[U-Boot] [PATCH v3] Update U-Boot's build timestamp on every compile
Use the GNU 'date' command to auto-generate a new U-Boot timestamp on every compile.
Signed-off-by: Peter Tyser ptyser@xes-inc.com --- NOTE: As far as the changes to the Makefile, I wasn't sure why the NAND_SPL and ONENAND_IPL didn't have the "depend" dependency and why they needed the $(VERSION_FILE) dependency. I added the $(TIMESTAMP) dependency to be consistent, but if its not correct, let me know.
Changes since v1: * Split up U_BOOT_DATE define (date and time) into U_BOOT_DATE (day, month, year) and U_BOOT_TIME (time of day) defines * Updated all architetures/boards
Changes since v2: * Placed U_BOOT_DATE and U_BOOT_TIME defines in timestamp_autogenerated.h. * Added include/timestamp.h
Makefile | 19 +++++++++++++------ board/bmw/bmw.c | 4 ++-- board/eXalion/eXalion.c | 3 ++- board/mousse/mousse.c | 3 ++- board/netstar/eeprom.c | 3 ++- board/sandburst/karef/karef.c | 6 ++++-- board/sandburst/metrobox/metrobox.c | 6 ++++-- board/trab/trab_fkt.c | 3 ++- board/voiceblue/eeprom.c | 3 ++- common/lcd.c | 4 +++- cpu/74xx_7xx/start.S | 3 ++- cpu/leon2/start.S | 3 ++- cpu/leon3/start.S | 3 ++- cpu/mcf5227x/start.S | 3 ++- cpu/mcf523x/start.S | 3 ++- cpu/mcf52x2/start.S | 3 ++- cpu/mcf532x/start.S | 3 ++- cpu/mcf5445x/start.S | 3 ++- cpu/mcf547x_8x/start.S | 3 ++- cpu/mpc512x/start.S | 3 ++- cpu/mpc5xx/start.S | 3 ++- cpu/mpc5xxx/start.S | 3 ++- cpu/mpc8220/start.S | 3 ++- cpu/mpc824x/start.S | 3 ++- cpu/mpc8260/start.S | 3 ++- cpu/mpc83xx/start.S | 3 ++- cpu/mpc85xx/start.S | 3 ++- cpu/mpc86xx/start.S | 3 ++- cpu/mpc8xx/start.S | 3 ++- cpu/mpc8xx/video.c | 4 +++- cpu/nios/start.S | 3 ++- cpu/nios2/start.S | 3 ++- cpu/ppc4xx/start.S | 3 ++- include/.gitignore | 1 + include/configs/NETPHONE.h | 2 +- include/configs/NETTA.h | 2 +- include/configs/NETTA2.h | 2 +- include/timestamp.h | 30 ++++++++++++++++++++++++++++++ lib_arm/board.c | 3 ++- lib_avr32/board.c | 3 ++- lib_blackfin/board.c | 3 ++- lib_i386/board.c | 3 ++- lib_microblaze/board.c | 3 ++- lib_mips/board.c | 3 ++- lib_sh/board.c | 3 ++- net/net.c | 3 +++ 46 files changed, 134 insertions(+), 51 deletions(-) create mode 100644 include/timestamp.h
diff --git a/Makefile b/Makefile index 9a132f7..f680479 100644 --- a/Makefile +++ b/Makefile @@ -30,6 +30,7 @@ U_BOOT_VERSION = $(VERSION).$(PATCHLEVEL).$(SUBLEVEL)$(EXTRAVERSION) else U_BOOT_VERSION = $(VERSION).$(PATCHLEVEL)$(EXTRAVERSION) endif +TIMESTAMP_FILE = $(obj)include/timestamp_autogenerated.h VERSION_FILE = $(obj)include/version_autogenerated.h
HOSTARCH := $(shell uname -m | \ @@ -259,7 +260,7 @@ LIBS += api/libapi.a LIBS += post/libpost.a
LIBS := $(addprefix $(obj),$(LIBS)) -.PHONY : $(LIBS) $(VERSION_FILE) +.PHONY : $(LIBS) $(TIMESTAMP_FILE) $(VERSION_FILE)
LIBBOARD = board/$(BOARDDIR)/lib$(BOARD).a LIBBOARD := $(addprefix $(obj),$(LIBBOARD)) @@ -351,13 +352,13 @@ $(SUBDIRS): depend $(obj)include/autoconf.mk $(LDSCRIPT): depend $(obj)include/autoconf.mk $(MAKE) -C $(dir $@) $(notdir $@)
-$(NAND_SPL): $(VERSION_FILE) $(obj)include/autoconf.mk +$(NAND_SPL): $(TIMESTAMP_FILE) $(VERSION_FILE) $(obj)include/autoconf.mk $(MAKE) -C nand_spl/board/$(BOARDDIR) all
$(U_BOOT_NAND): $(NAND_SPL) $(obj)u-boot.bin $(obj)include/autoconf.mk cat $(obj)nand_spl/u-boot-spl-16k.bin $(obj)u-boot.bin > $(obj)u-boot-nand.bin
-$(ONENAND_IPL): $(VERSION_FILE) $(obj)include/autoconf.mk +$(ONENAND_IPL): $(TIMESTAMP_FILE) $(VERSION_FILE) $(obj)include/autoconf.mk $(MAKE) -C onenand_ipl/board/$(BOARDDIR) all
$(U_BOOT_ONENAND): $(ONENAND_IPL) $(obj)u-boot.bin $(obj)include/autoconf.mk @@ -370,6 +371,12 @@ $(VERSION_FILE): ) > $@.tmp @cmp -s $@ $@.tmp && rm -f $@.tmp || mv -f $@.tmp $@
+$(TIMESTAMP_FILE): + @( printf '#define U_BOOT_DATE "%s"\n' '$(shell date +"%b %d %C%y")' \ + ) > $@ + @( printf '#define U_BOOT_TIME "%s"\n' '$(shell date +"%T")' \ + ) >> $@ + gdbtools: $(MAKE) -C tools/gdb all || exit 1
@@ -379,7 +386,7 @@ updater: env: $(MAKE) -C tools/env all MTD_VERSION=${MTD_VERSION} || exit 1
-depend dep: $(VERSION_FILE) +depend dep: $(TIMESTAMP_FILE) $(VERSION_FILE) for dir in $(SUBDIRS) ; do $(MAKE) -C $$dir _depend ; done
TAG_SUBDIRS += include @@ -460,7 +467,7 @@ sinclude $(obj)include/autoconf.mk.dep else # !config.mk all $(obj)u-boot.hex $(obj)u-boot.srec $(obj)u-boot.bin \ $(obj)u-boot.img $(obj)u-boot.dis $(obj)u-boot \ -$(SUBDIRS) $(VERSION_FILE) gdbtools updater env depend \ +$(SUBDIRS) $(TIMESTAMP_FILE) $(VERSION_FILE) gdbtools updater env depend \ dep tags ctags etags cscope $(obj)System.map: @echo "System not configured - see README" >&2 @ exit 1 @@ -3202,7 +3209,7 @@ clean: @rm -f $(obj)include/bmp_logo.h @rm -f $(obj)nand_spl/{u-boot-spl,u-boot-spl.map,System.map} @rm -f $(obj)onenand_ipl/onenand-{ipl,ipl.bin,ipl-2k.bin,ipl-4k.bin,ipl.map} - @rm -f $(obj)api_examples/demo $(VERSION_FILE) + @rm -f $(obj)api_examples/demo $(TIMESTAMP_FILE) $(VERSION_FILE) @find $(OBJTREE) -type f \ ( -name 'core' -o -name '*.bak' -o -name '*~' \ -o -name '*.o' -o -name '*.a' ) -print \ diff --git a/board/bmw/bmw.c b/board/bmw/bmw.c index b629c38..41ce14f 100644 --- a/board/bmw/bmw.c +++ b/board/bmw/bmw.c @@ -28,7 +28,7 @@ #include <malloc.h> #include <devices.h> #include <net.h> -#include <version.h> +#include <timestamp.h> #include <dtt.h> #include <mpc824x.h> #include <asm/processor.h> @@ -45,7 +45,7 @@ int checkboard(void) char buf[32];
puts ("Board: BMW MPC8245/KAHLUA2 - CHRP (MAP B)\n"); - printf("Built: %s at %s\n", __DATE__ , __TIME__ ); + printf("Built: %s at %s\n", U_BOOT_DATE, U_BOOT_TIME); /* printf("MPLD: Revision %d\n", SYS_REVID_GET()); */ printf("Local Bus at %s MHz\n", strmhz(buf, busfreq)); return 0; diff --git a/board/eXalion/eXalion.c b/board/eXalion/eXalion.c index 34538c4..c17498f 100644 --- a/board/eXalion/eXalion.c +++ b/board/eXalion/eXalion.c @@ -31,6 +31,7 @@ #include <pci.h> #include <ide.h> #include <netdev.h> +#include <timestamp.h> #include "piix_pci.h" #include "eXalion.h"
@@ -40,7 +41,7 @@ int checkboard (void) char buf[32];
printf ("Board: eXalion MPC824x - CHRP (MAP B)\n"); - printf ("Built: %s at %s\n", __DATE__, __TIME__); + printf ("Built: %s at %s\n", U_BOOT_DATE, U_BOOT_TIME); printf ("Local Bus: %s MHz\n", strmhz (buf, busfreq));
return 0; diff --git a/board/mousse/mousse.c b/board/mousse/mousse.c index 6a12b57..bd8d1c6 100644 --- a/board/mousse/mousse.c +++ b/board/mousse/mousse.c @@ -30,6 +30,7 @@ #include <mpc824x.h> #include <netdev.h> #include <asm/processor.h> +#include <timestamp.h>
#include "mousse.h" #include "m48t59y.h" @@ -42,7 +43,7 @@ int checkboard (void) char buf[32];
puts ("Board: MOUSSE MPC8240/KAHLUA - CHRP (MAP B)\n"); - printf ("Built: %s at %s\n", __DATE__, __TIME__); + printf ("Built: %s at %s\n", U_BOOT_DATE, U_BOOT_TIME); printf ("MPLD: Revision %d\n", SYS_REVID_GET ()); printf ("Local Bus: %s MHz\n", strmhz (buf, busfreq));
diff --git a/board/netstar/eeprom.c b/board/netstar/eeprom.c index 0de594b..5806128 100644 --- a/board/netstar/eeprom.c +++ b/board/netstar/eeprom.c @@ -26,6 +26,7 @@
#include <common.h> #include <exports.h> +#include <timestamp.h> #include "../drivers/net/smc91111.h"
#define SMC_BASE_ADDRESS CONFIG_SMC91111_BASE @@ -173,7 +174,7 @@ int eeprom(int argc, char *argv[]) /* Print help message */ if (argv[1][1] == 'h') { printf("VoiceBlue EEPROM writer\n"); - printf("Built: %s at %s\n", __DATE__ , __TIME__ ); + printf("Built: %s at %s\n", U_BOOT_DATE, U_BOOT_TIME); printf("Usage:\n\t<mac_address> [<element_1>] [<...>]\n"); return 0; } diff --git a/board/sandburst/karef/karef.c b/board/sandburst/karef/karef.c index 7909d34..8d97a9c 100644 --- a/board/sandburst/karef/karef.c +++ b/board/sandburst/karef/karef.c @@ -26,6 +26,7 @@ #include <command.h> #include "karef.h" #include "karef_version.h" +#include <timestamp.h> #include <asm/processor.h> #include <asm/io.h> #include <spd_sdram.h> @@ -299,7 +300,7 @@ int checkboard (void) "Serial Number: %d\n", sernum); printf ("%s\n", KAREF_U_BOOT_REL_STR);
- printf ("Built %s %s by %s\n", __DATE__, __TIME__, BUILDUSER); + printf ("Built %s %s by %s\n", U_BOOT_DATE, U_BOOT_TIME, BUILDUSER); if (sbcommon_get_master()) { printf("Slot 0 - Master\nSlave board"); if (sbcommon_secondary_present()) @@ -366,7 +367,8 @@ int misc_init_r (void) setenv("ubrelver", KAREF_U_BOOT_REL_STR);
memset(envstr, 0, 255); - sprintf (envstr, "Built %s %s by %s", __DATE__, __TIME__, BUILDUSER); + sprintf (envstr, "Built %s %s by %s", + U_BOOT_DATE, U_BOOT_TIME, BUILDUSER); setenv("bldstr", envstr); saveenv();
diff --git a/board/sandburst/metrobox/metrobox.c b/board/sandburst/metrobox/metrobox.c index c3c4459..19302dc 100644 --- a/board/sandburst/metrobox/metrobox.c +++ b/board/sandburst/metrobox/metrobox.c @@ -25,6 +25,7 @@ #include <command.h> #include "metrobox.h" #include "metrobox_version.h" +#include <timestamp.h> #include <asm/processor.h> #include <asm/io.h> #include <spd_sdram.h> @@ -270,7 +271,7 @@ int checkboard (void) printf ("Board: Sandburst Corporation MetroBox Serial Number: %d\n", sernum); printf ("%s\n", METROBOX_U_BOOT_REL_STR);
- printf ("Built %s %s by %s\n", __DATE__, __TIME__, BUILDUSER); + printf ("Built %s %s by %s\n", U_BOOT_DATE, U_BOOT_TIME, BUILDUSER); if (sbcommon_get_master()) { printf("Slot 0 - Master\nSlave board"); if (sbcommon_secondary_present()) @@ -335,7 +336,8 @@ int misc_init_r (void) setenv("ubrelver", METROBOX_U_BOOT_REL_STR);
diff --git a/board/trab/trab_fkt.c b/board/trab/trab_fkt.c index 7273ef9..93b9490 100644 --- a/board/trab/trab_fkt.c +++ b/board/trab/trab_fkt.c @@ -25,6 +25,7 @@
#include <common.h> #include <exports.h> +#include <timestamp.h> #include <s3c2400.h> #include "tsc2000.h" #include "rs485.h" @@ -296,7 +297,7 @@ int trab_fkt (int argc, char *argv[]) int do_info (void) { printf ("Stand-alone application for TRAB board function test\n"); - printf ("Built: %s at %s\n", __DATE__ , __TIME__ ); + printf ("Built: %s at %s\n", U_BOOT_DATE, U_BOOT_TIME);
return 0; } diff --git a/board/voiceblue/eeprom.c b/board/voiceblue/eeprom.c index d8ea6e5..f01597a 100644 --- a/board/voiceblue/eeprom.c +++ b/board/voiceblue/eeprom.c @@ -26,6 +26,7 @@
#define SMC_BASE_ADDRESS CONFIG_SMC91111_BASE @@ -169,7 +170,7 @@ int eeprom(int argc, char *argv[]) /* Print help message */ if (argv[1][1] == 'h') { printf("VoiceBlue EEPROM writer\n"); - printf("Built: %s at %s\n", __DATE__ , __TIME__ ); + printf("Built: %s at %s\n", U_BOOT_DATE, U_BOOT_TIME); printf("Usage:\n\t<mac_address> [<element_1>] [<...>]\n"); return 0; } diff --git a/common/lcd.c b/common/lcd.c index d104b26..3c15005 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -32,6 +32,7 @@ #include <config.h> #include <common.h> #include <command.h> +#include <timestamp.h> #include <version.h> #include <stdarg.h> #include <linux/types.h> @@ -788,7 +789,8 @@ static void *lcd_logo (void)
#ifdef CONFIG_MPC823 # ifdef CONFIG_LCD_INFO - sprintf (info, "%s (%s - %s) ", U_BOOT_VERSION, __DATE__, __TIME__); + sprintf (info, "%s (%s - %s) ", + U_BOOT_VERSION, U_BOOT_DATE, U_BOOT_TIME); lcd_drawchars (LCD_INFO_X, LCD_INFO_Y, (uchar *)info, strlen(info));
sprintf (info, "(C) 2008 DENX Software Engineering GmbH"); diff --git a/cpu/74xx_7xx/start.S b/cpu/74xx_7xx/start.S index 07bbe01..38b14c9 100644 --- a/cpu/74xx_7xx/start.S +++ b/cpu/74xx_7xx/start.S @@ -34,6 +34,7 @@ */ #include <config.h> #include <74xx_7xx.h> +#include <timestamp.h> #include <version.h>
#include <ppc_asm.tmpl> @@ -87,7 +88,7 @@ .globl version_string version_string: .ascii U_BOOT_VERSION - .ascii " (", __DATE__, " - ", __TIME__, ")" + .ascii " (", U_BOOT_DATE, " - ", U_BOOT_TIME, ")" .ascii CONFIG_IDENT_STRING, "\0"
. = EXC_OFF_SYS_RESET diff --git a/cpu/leon2/start.S b/cpu/leon2/start.S index 9b5d83e..b1f1eb5 100644 --- a/cpu/leon2/start.S +++ b/cpu/leon2/start.S @@ -27,6 +27,7 @@ #include <asm/psr.h> #include <asm/stack.h> #include <asm/leon.h> +#include <timestamp.h> #include <version.h>
/* Entry for traps which jump to a programmer-specified trap handler. */ @@ -199,7 +200,7 @@ _trap_table: .globl version_string version_string: .ascii U_BOOT_VERSION - .ascii " (", __DATE__, " - ", __TIME__, ")" + .ascii " (", U_BOOT_DATE, " - ", U_BOOT_TIME, ")" .ascii CONFIG_IDENT_STRING, "\0"
.section ".text" diff --git a/cpu/leon3/start.S b/cpu/leon3/start.S index 7afe10e..bd634bd 100644 --- a/cpu/leon3/start.S +++ b/cpu/leon3/start.S @@ -27,6 +27,7 @@ #include <asm/psr.h> #include <asm/stack.h> #include <asm/leon.h> +#include <timestamp.h> #include <version.h>
/* Entry for traps which jump to a programmer-specified trap handler. */ @@ -200,7 +201,7 @@ _trap_table: .globl version_string version_string: .ascii U_BOOT_VERSION - .ascii " (", __DATE__, " - ", __TIME__, ")" + .ascii " (", U_BOOT_DATE, " - ", U_BOOT_TIME, ")" .ascii CONFIG_IDENT_STRING, "\0"
.section ".text" diff --git a/cpu/mcf5227x/start.S b/cpu/mcf5227x/start.S index becaab7..43e7006 100644 --- a/cpu/mcf5227x/start.S +++ b/cpu/mcf5227x/start.S @@ -22,6 +22,7 @@ */
#include <config.h> +#include <timestamp.h> #include "version.h"
#ifndef CONFIG_IDENT_STRING @@ -352,6 +353,6 @@ dcache_status: .globl version_string version_string: .ascii U_BOOT_VERSION - .ascii " (", __DATE__, " - ", __TIME__, ")" + .ascii " (", U_BOOT_DATE, " - ", U_BOOT_TIME, ")" .ascii CONFIG_IDENT_STRING, "\0" .align 4 diff --git a/cpu/mcf523x/start.S b/cpu/mcf523x/start.S index b70b83b..d44da37 100644 --- a/cpu/mcf523x/start.S +++ b/cpu/mcf523x/start.S @@ -22,6 +22,7 @@ */
#ifndef CONFIG_IDENT_STRING @@ -336,6 +337,6 @@ dcache_status: .globl version_string version_string: .ascii U_BOOT_VERSION - .ascii " (", __DATE__, " - ", __TIME__, ")" + .ascii " (", U_BOOT_DATE, " - ", U_BOOT_TIME, ")" .ascii CONFIG_IDENT_STRING, "\0" .align 4 diff --git a/cpu/mcf52x2/start.S b/cpu/mcf52x2/start.S index da45bcb..ba6b884 100644 --- a/cpu/mcf52x2/start.S +++ b/cpu/mcf52x2/start.S @@ -22,6 +22,7 @@ */
#ifndef CONFIG_IDENT_STRING @@ -474,6 +475,6 @@ dcache_status: .globl version_string version_string: .ascii U_BOOT_VERSION - .ascii " (", __DATE__, " - ", __TIME__, ")" + .ascii " (", U_BOOT_DATE, " - ", U_BOOT_TIME, ")" .ascii CONFIG_IDENT_STRING, "\0" .align 4 diff --git a/cpu/mcf532x/start.S b/cpu/mcf532x/start.S index 7a3eb5f..3f92912 100644 --- a/cpu/mcf532x/start.S +++ b/cpu/mcf532x/start.S @@ -22,6 +22,7 @@ */
#ifndef CONFIG_IDENT_STRING @@ -331,6 +332,6 @@ dcache_status: .globl version_string version_string: .ascii U_BOOT_VERSION - .ascii " (", __DATE__, " - ", __TIME__, ")" + .ascii " (", U_BOOT_DATE, " - ", U_BOOT_TIME, ")" .ascii CONFIG_IDENT_STRING, "\0" .align 4 diff --git a/cpu/mcf5445x/start.S b/cpu/mcf5445x/start.S index 61e43ff..d5a7f93 100644 --- a/cpu/mcf5445x/start.S +++ b/cpu/mcf5445x/start.S @@ -22,6 +22,7 @@ */
#ifndef CONFIG_IDENT_STRING @@ -627,6 +628,6 @@ dcache_status: .globl version_string version_string: .ascii U_BOOT_VERSION - .ascii " (", __DATE__, " - ", __TIME__, ")" + .ascii " (", U_BOOT_DATE, " - ", U_BOOT_TIME, ")" .ascii CONFIG_IDENT_STRING, "\0" .align 4 diff --git a/cpu/mcf547x_8x/start.S b/cpu/mcf547x_8x/start.S index 41fc694..94ef14b 100644 --- a/cpu/mcf547x_8x/start.S +++ b/cpu/mcf547x_8x/start.S @@ -22,6 +22,7 @@ */
#ifndef CONFIG_IDENT_STRING @@ -357,6 +358,6 @@ dcache_status: .globl version_string version_string: .ascii U_BOOT_VERSION - .ascii " (", __DATE__, " - ", __TIME__, ")" + .ascii " (", U_BOOT_DATE, " - ", U_BOOT_TIME, ")" .ascii CONFIG_IDENT_STRING, "\0" .align 4 diff --git a/cpu/mpc512x/start.S b/cpu/mpc512x/start.S index 26f3c52..360682d 100644 --- a/cpu/mpc512x/start.S +++ b/cpu/mpc512x/start.S @@ -31,6 +31,7 @@
#include <config.h> #include <mpc512x.h> +#include <timestamp.h> #include <version.h>
#define CONFIG_521X 1 /* needed for Linux kernel header files*/ @@ -85,7 +86,7 @@ .globl version_string version_string: .ascii U_BOOT_VERSION - .ascii " (", __DATE__, " - ", __TIME__, ")" + .ascii " (", U_BOOT_DATE, " - ", U_BOOT_TIME, ")" .ascii " ", CONFIG_IDENT_STRING, "\0"
/* diff --git a/cpu/mpc5xx/start.S b/cpu/mpc5xx/start.S index f2ffe84..106935c 100644 --- a/cpu/mpc5xx/start.S +++ b/cpu/mpc5xx/start.S @@ -32,6 +32,7 @@
#include <config.h> #include <mpc5xx.h> +#include <timestamp.h> #include <version.h>
#define CONFIG_5xx 1 /* needed for Linux kernel header files */ @@ -80,7 +81,7 @@ .globl version_string version_string: .ascii U_BOOT_VERSION - .ascii " (", __DATE__, " - ", __TIME__, ")" + .ascii " (", U_BOOT_DATE, " - ", U_BOOT_TIME, ")" .ascii CONFIG_IDENT_STRING, "\0"
. = EXC_OFF_SYS_RESET diff --git a/cpu/mpc5xxx/start.S b/cpu/mpc5xxx/start.S index defe77d..6b1162a 100644 --- a/cpu/mpc5xxx/start.S +++ b/cpu/mpc5xxx/start.S @@ -27,6 +27,7 @@ */ #include <config.h> #include <mpc5xxx.h> +#include <timestamp.h> #include <version.h>
#define CONFIG_MPC5xxx 1 /* needed for Linux kernel header files */ @@ -78,7 +79,7 @@ .globl version_string version_string: .ascii U_BOOT_VERSION - .ascii " (", __DATE__, " - ", __TIME__, ")" + .ascii " (", U_BOOT_DATE, " - ", U_BOOT_TIME, ")" .ascii CONFIG_IDENT_STRING, "\0"
/* diff --git a/cpu/mpc8220/start.S b/cpu/mpc8220/start.S index 373be2c..3abc619 100644 --- a/cpu/mpc8220/start.S +++ b/cpu/mpc8220/start.S @@ -27,6 +27,7 @@ */ #include <config.h> #include <mpc8220.h> +#include <timestamp.h> #include <version.h>
#define _LINUX_CONFIG_H 1 /* avoid reading Linux autoconf.h file */ @@ -77,7 +78,7 @@ .globl version_string version_string: .ascii U_BOOT_VERSION - .ascii " (", __DATE__, " - ", __TIME__, ")" + .ascii " (", U_BOOT_DATE, " - ", U_BOOT_TIME, ")" .ascii CONFIG_IDENT_STRING, "\0"
/* diff --git a/cpu/mpc824x/start.S b/cpu/mpc824x/start.S index b5d7eb1..39325cd 100644 --- a/cpu/mpc824x/start.S +++ b/cpu/mpc824x/start.S @@ -39,6 +39,7 @@ */ #include <config.h> #include <mpc824x.h> +#include <timestamp.h> #include <version.h>
#define _LINUX_CONFIG_H 1 /* avoid reading Linux autoconf.h file */ @@ -90,7 +91,7 @@ .globl version_string version_string: .ascii U_BOOT_VERSION - .ascii " (", __DATE__, " - ", __TIME__, ")" + .ascii " (", U_BOOT_DATE, " - ", U_BOOT_TIME, ")" .ascii CONFIG_IDENT_STRING, "\0"
. = EXC_OFF_SYS_RESET diff --git a/cpu/mpc8260/start.S b/cpu/mpc8260/start.S index da0c516..379f2fb 100644 --- a/cpu/mpc8260/start.S +++ b/cpu/mpc8260/start.S @@ -27,6 +27,7 @@ */ #include <config.h> #include <mpc8260.h> +#include <timestamp.h> #include <version.h>
#define CONFIG_8260 1 /* needed for Linux kernel header files */ @@ -85,7 +86,7 @@ .globl version_string version_string: .ascii U_BOOT_VERSION - .ascii " (", __DATE__, " - ", __TIME__, ")" + .ascii " (", U_BOOT_DATE, " - ", U_BOOT_TIME, ")" .ascii CONFIG_IDENT_STRING, "\0"
/* diff --git a/cpu/mpc83xx/start.S b/cpu/mpc83xx/start.S index cd566b2..792b2c8 100644 --- a/cpu/mpc83xx/start.S +++ b/cpu/mpc83xx/start.S @@ -29,6 +29,7 @@
#include <config.h> #include <mpc83xx.h> +#include <timestamp.h> #include <version.h>
#define CONFIG_83XX 1 /* needed for Linux kernel header files*/ @@ -105,7 +106,7 @@ .globl version_string version_string: .ascii U_BOOT_VERSION - .ascii " (", __DATE__, " - ", __TIME__, ")" + .ascii " (", U_BOOT_DATE, " - ", U_BOOT_TIME, ")" .ascii " ", CONFIG_IDENT_STRING, "\0"
diff --git a/cpu/mpc85xx/start.S b/cpu/mpc85xx/start.S index fc3c336..7e9f3f3 100644 --- a/cpu/mpc85xx/start.S +++ b/cpu/mpc85xx/start.S @@ -30,6 +30,7 @@
#include <config.h> #include <mpc85xx.h> +#include <timestamp.h> #include <version.h>
#define _LINUX_CONFIG_H 1 /* avoid reading Linux autoconf.h file */ @@ -272,7 +273,7 @@ _start: .globl version_string version_string: .ascii U_BOOT_VERSION - .ascii " (", __DATE__, " - ", __TIME__, ")" + .ascii " (", U_BOOT_DATE, " - ", U_BOOT_TIME, ")" .ascii CONFIG_IDENT_STRING, "\0"
.align 4 diff --git a/cpu/mpc86xx/start.S b/cpu/mpc86xx/start.S index 159f3e1..7dca488 100644 --- a/cpu/mpc86xx/start.S +++ b/cpu/mpc86xx/start.S @@ -32,6 +32,7 @@ */ #include <config.h> #include <mpc86xx.h> +#include <timestamp.h> #include <version.h>
#include <ppc_asm.tmpl> @@ -76,7 +77,7 @@ .globl version_string version_string: .ascii U_BOOT_VERSION - .ascii " (", __DATE__, " - ", __TIME__, ")" + .ascii " (", U_BOOT_DATE, " - ", U_BOOT_TIME, ")" .ascii CONFIG_IDENT_STRING, "\0"
. = EXC_OFF_SYS_RESET diff --git a/cpu/mpc8xx/start.S b/cpu/mpc8xx/start.S index 7b75660..45c902e 100644 --- a/cpu/mpc8xx/start.S +++ b/cpu/mpc8xx/start.S @@ -39,6 +39,7 @@ */ #include <config.h> #include <mpc8xx.h> +#include <timestamp.h> #include <version.h>
#define CONFIG_8xx 1 /* needed for Linux kernel header files */ @@ -87,7 +88,7 @@ .globl version_string version_string: .ascii U_BOOT_VERSION - .ascii " (", __DATE__, " - ", __TIME__, ")" + .ascii " (", U_BOOT_DATE, " - ", U_BOOT_TIME, ")" .ascii CONFIG_IDENT_STRING, "\0"
. = EXC_OFF_SYS_RESET diff --git a/cpu/mpc8xx/video.c b/cpu/mpc8xx/video.c index 2e6a22a..aa47df7 100644 --- a/cpu/mpc8xx/video.c +++ b/cpu/mpc8xx/video.c @@ -32,6 +32,7 @@ #include <stdarg.h> #include <common.h> #include <config.h> +#include <timestamp.h> #include <version.h> #include <i2c.h> #include <linux/types.h> @@ -1174,7 +1175,8 @@ static void *video_logo (void) easylogo_plot (VIDEO_LOGO_ADDR, screen, width, 0, 0);
#ifdef VIDEO_INFO - sprintf (info, "%s (%s - %s) ", U_BOOT_VERSION, __DATE__, __TIME__); + sprintf (info, "%s (%s - %s) ", + U_BOOT_VERSION, U_BOOT_DATE, U_BOOT_TIME); video_drawstring (VIDEO_INFO_X, VIDEO_INFO_Y, info);
sprintf (info, "(C) 2002 DENX Software Engineering"); diff --git a/cpu/nios/start.S b/cpu/nios/start.S index 5d15e8d..3578a04 100644 --- a/cpu/nios/start.S +++ b/cpu/nios/start.S @@ -23,6 +23,7 @@
#if !defined(CONFIG_IDENT_STRING) @@ -233,5 +234,5 @@ dly_clks:
version_string: .ascii U_BOOT_VERSION - .ascii " (", __DATE__, " - ", __TIME__, ")" + .ascii " (", U_BOOT_DATE, " - ", U_BOOT_TIME, ")" .ascii CONFIG_IDENT_STRING, "\0" diff --git a/cpu/nios2/start.S b/cpu/nios2/start.S index ea41435..31cd5b0 100644 --- a/cpu/nios2/start.S +++ b/cpu/nios2/start.S @@ -23,6 +23,7 @@
/************************************************************************* @@ -212,5 +213,5 @@ dly_clks:
version_string: .ascii U_BOOT_VERSION - .ascii " (", __DATE__, " - ", __TIME__, ")" + .ascii " (", U_BOOT_DATE, " - ", U_BOOT_TIME, ")" .ascii CONFIG_IDENT_STRING, "\0" diff --git a/cpu/ppc4xx/start.S b/cpu/ppc4xx/start.S index 31902a0..050f049 100644 --- a/cpu/ppc4xx/start.S +++ b/cpu/ppc4xx/start.S @@ -63,6 +63,7 @@ */ #include <config.h> #include <ppc4xx.h> +#include <timestamp.h> #include <version.h>
#define _LINUX_CONFIG_H 1 /* avoid reading Linux autoconf.h file */ @@ -509,7 +510,7 @@ rsttlb: tlbwe r0,r1,0x0000 /* Invalidate all entries (V=0)*/ .globl version_string version_string: .ascii U_BOOT_VERSION - .ascii " (", __DATE__, " - ", __TIME__, ")" + .ascii " (", U_BOOT_DATE, " - ", U_BOOT_TIME, ")" .ascii CONFIG_IDENT_STRING, "\0"
. = EXC_OFF_SYS_RESET diff --git a/include/.gitignore b/include/.gitignore index ef7dd5f..4481412 100644 --- a/include/.gitignore +++ b/include/.gitignore @@ -5,4 +5,5 @@ /bmp_logo.h /config.h /config.mk +/timestamp_autogenerated.h /version_autogenerated.h diff --git a/include/configs/NETPHONE.h b/include/configs/NETPHONE.h index a147aff..34de947 100644 --- a/include/configs/NETPHONE.h +++ b/include/configs/NETPHONE.h @@ -799,7 +799,7 @@ typedef unsigned int led_id_t; #define CONFIG_CDP_DEVICE_ID_PREFIX "NP" /* netphone */ #define CONFIG_CDP_PORT_ID "eth%d" #define CONFIG_CDP_CAPABILITIES 0x00000010 -#define CONFIG_CDP_VERSION "u-boot" " " __DATE__ " " __TIME__ +#define CONFIG_CDP_VERSION "u-boot" " " U_BOOT_DATE " " U_BOOT_TIME #define CONFIG_CDP_PLATFORM "Intracom NetPhone" #define CONFIG_CDP_TRIGGER 0x20020001 #define CONFIG_CDP_POWER_CONSUMPTION 4300 /* 90 mA @ 48V */ diff --git a/include/configs/NETTA.h b/include/configs/NETTA.h index 63810b3..004b3c8 100644 --- a/include/configs/NETTA.h +++ b/include/configs/NETTA.h @@ -775,7 +775,7 @@ #define CONFIG_CDP_DEVICE_ID_PREFIX "NT" /* netta */ #define CONFIG_CDP_PORT_ID "eth%d" #define CONFIG_CDP_CAPABILITIES 0x00000010 -#define CONFIG_CDP_VERSION "u-boot 1.0" " " __DATE__ " " __TIME__ +#define CONFIG_CDP_VERSION "u-boot 1.0" " " U_BOOT_DATE " " U_BOOT_TIME #define CONFIG_CDP_PLATFORM "Intracom NetTA" #define CONFIG_CDP_TRIGGER 0x20020001 #define CONFIG_CDP_POWER_CONSUMPTION 4300 /* 90 mA @ 48V */ diff --git a/include/configs/NETTA2.h b/include/configs/NETTA2.h index 61c5547..70995fa 100644 --- a/include/configs/NETTA2.h +++ b/include/configs/NETTA2.h @@ -750,7 +750,7 @@ typedef unsigned int led_id_t; #define CONFIG_CDP_DEVICE_ID_PREFIX "NT" /* netta2 */ #define CONFIG_CDP_PORT_ID "eth%d" #define CONFIG_CDP_CAPABILITIES 0x00000010 -#define CONFIG_CDP_VERSION "u-boot" " " __DATE__ " " __TIME__ +#define CONFIG_CDP_VERSION "u-boot" " " U_BOOT_DATE " " U_BOOT_TIME #define CONFIG_CDP_PLATFORM "Intracom NetTA2" #define CONFIG_CDP_TRIGGER 0x20020001 #define CONFIG_CDP_POWER_CONSUMPTION 4300 /* 90 mA @ 48V */ diff --git a/include/timestamp.h b/include/timestamp.h new file mode 100644 index 0000000..b2f4cf4 --- /dev/null +++ b/include/timestamp.h @@ -0,0 +1,30 @@ +/* + * Copyright 2008 Extreme Engineering Solutions, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __TIMESTAMP_H__ +#define __TIMESTAMP_H__ + +#ifndef DO_DEPS_ONLY +#include "timestamp_autogenerated.h" +#endif + +#endif /* __TIMESTAMP_H__ */ diff --git a/lib_arm/board.c b/lib_arm/board.c index 4ba1f5e..2358beb 100644 --- a/lib_arm/board.c +++ b/lib_arm/board.c @@ -42,6 +42,7 @@ #include <command.h> #include <malloc.h> #include <devices.h> +#include <timestamp.h> #include <version.h> #include <net.h> #include <serial.h> @@ -69,7 +70,7 @@ extern void dataflash_print_info(void); #endif
const char version_string[] = - U_BOOT_VERSION" (" __DATE__ " - " __TIME__ ")"CONFIG_IDENT_STRING; + U_BOOT_VERSION" (" U_BOOT_DATE " - " U_BOOT_TIME ")"CONFIG_IDENT_STRING;
#ifdef CONFIG_DRIVER_CS8900 extern void cs8900_get_enetaddr (uchar * addr); diff --git a/lib_avr32/board.c b/lib_avr32/board.c index 8771de9..2a98bd4 100644 --- a/lib_avr32/board.c +++ b/lib_avr32/board.c @@ -23,6 +23,7 @@ #include <command.h> #include <malloc.h> #include <devices.h> +#include <timestamp.h> #include <version.h> #include <net.h>
@@ -36,7 +37,7 @@ DECLARE_GLOBAL_DATA_PTR;
const char version_string[] = - U_BOOT_VERSION " (" __DATE__ " - " __TIME__ ") " CONFIG_IDENT_STRING; + U_BOOT_VERSION " ("U_BOOT_DATE" - "U_BOOT_TIME") " CONFIG_IDENT_STRING;
unsigned long monitor_flash_len;
diff --git a/lib_blackfin/board.c b/lib_blackfin/board.c index ba57392..5f7d50d 100644 --- a/lib_blackfin/board.c +++ b/lib_blackfin/board.c @@ -16,6 +16,7 @@ #include <i2c.h> #include <malloc.h> #include <net.h> +#include <timestamp.h> #include <version.h>
#include <asm/cplb.h> @@ -32,7 +33,7 @@ int post_flag;
-const char version_string[] = U_BOOT_VERSION " (" __DATE__ " - " __TIME__ ")"; +const char version_string[] = U_BOOT_VERSION " ("U_BOOT_DATE" - "U_BOOT_TIME")";
__attribute__((always_inline)) static inline void serial_early_puts(const char *s) diff --git a/lib_i386/board.c b/lib_i386/board.c index 659f9a2..1734f86 100644 --- a/lib_i386/board.c +++ b/lib_i386/board.c @@ -32,6 +32,7 @@ #include <watchdog.h> #include <command.h> #include <devices.h> +#include <timestamp.h> #include <version.h> #include <malloc.h> #include <net.h> @@ -70,7 +71,7 @@ ulong i386boot_bios_size = (ulong)&_i386boot_bios_size; /* size of BIOS
const char version_string[] = - U_BOOT_VERSION" (" __DATE__ " - " __TIME__ ")"; + U_BOOT_VERSION" (" U_BOOT_DATE " - " U_BOOT_TIME ")";
/* diff --git a/lib_microblaze/board.c b/lib_microblaze/board.c index cd61918..250972c 100644 --- a/lib_microblaze/board.c +++ b/lib_microblaze/board.c @@ -27,12 +27,13 @@ #include <common.h> #include <command.h> #include <malloc.h> +#include <timestamp.h> #include <version.h> #include <watchdog.h>
#ifdef CONFIG_SYS_GPIO_0 extern int gpio_init (void); diff --git a/lib_mips/board.c b/lib_mips/board.c index 77e1cc8..9c997f1 100644 --- a/lib_mips/board.c +++ b/lib_mips/board.c @@ -25,6 +25,7 @@ #include <command.h> #include <malloc.h> #include <devices.h> +#include <timestamp.h> #include <version.h> #include <net.h> #include <environment.h> @@ -53,7 +54,7 @@ extern ulong uboot_end; ulong monitor_flash_len;
static char *failed = "*** failed ***\n";
diff --git a/lib_sh/board.c b/lib_sh/board.c index b6be22e..d4cc85c 100644 --- a/lib_sh/board.c +++ b/lib_sh/board.c @@ -22,6 +22,7 @@ #include <command.h> #include <malloc.h> #include <devices.h> +#include <timestamp.h> #include <version.h> #include <watchdog.h> #include <net.h> @@ -33,7 +34,7 @@ extern int board_init(void); extern int dram_init(void); extern int timer_init(void);
-const char version_string[] = U_BOOT_VERSION" (" __DATE__ " - " __TIME__ ")"; +const char version_string[] = U_BOOT_VERSION" ("U_BOOT_DATE" - "U_BOOT_TIME")";
unsigned long monitor_flash_len = CONFIG_SYS_MONITOR_LEN;
diff --git a/net/net.c b/net/net.c index 77e83b5..e9754e4 100644 --- a/net/net.c +++ b/net/net.c @@ -89,6 +89,9 @@ #if defined(CONFIG_CMD_SNTP) #include "sntp.h" #endif +#if defined(CONFIG_CDP_VERSION) +#include <timestamp.h> +#endif
#if defined(CONFIG_CMD_NET)
Dear Peter Tyser,
Sorry, this patch has whitespace issues and other problems:
Applying Update U-Boot's build timestamp on every compile .dotest/patch:85: trailing whitespace. .PHONY : $(LIBS) $(TIMESTAMP_FILE) $(VERSION_FILE) .dotest/patch:123: trailing whitespace. depend dep: $(TIMESTAMP_FILE) $(VERSION_FILE) error: patch failed: common/lcd.c:788 error: common/lcd.c: patch does not apply Using index info to reconstruct a base tree... <stdin>:85: trailing whitespace. .PHONY : $(LIBS) $(TIMESTAMP_FILE) $(VERSION_FILE) <stdin>:123: trailing whitespace. depend dep: $(TIMESTAMP_FILE) $(VERSION_FILE) warning: 2 lines add whitespace errors. Falling back to patching base and 3-way merge... Auto-merged Makefile Auto-merged common/lcd.c CONFLICT (content): Merge conflict in common/lcd.c Auto-merged cpu/mpc85xx/start.S Auto-merged cpu/mpc86xx/start.S Auto-merged cpu/ppc4xx/start.S Failed to merge in the changes. Patch failed at 0001.
Please rebase against current TOT and resubmit. Thanks.
Peter Tyser
