[U-Boot] [PATCH] net: rtl8169: Fix build error when DEBUG is on
When DEBUG_RTL8169 is on, a build error occurs in function 'rtl_init': error: 'dev' undeclared. Fix this.
Signed-off-by: Bin Meng bmeng.cn@gmail.com --- drivers/net/rtl8169.c | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/net/rtl8169.c b/drivers/net/rtl8169.c index 9e60adf..163b9df 100644 --- a/drivers/net/rtl8169.c +++ b/drivers/net/rtl8169.c @@ -995,7 +995,7 @@ static int rtl_init(unsigned long dev_ioaddr, const char *name, /* Force RTL8169 in 10/100/1000 Full/Half mode. */ if (option > 0) { #ifdef DEBUG_RTL8169 - printf("%s: Force-mode Enabled.\n", dev->name); + printf("%s: Force-mode Enabled.\n", name); #endif Cap10_100 = 0, Cap1000 = 0; switch (option) { @@ -1027,7 +1027,7 @@ static int rtl_init(unsigned long dev_ioaddr, const char *name, } else { #ifdef DEBUG_RTL8169 printf("%s: Auto-negotiation Enabled.\n", - dev->name); + name); #endif /* enable 10/100 Full/Half Mode, leave PHY_AUTO_NEGO_REG bit4:0 unchanged */ mdio_write(PHY_AUTO_NEGO_REG, @@ -1054,12 +1054,12 @@ static int rtl_init(unsigned long dev_ioaddr, const char *name, if (option & _1000bpsF) { #ifdef DEBUG_RTL8169 printf("%s: 1000Mbps Full-duplex operation.\n", - dev->name); + name); #endif } else { #ifdef DEBUG_RTL8169 printf("%s: %sMbps %s-duplex operation.\n", - dev->name, + name, (option & _100bps) ? "100" : "10", (option & FullDup) ? "Full" : @@ -1077,7 +1077,7 @@ static int rtl_init(unsigned long dev_ioaddr, const char *name, #ifdef DEBUG_RTL8169 printf ("%s: 1000Mbps Full-duplex operation, TBI Link %s!\n", - dev->name, + name, (RTL_R32(TBICSR) & TBILinkOK) ? "OK" : "Failed"); #endif }
Signed-off-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Tom Rini trini@konsulko.com Acked-by: Joe Hershberger joe.hershberger@ni.com
Bin Meng
Joe Hershberger
