[U-Boot] [PATCH v3] MAKEALL: fix get_target_arch() to adjust to '-' in Status field
Since the Kconfig conversion, boards.cfg scanned by MAKEALL is generated by tools/genboardscfg.py. Every board is supposed to have its own MAINTAINERS that contains maintainer and status information, but, in fact, MAINTAINERS is missing from some boards.
For such boards, the first field, Status, is filled with '-'. It causes a problem for "set" command, which ignores '-' in its arguments. Consequently, get_target_arch() returns a wrong field and MAKEALL fails to get a correct toolchain.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
Changes in v3: - Fix commit description
Changes in v2: - Improve git description
MAKEALL | 8 +------- 1 file changed, 1 insertion(+), 7 deletions(-)
diff --git a/MAKEALL b/MAKEALL index cd3b6c7..3808a59 100755 --- a/MAKEALL +++ b/MAKEALL @@ -551,13 +551,7 @@ get_target_maintainers() { get_target_arch() { local target=$1
- # Automatic mode - local line=`awk '$7 == "'"$target"'" { print $0 }' boards.cfg` - - if [ -z "${line}" ] ; then echo "" ; return ; fi - - set ${line} - echo "$2" + awk '$7 == "'$target'" { print $2 }' boards.cfg }
list_target() {
Masahiro Yamada
