[U-Boot] [PATCH V2] ARM: socfpga: Clear PL310 early in SPL
On SoCFPGA Gen5 systems, it can rarely happen that a reboot from Linux will result in stale data in PL310 L2 cache controller. Even if the L2 cache controller is disabled via the CTRL register CTRL_EN bit, those data can interfere with operation of devices using DMA, like e.g. the DWMMC controller. This can in turn cause e.g. SPL to fail reading data from SD/MMC.
The obvious solution here would be to fully reset the L2 cache controller via the reset manager MPUMODRST L2 bit, however this causes bus hang even if executed entirely from L1 I-cache to avoid generating any bus traffic through the L2 cache controller.
This patch thus configures and enables the L2 cache controller very early in the SPL boot process, clears the L2 cache and disables the L2 cache controller again.
The reason for doing it in SPL is because we need to avoid accessing any of the potentially stale data in the L2 cache, and we are certain any of the stale data will be below the OCRAM address range. To further reduce bus traffic during the L2 cache invalidation, we enable L1 I-cache and run the invalidation code entirely out of the L1 I-cache.
Signed-off-by: Marek Vasut marex@denx.de Cc: Dalon Westergreen dwesterg@gmail.com Cc: Dinh Nguyen dinguyen@kernel.org --- V2: Add missing pl310 header --- arch/arm/mach-socfpga/spl_gen5.c | 58 ++++++++++++++++++++++++++++++++ 1 file changed, 58 insertions(+)
diff --git a/arch/arm/mach-socfpga/spl_gen5.c b/arch/arm/mach-socfpga/spl_gen5.c index ccdc661d05..e7b13c4c70 100644 --- a/arch/arm/mach-socfpga/spl_gen5.c +++ b/arch/arm/mach-socfpga/spl_gen5.c @@ -5,6 +5,7 @@
#include <common.h> #include <asm/io.h> +#include <asm/pl310.h> #include <asm/u-boot.h> #include <asm/utils.h> #include <image.h> @@ -23,6 +24,8 @@
DECLARE_GLOBAL_DATA_PTR;
+static struct pl310_regs *const pl310 = + (struct pl310_regs *)CONFIG_SYS_PL310_BASE; static const struct socfpga_system_manager *sysmgr_regs = (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS;
@@ -63,6 +66,60 @@ u32 spl_boot_mode(const u32 boot_device) } #endif
+static void socfpga_pl310_clear(void) +{ + u32 mask = 0xff, ena = 0; + + icache_enable(); + + /* Disable the L2 cache */ + clrbits_le32(&pl310->pl310_ctrl, L2X0_CTRL_EN); + + writel(0x111, &pl310->pl310_tag_latency_ctrl); + writel(0x121, &pl310->pl310_data_latency_ctrl); + + /* enable BRESP, instruction and data prefetch, full line of zeroes */ + setbits_le32(&pl310->pl310_aux_ctrl, + L310_AUX_CTRL_DATA_PREFETCH_MASK | + L310_AUX_CTRL_INST_PREFETCH_MASK | + L310_SHARED_ATT_OVERRIDE_ENABLE); + + /* Enable the L2 cache */ + ena = readl(&pl310->pl310_ctrl); + ena |= L2X0_CTRL_EN; + + /* + * Invalidate the PL310 L2 cache. Keep the invalidation code + * entirely in L1 I-cache to avoid any bus traffic through + * the L2. + */ + asm volatile( + ".align 5 \n" + " b 3f \n" + "1: str %1, [%4] \n" + " dsb \n" + " isb \n" + " str %0, [%2] \n" + " dsb \n" + " isb \n" + "2: ldr %0, [%2] \n" + " cmp %0, #0 \n" + " bne 2b \n" + " str %0, [%3] \n" + " dsb \n" + " isb \n" + " b 4f \n" + "3: b 1b \n" + "4: nop \n" + : "+r"(mask), "+r"(ena) + : "r"(&pl310->pl310_inv_way), + "r"(&pl310->pl310_cache_sync), "r"(&pl310->pl310_ctrl) + : "memory", "cc"); + + /* Disable the L2 cache */ + clrbits_le32(&pl310->pl310_ctrl, L2X0_CTRL_EN); +} + void board_init_f(ulong dummy) { const struct cm_config *cm_default_cfg = cm_get_default_config(); @@ -85,6 +142,7 @@ void board_init_f(ulong dummy) memset(__bss_start, 0, __bss_end - __bss_start);
socfpga_sdram_remap_zero(); + socfpga_pl310_clear();
debug("Freezing all I/O banks\n"); /* freeze all IO banks */
Reviewed-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com
Tested on socfpga_socrates_defconfig: Tested-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com
icache_enable();
* the L2.
asm volatile(
".align 5 \n"
" b 3f \n"
" dsb \n"
" isb \n"
" str %0, [%2] \n"
" dsb \n"
" isb \n"
" cmp %0, #0 \n"
" bne 2b \n"
" str %0, [%3] \n"
" dsb \n"
" isb \n"
" b 4f \n"
"3: b 1b \n"
"4: nop \n"
: "memory", "cc");
socfpga_pl310_clear(); debug("Freezing all I/O banks\n"); /* freeze all IO banks */
-- 2.19.2
Simon Goldschmidt
