[U-Boot] [PATCH] Pass sdrc timing values through board_sdrc_timings structure
Instead of passing individual registers by value to board_get_mem_timings, pass a board_mem_timings structure pointer for the board files to fill in. Pass same structure pointer to write_sdrc_timings. This saves about 90 bytes of space in SPL.
Signed-off-by: Peter Barada peter.barada@logicpd.com --- arch/arm/cpu/armv7/omap3/sdrc.c | 36 ++++++++---------- arch/arm/include/asm/arch-omap3/sys_proto.h | 13 ++++++- board/corscience/tricorder/tricorder.c | 13 +++---- board/isee/igep0020/igep0020.c | 29 +++++++-------- board/isee/igep0030/igep0030.c | 29 +++++++-------- board/overo/overo.c | 37 +++++++++---------- board/ti/beagle/beagle.c | 53 +++++++++++++-------------- board/ti/evm/evm.c | 19 +++++----- board/timll/devkit8000/devkit8000.c | 13 +++---- 9 files changed, 120 insertions(+), 122 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap3/sdrc.c b/arch/arm/cpu/armv7/omap3/sdrc.c index f6d9b97..e32bf11 100644 --- a/arch/arm/cpu/armv7/omap3/sdrc.c +++ b/arch/arm/cpu/armv7/omap3/sdrc.c @@ -113,18 +113,18 @@ u32 get_sdr_cs_offset(u32 cs) * - Test CS to make sure it's OK for use */ static void write_sdrc_timings(u32 cs, struct sdrc_actim *sdrc_actim_base, - u32 mcfg, u32 ctrla, u32 ctrlb, u32 rfr_ctrl, u32 mr) + struct board_sdrc_timings *timings) { /* Setup timings we got from the board. */ - writel(mcfg, &sdrc_base->cs[cs].mcfg); - writel(ctrla, &sdrc_actim_base->ctrla); - writel(ctrlb, &sdrc_actim_base->ctrlb); - writel(rfr_ctrl, &sdrc_base->cs[cs].rfr_ctrl); + writel(timings->mcfg, &sdrc_base->cs[cs].mcfg); + writel(timings->ctrla, &sdrc_actim_base->ctrla); + writel(timings->ctrlb, &sdrc_actim_base->ctrlb); + writel(timings->rfr_ctrl, &sdrc_base->cs[cs].rfr_ctrl); writel(CMD_NOP, &sdrc_base->cs[cs].manual); writel(CMD_PRECHARGE, &sdrc_base->cs[cs].manual); writel(CMD_AUTOREFRESH, &sdrc_base->cs[cs].manual); writel(CMD_AUTOREFRESH, &sdrc_base->cs[cs].manual); - writel(mr, &sdrc_base->cs[cs].mr); + writel(timings->mr, &sdrc_base->cs[cs].mr);
/* * Test ram in this bank @@ -143,7 +143,7 @@ static void write_sdrc_timings(u32 cs, struct sdrc_actim *sdrc_actim_base, void do_sdrc_init(u32 cs, u32 early) { struct sdrc_actim *sdrc_actim_base0, *sdrc_actim_base1; - u32 mcfg, ctrla, ctrlb, rfr_ctrl, mr; + struct board_sdrc_timings timings;
sdrc_actim_base0 = (struct sdrc_actim *)SDRC_ACTIM_CTRL0_BASE; sdrc_actim_base1 = (struct sdrc_actim *)SDRC_ACTIM_CTRL1_BASE; @@ -158,7 +158,7 @@ void do_sdrc_init(u32 cs, u32 early) * setup CS1. */ #ifdef CONFIG_SPL_BUILD - get_board_mem_timings(&mcfg, &ctrla, &ctrlb, &rfr_ctrl, &mr); + get_board_mem_timings(&timings); #endif if (early) { /* reset sdrc controller */ @@ -177,11 +177,9 @@ void do_sdrc_init(u32 cs, u32 early) writel(ENADLL | DLLPHASE_90, &sdrc_base->dlla_ctrl); sdelay(0x20000); #ifdef CONFIG_SPL_BUILD - write_sdrc_timings(CS0, sdrc_actim_base0, mcfg, ctrla, ctrlb, - rfr_ctrl, mr); + write_sdrc_timings(CS0, sdrc_actim_base0, &timings); make_cs1_contiguous(); - write_sdrc_timings(CS1, sdrc_actim_base1, mcfg, ctrla, ctrlb, - rfr_ctrl, mr); + write_sdrc_timings(CS1, sdrc_actim_base1, &timings); #endif
} @@ -193,14 +191,12 @@ void do_sdrc_init(u32 cs, u32 early) * so we may be asked now to setup CS1. */ if (cs == CS1) { - mcfg = readl(&sdrc_base->cs[CS0].mcfg), - rfr_ctrl = readl(&sdrc_base->cs[CS0].rfr_ctrl); - ctrla = readl(&sdrc_actim_base0->ctrla), - ctrlb = readl(&sdrc_actim_base0->ctrlb); - mr = readl(&sdrc_base->cs[CS0].mr); - write_sdrc_timings(cs, sdrc_actim_base1, mcfg, ctrla, ctrlb, - rfr_ctrl, mr); - + timings.mcfg = readl(&sdrc_base->cs[CS0].mcfg), + timings.rfr_ctrl = readl(&sdrc_base->cs[CS0].rfr_ctrl); + timings.ctrla = readl(&sdrc_actim_base0->ctrla); + timings.ctrlb = readl(&sdrc_actim_base0->ctrlb); + timings.mr = readl(&sdrc_base->cs[CS0].mr); + write_sdrc_timings(cs, sdrc_actim_base1, &timings); } }
diff --git a/arch/arm/include/asm/arch-omap3/sys_proto.h b/arch/arm/include/asm/arch-omap3/sys_proto.h index 9e52b12..d60f2ad 100644 --- a/arch/arm/include/asm/arch-omap3/sys_proto.h +++ b/arch/arm/include/asm/arch-omap3/sys_proto.h @@ -32,6 +32,15 @@ struct emu_hal_params { u32 param1; };
+/* Board SDRC timing values */ +struct board_sdrc_timings { + u32 mcfg; + u32 ctrla; + u32 ctrlb; + u32 rfr_ctrl; + u32 mr; +}; + void prcm_init(void); void per_clocks_enable(void); void ehci_clocks_enable(void); @@ -39,8 +48,8 @@ void ehci_clocks_enable(void); void memif_init(void); void sdrc_init(void); void do_sdrc_init(u32, u32); -void get_board_mem_timings(u32 *mcfg, u32 *ctrla, u32 *ctrlb, u32 *rfr_ctrl, - u32 *mr); + +void get_board_mem_timings(struct board_sdrc_timings *timings); void identify_nand_chip(int *mfr, int *id); void emif4_init(void); void gpmc_init(void); diff --git a/board/corscience/tricorder/tricorder.c b/board/corscience/tricorder/tricorder.c index aaff2e8..56fe495 100644 --- a/board/corscience/tricorder/tricorder.c +++ b/board/corscience/tricorder/tricorder.c @@ -91,15 +91,14 @@ int board_mmc_init(bd_t *bis) * provides the timing values back to the function that configures * the memory. We have either one or two banks of 128MB DDR. */ -void get_board_mem_timings(u32 *mcfg, u32 *ctrla, u32 *ctrlb, u32 *rfr_ctrl, - u32 *mr) +void get_board_mem_timings(struct board_sdrc_timings *timings) { /* General SDRC config */ - *mcfg = MICRON_V_MCFG_165(128 << 20); - *rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz; + timings->mcfg = MICRON_V_MCFG_165(128 << 20); + timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz;
/* AC timings */ - *ctrla = MICRON_V_ACTIMA_165; - *ctrlb = MICRON_V_ACTIMB_165; - *mr = MICRON_V_MR_165; + timings->ctrla = MICRON_V_ACTIMA_165; + timings->ctrlb = MICRON_V_ACTIMB_165; + timings->mr = MICRON_V_MR_165; } diff --git a/board/isee/igep0020/igep0020.c b/board/isee/igep0020/igep0020.c index a8257a3..a0f2aa3 100644 --- a/board/isee/igep0020/igep0020.c +++ b/board/isee/igep0020/igep0020.c @@ -72,27 +72,26 @@ void omap_rev_string(void) * Description: If we use SPL then there is no x-loader nor config header * so we have to setup the DDR timings ourself on both banks. */ -void get_board_mem_timings(u32 *mcfg, u32 *ctrla, u32 *ctrlb, u32 *rfr_ctrl, - u32 *mr) +void get_board_mem_timings(struct board_sdrc_timings *timings) { - *mr = MICRON_V_MR_165; + timings->mr = MICRON_V_MR_165; #ifdef CONFIG_BOOT_NAND - *mcfg = MICRON_V_MCFG_200(256 << 20); - *ctrla = MICRON_V_ACTIMA_200; - *ctrlb = MICRON_V_ACTIMB_200; - *rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_200MHz; + timings->mcfg = MICRON_V_MCFG_200(256 << 20); + timings->ctrla = MICRON_V_ACTIMA_200; + timings->ctrlb = MICRON_V_ACTIMB_200; + timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_200MHz; #else if (get_cpu_family() == CPU_OMAP34XX) { - *mcfg = NUMONYX_V_MCFG_165(256 << 20); - *ctrla = NUMONYX_V_ACTIMA_165; - *ctrlb = NUMONYX_V_ACTIMB_165; - *rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz; + timings->mcfg = NUMONYX_V_MCFG_165(256 << 20); + timings->ctrla = NUMONYX_V_ACTIMA_165; + timings->ctrlb = NUMONYX_V_ACTIMB_165; + timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz;
} else { - *mcfg = NUMONYX_V_MCFG_200(256 << 20); - *ctrla = NUMONYX_V_ACTIMA_200; - *ctrlb = NUMONYX_V_ACTIMB_200; - *rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_200MHz; + timings->mcfg = NUMONYX_V_MCFG_200(256 << 20); + timings->ctrla = NUMONYX_V_ACTIMA_200; + timings->ctrlb = NUMONYX_V_ACTIMB_200; + timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_200MHz; } #endif } diff --git a/board/isee/igep0030/igep0030.c b/board/isee/igep0030/igep0030.c index 107cb7f..a41e752 100644 --- a/board/isee/igep0030/igep0030.c +++ b/board/isee/igep0030/igep0030.c @@ -59,27 +59,26 @@ void omap_rev_string(void) * Description: If we use SPL then there is no x-loader nor config header * so we have to setup the DDR timings ourself on both banks. */ -void get_board_mem_timings(u32 *mcfg, u32 *ctrla, u32 *ctrlb, u32 *rfr_ctrl, - u32 *mr) +void get_board_mem_timings(struct board_sdrc_timings *timings) { - *mr = MICRON_V_MR_165; + timings->mr = MICRON_V_MR_165; #ifdef CONFIG_BOOT_NAND - *mcfg = MICRON_V_MCFG_200(256 << 20); - *ctrla = MICRON_V_ACTIMA_200; - *ctrlb = MICRON_V_ACTIMB_200; - *rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_200MHz; + timings->mcfg = MICRON_V_MCFG_200(256 << 20); + timings->ctrla = MICRON_V_ACTIMA_200; + timings->ctrlb = MICRON_V_ACTIMB_200; + timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_200MHz; #else if (get_cpu_family() == CPU_OMAP34XX) { - *mcfg = NUMONYX_V_MCFG_165(256 << 20); - *ctrla = NUMONYX_V_ACTIMA_165; - *ctrlb = NUMONYX_V_ACTIMB_165; - *rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz; + timings->mcfg = NUMONYX_V_MCFG_165(256 << 20); + timings->ctrla = NUMONYX_V_ACTIMA_165; + timings->ctrlb = NUMONYX_V_ACTIMB_165; + timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz;
} else { - *mcfg = NUMONYX_V_MCFG_200(256 << 20); - *ctrla = NUMONYX_V_ACTIMA_200; - *ctrlb = NUMONYX_V_ACTIMB_200; - *rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_200MHz; + timings->mcfg = NUMONYX_V_MCFG_200(256 << 20); + timings->ctrla = NUMONYX_V_ACTIMA_200; + timings->ctrlb = NUMONYX_V_ACTIMB_200; + timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_200MHz; } #endif } diff --git a/board/overo/overo.c b/board/overo/overo.c index c6d50a0..fdf46a2 100644 --- a/board/overo/overo.c +++ b/board/overo/overo.c @@ -147,34 +147,33 @@ int get_board_revision(void) * Description: If we use SPL then there is no x-loader nor config header * so we have to setup the DDR timings ourself on both banks. */ -void get_board_mem_timings(u32 *mcfg, u32 *ctrla, u32 *ctrlb, u32 *rfr_ctrl, - u32 *mr) +void get_board_mem_timings(struct board_sdrc_timings *timings) { - *mr = MICRON_V_MR_165; + timings->mr = MICRON_V_MR_165; switch (get_board_revision()) { case REVISION_0: /* Micron 1286MB/256MB, 1/2 banks of 128MB */ - *mcfg = MICRON_V_MCFG_165(128 << 20); - *ctrla = MICRON_V_ACTIMA_165; - *ctrlb = MICRON_V_ACTIMB_165; - *rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz; + timings->mcfg = MICRON_V_MCFG_165(128 << 20); + timings->ctrla = MICRON_V_ACTIMA_165; + timings->ctrlb = MICRON_V_ACTIMB_165; + timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz; break; case REVISION_1: /* Micron 256MB/512MB, 1/2 banks of 256MB */ - *mcfg = MICRON_V_MCFG_165(256 << 20); - *ctrla = MICRON_V_ACTIMA_165; - *ctrlb = MICRON_V_ACTIMB_165; - *rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz; + timings->mcfg = MICRON_V_MCFG_165(256 << 20); + timings->ctrla = MICRON_V_ACTIMA_165; + timings->ctrlb = MICRON_V_ACTIMB_165; + timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz; break; case REVISION_2: /* Hynix 256MB/512MB, 1/2 banks of 256MB */ - *mcfg = HYNIX_V_MCFG_165(256 << 20); - *ctrla = HYNIX_V_ACTIMA_165; - *ctrlb = HYNIX_V_ACTIMB_165; - *rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz; + timings->mcfg = HYNIX_V_MCFG_165(256 << 20); + timings->ctrla = HYNIX_V_ACTIMA_165; + timings->ctrlb = HYNIX_V_ACTIMB_165; + timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz; break; default: - *mcfg = MICRON_V_MCFG_165(128 << 20); - *ctrla = MICRON_V_ACTIMA_165; - *ctrlb = MICRON_V_ACTIMB_165; - *rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz; + timings->mcfg = MICRON_V_MCFG_165(128 << 20); + timings->ctrla = MICRON_V_ACTIMA_165; + timings->ctrlb = MICRON_V_ACTIMB_165; + timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz; } } #endif diff --git a/board/ti/beagle/beagle.c b/board/ti/beagle/beagle.c index 6175e1d..4adf982 100644 --- a/board/ti/beagle/beagle.c +++ b/board/ti/beagle/beagle.c @@ -139,8 +139,7 @@ static int get_board_revision(void) * Description: If we use SPL then there is no x-loader nor config header * so we have to setup the DDR timings ourself on both banks. */ -void get_board_mem_timings(u32 *mcfg, u32 *ctrla, u32 *ctrlb, u32 *rfr_ctrl, - u32 *mr) +void get_board_mem_timings(struct board_sdrc_timings *timings) { int pop_mfr, pop_id;
@@ -151,29 +150,29 @@ void get_board_mem_timings(u32 *mcfg, u32 *ctrla, u32 *ctrlb, u32 *rfr_ctrl, */ identify_nand_chip(&pop_mfr, &pop_id);
- *mr = MICRON_V_MR_165; + timings->mr = MICRON_V_MR_165; switch (get_board_revision()) { case REVISION_C4: if (pop_mfr == NAND_MFR_STMICRO && pop_id == 0xba) { /* 512MB DDR */ - *mcfg = NUMONYX_V_MCFG_165(512 << 20); - *ctrla = NUMONYX_V_ACTIMA_165; - *ctrlb = NUMONYX_V_ACTIMB_165; - *rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz; + timings->mcfg = NUMONYX_V_MCFG_165(512 << 20); + timings->ctrla = NUMONYX_V_ACTIMA_165; + timings->ctrlb = NUMONYX_V_ACTIMB_165; + timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz; break; } else if (pop_mfr == NAND_MFR_MICRON && pop_id == 0xba) { /* Beagleboard Rev C4, 512MB Nand/256MB DDR*/ - *mcfg = MICRON_V_MCFG_165(128 << 20); - *ctrla = MICRON_V_ACTIMA_165; - *ctrlb = MICRON_V_ACTIMB_165; - *rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz; + timings->mcfg = MICRON_V_MCFG_165(128 << 20); + timings->ctrla = MICRON_V_ACTIMA_165; + timings->ctrlb = MICRON_V_ACTIMB_165; + timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz; break; } else if (pop_mfr == NAND_MFR_MICRON && pop_id == 0xbc) { /* Beagleboard Rev C5, 256MB DDR */ - *mcfg = MICRON_V_MCFG_200(256 << 20); - *ctrla = MICRON_V_ACTIMA_200; - *ctrlb = MICRON_V_ACTIMB_200; - *rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_200MHz; + timings->mcfg = MICRON_V_MCFG_200(256 << 20); + timings->ctrla = MICRON_V_ACTIMA_200; + timings->ctrlb = MICRON_V_ACTIMB_200; + timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_200MHz; break; } case REVISION_XM_A: @@ -181,24 +180,24 @@ void get_board_mem_timings(u32 *mcfg, u32 *ctrla, u32 *ctrlb, u32 *rfr_ctrl, case REVISION_XM_C: if (pop_mfr == 0) { /* 256MB DDR */ - *mcfg = MICRON_V_MCFG_200(256 << 20); - *ctrla = MICRON_V_ACTIMA_200; - *ctrlb = MICRON_V_ACTIMB_200; - *rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_200MHz; + timings->mcfg = MICRON_V_MCFG_200(256 << 20); + timings->ctrla = MICRON_V_ACTIMA_200; + timings->ctrlb = MICRON_V_ACTIMB_200; + timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_200MHz; } else { /* 512MB DDR */ - *mcfg = NUMONYX_V_MCFG_165(512 << 20); - *ctrla = NUMONYX_V_ACTIMA_165; - *ctrlb = NUMONYX_V_ACTIMB_165; - *rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz; + timings->mcfg = NUMONYX_V_MCFG_165(512 << 20); + timings->ctrla = NUMONYX_V_ACTIMA_165; + timings->ctrlb = NUMONYX_V_ACTIMB_165; + timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz; } break; default: /* Assume 128MB and Micron/165MHz timings to be safe */ - *mcfg = MICRON_V_MCFG_165(128 << 20); - *ctrla = MICRON_V_ACTIMA_165; - *ctrlb = MICRON_V_ACTIMB_165; - *rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz; + timings->mcfg = MICRON_V_MCFG_165(128 << 20); + timings->ctrla = MICRON_V_ACTIMA_165; + timings->ctrlb = MICRON_V_ACTIMB_165; + timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz; } } #endif diff --git a/board/ti/evm/evm.c b/board/ti/evm/evm.c index 61fc7b5..8a3aa0c 100644 --- a/board/ti/evm/evm.c +++ b/board/ti/evm/evm.c @@ -128,8 +128,7 @@ int board_init(void) * provides the timing values back to the function that configures * the memory. */ -void get_board_mem_timings(u32 *mcfg, u32 *ctrla, u32 *ctrlb, u32 *rfr_ctrl, - u32 *mr) +void get_board_mem_timings(struct board_sdrc_timings *timings) { int pop_mfr, pop_id;
@@ -142,17 +141,17 @@ void get_board_mem_timings(u32 *mcfg, u32 *ctrla, u32 *ctrlb, u32 *rfr_ctrl,
if (pop_mfr == NAND_MFR_HYNIX && pop_id == 0xbc) { /* 256MB DDR */ - *mcfg = HYNIX_V_MCFG_200(256 << 20); - *ctrla = HYNIX_V_ACTIMA_200; - *ctrlb = HYNIX_V_ACTIMB_200; + timings->mcfg = HYNIX_V_MCFG_200(256 << 20); + timings->ctrla = HYNIX_V_ACTIMA_200; + timings->ctrlb = HYNIX_V_ACTIMB_200; } else { /* 128MB DDR */ - *mcfg = MICRON_V_MCFG_165(128 << 20); - *ctrla = MICRON_V_ACTIMA_165; - *ctrlb = MICRON_V_ACTIMB_165; + timings->mcfg = MICRON_V_MCFG_165(128 << 20); + timings->ctrla = MICRON_V_ACTIMA_165; + timings->ctrlb = MICRON_V_ACTIMB_165; } - *rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz; - *mr = MICRON_V_MR_165; + timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz; + timings->mr = MICRON_V_MR_165; } #endif
diff --git a/board/timll/devkit8000/devkit8000.c b/board/timll/devkit8000/devkit8000.c index 35f5e15..85685ee 100644 --- a/board/timll/devkit8000/devkit8000.c +++ b/board/timll/devkit8000/devkit8000.c @@ -188,16 +188,15 @@ int spl_start_uboot(void) * provides the timing values back to the function that configures * the memory. We have either one or two banks of 128MB DDR. */ -void get_board_mem_timings(u32 *mcfg, u32 *ctrla, u32 *ctrlb, u32 *rfr_ctrl, - u32 *mr) +void get_board_mem_timings(struct board_sdrc_timings *timings) { /* General SDRC config */ - *mcfg = MICRON_V_MCFG_165(128 << 20); - *rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz; + timings->mcfg = MICRON_V_MCFG_165(128 << 20); + timings->rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz;
/* AC timings */ - *ctrla = MICRON_V_ACTIMA_165; - *ctrlb = MICRON_V_ACTIMB_165; + timings->ctrla = MICRON_V_ACTIMA_165; + timings->ctrlb = MICRON_V_ACTIMB_165;
- *mr = MICRON_V_MR_165; + timings->mr = MICRON_V_MR_165; }
(This is actually v2, just applying vs current of an older patch, pre MW closing).
Applied to u-boot-ti/master, thanks!
Peter Barada
