[U-Boot] [PATCH v5 0/5] Add support for reading memory configuration from DT at run-time
this is series which was send by Siva. I have just put there missing Tom's tag which we got and adding more people to TO.
Thanks, Michal
Changes in v5: - Add Tom's tag - https://lists.denx.de/pipermail/u-boot/2018-June/332810.html - Add Tom's tag - https://lists.denx.de/pipermail/u-boot/2018-June/332810.html
Changes in v4: - Rebased on latest master and used available ram_base - Separate the rename patch - Rebased on latest master - None, rebased on latest master
Changes in v3: - Used new varibale ram_start - Rename fdtdec_setup_memory_size
Changes in v2: - Removed commit reference from description as per comment - Update memory node as per comment - Removed intc and fclk as per comment
Siva Durga Prasad Paladugu (5): lib: fdtdec: Update ram_base to store ram start adddress lib: fdtdec: Rename routine fdtdec_setup_memory_size() arm: zynq: Dont define SDRAM_BASE and SDRAM_SIZE in .h arm: zynq: Add Nand flash mini u-boot configuration for zynq arm: zynq: Add parallel NOR flash mini u-boot configuration for zynq
arch/arm/dts/Makefile | 2 + arch/arm/dts/zynq-cse-nand.dts | 80 ++++++++++++++++++++ arch/arm/dts/zynq-cse-nor.dts | 88 ++++++++++++++++++++++ arch/arm/mach-mvebu/arm64-common.c | 2 +- board/emulation/qemu-arm/qemu-arm.c | 2 +- board/renesas/alt/alt.c | 2 +- board/renesas/blanche/blanche.c | 2 +- board/renesas/draak/draak.c | 2 +- board/renesas/eagle/eagle.c | 2 +- board/renesas/gose/gose.c | 2 +- board/renesas/koelsch/koelsch.c | 2 +- board/renesas/lager/lager.c | 2 +- board/renesas/porter/porter.c | 2 +- board/renesas/salvator-x/salvator-x.c | 2 +- board/renesas/silk/silk.c | 2 +- board/renesas/stout/stout.c | 2 +- board/renesas/ulcb/ulcb.c | 2 +- board/st/stm32f429-discovery/stm32f429-discovery.c | 2 +- .../st/stm32f429-evaluation/stm32f429-evaluation.c | 2 +- board/st/stm32f469-discovery/stm32f469-discovery.c | 2 +- board/st/stm32h743-disco/stm32h743-disco.c | 2 +- board/st/stm32h743-eval/stm32h743-eval.c | 2 +- board/xilinx/zynq/board.c | 2 +- board/xilinx/zynqmp/zynqmp.c | 2 +- board/xilinx/zynqmp_r5/board.c | 2 +- common/board_f.c | 4 +- configs/zynq_cse_nand_defconfig | 50 ++++++++++++ configs/zynq_cse_nor_defconfig | 50 ++++++++++++ include/configs/zynq_cse.h | 3 - include/fdtdec.h | 16 ++-- lib/fdtdec.c | 3 +- tools/patman/func_test.py | 2 +- tools/patman/test/0000-cover-letter.patch | 2 +- ...-cast-for-sandbox-in-fdtdec_setup_memory_.patch | 4 +- tools/patman/test/test01.txt | 2 +- 35 files changed, 310 insertions(+), 40 deletions(-) create mode 100644 arch/arm/dts/zynq-cse-nand.dts create mode 100644 arch/arm/dts/zynq-cse-nor.dts create mode 100644 configs/zynq_cse_nand_defconfig create mode 100644 configs/zynq_cse_nor_defconfig
From: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com
This patch updates the ram_base to store the start address of the first bank DRAM and the use this ram_base to calculate ram_top properly. This patch fixes the erroneous calculation of ram_top incase of non zero ram start address.
Signed-off-by: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com Reviewed-by: Tom Rini trini@konsulko.com
Changes in v2: None
common/board_f.c | 4 ++-- lib/fdtdec.c | 1 + 2 files changed, 3 insertions(+), 2 deletions(-)
diff --git a/common/board_f.c b/common/board_f.c index e943347ce3df..88d770071c38 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -281,9 +281,9 @@ static int setup_dest_addr(void) gd->ram_size -= CONFIG_SYS_MEM_TOP_HIDE; #endif #ifdef CONFIG_SYS_SDRAM_BASE - gd->ram_top = CONFIG_SYS_SDRAM_BASE; + gd->ram_base = CONFIG_SYS_SDRAM_BASE; #endif - gd->ram_top += get_effective_memsize(); + gd->ram_top = gd->ram_base + get_effective_memsize(); gd->ram_top = board_get_usable_ram_top(gd->mon_len); gd->relocaddr = gd->ram_top; debug("Ram top: %08lX\n", (ulong)gd->ram_top); diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 1b0c430945a9..66dff0f906b7 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -1173,6 +1173,7 @@ int fdtdec_setup_memory_size(void) }
gd->ram_size = (phys_size_t)(res.end - res.start + 1); + gd->ram_base = (unsigned long)res.start; debug("%s: Initial DRAM size %llx\n", __func__, (unsigned long long)gd->ram_size);
This patch renames the routine fdtdec_setup_memory_size() to fdtdec_setup_mem_size_base() as it now fills the mem base as well along with size.
Changes in v4: - Separate the rename patch
arch/arm/mach-mvebu/arm64-common.c | 2 +- board/emulation/qemu-arm/qemu-arm.c | 2 +- board/renesas/alt/alt.c | 2 +- board/renesas/blanche/blanche.c | 2 +- board/renesas/draak/draak.c | 2 +- board/renesas/eagle/eagle.c | 2 +- board/renesas/gose/gose.c | 2 +- board/renesas/koelsch/koelsch.c | 2 +- board/renesas/lager/lager.c | 2 +- board/renesas/porter/porter.c | 2 +- board/renesas/salvator-x/salvator-x.c | 2 +- board/renesas/silk/silk.c | 2 +- board/renesas/stout/stout.c | 2 +- board/renesas/ulcb/ulcb.c | 2 +- board/st/stm32f429-discovery/stm32f429-discovery.c | 2 +- board/st/stm32f429-evaluation/stm32f429-evaluation.c | 2 +- board/st/stm32f469-discovery/stm32f469-discovery.c | 2 +- board/st/stm32h743-disco/stm32h743-disco.c | 2 +- board/st/stm32h743-eval/stm32h743-eval.c | 2 +- board/xilinx/zynq/board.c | 2 +- board/xilinx/zynqmp/zynqmp.c | 2 +- board/xilinx/zynqmp_r5/board.c | 2 +- include/fdtdec.h | 16 +++++++++------- lib/fdtdec.c | 2 +- tools/patman/func_test.py | 2 +- tools/patman/test/0000-cover-letter.patch | 2 +- ...orrect-cast-for-sandbox-in-fdtdec_setup_memory_.patch | 4 ++-- tools/patman/test/test01.txt | 2 +- 28 files changed, 37 insertions(+), 35 deletions(-)
diff --git a/arch/arm/mach-mvebu/arm64-common.c b/arch/arm/mach-mvebu/arm64-common.c index d3ea9e67e07f..f47273fde9c6 100644 --- a/arch/arm/mach-mvebu/arm64-common.c +++ b/arch/arm/mach-mvebu/arm64-common.c @@ -54,7 +54,7 @@ int dram_init_banksize(void)
int dram_init(void) { - if (fdtdec_setup_memory_size() != 0) + if (fdtdec_setup_mem_size_base() != 0) return -EINVAL;
return 0; diff --git a/board/emulation/qemu-arm/qemu-arm.c b/board/emulation/qemu-arm/qemu-arm.c index 085cbbef994e..1f5a33d520bd 100644 --- a/board/emulation/qemu-arm/qemu-arm.c +++ b/board/emulation/qemu-arm/qemu-arm.c @@ -47,7 +47,7 @@ int board_init(void)
return 0; diff --git a/board/renesas/alt/alt.c b/board/renesas/alt/alt.c index 86e9d2446dcc..b18ab7ce8872 100644 --- a/board/renesas/alt/alt.c +++ b/board/renesas/alt/alt.c @@ -78,7 +78,7 @@ int board_init(void)
return 0; diff --git a/board/renesas/blanche/blanche.c b/board/renesas/blanche/blanche.c index 7d48d0faf957..f5ada6e288e9 100644 --- a/board/renesas/blanche/blanche.c +++ b/board/renesas/blanche/blanche.c @@ -339,7 +339,7 @@ int board_eth_init(bd_t *bis)
return 0; diff --git a/board/renesas/draak/draak.c b/board/renesas/draak/draak.c index f804fae6eebf..852fdda843c7 100644 --- a/board/renesas/draak/draak.c +++ b/board/renesas/draak/draak.c @@ -96,7 +96,7 @@ int board_init(void)
return 0; diff --git a/board/renesas/eagle/eagle.c b/board/renesas/eagle/eagle.c index 7b89c10cc742..931741007196 100644 --- a/board/renesas/eagle/eagle.c +++ b/board/renesas/eagle/eagle.c @@ -74,7 +74,7 @@ int board_init(void)
return 0; diff --git a/board/renesas/gose/gose.c b/board/renesas/gose/gose.c index 96ac29d9ab03..282381ede56f 100644 --- a/board/renesas/gose/gose.c +++ b/board/renesas/gose/gose.c @@ -83,7 +83,7 @@ int board_init(void)
return 0; diff --git a/board/renesas/koelsch/koelsch.c b/board/renesas/koelsch/koelsch.c index b6688a2cc082..52f37c970e78 100644 --- a/board/renesas/koelsch/koelsch.c +++ b/board/renesas/koelsch/koelsch.c @@ -85,7 +85,7 @@ int board_init(void)
return 0; diff --git a/board/renesas/lager/lager.c b/board/renesas/lager/lager.c index 6bfb0d140489..062e88c19832 100644 --- a/board/renesas/lager/lager.c +++ b/board/renesas/lager/lager.c @@ -94,7 +94,7 @@ int board_init(void)
return 0; diff --git a/board/renesas/porter/porter.c b/board/renesas/porter/porter.c index cadff2cd0230..663b8001ef6b 100644 --- a/board/renesas/porter/porter.c +++ b/board/renesas/porter/porter.c @@ -83,7 +83,7 @@ int board_init(void)
return 0; diff --git a/board/renesas/salvator-x/salvator-x.c b/board/renesas/salvator-x/salvator-x.c index 651877cac253..00256bc1a343 100644 --- a/board/renesas/salvator-x/salvator-x.c +++ b/board/renesas/salvator-x/salvator-x.c @@ -108,7 +108,7 @@ int board_init(void)
return 0; diff --git a/board/renesas/silk/silk.c b/board/renesas/silk/silk.c index 5fa472ce81b8..966c0717b249 100644 --- a/board/renesas/silk/silk.c +++ b/board/renesas/silk/silk.c @@ -78,7 +78,7 @@ int board_init(void)
return 0; diff --git a/board/renesas/stout/stout.c b/board/renesas/stout/stout.c index 778593b9ba5d..85e30db635f6 100644 --- a/board/renesas/stout/stout.c +++ b/board/renesas/stout/stout.c @@ -97,7 +97,7 @@ int board_init(void)
return 0; diff --git a/board/renesas/ulcb/ulcb.c b/board/renesas/ulcb/ulcb.c index 9e15e45a3047..213e869ebe66 100644 --- a/board/renesas/ulcb/ulcb.c +++ b/board/renesas/ulcb/ulcb.c @@ -96,7 +96,7 @@ int board_init(void)
return 0; diff --git a/board/st/stm32f429-discovery/stm32f429-discovery.c b/board/st/stm32f429-discovery/stm32f429-discovery.c index b7638c0f6a91..e800d70f763b 100644 --- a/board/st/stm32f429-discovery/stm32f429-discovery.c +++ b/board/st/stm32f429-discovery/stm32f429-discovery.c @@ -29,7 +29,7 @@ int dram_init(void) return rv; }
- if (fdtdec_setup_memory_size() != 0) + if (fdtdec_setup_mem_size_base() != 0) rv = -EINVAL;
return rv; diff --git a/board/st/stm32f429-evaluation/stm32f429-evaluation.c b/board/st/stm32f429-evaluation/stm32f429-evaluation.c index 2e638c605990..fd2109b27c0f 100644 --- a/board/st/stm32f429-evaluation/stm32f429-evaluation.c +++ b/board/st/stm32f429-evaluation/stm32f429-evaluation.c @@ -23,7 +23,7 @@ int dram_init(void) return rv; }
return rv; diff --git a/board/st/stm32f469-discovery/stm32f469-discovery.c b/board/st/stm32f469-discovery/stm32f469-discovery.c index 90d7045e9ab7..a457f9095276 100644 --- a/board/st/stm32f469-discovery/stm32f469-discovery.c +++ b/board/st/stm32f469-discovery/stm32f469-discovery.c @@ -23,7 +23,7 @@ int dram_init(void) return rv; }
return rv; diff --git a/board/st/stm32h743-disco/stm32h743-disco.c b/board/st/stm32h743-disco/stm32h743-disco.c index fa007c79864d..3ab95188048d 100644 --- a/board/st/stm32h743-disco/stm32h743-disco.c +++ b/board/st/stm32h743-disco/stm32h743-disco.c @@ -20,7 +20,7 @@ int dram_init(void) return ret; }
- if (fdtdec_setup_memory_size() != 0) + if (fdtdec_setup_mem_size_base() != 0) ret = -EINVAL;
return ret; diff --git a/board/st/stm32h743-eval/stm32h743-eval.c b/board/st/stm32h743-eval/stm32h743-eval.c index fa007c79864d..3ab95188048d 100644 --- a/board/st/stm32h743-eval/stm32h743-eval.c +++ b/board/st/stm32h743-eval/stm32h743-eval.c @@ -20,7 +20,7 @@ int dram_init(void) return ret; }
return ret; diff --git a/board/xilinx/zynq/board.c b/board/xilinx/zynq/board.c index 9c005e40e895..614d93c082a6 100644 --- a/board/xilinx/zynq/board.c +++ b/board/xilinx/zynq/board.c @@ -98,7 +98,7 @@ int dram_init_banksize(void)
zynq_ddrc_init(); diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index 06cdcbdba6b9..89fac6bb67ca 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -423,7 +423,7 @@ int dram_init_banksize(void)
return 0; diff --git a/board/xilinx/zynqmp_r5/board.c b/board/xilinx/zynqmp_r5/board.c index 70fb20235498..1c45ee7196f7 100644 --- a/board/xilinx/zynqmp_r5/board.c +++ b/board/xilinx/zynqmp_r5/board.c @@ -18,7 +18,7 @@ int dram_init_banksize(void)
return 0; diff --git a/include/fdtdec.h b/include/fdtdec.h index 58d5b721aa60..83be06403d8b 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -957,20 +957,22 @@ int fdtdec_decode_display_timing(const void *blob, int node, int index, struct display_timing *config);
/** - * fdtdec_setup_memory_size() - decode and setup gd->ram_size + * fdtdec_setup_mem_size_base() - decode and setup gd->ram_size and + * gd->ram_start * - * Decode the /memory 'reg' property to determine the size of the first memory - * bank, populate the global data with the size of the first bank of memory. + * Decode the /memory 'reg' property to determine the size and start of the + * first memory bank, populate the global data with the size and start of the + * first bank of memory. * * This function should be called from a boards dram_init(). This helper - * function allows for boards to query the device tree for DRAM size instead of - * hard coding the value in the case where the memory size cannot be detected - * automatically. + * function allows for boards to query the device tree for DRAM size and start + * address instead of hard coding the value in the case where the memory size + * and start address cannot be detected automatically. * * @return 0 if OK, -EINVAL if the /memory node or reg property is missing or * invalid */ -int fdtdec_setup_memory_size(void); +int fdtdec_setup_mem_size_base(void);
/** * fdtdec_setup_memory_banksize() - decode and populate gd->bd->bi_dram diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 66dff0f906b7..c373ddee358d 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -1155,7 +1155,7 @@ int fdtdec_decode_display_timing(const void *blob, int parent, int index, return ret; }
-int fdtdec_setup_memory_size(void) +int fdtdec_setup_mem_size_base(void) { int ret, mem; struct fdt_resource res; diff --git a/tools/patman/func_test.py b/tools/patman/func_test.py index 3f7e03214470..d79e716074b6 100644 --- a/tools/patman/func_test.py +++ b/tools/patman/func_test.py @@ -210,7 +210,7 @@ Changes in v4:
Simon Glass (2): pci: Correct cast for sandbox - fdt: Correct cast for sandbox in fdtdec_setup_memory_size() + fdt: Correct cast for sandbox in fdtdec_setup_mem_size_base()
cmd/pci.c | 3 ++- fs/fat/fat.c | 1 + diff --git a/tools/patman/test/0000-cover-letter.patch b/tools/patman/test/0000-cover-letter.patch index 29062015bc21..c99e635623f3 100644 --- a/tools/patman/test/0000-cover-letter.patch +++ b/tools/patman/test/0000-cover-letter.patch @@ -10,7 +10,7 @@ Content-Transfer-Encoding: 8bit
cmd/pci.c | 3 ++- fs/fat/fat.c | 1 + diff --git a/tools/patman/test/0002-fdt-Correct-cast-for-sandbox-in-fdtdec_setup_memory_.patch b/tools/patman/test/0002-fdt-Correct-cast-for-sandbox-in-fdtdec_setup_memory_.patch index e3284973a0d3..702c0306ffe1 100644 --- a/tools/patman/test/0002-fdt-Correct-cast-for-sandbox-in-fdtdec_setup_memory_.patch +++ b/tools/patman/test/0002-fdt-Correct-cast-for-sandbox-in-fdtdec_setup_memory_.patch @@ -1,7 +1,7 @@ From 5ab48490f03051875ab13d288a4bf32b507d76fd Mon Sep 17 00:00:00 2001 From: Simon Glass sjg@chromium.org Date: Sat, 15 Apr 2017 15:39:08 -0600 -Subject: [RFC 2/2] fdt: Correct cast for sandbox in fdtdec_setup_memory_size() +Subject: [RFC 2/2] fdt: Correct cast for sandbox in fdtdec_setup_mem_size_base() MIME-Version: 1.0 Content-Type: text/plain; charset=UTF-8 Content-Transfer-Encoding: 8bit @@ -58,7 +58,7 @@ diff --git a/lib/fdtdec.c b/lib/fdtdec.c index c072e54..942244f 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c -@@ -1200,7 +1200,8 @@ int fdtdec_setup_memory_size(void) +@@ -1200,7 +1200,8 @@ int fdtdec_setup_mem_size_base(void) }
gd->ram_size = (phys_size_t)(res.end - res.start + 1); diff --git a/tools/patman/test/test01.txt b/tools/patman/test/test01.txt index 8ad9587aef53..478ea93674d0 100644 --- a/tools/patman/test/test01.txt +++ b/tools/patman/test/test01.txt @@ -28,7 +28,7 @@ commit 5ab48490f03051875ab13d288a4bf32b507d76fd Author: Simon Glass sjg@chromium.org Date: Sat Apr 15 15:39:08 2017 -0600
This gives a warning with some native compilers:
Remove the SDRAM_BASE nad SDRAM_SIZE as it can now get these details from DT.
Signed-off-by: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: - Removed commit reference from description as per comment
include/configs/zynq_cse.h | 3 --- 1 file changed, 3 deletions(-)
diff --git a/include/configs/zynq_cse.h b/include/configs/zynq_cse.h index 2f5843f9ec31..adc02f0a4a3b 100644 --- a/include/configs/zynq_cse.h +++ b/include/configs/zynq_cse.h @@ -41,7 +41,4 @@ #undef CONFIG_SYS_MALLOC_LEN #define CONFIG_SYS_MALLOC_LEN 0x1000
-#define CONFIG_SYS_SDRAM_BASE 0xfffc0000 -#define CONFIG_SYS_SDRAM_SIZE 0x40000 - #endif /* __CONFIG_ZYNQ_CSE_H */
and
details from DT.
Add configuration files/dtses for mini u-boot configuration which runs on smaller footprint of memory. This configuration has only required nand flash support.
Changes in v5: None Changes in v4: - Rebased on latest master
Changes in v3: None Changes in v2: - Update memory node as per comment - Removed intc and fclk as per comment
arch/arm/dts/Makefile | 1 + arch/arm/dts/zynq-cse-nand.dts | 80 +++++++++++++++++++++++++++++++++++++++++ configs/zynq_cse_nand_defconfig | 50 ++++++++++++++++++++++++++ 3 files changed, 131 insertions(+) create mode 100644 arch/arm/dts/zynq-cse-nand.dts create mode 100644 configs/zynq_cse_nand_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 946023093df6..834a19b664e9 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -129,6 +129,7 @@ dtb-$(CONFIG_ARCH_UNIPHIER_SLD8) += \
dtb-$(CONFIG_ARCH_ZYNQ) += \ zynq-cc108.dtb \ + zynq-cse-nand.dtb \ zynq-cse-qspi-single.dtb \ zynq-microzed.dtb \ zynq-minized.dtb \ diff --git a/arch/arm/dts/zynq-cse-nand.dts b/arch/arm/dts/zynq-cse-nand.dts new file mode 100644 index 000000000000..9b1dd19a85df --- /dev/null +++ b/arch/arm/dts/zynq-cse-nand.dts @@ -0,0 +1,80 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Xilinx CSE NAND board DTS + * + * Copyright (C) 2018 Xilinx, Inc. + */ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + model = "Zynq CSE NAND Board"; + compatible = "xlnx,zynq-cse-nand", "xlnx,zynq-7000"; + + aliases { + serial0 = &dcc; + }; + + memory@0 { + device_type = "memory"; + reg = <0x0 0x400000>; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + dcc: dcc { + compatible = "arm,dcc"; + status = "disabled"; + u-boot,dm-pre-reloc; + }; + + amba: amba { + u-boot,dm-pre-reloc; + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + slcr: slcr@f8000000 { + u-boot,dm-pre-reloc; + #address-cells = <1>; + #size-cells = <1>; + compatible = "xlnx,zynq-slcr", "syscon", "simple-bus"; + reg = <0xF8000000 0x1000>; + ranges; + clkc: clkc@100 { + u-boot,dm-pre-reloc; + #clock-cells = <1>; + compatible = "xlnx,ps7-clkc"; + clock-output-names = "armpll", "ddrpll", + "iopll", "cpu_6or4x", + "cpu_3or2x", "cpu_2x", "cpu_1x", + "ddr2x", "ddr3x", "dci", + "lqspi", "smc", "pcap", "gem0", + "gem1", "fclk0", "fclk1", + "fclk2", "fclk3", "can0", + "can1", "sdio0", "sdio1", + "uart0", "uart1", "spi0", + "spi1", "dma", "usb0_aper", + "usb1_aper", "gem0_aper", + "gem1_aper", "sdio0_aper", + "sdio1_aper", "spi0_aper", + "spi1_aper", "can0_aper", + "can1_aper", "i2c0_aper", + "i2c1_aper", "uart0_aper", + "uart1_aper", "gpio_aper", + "lqspi_aper", "smc_aper", + "swdt", "dbg_trc", "dbg_apb"; + reg = <0x100 0x100>; + }; + }; + }; + +}; + +&dcc { + status = "okay"; +}; diff --git a/configs/zynq_cse_nand_defconfig b/configs/zynq_cse_nand_defconfig new file mode 100644 index 000000000000..7c7e1430c60f --- /dev/null +++ b/configs/zynq_cse_nand_defconfig @@ -0,0 +1,50 @@ +CONFIG_ARM=y +CONFIG_SYS_CONFIG_NAME="zynq_cse" +CONFIG_ARCH_ZYNQ=y +CONFIG_SYS_TEXT_BASE=0x100000 +CONFIG_SPL_STACK_R_ADDR=0x200000 +CONFIG_SYS_MALLOC_LEN=0x20000 +CONFIG_DEFAULT_DEVICE_TREE="zynq-cse-nand" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL=y +CONFIG_SPL_STACK_R=y +CONFIG_SYS_PROMPT="Zynq> " +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_CONSOLE is not set +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_BOOTM is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_FDT is not set +# CONFIG_CMD_GO is not set +# CONFIG_CMD_RUN is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_SPL is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_EDITENV is not set +# CONFIG_CMD_SAVEENV is not set +# CONFIG_CMD_ENV_EXISTS is not set +# CONFIG_CMD_CRC32 is not set +# CONFIG_CMD_CLK is not set +# CONFIG_CMD_DM is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +# CONFIG_CMD_ECHO is not set +# CONFIG_CMD_ITEST is not set +# CONFIG_CMD_SOURCE is not set +# CONFIG_CMD_SETEXPR is not set +# CONFIG_CMD_NET is not set +# CONFIG_CMD_NFS is not set +# CONFIG_CMD_MISC is not set +# CONFIG_PARTITIONS is not set +CONFIG_OF_EMBED=y +# CONFIG_DM_WARN is not set +# CONFIG_DM_DEVICE_REMOVE is not set +CONFIG_SPL_DM_SEQ_ALIAS=y +# CONFIG_MMC is not set +CONFIG_NAND=y +CONFIG_NAND_ZYNQ=y +# CONFIG_EFI_LOADER is not set
Add configuration files/dtses for mini u-boot configuration which runs on smaller footprint OCM memory. This configuration only has required parallel nor flash support.
Changes in v5: None Changes in v4: - None, rebased on latest master
arch/arm/dts/Makefile | 1 + arch/arm/dts/zynq-cse-nor.dts | 88 ++++++++++++++++++++++++++++++++++++++++++ configs/zynq_cse_nor_defconfig | 50 ++++++++++++++++++++++++ 3 files changed, 139 insertions(+) create mode 100644 arch/arm/dts/zynq-cse-nor.dts create mode 100644 configs/zynq_cse_nor_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 834a19b664e9..6785fefff52a 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -130,6 +130,7 @@ dtb-$(CONFIG_ARCH_UNIPHIER_SLD8) += \ dtb-$(CONFIG_ARCH_ZYNQ) += \ zynq-cc108.dtb \ zynq-cse-nand.dtb \ + zynq-cse-nor.dtb \ zynq-cse-qspi-single.dtb \ zynq-microzed.dtb \ zynq-minized.dtb \ diff --git a/arch/arm/dts/zynq-cse-nor.dts b/arch/arm/dts/zynq-cse-nor.dts new file mode 100644 index 000000000000..ba6f9a1a79e3 --- /dev/null +++ b/arch/arm/dts/zynq-cse-nor.dts @@ -0,0 +1,88 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Xilinx CSE NOR board DTS + * + * Copyright (C) 2018 Xilinx, Inc. + */ +/dts-v1/; +#include "zynq-7000.dtsi" + +/ { + #address-cells = <1>; + #size-cells = <1>; + model = "Zynq CSE NOR Board"; + compatible = "xlnx,zynq-cse-nor", "xlnx,zynq-7000"; + + aliases { + serial0 = &dcc; + }; + + memory@fffc0000 { + device_type = "memory"; + reg = <0xFFFC0000 0x40000>; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + dcc: dcc { + compatible = "arm,dcc"; + status = "disabled"; + u-boot,dm-pre-reloc; + }; + + amba: amba { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + interrupt-parent = <&intc>; + ranges; + + intc: interrupt-controller@f8f01000 { + compatible = "arm,cortex-a9-gic"; + #interrupt-cells = <3>; + interrupt-controller; + reg = <0xF8F01000 0x1000>, + <0xF8F00100 0x100>; + }; + + slcr: slcr@f8000000 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "xlnx,zynq-slcr", "syscon", "simple-bus"; + reg = <0xF8000000 0x1000>; + ranges; + clkc: clkc@100 { + #clock-cells = <1>; + compatible = "xlnx,ps7-clkc"; + fclk-enable = <0xf>; + clock-output-names = "armpll", "ddrpll", + "iopll", "cpu_6or4x", + "cpu_3or2x", "cpu_2x", "cpu_1x", + "ddr2x", "ddr3x", "dci", + "lqspi", "smc", "pcap", "gem0", + "gem1", "fclk0", "fclk1", + "fclk2", "fclk3", "can0", + "can1", "sdio0", "sdio1", + "uart0", "uart1", "spi0", + "spi1", "dma", "usb0_aper", + "usb1_aper", "gem0_aper", + "gem1_aper", "sdio0_aper", + "sdio1_aper", "spi0_aper", + "spi1_aper", "can0_aper", + "can1_aper", "i2c0_aper", + "i2c1_aper", "uart0_aper", + "uart1_aper", "gpio_aper", + "lqspi_aper", "smc_aper", + "swdt", "dbg_trc", "dbg_apb"; + reg = <0x100 0x100>; + }; + }; + }; + +}; + +&dcc { + status = "okay"; +}; diff --git a/configs/zynq_cse_nor_defconfig b/configs/zynq_cse_nor_defconfig new file mode 100644 index 000000000000..842d5206a7a6 --- /dev/null +++ b/configs/zynq_cse_nor_defconfig @@ -0,0 +1,50 @@ +CONFIG_ARM=y +CONFIG_SYS_CONFIG_NAME="zynq_cse" +CONFIG_ARCH_ZYNQ=y +CONFIG_SYS_TEXT_BASE=0xFFFC0000 +CONFIG_SPL_STACK_R_ADDR=0x200000 +CONFIG_SYS_MALLOC_LEN=0x1000 +CONFIG_ZYNQ_M29EW_WB_HACK=y +CONFIG_DEFAULT_DEVICE_TREE="zynq-cse-nor" +CONFIG_BOOTDELAY=-1 +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL=y +CONFIG_SPL_STACK_R=y +CONFIG_SYS_PROMPT="Zynq> " +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_CONSOLE is not set +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_BOOTM is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_FDT is not set +# CONFIG_CMD_GO is not set +# CONFIG_CMD_RUN is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_SPL is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_EDITENV is not set +# CONFIG_CMD_SAVEENV is not set +# CONFIG_CMD_ENV_EXISTS is not set +# CONFIG_CMD_CRC32 is not set +# CONFIG_CMD_CLK is not set +# CONFIG_CMD_DM is not set +# CONFIG_CMD_FPGA is not set +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +# CONFIG_CMD_ECHO is not set +# CONFIG_CMD_ITEST is not set +# CONFIG_CMD_SOURCE is not set +# CONFIG_CMD_SETEXPR is not set +# CONFIG_CMD_NET is not set +# CONFIG_CMD_NFS is not set +# CONFIG_CMD_MISC is not set +# CONFIG_PARTITIONS is not set +CONFIG_OF_EMBED=y +# CONFIG_DM_WARN is not set +# CONFIG_DM_DEVICE_REMOVE is not set +CONFIG_SPL_DM_SEQ_ALIAS=y +# CONFIG_MMC is not set +CONFIG_MTD_NOR_FLASH=y +# CONFIG_EFI_LOADER is not set
Michal Simek
