[U-Boot] [PATCH 0/6] arm: am335x: Enable SPL_DM
Enable SPL_DM on all AM335x based TI platforms.
am335x_evm_defconfig: Before this seires: text data bss dec hex filename 76508 4185 204672 285365 45ab5 spl/u-boot-spl spl/u-boot-spl.bin: 80700 After this seires: text data bss dec hex filename 75589 3369 204608 283566 453ae spl/u-boot-spl spl/u-boot-spl.bin: 78964
am335x_hs_evm_defconfig: Before this series: text data bss dec hex filename 34317 2412 198856 235585 39841 spl/u-boot-spl spl/u-boot-spl.bin: 36732 After this series: text data bss dec hex filename 37590 2636 198856 239082 3a5ea spl/u-boot-spl spl/u-boot-spl.bin: 40228
Using board-data way instead of using DT as suggested by Tom here[1]. This is mainly due to space constraints.
[1] https://www.mail-archive.com/u-boot@lists.denx.de/msg238483.html
Lokesh Vutla (6): dm: mmc: omap_hsmmc: Update to support of-platdata dm: mmc: omap_hsmmc: Add pre-reloc flag to the driver configs: am335x_evm: Use omap2 generic spl load script am33xx: Provide platform data for mmc configs: am335x_evm: Enable SPL_DM arm: am335x: Enable tiny printf in SPL
arch/arm/Kconfig | 1 + arch/arm/include/asm/omap_mmc.h | 9 +++++++++ arch/arm/mach-omap2/am33xx/Kconfig | 5 +++++ board/ti/am335x/board.c | 32 ++++++++++++++++++++++++++++++++ drivers/mmc/omap_hsmmc.c | 25 +++++++++++++++---------- include/configs/am335x_evm.h | 3 +-- include/configs/ti_am335x_common.h | 2 ++ 7 files changed, 65 insertions(+), 12 deletions(-)
This is to aid platforms that uses OF_PLATDATA.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/include/asm/omap_mmc.h | 9 +++++++++ drivers/mmc/omap_hsmmc.c | 24 ++++++++++++++---------- 2 files changed, 23 insertions(+), 10 deletions(-)
diff --git a/arch/arm/include/asm/omap_mmc.h b/arch/arm/include/asm/omap_mmc.h index f2bf645b33..ba019b0788 100644 --- a/arch/arm/include/asm/omap_mmc.h +++ b/arch/arm/include/asm/omap_mmc.h @@ -25,6 +25,8 @@ #ifndef OMAP_MMC_H_ #define OMAP_MMC_H_
+#include <mmc.h> + struct hsmmc { #ifdef CONFIG_DM_MMC unsigned char res0[0x100]; @@ -52,6 +54,13 @@ struct hsmmc { unsigned int capa; /* 0x140 */ };
+struct omap_hsmmc_plat { + struct mmc_config cfg; + struct hsmmc *base_addr; + struct mmc mmc; + bool cd_inverted; +}; + /* * OMAP HS MMC Bit definitions */ diff --git a/drivers/mmc/omap_hsmmc.c b/drivers/mmc/omap_hsmmc.c index 83dda09c1f..f2489473b0 100644 --- a/drivers/mmc/omap_hsmmc.c +++ b/drivers/mmc/omap_hsmmc.c @@ -56,11 +56,6 @@ DECLARE_GLOBAL_DATA_PTR; #define SYSCTL_SRC (1 << 25) #define SYSCTL_SRD (1 << 26)
-struct omap_hsmmc_plat { - struct mmc_config cfg; - struct mmc mmc; -}; - struct omap_hsmmc_data { struct hsmmc *base_addr; #ifndef CONFIG_DM_MMC @@ -773,16 +768,16 @@ int omap_mmc_init(int dev_index, uint host_caps_mask, uint f_max, int cd_gpio, return 0; } #else +#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) static int omap_hsmmc_ofdata_to_platdata(struct udevice *dev) { - struct omap_hsmmc_data *priv = dev_get_priv(dev); struct omap_hsmmc_plat *plat = dev_get_platdata(dev); struct mmc_config *cfg = &plat->cfg; const void *fdt = gd->fdt_blob; int node = dev_of_offset(dev); int val;
- priv->base_addr = map_physmem(dev_get_addr(dev), sizeof(struct hsmmc *), + plat->base_addr = map_physmem(dev_get_addr(dev), sizeof(struct hsmmc *), MAP_NOCACHE);
cfg->host_caps = MMC_MODE_HS_52MHz | MMC_MODE_HS; @@ -809,11 +804,12 @@ static int omap_hsmmc_ofdata_to_platdata(struct udevice *dev) cfg->b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT;
#ifdef OMAP_HSMMC_USE_GPIO - priv->cd_inverted = fdtdec_get_bool(fdt, node, "cd-inverted"); + plat->cd_inverted = fdtdec_get_bool(fdt, node, "cd-inverted"); #endif
return 0; } +#endif
#ifdef CONFIG_BLK
@@ -834,6 +830,10 @@ static int omap_hsmmc_probe(struct udevice *dev)
cfg->name = "OMAP SD/MMC"; cfg->ops = &omap_hsmmc_ops; + priv->base_addr = plat->base_addr; +#ifdef OMAP_HSMMC_USE_GPIO + priv->cd_inverted = plat->cd_inverted; +#endif
#ifdef CONFIG_BLK mmc = &plat->mmc; @@ -843,7 +843,7 @@ static int omap_hsmmc_probe(struct udevice *dev) return -1; #endif
-#ifdef OMAP_HSMMC_USE_GPIO +#if defined(OMAP_HSMMC_USE_GPIO) && CONFIG_IS_ENABLED(OF_CONTROL) gpio_request_by_name(dev, "cd-gpios", 0, &priv->cd_gpio, GPIOD_IS_IN); gpio_request_by_name(dev, "wp-gpios", 0, &priv->wp_gpio, GPIOD_IS_IN); #endif @@ -854,23 +854,27 @@ static int omap_hsmmc_probe(struct udevice *dev) return 0; }
+#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) static const struct udevice_id omap_hsmmc_ids[] = { { .compatible = "ti,omap3-hsmmc" }, { .compatible = "ti,omap4-hsmmc" }, { .compatible = "ti,am33xx-hsmmc" }, { } }; +#endif
U_BOOT_DRIVER(omap_hsmmc) = { .name = "omap_hsmmc", .id = UCLASS_MMC, +#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) .of_match = omap_hsmmc_ids, .ofdata_to_platdata = omap_hsmmc_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct omap_hsmmc_plat), +#endif #ifdef CONFIG_BLK .bind = omap_hsmmc_bind, #endif .probe = omap_hsmmc_probe, .priv_auto_alloc_size = sizeof(struct omap_hsmmc_data), - .platdata_auto_alloc_size = sizeof(struct omap_hsmmc_plat), }; #endif
For platforms that don't use device tree in SPL the only way to mark this driver as 'required by relocation' is with the DM_FLAG_PRE_RELOC flag. Add this to ensure that the driver is bound.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- drivers/mmc/omap_hsmmc.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/mmc/omap_hsmmc.c b/drivers/mmc/omap_hsmmc.c index f2489473b0..d6194adc5e 100644 --- a/drivers/mmc/omap_hsmmc.c +++ b/drivers/mmc/omap_hsmmc.c @@ -876,5 +876,6 @@ U_BOOT_DRIVER(omap_hsmmc) = { #endif .probe = omap_hsmmc_probe, .priv_auto_alloc_size = sizeof(struct omap_hsmmc_data), + .flags = DM_FLAG_PRE_RELOC, }; #endif
No reason to use a separate load script for am33xx than using omap-common load script.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- include/configs/am335x_evm.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index fc8a08f5b7..796d5c32e9 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -194,7 +194,7 @@
/* USB gadget RNDIS */
-#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/am33xx/u-boot-spl.lds" +#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds" #endif
#ifdef CONFIG_NAND
Can we make this change to all other am335x platforms? They all are copy/paste from this config and now need to also be updated. After that we should delete am33xx/u-boot-spl.lds.
#endif
#ifdef CONFIG_NAND
okay. Ill also wait for Tom to comment on rest of the series, and then post v2.
Thanks and regards, Lokesh
Agreed. It looks like d0b5d9da5de2 needs to be done to arch/arm/mach-omap2/u-boot-spl.lds as well, btw.
The mentioned commit takes care of mach-omap2/u-boot-spl.lds(It was arch/arm/cpu/armv7/omap-common/u-boot-spl.lds) as well. Or did I miss something?
No, maybe I just mis-read the diff yesterday morning, sorry, thanks!
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- board/ti/am335x/board.c | 32 ++++++++++++++++++++++++++++++++ 1 file changed, 32 insertions(+)
diff --git a/board/ti/am335x/board.c b/board/ti/am335x/board.c index 3e842d3187..566183e669 100644 --- a/board/ti/am335x/board.c +++ b/board/ti/am335x/board.c @@ -9,6 +9,7 @@ */
#include <common.h> +#include <dm.h> #include <errno.h> #include <spl.h> #include <serial.h> @@ -26,6 +27,7 @@ #include <asm/emif.h> #include <asm/gpio.h> #include <asm/omap_sec_common.h> +#include <asm/omap_mmc.h> #include <i2c.h> #include <miiphy.h> #include <cpsw.h> @@ -892,3 +894,33 @@ void board_fit_image_post_process(void **p_image, size_t *p_size) secure_boot_verify_image(p_image, p_size); } #endif + +#if !CONFIG_IS_ENABLED(OF_CONTROL) +static const struct omap_hsmmc_plat am335x_mmc0_platdata = { + .base_addr = (struct hsmmc *)0x48060000, + .cfg.host_caps = MMC_MODE_HS_52MHz | MMC_MODE_HS | MMC_MODE_4BIT, + .cfg.f_min = 400000, + .cfg.f_max = 52000000, + .cfg.voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195, + .cfg.b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT, +}; + +U_BOOT_DEVICE(am335x_mmc0) = { + .name = "omap_hsmmc", + .platdata = &am335x_mmc0_platdata, +}; + +static const struct omap_hsmmc_plat am335x_mmc1_platdata = { + .base_addr = (struct hsmmc *)0x481d8000, + .cfg.host_caps = MMC_MODE_HS_52MHz | MMC_MODE_HS | MMC_MODE_8BIT, + .cfg.f_min = 400000, + .cfg.f_max = 52000000, + .cfg.voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195, + .cfg.b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT, +}; + +U_BOOT_DEVICE(am335x_mmc1) = { + .name = "omap_hsmmc", + .platdata = &am335x_mmc1_platdata, +}; +#endif
- .base_addr = (struct hsmmc *)0x48060000,
OK. So, off the top of my head, from Adam's series about converting omap3, OMAP_HSMMC1_BASE and company aren't defined correctly? Or we're playing games with that 0x100 offset? I bring this up as since we have defines for these base addresses already, we should make use of them, but in this case first we'll have to do... something, yes?
The base address for the AM335xx he has listed is correct at 0x480600, however the offset is 0x100. Without without my patch I would expect this to correctly. SYSCONFIG is at offset 0x110 and for OMAP3 the offset would be 0x10. His patch looks like it supports the condition without OF_CONTROL, so maybe using a #define here would be appropriate, however without OF_CONFIG, I am guessing my patch would break stuff.
I only did my series to eliminate the #ifdef stuff, but we might have to add something like && !define (OF_CONTROL) to my series.
If you want to pull his in, I can rebase and resubmit my series against his. I don't have an AM33xx or OMAP4+ to test, I only have a DM3730 to test.
adam
-- Tom
Hi Adam,
Your patch[1] definitely make sense and this is how it is handled in kernel as well. Please keep it as is. Ill re-base this series on top of your series and send a v2.
[1] http://patchwork.ozlabs.org/patch/751300/
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/mach-omap2/am33xx/Kconfig | 5 +++++ include/configs/am335x_evm.h | 1 - include/configs/ti_am335x_common.h | 2 ++ 3 files changed, 7 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-omap2/am33xx/Kconfig b/arch/arm/mach-omap2/am33xx/Kconfig index cf5d95a26d..acdb88a702 100644 --- a/arch/arm/mach-omap2/am33xx/Kconfig +++ b/arch/arm/mach-omap2/am33xx/Kconfig @@ -29,6 +29,11 @@ config TARGET_AM335X_EVM imply SPL_SERIAL_SUPPORT imply SPL_WATCHDOG_SUPPORT imply SPL_YMODEM_SUPPORT + imply SPL_SYS_MALLOC_SIMPLE + imply SPL_SEPARATE_BSS + imply SPL_DM + imply SPL_DM_SEQ_ALIAS + imply SPL_OF_LIBFDT help This option specifies support for the AM335x GP and HS EVM development platforms. The AM335x diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 796d5c32e9..51c3d493c8 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -291,7 +291,6 @@ * DM support in SPL */ #ifdef CONFIG_SPL_BUILD -#undef CONFIG_DM_MMC #undef CONFIG_TIMER #undef CONFIG_DM_USB #endif diff --git a/include/configs/ti_am335x_common.h b/include/configs/ti_am335x_common.h index c0e4336eb0..e4c3c807f2 100644 --- a/include/configs/ti_am335x_common.h +++ b/include/configs/ti_am335x_common.h @@ -22,8 +22,10 @@ /* NS16550 Configuration */ #ifdef CONFIG_SPL_BUILD #define CONFIG_SYS_NS16550_SERIAL +#ifndef CONFIG_DM_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE (-4) #endif +#endif #define CONFIG_SYS_NS16550_CLK 48000000
#ifndef CONFIG_SPL_BUILD
am335x_evm SPL is very close to its limit in SRAM space. Switch to use tiny printf to reclaim some size.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 7812f21f36..7368f6b95c 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -761,6 +761,7 @@ config AM33XX bool "AM33XX SoC" select ARCH_OMAP2 imply SYS_THUMB_BUILD + imply USE_TINY_PRINTF help Support for AM335x SOC from Texas Instruments. The AM335x high performance SOC features a Cortex-A8
Adam Ford
Andrew F. Davis
Lokesh Vutla
