[U-Boot] [PATCH v2] mmc: atmel_sdhci: Convert to the driver model support
Convert the driver to the driver model while retaining the existing legacy code. This allows the driver to support boards that have converted to driver model as well as those that have not.
Signed-off-by: Wenyou Yang wenyou.yang@atmel.com ---
Changes in v2: - Add clock support, include enabling peripheral clock and generated clock. - Retain the existing legacy code to support boards which have not converted to driver model.
drivers/mmc/Kconfig | 10 +++++ drivers/mmc/atmel_sdhci.c | 110 ++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 120 insertions(+)
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index dc8532f..7f6b2e1 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -16,6 +16,16 @@ config DM_MMC appear as block devices in U-Boot and can support filesystems such as EXT4 and FAT.
+config ATMEL_SDHCI + bool "Atmel SDHCI controller support" + depends on DM_MMC && ARCH_AT91 + help + This enables support for the Atmel SDHCI controller, which supports + the embedded MultiMedia Card (e.MMC) Specification V4.51, the SD + Memory Card Specification V3.0, and the SDIO V3.0 specification. + It is compliant with the SD Host Controller Standard V3.0 + specification. + config ROCKCHIP_DWMMC bool "Rockchip SD/MMC controller support" depends on DM_MMC && OF_CONTROL diff --git a/drivers/mmc/atmel_sdhci.c b/drivers/mmc/atmel_sdhci.c index 24b68b6..6db3021 100644 --- a/drivers/mmc/atmel_sdhci.c +++ b/drivers/mmc/atmel_sdhci.c @@ -6,12 +6,16 @@ */
#include <common.h> +#include <clk.h> +#include <dm.h> #include <malloc.h> #include <sdhci.h> #include <asm/arch/clk.h>
#define ATMEL_SDHC_MIN_FREQ 400000
+#ifndef CONFIG_DM_MMC + int atmel_sdhci_init(void *regbase, u32 id) { struct sdhci_host *host; @@ -38,3 +42,109 @@ int atmel_sdhci_init(void *regbase, u32 id)
return 0; } + +#else + +DECLARE_GLOBAL_DATA_PTR; + +static int atmel_sdhci_probe(struct udevice *dev) +{ + struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev); + struct sdhci_host *host = dev_get_priv(dev); + u32 max_clk, min_clk = ATMEL_SDHC_MIN_FREQ; + u32 caps0, caps1; + u32 clk_base, clk_mul; + u32 gck_rate; + struct udevice *clkdev; + int periph, ret; + + ret = clk_get_by_index(dev, 0, &clkdev); + if (ret) { + dev_err(dev, "Failed to get peripheral clock\n"); + return ret; + } + + periph = fdtdec_get_uint(gd->fdt_blob, clkdev->of_offset, "reg", -1); + if (periph < 0) { + dev_err(dev, "Failed to find peripheral id\n"); + return -EINVAL; + } + + clkdev = dev_get_parent(clkdev); + if (!clkdev) { + dev_err(dev, "Failed to find parent node\n"); + return -ENODEV; + } + + ret = clk_enable(clkdev, periph); + if (ret) { + dev_err(dev, "Failed to enable peripheral clock\n"); + return ret; + } + + host->name = (char *)dev->name; + host->ioaddr = (void *)dev_get_addr(dev); + + host->quirks = 0; + host->version = sdhci_readw(host, SDHCI_HOST_VERSION); + + host->bus_width = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "bus-width", 4); + + caps0 = readl(host->ioaddr + SDHCI_CAPABILITIES); + caps1 = readl(host->ioaddr + SDHCI_CAPABILITIES_1); + clk_base = (caps0 & SDHCI_CLOCK_V3_BASE_MASK) >> SDHCI_CLOCK_BASE_SHIFT; + clk_mul = (caps1 & SDHCI_CLOCK_MUL_MASK) >> SDHCI_CLOCK_MUL_SHIFT; + gck_rate = clk_base * 1000000 * (clk_mul + 1); + + ret = clk_get_by_index(dev, 1, &clkdev); + if (ret) { + dev_err(dev, "Failed to get generated clock\n"); + return ret; + } + + periph = fdtdec_get_uint(gd->fdt_blob, clkdev->of_offset, "reg", -1); + if (periph < 0) { + dev_err(dev, "Failed to find peripheral id\n"); + return -EINVAL; + } + + clkdev = dev_get_parent(clkdev); + if (!clkdev) { + dev_err(dev, "Failed to find parent node\n"); + return -ENODEV; + } + + ret = clk_set_periph_rate(clkdev, periph, gck_rate); + if (ret) { + dev_err(dev, "Failed to set generated clock rate\n"); + return -ENODEV; + } + + max_clk = clk_get_periph_rate(clkdev, periph); + if (!max_clk) { + dev_err(dev, "Failed to get generated clock rate\n"); + return -ENODEV; + } + + add_sdhci(host, max_clk, min_clk); + + upriv->mmc = host->mmc; + + return 0; +} + +static const struct udevice_id atmel_sdhci_ids[] = { + { .compatible = "atmel,sama5d2-sdhci" }, + { } +}; + +U_BOOT_DRIVER(atmel_sdhci_drv) = { + .name = "atmel_sdhci", + .id = UCLASS_MMC, + .of_match = atmel_sdhci_ids, + .probe = atmel_sdhci_probe, + .priv_auto_alloc_size = sizeof(struct sdhci_host), +}; + +#endif
Wenyou Yang
