[U-Boot] [PATCH v7 08/17] sf: Discover read dummy_byte
Discovered the read dummy_byte based on the configured read command.
Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com --- drivers/mtd/spi/sf_internal.h | 2 ++ drivers/mtd/spi/sf_ops.c | 16 +++++++++------- drivers/mtd/spi/sf_probe.c | 19 +++++++++++++++++++ include/spi_flash.h | 2 ++ 4 files changed, 32 insertions(+), 7 deletions(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index 7be0292..a9f5a81 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -10,6 +10,8 @@ #ifndef _SF_INTERNAL_H_ #define _SF_INTERNAL_H_
+#define SPI_FLASH_3B_ADDR_LEN 3 +#define SPI_FLASH_CMD_LEN (1 + SPI_FLASH_3B_ADDR_LEN) #define SPI_FLASH_16MB_BOUN 0x1000000
/* CFI Manufacture ID's */ diff --git a/drivers/mtd/spi/sf_ops.c b/drivers/mtd/spi/sf_ops.c index 827f719..6adee32 100644 --- a/drivers/mtd/spi/sf_ops.c +++ b/drivers/mtd/spi/sf_ops.c @@ -9,6 +9,7 @@ */
#include <common.h> +#include <malloc.h> #include <spi.h> #include <spi_flash.h> #include <watchdog.h> @@ -216,7 +217,7 @@ int spi_flash_write_common(struct spi_flash *flash, const u8 *cmd, int spi_flash_cmd_erase_ops(struct spi_flash *flash, u32 offset, size_t len) { u32 erase_size; - u8 cmd[4]; + u8 cmd[SPI_FLASH_CMD_LEN]; int ret = -1;
erase_size = flash->erase_size; @@ -255,7 +256,7 @@ int spi_flash_cmd_write_ops(struct spi_flash *flash, u32 offset, { unsigned long byte_addr, page_size; size_t chunk_len, actual; - u8 cmd[4]; + u8 cmd[SPI_FLASH_CMD_LEN]; int ret = -1;
page_size = flash->page_size; @@ -317,7 +318,7 @@ int spi_flash_read_common(struct spi_flash *flash, const u8 *cmd, int spi_flash_cmd_read_ops(struct spi_flash *flash, u32 offset, size_t len, void *data) { - u8 cmd[5], bank_sel = 0; + u8 *cmd, cmdsz, bank_sel = 0; u32 remain_len, read_len; int ret = -1;
@@ -335,9 +336,11 @@ int spi_flash_cmd_read_ops(struct spi_flash *flash, u32 offset, return 0; }
- cmd[0] = flash->read_cmd; - cmd[4] = 0x00; + cmdsz = SPI_FLASH_CMD_LEN + flash->dummy_byte; + cmd = malloc(cmdsz); + memset(cmd, 0, cmdsz);
+ cmd[0] = flash->read_cmd; while (len) { #ifdef CONFIG_SPI_FLASH_BAR bank_sel = offset / SPI_FLASH_16MB_BOUN; @@ -356,8 +359,7 @@ int spi_flash_cmd_read_ops(struct spi_flash *flash, u32 offset,
spi_flash_addr(offset, cmd);
- ret = spi_flash_read_common(flash, cmd, sizeof(cmd), - data, read_len); + ret = spi_flash_read_common(flash, cmd, cmdsz, data, read_len); if (ret < 0) { debug("SF: read failed\n"); break; diff --git a/drivers/mtd/spi/sf_probe.c b/drivers/mtd/spi/sf_probe.c index a049e72..8bd06ee 100644 --- a/drivers/mtd/spi/sf_probe.c +++ b/drivers/mtd/spi/sf_probe.c @@ -140,6 +140,25 @@ static struct spi_flash *spi_flash_validate_params(struct spi_slave *spi, } }
+ /* Read dummy_byte: dummy byte is determined based on the + * dummy cycles of a particular command. + * Fast commands - dummy_byte = dummy_cycles/8 + * I/O commands- dummy_byte = (dummy_cycles * no.of lines)/8 + * For I/O commands except cmd[0] everything goes on no.of lines + * based on particular command but incase of fast commands except + * data all go on single line irrespective of command. + */ + switch (flash->read_cmd) { + case CMD_READ_QUAD_IO_FAST: + flash->dummy_byte = 2; + break; + case CMD_READ_ARRAY_SLOW: + flash->dummy_byte = 0; + break; + default: + flash->dummy_byte = 1; + } + /* Poll cmd seclection */ flash->poll_cmd = CMD_READ_STATUS; #ifdef CONFIG_SPI_FLASH_STMICRO diff --git a/include/spi_flash.h b/include/spi_flash.h index 99724a0..437937c 100644 --- a/include/spi_flash.h +++ b/include/spi_flash.h @@ -72,6 +72,7 @@ extern const struct spi_flash_params spi_flash_params_table[]; * @erase_cmd: Erase cmd 4K, 32K, 64K * @read_cmd: Read cmd - Array Fast, Extn read and quad read. * @write_cmd: Write cmd - page and quad program. + * @dummy_byte: Dummy cycles for read operation. * @memory_map: Address of read-only SPI flash access * @read: Flash read ops: Read len bytes at offset into buf * Supported cmds: Fast Array Read @@ -98,6 +99,7 @@ struct spi_flash { u8 erase_cmd; u8 read_cmd; u8 write_cmd; + u8 dummy_byte;
void *memory_map; int (*read)(struct spi_flash *flash, u32 offset, size_t len, void *buf);
