[PATCH 1/1] riscv: Clean up asm/io.h
Clean up asm/io.h by - removing commented code - removing outdated comments - removing unused definitions (for mem_isa, mem_pci)
Suggested by commits: (7ab2e47d27) arm: Clean up asm/io.h (909d0399a5) ARM: asm/io.h: kill off confusing #ifdef __mem_pci block
This massively improves the readability of the file.
Signed-off-by: Leo Yu-Chi Liang ycliang@andestech.com --- arch/riscv/include/asm/io.h | 117 +----------------------------------- 1 file changed, 1 insertion(+), 116 deletions(-)
diff --git a/arch/riscv/include/asm/io.h b/arch/riscv/include/asm/io.h index fc39bb2c70..49bffac03c 100644 --- a/arch/riscv/include/asm/io.h +++ b/arch/riscv/include/asm/io.h @@ -7,8 +7,6 @@ #ifndef __ASM_RISCV_IO_H #define __ASM_RISCV_IO_H
-#ifdef __KERNEL__ - #include <linux/types.h> #include <asm/barrier.h> #include <asm/byteorder.h> @@ -39,11 +37,7 @@ static inline phys_addr_t map_to_sysmem(const void *ptr) } #endif
-/* - * Generic virtual read/write. Note that we don't support half-word - * read/writes. We define __arch_*[bl] here, and leave __arch_*w - * to the architecture specific code. - */ +/* Generic virtual read/write. */ #define __arch_getb(a) (*(volatile unsigned char *)(a)) #define __arch_getw(a) (*(volatile unsigned short *)(a)) #define __arch_getl(a) (*(volatile unsigned int *)(a)) @@ -352,115 +346,6 @@ static inline void writesl(unsigned int *addr, const void *data, int longlen) #define insw_p(port, to, len) insw(port, to, len) #define insl_p(port, to, len) insl(port, to, len)
-/* - * DMA-consistent mapping functions. These allocate/free a region of - * uncached, unwrite-buffered mapped memory space for use with DMA - * devices. This is the "generic" version. The PCI specific version - * is in pci.h - */ - -/* - * String version of IO memory access ops: - */ - -/* - * If this architecture has PCI memory IO, then define the read/write - * macros. These should only be used with the cookie passed from - * ioremap. - */ -#ifdef __mem_pci - -#define readb(c) ({ unsigned int __v = \ - __raw_readb(__mem_pci(c)); __v; }) -#define readw(c) ({ unsigned int __v = \ - le16_to_cpu(__raw_readw(__mem_pci(c))); __v; }) -#define readl(c) ({ unsigned int __v = \ - le32_to_cpu(__raw_readl(__mem_pci(c))); __v; }) - -#define writeb(v, c) __raw_writeb(v, __mem_pci(c)) -#define writew(v, c) __raw_writew(cpu_to_le16(v), __mem_pci(c)) -#define writel(v, c) __raw_writel(cpu_to_le32(v), __mem_pci(c)) - -#define memset_io(c, v, l) _memset_io(__mem_pci(c), (v), (l)) -#define memcpy_fromio(a, c, l) _memcpy_fromio((a), __mem_pci(c), (l)) -#define memcpy_toio(c, a, l) _memcpy_toio(__mem_pci(c), (a), (l)) - -#define eth_io_copy_and_sum(s, c, l, b) \ - eth_copy_and_sum((s), __mem_pci(c), (l), (b)) - -static inline int check_signature(ulong io_addr, const uchar *s, int len) -{ - int retval = 0; - - do { - if (readb(io_addr) != *s) - goto out; - io_addr++; - s++; - len--; - } while (len); - retval = 1; -out: - return retval; -} -#endif /* __mem_pci */ - -/* - * If this architecture has ISA IO, then define the isa_read/isa_write - * macros. - */ -#ifdef __mem_isa - -#define isa_readb(addr) __raw_readb(__mem_isa(addr)) -#define isa_readw(addr) __raw_readw(__mem_isa(addr)) -#define isa_readl(addr) __raw_readl(__mem_isa(addr)) -#define isa_writeb(val, addr) __raw_writeb(val, __mem_isa(addr)) -#define isa_writew(val, addr) __raw_writew(val, __mem_isa(addr)) -#define isa_writel(val, addr) __raw_writel(val, __mem_isa(addr)) -#define isa_memset_io(a, b, c) _memset_io(__mem_isa(a), (b), (c)) -#define isa_memcpy_fromio(a, b, c) _memcpy_fromio((a), __mem_isa(b), (c)) -#define isa_memcpy_toio(a, b, c) _memcpy_toio(__mem_isa((a)), (b), (c)) - -#define isa_eth_io_copy_and_sum(a, b, c, d) \ - eth_copy_and_sum((a), __mem_isa(b), (c), (d)) - -static inline int -isa_check_signature(ulong io_addr, const uchar *s, int len) -{ - int retval = 0; - - do { - if (isa_readb(io_addr) != *s) - goto out; - io_addr++; - s++; - len--; - } while (len); - retval = 1; -out: - return retval; -} - -#else /* __mem_isa */ - -#define isa_readb(addr) (__readwrite_bug("isa_readb"), 0) -#define isa_readw(addr) (__readwrite_bug("isa_readw"), 0) -#define isa_readl(addr) (__readwrite_bug("isa_readl"), 0) -#define isa_writeb(val, addr) __readwrite_bug("isa_writeb") -#define isa_writew(val, addr) __readwrite_bug("isa_writew") -#define isa_writel(val, addr) __readwrite_bug("isa_writel") -#define isa_memset_io(a, b, c) __readwrite_bug("isa_memset_io") -#define isa_memcpy_fromio(a, b, c) __readwrite_bug("isa_memcpy_fromio") -#define isa_memcpy_toio(a, b, c) __readwrite_bug("isa_memcpy_toio") - -#define isa_eth_io_copy_and_sum(a, b, c, d) \ - __readwrite_bug("isa_eth_io_copy_and_sum") - -#define isa_check_signature(io, sig, len) (0) - -#endif /* __mem_isa */ -#endif /* __KERNEL__ */ - #include <asm-generic/io.h>
#endif /* __ASM_RISCV_IO_H */
On Thu, May 19, 2022 at 10:44 AM Leo Yu-Chi Liang ycliang@andestech.com wrote:
nits: the commits format is not correct
-#ifdef __KERNEL__
- Generic virtual read/write. Note that we don't support half-word
- read/writes. We define __arch_*[bl] here, and leave __arch_*w
- to the architecture specific code.
- DMA-consistent mapping functions. These allocate/free a region of
- uncached, unwrite-buffered mapped memory space for use with DMA
- devices. This is the "generic" version. The PCI specific version
- is in pci.h
- String version of IO memory access ops:
- If this architecture has PCI memory IO, then define the read/write
- macros. These should only be used with the cookie passed from
- ioremap.
-#ifdef __mem_pci
int retval = 0;
do {
goto out;
io_addr++;
s++;
len--;
} while (len);
retval = 1;
-out:
return retval;
- If this architecture has ISA IO, then define the isa_read/isa_write
- macros.
-#ifdef __mem_isa
int retval = 0;
do {
goto out;
io_addr++;
s++;
len--;
} while (len);
retval = 1;
-out:
return retval;
Otherwise, Reviewed-by: Bin Meng bmeng.cn@gmail.com
Bin Meng
Leo Yu-Chi Liang
