[PATCH] dm: core: Provide fallbacks for ofnode_conf_read_...
Because fdt_get_config_str et al. were moved/renamed to ofnode_conf_read_str, they now depend on CONFIG_DM as well as CONFIG_OF_CONTROL. Add some fallback implementations, preventing a linker error when CONFIG_SPL_OF_CONTROL and CONFIG_SPL_ENV_IS_IN_MMC are enabled and CONFIG_SPL_DM is disabled.
Fixes: 7de8bd03c3 ("treewide: fdt: Move fdt_get_config_... to ofnode_conf_read...") Signed-off-by: Sean Anderson sean.anderson@seco.com ---
include/dm/ofnode.h | 17 +++++++++++++++++ 1 file changed, 17 insertions(+)
diff --git a/include/dm/ofnode.h b/include/dm/ofnode.h index 744dffe0a2..434696b2b6 100644 --- a/include/dm/ofnode.h +++ b/include/dm/ofnode.h @@ -1180,6 +1180,7 @@ int ofnode_write_string(ofnode node, const char *propname, const char *value); */ int ofnode_set_enabled(ofnode node, bool value);
+#if CONFIG_IS_ENABLED(DM) /** * ofnode_conf_read_bool() - Read a boolean value from the U-Boot config * @@ -1216,5 +1217,21 @@ int ofnode_conf_read_int(const char *prop_name, int default_val); * Return: string value, if found, or NULL if not */ const char *ofnode_conf_read_str(const char *prop_name); +#else /* CONFIG_DM */ +static inline bool ofnode_conf_read_bool(const char *prop_name) +{ + return false; +} + +static inline int ofnode_conf_read_int(const char *prop_name, int default_val) +{ + return default_val; +} + +static inline const char *ofnode_conf_read_str(const char *prop_name) +{ + return NULL; +} +#endif /* CONFIG_DM */
#endif
- ofnode_conf_read_bool() - Read a boolean value from the U-Boot config
- Return: string value, if found, or NULL if not
- return false;
- return default_val;
- return NULL;
#endif
ping?
--Sean
Applied to u-boot-dm, thanks!
Sean Anderson
