[U-Boot] [PATCH 0/7] Blackfin updates for 2009.03 (part 3)
These are mostly updates to the startup code to fix misc bugs and get it working with recent parts and some newer bootrom features.
Mike Frysinger (7): Blackfin: update anomaly lists Blackfin: use on-chip syscontrol() rom function when available Blackfin: set default voltage levels for BF538/BF539 parts Blackfin: check for reserved settings in DDR MMRs Blackfin: add support for fast SPI reads with Boot ROM Blackfin: dynamically update UART speed when initializing Blackfin: move default boot SPI CS to common code
board/bf537-stamp/spi_flash.c | 8 +- cpu/blackfin/initcode.c | 155 +++++++++++++++----------- cpu/blackfin/serial.h | 72 +++--------- include/asm-blackfin/blackfin-config-pre.h | 9 ++ include/asm-blackfin/mach-bf527/anomaly.h | 166 ++++++++++++++++++++-------- include/asm-blackfin/mach-bf533/anomaly.h | 55 ++++++---- include/asm-blackfin/mach-bf537/anomaly.h | 14 ++- include/asm-blackfin/mach-bf548/anomaly.h | 45 +++++--- include/asm-blackfin/mach-bf561/anomaly.h | 17 +++- 9 files changed, 330 insertions(+), 211 deletions(-)
Update the anomaly lists to match latest anomaly sheets.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- include/asm-blackfin/mach-bf527/anomaly.h | 166 +++++++++++++++++++++-------- include/asm-blackfin/mach-bf533/anomaly.h | 55 ++++++---- include/asm-blackfin/mach-bf537/anomaly.h | 14 +++- include/asm-blackfin/mach-bf548/anomaly.h | 45 ++++++--- include/asm-blackfin/mach-bf561/anomaly.h | 17 +++- 5 files changed, 213 insertions(+), 84 deletions(-)
diff --git a/include/asm-blackfin/mach-bf527/anomaly.h b/include/asm-blackfin/mach-bf527/anomaly.h index 7c5127e..035e8d8 100644 --- a/include/asm-blackfin/mach-bf527/anomaly.h +++ b/include/asm-blackfin/mach-bf527/anomaly.h @@ -7,82 +7,154 @@ */
/* This file shoule be up to date with: - * - Revision C, 01/25/2008; ADSP-BF527 Blackfin Processor Anomaly List + * - Revision B, 08/12/2008; ADSP-BF526 Blackfin Processor Anomaly List + * - Revision E, 08/18/2008; ADSP-BF527 Blackfin Processor Anomaly List */
#ifndef _MACH_ANOMALY_H_ #define _MACH_ANOMALY_H_
+#if defined(__ADSPBF522__) || defined(__ADSPBF524__) || defined(__ADSPBF526__) +# define ANOMALY_BF526 1 +#else +# define ANOMALY_BF526 0 +#endif +#if defined(__ADSPBF523__) || defined(__ADSPBF525__) || defined(__ADSPBF527__) +# define ANOMALY_BF527 1 +#else +# define ANOMALY_BF527 0 +#endif + /* Multi-Issue Instruction with dsp32shiftimm in slot1 and P-reg Store in slot2 Not Supported */ #define ANOMALY_05000074 (1) /* DMA_RUN Bit Is Not Valid after a Peripheral Receive Channel DMA Stops */ -#define ANOMALY_05000119 (1) +#define ANOMALY_05000119 (1) /* note: brokenness is noted in documentation, not anomaly sheet */ /* Rx.H Cannot Be Used to Access 16-bit System MMR Registers */ #define ANOMALY_05000122 (1) /* Spurious Hardware Error from an Access in the Shadow of a Conditional Branch */ #define ANOMALY_05000245 (1) /* Sensitivity To Noise with Slow Input Edge Rates on External SPORT TX and RX Clocks */ #define ANOMALY_05000265 (1) -/* Errors when SSYNC, CSYNC, or Loads to LT, LB and LC Registers Are Interrupted */ -#define ANOMALY_05000312 (1) +/* False Hardware Errors Caused by Fetches at the Boundary of Reserved Memory */ +#define ANOMALY_05000310 (1) +/* PPI Is Level-Sensitive on First Transfer In Single Frame Sync Modes */ +#define ANOMALY_05000313 (__SILICON_REVISION__ < 2) /* Incorrect Access of OTP_STATUS During otp_write() Function */ -#define ANOMALY_05000328 (1) +#define ANOMALY_05000328 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) /* Disallowed Configuration Prevents Subsequent Allowed Configuration on Host DMA Port */ -#define ANOMALY_05000337 (1) +#define ANOMALY_05000337 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) /* Ethernet MAC MDIO Reads Do Not Meet IEEE Specification */ -#define ANOMALY_05000341 (1) +#define ANOMALY_05000341 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) /* TWI May Not Operate Correctly Under Certain Signal Termination Conditions */ -#define ANOMALY_05000342 (1) +#define ANOMALY_05000342 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) /* USB Calibration Value Is Not Initialized */ -#define ANOMALY_05000346 (1) +#define ANOMALY_05000346 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +/* USB Calibration Value to use */ +#define ANOMALY_05000346_value 0xE510 /* Preboot Routine Incorrectly Alters Reset Value of USB Register */ -#define ANOMALY_05000347 (1) +#define ANOMALY_05000347 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) /* Security Features Are Not Functional */ -#define ANOMALY_05000348 (__SILICON_REVISION__ < 1) +#define ANOMALY_05000348 (ANOMALY_BF527 && __SILICON_REVISION__ < 1) +/* bfrom_SysControl() Firmware Function Performs Improper System Reset */ +#define ANOMALY_05000353 (ANOMALY_BF526) /* Regulator Programming Blocked when Hibernate Wakeup Source Remains Active */ -#define ANOMALY_05000355 (1) +#define ANOMALY_05000355 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) /* Serial Port (SPORT) Multichannel Transmit Failure when Channel 0 Is Disabled */ -#define ANOMALY_05000357 (1) +#define ANOMALY_05000357 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) /* Incorrect Revision Number in DSPID Register */ -#define ANOMALY_05000364 (__SILICON_REVISION__ > 0) +#define ANOMALY_05000364 (ANOMALY_BF527 && __SILICON_REVISION__ == 1) /* PPI Underflow Error Goes Undetected in ITU-R 656 Mode */ #define ANOMALY_05000366 (1) -/* New Feature: Higher Default CCLK Rate */ -#define ANOMALY_05000368 (1) +/* Incorrect Default CSEL Value in PLL_DIV */ +#define ANOMALY_05000368 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) /* Possible RETS Register Corruption when Subroutine Is under 5 Cycles in Duration */ -#define ANOMALY_05000371 (1) +#define ANOMALY_05000371 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) /* Authentication Fails To Initiate */ -#define ANOMALY_05000376 (__SILICON_REVISION__ > 0) +#define ANOMALY_05000376 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) /* Data Read From L3 Memory by USB DMA May be Corrupted */ -#define ANOMALY_05000380 (1) -/* USB Full-speed Mode not Fully Tested */ -#define ANOMALY_05000381 (1) -/* New Feature: Boot from OTP Memory */ -#define ANOMALY_05000385 (1) -/* New Feature: bfrom_SysControl() Routine */ -#define ANOMALY_05000386 (1) -/* New Feature: Programmable Preboot Settings */ -#define ANOMALY_05000387 (1) +#define ANOMALY_05000380 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +/* 8-Bit NAND Flash Boot Mode Not Functional */ +#define ANOMALY_05000382 (__SILICON_REVISION__ < 2) +/* Host Must Not Read Back During Host DMA Boot */ +#define ANOMALY_05000384 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +/* Boot from OTP Memory Not Functional */ +#define ANOMALY_05000385 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +/* bfrom_SysControl() Firmware Routine Not Functional */ +#define ANOMALY_05000386 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +/* Programmable Preboot Settings Not Functional */ +#define ANOMALY_05000387 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +/* CRC32 Checksum Support Not Functional */ +#define ANOMALY_05000388 (__SILICON_REVISION__ < 2) /* Reset Vector Must Not Be in SDRAM Memory Space */ -#define ANOMALY_05000389 (1) -/* New Feature: pTempCurrent Added to ADI_BOOT_DATA Structure */ -#define ANOMALY_05000392 (1) -/* New Feature: dTempByteCount Value Increased in ADI_BOOT_DATA Structure */ -#define ANOMALY_05000393 (1) -/* New Feature: Log Buffer Functionality */ -#define ANOMALY_05000394 (1) -/* New Feature: Hook Routine Functionality */ -#define ANOMALY_05000395 (1) -/* New Feature: Header Indirect Bit */ -#define ANOMALY_05000396 (1) -/* New Feature: BK_ONES, BK_ZEROS, and BK_DATECODE Constants */ -#define ANOMALY_05000397 (1) -/* New Feature: SWRESET, DFRESET and WDRESET Bits Added to SYSCR Register */ -#define ANOMALY_05000398 (1) -/* New Feature: BCODE_NOBOOT Added to BCODE Field of SYSCR Register */ -#define ANOMALY_05000399 (1) +#define ANOMALY_05000389 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +/* pTempCurrent Not Present in ADI_BOOT_DATA Structure */ +#define ANOMALY_05000392 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +/* Deprecated Value of dTempByteCount in ADI_BOOT_DATA Structure */ +#define ANOMALY_05000393 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +/* Log Buffer Not Functional */ +#define ANOMALY_05000394 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +/* Hook Routine Not Functional */ +#define ANOMALY_05000395 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +/* Header Indirect Bit Not Functional */ +#define ANOMALY_05000396 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +/* BK_ONES, BK_ZEROS, and BK_DATECODE Constants Not Functional */ +#define ANOMALY_05000397 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +/* SWRESET, DFRESET and WDRESET Bits in the SYSCR Register Not Functional */ +#define ANOMALY_05000398 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +/* BCODE_NOBOOT in BCODE Field of SYSCR Register Not Functional */ +#define ANOMALY_05000399 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) /* PPI Data Signals D0 and D8 do not Tristate After Disabling PPI */ -#define ANOMALY_05000401 (1) +#define ANOMALY_05000401 (__SILICON_REVISION__ < 2) +/* Level-Sensitive External GPIO Wakeups May Cause Indefinite Stall */ +#define ANOMALY_05000403 (__SILICON_REVISION__ < 2) +/* Lockbox SESR Disallows Certain User Interrupts */ +#define ANOMALY_05000404 (__SILICON_REVISION__ < 2) +/* Lockbox SESR Firmware Does Not Save/Restore Full Context */ +#define ANOMALY_05000405 (1) +/* Lockbox SESR Firmware Arguments Are Not Retained After First Initialization */ +#define ANOMALY_05000407 (__SILICON_REVISION__ < 2) +/* Lockbox Firmware Memory Cleanup Routine Does not Clear Registers */ +#define ANOMALY_05000408 (1) +/* Lockbox firmware leaves MDMA0 channel enabled */ +#define ANOMALY_05000409 (__SILICON_REVISION__ < 2) +/* Incorrect Default Internal Voltage Regulator Setting */ +#define ANOMALY_05000410 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +/* bfrom_SysControl() Firmware Function Cannot be Used to Enter Power Saving Modes */ +#define ANOMALY_05000411 (__SILICON_REVISION__ < 2) +/* OTP_CHECK_FOR_PREV_WRITE Bit is Not Functional in bfrom_OtpWrite() API */ +#define ANOMALY_05000414 (__SILICON_REVISION__ < 2) +/* DEB2_URGENT Bit Not Functional */ +#define ANOMALY_05000415 (__SILICON_REVISION__ < 2) +/* Speculative Fetches Can Cause Undesired External FIFO Operations */ +#define ANOMALY_05000416 (1) +/* SPORT0 Ignores External TSCLK0 on PG14 When TMR6 is an Output */ +#define ANOMALY_05000417 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +/* tSFSPE and tHFSPE Do Not Meet Data Sheet Specifications */ +#define ANOMALY_05000418 (__SILICON_REVISION__ < 2) +/* USB PLL_STABLE Bit May Not Accurately Reflect the USB PLL's Status */ +#define ANOMALY_05000420 (__SILICON_REVISION__ < 2) +/* TWI Fall Time (Tof) May Violate the Minimum I2C Specification */ +#define ANOMALY_05000421 (1) +/* TWI Input Capacitance (Ci) May Violate the Maximum I2C Specification */ +#define ANOMALY_05000422 (ANOMALY_BF527 && __SILICON_REVISION__ > 1) +/* Certain Ethernet Frames With Errors are Misclassified in RMII Mode */ +#define ANOMALY_05000423 (__SILICON_REVISION__ < 2) +/* Internal Voltage Regulator Not Trimmed */ +#define ANOMALY_05000424 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +/* Multichannel SPORT Channel Misalignment Under Specific Configuration */ +#define ANOMALY_05000425 (__SILICON_REVISION__ < 2) +/* Speculative Fetches of Indirect-Pointer Instructions Can Cause Spurious Hardware Errors */ +#define ANOMALY_05000426 (1) +/* WB_EDGE Bit in NFC_IRQSTAT Incorrectly Reflects Buffer Status Instead of IRQ Status */ +#define ANOMALY_05000429 (__SILICON_REVISION__ < 2) +/* Software System Reset Corrupts PLL_LOCKCNT Register */ +#define ANOMALY_05000430 (ANOMALY_BF527 && __SILICON_REVISION__ > 1) +/* bfrom_SysControl() Does Not Clear SIC_IWR1 Before Executing PLL Programming Sequence */ +#define ANOMALY_05000432 (ANOMALY_BF526) +/* Certain SIC Registers are not Reset After Soft or Core Double Fault Reset */ +#define ANOMALY_05000435 ((ANOMALY_BF526 && __SILICON_REVISION__ < 1) || ANOMALY_BF527) +/* IFLUSH Instruction at End of Hardware Loop Causes Infinite Stall */ +#define ANOMALY_05000443 (1)
/* Anomalies that don't exist on this proc */ #define ANOMALY_05000125 (0) @@ -95,10 +167,12 @@ #define ANOMALY_05000263 (0) #define ANOMALY_05000266 (0) #define ANOMALY_05000273 (0) +#define ANOMALY_05000285 (0) #define ANOMALY_05000307 (0) #define ANOMALY_05000311 (0) +#define ANOMALY_05000312 (0) #define ANOMALY_05000323 (0) -#define ANOMALY_05000353 (1) #define ANOMALY_05000363 (0) +#define ANOMALY_05000412 (0)
#endif diff --git a/include/asm-blackfin/mach-bf533/anomaly.h b/include/asm-blackfin/mach-bf533/anomaly.h index 7c34c38..0d3a034 100644 --- a/include/asm-blackfin/mach-bf533/anomaly.h +++ b/include/asm-blackfin/mach-bf533/anomaly.h @@ -7,7 +7,7 @@ */
/* This file shoule be up to date with: - * - Revision C, 02/08/2008; ADSP-BF531/BF532/BF533 Blackfin Processor Anomaly List + * - Revision E, 09/18/2008; ADSP-BF531/BF532/BF533 Blackfin Processor Anomaly List */
#ifndef _MACH_ANOMALY_H_ @@ -97,11 +97,11 @@ /* UART STB Bit Incorrectly Affects Receiver Setting */ #define ANOMALY_05000231 (__SILICON_REVISION__ < 5) /* PPI_FS3 Is Not Driven in 2 or 3 Internal Frame Sync Transmit Modes */ -#define ANOMALY_05000233 (__SILICON_REVISION__ < 4) +#define ANOMALY_05000233 (__SILICON_REVISION__ < 6) /* Incorrect Revision Number in DSPID Register */ #define ANOMALY_05000234 (__SILICON_REVISION__ == 4) /* DF Bit in PLL_CTL Register Does Not Respond to Hardware Reset */ -#define ANOMALY_05000242 (__SILICON_REVISION__ < 4) +#define ANOMALY_05000242 (__SILICON_REVISION__ < 5) /* If I-Cache Is On, CSYNC/SSYNC/IDLE Around Change of Control Causes Failures */ #define ANOMALY_05000244 (__SILICON_REVISION__ < 5) /* Spurious Hardware Error from an Access in the Shadow of a Conditional Branch */ @@ -131,7 +131,7 @@ /* CSYNC/SSYNC/IDLE Causes Infinite Stall in Penultimate Instruction in Hardware Loop */ #define ANOMALY_05000264 (__SILICON_REVISION__ < 5) /* Sensitivity To Noise with Slow Input Edge Rates on External SPORT TX and RX Clocks */ -#define ANOMALY_05000265 (__SILICON_REVISION__ < 5) +#define ANOMALY_05000265 (1) /* High I/O Activity Causes Output Voltage of Internal Voltage Regulator (Vddint) to Increase */ #define ANOMALY_05000269 (__SILICON_REVISION__ < 5) /* High I/O Activity Causes Output Voltage of Internal Voltage Regulator (Vddint) to Decrease */ @@ -141,23 +141,23 @@ /* Certain Data Cache Writethrough Modes Fail for Vddint <= 0.9V */ #define ANOMALY_05000272 (1) /* Writes to Synchronous SDRAM Memory May Be Lost */ -#define ANOMALY_05000273 (1) +#define ANOMALY_05000273 (__SILICON_REVISION__ < 6) /* Timing Requirements Change for External Frame Sync PPI Modes with Non-Zero PPI_DELAY */ #define ANOMALY_05000276 (1) /* Writes to an I/O Data Register One SCLK Cycle after an Edge Is Detected May Clear Interrupt */ -#define ANOMALY_05000277 (1) +#define ANOMALY_05000277 (__SILICON_REVISION__ < 6) /* Disabling Peripherals with DMA Running May Cause DMA System Instability */ -#define ANOMALY_05000278 (1) +#define ANOMALY_05000278 (__SILICON_REVISION__ < 6) /* False Hardware Error Exception When ISR Context Is Not Restored */ -#define ANOMALY_05000281 (1) +#define ANOMALY_05000281 (__SILICON_REVISION__ < 6) /* Memory DMA Corruption with 32-Bit Data and Traffic Control */ -#define ANOMALY_05000282 (1) +#define ANOMALY_05000282 (__SILICON_REVISION__ < 6) /* System MMR Write Is Stalled Indefinitely When Killed in a Particular Stage */ -#define ANOMALY_05000283 (1) +#define ANOMALY_05000283 (__SILICON_REVISION__ < 6) /* SPORTs May Receive Bad Data If FIFOs Fill Up */ -#define ANOMALY_05000288 (1) +#define ANOMALY_05000288 (__SILICON_REVISION__ < 6) /* Memory-To-Memory DMA Source/Destination Descriptors Must Be in Same Memory Space */ -#define ANOMALY_05000301 (1) +#define ANOMALY_05000301 (__SILICON_REVISION__ < 6) /* SSYNCs After Writes To DMA MMR Registers May Not Be Handled Correctly */ #define ANOMALY_05000302 (__SILICON_REVISION__ < 5) /* New Feature: Additional Hysteresis on SPORT Input Pins (Not Available On Older Silicon) */ @@ -169,30 +169,37 @@ /* False Hardware Errors Caused by Fetches at the Boundary of Reserved Memory */ #define ANOMALY_05000310 (1) /* Erroneous Flag (GPIO) Pin Operations under Specific Sequences */ -#define ANOMALY_05000311 (1) +#define ANOMALY_05000311 (__SILICON_REVISION__ < 6) /* Errors When SSYNC, CSYNC, or Loads to LT, LB and LC Registers Are Interrupted */ -#define ANOMALY_05000312 (1) +#define ANOMALY_05000312 (__SILICON_REVISION__ < 6) /* PPI Is Level-Sensitive on First Transfer */ -#define ANOMALY_05000313 (1) +#define ANOMALY_05000313 (__SILICON_REVISION__ < 6) /* Killed System MMR Write Completes Erroneously On Next System MMR Access */ -#define ANOMALY_05000315 (1) +#define ANOMALY_05000315 (__SILICON_REVISION__ < 6) /* Internal Voltage Regulator Values of 1.05V, 1.10V and 1.15V Not Allowed for LQFP Packages */ -#define ANOMALY_05000319 (ANOMALY_BF531 || ANOMALY_BF532) +#define ANOMALY_05000319 ((ANOMALY_BF531 || ANOMALY_BF532) && __SILICON_REVISION__ < 6) /* Serial Port (SPORT) Multichannel Transmit Failure when Channel 0 Is Disabled */ -#define ANOMALY_05000357 (1) +#define ANOMALY_05000357 (__SILICON_REVISION__ < 6) /* UART Break Signal Issues */ #define ANOMALY_05000363 (__SILICON_REVISION__ < 5) /* PPI Underflow Error Goes Undetected in ITU-R 656 Mode */ #define ANOMALY_05000366 (1) /* Possible RETS Register Corruption when Subroutine Is under 5 Cycles in Duration */ -#define ANOMALY_05000371 (1) +#define ANOMALY_05000371 (__SILICON_REVISION__ < 6) /* PPI Does Not Start Properly In Specific Mode */ -#define ANOMALY_05000400 (__SILICON_REVISION__ >= 5) +#define ANOMALY_05000400 (__SILICON_REVISION__ == 5) /* SSYNC Stalls Processor when Executed from Non-Cacheable Memory */ -#define ANOMALY_05000402 (__SILICON_REVISION__ >= 5) +#define ANOMALY_05000402 (__SILICON_REVISION__ == 5) /* Level-Sensitive External GPIO Wakeups May Cause Indefinite Stall */ #define ANOMALY_05000403 (1) - +/* Speculative Fetches Can Cause Undesired External FIFO Operations */ +#define ANOMALY_05000416 (1) +/* Multichannel SPORT Channel Misalignment Under Specific Configuration */ +#define ANOMALY_05000425 (1) +/* Speculative Fetches of Indirect-Pointer Instructions Can Cause False Hardware Errors */ +#define ANOMALY_05000426 (1) +/* IFLUSH Instruction at End of Hardware Loop Causes Infinite Stall */ +#define ANOMALY_05000443 (1)
/* These anomalies have been "phased" out of analog.com anomaly sheets and are * here to show running on older silicon just isn't feasible. @@ -271,5 +278,9 @@ #define ANOMALY_05000266 (0) #define ANOMALY_05000323 (0) #define ANOMALY_05000353 (1) +#define ANOMALY_05000386 (1) +#define ANOMALY_05000412 (0) +#define ANOMALY_05000432 (0) +#define ANOMALY_05000435 (0)
#endif diff --git a/include/asm-blackfin/mach-bf537/anomaly.h b/include/asm-blackfin/mach-bf537/anomaly.h index 8d7f305..9cb3912 100644 --- a/include/asm-blackfin/mach-bf537/anomaly.h +++ b/include/asm-blackfin/mach-bf537/anomaly.h @@ -7,7 +7,7 @@ */
/* This file shoule be up to date with: - * - Revision C, 02/08/2008; ADSP-BF534/ADSP-BF536/ADSP-BF537 Blackfin Processor Anomaly List + * - Revision D, 09/18/2008; ADSP-BF534/ADSP-BF536/ADSP-BF537 Blackfin Processor Anomaly List */
#ifndef _MACH_ANOMALY_H_ @@ -148,6 +148,14 @@ #define ANOMALY_05000402 (__SILICON_REVISION__ >= 5) /* Level-Sensitive External GPIO Wakeups May Cause Indefinite Stall */ #define ANOMALY_05000403 (1) +/* Speculative Fetches Can Cause Undesired External FIFO Operations */ +#define ANOMALY_05000416 (1) +/* Multichannel SPORT Channel Misalignment Under Specific Configuration */ +#define ANOMALY_05000425 (1) +/* Speculative Fetches of Indirect-Pointer Instructions Can Cause False Hardware Errors */ +#define ANOMALY_05000426 (1) +/* IFLUSH Instruction at End of Hardware Loop Causes Infinite Stall */ +#define ANOMALY_05000443 (1)
/* Anomalies that don't exist on this proc */ #define ANOMALY_05000125 (0) @@ -160,5 +168,9 @@ #define ANOMALY_05000323 (0) #define ANOMALY_05000353 (1) #define ANOMALY_05000363 (0) +#define ANOMALY_05000386 (1) +#define ANOMALY_05000412 (0) +#define ANOMALY_05000432 (0) +#define ANOMALY_05000435 (0)
#endif diff --git a/include/asm-blackfin/mach-bf548/anomaly.h b/include/asm-blackfin/mach-bf548/anomaly.h index 1dc75ef..3b54309 100644 --- a/include/asm-blackfin/mach-bf548/anomaly.h +++ b/include/asm-blackfin/mach-bf548/anomaly.h @@ -7,7 +7,7 @@ */
/* This file shoule be up to date with: - * - Revision F, 06/11/2008; ADSP-BF542/BF544/BF547/BF548/BF549 Blackfin Processor Anomaly List + * - Revision G, 08/07/2008; ADSP-BF542/BF544/BF547/BF548/BF549 Blackfin Processor Anomaly List */
#ifndef _MACH_ANOMALY_H_ @@ -36,7 +36,7 @@ /* TWI Slave Boot Mode Is Not Functional */ #define ANOMALY_05000324 (__SILICON_REVISION__ < 1) /* External FIFO Boot Mode Is Not Functional */ -#define ANOMALY_05000325 (__SILICON_REVISION__ < 1) +#define ANOMALY_05000325 (__SILICON_REVISION__ < 2) /* Data Lost When Core and DMA Accesses Are Made to the USB FIFO Simultaneously */ #define ANOMALY_05000327 (__SILICON_REVISION__ < 1) /* Incorrect Access of OTP_STATUS During otp_write() Function */ @@ -61,6 +61,8 @@ #define ANOMALY_05000344 (__SILICON_REVISION__ < 1) /* USB Calibration Value Is Not Intialized */ #define ANOMALY_05000346 (__SILICON_REVISION__ < 1) +/* USB Calibration Value to use */ +#define ANOMALY_05000346_value 0x5411 /* Preboot Routine Incorrectly Alters Reset Value of USB Register */ #define ANOMALY_05000347 (__SILICON_REVISION__ < 1) /* Data Lost when Core Reads SDH Data FIFO */ @@ -68,7 +70,7 @@ /* PLL Status Register Is Inaccurate */ #define ANOMALY_05000351 (__SILICON_REVISION__ < 1) /* bfrom_SysControl() Firmware Function Performs Improper System Reset */ -#define ANOMALY_05000353 (1) +#define ANOMALY_05000353 (__SILICON_REVISION__ < 2) /* Regulator Programming Blocked when Hibernate Wakeup Source Remains Active */ #define ANOMALY_05000355 (__SILICON_REVISION__ < 1) /* System Stalled During A Core Access To AMC While A Core Access To NFC FIFO Is Required */ @@ -86,13 +88,13 @@ /* Default PLL MSEL and SSEL Settings Can Cause 400MHz Product To Violate Specifications */ #define ANOMALY_05000370 (__SILICON_REVISION__ < 1) /* Possible RETS Register Corruption when Subroutine Is under 5 Cycles in Duration */ -#define ANOMALY_05000371 (1) +#define ANOMALY_05000371 (__SILICON_REVISION__ < 2) /* USB DP/DM Data Pins May Lose State When Entering Hibernate */ #define ANOMALY_05000372 (__SILICON_REVISION__ < 1) /* Mobile DDR Operation Not Functional */ #define ANOMALY_05000377 (1) /* Security/Authentication Speedpath Causes Authentication To Fail To Initiate */ -#define ANOMALY_05000378 (1) +#define ANOMALY_05000378 (__SILICON_REVISION__ < 2) /* 16-Bit NAND FLASH Boot Mode Is Not Functional */ #define ANOMALY_05000379 (1) /* 8-Bit NAND Flash Boot Mode Not Functional */ @@ -126,25 +128,37 @@ /* BK_ONES, BK_ZEROS, and BK_DATECODE Constants Not Functional */ #define ANOMALY_05000397 (__SILICON_REVISION__ < 1) /* Lockbox SESR Disallows Certain User Interrupts */ -#define ANOMALY_05000404 (1) +#define ANOMALY_05000404 (__SILICON_REVISION__ < 2) /* Lockbox SESR Firmware Does Not Save/Restore Full Context */ #define ANOMALY_05000405 (1) /* Lockbox SESR Argument Checking Does Not Check L2 Memory Protection Range */ -#define ANOMALY_05000406 (1) +#define ANOMALY_05000406 (__SILICON_REVISION__ < 2) /* Lockbox SESR Firmware Arguments Are Not Retained After First Initialization */ -#define ANOMALY_05000407 (1) +#define ANOMALY_05000407 (__SILICON_REVISION__ < 2) /* Lockbox Firmware Memory Cleanup Routine Does not Clear Registers */ #define ANOMALY_05000408 (1) /* Lockbox firmware leaves MDMA0 channel enabled */ -#define ANOMALY_05000409 (1) +#define ANOMALY_05000409 (__SILICON_REVISION__ < 2) /* bfrom_SysControl() Firmware Function Cannot be Used to Enter Power Saving Modes */ -#define ANOMALY_05000411 (1) -/* FIFO Boot Mode Is Not Functional */ -#define ANOMALY_05000412 (1) +#define ANOMALY_05000411 (__SILICON_REVISION__ < 2) /* NAND Boot Mode Not Compatible With Some NAND Flash Devices */ -#define ANOMALY_05000413 (1) +#define ANOMALY_05000413 (__SILICON_REVISION__ < 2) /* OTP_CHECK_FOR_PREV_WRITE Bit is Not Functional in bfrom_OtpWrite() API */ -#define ANOMALY_05000414 (1) +#define ANOMALY_05000414 (__SILICON_REVISION__ < 2) +/* Speculative Fetches Can Cause Undesired External FIFO Operations */ +#define ANOMALY_05000416 (1) +/* Multichannel SPORT Channel Misalignment Under Specific Configuration */ +#define ANOMALY_05000425 (1) +/* Speculative Fetches of Indirect-Pointer Instructions Can Cause Spurious Hardware Errors */ +#define ANOMALY_05000426 (1) +/* CORE_EPPI_PRIO bit and SYS_EPPI_PRIO bit in the HMDMA1_CONTROL register are not functional */ +#define ANOMALY_05000427 (__SILICON_REVISION__ < 2) +/* WB_EDGE Bit in NFC_IRQSTAT Incorrectly Behaves as a Buffer Status Bit Instead of an IRQ Status Bit */ +#define ANOMALY_05000429 (__SILICON_REVISION__ < 2) +/* Software System Reset Corrupts PLL_LOCKCNT Register */ +#define ANOMALY_05000430 (__SILICON_REVISION__ >= 2) +/* IFLUSH Instruction at End of Hardware Loop Causes Infinite Stall */ +#define ANOMALY_05000443 (1)
/* Anomalies that don't exist on this proc */ #define ANOMALY_05000125 (0) @@ -161,5 +175,8 @@ #define ANOMALY_05000311 (0) #define ANOMALY_05000323 (0) #define ANOMALY_05000363 (0) +#define ANOMALY_05000412 (0) +#define ANOMALY_05000432 (0) +#define ANOMALY_05000435 (0)
#endif diff --git a/include/asm-blackfin/mach-bf561/anomaly.h b/include/asm-blackfin/mach-bf561/anomaly.h index e9c4ca8..1a9e175 100644 --- a/include/asm-blackfin/mach-bf561/anomaly.h +++ b/include/asm-blackfin/mach-bf561/anomaly.h @@ -7,7 +7,7 @@ */
/* This file shoule be up to date with: - * - Revision P, 02/08/2008; ADSP-BF561 Blackfin Processor Anomaly List + * - Revision Q, 11/07/2008; ADSP-BF561 Blackfin Processor Anomaly List */
#ifndef _MACH_ANOMALY_H_ @@ -264,6 +264,18 @@ #define ANOMALY_05000371 (1) /* Level-Sensitive External GPIO Wakeups May Cause Indefinite Stall */ #define ANOMALY_05000403 (1) +/* TESTSET Instruction Causes Data Corruption with Writeback Data Cache Enabled */ +#define ANOMALY_05000412 (1) +/* Speculative Fetches Can Cause Undesired External FIFO Operations */ +#define ANOMALY_05000416 (1) +/* Multichannel SPORT Channel Misalignment Under Specific Configuration */ +#define ANOMALY_05000425 (1) +/* Speculative Fetches of Indirect-Pointer Instructions Can Cause False Hardware Errors */ +#define ANOMALY_05000426 (1) +/* Lost/Corrupted L2/L3 Memory Write after Speculative L2 Memory Read by Core B */ +#define ANOMALY_05000428 (__SILICON_REVISION__ > 3) +/* IFLUSH Instruction at End of Hardware Loop Causes Infinite Stall */ +#define ANOMALY_05000443 (1)
/* Anomalies that don't exist on this proc */ #define ANOMALY_05000158 (0) @@ -271,5 +283,8 @@ #define ANOMALY_05000273 (0) #define ANOMALY_05000311 (0) #define ANOMALY_05000353 (1) +#define ANOMALY_05000386 (1) +#define ANOMALY_05000432 (0) +#define ANOMALY_05000435 (0)
#endif
Newer Blackfin's have an on-chip rom with a syscontrol() function that needs to be used to properly program the memory and voltage settings as it will include (possibly critical) factory tested bias values.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- cpu/blackfin/initcode.c | 58 ++++++++++++++++++++++++++++++----------------- 1 files changed, 37 insertions(+), 21 deletions(-)
diff --git a/cpu/blackfin/initcode.c b/cpu/blackfin/initcode.c index 6091f8c..b2c8238 100644 --- a/cpu/blackfin/initcode.c +++ b/cpu/blackfin/initcode.c @@ -267,34 +267,50 @@ void initcode(ADI_BOOT_DATA *bootstruct) bfin_write_SIC_IWR(1); #endif
- serial_putc('L'); + /* With newer bootroms, we use the helper function to set up + * the memory controller. Older bootroms lacks such helpers + * so we do it ourselves. + */ + if (BOOTROM_CAPS_SYSCONTROL) { + serial_putc('S');
- bfin_write_PLL_LOCKCNT(CONFIG_PLL_LOCKCNT_VAL); + ADI_SYSCTRL_VALUES memory_settings; + memory_settings.uwVrCtl = CONFIG_VR_CTL_VAL; + memory_settings.uwPllCtl = CONFIG_PLL_CTL_VAL; + memory_settings.uwPllDiv = CONFIG_PLL_DIV_VAL; + memory_settings.uwPllLockCnt = CONFIG_PLL_LOCKCNT_VAL; + syscontrol(SYSCTRL_WRITE | SYSCTRL_VRCTL | SYSCTRL_PLLCTL | SYSCTRL_PLLDIV | SYSCTRL_LOCKCNT | + (CONFIG_VR_CTL_VAL & FREQ_MASK ? SYSCTRL_INTVOLTAGE : SYSCTRL_EXTVOLTAGE), &memory_settings, NULL); + } else { + serial_putc('L');
- serial_putc('A'); + bfin_write_PLL_LOCKCNT(CONFIG_PLL_LOCKCNT_VAL);
- /* Only reprogram when needed to avoid triggering unnecessary - * PLL relock sequences. - */ - if (bfin_read_VR_CTL() != CONFIG_VR_CTL_VAL) { - serial_putc('!'); - bfin_write_VR_CTL(CONFIG_VR_CTL_VAL); - asm("idle;"); - } + serial_putc('A');
- serial_putc('C'); + /* Only reprogram when needed to avoid triggering unnecessary + * PLL relock sequences. + */ + if (bfin_read_VR_CTL() != CONFIG_VR_CTL_VAL) { + serial_putc('!'); + bfin_write_VR_CTL(CONFIG_VR_CTL_VAL); + asm("idle;"); + }
- bfin_write_PLL_DIV(CONFIG_PLL_DIV_VAL); + serial_putc('C');
- serial_putc('K'); + bfin_write_PLL_DIV(CONFIG_PLL_DIV_VAL);
- /* Only reprogram when needed to avoid triggering unnecessary - * PLL relock sequences. - */ - if (bfin_read_PLL_CTL() != CONFIG_PLL_CTL_VAL) { - serial_putc('!'); - bfin_write_PLL_CTL(CONFIG_PLL_CTL_VAL); - asm("idle;"); + serial_putc('K'); + + /* Only reprogram when needed to avoid triggering unnecessary + * PLL relock sequences. + */ + if (bfin_read_PLL_CTL() != CONFIG_PLL_CTL_VAL) { + serial_putc('!'); + bfin_write_PLL_CTL(CONFIG_PLL_CTL_VAL); + asm("idle;"); + } }
/* Since we've changed the SCLK above, we may need to update
Signed-off-by: Mike Frysinger vapier@gentoo.org --- cpu/blackfin/initcode.c | 3 +++ 1 files changed, 3 insertions(+), 0 deletions(-)
diff --git a/cpu/blackfin/initcode.c b/cpu/blackfin/initcode.c index b2c8238..ffa5f61 100644 --- a/cpu/blackfin/initcode.c +++ b/cpu/blackfin/initcode.c @@ -199,6 +199,9 @@ static inline void serial_putc(char c) # elif defined(__ADSPBF54x__) /* TBD; use default */ # undef CONFIG_VR_CTL_VLEV # define CONFIG_VR_CTL_VLEV VLEV_120 +# elif defined(__ADSPBF538__) || defined(__ADSPBF539__) /* TBD; use default */ +# undef CONFIG_VR_CTL_VLEV +# define CONFIG_VR_CTL_VLEV VLEV_125 # endif
# ifdef CONFIG_BFIN_MAC
Some bits of the DDR MMRs should not be set. If they do, bad things may happen (like random failures or hardware destruction).
Signed-off-by: Mike Frysinger vapier@gentoo.org --- cpu/blackfin/initcode.c | 7 +++++++ 1 files changed, 7 insertions(+), 0 deletions(-)
diff --git a/cpu/blackfin/initcode.c b/cpu/blackfin/initcode.c index ffa5f61..a6e95f4 100644 --- a/cpu/blackfin/initcode.c +++ b/cpu/blackfin/initcode.c @@ -168,11 +168,18 @@ static inline void serial_putc(char c) #ifndef CONFIG_EBIU_RSTCTL_VAL # define CONFIG_EBIU_RSTCTL_VAL 0 /* only MDDRENABLE is useful */ #endif +#if ((CONFIG_EBIU_RSTCTL_VAL & 0xFFFFFFC4) != 0) +# error invalid EBIU_RSTCTL value: must not set reserved bits +#endif
#ifndef CONFIG_EBIU_MBSCTL_VAL # define CONFIG_EBIU_MBSCTL_VAL 0 #endif
+#if defined(CONFIG_EBIU_DDRQUE_VAL) && ((CONFIG_EBIU_DDRQUE_VAL & 0xFFFF8000) != 0) +# error invalid EBIU_DDRQUE value: must not set reserved bits +#endif + /* Make sure our voltage value is sane so we don't blow up! */ #ifndef CONFIG_VR_CTL_VAL # define BFIN_CCLK ((CONFIG_CLKIN_HZ * CONFIG_VCO_MULT) / CONFIG_CCLK_DIV)
Newer Blackfin boot roms support using the fast SPI read command rather than just the slow one. If the functionality is available, then use it.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- cpu/blackfin/initcode.c | 25 +++++++++++++++++-------- 1 files changed, 17 insertions(+), 8 deletions(-)
diff --git a/cpu/blackfin/initcode.c b/cpu/blackfin/initcode.c index a6e95f4..0fdaf40 100644 --- a/cpu/blackfin/initcode.c +++ b/cpu/blackfin/initcode.c @@ -133,12 +133,22 @@ static inline void serial_putc(char c) }
-/* Max SCLK can be 133MHz ... dividing that by 4 gives - * us a freq of 33MHz for SPI which should generally be +/* Max SCLK can be 133MHz ... dividing that by (2*4) gives + * us a freq of 16MHz for SPI which should generally be * slow enough for the slow reads the bootrom uses. */ +#if !defined(CONFIG_SPI_FLASH_SLOW_READ) && \ + ((defined(__ADSPBF52x__) && __SILICON_REVISION__ >= 2) || \ + (defined(__ADSPBF54x__) && __SILICON_REVISION__ >= 1)) +# define BOOTROM_SUPPORTS_SPI_FAST_READ 1 +#else +# define BOOTROM_SUPPORTS_SPI_FAST_READ 0 +#endif #ifndef CONFIG_SPI_BAUD_INITBLOCK -# define CONFIG_SPI_BAUD_INITBLOCK 4 +# define CONFIG_SPI_BAUD_INITBLOCK (BOOTROM_SUPPORTS_SPI_FAST_READ ? 2 : 4) +#endif +#ifdef SPI0_BAUD +# define bfin_write_SPI_BAUD bfin_write_SPI0_BAUD #endif
/* PLL_DIV defines */ @@ -254,12 +264,11 @@ void initcode(ADI_BOOT_DATA *bootstruct) * boot. Once we switch over to u-boot's SPI flash driver, we'll * increase the speed appropriately. */ - if (CONFIG_BFIN_BOOT_MODE == BFIN_BOOT_SPI_MASTER) -#ifdef SPI0_BAUD - bfin_write_SPI0_BAUD(CONFIG_SPI_BAUD_INITBLOCK); -#else + if (CONFIG_BFIN_BOOT_MODE == BFIN_BOOT_SPI_MASTER) { + if (BOOTROM_SUPPORTS_SPI_FAST_READ && CONFIG_SPI_BAUD_INITBLOCK < 4) + bootstruct->dFlags |= BFLAG_FASTREAD; bfin_write_SPI_BAUD(CONFIG_SPI_BAUD_INITBLOCK); -#endif + }
serial_putc('B');
Previously, booting over the UART required the baud rate to be known ahead of time. Using a bit of tricky simple math, we can calculate the new board rate based on the old divisors.
Signed-off-by: Mike Frysinger vapier@gentoo.org Signed-off-by: Robin Getz rgetz@blackfin.uclinux.org --- cpu/blackfin/initcode.c | 62 +++++++++++++++------------------------ cpu/blackfin/serial.h | 72 ++++++++++++---------------------------------- 2 files changed, 43 insertions(+), 91 deletions(-)
diff --git a/cpu/blackfin/initcode.c b/cpu/blackfin/initcode.c index 0fdaf40..60a0554 100644 --- a/cpu/blackfin/initcode.c +++ b/cpu/blackfin/initcode.c @@ -20,7 +20,7 @@ #include "serial.h"
__attribute__((always_inline)) -static inline uint32_t serial_init(void) +static inline void serial_init(void) { #ifdef __ADSPBF54x__ # ifdef BFIN_BOOT_UART_USE_RTS @@ -61,25 +61,16 @@ static inline uint32_t serial_init(void) } #endif
- uint32_t old_baud; - if (BFIN_DEBUG_EARLY_SERIAL || CONFIG_BFIN_BOOT_MODE == BFIN_BOOT_UART) - old_baud = serial_early_get_baud(); - else - old_baud = CONFIG_BAUDRATE; - if (BFIN_DEBUG_EARLY_SERIAL) { + int ucen = *pUART_GCTL & UCEN; serial_early_init();
/* If the UART is off, that means we need to program * the baud rate ourselves initially. */ - if (!old_baud) { - old_baud = CONFIG_BAUDRATE; + if (ucen != UCEN) serial_early_set_baud(CONFIG_BAUDRATE); - } } - - return old_baud; }
__attribute__((always_inline)) @@ -93,30 +84,6 @@ static inline void serial_deinit(void) #endif }
-/* We need to reset the baud rate when we have early debug turned on - * or when we are booting over the UART. - * XXX: we should fix this to calc the old baud and restore it rather - * than hardcoding it via CONFIG_LDR_LOAD_BAUD ... but we have - * to figure out how to avoid the division in the baud calc ... - */ -__attribute__((always_inline)) -static inline void serial_reset_baud(uint32_t baud) -{ - if (!BFIN_DEBUG_EARLY_SERIAL && CONFIG_BFIN_BOOT_MODE != BFIN_BOOT_UART) - return; - -#ifndef CONFIG_LDR_LOAD_BAUD -# define CONFIG_LDR_LOAD_BAUD 115200 -#endif - - if (CONFIG_BFIN_BOOT_MODE == BFIN_BOOT_BYPASS) - serial_early_set_baud(baud); - else if (CONFIG_BFIN_BOOT_MODE == BFIN_BOOT_UART) - serial_early_set_baud(CONFIG_LDR_LOAD_BAUD); - else - serial_early_set_baud(CONFIG_BAUDRATE); -} - __attribute__((always_inline)) static inline void serial_putc(char c) { @@ -239,7 +206,14 @@ static inline void serial_putc(char c) __attribute__((saveall)) void initcode(ADI_BOOT_DATA *bootstruct) { - uint32_t old_baud = serial_init(); + /* Save the clock pieces that are used in baud rate calculation */ + unsigned int sdivB, divB, vcoB; + serial_init(); + if (BFIN_DEBUG_EARLY_SERIAL || CONFIG_BFIN_BOOT_MODE == BFIN_BOOT_UART) { + sdivB = bfin_read_PLL_DIV() & 0xf; + vcoB = (bfin_read_PLL_CTL() >> 9) & 0x3f; + divB = serial_early_get_div(); + }
#ifdef CONFIG_HW_WATCHDOG # ifndef CONFIG_HW_WATCHDOG_TIMEOUT_INITCODE @@ -334,8 +308,20 @@ void initcode(ADI_BOOT_DATA *bootstruct)
/* Since we've changed the SCLK above, we may need to update * the UART divisors (UART baud rates are based on SCLK). + * Do the division by hand as there are no native instructions + * for dividing which means we'd generate a libgcc reference. */ - serial_reset_baud(old_baud); + if (CONFIG_BFIN_BOOT_MODE == BFIN_BOOT_UART) { + unsigned int sdivR, vcoR; + sdivR = bfin_read_PLL_DIV() & 0xf; + vcoR = (bfin_read_PLL_CTL() >> 9) & 0x3f; + int dividend = sdivB * divB * vcoR; + int divisor = vcoB * sdivR; + unsigned int quotient; + for (quotient = 0; dividend > 0; ++quotient) + dividend -= divisor; + serial_early_put_div(quotient - ANOMALY_05000230); + }
serial_putc('F');
diff --git a/cpu/blackfin/serial.h b/cpu/blackfin/serial.h index f671096..ce39148 100644 --- a/cpu/blackfin/serial.h +++ b/cpu/blackfin/serial.h @@ -156,16 +156,25 @@ static inline void serial_early_init(void) }
__attribute__((always_inline)) -static inline uint32_t serial_early_get_baud(void) +static inline void serial_early_put_div(uint16_t divisor) { - /* If the UART isnt enabled, then we are booting an LDR - * from a non-UART source (so like flash) which means - * the baud rate here is meaningless. - */ - if ((*pUART_GCTL & UCEN) != UCEN) - return 0; + /* Set DLAB in LCR to Access DLL and DLH */ + ACCESS_LATCH(); + SSYNC();
-#if (0) /* See comment for serial_reset_baud() in initcode.c */ + /* Program the divisor to get the baud rate we want */ + *pUART_DLL = LOB(divisor); + *pUART_DLH = HIB(divisor); + SSYNC(); + + /* Clear DLAB in LCR to Access THR RBR IER */ + ACCESS_PORT_IER(); + SSYNC(); +} + +__attribute__((always_inline)) +static inline uint16_t serial_early_get_div(void) +{ /* Set DLAB in LCR to Access DLL and DLH */ ACCESS_LATCH(); SSYNC(); @@ -173,16 +182,12 @@ static inline uint32_t serial_early_get_baud(void) uint8_t dll = *pUART_DLL; uint8_t dlh = *pUART_DLH; uint16_t divisor = (dlh << 8) | dll; - uint32_t baud = get_sclk() / (divisor * 16);
/* Clear DLAB in LCR to Access THR RBR IER */ ACCESS_PORT_IER(); SSYNC();
- return baud; -#else - return CONFIG_BAUDRATE; -#endif + return divisor; }
__attribute__((always_inline)) @@ -192,20 +197,7 @@ static inline void serial_early_set_baud(uint32_t baud) * weird multiplication is to make sure we over sample just * a little rather than under sample the incoming signals. */ - uint16_t divisor = (get_sclk() + (baud * 8)) / (baud * 16) - ANOMALY_05000230; - - /* Set DLAB in LCR to Access DLL and DLH */ - ACCESS_LATCH(); - SSYNC(); - - /* Program the divisor to get the baud rate we want */ - *pUART_DLL = LOB(divisor); - *pUART_DLH = HIB(divisor); - SSYNC(); - - /* Clear DLAB in LCR to Access THR RBR IER */ - ACCESS_PORT_IER(); - SSYNC(); + serial_early_put_div((get_sclk() + (baud * 8)) / (baud * 16) - ANOMALY_05000230); }
#ifndef BFIN_IN_INITCODE @@ -235,32 +227,6 @@ static inline void serial_early_puts(const char *s) #endif .endm
-/* Recursively expand calls to _serial_putc for every byte - * passed to us. Append a newline when we're all done. - */ -.macro _serial_early_putc byte:req morebytes:vararg -#ifdef CONFIG_DEBUG_EARLY_SERIAL - R0 = \byte; - call _serial_putc; -.ifnb \morebytes - _serial_early_putc \morebytes -.else -.if (\byte != '\n') - _serial_early_putc '\n' -.endif -.endif -#endif -.endm - -/* Wrapper around recurisve _serial_early_putc macro which - * simply prepends the string "Early: " - */ -.macro serial_early_putc byte:req morebytes:vararg -#ifdef CONFIG_DEBUG_EARLY_SERIAL - _serial_early_putc 'E', 'a', 'r', 'l', 'y', ':', ' ', \byte, \morebytes -#endif -.endm - /* Since we embed the string right into our .text section, we need * to find its address. We do this by getting our PC and adding 2 * bytes (which is the length of the jump instruction). Then we
Move the default SPI CS that we boot from into common code so that it can be used in other SPI drivers and environment settings.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- board/bf537-stamp/spi_flash.c | 8 +------- include/asm-blackfin/blackfin-config-pre.h | 9 +++++++++ 2 files changed, 10 insertions(+), 7 deletions(-)
diff --git a/board/bf537-stamp/spi_flash.c b/board/bf537-stamp/spi_flash.c index b147ce7..7b764b4 100644 --- a/board/bf537-stamp/spi_flash.c +++ b/board/bf537-stamp/spi_flash.c @@ -180,13 +180,7 @@ static struct manufacturer_info flash_manufacturers[] = { * BF51x, BF533, BF561: SSEL2 */ #ifndef CONFIG_SPI_FLASH_SSEL -# if defined(__ADSPBF531__) || defined(__ADSPBF532__) || defined(__ADSPBF533__) || \ - defined(__ADSPBF538__) || defined(__ADSPBF539__) || defined(__ADSPBF561__) || \ - defined(__ADSPBF51x__) -# define CONFIG_SPI_FLASH_SSEL 2 -# else -# define CONFIG_SPI_FLASH_SSEL 1 -# endif +# define CONFIG_SPI_FLASH_SSEL BFIN_BOOT_SPI_SSEL #endif #define SSEL_MASK (1 << CONFIG_SPI_FLASH_SSEL)
diff --git a/include/asm-blackfin/blackfin-config-pre.h b/include/asm-blackfin/blackfin-config-pre.h index a1fae5c..9df01ad 100644 --- a/include/asm-blackfin/blackfin-config-pre.h +++ b/include/asm-blackfin/blackfin-config-pre.h @@ -60,4 +60,13 @@ static inline const char *get_bfin_boot_mode(int bfin_boot) } #endif
+/* Define the default SPI CS used when booting out of SPI */ +#if defined(__ADSPBF531__) || defined(__ADSPBF532__) || defined(__ADSPBF533__) || \ + defined(__ADSPBF538__) || defined(__ADSPBF539__) || defined(__ADSPBF561__) || \ + defined(__ADSPBF51x__) +# define BFIN_BOOT_SPI_SSEL 2 +#else +# define BFIN_BOOT_SPI_SSEL 1 +#endif + #endif
Mike Frysinger
