[U-Boot-Users] Netconsole at startup
Greetings
Bit of a puzzle with netconsole operation.
If I undef CFG_CONSOLE_IS_IN_ENV, then I can boot to the serial console and manually switch it to nc and it works great. Problem with that is that on boot it just uses the first device that has the correct in/out properties - i.e. serial and ignores any env setting.
If I define CFG_CONSOLE_IS_IN_ENV, then the netconsole stuff refuses to run (i.e. it doesn't use serial but it doesn't use nc either!!) - even though when checking with the BDI2000 I can see that the correct nc devices have been set up in the dev structures. If I start up in serial and then try to switch to nc it just doesn't work - it continues to use serial.
Any clues from anyone? Should netconsole be able to run from bootup?
Which architecture, which board?
What exactly is the problem with this? It's what I would expect... If you want to automatically switch to NC as soon as it becomes available you can always do this using some CONFIG_PREBOOT settings.
What does your overwrite_console() look like?
And what exactly are you trying to do here? What does your environment settings look like?
What do you mean by "bootup"? NC will or course only work after the main intitialization sequence has been completed, i. e. after relocation to RAM, and after ethernet and devices initialization.
I thought the whole point of the core code of u-boot was that it was architecture independent - I'm obviously wrong there...Its a custom mpc859 board as it happens.
I was relating the results of the two possible states of the compile time #define
Why should I even have it defined - if its supposed to read the device from the environment then it seems reasonable that it does so at a point when initialisation is complete and its able to make use of it.
I have stdin=nc, stdout=nc, stderr=nc, ncip=172.25.x.x - all values that work fine when used interactively!!
I can see the assignment in console_init_r() occuring OK for the values in the environment, its just that (presumably) the init order is not correct somewhere so it doesn't actually work!!
The whole point is now moot since your suggestion of CONFIG_PREBOOT solves the problem - its a bit of a cackhanded way of doing it which is what threw me for a while there!
One suggestion for the shell script to drive it from Linux - add a '-icrnl' to the stty line to stop 'cr' characters getting translated - works wonders at confounding the password patch from Pantelis Antoniou :-))
It's the intention to be HW independent, but obviously this may need support on the driver side, too.
MPC8xx should work, though.
It may be reasonable, but I'm also pretty sure that it was never tested when we implemented the NC stuff.
In interactive mode these settings take effect MUCH later.
Probably. I guess you will have to debug & fix this.
I hate boot loaders which have passwords. They might deny me access to the machine ...
Robin Gilks
