[U-Boot] [RFC PATCH] scsi: ceva: Convert driver to use UCLASS_AHCI instead of SCSI
In v2018 the patch "dm: ahci: Correct uclass private data" (sha1: bfc1c6b4838501d10aa48c0e92eaf70976f4b2dd) was causing an issue for ceva_sata. But this issue is not in v2018.05-rc1 but still converting to UCLASS_AHCI would make more sense.
drivers/ata/sata_ceva.c | 36 ++++++++++++++++++++---------------- 1 file changed, 20 insertions(+), 16 deletions(-)
diff --git a/drivers/ata/sata_ceva.c b/drivers/ata/sata_ceva.c index bae26898bad2..2a9f8041e3ef 100644 --- a/drivers/ata/sata_ceva.c +++ b/drivers/ata/sata_ceva.c @@ -73,6 +73,10 @@ #define DRV_NAME "ahci-ceva" #define CEVA_FLAG_BROKEN_GEN2 1
+struct ceva_sata_priv { + ulong base; +}; + static int ceva_init_sata(ulong mmio) { ulong tmp; @@ -111,18 +115,20 @@ static int ceva_init_sata(ulong mmio) return 0; }
-static int sata_ceva_probe(struct udevice *dev) +static int sata_ceva_bind(struct udevice *dev) { - int ret; - struct scsi_platdata *plat = dev_get_uclass_platdata(dev); + struct udevice *scsi_dev; + + return ahci_bind_scsi(dev, &scsi_dev); +}
- ceva_init_sata(plat->base); +static int sata_ceva_probe(struct udevice *dev) +{ + struct ceva_sata_priv *priv = dev_get_priv(dev);
- ret = ahci_init_one_dm(dev); - if (ret) - return ret; + ceva_init_sata(priv->base);
- return ahci_start_ports_dm(dev); + return ahci_probe_scsi(dev, priv->base); }
static const struct udevice_id sata_ceva_ids[] = { @@ -132,24 +138,22 @@ static const struct udevice_id sata_ceva_ids[] = {
static int sata_ceva_ofdata_to_platdata(struct udevice *dev) { - struct scsi_platdata *plat = dev_get_uclass_platdata(dev); + struct ceva_sata_priv *priv = dev_get_priv(dev);
- plat->base = devfdt_get_addr(dev); - if (plat->base == FDT_ADDR_T_NONE) + priv->base = devfdt_get_addr(dev); + if (priv->base == FDT_ADDR_T_NONE) return -EINVAL;
- /* Hardcode number for ceva sata controller */ - plat->max_lun = 1; /* Actually two but untested */ - plat->max_id = 2; - return 0; }
U_BOOT_DRIVER(ceva_host_blk) = { .name = "ceva_sata", - .id = UCLASS_SCSI, + .id = UCLASS_AHCI, .of_match = sata_ceva_ids, + .bind = sata_ceva_bind, .ops = &scsi_ops, + .priv_auto_alloc_size = sizeof(struct ceva_sata_priv), .probe = sata_ceva_probe, .ofdata_to_platdata = sata_ceva_ofdata_to_platdata, };
Michal Simek
