[U-Boot] [PATCH 7/7] FAT: Make it possible to read from any file position
When storage devices contain files larger than the embedded RAM, it is useful to be able to read these files by chunks, e.g. for a software update to the embedded NAND Flash from an external storage device (USB stick, SD card, etc.).
Hence, this patch makes it possible by adding a new FAT API to read files from a given position.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com Cc: Wolfgang Denk wd@denx.de --- .../fs/fat/fat.c | 90 ++++++++++++++++---- 1 file changed, 72 insertions(+), 18 deletions(-)
diff --git u-boot-66714b1.orig/fs/fat/fat.c u-boot-66714b1/fs/fat/fat.c index 8ac8b85..709a5eb 100644 --- u-boot-66714b1.orig/fs/fat/fat.c +++ u-boot-66714b1/fs/fat/fat.c @@ -329,13 +329,16 @@ get_cluster (fsdata *mydata, __u32 clustnum, __u8 *buffer, }
/* - * Read at most 'maxsize' bytes from the file associated with 'dentptr' + * Read at most 'maxsize' bytes from 'pos' in the file associated with 'dentptr' * into 'buffer'. * Return the number of bytes read or -1 on fatal errors. */ +__u8 get_contents_vfatname_block[MAX_CLUSTSIZE] + __aligned(ARCH_DMA_MINALIGN); + static long -get_contents (fsdata *mydata, dir_entry *dentptr, __u8 *buffer, - unsigned long maxsize) +get_contents (fsdata *mydata, dir_entry *dentptr, unsigned long pos, + __u8 *buffer, unsigned long maxsize) { unsigned long filesize = FAT2CPU32(dentptr->size), gotsize = 0; unsigned int bytesperclust = mydata->clust_size * mydata->sect_size; @@ -345,12 +348,59 @@ get_contents (fsdata *mydata, dir_entry *dentptr, __u8 *buffer,
debug("Filesize: %ld bytes\n", filesize);
- if (maxsize > 0 && filesize > maxsize) - filesize = maxsize; + if (pos >= filesize) { + debug("Read position past EOF: %lu\n", pos); + return gotsize; + } + + if (maxsize > 0 && filesize > pos + maxsize) + filesize = pos + maxsize;
debug("%ld bytes\n", filesize);
actsize = bytesperclust; + + /* go to cluster at pos */ + while (actsize <= pos) { + curclust = get_fatent(mydata, curclust); + if (CHECK_CLUST(curclust, mydata->fatsize)) { + debug("curclust: 0x%x\n", curclust); + debug("Invalid FAT entry\n"); + return gotsize; + } + actsize += bytesperclust; + } + + /* actsize > pos */ + actsize -= bytesperclust; + filesize -= actsize; + pos -= actsize; + + /* align to beginning of next cluster if any */ + if (pos) { + actsize = min(filesize, bytesperclust); + if (get_cluster(mydata, curclust, get_contents_vfatname_block, + (int)actsize) != 0) { + printf("Error reading cluster\n"); + return -1; + } + filesize -= actsize; + actsize -= pos; + memcpy(buffer, get_contents_vfatname_block + pos, actsize); + gotsize += actsize; + if (!filesize) + return gotsize; + buffer += actsize; + + curclust = get_fatent(mydata, curclust); + if (CHECK_CLUST(curclust, mydata->fatsize)) { + debug("curclust: 0x%x\n", curclust); + debug("Invalid FAT entry\n"); + return gotsize; + } + } + + actsize = bytesperclust; endclust = curclust;
do { @@ -434,9 +484,6 @@ static int slot2str (dir_slot *slotptr, char *l_name, int *idx) * into 'retdent' * Return 0 on success, -1 otherwise. */ -__u8 get_vfatname_block[MAX_CLUSTSIZE] - __aligned(ARCH_DMA_MINALIGN); - static int get_vfatname (fsdata *mydata, int curclust, __u8 *cluster, dir_entry *retdent, char *l_name) @@ -475,13 +522,13 @@ get_vfatname (fsdata *mydata, int curclust, __u8 *cluster, return -1; }
- if (get_cluster(mydata, curclust, get_vfatname_block, + if (get_cluster(mydata, curclust, get_contents_vfatname_block, mydata->clust_size * mydata->sect_size) != 0) { debug("Error: reading directory block\n"); return -1; }
- slotptr2 = (dir_slot *)get_vfatname_block; + slotptr2 = (dir_slot *)get_contents_vfatname_block; while (counter > 0) { if (((slotptr2->id & ~LAST_LONG_ENTRY_MASK) & 0xff) != counter) @@ -492,7 +539,7 @@ get_vfatname (fsdata *mydata, int curclust, __u8 *cluster,
/* Save the real directory entry */ realdent = (dir_entry *)slotptr2; - while ((__u8 *)slotptr2 > get_vfatname_block) { + while ((__u8 *)slotptr2 > get_contents_vfatname_block) { slotptr2--; slot2str(slotptr2, l_name, &idx); } @@ -771,12 +818,12 @@ exit: return ret; }
-__u8 do_fat_read_block[MAX_CLUSTSIZE] +__u8 do_fat_read_at_block[MAX_CLUSTSIZE] __aligned(ARCH_DMA_MINALIGN);
long -do_fat_read (const char *filename, void *buffer, unsigned long maxsize, - int dols) +do_fat_read_at (const char *filename, unsigned long pos, void *buffer, + unsigned long maxsize, int dols) { char fnamecopy[2048]; boot_sector bs; @@ -890,12 +937,12 @@ do_fat_read (const char *filename, void *buffer, unsigned long maxsize, (mydata->fatsize == 32) ? (mydata->clust_size) : PREFETCH_BLOCKS, - do_fat_read_block) < 0) { + do_fat_read_at_block) < 0) { debug("Error: reading rootdir block\n"); goto exit; }
- dentptr = (dir_entry *) do_fat_read_block; + dentptr = (dir_entry *) do_fat_read_at_block; }
for (i = 0; i < DIRENTSPERBLOCK; i++) { @@ -915,7 +962,7 @@ do_fat_read (const char *filename, void *buffer, unsigned long maxsize,
get_vfatname(mydata, root_cluster, - do_fat_read_block, + do_fat_read_at_block, dentptr, l_name);
if (dols == LS_ROOT) { @@ -1118,7 +1165,7 @@ rootdir_done: subname = nextname; }
- ret = get_contents(mydata, dentptr, buffer, maxsize); + ret = get_contents(mydata, dentptr, pos, buffer, maxsize); debug("Size: %d, got: %ld\n", FAT2CPU32(dentptr->size), ret);
exit: @@ -1126,6 +1173,13 @@ exit: return ret; }
+long +do_fat_read (const char *filename, void *buffer, unsigned long maxsize, + int dols) +{ + return do_fat_read_at(filename, 0, buffer, maxsize, dols); +} + int file_fat_detectfs (void) { boot_sector bs;
is there any reason for this to be exported ? could you mark it static ?
delete the space before the "("
int dols)
no spaces before that "(" -mike
I'll do that. There are probably other variables in fat.c missing static, so I'll do a dedicated patch before this series. That will shift the patch numbers. How should I repost the new version of the series? Should I keep the message ID of each patch even if the numbering changes, or should I post a v2 completely separately from v1?
int dols)
I'll add a cosmetic patch for that in a prequel.
Regards, Benoît
it's easier on everyone to do this. you might want to look at tools/patman/ as a way for managing the review process. -mike
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com Cc: Wolfgang Denk wd@denx.de --- Changes for v2: - Patch renumbering because of the new v2 1/8. - Possible code style changes due to the new v2 1/8. - Add missing vairable renaming to fat_write.c.
.../fs/fat/fat.c | 88 ++++++++++++++++---- .../fs/fat/fat_write.c | 18 ++-- 2 files changed, 80 insertions(+), 26 deletions(-)
diff --git u-boot-66714b1.orig/fs/fat/fat.c u-boot-66714b1/fs/fat/fat.c index 19f6a8c..8c94b28 100644 --- u-boot-66714b1.orig/fs/fat/fat.c +++ u-boot-66714b1/fs/fat/fat.c @@ -328,13 +328,16 @@ get_cluster(fsdata *mydata, __u32 clustnum, __u8 *buffer, unsigned long size) }
/* - * Read at most 'maxsize' bytes from the file associated with 'dentptr' + * Read at most 'maxsize' bytes from 'pos' in the file associated with 'dentptr' * into 'buffer'. * Return the number of bytes read or -1 on fatal errors. */ +__u8 get_contents_vfatname_block[MAX_CLUSTSIZE] + __aligned(ARCH_DMA_MINALIGN); + static long -get_contents(fsdata *mydata, dir_entry *dentptr, __u8 *buffer, - unsigned long maxsize) +get_contents(fsdata *mydata, dir_entry *dentptr, unsigned long pos, + __u8 *buffer, unsigned long maxsize) { unsigned long filesize = FAT2CPU32(dentptr->size), gotsize = 0; unsigned int bytesperclust = mydata->clust_size * mydata->sect_size; @@ -344,12 +347,59 @@ get_contents(fsdata *mydata, dir_entry *dentptr, __u8 *buffer,
do { @@ -433,9 +483,6 @@ static int slot2str(dir_slot *slotptr, char *l_name, int *idx) * into 'retdent' * Return 0 on success, -1 otherwise. */ -__u8 get_vfatname_block[MAX_CLUSTSIZE] - __aligned(ARCH_DMA_MINALIGN); - static int get_vfatname(fsdata *mydata, int curclust, __u8 *cluster, dir_entry *retdent, char *l_name) @@ -474,13 +521,13 @@ get_vfatname(fsdata *mydata, int curclust, __u8 *cluster, return -1; }
- slotptr2 = (dir_slot *)get_vfatname_block; + slotptr2 = (dir_slot *)get_contents_vfatname_block; while (counter > 0) { if (((slotptr2->id & ~LAST_LONG_ENTRY_MASK) & 0xff) != counter) @@ -491,7 +538,7 @@ get_vfatname(fsdata *mydata, int curclust, __u8 *cluster,
/* Save the real directory entry */ realdent = (dir_entry *)slotptr2; - while ((__u8 *)slotptr2 > get_vfatname_block) { + while ((__u8 *)slotptr2 > get_contents_vfatname_block) { slotptr2--; slot2str(slotptr2, l_name, &idx); } @@ -770,11 +817,12 @@ exit: return ret; }
long -do_fat_read(const char *filename, void *buffer, unsigned long maxsize, int dols) +do_fat_read_at(const char *filename, unsigned long pos, void *buffer, + unsigned long maxsize, int dols) { char fnamecopy[2048]; boot_sector bs; @@ -888,12 +936,12 @@ do_fat_read(const char *filename, void *buffer, unsigned long maxsize, int dols) (mydata->fatsize == 32) ? (mydata->clust_size) : PREFETCH_BLOCKS, - do_fat_read_block) < 0) { + do_fat_read_at_block) < 0) { debug("Error: reading rootdir block\n"); goto exit; }
for (i = 0; i < DIRENTSPERBLOCK; i++) { @@ -913,7 +961,7 @@ do_fat_read(const char *filename, void *buffer, unsigned long maxsize, int dols)
if (dols == LS_ROOT) { @@ -1116,7 +1164,7 @@ rootdir_done: subname = nextname; }
exit: @@ -1124,6 +1172,12 @@ exit: return ret; }
+long +do_fat_read(const char *filename, void *buffer, unsigned long maxsize, int dols) +{ + return do_fat_read_at(filename, 0, buffer, maxsize, dols); +} + int file_fat_detectfs(void) { boot_sector bs; diff --git u-boot-66714b1.orig/fs/fat/fat_write.c u-boot-66714b1/fs/fat/fat_write.c index a6181e7..5829adf 100644 --- u-boot-66714b1.orig/fs/fat/fat_write.c +++ u-boot-66714b1/fs/fat/fat_write.c @@ -328,7 +328,7 @@ static void flush_dir_table(fsdata *mydata, dir_entry **dentptr); static void fill_dir_slot(fsdata *mydata, dir_entry **dentptr, const char *l_name) { - dir_slot *slotptr = (dir_slot *)get_vfatname_block; + dir_slot *slotptr = (dir_slot *)get_contents_vfatname_block; __u8 counter = 0, checksum; int idx = 0, ret; char s_name[16]; @@ -373,7 +373,7 @@ static __u32 dir_curclust; * a slot) into 'l_name'. If successful also copy the real directory entry * into 'retdent' * If additional adjacent cluster for directory entries is read into memory, - * then 'get_vfatname_block' is copied into 'get_dentfromdir_block' and + * then 'get_contents_vfatname_block' is copied into 'get_dentfromdir_block' and * the location of the real directory entry is returned by 'retdent' * Return 0 on success, -1 otherwise. */ @@ -416,13 +416,13 @@ get_long_file_name(fsdata *mydata, int curclust, __u8 *cluster,
dir_curclust = curclust;
- slotptr2 = (dir_slot *)get_vfatname_block; + slotptr2 = (dir_slot *)get_contents_vfatname_block; while (counter > 0) { if (((slotptr2->id & ~LAST_LONG_ENTRY_MASK) & 0xff) != counter) @@ -433,7 +433,7 @@ get_long_file_name(fsdata *mydata, int curclust, __u8 *cluster,
/* Save the real directory entry */ realdent = (dir_entry *)slotptr2; - while ((__u8 *)slotptr2 > get_vfatname_block) { + while ((__u8 *)slotptr2 > get_contents_vfatname_block) { slotptr2--; slot2str(slotptr2, l_name, &idx); } @@ -459,9 +459,9 @@ get_long_file_name(fsdata *mydata, int curclust, __u8 *cluster, *retdent = realdent;
if (slotptr2) { - memcpy(get_dentfromdir_block, get_vfatname_block, + memcpy(get_dentfromdir_block, get_contents_vfatname_block, mydata->clust_size * mydata->sect_size); - cur_position = (__u8 *)realdent - get_vfatname_block; + cur_position = (__u8 *)realdent - get_contents_vfatname_block; *retdent = (dir_entry *) &get_dentfromdir_block[cur_position]; }
@@ -980,11 +980,11 @@ static int do_fat_write(const char *filename, void *buffer, if (disk_read(cursect, (mydata->fatsize == 32) ? (mydata->clust_size) : - PREFETCH_BLOCKS, do_fat_read_block) < 0) { + PREFETCH_BLOCKS, do_fat_read_at_block) < 0) { debug("Error: reading rootdir block\n"); goto exit; } - dentptr = (dir_entry *) do_fat_read_block; + dentptr = (dir_entry *) do_fat_read_at_block;
name_len = strlen(filename); if (name_len >= VFAT_MAXLEN_BYTES)
Dear Benoît Thébaudeau,
In message 1285759492.332736.1342790529256.JavaMail.root@advansee.com you wrote:
When storage devices contain files larger than the embedded RAM, it is usef> ul to be able to read these files by chunks, e.g. for a software update to the embedded NAND Flash from an external storage device (USB stick, SD card, et> c.).
Hence, this patch makes it possible by adding a new FAT API to read files f> rom a given position.
Changes for v2:
.../fs/fat/fat.c | 88 ++++++++++++++++> ---- .../fs/fat/fat_write.c | 18 ++-- 2 files changed, 80 insertions(+), 26 deletions(-)
I don't see any command line interface to actually use this code.
How would I put this to use?
Skipped for now.
Dear Wolfgang Denk,
Changes for v2:
Here is the current "fatload" command line interface: fatload <interface> <dev[:part]> <addr> <filename> [bytes]
Do you prefer to change it to: fatload <interface> <dev[:part]> <addr> <filename> [offset] [bytes]
or to have a new dedicated command, or something else?
Best regards, Benoît
On Mon, Sep 03, 2012 at 04:17:09PM +0200, Beno??t Th??baudeau wrote:
Dear Wolfgang Denk,
Dear Beno??t Th??baudeau,
Signed-off-by: Beno??t Th??baudeau benoit.thebaudeau@advansee.com Cc: Wolfgang Denk wd@denx.de
Changes for v2:
Lets go with: fatload <interface> <dev[:part]> <addr> <filename> [bytes] [offset] and update the long help text to mention both bytes and offset and that offset requires bytes.
Dear Wolfgang Denk,
Changes for v2:
OK. Do you want that in an update of this patch or in a separate patch?
You're right: Having [bytes] before [offset] will avoid breaking the current users of this command. However, this has one drawback: fatls first has to be used to get the file size (with [offset] first, 0 could be easily used for offset to access [bytes]). Hence, still with [bytes] first, would you like to have some special bytes value (let's say -1 or any negative value) meaning "from offset to end of file"?
Dear Wolfgang Denk,
Changes for v2:
New patch to replace this.
Lets go with -1 meaning until end of file since we don't have a good way today to determine total filesize.
Dear Wolfgang Denk,
Changes for v2:
OK. I took 0 instead of -1 because 0 already had this behavior.
Done here: http://patchwork.ozlabs.org/patch/184793/
Hence, this patch makes it possible by adding a new FAT API to read files from a given position. This patch also adds this feature to the fatload command.
Signed-off-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com Cc: Tom Rini trini@ti.com Cc: Wolfgang Denk wd@denx.de --- Changes for v2: - Add missing variable renaming to fat_write.c. Changes for v3: - Make this new feature available through the fatload command.
.../common/cmd_fat.c | 25 +++-- .../fs/fat/fat.c | 98 ++++++++++++++++---- .../fs/fat/fat_write.c | 18 ++-- .../include/fat.h | 2 + 4 files changed, 105 insertions(+), 38 deletions(-)
diff --git u-boot-037e9d3.orig/common/cmd_fat.c u-boot-037e9d3/common/cmd_fat.c index 559a16d..2e34c54 100644 --- u-boot-037e9d3.orig/common/cmd_fat.c +++ u-boot-037e9d3/common/cmd_fat.c @@ -37,7 +37,8 @@ int do_fat_fsload (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { long size; unsigned long offset; - unsigned long count; + unsigned long count = 0; + unsigned long pos = 0; char buf [12]; block_dev_desc_t *dev_desc=NULL; int dev=0; @@ -46,7 +47,7 @@ int do_fat_fsload (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
if (argc < 5) { printf( "usage: fatload <interface> <dev[:part]> " - "<addr> <filename> [bytes]\n"); + "<addr> <filename> [bytes [pos]]\n"); return 1; }
@@ -69,11 +70,11 @@ int do_fat_fsload (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 1; } offset = simple_strtoul(argv[3], NULL, 16); - if (argc == 6) + if (argc >= 6) count = simple_strtoul(argv[5], NULL, 16); - else - count = 0; - size = file_fat_read(argv[4], (unsigned char *)offset, count); + if (argc >= 7) + pos = simple_strtoul(argv[6], NULL, 16); + size = file_fat_read_at(argv[4], pos, (unsigned char *)offset, count);
if(size==-1) { printf("\n** Unable to read "%s" from %s %d:%d **\n", @@ -91,11 +92,15 @@ int do_fat_fsload (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
U_BOOT_CMD( - fatload, 6, 0, do_fat_fsload, + fatload, 7, 0, do_fat_fsload, "load binary file from a dos filesystem", - "<interface> <dev[:part]> <addr> <filename> [bytes]\n" - " - load binary file 'filename' from 'dev' on 'interface'\n" - " to address 'addr' from dos filesystem" + "<interface> <dev[:part]> <addr> <filename> [bytes [pos]]\n" + " - Load binary file 'filename' from 'dev' on 'interface'\n" + " to address 'addr' from dos filesystem.\n" + " 'pos' gives the file position to start loading from.\n" + " If 'pos' is omitted, 0 is used. 'pos' requires 'bytes'.\n" + " 'bytes' gives the size to load. If 'bytes' is 0 or omitted,\n" + " the load stops on end of file." );
int do_fat_ls (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) diff --git u-boot-037e9d3.orig/fs/fat/fat.c u-boot-037e9d3/fs/fat/fat.c index f7bb1da..c8beb30 100644 --- u-boot-037e9d3.orig/fs/fat/fat.c +++ u-boot-037e9d3/fs/fat/fat.c @@ -328,13 +328,16 @@ get_cluster(fsdata *mydata, __u32 clustnum, __u8 *buffer, unsigned long size) }
if (dols == LS_ROOT) { @@ -1116,7 +1164,7 @@ rootdir_done: } }
+long +do_fat_read(const char *filename, void *buffer, unsigned long maxsize, int dols) +{ + return do_fat_read_at(filename, 0, buffer, maxsize, dols); +} + int file_fat_detectfs(void) { boot_sector bs; @@ -1192,8 +1246,14 @@ int file_fat_ls(const char *dir) return do_fat_read(dir, NULL, 0, LS_YES); }
-long file_fat_read(const char *filename, void *buffer, unsigned long maxsize) +long file_fat_read_at(const char *filename, unsigned long pos, void *buffer, + unsigned long maxsize) { printf("reading %s\n", filename); - return do_fat_read(filename, buffer, maxsize, LS_NO); + return do_fat_read_at(filename, pos, buffer, maxsize, LS_NO); +} + +long file_fat_read(const char *filename, void *buffer, unsigned long maxsize) +{ + return file_fat_read_at(filename, 0, buffer, maxsize); } diff --git u-boot-037e9d3.orig/fs/fat/fat_write.c u-boot-037e9d3/fs/fat/fat_write.c index a6181e7..5829adf 100644 --- u-boot-037e9d3.orig/fs/fat/fat_write.c +++ u-boot-037e9d3/fs/fat/fat_write.c @@ -328,7 +328,7 @@ static void flush_dir_table(fsdata *mydata, dir_entry **dentptr); static void fill_dir_slot(fsdata *mydata, dir_entry **dentptr, const char *l_name) { - dir_slot *slotptr = (dir_slot *)get_vfatname_block; + dir_slot *slotptr = (dir_slot *)get_contents_vfatname_block; __u8 counter = 0, checksum; int idx = 0, ret; char s_name[16]; @@ -373,7 +373,7 @@ static __u32 dir_curclust; * a slot) into 'l_name'. If successful also copy the real directory entry * into 'retdent' * If additional adjacent cluster for directory entries is read into memory, - * then 'get_vfatname_block' is copied into 'get_dentfromdir_block' and + * then 'get_contents_vfatname_block' is copied into 'get_dentfromdir_block' and * the location of the real directory entry is returned by 'retdent' * Return 0 on success, -1 otherwise. */ @@ -416,13 +416,13 @@ get_long_file_name(fsdata *mydata, int curclust, __u8 *cluster,
name_len = strlen(filename); if (name_len >= VFAT_MAXLEN_BYTES) diff --git u-boot-037e9d3.orig/include/fat.h u-boot-037e9d3/include/fat.h index f1b4a0d..cc85b06 100644 --- u-boot-037e9d3.orig/include/fat.h +++ u-boot-037e9d3/include/fat.h @@ -208,6 +208,8 @@ file_read_func file_fat_read; int file_cd(const char *path); int file_fat_detectfs(void); int file_fat_ls(const char *dir); +long file_fat_read_at(const char *filename, unsigned long pos, void *buffer, + unsigned long maxsize); long file_fat_read(const char *filename, void *buffer, unsigned long maxsize); const char *file_getfsname(int idx); int fat_register_device(block_dev_desc_t *dev_desc, int part_no);
Signed-off-by: Beno?t Th?baudeau benoit.thebaudeau@advansee.com Cc: Tom Rini trini@ti.com Cc: Wolfgang Denk wd@denx.de
With a reformatting of the commit message and making the changes re-apply to master, I've applied this to u-boot/master, thanks!
Hi Tom,
Perfect.
I have a concern regarding the two patches that came in between: [1] http://git.denx.de/cgi-bin/gitweb.cgi?p=u-boot.git;a=commitdiff;h=cfda5aeab8... [2] http://git.denx.de/cgi-bin/gitweb.cgi?p=u-boot.git;a=commitdiff;h=10a37fd7a4...
Perhaps I'm wrong, and I admit I have not tested them, but looking at the code, it seems to me that [2] breaks the "-" in the following feature of [1]: "With the common function "dev:part" can come from the environment and a '-' can be used in that case." Hence, tests like "if (argc < 5)" in do_fat_fsload() get broken.
Also, the command usage message marks dev:part as optional, but it does not say that this should actually be replaced by "-" if skipped.
On 09/28/2012 05:32 AM, Benoît Thébaudeau wrote:
Hi Tom,
Perfect.
I've sent a patch to fix this.
On Fri, Sep 28, 2012 at 09:34:42AM -0600, Stephen Warren wrote:
On 09/28/2012 05:32 AM, Beno??t Th??baudeau wrote:
Hi Tom,
Perfect.
Thanks guys, I was a little worried about that merge, but not as worried as I should have been.
participants (5)
Benoît Thébaudeau
Mike Frysinger
Stephen Warren
