[U-Boot] please pull u-boot-samsung master
Dear Albert,
The following changes since commit 9ed887caecb9ecb0c68773a1870d143b9f28d3da:
Merge branch 'u-boot-imx/master' into 'u-boot-arm/master' (2013-08-17 18:24:13 +0200)
git://git.denx.de/u-boot-samsung master
for you to fetch changes up to 5c18a1cf3e56e0177388258696be4a17a672e9d0:
arm:goni:mmc: Add sd card detection and initialization. (2013-09-11 11:09:27 +0900)
---------------------------------------------------------------- Chander Kashyap (3): CONFIG: EXYNOS5: Replace misnomer SMDK5250 with EXYNOS5250 and update Makefiles exynos5250: Add arndale board support dts: samsung: arndale: Fix include path
Inderpal Singh (1): exynos5250: arndale: Add mmc support
Minkyu Kang (2): arm: smdkc100: remove config.mk file arm: goni: remove config.mk file
Piotr Wilczek (2): arm:exynos:gpio: fix s5p_gpio_part_max for exynos4x12 drivers:power:max77686: add function to set voltage and mode
Przemyslaw Marczak (2): arm:mmc:goni/exynos: Fix wrong mmc base register devices offset. arm:goni:mmc: Add sd card detection and initialization.
MAINTAINERS | 4 + Makefile | 2 +- arch/arm/include/asm/arch-exynos/gpio.h | 17 +- arch/arm/include/asm/arch-exynos/mmc.h | 6 +- arch/arm/include/asm/arch-s5pc1xx/mmc.h | 6 +- board/samsung/arndale/Makefile | 34 ++++ board/samsung/arndale/arndale.c | 101 ++++++++++++ board/samsung/arndale/arndale_spl.c | 50 ++++++ board/samsung/dts/exynos5250-arndale.dts | 39 +++++ board/samsung/goni/config.mk | 18 --- board/samsung/goni/goni.c | 33 +++- board/samsung/smdkc100/config.mk | 16 -- boards.cfg | 1 + drivers/power/pmic/pmic_max77686.c | 192 ++++++++++++++++++++++ include/configs/arndale.h | 255 ++++++++++++++++++++++++++++++ include/configs/exynos5250-dt.h | 2 +- include/configs/s5p_goni.h | 3 + include/configs/smdkc100.h | 3 + include/power/max77686_pmic.h | 26 +++ tools/Makefile | 4 +- 20 files changed, 766 insertions(+), 46 deletions(-) create mode 100644 board/samsung/arndale/Makefile create mode 100644 board/samsung/arndale/arndale.c create mode 100644 board/samsung/arndale/arndale_spl.c create mode 100644 board/samsung/dts/exynos5250-arndale.dts delete mode 100644 board/samsung/goni/config.mk delete mode 100644 board/samsung/smdkc100/config.mk create mode 100644 include/configs/arndale.h
Hi Minkyu,
On Wed, 11 Sep 2013 11:28:54 +0900, Minkyu Kang mk7.kang@samsung.com wrote:
Dear Albert,
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Minkyu Kang
