[U-Boot] [GIT PULL] Pull request: u-boot-imx
Hi Albert,
The following changes since commit 67a490d60d70f2b01d55976440ba30154af96965:
atmel_nand: don't require CONFIG_SYS_NAND_ENABLE_PIN (2011-04-01 14:49:08 -0500)
are available in the git repository at: git://www.denx.de/git/u-boot-imx.git master
Fabio Estevam (1): mx25: Make the UART port number explicit in its setup function
Jason Liu (2): mx53loco: set mmc env to MMC slot1 MX5: Enable flat-device-tree support on mx53 loco board
Liu Hui-R64343 (3): MX53: drop config.mk from mx53evk MX53: support for freescale MX53LOCO board MX5: Enable flat-device-tree support on mx51/53 evk board
Stefano Babic (5): Makefile: change rule to build IMX image MX51: drop config.mk from mx51evk MX31: add support for MX31 watchdog MX31: qong: add watchdog IMX: MX31: Cleanup include files and drop nasty #ifdef in drivers
MAINTAINERS | 1 + Makefile | 2 +- arch/arm/cpu/arm1136/mx31/devices.c | 4 +- arch/arm/cpu/arm1136/mx31/generic.c | 2 +- arch/arm/cpu/arm1136/mx31/timer.c | 40 +++- arch/arm/cpu/arm926ejs/mx25/generic.c | 2 +- arch/arm/include/asm/arch-mx31/{mx31.h => clock.h} | 6 +- .../asm/arch-mx31/{mx31-regs.h => imx-regs.h} | 10 + board/davedenx/qong/fpga.c | 4 +- board/davedenx/qong/lowlevel_init.S | 2 +- board/davedenx/qong/qong.c | 16 +- board/freescale/mx31ads/lowlevel_init.S | 2 +- board/freescale/mx31ads/mx31ads.c | 4 +- board/freescale/mx31pdk/lowlevel_init.S | 2 +- board/freescale/mx31pdk/mx31pdk.c | 4 +- board/freescale/mx53evk/config.mk | 24 -- .../{mx51evk/config.mk => mx53loco/Makefile} | 36 ++- board/freescale/mx53loco/imximage.cfg | 96 ++++++ board/freescale/mx53loco/mx53loco.c | 316 ++++++++++++++++++++ board/imx31_phycore/imx31_phycore.c | 4 +- board/imx31_phycore/lowlevel_init.S | 2 +- board/karo/tx25/tx25.c | 4 +- board/logicpd/imx31_litekit/imx31_litekit.c | 4 +- board/logicpd/imx31_litekit/lowlevel_init.S | 2 +- boards.cfg | 5 +- drivers/gpio/mxc_gpio.c | 5 - drivers/i2c/mxc_i2c.c | 7 +- drivers/serial/serial_mxc.c | 4 - drivers/spi/mxc_spi.c | 9 +- drivers/usb/host/ehci-mxc.c | 2 +- drivers/video/mx3fb.c | 6 +- include/configs/imx31_litekit.h | 2 +- include/configs/mx31ads.h | 2 +- include/configs/mx31pdk.h | 2 +- include/configs/mx51evk.h | 5 + include/configs/mx53evk.h | 3 + include/configs/mx53loco.h | 199 ++++++++++++ include/configs/qong.h | 3 +- nand_spl/nand_boot_fsl_nfc.c | 4 - 39 files changed, 751 insertions(+), 96 deletions(-) rename arch/arm/include/asm/arch-mx31/{mx31.h => clock.h} (92%) rename arch/arm/include/asm/arch-mx31/{mx31-regs.h => imx-regs.h} (99%) delete mode 100644 board/freescale/mx53evk/config.mk rename board/freescale/{mx51evk/config.mk => mx53loco/Makefile} (51%) create mode 100755 board/freescale/mx53loco/imximage.cfg create mode 100755 board/freescale/mx53loco/mx53loco.c create mode 100644 include/configs/mx53loco.h
Best regards, Stefano
Hi Stefano,
Le 05/04/2011 15:29, Stefano Babic a écrit :
Hi Albert,
Applied, thanks.
Amicalement,
Albert ARIBAUD
Stefano Babic
