[PATCH] imx: spl: Fix build-time test for CONFIG_SPL_FS_FAT
This was already changed in 0c3a9ed409a5 but apparently missed when adding 9d86dbd9cf9d.
Signed-off-by: Jan Kiszka jan.kiszka@siemens.com ---
Found by chance while working on other code. Not tested.
arch/arm/mach-imx/spl.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-imx/spl.c b/arch/arm/mach-imx/spl.c index 49bb3b928d..bfdb3f3ada 100644 --- a/arch/arm/mach-imx/spl.c +++ b/arch/arm/mach-imx/spl.c @@ -197,7 +197,7 @@ u32 spl_mmc_boot_mode(const u32 boot_device) case SD1_BOOT: case SD2_BOOT: case SD3_BOOT: -#if defined(CONFIG_SPL_FAT_SUPPORT) +#if defined(CONFIG_SPL_FS_FAT) return MMCSD_MODE_FS; #else return MMCSD_MODE_RAW; @@ -206,7 +206,7 @@ u32 spl_mmc_boot_mode(const u32 boot_device) case MMC1_BOOT: case MMC2_BOOT: case MMC3_BOOT: -#if defined(CONFIG_SPL_FAT_SUPPORT) +#if defined(CONFIG_SPL_FS_FAT) return MMCSD_MODE_FS; #elif defined(CONFIG_SUPPORT_EMMC_BOOT) return MMCSD_MODE_EMMCBOOT; -- 2.16.4
Hello Jan,
I sent a very similar patch [1] as part of my "Fix spl_mmc_boot_mode() implementation for IMX" series [2] which tries to solve a few more issues in this particular function.
[1]: http://patchwork.ozlabs.org/project/uboot/patch/20200423110753.51231-6-hws@d... [2]: http://patchwork.ozlabs.org/project/uboot/list/?series=172241
Regards,
On 30.04.20 12:06, Harald Seiler wrote:
Hello Jan,
Oh, didn't check - then please ignore mine.
Jan
Regards,
Harald Seiler
Jan Kiszka
