[PATCH 1/1] efi_loader: use logging for bootefi command
Log messages of the bootefi command instead of simply printing them to the console.
Do not show "## Application terminated" message when the UEFI binary completed successfully.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- cmd/bootefi.c | 42 ++++++++++++++++++++++++------------------ 1 file changed, 24 insertions(+), 18 deletions(-)
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 57552f99fc..8154efde52 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -5,6 +5,8 @@ * Copyright (c) 2016 Alexander Graf */
+#define LOG_CATEGORY LOGC_EFI + #include <common.h> #include <charset.h> #include <command.h> @@ -14,6 +16,7 @@ #include <env.h> #include <errno.h> #include <image.h> +#include <log.h> #include <malloc.h> #include <linux/libfdt.h> #include <linux/libfdt_env.h> @@ -62,7 +65,7 @@ static efi_status_t set_load_options(efi_handle_t handle, const char *env_var, size = utf8_utf16_strlen(env) + 1; loaded_image_info->load_options = calloc(size, sizeof(u16)); if (!loaded_image_info->load_options) { - printf("ERROR: Out of memory\n"); + log_err("ERROR: Out of memory\n"); EFI_CALL(systab.boottime->close_protocol(handle, &efi_guid_loaded_image, efi_root, NULL)); @@ -137,7 +140,7 @@ static efi_status_t copy_fdt(void **fdtp) EFI_ACPI_RECLAIM_MEMORY, fdt_pages, &new_fdt_addr); if (ret != EFI_SUCCESS) { - printf("ERROR: Failed to reserve space for FDT\n"); + log_err("ERROR: Failed to reserve space for FDT\n"); goto done; } } @@ -156,8 +159,8 @@ static void efi_reserve_memory(u64 addr, u64 size) addr = (uintptr_t)map_sysmem(addr, 0); if (efi_add_memory_map(addr, size, EFI_RESERVED_MEMORY_TYPE) != EFI_SUCCESS) - printf("Reserved memory mapping failed addr %llx size %llx\n", - addr, size); + log_err("Reserved memory mapping failed addr %llx size %llx\n", + addr, size); }
/** @@ -252,7 +255,7 @@ efi_status_t efi_install_fdt(void *fdt) */ #if CONFIG_IS_ENABLED(GENERATE_ACPI_TABLE) if (fdt) { - printf("ERROR: can't have ACPI table and device tree.\n"); + log_err("ERROR: can't have ACPI table and device tree.\n"); return EFI_LOAD_ERROR; } #else @@ -272,13 +275,13 @@ efi_status_t efi_install_fdt(void *fdt) if (!fdt_opt) { fdt_opt = env_get("fdtcontroladdr"); if (!fdt_opt) { - printf("ERROR: need device tree\n"); + log_err("ERROR: need device tree\n"); return EFI_NOT_FOUND; } } fdt_addr = simple_strtoul(fdt_opt, NULL, 16); if (!fdt_addr) { - printf("ERROR: invalid $fdt_addr or $fdtcontroladdr\n"); + log_err("ERROR: invalid $fdt_addr or $fdtcontroladdr\n"); return EFI_LOAD_ERROR; } fdt = map_sysmem(fdt_addr, 0); @@ -286,19 +289,19 @@ efi_status_t efi_install_fdt(void *fdt)
/* Install device tree */ if (fdt_check_header(fdt)) { - printf("ERROR: invalid device tree\n"); + log_err("ERROR: invalid device tree\n"); return EFI_LOAD_ERROR; }
/* Prepare device tree for payload */ ret = copy_fdt(&fdt); if (ret) { - printf("ERROR: out of memory\n"); + log_err("ERROR: out of memory\n"); return EFI_OUT_OF_RESOURCES; }
if (image_setup_libfdt(&img, fdt, 0, NULL)) { - printf("ERROR: failed to process device tree\n"); + log_err("ERROR: failed to process device tree\n"); return EFI_LOAD_ERROR; }
@@ -308,7 +311,7 @@ efi_status_t efi_install_fdt(void *fdt) /* Install device tree as UEFI table */ ret = efi_install_configuration_table(&efi_guid_fdt, fdt); if (ret != EFI_SUCCESS) { - printf("ERROR: failed to install device tree\n"); + log_err("ERROR: failed to install device tree\n"); return ret; } #endif /* GENERATE_ACPI_TABLE */ @@ -339,10 +342,13 @@ static efi_status_t do_bootefi_exec(efi_handle_t handle)
/* Call our payload! */ ret = EFI_CALL(efi_start_image(handle, &exit_data_size, &exit_data)); - printf("## Application terminated, r = %lu\n", ret & ~EFI_ERROR_MASK); - if (ret && exit_data) { - printf("## %ls\n", exit_data); - efi_free_pool(exit_data); + if (ret != EFI_SUCCESS) { + log_err("## Application failed, r = %lu\n", + ret & ~EFI_ERROR_MASK); + if (exit_data) { + log_err("## %ls\n", exit_data); + efi_free_pool(exit_data); + } }
efi_restore_gd(); @@ -364,7 +370,7 @@ static int do_efibootmgr(void)
ret = efi_bootmgr_load(&handle); if (ret != EFI_SUCCESS) { - printf("EFI boot manager: Cannot load any image\n"); + log_notice("EFI boot manager: Cannot load any image\n"); return CMD_RET_FAILURE; }
@@ -611,8 +617,8 @@ static int do_bootefi(struct cmd_tbl *cmdtp, int flag, int argc, /* Initialize EFI drivers */ ret = efi_init_obj_list(); if (ret != EFI_SUCCESS) { - printf("Error: Cannot initialize UEFI sub-system, r = %lu\n", - ret & ~EFI_ERROR_MASK); + log_err("Error: Cannot initialize UEFI sub-system, r = %lu\n", + ret & ~EFI_ERROR_MASK); return CMD_RET_FAILURE; }
-- 2.27.0
