[PATCH 0/2] treewide: rework linker symbol declarations and references
1. Convert all linker symbol declarations to char[] type. 2. Unify the linker symbol reference format.
CI check: https://github.com/u-boot/u-boot/pull/401
Shiji Yang (2): treewide: rework linker symbol declarations in sections header treewide: unify the linker symbol reference format
arch/arc/include/asm/sections.h | 5 ++- arch/arc/lib/relocate.c | 37 ++++++++----------- arch/arm/cpu/arm926ejs/mxs/mxs.c | 2 +- arch/arm/cpu/arm926ejs/mxs/spl_boot.c | 2 +- arch/arm/include/asm/spl.h | 3 -- arch/arm/mach-stm32mp/boot_params.c | 4 +- arch/microblaze/include/asm/processor.h | 5 --- arch/mips/lib/reloc.c | 2 +- arch/mips/mach-jz47xx/jz4780/jz4780.c | 2 +- arch/mips/mach-mtmips/mt7621/spl/launch.c | 2 +- arch/mips/mach-mtmips/mt7621/spl/spl.c | 2 +- arch/riscv/cpu/jh7110/spl.c | 4 +- arch/x86/include/asm/sections.h | 2 + arch/x86/lib/relocate.c | 14 +++---- arch/x86/lib/spl.c | 6 +-- arch/xtensa/lib/relocate.c | 4 +- board/advantech/imx8qm_dmsse20_a1/spl.c | 1 + board/advantech/imx8qm_rom7720_a1/spl.c | 1 + board/aristainetos/aristainetos.c | 2 +- board/beacon/imx8mm/spl.c | 1 + board/beacon/imx8mn/spl.c | 1 + board/bosch/acc/acc.c | 1 + board/bsh/imx8mn_smm_s2/spl.c | 1 + board/cloos/imx8mm_phg/spl.c | 1 + board/compulab/cl-som-imx7/spl.c | 1 + board/compulab/imx8mm-cl-iot-gate/spl.c | 1 + board/congatec/cgtqmx8/spl.c | 1 + board/dhelectronics/dh_imx6/dh_imx6_spl.c | 1 + board/dhelectronics/dh_imx8mp/spl.c | 1 + board/engicam/imx8mm/spl.c | 1 + board/freescale/imx8mm_evk/spl.c | 1 + board/freescale/imx8mn_evk/spl.c | 1 + board/freescale/imx8mq_evk/spl.c | 1 + board/freescale/imx8qm_mek/spl.c | 1 + board/freescale/imx8qxp_mek/spl.c | 1 + board/freescale/imx8ulp_evk/spl.c | 1 + board/freescale/imx93_evk/spl.c | 1 + board/freescale/ls1021aiot/ls1021aiot.c | 1 + board/freescale/ls1021aqds/ls1021aqds.c | 1 + board/freescale/ls1021atsn/ls1021atsn.c | 1 + board/freescale/ls1021atwr/ls1021atwr.c | 1 + board/freescale/mx6sabreauto/mx6sabreauto.c | 1 + board/freescale/mx6sabresd/mx6sabresd.c | 1 + board/freescale/mx6slevk/mx6slevk.c | 1 + .../mx6ul_14x14_evk/mx6ul_14x14_evk.c | 1 + board/gateworks/venice/spl.c | 1 + board/k+p/kp_imx6q_tpc/kp_imx6q_tpc_spl.c | 1 + board/kontron/pitx_imx8m/spl.c | 1 + board/kontron/sl-mx6ul/spl.c | 1 + board/kontron/sl-mx8mm/spl.c | 1 + board/liebherr/display5/spl.c | 1 + board/mntre/imx8mq_reform2/spl.c | 1 + board/phytec/pcm058/pcm058.c | 1 + board/phytec/phycore_imx8mm/spl.c | 1 + board/ronetix/imx7-cm/spl.c | 1 + board/ronetix/imx8mq-cm/spl.c | 1 + board/siemens/capricorn/spl.c | 1 + board/sifive/unleashed/unleashed.c | 2 +- board/sifive/unmatched/unmatched.c | 2 +- board/softing/vining_2000/vining_2000.c | 1 + board/solidrun/mx6cuboxi/mx6cuboxi.c | 1 + .../visionfive2/starfive_visionfive2.c | 2 +- board/technexion/pico-imx6ul/spl.c | 1 + board/technexion/pico-imx7d/spl.c | 1 + board/technexion/pico-imx8mq/spl.c | 1 + board/toradex/apalis_imx6/apalis_imx6.c | 1 + board/toradex/colibri_imx6/colibri_imx6.c | 1 + board/toradex/verdin-imx8mm/spl.c | 1 + board/udoo/neo/neo.c | 1 + board/variscite/dart_6ul/spl.c | 1 + board/variscite/imx8mn_var_som/spl.c | 1 + board/xilinx/common/board.c | 6 +-- common/board_f.c | 16 ++++---- common/board_r.c | 4 +- drivers/ddr/imx/phy/helper.c | 4 +- include/asm-generic/sections.h | 34 +++-------------- lib/fdtdec.c | 6 +-- lib/trace.c | 2 +- 78 files changed, 123 insertions(+), 104 deletions(-)
On Thu, Aug 03, 2023 at 09:47:15AM +0800, Shiji Yang wrote:
- Convert all linker symbol declarations to char[] type.
- Unify the linker symbol reference format.
Thanks for digging in to this.
Shiji Yang
