Re: [PATCH v2 0/3] dt-bindings: arm: bcm: raspberrypi,bcm2835-firmware: Drive-by fixes
[add Peter and Ivan]
Am 26.03.24 um 20:58 schrieb Laurent Pinchart:
Hello,
This small series includes a few drive-by fixes for DT validation errors.
The first patch has been posted previously in v1 ([1], and now addresses a small review comment. I think it's good to go.
The next two patches address the same issue as "[PATCH 1/2] dt-bindings: arm: bcm: raspberrypi,bcm2835-firmware: Add missing properties" ([2]), but this time with a (hopefully) correct approach. Patch 2/3 starts by fixing the raspberrypi-bcm2835-firmware driver, removing the need for DT properties that are specified in bcm2835-rpi.dtsi but not documented in the corresponding bindings. Patch 3/3 can then drop those properties, getting rid of the warnings.
since this series drops properties from the device tree, does anyone have the chance to test it with a recent U-Boot?
[1] https://lore.kernel.org/linux-arm-kernel/20240326004902.17054-3-laurent.pinc... [2] https://lore.kernel.org/linux-arm-kernel/20240326004902.17054-2-laurent.pinc...
Laurent Pinchart (3): dt-bindings: arm: bcm: raspberrypi,bcm2835-firmware: Add gpio child node firmware: raspberrypi: Use correct device for DMA mappings ARM: dts: bcm283x: Drop unneeded properties in the bcm2835-firmware node
.../arm/bcm/raspberrypi,bcm2835-firmware.yaml | 30 +++++++++++++++++++ .../gpio/raspberrypi,firmware-gpio.txt | 30 ------------------- arch/arm/boot/dts/broadcom/bcm2835-rpi.dtsi | 4 --- drivers/firmware/raspberrypi.c | 7 +++-- 4 files changed, 34 insertions(+), 37 deletions(-) delete mode 100644 Documentation/devicetree/bindings/gpio/raspberrypi,firmware-gpio.txt
Hello,
I don't have U-Boot running with my RPi, so I would appreciate if someone could help :-)
On 28 Mar 2024, at 1:37, Laurent Pinchart laurent.pinchart@ideasonboard.com wrote:
Hello,
Sure, just give me some time :-)
Regards, Ivan
Hello,
Sorry for taking me so long to verify this.
I think on RPi U-Boot side we are fine. API used when accessing Mbox device do not follow DM model and do not use DMA, but just access device directly using this nice macros phys_to_bus/bus_to_phys.
I build new DTB files with this patch included and U-Boot build from the latest sources. No obvious issues on RPi3 and RPi4. Devices boot fine.
Regards, Ivan
Am 02.04.24 um 10:58 schrieb Ivan T. Ivanov:
Hello,
addresses
dt-bindings:
([2]),
starts by
for DT
documented in
Thanks you, Laurent and Ivan
Reviewed-by: Stefan Wahren wahrenst@gmx.net
Regards, Ivan
Hello,
Hello,
Thank you for testing Ivan.
Stefan, I'm quite unfamiliar with the Raspberry Pi upstreaming process (despite having sent patches for ages :-)), do I understand correctly that this patch will go through your tree, or do I need to work with someone else to get it merged upstream ?
On 4/2/24 13:08, Laurent Pinchart wrote:
Hello,
Hello,
I will be taking those via the Broadcom SoC tree.
Hi Florian,
Am 26.03.24 um 20:58 schrieb Laurent Pinchart: > Hello, > > This small series includes a few drive-by fixes for DT validation > errors. > > The first patch has been posted previously in v1 ([1], and now addresses > a small review comment. I think it's good to go. > > The next two patches address the same issue as "[PATCH 1/2] dt-bindings: > arm: bcm: raspberrypi,bcm2835-firmware: Add missing properties" ([2]), > but this time with a (hopefully) correct approach. Patch 2/3 starts by > fixing the raspberrypi-bcm2835-firmware driver, removing the need for DT > properties that are specified in bcm2835-rpi.dtsi but not documented in > the corresponding bindings. Patch 3/3 can then drop those properties, > getting rid of the warnings.
Thank you.
If there's a chance to include patches 05/10, 07/10, 08/10 and 09/10 from [1] at the same time, that would be great :-)
[1] https://lore.kernel.org/linux-media/20240402000424.4650-1-laurent.pinchart@i...
On 4/2/24 13:32, Laurent Pinchart wrote:
Hi Florian,
On Wed, Mar 27, 2024 at 07:49:38AM +0100, Stefan Wahren wrote: > Hi, > > [add Peter and Ivan] > > Am 26.03.24 um 20:58 schrieb Laurent Pinchart: >> Hello, >> >> This small series includes a few drive-by fixes for DT validation >> errors. >> >> The first patch has been posted previously in v1 ([1], and now addresses >> a small review comment. I think it's good to go. >> >> The next two patches address the same issue as "[PATCH 1/2] dt-bindings: >> arm: bcm: raspberrypi,bcm2835-firmware: Add missing properties" ([2]), >> but this time with a (hopefully) correct approach. Patch 2/3 starts by >> fixing the raspberrypi-bcm2835-firmware driver, removing the need for DT >> properties that are specified in bcm2835-rpi.dtsi but not documented in >> the corresponding bindings. Patch 3/3 can then drop those properties, >> getting rid of the warnings. > > since this series drops properties from the device tree, does anyone > have the chance to test it with a recent U-Boot?
Thank you.
Yes, now done, thanks!
Hi Laurent,
Am 02.04.24 um 22:08 schrieb Laurent Pinchart:
Hello,
i'm not the maintainer, but i'm trying to help. Florian is the maintainer, so i would expect this series goes through his tree. So MAINTAINERS file is correct here.
Hello,
addresses
dt-bindings:
for DT
documented in
Can I add this as a Tested-by tag from you while applying then?
participants (5)
Florian Fainelli
Florian Fainelli
Ivan T. Ivanov
Laurent Pinchart
Stefan Wahren
