A3720 - Disable slot when eMMC is not present
Hello! I looked at what is initialized and enabled for sd/emmc slots and I found out that comphy mmc needs to be enabled if at least one slot is used (e.g. SD card) and then remaining part is slot initialization in xenon driver.
I wrote quick patch to disable slot when unregistering mmc device from U-Boot and also unregister emmc on A3720 from U-Boot when it is not present. But I have not tested it yet.
What do you think about it?
diff --git a/board/Marvell/mvebu_armada-37xx/board.c b/board/Marvell/mvebu_armada-37xx/board.c index f67b04b78c..1b9e7520cc 100644 --- a/board/Marvell/mvebu_armada-37xx/board.c +++ b/board/Marvell/mvebu_armada-37xx/board.c @@ -5,6 +5,7 @@
#include <common.h> #include <dm.h> +#include <dm/device-internal.h> #include <env.h> #include <i2c.h> #include <init.h> @@ -84,12 +85,10 @@ int board_init(void) #ifdef CONFIG_BOARD_LATE_INIT int board_late_init(void) { + struct udevice *dev; struct mmc *mmc_dev; bool ddr4, emmc;
- if (env_get("fdtfile")) - return 0; - if (!of_machine_is_compatible("globalscale,espressobin")) return 0;
@@ -101,6 +100,16 @@ int board_late_init(void) mmc_dev = find_mmc_device(1); emmc = (mmc_dev && mmc_init(mmc_dev) == 0);
+ /* if eMMC is not present then remove it from DM */ + if (!emmc && mmc_dev) { + dev = mmc_dev->dev; + device_remove(dev, DM_REMOVE_NORMAL); + device_unbind(dev); + } + + if (env_get("fdtfile")) + return 0; + if (ddr4 && emmc) env_set("fdtfile", "marvell/armada-3720-espressobin-v7-emmc.dtb"); else if (ddr4) diff --git a/drivers/mmc/xenon_sdhci.c b/drivers/mmc/xenon_sdhci.c index 6ce9d00d0a..da9882cbf6 100644 --- a/drivers/mmc/xenon_sdhci.c +++ b/drivers/mmc/xenon_sdhci.c @@ -350,6 +350,16 @@ static void xenon_mmc_enable_slot(struct sdhci_host *host, u8 slot) sdhci_writel(host, var, SDHC_SYS_OP_CTRL); }
+/* Disable specific slot */ +static void xenon_mmc_disable_slot(struct sdhci_host *host, u8 slot) +{ + u32 var; + + var = sdhci_readl(host, SDHC_SYS_OP_CTRL); + var &= ~(SLOT_MASK(slot) << SLOT_ENABLE_SHIFT); + sdhci_writel(host, var, SDHC_SYS_OP_CTRL); +} + /* Enable Parallel Transfer Mode */ static void xenon_mmc_enable_parallel_tran(struct sdhci_host *host, u8 slot) { @@ -515,6 +525,14 @@ static int xenon_sdhci_probe(struct udevice *dev) return ret; }
+static int xenon_sdhci_remove(struct udevice *dev) +{ + struct sdhci_host *host = dev_get_priv(dev); + + xenon_mmc_disable_slot(host, XENON_MMC_SLOT_ID_HYPERION); + return 0; +} + static int xenon_sdhci_ofdata_to_platdata(struct udevice *dev) { struct sdhci_host *host = dev_get_priv(dev); @@ -564,6 +582,7 @@ U_BOOT_DRIVER(xenon_sdhci_drv) = { .ops = &sdhci_ops, .bind = xenon_sdhci_bind, .probe = xenon_sdhci_probe, + .remove = xenon_sdhci_remove, .priv_auto_alloc_size = sizeof(struct xenon_sdhci_priv), .platdata_auto_alloc_size = sizeof(struct xenon_sdhci_plat), };
Logically, it's possible to disable slot. But i'm not sure because of not having its board. Just minor question.. Does it support multi slot per one IP?
Best Regards, Jaehoon Chung
- struct udevice *dev; struct mmc *mmc_dev; bool ddr4, emmc;
- /* if eMMC is not present then remove it from DM */
- if (!emmc && mmc_dev) {
dev = mmc_dev->dev;
device_unbind(dev);
- if (ddr4 && emmc) env_set("fdtfile", "marvell/armada-3720-espressobin-v7-emmc.dtb"); else if (ddr4)
- u32 var;
- var = sdhci_readl(host, SDHC_SYS_OP_CTRL);
- var &= ~(SLOT_MASK(slot) << SLOT_ENABLE_SHIFT);
- sdhci_writel(host, var, SDHC_SYS_OP_CTRL);
- struct sdhci_host *host = dev_get_priv(dev);
- xenon_mmc_disable_slot(host, XENON_MMC_SLOT_ID_HYPERION);
- .remove = xenon_sdhci_remove, .priv_auto_alloc_size = sizeof(struct xenon_sdhci_priv), .platdata_auto_alloc_size = sizeof(struct xenon_sdhci_plat),
A3720 has only one slot with index XENON_MMC_SLOT_ID_HYPERION.
A3720 has two mmc/sd IPs at two different address spaces, so uSD and eMMC do not share config address space.
dev = mmc_dev->dev;
device_unbind(dev);
- u32 var;
Thanks for explanation kindly. I asked because didn't see a real case that multi slot is supported.
dev = mmc_dev->dev;
device_unbind(dev);
- u32 var;
I haven't tested this yet, but it looks like it should leave the hw in a state as it was on a non-emmc board before the emmc/non-emmc merge. So I like the idea!
You can merge your xenon_mmc_disable_slot() with xenon_mmc_enable_slot() though, and instead add a 'bool enable' as with xenon_mmc_set_acg() above.
Thanks, Andre
dev = mmc_dev->dev;
device_unbind(dev);
- u32 var;
- /* Enable Parallel Transfer Mode */ static void xenon_mmc_enable_parallel_tran(struct sdhci_host *host, u8 slot) {
- static int xenon_sdhci_ofdata_to_platdata(struct udevice *dev) { struct sdhci_host *host = dev_get_priv(dev);
- .remove = xenon_sdhci_remove, .priv_auto_alloc_size = sizeof(struct xenon_sdhci_priv), .platdata_auto_alloc_size = sizeof(struct xenon_sdhci_plat), };
Hello!
Now I have tested this patch on Espressobin v5 without eMMC and mmc device was correctly removed, it even does not show in 'mmc list' output. From uSD card is working fine as before.
I do not observe any slowdown of init sequence. And I still have a problem to catch output and press key to stop uboot booting :D So I think initialization is still very fast.
I was thinking about it and I chosen separate function as separated it is also in the linux kernel driver.
But I have no problem to choose any variant. Stefan (or any other maintainer of this sdhc code), please let me know what style would you like to see or if you have any other comments for changes.
Thanks, Andre
diff --git a/board/Marvell/mvebu_armada-37xx/board.c b/board/Marvell/mvebu_armada-37xx/board.c index f67b04b78c..1b9e7520cc 100644 --- a/board/Marvell/mvebu_armada-37xx/board.c +++ b/board/Marvell/mvebu_armada-37xx/board.c @@ -5,6 +5,7 @@ #include <common.h> #include <dm.h> +#include <dm/device-internal.h> #include <env.h> #include <i2c.h> #include <init.h> @@ -84,12 +85,10 @@ int board_init(void) #ifdef CONFIG_BOARD_LATE_INIT int board_late_init(void) {
dev = mmc_dev->dev;
device_unbind(dev);
diff --git a/drivers/mmc/xenon_sdhci.c b/drivers/mmc/xenon_sdhci.c index 6ce9d00d0a..da9882cbf6 100644 --- a/drivers/mmc/xenon_sdhci.c +++ b/drivers/mmc/xenon_sdhci.c @@ -350,6 +350,16 @@ static void xenon_mmc_enable_slot(struct sdhci_host *host, u8 slot) sdhci_writel(host, var, SDHC_SYS_OP_CTRL); } +/* Disable specific slot */ +static void xenon_mmc_disable_slot(struct sdhci_host *host, u8 slot) +{
- u32 var;
@@ -515,6 +525,14 @@ static int xenon_sdhci_probe(struct udevice *dev) return ret; } +static int xenon_sdhci_remove(struct udevice *dev) +{
Andre Heider
Jaehoon Chung
Pali Rohár
