/arch/arm/dts/stm32mp15xx-dhcor-som.dtsi +++ /dev/null @@ -1,221 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0 OR BSD-3-Clause) -/* - * Copyright (C) Linaro Ltd 2019 - All Rights Reserved - * Author: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org - * Copyright (C) 2020 Marek Vasut marex@denx.de - */ - -#include "stm32mp15-pinctrl.dtsi" -#include "stm32mp15xxac-pinctrl.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/mfd/st,stpmic1.h> - -/ { - aliases { - spi0 = &qspi; - }; - - memory@c0000000 { - device_type = "memory"; - reg = <0xc0000000 0x40000000>; - }; -}; - -&crc1 { - status = "okay"; -}; - -&dts { - status = "okay"; -}; - -&i2c4 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c4_pins_a>; - i2c-scl-rising-time-ns = <185>; - i2c-scl-falling-time-ns = <20>; - status = "okay"; - /delete-property/dmas; - /delete-property/dma-names; - - pmic: stpmic@33 { - compatible = "st,stpmic1"; - reg = <0x33>; - interrupts-extended = <&gpioa 0 IRQ_TYPE_EDGE_FALLING>; - interrupt-controller; - #interrupt-cells = <2>; - status = "okay"; - - regulators { - compatible = "st,stpmic1-regulators"; - - ldo1-supply = <&v3v3>; - ldo2-supply = <&v3v3>; - ldo3-supply = <&vdd_ddr>; - ldo5-supply = <&v3v3>; - ldo6-supply = <&v3v3>; - pwr_sw1-supply = <&bst_out>; - pwr_sw2-supply = <&bst_out>; - - vddcore: buck1 { - regulator-name = "vddcore"; - regulator-min-microvolt = <1200000>; - regulator-max-microvolt = <1350000>; - regulator-always-on; - regulator-initial-mode = <0>; - regulator-over-current-protection; - }; - - vdd_ddr: buck2 { - regulator-name = "vdd_ddr"; - regulator-min-microvolt = <1350000>; - regulator-max-microvolt = <1350000>; - regulator-always-on; - regulator-initial-mode = <0>; - regulator-over-current-protection; - }; - - vdd: buck3 { - regulator-name = "vdd"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - regulator-initial-mode = <0>; - regulator-over-current-protection; - }; - - v3v3: buck4 { - regulator-name = "v3v3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - regulator-over-current-protection; - regulator-initial-mode = <0>; - }; - - vdda: ldo1 { - regulator-name = "vdda"; - regulator-min-microvolt = <2900000>; - regulator-max-microvolt = <2900000>; - interrupts = <IT_CURLIM_LDO1 0>; - }; - - v2v8: ldo2 { - regulator-name = "v2v8"; - regulator-min-microvolt = <2800000>; - regulator-max-microvolt = <2800000>; - interrupts = <IT_CURLIM_LDO2 0>; - }; - - vtt_ddr: ldo3 { - regulator-name = "vtt_ddr"; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <750000>; - regulator-always-on; - regulator-over-current-protection; - }; - - vdd_usb: ldo4 { - regulator-name = "vdd_usb"; - interrupts = <IT_CURLIM_LDO4 0>; - }; - - vdd_sd: ldo5 { - regulator-name = "vdd_sd"; - regulator-min-microvolt = <2900000>; - regulator-max-microvolt = <2900000>; - interrupts = <IT_CURLIM_LDO5 0>; - regulator-boot-on; - }; - - v1v8: ldo6 { - regulator-name = "v1v8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - interrupts = <IT_CURLIM_LDO6 0>; - regulator-enable-ramp-delay = <300000>; - }; - - vref_ddr: vref_ddr { - regulator-name = "vref_ddr"; - regulator-always-on; - }; - - bst_out: boost { - regulator-name = "bst_out"; - interrupts = <IT_OCP_BOOST 0>; - }; - - vbus_otg: pwr_sw1 { - regulator-name = "vbus_otg"; - interrupts = <IT_OCP_OTG 0>; - regulator-active-discharge = <1>; - }; - - vbus_sw: pwr_sw2 { - regulator-name = "vbus_sw"; - interrupts = <IT_OCP_SWOUT 0>; - regulator-active-discharge = <1>; - }; - }; - - onkey { - compatible = "st,stpmic1-onkey"; - interrupts = <IT_PONKEY_F 0>, <IT_PONKEY_R 1>; - interrupt-names = "onkey-falling", "onkey-rising"; - status = "okay"; - }; - - watchdog { - compatible = "st,stpmic1-wdt"; - status = "disabled"; - }; - }; - - eeprom@53 { - compatible = "atmel,24c02"; - reg = <0x53>; - pagesize = <16>; - }; -}; - -&iwdg2 { - timeout-sec = <32>; - status = "okay"; -}; - -&pwr_regulators { - vdd-supply = <&vdd>; - vdd_3v3_usbfs-supply = <&vdd_usb>; -}; - -&qspi { - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&qspi_clk_pins_a - &qspi_bk1_pins_a - &qspi_cs1_pins_a>; - pinctrl-1 = <&qspi_clk_sleep_pins_a - &qspi_bk1_sleep_pins_a - &qspi_cs1_sleep_pins_a>; - reg = <0x58003000 0x1000>, <0x70000000 0x200000>; - #address-cells = <1>; - #size-cells = <0>; - status = "okay"; - - flash0: flash@0 { - compatible = "jedec,spi-nor"; - reg = <0>; - spi-rx-bus-width = <4>; - spi-max-frequency = <50000000>; - #address-cells = <1>; - #size-cells = <1>; - }; -}; - -&rng1 { - status = "okay"; -}; - -&rtc { - status = "okay"; -}; diff --git a/arch/arm/dts/stm32mp15xx-dhcor-testbench.dts b/arch/arm/dts/stm32mp15xx-dhcor-testbench.dts deleted file mode 100644 index 5fdd762ddbf..00000000000 --- a/arch/arm/dts/stm32mp15xx-dhcor-testbench.dts +++ /dev/null @@ -1,180 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0 OR BSD-3-Clause) -/* - * Copyright (C) 2022 Marek Vasut marex@denx.de - */ -/dts-v1/; - -#include "stm32mp151.dtsi" -#include "stm32mp15xx-dhcor-som.dtsi" - -/ { - model = "DH electronics STM32MP15xx DHCOR Testbench"; - compatible = "dh,stm32mp15xx-dhcor-testbench", - "dh,stm32mp15xx-dhcor-som", - "st,stm32mp1xx"; - - aliases { - ethernet0 = ðernet0; - mmc0 = &sdmmc1; - mmc1 = &sdmmc2; - serial0 = &uart4; - serial1 = &uart7; - spi0 = &qspi; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - sd_switch: regulator-sd_switch { - compatible = "regulator-gpio"; - regulator-name = "sd_switch"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <2900000>; - regulator-type = "voltage"; - regulator-always-on; - - gpios = <&gpioi 5 GPIO_ACTIVE_HIGH>; - gpios-states = <0>; - states = <1800000 0x1>, - <2900000 0x0>; - }; -}; - -&adc { - pinctrl-names = "default"; - pinctrl-0 = <&adc12_ain_pins_b>; - vdd-supply = <&vdd>; - vdda-supply = <&vdda>; - vref-supply = <&vdda>; - status = "okay"; - - adc1: adc@0 { - st,adc-channels = <0 1 6>; - st,min-sample-time-nsecs = <5000>; - status = "okay"; - }; - - adc2: adc@100 { - st,adc-channels = <0 1 2>; - st,min-sample-time-nsecs = <5000>; - status = "okay"; - }; -}; - -ðernet0 { - status = "okay"; - pinctrl-0 = <ðernet0_rgmii_pins_c>; - pinctrl-1 = <ðernet0_rgmii_sleep_pins_c>; - pinctrl-names = "default", "sleep"; - phy-mode = "rgmii"; - max-speed = <1000>; - phy-handle = <&phy0>; - - mdio0 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "snps,dwmac-mdio"; - reset-gpios = <&gpioz 2 GPIO_ACTIVE_LOW>; - reset-delay-us = <1000>; - - phy0: ethernet-phy@7 { - reg = <7>; - - rxc-skew-ps = <1500>; - rxdv-skew-ps = <540>; - rxd0-skew-ps = <420>; - rxd1-skew-ps = <420>; - rxd2-skew-ps = <420>; - rxd3-skew-ps = <420>; - - txc-skew-ps = <1440>; - txen-skew-ps = <540>; - txd0-skew-ps = <420>; - txd1-skew-ps = <420>; - txd2-skew-ps = <420>; - txd3-skew-ps = <420>; - }; - }; -}; - -&sdmmc1 { - pinctrl-names = "default", "opendrain", "sleep"; - pinctrl-0 = <&sdmmc1_b4_pins_a &sdmmc1_dir_pins_b>; - pinctrl-1 = <&sdmmc1_b4_od_pins_a &sdmmc1_dir_pins_b>; - pinctrl-2 = <&sdmmc1_b4_sleep_pins_a &sdmmc1_dir_sleep_pins_b>; - cd-gpios = <&gpioi 8 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>; - disable-wp; - st,sig-dir; - st,neg-edge; - st,use-ckin; - bus-width = <4>; - vmmc-supply = <&vdd_sd>; - vqmmc-supply = <&sd_switch>; - status = "okay"; -}; - -&sdmmc2 { - pinctrl-names = "default", "opendrain", "sleep"; - pinctrl-0 = <&sdmmc2_b4_pins_a &sdmmc2_d47_pins_c>; - pinctrl-1 = <&sdmmc2_b4_od_pins_a &sdmmc2_d47_pins_c>; - pinctrl-2 = <&sdmmc2_b4_sleep_pins_a &sdmmc2_d47_sleep_pins_c>; - bus-width = <8>; - mmc-ddr-1_8v; - no-sd; - no-sdio; - non-removable; - st,neg-edge; - vmmc-supply = <&v3v3>; - vqmmc-supply = <&v3v3>; - status = "okay"; -}; - -&uart4 { - pinctrl-names = "default"; - pinctrl-0 = <&uart4_pins_b>; - /delete-property/dmas; - /delete-property/dma-names; - status = "okay"; -}; - -&uart7 { - pinctrl-names = "default"; - pinctrl-0 = <&uart7_pins_a>; - uart-has-rtscts; - /delete-property/dmas; - /delete-property/dma-names; - status = "okay"; -}; - -&usbh_ehci { - phys = <&usbphyc_port0>; - phy-names = "usb"; - status = "okay"; -}; - -&usbotg_hs { - pinctrl-0 = <&usbotg_hs_pins_a>; - pinctrl-names = "default"; - phy-names = "usb2-phy"; - phys = <&usbphyc_port1 0>; - status = "okay"; - vbus-supply = <&vbus_otg>; -}; - -&usbphyc { - status = "okay"; -}; - -&usbphyc_port0 { - phy-supply = <&vdd_usb>; -}; - -&usbphyc_port1 { - phy-supply = <&vdd_usb>; -}; - -&vdd { - /delete-property/ regulator-always-on; - regulator-min-microvolt = <1200000>; -}; diff --git a/board/dhelectronics/dh_stm32mp1/u-boot-dhcom.its b/board/dhelectronics/dh_stm32mp1/u-boot-dhcom.its index 8eed9d0fb24..38ecb601190 100644 --- a/board/dhelectronics/dh_stm32mp1/u-boot-dhcom.its +++ b/board/dhelectronics/dh_stm32mp1/u-boot-dhcom.its @@ -18,7 +18,7 @@
fdt-1 { description = ".dtb"; - data = /incbin/("arch/arm/dts/stm32mp15xx-dhcom-pdk2.dtb"); + data = /incbin/("dts/upstream/src/arm/st/stm32mp157c-dhcom-pdk2.dtb"); type = "flat_dt"; arch = "arm"; compression = "none"; @@ -26,7 +26,7 @@
fdt-2 { description = ".dtb"; - data = /incbin/("arch/arm/dts/stm32mp15xx-dhcom-drc02.dtb"); + data = /incbin/("dts/upstream/src/arm/st/stm32mp153c-dhcom-drc02.dtb"); type = "flat_dt"; arch = "arm"; compression = "none"; @@ -34,7 +34,7 @@
fdt-3 { description = ".dtb"; - data = /incbin/("arch/arm/dts/stm32mp15xx-dhcom-picoitx.dtb"); + data = /incbin/("dts/upstream/src/arm/st/stm32mp157c-dhcom-picoitx.dtb"); type = "flat_dt"; arch = "arm"; compression = "none"; @@ -46,42 +46,42 @@
config-1 { /* DT+SoM+board model */ - description = "dh,stm32mp15xx-dhcom-pdk2_somrev0_boardrev0"; + description = "dh,stm32mp157c-dhcom-pdk2_somrev0_boardrev0"; firmware = "uboot"; fdt = "fdt-1"; };
config-2 { /* DT+SoM+board model */ - description = "dh,stm32mp15xx-dhcom-pdk2_somrev1_boardrev0"; + description = "dh,stm32mp157c-dhcom-pdk2_somrev1_boardrev0"; firmware = "uboot"; fdt = "fdt-1"; };
config-3 { /* DT+SoM+board model */ - description = "dh,stm32mp15xx-dhcom-drc02_somrev0_boardrev0"; + description = "dh,stm32mp153c-dhcom-drc02_somrev0_boardrev0"; firmware = "uboot"; fdt = "fdt-2"; };
config-4 { /* DT+SoM+board model */ - description = "dh,stm32mp15xx-dhcom-drc02_somrev1_boardrev0"; + description = "dh,stm32mp153c-dhcom-drc02_somrev1_boardrev0"; firmware = "uboot"; fdt = "fdt-2"; };
config-5 { /* DT+SoM+board model */ - description = "dh,stm32mp15xx-dhcom-picoitx_somrev0_boardrev0"; + description = "dh,stm32mp157c-dhcom-picoitx_somrev0_boardrev0"; loadables = "uboot"; fdt = "fdt-3"; };
config-6 { /* DT+SoM+board model */ - description = "dh,stm32mp15xx-dhcom-picoitx_somrev1_boardrev0"; + description = "dh,stm32mp157c-dhcom-picoitx_somrev1_boardrev0"; loadables = "uboot"; fdt = "fdt-3"; }; diff --git a/board/dhelectronics/dh_stm32mp1/u-boot-dhcor.its b/board/dhelectronics/dh_stm32mp1/u-boot-dhcor.its index f9c1075616b..e17dac77804 100644 --- a/board/dhelectronics/dh_stm32mp1/u-boot-dhcor.its +++ b/board/dhelectronics/dh_stm32mp1/u-boot-dhcor.its @@ -18,7 +18,7 @@
fdt-1 { description = ".dtb"; - data = /incbin/("arch/arm/dts/stm32mp15xx-dhcor-testbench.dtb"); + data = /incbin/("dts/upstream/src/arm/st/stm32mp151a-dhcor-testbench.dtb"); type = "flat_dt"; arch = "arm"; compression = "none"; @@ -26,7 +26,7 @@
fdt-2 { description = ".dtb"; - data = /incbin/("arch/arm/dts/stm32mp15xx-dhcor-avenger96.dtb"); + data = /incbin/("dts/upstream/src/arm/st/stm32mp157a-dhcor-avenger96.dtb"); type = "flat_dt"; arch = "arm"; compression = "none"; @@ -34,7 +34,7 @@
fdt-3 { description = ".dtb"; - data = /incbin/("arch/arm/dts/stm32mp15xx-dhcor-drc-compact.dtb"); + data = /incbin/("dts/upstream/src/arm/st/stm32mp153c-dhcor-drc-compact.dtb"); type = "flat_dt"; arch = "arm"; compression = "none"; @@ -46,21 +46,21 @@
config-1 { /* DT+SoM+board model */ - description = "dh,stm32mp15xx-dhcor-testbench_somrev0_boardrev1"; + description = "dh,stm32mp151a-dhcor-testbench_somrev0_boardrev1"; firmware = "uboot"; fdt = "fdt-1"; };
config-2 { /* DT+SoM+board model */ - description = "arrow,stm32mp15xx-avenger96_somrev0_boardrev1"; + description = "arrow,stm32mp157a-avenger96_somrev0_boardrev1"; firmware = "uboot"; fdt = "fdt-2"; };
config-3 { /* DT+SoM+board model */ - description = "dh,stm32mp15xx-dhcor-drc-compact_somrev0_boardrev0"; + description = "dh,stm32mp153c-dhcor-drc-compact_somrev0_boardrev0"; firmware = "uboot"; fdt = "fdt-3"; }; diff --git a/configs/stm32mp13_dhcor_defconfig b/configs/stm32mp13_dhcor_defconfig index fb3d86deb64..1480f3013e0 100644 --- a/configs/stm32mp13_dhcor_defconfig +++ b/configs/stm32mp13_dhcor_defconfig @@ -6,7 +6,7 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc0400000 CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_OFFSET=0x3E0000 CONFIG_ENV_SECT_SIZE=0x1000 -CONFIG_DEFAULT_DEVICE_TREE="stm32mp135f-dhcor-dhsbc" +CONFIG_DEFAULT_DEVICE_TREE="st/stm32mp135f-dhcor-dhsbc" CONFIG_STM32MP13X=y CONFIG_DDR_CACHEABLE_SIZE=0x8000000 CONFIG_CMD_STM32KEY=y @@ -64,6 +64,7 @@ CONFIG_CMD_LOG=y CONFIG_CMD_UBI=y # CONFIG_ISO_PARTITION is not set CONFIG_OF_LIVE=y +CONFIG_OF_UPSTREAM=y CONFIG_ENV_IS_NOWHERE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_ENV_SPI_MAX_HZ=50000000 diff --git a/configs/stm32mp15_dhcom_basic_defconfig b/configs/stm32mp15_dhcom_basic_defconfig index c9095a9d2d8..e2a26e2b774 100644 --- a/configs/stm32mp15_dhcom_basic_defconfig +++ b/configs/stm32mp15_dhcom_basic_defconfig @@ -7,7 +7,7 @@ CONFIG_SF_DEFAULT_SPEED=50000000 CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_SPL_DM_SPI=y -CONFIG_DEFAULT_DEVICE_TREE="stm32mp15xx-dhcom-pdk2" +CONFIG_DEFAULT_DEVICE_TREE="st/stm32mp157c-dhcom-pdk2" CONFIG_SPL_TEXT_BASE=0x2FFC2500 CONFIG_SPL_MMC=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 @@ -95,7 +95,8 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_ISO_PARTITION is not set # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_OF_LIVE=y -CONFIG_OF_LIST="stm32mp15xx-dhcom-pdk2 stm32mp15xx-dhcom-drc02 stm32mp15xx-dhcom-picoitx" +CONFIG_OF_UPSTREAM=y +CONFIG_OF_LIST="st/stm32mp157c-dhcom-pdk2 st/stm32mp153c-dhcom-drc02 st/stm32mp157c-dhcom-picoitx" CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-names interrupts-extended interrupt-controller \#interrupt-cells interrupt-parent dmas dma-names assigned-clocks assigned-clock-rates assigned-clock-parents hwlocks" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y diff --git a/configs/stm32mp15_dhcor_basic_defconfig b/configs/stm32mp15_dhcor_basic_defconfig index fe4540278f4..f73bd2fa12c 100644 --- a/configs/stm32mp15_dhcor_basic_defconfig +++ b/configs/stm32mp15_dhcor_basic_defconfig @@ -7,7 +7,7 @@ CONFIG_SF_DEFAULT_SPEED=50000000 CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_SPL_DM_SPI=y -CONFIG_DEFAULT_DEVICE_TREE="stm32mp15xx-dhcor-avenger96" +CONFIG_DEFAULT_DEVICE_TREE="st/stm32mp157a-dhcor-avenger96" CONFIG_SPL_TEXT_BASE=0x2FFC2500 CONFIG_SPL_MMC=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 @@ -93,7 +93,8 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_ISO_PARTITION is not set # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_OF_LIVE=y -CONFIG_OF_LIST="stm32mp15xx-dhcor-avenger96 stm32mp15xx-dhcor-testbench stm32mp15xx-dhcor-drc-compact" +CONFIG_OF_UPSTREAM=y +CONFIG_OF_LIST="st/stm32mp157a-dhcor-avenger96 st/stm32mp151a-dhcor-testbench st/stm32mp153c-dhcor-drc-compact" CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-names interrupts-extended interrupt-controller \#interrupt-cells interrupt-parent dmas dma-names assigned-clocks assigned-clock-rates assigned-clock-parents hwlocks" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y
On 10/5/24 03:15, Marek Vasut wrote:
Enable OF_UPSTREAM to use upstream DT and add st/ prefix to the DEFAULT_DEVICE_TREE. And thereby directly build DTB from dts/upstream/src/ including *-u-boot.dtsi from arch/$(ARCH)/dts/ directory.
The previous setup used generic SoC prefix like stm32mp15xx-dhco* for generic DTs which could be used on any STM32MP15xx DHSOM variant. The new setup uses specific SoC prefix stm32mp157c-dhco* to match Linux DT names. Since the hardware present on STM32MP153 and STM32MP157 is not enabled in the board configuration and not supported by U-Boot except for the DSI host, using the existing Linux DTs poses no issue even on plain STM32MP151A based SoMs.
Signed-off-by: Marek Vasut marex@denx.de
Cc: Patrice Chotard patrice.chotard@foss.st.com Cc: Patrick Delaunay patrick.delaunay@foss.st.com Cc: Sean Anderson seanga2@gmail.com Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com Cc: u-boot@dh-electronics.com Cc: u-boot@lists.denx.de Cc: uboot-stm32@st-md-mailman.stormreply.com
V2: - Drop arch/arm/dts/Makefile entries - Convert stm32mp135f-dhcom-dhsbc
arch/arm/dts/Makefile | 9 +- arch/arm/dts/stm32mp135f-dhcor-dhsbc.dts | 383 ------------ ...> stm32mp151a-dhcor-testbench-u-boot.dtsi} | 0 ...si => stm32mp153c-dhcom-drc02-u-boot.dtsi} | 0 ...stm32mp153c-dhcor-drc-compact-u-boot.dtsi} | 0 ...> stm32mp157a-dhcor-avenger96-u-boot.dtsi} | 0 ...tsi => stm32mp157c-dhcom-pdk2-u-boot.dtsi} | 0 ... => stm32mp157c-dhcom-picoitx-u-boot.dtsi} | 0 arch/arm/dts/stm32mp15xx-dhcom-drc02.dts | 17 - arch/arm/dts/stm32mp15xx-dhcom-drc02.dtsi | 169 ------ arch/arm/dts/stm32mp15xx-dhcom-pdk2.dts | 17 - arch/arm/dts/stm32mp15xx-dhcom-pdk2.dtsi | 329 ----------- arch/arm/dts/stm32mp15xx-dhcom-picoitx.dts | 17 - arch/arm/dts/stm32mp15xx-dhcom-picoitx.dtsi | 151 ----- arch/arm/dts/stm32mp15xx-dhcom-som.dtsi | 544 ------------------ arch/arm/dts/stm32mp15xx-dhcor-avenger96.dts | 20 - arch/arm/dts/stm32mp15xx-dhcor-avenger96.dtsi | 437 -------------- .../arm/dts/stm32mp15xx-dhcor-drc-compact.dts | 18 - .../dts/stm32mp15xx-dhcor-drc-compact.dtsi | 326 ----------- arch/arm/dts/stm32mp15xx-dhcor-io1v8.dtsi | 28 - arch/arm/dts/stm32mp15xx-dhcor-som.dtsi | 221 ------- arch/arm/dts/stm32mp15xx-dhcor-testbench.dts | 180 ------ .../dh_stm32mp1/u-boot-dhcom.its | 18 +- .../dh_stm32mp1/u-boot-dhcor.its | 12 +- configs/stm32mp13_dhcor_defconfig | 3 +- configs/stm32mp15_dhcom_basic_defconfig | 5 +- configs/stm32mp15_dhcor_basic_defconfig | 5 +- 27 files changed, 24 insertions(+), 2885 deletions(-) delete mode 100644 arch/arm/dts/stm32mp135f-dhcor-dhsbc.dts rename arch/arm/dts/{stm32mp15xx-dhcor-testbench-u-boot.dtsi => stm32mp151a-dhcor-testbench-u-boot.dtsi} (100%) rename arch/arm/dts/{stm32mp15xx-dhcom-drc02-u-boot.dtsi => stm32mp153c-dhcom-drc02-u-boot.dtsi} (100%) rename arch/arm/dts/{stm32mp15xx-dhcor-drc-compact-u-boot.dtsi => stm32mp153c-dhcor-drc-compact-u-boot.dtsi} (100%) rename arch/arm/dts/{stm32mp15xx-dhcor-avenger96-u-boot.dtsi => stm32mp157a-dhcor-avenger96-u-boot.dtsi} (100%) rename arch/arm/dts/{stm32mp15xx-dhcom-pdk2-u-boot.dtsi => stm32mp157c-dhcom-pdk2-u-boot.dtsi} (100%) rename arch/arm/dts/{stm32mp15xx-dhcom-picoitx-u-boot.dtsi => stm32mp157c-dhcom-picoitx-u-boot.dtsi} (100%) delete mode 100644 arch/arm/dts/stm32mp15xx-dhcom-drc02.dts delete mode 100644 arch/arm/dts/stm32mp15xx-dhcom-drc02.dtsi delete mode 100644 arch/arm/dts/stm32mp15xx-dhcom-pdk2.dts delete mode 100644 arch/arm/dts/stm32mp15xx-dhcom-pdk2.dtsi delete mode 100644 arch/arm/dts/stm32mp15xx-dhcom-picoitx.dts delete mode 100644 arch/arm/dts/stm32mp15xx-dhcom-picoitx.dtsi delete mode 100644 arch/arm/dts/stm32mp15xx-dhcom-som.dtsi delete mode 100644 arch/arm/dts/stm32mp15xx-dhcor-avenger96.dts delete mode 100644 arch/arm/dts/stm32mp15xx-dhcor-avenger96.dtsi delete mode 100644 arch/arm/dts/stm32mp15xx-dhcor-drc-compact.dts delete mode 100644 arch/arm/dts/stm32mp15xx-dhcor-drc-compact.dtsi delete mode 100644 arch/arm/dts/stm32mp15xx-dhcor-io1v8.dtsi delete mode 100644 arch/arm/dts/stm32mp15xx-dhcor-som.dtsi delete mode 100644 arch/arm/dts/stm32mp15xx-dhcor-testbench.dts
Nice.
Reviewed-by: Patrick Delaunay patrick.delaunay@foss.st.com
Thanks Patrick
Nice.
Thanks Patrick
Applied to u-boot-stm/master, thanks!
Regards Patrick
Describe the u-boot.its generation in stm32mp15xx-dhsom-u-boot.dtsi binman {} DT node as a replacement for current CONFIG_SPL_FIT_SOURCE use, dispose of both u-boot-dhcom.its and u-boot-dhcor.its.
Use fdt-SEQ/config-SEQ to generate a list of fdt-N fitImage images {} and matching configuration {} node entries. The configuration node entry names no longer encode _somrevN_boardrevN suffix, which was never really used, so drop this functionality by default. Rework board_fit_config_name_match() to match on the new configuration node entry names.
Users who do need the match on _somrevN_boardrevN can either replace the fdt-SEQ/config-SEQ with fixed fdt-N/config-N nodes which each encode the matching 'description = "NAME_somrevN_boardrevN"' to restore the old behavior verbatim, or better use SPL DT overlays for U-Boot control DT the same way e.g. i.MX8MP DHCOM does to support multiple SoM and board variants.
Signed-off-by: Marek Vasut marex@denx.de --- Cc: Patrice Chotard patrice.chotard@foss.st.com Cc: Patrick Delaunay patrick.delaunay@foss.st.com Cc: Sean Anderson seanga2@gmail.com Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com Cc: u-boot@dh-electronics.com Cc: u-boot@lists.denx.de Cc: uboot-stm32@st-md-mailman.stormreply.com --- V2: No change --- arch/arm/dts/stm32mp15xx-dhcom-u-boot.dtsi | 1 + arch/arm/dts/stm32mp15xx-dhcor-u-boot.dtsi | 1 + arch/arm/dts/stm32mp15xx-dhsom-u-boot.dtsi | 53 +++++++++++ board/dhelectronics/dh_stm32mp1/board.c | 19 +++- .../dh_stm32mp1/u-boot-dhcom.its | 91 ------------------- .../dh_stm32mp1/u-boot-dhcor.its | 70 -------------- configs/stm32mp15_dhcom_basic_defconfig | 2 - configs/stm32mp15_dhcor_basic_defconfig | 2 - 8 files changed, 70 insertions(+), 169 deletions(-) create mode 100644 arch/arm/dts/stm32mp15xx-dhsom-u-boot.dtsi delete mode 100644 board/dhelectronics/dh_stm32mp1/u-boot-dhcom.its delete mode 100644 board/dhelectronics/dh_stm32mp1/u-boot-dhcor.its
diff --git a/arch/arm/dts/stm32mp15xx-dhcom-u-boot.dtsi b/arch/arm/dts/stm32mp15xx-dhcom-u-boot.dtsi index d7b78cdcfa9..dd67e960a64 100644 --- a/arch/arm/dts/stm32mp15xx-dhcom-u-boot.dtsi +++ b/arch/arm/dts/stm32mp15xx-dhcom-u-boot.dtsi @@ -8,6 +8,7 @@ #include "stm32mp15-ddr3-dhsom-2x1Gb-1066-binG.dtsi" #include "stm32mp15-ddr3-dhsom-2x2Gb-1066-binG.dtsi" #include "stm32mp15-ddr3-dhsom-2x4Gb-1066-binG.dtsi" +#include "stm32mp15xx-dhsom-u-boot.dtsi"
/ { aliases { diff --git a/arch/arm/dts/stm32mp15xx-dhcor-u-boot.dtsi b/arch/arm/dts/stm32mp15xx-dhcor-u-boot.dtsi index ba84db679e1..08439342cb2 100644 --- a/arch/arm/dts/stm32mp15xx-dhcor-u-boot.dtsi +++ b/arch/arm/dts/stm32mp15xx-dhcor-u-boot.dtsi @@ -12,6 +12,7 @@ #include "stm32mp15-ddr3-dhsom-2x1Gb-1066-binG.dtsi" #include "stm32mp15-ddr3-dhsom-2x2Gb-1066-binG.dtsi" #include "stm32mp15-ddr3-dhsom-2x4Gb-1066-binG.dtsi" +#include "stm32mp15xx-dhsom-u-boot.dtsi"
/ { bootph-all; diff --git a/arch/arm/dts/stm32mp15xx-dhsom-u-boot.dtsi b/arch/arm/dts/stm32mp15xx-dhsom-u-boot.dtsi new file mode 100644 index 00000000000..386c605c07f --- /dev/null +++ b/arch/arm/dts/stm32mp15xx-dhsom-u-boot.dtsi @@ -0,0 +1,53 @@ +// SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause +/* + * Copyright (C) 2024 Marek Vasut marex@denx.de + */ + +&binman { + u-boot { + filename = "u-boot.itb"; + + fit { + description = "U-Boot mainline"; + fit,fdt-list = "of-list"; + #address-cells = <1>; + + images { + uboot { + arch = "arm"; + compression = "none"; + description = "U-Boot (32-bit)"; + entry = <CONFIG_TEXT_BASE>; + load = <CONFIG_TEXT_BASE>; + type = "standalone"; + + uboot-blob { + filename = "u-boot-nodtb.bin"; + type = "blob-ext"; + }; + }; + + @fdt-SEQ { + compression = "none"; + description = "NAME"; + type = "flat_dt"; + + uboot-fdt-blob { + filename = "u-boot.dtb"; + type = "blob-ext"; + }; + }; + }; + + configurations { + default = "@config-DEFAULT-SEQ"; + + @config-SEQ { + description = "NAME"; + fdt = "fdt-SEQ"; + firmware = "uboot"; + }; + }; + }; + }; +}; diff --git a/board/dhelectronics/dh_stm32mp1/board.c b/board/dhelectronics/dh_stm32mp1/board.c index 24c5f37c12f..3e4b22505ff 100644 --- a/board/dhelectronics/dh_stm32mp1/board.c +++ b/board/dhelectronics/dh_stm32mp1/board.c @@ -276,15 +276,26 @@ int board_early_init_f(void) #ifdef CONFIG_SPL_LOAD_FIT int board_fit_config_name_match(const char *name) { + char *cdevice, *ndevice; const char *compat; - char test[128];
compat = ofnode_get_property(ofnode_root(), "compatible", NULL); + if (!compat) + return -EINVAL; + + cdevice = strchr(compat, ','); + if (!cdevice) + return -ENODEV; + + cdevice++; /* Move past the comma right after vendor prefix. */ + + ndevice = strchr(name, '/'); + if (!ndevice) + return -ENODEV;
- snprintf(test, sizeof(test), "%s_somrev%d_boardrev%d", - compat, somcode, brdcode); + ndevice++; /* Move past the last slash in DT path */
- if (!strcmp(name, test)) + if (!strcmp(cdevice, ndevice)) return 0;
return -EINVAL; diff --git a/board/dhelectronics/dh_stm32mp1/u-boot-dhcom.its b/board/dhelectronics/dh_stm32mp1/u-boot-dhcom.its deleted file mode 100644 index 38ecb601190..00000000000 --- a/board/dhelectronics/dh_stm32mp1/u-boot-dhcom.its +++ /dev/null @@ -1,91 +0,0 @@ -/dts-v1/; - -/ { - description = "U-Boot mainline"; - #address-cells = <1>; - - images { - uboot { - description = "U-Boot (32-bit)"; - data = /incbin/("u-boot-nodtb.bin"); - type = "standalone"; - os = "U-Boot"; - arch = "arm"; - compression = "none"; - load = <0xc0100000>; - entry = <0xc0100000>; - }; - - fdt-1 { - description = ".dtb"; - data = /incbin/("dts/upstream/src/arm/st/stm32mp157c-dhcom-pdk2.dtb"); - type = "flat_dt"; - arch = "arm"; - compression = "none"; - }; - - fdt-2 { - description = ".dtb"; - data = /incbin/("dts/upstream/src/arm/st/stm32mp153c-dhcom-drc02.dtb"); - type = "flat_dt"; - arch = "arm"; - compression = "none"; - }; - - fdt-3 { - description = ".dtb"; - data = /incbin/("dts/upstream/src/arm/st/stm32mp157c-dhcom-picoitx.dtb"); - type = "flat_dt"; - arch = "arm"; - compression = "none"; - }; - }; - - configurations { - default = "config-1"; - - config-1 { - /* DT+SoM+board model */ - description = "dh,stm32mp157c-dhcom-pdk2_somrev0_boardrev0"; - firmware = "uboot"; - fdt = "fdt-1"; - }; - - config-2 { - /* DT+SoM+board model */ - description = "dh,stm32mp157c-dhcom-pdk2_somrev1_boardrev0"; - firmware = "uboot"; - fdt = "fdt-1"; - }; - - config-3 { - /* DT+SoM+board model */ - description = "dh,stm32mp153c-dhcom-drc02_somrev0_boardrev0"; - firmware = "uboot"; - fdt = "fdt-2"; - }; - - config-4 { - /* DT+SoM+board model */ - description = "dh,stm32mp153c-dhcom-drc02_somrev1_boardrev0"; - firmware = "uboot"; - fdt = "fdt-2"; - }; - - config-5 { - /* DT+SoM+board model */ - description = "dh,stm32mp157c-dhcom-picoitx_somrev0_boardrev0"; - loadables = "uboot"; - fdt = "fdt-3"; - }; - - config-6 { - /* DT+SoM+board model */ - description = "dh,stm32mp157c-dhcom-picoitx_somrev1_boardrev0"; - loadables = "uboot"; - fdt = "fdt-3"; - }; - - /* Add 587-100..587-400 with fdt-2..fdt-4 here */ - }; -}; diff --git a/board/dhelectronics/dh_stm32mp1/u-boot-dhcor.its b/board/dhelectronics/dh_stm32mp1/u-boot-dhcor.its deleted file mode 100644 index e17dac77804..00000000000 --- a/board/dhelectronics/dh_stm32mp1/u-boot-dhcor.its +++ /dev/null @@ -1,70 +0,0 @@ -/dts-v1/; - -/ { - description = "U-Boot mainline"; - #address-cells = <1>; - - images { - uboot { - description = "U-Boot (32-bit)"; - data = /incbin/("u-boot-nodtb.bin"); - type = "standalone"; - os = "U-Boot"; - arch = "arm"; - compression = "none"; - load = <0xc0100000>; - entry = <0xc0100000>; - }; - - fdt-1 { - description = ".dtb"; - data = /incbin/("dts/upstream/src/arm/st/stm32mp151a-dhcor-testbench.dtb"); - type = "flat_dt"; - arch = "arm"; - compression = "none"; - }; - - fdt-2 { - description = ".dtb"; - data = /incbin/("dts/upstream/src/arm/st/stm32mp157a-dhcor-avenger96.dtb"); - type = "flat_dt"; - arch = "arm"; - compression = "none"; - }; - - fdt-3 { - description = ".dtb"; - data = /incbin/("dts/upstream/src/arm/st/stm32mp153c-dhcor-drc-compact.dtb"); - type = "flat_dt"; - arch = "arm"; - compression = "none"; - }; - }; - - configurations { - default = "config-1"; - - config-1 { - /* DT+SoM+board model */ - description = "dh,stm32mp151a-dhcor-testbench_somrev0_boardrev1"; - firmware = "uboot"; - fdt = "fdt-1"; - }; - - config-2 { - /* DT+SoM+board model */ - description = "arrow,stm32mp157a-avenger96_somrev0_boardrev1"; - firmware = "uboot"; - fdt = "fdt-2"; - }; - - config-3 { - /* DT+SoM+board model */ - description = "dh,stm32mp153c-dhcor-drc-compact_somrev0_boardrev0"; - firmware = "uboot"; - fdt = "fdt-3"; - }; - - /* Add 586-200..586-400 with fdt-2..fdt-4 here */ - }; -}; diff --git a/configs/stm32mp15_dhcom_basic_defconfig b/configs/stm32mp15_dhcom_basic_defconfig index e2a26e2b774..bb2866a6782 100644 --- a/configs/stm32mp15_dhcom_basic_defconfig +++ b/configs/stm32mp15_dhcom_basic_defconfig @@ -30,7 +30,6 @@ CONFIG_BOARD_SIZE_LIMIT=1441792 CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0xc1000000 -CONFIG_SPL_FIT_SOURCE="board/dhelectronics/dh_stm32mp1/u-boot-dhcom.its" CONFIG_SYS_BOOTM_LEN=0x2000000 CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=1 @@ -59,7 +58,6 @@ CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_SPI_FLASH_MTD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x80000 -CONFIG_SPL_TARGET="u-boot.itb" CONFIG_SYS_PROMPT="STM32MP> " # CONFIG_CMD_ELF is not set # CONFIG_CMD_EXPORTENV is not set diff --git a/configs/stm32mp15_dhcor_basic_defconfig b/configs/stm32mp15_dhcor_basic_defconfig index f73bd2fa12c..8868d54c120 100644 --- a/configs/stm32mp15_dhcor_basic_defconfig +++ b/configs/stm32mp15_dhcor_basic_defconfig @@ -28,7 +28,6 @@ CONFIG_BOARD_SIZE_LIMIT=1441792 CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0xc1000000 -CONFIG_SPL_FIT_SOURCE="board/dhelectronics/dh_stm32mp1/u-boot-dhcor.its" CONFIG_SYS_BOOTM_LEN=0x2000000 CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=1 @@ -57,7 +56,6 @@ CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y CONFIG_SPL_SPI_FLASH_MTD=y CONFIG_SYS_SPI_U_BOOT_OFFS=0x80000 -CONFIG_SPL_TARGET="u-boot.itb" CONFIG_SYS_PROMPT="STM32MP> " # CONFIG_CMD_ELF is not set # CONFIG_CMD_EXPORTENV is not set
V2: No change
Nice, I discover the binman FIT Substitutions with N / SEQ
Thanks Patrick
V2: No change
Thanks Patrick
Regards Patrick
The cpu0-opp-table {} node does not exist in upstream Linux stm32mp151.dtsi file, in order to enable conversion to OF_UPSTREAM, duplicate the node from current U-Boot stm32mp151.dtsi into stm32mp15-u-boot.dtsi. This makes STM32 DTs buildable even with OF_UPSTREAM enabled. No functional change, since the current U-Boot stm32mp151.dtsi already contains the cpu0-opp-table {} node, stm32mp15-u-boot.dtsi is applied at the end, and does not bring in any new content.
V2: No change
arch/arm/dts/stm32mp15-u-boot.dtsi | 30 ++++++++++++++++++++++-------- 1 file changed, 22 insertions(+), 8 deletions(-)
Sorry for previous message,
Re: [PATCH 1/3] ARM: dts: stm32: Duplicate cpu0-opp-table node into stm32mp15-u-boot.dtsi
I answered on V1 by error.
Thanks Patrick
V2: No change
Thanks Patrick
Regards Patrick
Patrick DELAUNAY
