[U-Boot] [PATCH v4 0/4] add dfu support for at91 sam9260 based boards
add dfu supprt for at91 sam9260 based boards. The USB gadget driver is ported from linux: c94e289f195e: usb: gadget: remove incorrect __init/__exit annotations
it drops a lot of checkpatch warnings/errors:
checkpatch.pl found 12 error(s), 28 warning(s), 38 checks(s)
but for further updates I did not fix them. The errors are all from this sort:
error: drivers/usb/gadget/at91_udc.c,87: space prohibited before open square bracket '['
a lot of "line over 80 characters" warnings ...
Changes in v4: - rebase after taurus board changes
Changes in v3: - new in v3 - add comments from Alexandre Belloni get rid of cpu_is_at91*, use newer linux version as base for the port to U-Boot. - adapt changes for U-Boot, as newer linux version is used.
Changes in v2: - add comments from Lukasz Majewski - seperate usb gadget driver port from linux into 2 commits - first patch original from linux (with complete commit message) - second adds U-Boot changes without "#ifdef __UBOOT__" - new in version 2, contains U-Boot changes - rebase to bd48c0617b5c7212e5bf22169e716da878842da4 - fix changes introduced through commit: 01acd6abbdd5: usb: USB download gadget and functions config options coherent naming - add comments from Lukasz Majewski l.majewski@samsung.com - use SZ_X defines
Heiko Schocher (4): bitops: introduce BIT() definition usb: gadget: at91_udc: port linux driver at91_udc usb: gadget: at91_udc: add at91_udc into U-Boot at91, taurus, smartweb: add dfu support
board/siemens/smartweb/smartweb.c | 29 + board/siemens/taurus/taurus.c | 27 + drivers/usb/gadget/Makefile | 1 + drivers/usb/gadget/at91_udc.c | 1625 +++++++++++++++++++++++++++++++++++++ drivers/usb/gadget/at91_udc.h | 171 ++++ include/configs/smartweb.h | 53 +- include/configs/taurus.h | 30 +- include/linux/bitops.h | 2 + include/linux/usb/at91_udc.h | 20 + 9 files changed, 1943 insertions(+), 15 deletions(-) create mode 100644 drivers/usb/gadget/at91_udc.c create mode 100644 drivers/usb/gadget/at91_udc.h create mode 100644 include/linux/usb/at91_udc.h
introduce BIT() definition, used in at91_udc gadget driver.
Signed-off-by: Heiko Schocher hs@denx.de
Changes in v4: None Changes in v3: - new in v3
Changes in v2: None
include/linux/bitops.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/linux/bitops.h b/include/linux/bitops.h index e724310..7d30ace 100644 --- a/include/linux/bitops.h +++ b/include/linux/bitops.h @@ -3,6 +3,8 @@
#include <asm/types.h>
+#define BIT(nr) (1UL << (nr)) + /* * ffs: find first bit set. This is defined the same way as * the libc and compiler builtin ffs routines, therefore
Am Freitag, 21. August 2015, 19:01:56 schrieb Heiko Schocher:
- new in v3
Changes in v2: None
JFYI, a few months ago, Wolfgang Denk NAKed a similar patch: http://lists.denx.de/pipermail/u-boot/2014-February/173669.html
But I don't know whether this still stands.
- ffs: find first bit set. This is defined the same way as
- the libc and compiler builtin ffs routines, therefore
Best regards, Michael
- new in v3
Changes in v2: None
Linux also uses this BIT() macro, I think we should just run with it.
Best regards, Marek Vasut
NAK, this one breaks a lot of boards which already defined BIT()
- new in v3
Changes in v2: None
Hello Andreas,
Am 07.09.2015 um 13:20 schrieb Andreas Bießmann:
Uhh... seems this BIT() macro is a big mess ...
Hmm Wolfgang Denk NACKed a similiar patch: http://lists.denx.de/pipermail/u-boot/2014-February/173669.html
In drivers/usb/gadget/at91_udc.c BIT(x) is used only once... So I fix it there and use (1 << x) there. Would be this OK?
bye, Heiko
- new in v3
Changes in v2: None
Hi Heiko,
On 2015-09-07 13:52, Heiko Schocher wrote:
Hello Andreas,
I'm fine with this solution.
Andreas
bye, Heiko
- new in v3
Changes in v2: None
On Monday, September 07, 2015 at 02:01:11 PM, Andreas Bießmann wrote:
Hi Heiko,
Hello Andreas,
On the other hand, mainline Linux is moving towards GENMASK() and BIT(), so we should probably go with that as well.
Hi Heiko,
Hello Andreas,
Sent some couple of patches to use these macros, but Wolfgang Denk is not quite OK, with this move.
https://patchwork.ozlabs.org/patch/470475/ https://patchwork.ozlabs.org/patch/470476/ https://patchwork.ozlabs.org/patch/470477/ https://patchwork.ozlabs.org/patch/470478/ https://patchwork.ozlabs.org/patch/470479/
thanks!
Signed-off-by: Heiko Schocher hs@denx.de [remove all other occurrences of BIT(x) definition] Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com --- Full buildman is running
Would be nice to get some Acked-by/Reviewed-by since this is a fixup of one patch in a series that should go into 2015.10.
Andreas
Changes in v5: - remove other definitions of BIT()
Changes in v3: - new in this version
arch/arm/include/asm/arch-am33xx/cpu.h | 1 - arch/arm/include/asm/arch-hi6220/gpio.h | 2 -- arch/arm/include/asm/arch-omap5/cpu.h | 2 -- arch/arm/include/asm/arch-tegra/dc.h | 2 -- arch/arm/mach-davinci/cpu.c | 2 -- arch/arm/mach-keystone/include/mach/clock_defs.h | 2 -- arch/arm/mach-keystone/include/mach/hardware.h | 2 -- arch/arm/mach-mvebu/include/mach/soc.h | 2 -- arch/arm/mach-zynq/include/mach/gpio.h | 2 -- drivers/ddr/marvell/a38x/ddr3_init.h | 2 -- drivers/mtd/nand/jz4740_nand.c | 1 - drivers/spi/davinci_spi.c | 2 -- drivers/spi/ep93xx_spi.c | 2 -- drivers/video/anx9804.c | 2 -- include/fsl-mc/fsl_mc.h | 1 - include/linux/bitops.h | 2 ++ 16 files changed, 2 insertions(+), 27 deletions(-)
diff --git a/arch/arm/include/asm/arch-am33xx/cpu.h b/arch/arm/include/asm/arch-am33xx/cpu.h index 13a9cad..112ac5e 100644 --- a/arch/arm/include/asm/arch-am33xx/cpu.h +++ b/arch/arm/include/asm/arch-am33xx/cpu.h @@ -17,7 +17,6 @@
#include <asm/arch/hardware.h>
-#define BIT(x) (1 << x) #define CL_BIT(x) (0 << x)
/* Timer register bits */ diff --git a/arch/arm/include/asm/arch-hi6220/gpio.h b/arch/arm/include/asm/arch-hi6220/gpio.h index 98122a2..4fafaef 100644 --- a/arch/arm/include/asm/arch-hi6220/gpio.h +++ b/arch/arm/include/asm/arch-hi6220/gpio.h @@ -11,8 +11,6 @@ #define HI6220_GPIO_BASE(bank) (((bank < 4) ? 0xf8011000 : \ 0xf7020000 - 0x4000) + (0x1000 * bank))
-#define BIT(x) (1 << (x)) - #define HI6220_GPIO_PER_BANK 8 #define HI6220_GPIO_DIR 0x400
diff --git a/arch/arm/include/asm/arch-omap5/cpu.h b/arch/arm/include/asm/arch-omap5/cpu.h index 6109b92..b1513e9 100644 --- a/arch/arm/include/asm/arch-omap5/cpu.h +++ b/arch/arm/include/asm/arch-omap5/cpu.h @@ -56,8 +56,6 @@ struct watchdog { #endif /* __ASSEMBLY__ */ #endif /* __KERNEL_STRICT_NAMES */
-#define BIT(x) (1 << (x)) - #define WD_UNLOCK1 0xAAAA #define WD_UNLOCK2 0x5555
diff --git a/arch/arm/include/asm/arch-tegra/dc.h b/arch/arm/include/asm/arch-tegra/dc.h index 6ffb468..3a87f0b 100644 --- a/arch/arm/include/asm/arch-tegra/dc.h +++ b/arch/arm/include/asm/arch-tegra/dc.h @@ -364,8 +364,6 @@ struct dc_ctlr { struct dc_winbuf_reg winbuf; /* WINBUF A/B/C 0x800 ~ 0x80d */ };
-#define BIT(pos) (1U << pos) - /* DC_CMD_DISPLAY_COMMAND 0x032 */ #define CTRL_MODE_SHIFT 5 #define CTRL_MODE_MASK (0x3 << CTRL_MODE_SHIFT) diff --git a/arch/arm/mach-davinci/cpu.c b/arch/arm/mach-davinci/cpu.c index ff61147..74c3d5d 100644 --- a/arch/arm/mach-davinci/cpu.c +++ b/arch/arm/mach-davinci/cpu.c @@ -28,8 +28,6 @@ DECLARE_GLOBAL_DATA_PTR; #define PLLC_PLLDIV8 0x170 #define PLLC_PLLDIV9 0x174
-#define BIT(x) (1 << (x)) - /* SOC-specific pll info */ #ifdef CONFIG_SOC_DM355 #define ARM_PLLDIV PLLC_PLLDIV1 diff --git a/arch/arm/mach-keystone/include/mach/clock_defs.h b/arch/arm/mach-keystone/include/mach/clock_defs.h index 8ad371f..f8d61d6 100644 --- a/arch/arm/mach-keystone/include/mach/clock_defs.h +++ b/arch/arm/mach-keystone/include/mach/clock_defs.h @@ -11,8 +11,6 @@
-#define BIT(x) (1 << (x)) - /* PLL Control Registers */ struct pllctl_regs { u32 ctl; /* 00 */ diff --git a/arch/arm/mach-keystone/include/mach/hardware.h b/arch/arm/mach-keystone/include/mach/hardware.h index 53f28ec..f98a24e 100644 --- a/arch/arm/mach-keystone/include/mach/hardware.h +++ b/arch/arm/mach-keystone/include/mach/hardware.h @@ -24,8 +24,6 @@ typedef volatile unsigned int *dv_reg_p;
#endif
-#define BIT(x) (1 << (x)) - #define KS2_DDRPHY_PIR_OFFSET 0x04 #define KS2_DDRPHY_PGCR0_OFFSET 0x08 #define KS2_DDRPHY_PGCR1_OFFSET 0x0C diff --git a/arch/arm/mach-mvebu/include/mach/soc.h b/arch/arm/mach-mvebu/include/mach/soc.h index a8a6b27..02c21bc 100644 --- a/arch/arm/mach-mvebu/include/mach/soc.h +++ b/arch/arm/mach-mvebu/include/mach/soc.h @@ -11,8 +11,6 @@ #ifndef _MVEBU_SOC_H #define _MVEBU_SOC_H
-#define BIT(x) (1 << (x)) - #define SOC_MV78460_ID 0x7846 #define SOC_88F6810_ID 0x6810 #define SOC_88F6820_ID 0x6820 diff --git a/arch/arm/mach-zynq/include/mach/gpio.h b/arch/arm/mach-zynq/include/mach/gpio.h index 9e1e7da..0789c49 100644 --- a/arch/arm/mach-zynq/include/mach/gpio.h +++ b/arch/arm/mach-zynq/include/mach/gpio.h @@ -71,6 +71,4 @@ /* GPIO upper 16 bit mask */ #define ZYNQ_GPIO_UPPER_MASK 0xFFFF0000
-#define BIT(x) (1<<x) - #endif /* _ZYNQ_GPIO_H */ diff --git a/drivers/ddr/marvell/a38x/ddr3_init.h b/drivers/ddr/marvell/a38x/ddr3_init.h index e2ff040..cb3fb24 100644 --- a/drivers/ddr/marvell/a38x/ddr3_init.h +++ b/drivers/ddr/marvell/a38x/ddr3_init.h @@ -32,8 +32,6 @@ */ #define MV_DEBUG_INIT
-#define BIT(x) (1 << (x)) - #ifdef MV_DEBUG_INIT #define DEBUG_INIT_S(s) puts(s) #define DEBUG_INIT_D(d, l) printf("%x", d) diff --git a/drivers/mtd/nand/jz4740_nand.c b/drivers/mtd/nand/jz4740_nand.c index 7a62cc3..abcedc2 100644 --- a/drivers/mtd/nand/jz4740_nand.c +++ b/drivers/mtd/nand/jz4740_nand.c @@ -16,7 +16,6 @@ #define JZ_NAND_CMD_ADDR (JZ_NAND_DATA_ADDR + 0x8000) #define JZ_NAND_ADDR_ADDR (JZ_NAND_DATA_ADDR + 0x10000)
-#define BIT(x) (1 << (x)) #define JZ_NAND_ECC_CTRL_ENCODING BIT(3) #define JZ_NAND_ECC_CTRL_RS BIT(2) #define JZ_NAND_ECC_CTRL_RESET BIT(1) diff --git a/drivers/spi/davinci_spi.c b/drivers/spi/davinci_spi.c index 0a036cc..0bd4f88 100644 --- a/drivers/spi/davinci_spi.c +++ b/drivers/spi/davinci_spi.c @@ -15,8 +15,6 @@ #include <asm/io.h> #include <asm/arch/hardware.h>
-#define BIT(x) (1 << (x)) - /* SPIGCR0 */ #define SPIGCR0_SPIENA_MASK 0x1 #define SPIGCR0_SPIRST_MASK 0x0 diff --git a/drivers/spi/ep93xx_spi.c b/drivers/spi/ep93xx_spi.c index 235557e..cb682dd 100644 --- a/drivers/spi/ep93xx_spi.c +++ b/drivers/spi/ep93xx_spi.c @@ -16,8 +16,6 @@
#include <asm/arch/ep93xx.h>
- -#define BIT(x) (1<<(x)) #define SSPBASE SPI_BASE
#define SSPCR0 0x0000 diff --git a/drivers/video/anx9804.c b/drivers/video/anx9804.c index 83d60d6..37ad69a 100755 --- a/drivers/video/anx9804.c +++ b/drivers/video/anx9804.c @@ -14,8 +14,6 @@ #include <i2c.h> #include "anx9804.h"
-#define BIT(x) (1 << (x)) - /* Registers at i2c address 0x38 */
#define ANX9804_HDCP_CONTROL_0_REG 0x01 diff --git a/include/fsl-mc/fsl_mc.h b/include/fsl-mc/fsl_mc.h index 9106f25..9517a4a 100644 --- a/include/fsl-mc/fsl_mc.h +++ b/include/fsl-mc/fsl_mc.h @@ -12,7 +12,6 @@ #define MC_CCSR_BASE_ADDR \ ((struct mc_ccsr_registers __iomem *)0x8340000)
-#define BIT(x) (1 << (x)) #define GCR1_P1_STOP BIT(31) #define GCR1_P2_STOP BIT(30) #define GCR1_P1_DE_RST BIT(23) diff --git a/include/linux/bitops.h b/include/linux/bitops.h index e724310..7d30ace 100644 --- a/include/linux/bitops.h +++ b/include/linux/bitops.h @@ -3,6 +3,8 @@
Thanks Andreas for cleaning this up. I didn't compile test this yet, but for the mvebu related stuff:
Acked-by: Stefan Roese sr@denx.de
Thanks, Stefan
-----Original Message----- From: Andreas Bießmann [mailto:andreas.devel@googlemail.com] Sent: Monday, September 07, 2015 4:44 AM To: U-Boot ML Cc: Tom Rini; Simon Glass; Tom Warren; Stephen Warren; Lukasz Majewski; Scott Wood; Jagan Teki; Michal Simek; Prafulla Wadaskar; Anatolij Gustschin; Albert Aribaud; Heiko Schocher; Andreas Bießmann; Stuart Yoder; Andrea Scian; Marek Vasut; Hao Zhang; Steve Kipisz; Michal Simek; Lijun Pan; Lokesh Vutla; Vitaly Andrianov; Ivan"; James Doublesin; Anton Schubert; Peter Griffin; Stefan Roese; J. German Rivera; York Sun; Masahiro Yamada; Bhupesh Sharma; Kishon Vijay Abraham I; Muralidharan"; Prabhakar Kushwaha Subject: [PATCH v5] bitops: introduce BIT() definition
Acked-by Tom Warren twarren@nvidia.com for the Tegra bits. I'll apply this and start converting to BIT() in code I'm currently cleaning up. Thanks! -- nvpublic
Andreas
Changes in v5:
Changes in v3:
#endif
#define KS2_DDRPHY_PIR_OFFSET 0x04 #define KS2_DDRPHY_PGCR0_OFFSET 0x08 #define KS2_DDRPHY_PGCR1_OFFSET 0x0C diff --git a/arch/arm/mach-mvebu/include/mach/soc.h b/arch/arm/mach- mvebu/include/mach/soc.h index a8a6b27..02c21bc 100644 --- a/arch/arm/mach-mvebu/include/mach/soc.h +++ b/arch/arm/mach-mvebu/include/mach/soc.h @@ -11,8 +11,6 @@ #ifndef _MVEBU_SOC_H #define _MVEBU_SOC_H
#define SOC_MV78460_ID 0x7846 #define SOC_88F6810_ID 0x6810 #define SOC_88F6820_ID 0x6820 diff --git a/arch/arm/mach-zynq/include/mach/gpio.h b/arch/arm/mach- zynq/include/mach/gpio.h index 9e1e7da..0789c49 100644 --- a/arch/arm/mach-zynq/include/mach/gpio.h +++ b/arch/arm/mach-zynq/include/mach/gpio.h @@ -71,6 +71,4 @@ /* GPIO upper 16 bit mask */ #define ZYNQ_GPIO_UPPER_MASK 0xFFFF0000
-- 2.1.4
On Mon, 7 Sep 2015 13:43:52 +0200 Andreas Bießmann andreas.devel@googlemail.com wrote:
for anx9804 video driver
Acked-by: Anatolij Gustschin agust@denx.de
Thanks,
Anatolij
Hi, Andreas
Why UL? Why not simply 1 << (nr)? What if I need set ULL bit on 32-bit system? Thanks for explanation.
On Tue, 2015-09-08 at 21:01 +0300, ivan.khoronzhuk wrote:
Hi, Andreas
That would give the wrong result for nr == 31 if used as a 64-bit number, and would produce undefined behavior for nr >= 32 (though even with 1UL that would be undefined on 32-bit builds).
Yes, ULL would be better.
-Scott
Hi, Andreas
That would be BIT_ULL(nr) ? I want to assume that there was some care given upstream here. It was about 2 years ago now the kernel added a specific BIT_ULL and family in addition to BIT(nr) from back in 2007.
Hi, Andreas
A quick search didn't turn up much justification for keeping them separate (and it seems like using BIT where BIT_ULL is needed could be a source of difficult bugs), but sure, we don't want to encourage writing driver code that will break on Linux.
-Scott
Hi, Andreas
Better to keep same approach.
-Scott
Hi, Andreas
Did you mean with 64-bit signed number? After fast glance seems there is no places, but if they are, this can add interesting fixes.
-Scott
Hi, Andreas
No.
"u64 x = 1 << 31" will put 0xffffffff80000000 in x, because (unlike 0x80000000 as a constant) "1 << 31" is signed.
-Scott
Dear Andreas,
In message 1441626234-16364-1-git-send-email-andreas.devel@googlemail.com you wrote: ...
What happens when someone decides to use this on a 64 bit register?
Also, this definition is inherently wrong for Power Architecture (TM) systems, where bit 0 is the most significant bit.
On Wed, 2015-09-09 at 20:25 +0200, Wolfgang Denk wrote:
Dear Andreas,
It's not "inherently wrong" to number bits from LSB on such systems -- it just doesn't match the unusual convention found in PPC documentation and the rotate instructions.
In any case, this would be part of the Linux driver compatibility layer rather than the placement in common.h that you previously objected to.
-Scott
Signed-off-by: Heiko Schocher hs@denx.de [remove all other occurrences of BIT(x) definition] Signed-off-by: Andreas Bießmann andreas.devel@googlemail.com Acked-by: Stefan Roese sr@denx.de Acked-by: Anatolij Gustschin agust@denx.de
- new in v3
Changes in v2: None
Looks like few of them are interested with this BIT macro, but I'm thinking this is not the right place just add above BIT_MASK
@@ -104,6 +104,7 @@ static inline unsigned int generic_hweight8(unsigned int w) return (res & 0x0F) + ((res >> 4) & 0x0F); }
+#define BIT(nr) (1UL << (nr)) #define BIT_MASK(nr) (1UL << ((nr) % BITS_PER_LONG)) #define BIT_WORD(nr) ((nr) / BITS_PER_LONG)
this will give an impression to have all BIT macro's at once like Linux.
-- 2.1.0
thanks!
port at91_udc driver from linux:
original commit Message: commit c94e289f195e0e13cf34d27f9338d28221a85751 Author: Arnd Bergmann arnd@arndb.de Date: Sat Apr 11 00:14:21 2015 +0200
A recent change introduced a link error for the composite printer gadget driver:
`printer_unbind' referenced in section `.ref.data' of drivers/built-in.o: defined in discarded section `.exit.text' of drivers/built-in.o
Evidently the unbind function should not be marked __exit here, because it is called through a callback pointer that is not necessarily discarded, __composite_unbind() is indeed called from the error path of composite_bind(), which can never work for a built-in driver.
Looking at the surrounding code, I found the same problem in all other composite gadget drivers in both the bind and unbind functions, as well as the udc platform driver 'remove' functions. Those will break if anyone uses the 'unbind' sysfs attribute to detach a device from a built-in driver.
This patch removes the incorrect annotations from all the gadget drivers.
Signed-off-by: Heiko Schocher hs@denx.de --- checkpatch detects a lot of errors, but as this code is copied from linux, I tend to not fix them, so later updates with linux code is easier.
Changes in v4: None Changes in v3: - add comments from Alexandre Belloni get rid of cpu_is_at91*, use newer linux version as base for the port to U-Boot.
drivers/usb/gadget/at91_udc.c | 2036 +++++++++++++++++++++++++++++++++++++++++ drivers/usb/gadget/at91_udc.h | 175 ++++ 2 files changed, 2211 insertions(+) create mode 100644 drivers/usb/gadget/at91_udc.c create mode 100644 drivers/usb/gadget/at91_udc.h
diff --git a/drivers/usb/gadget/at91_udc.c b/drivers/usb/gadget/at91_udc.c new file mode 100644 index 0000000..fc42264 --- /dev/null +++ b/drivers/usb/gadget/at91_udc.c @@ -0,0 +1,2036 @@ +/* + * at91_udc -- driver for at91-series USB peripheral controller + * + * Copyright (C) 2004 by Thomas Rathbone + * Copyright (C) 2005 by HP Labs + * Copyright (C) 2005 by David Brownell + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + */ + +#undef VERBOSE_DEBUG +#undef PACKET_TRACE + +#include <linux/kernel.h> +#include <linux/module.h> +#include <linux/platform_device.h> +#include <linux/delay.h> +#include <linux/ioport.h> +#include <linux/slab.h> +#include <linux/errno.h> +#include <linux/list.h> +#include <linux/interrupt.h> +#include <linux/proc_fs.h> +#include <linux/prefetch.h> +#include <linux/clk.h> +#include <linux/usb/ch9.h> +#include <linux/usb/gadget.h> +#include <linux/of.h> +#include <linux/of_gpio.h> +#include <linux/platform_data/atmel.h> +#include <linux/regmap.h> +#include <linux/mfd/syscon.h> +#include <linux/mfd/syscon/atmel-matrix.h> + +#include "at91_udc.h" + + +/* + * This controller is simple and PIO-only. It's used in many AT91-series + * full speed USB controllers, including the at91rm9200 (arm920T, with MMU), + * at91sam926x (arm926ejs, with MMU), and several no-mmu versions. + * + * This driver expects the board has been wired with two GPIOs supporting + * a VBUS sensing IRQ, and a D+ pullup. (They may be omitted, but the + * testing hasn't covered such cases.) + * + * The pullup is most important (so it's integrated on sam926x parts). It + * provides software control over whether the host enumerates the device. + * + * The VBUS sensing helps during enumeration, and allows both USB clocks + * (and the transceiver) to stay gated off until they're necessary, saving + * power. During USB suspend, the 48 MHz clock is gated off in hardware; + * it may also be gated off by software during some Linux sleep states. + */ + +#define DRIVER_VERSION "3 May 2006" + +static const char driver_name [] = "at91_udc"; +static const char * const ep_names[] = { + "ep0", + "ep1", + "ep2", + "ep3-int", + "ep4", + "ep5", +}; +#define ep0name ep_names[0] + +#define VBUS_POLL_TIMEOUT msecs_to_jiffies(1000) + +#define at91_udp_read(udc, reg) \ + __raw_readl((udc)->udp_baseaddr + (reg)) +#define at91_udp_write(udc, reg, val) \ + __raw_writel((val), (udc)->udp_baseaddr + (reg)) + +/*-------------------------------------------------------------------------*/ + +#ifdef CONFIG_USB_GADGET_DEBUG_FILES + +#include <linux/seq_file.h> + +static const char debug_filename[] = "driver/udc"; + +#define FOURBITS "%s%s%s%s" +#define EIGHTBITS FOURBITS FOURBITS + +static void proc_ep_show(struct seq_file *s, struct at91_ep *ep) +{ + static char *types[] = { + "control", "out-iso", "out-bulk", "out-int", + "BOGUS", "in-iso", "in-bulk", "in-int"}; + + u32 csr; + struct at91_request *req; + unsigned long flags; + struct at91_udc *udc = ep->udc; + + spin_lock_irqsave(&udc->lock, flags); + + csr = __raw_readl(ep->creg); + + /* NOTE: not collecting per-endpoint irq statistics... */ + + seq_printf(s, "\n"); + seq_printf(s, "%s, maxpacket %d %s%s %s%s\n", + ep->ep.name, ep->ep.maxpacket, + ep->is_in ? "in" : "out", + ep->is_iso ? " iso" : "", + ep->is_pingpong + ? (ep->fifo_bank ? "pong" : "ping") + : "", + ep->stopped ? " stopped" : ""); + seq_printf(s, "csr %08x rxbytes=%d %s %s %s" EIGHTBITS "\n", + csr, + (csr & 0x07ff0000) >> 16, + (csr & (1 << 15)) ? "enabled" : "disabled", + (csr & (1 << 11)) ? "DATA1" : "DATA0", + types[(csr & 0x700) >> 8], + + /* iff type is control then print current direction */ + (!(csr & 0x700)) + ? ((csr & (1 << 7)) ? " IN" : " OUT") + : "", + (csr & (1 << 6)) ? " rxdatabk1" : "", + (csr & (1 << 5)) ? " forcestall" : "", + (csr & (1 << 4)) ? " txpktrdy" : "", + + (csr & (1 << 3)) ? " stallsent" : "", + (csr & (1 << 2)) ? " rxsetup" : "", + (csr & (1 << 1)) ? " rxdatabk0" : "", + (csr & (1 << 0)) ? " txcomp" : ""); + if (list_empty (&ep->queue)) + seq_printf(s, "\t(queue empty)\n"); + + else list_for_each_entry (req, &ep->queue, queue) { + unsigned length = req->req.actual; + + seq_printf(s, "\treq %p len %d/%d buf %p\n", + &req->req, length, + req->req.length, req->req.buf); + } + spin_unlock_irqrestore(&udc->lock, flags); +} + +static void proc_irq_show(struct seq_file *s, const char *label, u32 mask) +{ + int i; + + seq_printf(s, "%s %04x:%s%s" FOURBITS, label, mask, + (mask & (1 << 13)) ? " wakeup" : "", + (mask & (1 << 12)) ? " endbusres" : "", + + (mask & (1 << 11)) ? " sofint" : "", + (mask & (1 << 10)) ? " extrsm" : "", + (mask & (1 << 9)) ? " rxrsm" : "", + (mask & (1 << 8)) ? " rxsusp" : ""); + for (i = 0; i < 8; i++) { + if (mask & (1 << i)) + seq_printf(s, " ep%d", i); + } + seq_printf(s, "\n"); +} + +static int proc_udc_show(struct seq_file *s, void *unused) +{ + struct at91_udc *udc = s->private; + struct at91_ep *ep; + u32 tmp; + + seq_printf(s, "%s: version %s\n", driver_name, DRIVER_VERSION); + + seq_printf(s, "vbus %s, pullup %s, %s powered%s, gadget %s\n\n", + udc->vbus ? "present" : "off", + udc->enabled + ? (udc->vbus ? "active" : "enabled") + : "disabled", + udc->gadget.is_selfpowered ? "self" : "VBUS", + udc->suspended ? ", suspended" : "", + udc->driver ? udc->driver->driver.name : "(none)"); + + /* don't access registers when interface isn't clocked */ + if (!udc->clocked) { + seq_printf(s, "(not clocked)\n"); + return 0; + } + + tmp = at91_udp_read(udc, AT91_UDP_FRM_NUM); + seq_printf(s, "frame %05x:%s%s frame=%d\n", tmp, + (tmp & AT91_UDP_FRM_OK) ? " ok" : "", + (tmp & AT91_UDP_FRM_ERR) ? " err" : "", + (tmp & AT91_UDP_NUM)); + + tmp = at91_udp_read(udc, AT91_UDP_GLB_STAT); + seq_printf(s, "glbstate %02x:%s" FOURBITS "\n", tmp, + (tmp & AT91_UDP_RMWUPE) ? " rmwupe" : "", + (tmp & AT91_UDP_RSMINPR) ? " rsminpr" : "", + (tmp & AT91_UDP_ESR) ? " esr" : "", + (tmp & AT91_UDP_CONFG) ? " confg" : "", + (tmp & AT91_UDP_FADDEN) ? " fadden" : ""); + + tmp = at91_udp_read(udc, AT91_UDP_FADDR); + seq_printf(s, "faddr %03x:%s fadd=%d\n", tmp, + (tmp & AT91_UDP_FEN) ? " fen" : "", + (tmp & AT91_UDP_FADD)); + + proc_irq_show(s, "imr ", at91_udp_read(udc, AT91_UDP_IMR)); + proc_irq_show(s, "isr ", at91_udp_read(udc, AT91_UDP_ISR)); + + if (udc->enabled && udc->vbus) { + proc_ep_show(s, &udc->ep[0]); + list_for_each_entry (ep, &udc->gadget.ep_list, ep.ep_list) { + if (ep->ep.desc) + proc_ep_show(s, ep); + } + } + return 0; +} + +static int proc_udc_open(struct inode *inode, struct file *file) +{ + return single_open(file, proc_udc_show, PDE_DATA(inode)); +} + +static const struct file_operations proc_ops = { + .owner = THIS_MODULE, + .open = proc_udc_open, + .read = seq_read, + .llseek = seq_lseek, + .release = single_release, +}; + +static void create_debug_file(struct at91_udc *udc) +{ + udc->pde = proc_create_data(debug_filename, 0, NULL, &proc_ops, udc); +} + +static void remove_debug_file(struct at91_udc *udc) +{ + if (udc->pde) + remove_proc_entry(debug_filename, NULL); +} + +#else + +static inline void create_debug_file(struct at91_udc *udc) {} +static inline void remove_debug_file(struct at91_udc *udc) {} + +#endif + + +/*-------------------------------------------------------------------------*/ + +static void done(struct at91_ep *ep, struct at91_request *req, int status) +{ + unsigned stopped = ep->stopped; + struct at91_udc *udc = ep->udc; + + list_del_init(&req->queue); + if (req->req.status == -EINPROGRESS) + req->req.status = status; + else + status = req->req.status; + if (status && status != -ESHUTDOWN) + VDBG("%s done %p, status %d\n", ep->ep.name, req, status); + + ep->stopped = 1; + spin_unlock(&udc->lock); + usb_gadget_giveback_request(&ep->ep, &req->req); + spin_lock(&udc->lock); + ep->stopped = stopped; + + /* ep0 is always ready; other endpoints need a non-empty queue */ + if (list_empty(&ep->queue) && ep->int_mask != (1 << 0)) + at91_udp_write(udc, AT91_UDP_IDR, ep->int_mask); +} + +/*-------------------------------------------------------------------------*/ + +/* bits indicating OUT fifo has data ready */ +#define RX_DATA_READY (AT91_UDP_RX_DATA_BK0 | AT91_UDP_RX_DATA_BK1) + +/* + * Endpoint FIFO CSR bits have a mix of bits, making it unsafe to just write + * back most of the value you just read (because of side effects, including + * bits that may change after reading and before writing). + * + * Except when changing a specific bit, always write values which: + * - clear SET_FX bits (setting them could change something) + * - set CLR_FX bits (clearing them could change something) + * + * There are also state bits like FORCESTALL, EPEDS, DIR, and EPTYPE + * that shouldn't normally be changed. + * + * NOTE at91sam9260 docs mention synch between UDPCK and MCK clock domains, + * implying a need to wait for one write to complete (test relevant bits) + * before starting the next write. This shouldn't be an issue given how + * infrequently we write, except maybe for write-then-read idioms. + */ +#define SET_FX (AT91_UDP_TXPKTRDY) +#define CLR_FX (RX_DATA_READY | AT91_UDP_RXSETUP \ + | AT91_UDP_STALLSENT | AT91_UDP_TXCOMP) + +/* pull OUT packet data from the endpoint's fifo */ +static int read_fifo (struct at91_ep *ep, struct at91_request *req) +{ + u32 __iomem *creg = ep->creg; + u8 __iomem *dreg = ep->creg + (AT91_UDP_FDR(0) - AT91_UDP_CSR(0)); + u32 csr; + u8 *buf; + unsigned int count, bufferspace, is_done; + + buf = req->req.buf + req->req.actual; + bufferspace = req->req.length - req->req.actual; + + /* + * there might be nothing to read if ep_queue() calls us, + * or if we already emptied both pingpong buffers + */ +rescan: + csr = __raw_readl(creg); + if ((csr & RX_DATA_READY) == 0) + return 0; + + count = (csr & AT91_UDP_RXBYTECNT) >> 16; + if (count > ep->ep.maxpacket) + count = ep->ep.maxpacket; + if (count > bufferspace) { + DBG("%s buffer overflow\n", ep->ep.name); + req->req.status = -EOVERFLOW; + count = bufferspace; + } + __raw_readsb(dreg, buf, count); + + /* release and swap pingpong mem bank */ + csr |= CLR_FX; + if (ep->is_pingpong) { + if (ep->fifo_bank == 0) { + csr &= ~(SET_FX | AT91_UDP_RX_DATA_BK0); + ep->fifo_bank = 1; + } else { + csr &= ~(SET_FX | AT91_UDP_RX_DATA_BK1); + ep->fifo_bank = 0; + } + } else + csr &= ~(SET_FX | AT91_UDP_RX_DATA_BK0); + __raw_writel(csr, creg); + + req->req.actual += count; + is_done = (count < ep->ep.maxpacket); + if (count == bufferspace) + is_done = 1; + + PACKET("%s %p out/%d%s\n", ep->ep.name, &req->req, count, + is_done ? " (done)" : ""); + + /* + * avoid extra trips through IRQ logic for packets already in + * the fifo ... maybe preventing an extra (expensive) OUT-NAK + */ + if (is_done) + done(ep, req, 0); + else if (ep->is_pingpong) { + /* + * One dummy read to delay the code because of a HW glitch: + * CSR returns bad RXCOUNT when read too soon after updating + * RX_DATA_BK flags. + */ + csr = __raw_readl(creg); + + bufferspace -= count; + buf += count; + goto rescan; + } + + return is_done; +} + +/* load fifo for an IN packet */ +static int write_fifo(struct at91_ep *ep, struct at91_request *req) +{ + u32 __iomem *creg = ep->creg; + u32 csr = __raw_readl(creg); + u8 __iomem *dreg = ep->creg + (AT91_UDP_FDR(0) - AT91_UDP_CSR(0)); + unsigned total, count, is_last; + u8 *buf; + + /* + * TODO: allow for writing two packets to the fifo ... that'll + * reduce the amount of IN-NAKing, but probably won't affect + * throughput much. (Unlike preventing OUT-NAKing!) + */ + + /* + * If ep_queue() calls us, the queue is empty and possibly in + * odd states like TXCOMP not yet cleared (we do it, saving at + * least one IRQ) or the fifo not yet being free. Those aren't + * issues normally (IRQ handler fast path). + */ + if (unlikely(csr & (AT91_UDP_TXCOMP | AT91_UDP_TXPKTRDY))) { + if (csr & AT91_UDP_TXCOMP) { + csr |= CLR_FX; + csr &= ~(SET_FX | AT91_UDP_TXCOMP); + __raw_writel(csr, creg); + csr = __raw_readl(creg); + } + if (csr & AT91_UDP_TXPKTRDY) + return 0; + } + + buf = req->req.buf + req->req.actual; + prefetch(buf); + total = req->req.length - req->req.actual; + if (ep->ep.maxpacket < total) { + count = ep->ep.maxpacket; + is_last = 0; + } else { + count = total; + is_last = (count < ep->ep.maxpacket) || !req->req.zero; + } + + /* + * Write the packet, maybe it's a ZLP. + * + * NOTE: incrementing req->actual before we receive the ACK means + * gadget driver IN bytecounts can be wrong in fault cases. That's + * fixable with PIO drivers like this one (save "count" here, and + * do the increment later on TX irq), but not for most DMA hardware. + * + * So all gadget drivers must accept that potential error. Some + * hardware supports precise fifo status reporting, letting them + * recover when the actual bytecount matters (e.g. for USB Test + * and Measurement Class devices). + */ + __raw_writesb(dreg, buf, count); + csr &= ~SET_FX; + csr |= CLR_FX | AT91_UDP_TXPKTRDY; + __raw_writel(csr, creg); + req->req.actual += count; + + PACKET("%s %p in/%d%s\n", ep->ep.name, &req->req, count, + is_last ? " (done)" : ""); + if (is_last) + done(ep, req, 0); + return is_last; +} + +static void nuke(struct at91_ep *ep, int status) +{ + struct at91_request *req; + + /* terminate any request in the queue */ + ep->stopped = 1; + if (list_empty(&ep->queue)) + return; + + VDBG("%s %s\n", __func__, ep->ep.name); + while (!list_empty(&ep->queue)) { + req = list_entry(ep->queue.next, struct at91_request, queue); + done(ep, req, status); + } +} + +/*-------------------------------------------------------------------------*/ + +static int at91_ep_enable(struct usb_ep *_ep, + const struct usb_endpoint_descriptor *desc) +{ + struct at91_ep *ep = container_of(_ep, struct at91_ep, ep); + struct at91_udc *udc; + u16 maxpacket; + u32 tmp; + unsigned long flags; + + if (!_ep || !ep + || !desc || _ep->name == ep0name + || desc->bDescriptorType != USB_DT_ENDPOINT + || (maxpacket = usb_endpoint_maxp(desc)) == 0 + || maxpacket > ep->maxpacket) { + DBG("bad ep or descriptor\n"); + return -EINVAL; + } + + udc = ep->udc; + if (!udc->driver || udc->gadget.speed == USB_SPEED_UNKNOWN) { + DBG("bogus device state\n"); + return -ESHUTDOWN; + } + + tmp = usb_endpoint_type(desc); + switch (tmp) { + case USB_ENDPOINT_XFER_CONTROL: + DBG("only one control endpoint\n"); + return -EINVAL; + case USB_ENDPOINT_XFER_INT: + if (maxpacket > 64) + goto bogus_max; + break; + case USB_ENDPOINT_XFER_BULK: + switch (maxpacket) { + case 8: + case 16: + case 32: + case 64: + goto ok; + } +bogus_max: + DBG("bogus maxpacket %d\n", maxpacket); + return -EINVAL; + case USB_ENDPOINT_XFER_ISOC: + if (!ep->is_pingpong) { + DBG("iso requires double buffering\n"); + return -EINVAL; + } + break; + } + +ok: + spin_lock_irqsave(&udc->lock, flags); + + /* initialize endpoint to match this descriptor */ + ep->is_in = usb_endpoint_dir_in(desc); + ep->is_iso = (tmp == USB_ENDPOINT_XFER_ISOC); + ep->stopped = 0; + if (ep->is_in) + tmp |= 0x04; + tmp <<= 8; + tmp |= AT91_UDP_EPEDS; + __raw_writel(tmp, ep->creg); + + ep->ep.maxpacket = maxpacket; + + /* + * reset/init endpoint fifo. NOTE: leaves fifo_bank alone, + * since endpoint resets don't reset hw pingpong state. + */ + at91_udp_write(udc, AT91_UDP_RST_EP, ep->int_mask); + at91_udp_write(udc, AT91_UDP_RST_EP, 0); + + spin_unlock_irqrestore(&udc->lock, flags); + return 0; +} + +static int at91_ep_disable (struct usb_ep * _ep) +{ + struct at91_ep *ep = container_of(_ep, struct at91_ep, ep); + struct at91_udc *udc = ep->udc; + unsigned long flags; + + if (ep == &ep->udc->ep[0]) + return -EINVAL; + + spin_lock_irqsave(&udc->lock, flags); + + nuke(ep, -ESHUTDOWN); + + /* restore the endpoint's pristine config */ + ep->ep.desc = NULL; + ep->ep.maxpacket = ep->maxpacket; + + /* reset fifos and endpoint */ + if (ep->udc->clocked) { + at91_udp_write(udc, AT91_UDP_RST_EP, ep->int_mask); + at91_udp_write(udc, AT91_UDP_RST_EP, 0); + __raw_writel(0, ep->creg); + } + + spin_unlock_irqrestore(&udc->lock, flags); + return 0; +} + +/* + * this is a PIO-only driver, so there's nothing + * interesting for request or buffer allocation. + */ + +static struct usb_request * +at91_ep_alloc_request(struct usb_ep *_ep, gfp_t gfp_flags) +{ + struct at91_request *req; + + req = kzalloc(sizeof (struct at91_request), gfp_flags); + if (!req) + return NULL; + + INIT_LIST_HEAD(&req->queue); + return &req->req; +} + +static void at91_ep_free_request(struct usb_ep *_ep, struct usb_request *_req) +{ + struct at91_request *req; + + req = container_of(_req, struct at91_request, req); + BUG_ON(!list_empty(&req->queue)); + kfree(req); +} + +static int at91_ep_queue(struct usb_ep *_ep, + struct usb_request *_req, gfp_t gfp_flags) +{ + struct at91_request *req; + struct at91_ep *ep; + struct at91_udc *udc; + int status; + unsigned long flags; + + req = container_of(_req, struct at91_request, req); + ep = container_of(_ep, struct at91_ep, ep); + + if (!_req || !_req->complete + || !_req->buf || !list_empty(&req->queue)) { + DBG("invalid request\n"); + return -EINVAL; + } + + if (!_ep || (!ep->ep.desc && ep->ep.name != ep0name)) { + DBG("invalid ep\n"); + return -EINVAL; + } + + udc = ep->udc; + + if (!udc || !udc->driver || udc->gadget.speed == USB_SPEED_UNKNOWN) { + DBG("invalid device\n"); + return -EINVAL; + } + + _req->status = -EINPROGRESS; + _req->actual = 0; + + spin_lock_irqsave(&udc->lock, flags); + + /* try to kickstart any empty and idle queue */ + if (list_empty(&ep->queue) && !ep->stopped) { + int is_ep0; + + /* + * If this control request has a non-empty DATA stage, this + * will start that stage. It works just like a non-control + * request (until the status stage starts, maybe early). + * + * If the data stage is empty, then this starts a successful + * IN/STATUS stage. (Unsuccessful ones use set_halt.) + */ + is_ep0 = (ep->ep.name == ep0name); + if (is_ep0) { + u32 tmp; + + if (!udc->req_pending) { + status = -EINVAL; + goto done; + } + + /* + * defer changing CONFG until after the gadget driver + * reconfigures the endpoints. + */ + if (udc->wait_for_config_ack) { + tmp = at91_udp_read(udc, AT91_UDP_GLB_STAT); + tmp ^= AT91_UDP_CONFG; + VDBG("toggle config\n"); + at91_udp_write(udc, AT91_UDP_GLB_STAT, tmp); + } + if (req->req.length == 0) { +ep0_in_status: + PACKET("ep0 in/status\n"); + status = 0; + tmp = __raw_readl(ep->creg); + tmp &= ~SET_FX; + tmp |= CLR_FX | AT91_UDP_TXPKTRDY; + __raw_writel(tmp, ep->creg); + udc->req_pending = 0; + goto done; + } + } + + if (ep->is_in) + status = write_fifo(ep, req); + else { + status = read_fifo(ep, req); + + /* IN/STATUS stage is otherwise triggered by irq */ + if (status && is_ep0) + goto ep0_in_status; + } + } else + status = 0; + + if (req && !status) { + list_add_tail (&req->queue, &ep->queue); + at91_udp_write(udc, AT91_UDP_IER, ep->int_mask); + } +done: + spin_unlock_irqrestore(&udc->lock, flags); + return (status < 0) ? status : 0; +} + +static int at91_ep_dequeue(struct usb_ep *_ep, struct usb_request *_req) +{ + struct at91_ep *ep; + struct at91_request *req; + unsigned long flags; + struct at91_udc *udc; + + ep = container_of(_ep, struct at91_ep, ep); + if (!_ep || ep->ep.name == ep0name) + return -EINVAL; + + udc = ep->udc; + + spin_lock_irqsave(&udc->lock, flags); + + /* make sure it's actually queued on this endpoint */ + list_for_each_entry (req, &ep->queue, queue) { + if (&req->req == _req) + break; + } + if (&req->req != _req) { + spin_unlock_irqrestore(&udc->lock, flags); + return -EINVAL; + } + + done(ep, req, -ECONNRESET); + spin_unlock_irqrestore(&udc->lock, flags); + return 0; +} + +static int at91_ep_set_halt(struct usb_ep *_ep, int value) +{ + struct at91_ep *ep = container_of(_ep, struct at91_ep, ep); + struct at91_udc *udc = ep->udc; + u32 __iomem *creg; + u32 csr; + unsigned long flags; + int status = 0; + + if (!_ep || ep->is_iso || !ep->udc->clocked) + return -EINVAL; + + creg = ep->creg; + spin_lock_irqsave(&udc->lock, flags); + + csr = __raw_readl(creg); + + /* + * fail with still-busy IN endpoints, ensuring correct sequencing + * of data tx then stall. note that the fifo rx bytecount isn't + * completely accurate as a tx bytecount. + */ + if (ep->is_in && (!list_empty(&ep->queue) || (csr >> 16) != 0)) + status = -EAGAIN; + else { + csr |= CLR_FX; + csr &= ~SET_FX; + if (value) { + csr |= AT91_UDP_FORCESTALL; + VDBG("halt %s\n", ep->ep.name); + } else { + at91_udp_write(udc, AT91_UDP_RST_EP, ep->int_mask); + at91_udp_write(udc, AT91_UDP_RST_EP, 0); + csr &= ~AT91_UDP_FORCESTALL; + } + __raw_writel(csr, creg); + } + + spin_unlock_irqrestore(&udc->lock, flags); + return status; +} + +static const struct usb_ep_ops at91_ep_ops = { + .enable = at91_ep_enable, + .disable = at91_ep_disable, + .alloc_request = at91_ep_alloc_request, + .free_request = at91_ep_free_request, + .queue = at91_ep_queue, + .dequeue = at91_ep_dequeue, + .set_halt = at91_ep_set_halt, + /* there's only imprecise fifo status reporting */ +}; + +/*-------------------------------------------------------------------------*/ + +static int at91_get_frame(struct usb_gadget *gadget) +{ + struct at91_udc *udc = to_udc(gadget); + + if (!to_udc(gadget)->clocked) + return -EINVAL; + return at91_udp_read(udc, AT91_UDP_FRM_NUM) & AT91_UDP_NUM; +} + +static int at91_wakeup(struct usb_gadget *gadget) +{ + struct at91_udc *udc = to_udc(gadget); + u32 glbstate; + int status = -EINVAL; + unsigned long flags; + + DBG("%s\n", __func__ ); + spin_lock_irqsave(&udc->lock, flags); + + if (!udc->clocked || !udc->suspended) + goto done; + + /* NOTE: some "early versions" handle ESR differently ... */ + + glbstate = at91_udp_read(udc, AT91_UDP_GLB_STAT); + if (!(glbstate & AT91_UDP_ESR)) + goto done; + glbstate |= AT91_UDP_ESR; + at91_udp_write(udc, AT91_UDP_GLB_STAT, glbstate); + +done: + spin_unlock_irqrestore(&udc->lock, flags); + return status; +} + +/* reinit == restore initial software state */ +static void udc_reinit(struct at91_udc *udc) +{ + u32 i; + + INIT_LIST_HEAD(&udc->gadget.ep_list); + INIT_LIST_HEAD(&udc->gadget.ep0->ep_list); + + for (i = 0; i < NUM_ENDPOINTS; i++) { + struct at91_ep *ep = &udc->ep[i]; + + if (i != 0) + list_add_tail(&ep->ep.ep_list, &udc->gadget.ep_list); + ep->ep.desc = NULL; + ep->stopped = 0; + ep->fifo_bank = 0; + usb_ep_set_maxpacket_limit(&ep->ep, ep->maxpacket); + ep->creg = (void __iomem *) udc->udp_baseaddr + AT91_UDP_CSR(i); + /* initialize one queue per endpoint */ + INIT_LIST_HEAD(&ep->queue); + } +} + +static void reset_gadget(struct at91_udc *udc) +{ + struct usb_gadget_driver *driver = udc->driver; + int i; + + if (udc->gadget.speed == USB_SPEED_UNKNOWN) + driver = NULL; + udc->gadget.speed = USB_SPEED_UNKNOWN; + udc->suspended = 0; + + for (i = 0; i < NUM_ENDPOINTS; i++) { + struct at91_ep *ep = &udc->ep[i]; + + ep->stopped = 1; + nuke(ep, -ESHUTDOWN); + } + if (driver) { + spin_unlock(&udc->lock); + usb_gadget_udc_reset(&udc->gadget, driver); + spin_lock(&udc->lock); + } + + udc_reinit(udc); +} + +static void stop_activity(struct at91_udc *udc) +{ + struct usb_gadget_driver *driver = udc->driver; + int i; + + if (udc->gadget.speed == USB_SPEED_UNKNOWN) + driver = NULL; + udc->gadget.speed = USB_SPEED_UNKNOWN; + udc->suspended = 0; + + for (i = 0; i < NUM_ENDPOINTS; i++) { + struct at91_ep *ep = &udc->ep[i]; + ep->stopped = 1; + nuke(ep, -ESHUTDOWN); + } + if (driver) { + spin_unlock(&udc->lock); + driver->disconnect(&udc->gadget); + spin_lock(&udc->lock); + } + + udc_reinit(udc); +} + +static void clk_on(struct at91_udc *udc) +{ + if (udc->clocked) + return; + udc->clocked = 1; + + clk_enable(udc->iclk); + clk_enable(udc->fclk); +} + +static void clk_off(struct at91_udc *udc) +{ + if (!udc->clocked) + return; + udc->clocked = 0; + udc->gadget.speed = USB_SPEED_UNKNOWN; + clk_disable(udc->fclk); + clk_disable(udc->iclk); +} + +/* + * activate/deactivate link with host; minimize power usage for + * inactive links by cutting clocks and transceiver power. + */ +static void pullup(struct at91_udc *udc, int is_on) +{ + if (!udc->enabled || !udc->vbus) + is_on = 0; + DBG("%sactive\n", is_on ? "" : "in"); + + if (is_on) { + clk_on(udc); + at91_udp_write(udc, AT91_UDP_ICR, AT91_UDP_RXRSM); + at91_udp_write(udc, AT91_UDP_TXVC, 0); + } else { + stop_activity(udc); + at91_udp_write(udc, AT91_UDP_IDR, AT91_UDP_RXRSM); + at91_udp_write(udc, AT91_UDP_TXVC, AT91_UDP_TXVC_TXVDIS); + clk_off(udc); + } + + if (udc->caps && udc->caps->pullup) + udc->caps->pullup(udc, is_on); +} + +/* vbus is here! turn everything on that's ready */ +static int at91_vbus_session(struct usb_gadget *gadget, int is_active) +{ + struct at91_udc *udc = to_udc(gadget); + unsigned long flags; + + /* VDBG("vbus %s\n", is_active ? "on" : "off"); */ + spin_lock_irqsave(&udc->lock, flags); + udc->vbus = (is_active != 0); + if (udc->driver) + pullup(udc, is_active); + else + pullup(udc, 0); + spin_unlock_irqrestore(&udc->lock, flags); + return 0; +} + +static int at91_pullup(struct usb_gadget *gadget, int is_on) +{ + struct at91_udc *udc = to_udc(gadget); + unsigned long flags; + + spin_lock_irqsave(&udc->lock, flags); + udc->enabled = is_on = !!is_on; + pullup(udc, is_on); + spin_unlock_irqrestore(&udc->lock, flags); + return 0; +} + +static int at91_set_selfpowered(struct usb_gadget *gadget, int is_on) +{ + struct at91_udc *udc = to_udc(gadget); + unsigned long flags; + + spin_lock_irqsave(&udc->lock, flags); + gadget->is_selfpowered = (is_on != 0); + spin_unlock_irqrestore(&udc->lock, flags); + return 0; +} + +static int at91_start(struct usb_gadget *gadget, + struct usb_gadget_driver *driver); +static int at91_stop(struct usb_gadget *gadget); + +static const struct usb_gadget_ops at91_udc_ops = { + .get_frame = at91_get_frame, + .wakeup = at91_wakeup, + .set_selfpowered = at91_set_selfpowered, + .vbus_session = at91_vbus_session, + .pullup = at91_pullup, + .udc_start = at91_start, + .udc_stop = at91_stop, + + /* + * VBUS-powered devices may also also want to support bigger + * power budgets after an appropriate SET_CONFIGURATION. + */ + /* .vbus_power = at91_vbus_power, */ +}; + +/*-------------------------------------------------------------------------*/ + +static int handle_ep(struct at91_ep *ep) +{ + struct at91_request *req; + u32 __iomem *creg = ep->creg; + u32 csr = __raw_readl(creg); + + if (!list_empty(&ep->queue)) + req = list_entry(ep->queue.next, + struct at91_request, queue); + else + req = NULL; + + if (ep->is_in) { + if (csr & (AT91_UDP_STALLSENT | AT91_UDP_TXCOMP)) { + csr |= CLR_FX; + csr &= ~(SET_FX | AT91_UDP_STALLSENT | AT91_UDP_TXCOMP); + __raw_writel(csr, creg); + } + if (req) + return write_fifo(ep, req); + + } else { + if (csr & AT91_UDP_STALLSENT) { + /* STALLSENT bit == ISOERR */ + if (ep->is_iso && req) + req->req.status = -EILSEQ; + csr |= CLR_FX; + csr &= ~(SET_FX | AT91_UDP_STALLSENT); + __raw_writel(csr, creg); + csr = __raw_readl(creg); + } + if (req && (csr & RX_DATA_READY)) + return read_fifo(ep, req); + } + return 0; +} + +union setup { + u8 raw[8]; + struct usb_ctrlrequest r; +}; + +static void handle_setup(struct at91_udc *udc, struct at91_ep *ep, u32 csr) +{ + u32 __iomem *creg = ep->creg; + u8 __iomem *dreg = ep->creg + (AT91_UDP_FDR(0) - AT91_UDP_CSR(0)); + unsigned rxcount, i = 0; + u32 tmp; + union setup pkt; + int status = 0; + + /* read and ack SETUP; hard-fail for bogus packets */ + rxcount = (csr & AT91_UDP_RXBYTECNT) >> 16; + if (likely(rxcount == 8)) { + while (rxcount--) + pkt.raw[i++] = __raw_readb(dreg); + if (pkt.r.bRequestType & USB_DIR_IN) { + csr |= AT91_UDP_DIR; + ep->is_in = 1; + } else { + csr &= ~AT91_UDP_DIR; + ep->is_in = 0; + } + } else { + /* REVISIT this happens sometimes under load; why?? */ + ERR("SETUP len %d, csr %08x\n", rxcount, csr); + status = -EINVAL; + } + csr |= CLR_FX; + csr &= ~(SET_FX | AT91_UDP_RXSETUP); + __raw_writel(csr, creg); + udc->wait_for_addr_ack = 0; + udc->wait_for_config_ack = 0; + ep->stopped = 0; + if (unlikely(status != 0)) + goto stall; + +#define w_index le16_to_cpu(pkt.r.wIndex) +#define w_value le16_to_cpu(pkt.r.wValue) +#define w_length le16_to_cpu(pkt.r.wLength) + + VDBG("SETUP %02x.%02x v%04x i%04x l%04x\n", + pkt.r.bRequestType, pkt.r.bRequest, + w_value, w_index, w_length); + + /* + * A few standard requests get handled here, ones that touch + * hardware ... notably for device and endpoint features. + */ + udc->req_pending = 1; + csr = __raw_readl(creg); + csr |= CLR_FX; + csr &= ~SET_FX; + switch ((pkt.r.bRequestType << 8) | pkt.r.bRequest) { + + case ((USB_TYPE_STANDARD|USB_RECIP_DEVICE) << 8) + | USB_REQ_SET_ADDRESS: + __raw_writel(csr | AT91_UDP_TXPKTRDY, creg); + udc->addr = w_value; + udc->wait_for_addr_ack = 1; + udc->req_pending = 0; + /* FADDR is set later, when we ack host STATUS */ + return; + + case ((USB_TYPE_STANDARD|USB_RECIP_DEVICE) << 8) + | USB_REQ_SET_CONFIGURATION: + tmp = at91_udp_read(udc, AT91_UDP_GLB_STAT) & AT91_UDP_CONFG; + if (pkt.r.wValue) + udc->wait_for_config_ack = (tmp == 0); + else + udc->wait_for_config_ack = (tmp != 0); + if (udc->wait_for_config_ack) + VDBG("wait for config\n"); + /* CONFG is toggled later, if gadget driver succeeds */ + break; + + /* + * Hosts may set or clear remote wakeup status, and + * devices may report they're VBUS powered. + */ + case ((USB_DIR_IN|USB_TYPE_STANDARD|USB_RECIP_DEVICE) << 8) + | USB_REQ_GET_STATUS: + tmp = (udc->gadget.is_selfpowered << USB_DEVICE_SELF_POWERED); + if (at91_udp_read(udc, AT91_UDP_GLB_STAT) & AT91_UDP_ESR) + tmp |= (1 << USB_DEVICE_REMOTE_WAKEUP); + PACKET("get device status\n"); + __raw_writeb(tmp, dreg); + __raw_writeb(0, dreg); + goto write_in; + /* then STATUS starts later, automatically */ + case ((USB_TYPE_STANDARD|USB_RECIP_DEVICE) << 8) + | USB_REQ_SET_FEATURE: + if (w_value != USB_DEVICE_REMOTE_WAKEUP) + goto stall; + tmp = at91_udp_read(udc, AT91_UDP_GLB_STAT); + tmp |= AT91_UDP_ESR; + at91_udp_write(udc, AT91_UDP_GLB_STAT, tmp); + goto succeed; + case ((USB_TYPE_STANDARD|USB_RECIP_DEVICE) << 8) + | USB_REQ_CLEAR_FEATURE: + if (w_value != USB_DEVICE_REMOTE_WAKEUP) + goto stall; + tmp = at91_udp_read(udc, AT91_UDP_GLB_STAT); + tmp &= ~AT91_UDP_ESR; + at91_udp_write(udc, AT91_UDP_GLB_STAT, tmp); + goto succeed; + + /* + * Interfaces have no feature settings; this is pretty useless. + * we won't even insist the interface exists... + */ + case ((USB_DIR_IN|USB_TYPE_STANDARD|USB_RECIP_INTERFACE) << 8) + | USB_REQ_GET_STATUS: + PACKET("get interface status\n"); + __raw_writeb(0, dreg); + __raw_writeb(0, dreg); + goto write_in; + /* then STATUS starts later, automatically */ + case ((USB_TYPE_STANDARD|USB_RECIP_INTERFACE) << 8) + | USB_REQ_SET_FEATURE: + case ((USB_TYPE_STANDARD|USB_RECIP_INTERFACE) << 8) + | USB_REQ_CLEAR_FEATURE: + goto stall; + + /* + * Hosts may clear bulk/intr endpoint halt after the gadget + * driver sets it (not widely used); or set it (for testing) + */ + case ((USB_DIR_IN|USB_TYPE_STANDARD|USB_RECIP_ENDPOINT) << 8) + | USB_REQ_GET_STATUS: + tmp = w_index & USB_ENDPOINT_NUMBER_MASK; + ep = &udc->ep[tmp]; + if (tmp >= NUM_ENDPOINTS || (tmp && !ep->ep.desc)) + goto stall; + + if (tmp) { + if ((w_index & USB_DIR_IN)) { + if (!ep->is_in) + goto stall; + } else if (ep->is_in) + goto stall; + } + PACKET("get %s status\n", ep->ep.name); + if (__raw_readl(ep->creg) & AT91_UDP_FORCESTALL) + tmp = (1 << USB_ENDPOINT_HALT); + else + tmp = 0; + __raw_writeb(tmp, dreg); + __raw_writeb(0, dreg); + goto write_in; + /* then STATUS starts later, automatically */ + case ((USB_TYPE_STANDARD|USB_RECIP_ENDPOINT) << 8) + | USB_REQ_SET_FEATURE: + tmp = w_index & USB_ENDPOINT_NUMBER_MASK; + ep = &udc->ep[tmp]; + if (w_value != USB_ENDPOINT_HALT || tmp >= NUM_ENDPOINTS) + goto stall; + if (!ep->ep.desc || ep->is_iso) + goto stall; + if ((w_index & USB_DIR_IN)) { + if (!ep->is_in) + goto stall; + } else if (ep->is_in) + goto stall; + + tmp = __raw_readl(ep->creg); + tmp &= ~SET_FX; + tmp |= CLR_FX | AT91_UDP_FORCESTALL; + __raw_writel(tmp, ep->creg); + goto succeed; + case ((USB_TYPE_STANDARD|USB_RECIP_ENDPOINT) << 8) + | USB_REQ_CLEAR_FEATURE: + tmp = w_index & USB_ENDPOINT_NUMBER_MASK; + ep = &udc->ep[tmp]; + if (w_value != USB_ENDPOINT_HALT || tmp >= NUM_ENDPOINTS) + goto stall; + if (tmp == 0) + goto succeed; + if (!ep->ep.desc || ep->is_iso) + goto stall; + if ((w_index & USB_DIR_IN)) { + if (!ep->is_in) + goto stall; + } else if (ep->is_in) + goto stall; + + at91_udp_write(udc, AT91_UDP_RST_EP, ep->int_mask); + at91_udp_write(udc, AT91_UDP_RST_EP, 0); + tmp = __raw_readl(ep->creg); + tmp |= CLR_FX; + tmp &= ~(SET_FX | AT91_UDP_FORCESTALL); + __raw_writel(tmp, ep->creg); + if (!list_empty(&ep->queue)) + handle_ep(ep); + goto succeed; + } + +#undef w_value +#undef w_index +#undef w_length + + /* pass request up to the gadget driver */ + if (udc->driver) { + spin_unlock(&udc->lock); + status = udc->driver->setup(&udc->gadget, &pkt.r); + spin_lock(&udc->lock); + } + else + status = -ENODEV; + if (status < 0) { +stall: + VDBG("req %02x.%02x protocol STALL; stat %d\n", + pkt.r.bRequestType, pkt.r.bRequest, status); + csr |= AT91_UDP_FORCESTALL; + __raw_writel(csr, creg); + udc->req_pending = 0; + } + return; + +succeed: + /* immediate successful (IN) STATUS after zero length DATA */ + PACKET("ep0 in/status\n"); +write_in: + csr |= AT91_UDP_TXPKTRDY; + __raw_writel(csr, creg); + udc->req_pending = 0; +} + +static void handle_ep0(struct at91_udc *udc) +{ + struct at91_ep *ep0 = &udc->ep[0]; + u32 __iomem *creg = ep0->creg; + u32 csr = __raw_readl(creg); + struct at91_request *req; + + if (unlikely(csr & AT91_UDP_STALLSENT)) { + nuke(ep0, -EPROTO); + udc->req_pending = 0; + csr |= CLR_FX; + csr &= ~(SET_FX | AT91_UDP_STALLSENT | AT91_UDP_FORCESTALL); + __raw_writel(csr, creg); + VDBG("ep0 stalled\n"); + csr = __raw_readl(creg); + } + if (csr & AT91_UDP_RXSETUP) { + nuke(ep0, 0); + udc->req_pending = 0; + handle_setup(udc, ep0, csr); + return; + } + + if (list_empty(&ep0->queue)) + req = NULL; + else + req = list_entry(ep0->queue.next, struct at91_request, queue); + + /* host ACKed an IN packet that we sent */ + if (csr & AT91_UDP_TXCOMP) { + csr |= CLR_FX; + csr &= ~(SET_FX | AT91_UDP_TXCOMP); + + /* write more IN DATA? */ + if (req && ep0->is_in) { + if (handle_ep(ep0)) + udc->req_pending = 0; + + /* + * Ack after: + * - last IN DATA packet (including GET_STATUS) + * - IN/STATUS for OUT DATA + * - IN/STATUS for any zero-length DATA stage + * except for the IN DATA case, the host should send + * an OUT status later, which we'll ack. + */ + } else { + udc->req_pending = 0; + __raw_writel(csr, creg); + + /* + * SET_ADDRESS takes effect only after the STATUS + * (to the original address) gets acked. + */ + if (udc->wait_for_addr_ack) { + u32 tmp; + + at91_udp_write(udc, AT91_UDP_FADDR, + AT91_UDP_FEN | udc->addr); + tmp = at91_udp_read(udc, AT91_UDP_GLB_STAT); + tmp &= ~AT91_UDP_FADDEN; + if (udc->addr) + tmp |= AT91_UDP_FADDEN; + at91_udp_write(udc, AT91_UDP_GLB_STAT, tmp); + + udc->wait_for_addr_ack = 0; + VDBG("address %d\n", udc->addr); + } + } + } + + /* OUT packet arrived ... */ + else if (csr & AT91_UDP_RX_DATA_BK0) { + csr |= CLR_FX; + csr &= ~(SET_FX | AT91_UDP_RX_DATA_BK0); + + /* OUT DATA stage */ + if (!ep0->is_in) { + if (req) { + if (handle_ep(ep0)) { + /* send IN/STATUS */ + PACKET("ep0 in/status\n"); + csr = __raw_readl(creg); + csr &= ~SET_FX; + csr |= CLR_FX | AT91_UDP_TXPKTRDY; + __raw_writel(csr, creg); + udc->req_pending = 0; + } + } else if (udc->req_pending) { + /* + * AT91 hardware has a hard time with this + * "deferred response" mode for control-OUT + * transfers. (For control-IN it's fine.) + * + * The normal solution leaves OUT data in the + * fifo until the gadget driver is ready. + * We couldn't do that here without disabling + * the IRQ that tells about SETUP packets, + * e.g. when the host gets impatient... + * + * Working around it by copying into a buffer + * would almost be a non-deferred response, + * except that it wouldn't permit reliable + * stalling of the request. Instead, demand + * that gadget drivers not use this mode. + */ + DBG("no control-OUT deferred responses!\n"); + __raw_writel(csr | AT91_UDP_FORCESTALL, creg); + udc->req_pending = 0; + } + + /* STATUS stage for control-IN; ack. */ + } else { + PACKET("ep0 out/status ACK\n"); + __raw_writel(csr, creg); + + /* "early" status stage */ + if (req) + done(ep0, req, 0); + } + } +} + +static irqreturn_t at91_udc_irq (int irq, void *_udc) +{ + struct at91_udc *udc = _udc; + u32 rescans = 5; + int disable_clock = 0; + unsigned long flags; + + spin_lock_irqsave(&udc->lock, flags); + + if (!udc->clocked) { + clk_on(udc); + disable_clock = 1; + } + + while (rescans--) { + u32 status; + + status = at91_udp_read(udc, AT91_UDP_ISR) + & at91_udp_read(udc, AT91_UDP_IMR); + if (!status) + break; + + /* USB reset irq: not maskable */ + if (status & AT91_UDP_ENDBUSRES) { + at91_udp_write(udc, AT91_UDP_IDR, ~MINIMUS_INTERRUPTUS); + at91_udp_write(udc, AT91_UDP_IER, MINIMUS_INTERRUPTUS); + /* Atmel code clears this irq twice */ + at91_udp_write(udc, AT91_UDP_ICR, AT91_UDP_ENDBUSRES); + at91_udp_write(udc, AT91_UDP_ICR, AT91_UDP_ENDBUSRES); + VDBG("end bus reset\n"); + udc->addr = 0; + reset_gadget(udc); + + /* enable ep0 */ + at91_udp_write(udc, AT91_UDP_CSR(0), + AT91_UDP_EPEDS | AT91_UDP_EPTYPE_CTRL); + udc->gadget.speed = USB_SPEED_FULL; + udc->suspended = 0; + at91_udp_write(udc, AT91_UDP_IER, AT91_UDP_EP(0)); + + /* + * NOTE: this driver keeps clocks off unless the + * USB host is present. That saves power, but for + * boards that don't support VBUS detection, both + * clocks need to be active most of the time. + */ + + /* host initiated suspend (3+ms bus idle) */ + } else if (status & AT91_UDP_RXSUSP) { + at91_udp_write(udc, AT91_UDP_IDR, AT91_UDP_RXSUSP); + at91_udp_write(udc, AT91_UDP_IER, AT91_UDP_RXRSM); + at91_udp_write(udc, AT91_UDP_ICR, AT91_UDP_RXSUSP); + /* VDBG("bus suspend\n"); */ + if (udc->suspended) + continue; + udc->suspended = 1; + + /* + * NOTE: when suspending a VBUS-powered device, the + * gadget driver should switch into slow clock mode + * and then into standby to avoid drawing more than + * 500uA power (2500uA for some high-power configs). + */ + if (udc->driver && udc->driver->suspend) { + spin_unlock(&udc->lock); + udc->driver->suspend(&udc->gadget); + spin_lock(&udc->lock); + } + + /* host initiated resume */ + } else if (status & AT91_UDP_RXRSM) { + at91_udp_write(udc, AT91_UDP_IDR, AT91_UDP_RXRSM); + at91_udp_write(udc, AT91_UDP_IER, AT91_UDP_RXSUSP); + at91_udp_write(udc, AT91_UDP_ICR, AT91_UDP_RXRSM); + /* VDBG("bus resume\n"); */ + if (!udc->suspended) + continue; + udc->suspended = 0; + + /* + * NOTE: for a VBUS-powered device, the gadget driver + * would normally want to switch out of slow clock + * mode into normal mode. + */ + if (udc->driver && udc->driver->resume) { + spin_unlock(&udc->lock); + udc->driver->resume(&udc->gadget); + spin_lock(&udc->lock); + } + + /* endpoint IRQs are cleared by handling them */ + } else { + int i; + unsigned mask = 1; + struct at91_ep *ep = &udc->ep[1]; + + if (status & mask) + handle_ep0(udc); + for (i = 1; i < NUM_ENDPOINTS; i++) { + mask <<= 1; + if (status & mask) + handle_ep(ep); + ep++; + } + } + } + + if (disable_clock) + clk_off(udc); + + spin_unlock_irqrestore(&udc->lock, flags); + + return IRQ_HANDLED; +} + +/*-------------------------------------------------------------------------*/ + +static void at91_vbus_update(struct at91_udc *udc, unsigned value) +{ + value ^= udc->board.vbus_active_low; + if (value != udc->vbus) + at91_vbus_session(&udc->gadget, value); +} + +static irqreturn_t at91_vbus_irq(int irq, void *_udc) +{ + struct at91_udc *udc = _udc; + + /* vbus needs at least brief debouncing */ + udelay(10); + at91_vbus_update(udc, gpio_get_value(udc->board.vbus_pin)); + + return IRQ_HANDLED; +} + +static void at91_vbus_timer_work(struct work_struct *work) +{ + struct at91_udc *udc = container_of(work, struct at91_udc, + vbus_timer_work); + + at91_vbus_update(udc, gpio_get_value_cansleep(udc->board.vbus_pin)); + + if (!timer_pending(&udc->vbus_timer)) + mod_timer(&udc->vbus_timer, jiffies + VBUS_POLL_TIMEOUT); +} + +static void at91_vbus_timer(unsigned long data) +{ + struct at91_udc *udc = (struct at91_udc *)data; + + /* + * If we are polling vbus it is likely that the gpio is on an + * bus such as i2c or spi which may sleep, so schedule some work + * to read the vbus gpio + */ + schedule_work(&udc->vbus_timer_work); +} + +static int at91_start(struct usb_gadget *gadget, + struct usb_gadget_driver *driver) +{ + struct at91_udc *udc; + + udc = container_of(gadget, struct at91_udc, gadget); + udc->driver = driver; + udc->gadget.dev.of_node = udc->pdev->dev.of_node; + udc->enabled = 1; + udc->gadget.is_selfpowered = 1; + + return 0; +} + +static int at91_stop(struct usb_gadget *gadget) +{ + struct at91_udc *udc; + unsigned long flags; + + udc = container_of(gadget, struct at91_udc, gadget); + spin_lock_irqsave(&udc->lock, flags); + udc->enabled = 0; + at91_udp_write(udc, AT91_UDP_IDR, ~0); + spin_unlock_irqrestore(&udc->lock, flags); + + udc->driver = NULL; + + return 0; +} + +/*-------------------------------------------------------------------------*/ + +static void at91udc_shutdown(struct platform_device *dev) +{ + struct at91_udc *udc = platform_get_drvdata(dev); + unsigned long flags; + + /* force disconnect on reboot */ + spin_lock_irqsave(&udc->lock, flags); + pullup(platform_get_drvdata(dev), 0); + spin_unlock_irqrestore(&udc->lock, flags); +} + +static int at91rm9200_udc_init(struct at91_udc *udc) +{ + struct at91_ep *ep; + int ret; + int i; + + for (i = 0; i < NUM_ENDPOINTS; i++) { + ep = &udc->ep[i]; + + switch (i) { + case 0: + case 3: + ep->maxpacket = 8; + break; + case 1 ... 2: + ep->maxpacket = 64; + break; + case 4 ... 5: + ep->maxpacket = 256; + break; + } + } + + if (!gpio_is_valid(udc->board.pullup_pin)) { + DBG("no D+ pullup?\n"); + return -ENODEV; + } + + ret = devm_gpio_request(&udc->pdev->dev, udc->board.pullup_pin, + "udc_pullup"); + if (ret) { + DBG("D+ pullup is busy\n"); + return ret; + } + + gpio_direction_output(udc->board.pullup_pin, + udc->board.pullup_active_low); + + return 0; +} + +static void at91rm9200_udc_pullup(struct at91_udc *udc, int is_on) +{ + int active = !udc->board.pullup_active_low; + + if (is_on) + gpio_set_value(udc->board.pullup_pin, active); + else + gpio_set_value(udc->board.pullup_pin, !active); +} + +static const struct at91_udc_caps at91rm9200_udc_caps = { + .init = at91rm9200_udc_init, + .pullup = at91rm9200_udc_pullup, +}; + +static int at91sam9260_udc_init(struct at91_udc *udc) +{ + struct at91_ep *ep; + int i; + + for (i = 0; i < NUM_ENDPOINTS; i++) { + ep = &udc->ep[i]; + + switch (i) { + case 0 ... 3: + ep->maxpacket = 64; + break; + case 4 ... 5: + ep->maxpacket = 512; + break; + } + } + + return 0; +} + +static void at91sam9260_udc_pullup(struct at91_udc *udc, int is_on) +{ + u32 txvc = at91_udp_read(udc, AT91_UDP_TXVC); + + if (is_on) + txvc |= AT91_UDP_TXVC_PUON; + else + txvc &= ~AT91_UDP_TXVC_PUON; + + at91_udp_write(udc, AT91_UDP_TXVC, txvc); +} + +static const struct at91_udc_caps at91sam9260_udc_caps = { + .init = at91sam9260_udc_init, + .pullup = at91sam9260_udc_pullup, +}; + +static int at91sam9261_udc_init(struct at91_udc *udc) +{ + struct at91_ep *ep; + int i; + + for (i = 0; i < NUM_ENDPOINTS; i++) { + ep = &udc->ep[i]; + + switch (i) { + case 0: + ep->maxpacket = 8; + break; + case 1 ... 3: + ep->maxpacket = 64; + break; + case 4 ... 5: + ep->maxpacket = 256; + break; + } + } + + udc->matrix = syscon_regmap_lookup_by_phandle(udc->pdev->dev.of_node, + "atmel,matrix"); + if (IS_ERR(udc->matrix)) + return PTR_ERR(udc->matrix); + + return 0; +} + +static void at91sam9261_udc_pullup(struct at91_udc *udc, int is_on) +{ + u32 usbpucr = 0; + + if (is_on) + usbpucr = AT91_MATRIX_USBPUCR_PUON; + + regmap_update_bits(udc->matrix, AT91SAM9261_MATRIX_USBPUCR, + AT91_MATRIX_USBPUCR_PUON, usbpucr); +} + +static const struct at91_udc_caps at91sam9261_udc_caps = { + .init = at91sam9261_udc_init, + .pullup = at91sam9261_udc_pullup, +}; + +static int at91sam9263_udc_init(struct at91_udc *udc) +{ + struct at91_ep *ep; + int i; + + for (i = 0; i < NUM_ENDPOINTS; i++) { + ep = &udc->ep[i]; + + switch (i) { + case 0: + case 1: + case 2: + case 3: + ep->maxpacket = 64; + break; + case 4: + case 5: + ep->maxpacket = 256; + break; + } + } + + return 0; +} + +static const struct at91_udc_caps at91sam9263_udc_caps = { + .init = at91sam9263_udc_init, + .pullup = at91sam9260_udc_pullup, +}; + +static const struct of_device_id at91_udc_dt_ids[] = { + { + .compatible = "atmel,at91rm9200-udc", + .data = &at91rm9200_udc_caps, + }, + { + .compatible = "atmel,at91sam9260-udc", + .data = &at91sam9260_udc_caps, + }, + { + .compatible = "atmel,at91sam9261-udc", + .data = &at91sam9261_udc_caps, + }, + { + .compatible = "atmel,at91sam9263-udc", + .data = &at91sam9263_udc_caps, + }, + { /* sentinel */ } +}; +MODULE_DEVICE_TABLE(of, at91_udc_dt_ids); + +static void at91udc_of_init(struct at91_udc *udc, struct device_node *np) +{ + struct at91_udc_data *board = &udc->board; + const struct of_device_id *match; + enum of_gpio_flags flags; + u32 val; + + if (of_property_read_u32(np, "atmel,vbus-polled", &val) == 0) + board->vbus_polled = 1; + + board->vbus_pin = of_get_named_gpio_flags(np, "atmel,vbus-gpio", 0, + &flags); + board->vbus_active_low = (flags & OF_GPIO_ACTIVE_LOW) ? 1 : 0; + + board->pullup_pin = of_get_named_gpio_flags(np, "atmel,pullup-gpio", 0, + &flags); + + board->pullup_active_low = (flags & OF_GPIO_ACTIVE_LOW) ? 1 : 0; + + match = of_match_node(at91_udc_dt_ids, np); + if (match) + udc->caps = match->data; +} + +static int at91udc_probe(struct platform_device *pdev) +{ + struct device *dev = &pdev->dev; + struct at91_udc *udc; + int retval; + struct resource *res; + struct at91_ep *ep; + int i; + + udc = devm_kzalloc(dev, sizeof(*udc), GFP_KERNEL); + if (!udc) + return -ENOMEM; + + /* init software state */ + udc->gadget.dev.parent = dev; + at91udc_of_init(udc, pdev->dev.of_node); + udc->pdev = pdev; + udc->enabled = 0; + spin_lock_init(&udc->lock); + + udc->gadget.ops = &at91_udc_ops; + udc->gadget.ep0 = &udc->ep[0].ep; + udc->gadget.name = driver_name; + udc->gadget.dev.init_name = "gadget"; + + for (i = 0; i < NUM_ENDPOINTS; i++) { + ep = &udc->ep[i]; + ep->ep.name = ep_names[i]; + ep->ep.ops = &at91_ep_ops; + ep->udc = udc; + ep->int_mask = BIT(i); + if (i != 0 && i != 3) + ep->is_pingpong = 1; + } + + res = platform_get_resource(pdev, IORESOURCE_MEM, 0); + udc->udp_baseaddr = devm_ioremap_resource(dev, res); + if (IS_ERR(udc->udp_baseaddr)) + return PTR_ERR(udc->udp_baseaddr); + + if (udc->caps && udc->caps->init) { + retval = udc->caps->init(udc); + if (retval) + return retval; + } + + udc_reinit(udc); + + /* get interface and function clocks */ + udc->iclk = devm_clk_get(dev, "pclk"); + if (IS_ERR(udc->iclk)) + return PTR_ERR(udc->iclk); + + udc->fclk = devm_clk_get(dev, "hclk"); + if (IS_ERR(udc->fclk)) + return PTR_ERR(udc->fclk); + + /* don't do anything until we have both gadget driver and VBUS */ + clk_set_rate(udc->fclk, 48000000); + retval = clk_prepare(udc->fclk); + if (retval) + return retval; + + retval = clk_prepare_enable(udc->iclk); + if (retval) + goto err_unprepare_fclk; + + at91_udp_write(udc, AT91_UDP_TXVC, AT91_UDP_TXVC_TXVDIS); + at91_udp_write(udc, AT91_UDP_IDR, 0xffffffff); + /* Clear all pending interrupts - UDP may be used by bootloader. */ + at91_udp_write(udc, AT91_UDP_ICR, 0xffffffff); + clk_disable(udc->iclk); + + /* request UDC and maybe VBUS irqs */ + udc->udp_irq = platform_get_irq(pdev, 0); + retval = devm_request_irq(dev, udc->udp_irq, at91_udc_irq, 0, + driver_name, udc); + if (retval) { + DBG("request irq %d failed\n", udc->udp_irq); + goto err_unprepare_iclk; + } + + if (gpio_is_valid(udc->board.vbus_pin)) { + retval = devm_gpio_request(dev, udc->board.vbus_pin, + "udc_vbus"); + if (retval) { + DBG("request vbus pin failed\n"); + goto err_unprepare_iclk; + } + + gpio_direction_input(udc->board.vbus_pin); + + /* + * Get the initial state of VBUS - we cannot expect + * a pending interrupt. + */ + udc->vbus = gpio_get_value_cansleep(udc->board.vbus_pin) ^ + udc->board.vbus_active_low; + + if (udc->board.vbus_polled) { + INIT_WORK(&udc->vbus_timer_work, at91_vbus_timer_work); + setup_timer(&udc->vbus_timer, at91_vbus_timer, + (unsigned long)udc); + mod_timer(&udc->vbus_timer, + jiffies + VBUS_POLL_TIMEOUT); + } else { + retval = devm_request_irq(dev, + gpio_to_irq(udc->board.vbus_pin), + at91_vbus_irq, 0, driver_name, udc); + if (retval) { + DBG("request vbus irq %d failed\n", + udc->board.vbus_pin); + goto err_unprepare_iclk; + } + } + } else { + DBG("no VBUS detection, assuming always-on\n"); + udc->vbus = 1; + } + retval = usb_add_gadget_udc(dev, &udc->gadget); + if (retval) + goto err_unprepare_iclk; + dev_set_drvdata(dev, udc); + device_init_wakeup(dev, 1); + create_debug_file(udc); + + INFO("%s version %s\n", driver_name, DRIVER_VERSION); + return 0; + +err_unprepare_iclk: + clk_unprepare(udc->iclk); +err_unprepare_fclk: + clk_unprepare(udc->fclk); + + DBG("%s probe failed, %d\n", driver_name, retval); + + return retval; +} + +static int at91udc_remove(struct platform_device *pdev) +{ + struct at91_udc *udc = platform_get_drvdata(pdev); + unsigned long flags; + + DBG("remove\n"); + + usb_del_gadget_udc(&udc->gadget); + if (udc->driver) + return -EBUSY; + + spin_lock_irqsave(&udc->lock, flags); + pullup(udc, 0); + spin_unlock_irqrestore(&udc->lock, flags); + + device_init_wakeup(&pdev->dev, 0); + remove_debug_file(udc); + clk_unprepare(udc->fclk); + clk_unprepare(udc->iclk); + + return 0; +} + +#ifdef CONFIG_PM +static int at91udc_suspend(struct platform_device *pdev, pm_message_t mesg) +{ + struct at91_udc *udc = platform_get_drvdata(pdev); + int wake = udc->driver && device_may_wakeup(&pdev->dev); + unsigned long flags; + + /* Unless we can act normally to the host (letting it wake us up + * whenever it has work for us) force disconnect. Wakeup requires + * PLLB for USB events (signaling for reset, wakeup, or incoming + * tokens) and VBUS irqs (on systems which support them). + */ + if ((!udc->suspended && udc->addr) + || !wake + || at91_suspend_entering_slow_clock()) { + spin_lock_irqsave(&udc->lock, flags); + pullup(udc, 0); + wake = 0; + spin_unlock_irqrestore(&udc->lock, flags); + } else + enable_irq_wake(udc->udp_irq); + + udc->active_suspend = wake; + if (gpio_is_valid(udc->board.vbus_pin) && !udc->board.vbus_polled && wake) + enable_irq_wake(udc->board.vbus_pin); + return 0; +} + +static int at91udc_resume(struct platform_device *pdev) +{ + struct at91_udc *udc = platform_get_drvdata(pdev); + unsigned long flags; + + if (gpio_is_valid(udc->board.vbus_pin) && !udc->board.vbus_polled && + udc->active_suspend) + disable_irq_wake(udc->board.vbus_pin); + + /* maybe reconnect to host; if so, clocks on */ + if (udc->active_suspend) + disable_irq_wake(udc->udp_irq); + else { + spin_lock_irqsave(&udc->lock, flags); + pullup(udc, 1); + spin_unlock_irqrestore(&udc->lock, flags); + } + return 0; +} +#else +#define at91udc_suspend NULL +#define at91udc_resume NULL +#endif + +static struct platform_driver at91_udc_driver = { + .remove = at91udc_remove, + .shutdown = at91udc_shutdown, + .suspend = at91udc_suspend, + .resume = at91udc_resume, + .driver = { + .name = (char *) driver_name, + .of_match_table = at91_udc_dt_ids, + }, +}; + +module_platform_driver_probe(at91_udc_driver, at91udc_probe); + +MODULE_DESCRIPTION("AT91 udc driver"); +MODULE_AUTHOR("Thomas Rathbone, David Brownell"); +MODULE_LICENSE("GPL"); +MODULE_ALIAS("platform:at91_udc"); diff --git a/drivers/usb/gadget/at91_udc.h b/drivers/usb/gadget/at91_udc.h new file mode 100644 index 0000000..2679c8b --- /dev/null +++ b/drivers/usb/gadget/at91_udc.h @@ -0,0 +1,175 @@ +/* + * Copyright (C) 2004 by Thomas Rathbone, HP Labs + * Copyright (C) 2005 by Ivan Kokshaysky + * Copyright (C) 2006 by SAN People + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + */ + +#ifndef AT91_UDC_H +#define AT91_UDC_H + +/* + * USB Device Port (UDP) registers. + * Based on AT91RM9200 datasheet revision E. + */ + +#define AT91_UDP_FRM_NUM 0x00 /* Frame Number Register */ +#define AT91_UDP_NUM (0x7ff << 0) /* Frame Number */ +#define AT91_UDP_FRM_ERR (1 << 16) /* Frame Error */ +#define AT91_UDP_FRM_OK (1 << 17) /* Frame OK */ + +#define AT91_UDP_GLB_STAT 0x04 /* Global State Register */ +#define AT91_UDP_FADDEN (1 << 0) /* Function Address Enable */ +#define AT91_UDP_CONFG (1 << 1) /* Configured */ +#define AT91_UDP_ESR (1 << 2) /* Enable Send Resume */ +#define AT91_UDP_RSMINPR (1 << 3) /* Resume has been sent */ +#define AT91_UDP_RMWUPE (1 << 4) /* Remote Wake Up Enable */ + +#define AT91_UDP_FADDR 0x08 /* Function Address Register */ +#define AT91_UDP_FADD (0x7f << 0) /* Function Address Value */ +#define AT91_UDP_FEN (1 << 8) /* Function Enable */ + +#define AT91_UDP_IER 0x10 /* Interrupt Enable Register */ +#define AT91_UDP_IDR 0x14 /* Interrupt Disable Register */ +#define AT91_UDP_IMR 0x18 /* Interrupt Mask Register */ + +#define AT91_UDP_ISR 0x1c /* Interrupt Status Register */ +#define AT91_UDP_EP(n) (1 << (n)) /* Endpoint Interrupt Status */ +#define AT91_UDP_RXSUSP (1 << 8) /* USB Suspend Interrupt Status */ +#define AT91_UDP_RXRSM (1 << 9) /* USB Resume Interrupt Status */ +#define AT91_UDP_EXTRSM (1 << 10) /* External Resume Interrupt Status [AT91RM9200 only] */ +#define AT91_UDP_SOFINT (1 << 11) /* Start of Frame Interrupt Status */ +#define AT91_UDP_ENDBUSRES (1 << 12) /* End of Bus Reset Interrupt Status */ +#define AT91_UDP_WAKEUP (1 << 13) /* USB Wakeup Interrupt Status [AT91RM9200 only] */ + +#define AT91_UDP_ICR 0x20 /* Interrupt Clear Register */ +#define AT91_UDP_RST_EP 0x28 /* Reset Endpoint Register */ + +#define AT91_UDP_CSR(n) (0x30+((n)*4)) /* Endpoint Control/Status Registers 0-7 */ +#define AT91_UDP_TXCOMP (1 << 0) /* Generates IN packet with data previously written in DPR */ +#define AT91_UDP_RX_DATA_BK0 (1 << 1) /* Receive Data Bank 0 */ +#define AT91_UDP_RXSETUP (1 << 2) /* Send STALL to the host */ +#define AT91_UDP_STALLSENT (1 << 3) /* Stall Sent / Isochronous error (Isochronous endpoints) */ +#define AT91_UDP_TXPKTRDY (1 << 4) /* Transmit Packet Ready */ +#define AT91_UDP_FORCESTALL (1 << 5) /* Force Stall */ +#define AT91_UDP_RX_DATA_BK1 (1 << 6) /* Receive Data Bank 1 */ +#define AT91_UDP_DIR (1 << 7) /* Transfer Direction */ +#define AT91_UDP_EPTYPE (7 << 8) /* Endpoint Type */ +#define AT91_UDP_EPTYPE_CTRL (0 << 8) +#define AT91_UDP_EPTYPE_ISO_OUT (1 << 8) +#define AT91_UDP_EPTYPE_BULK_OUT (2 << 8) +#define AT91_UDP_EPTYPE_INT_OUT (3 << 8) +#define AT91_UDP_EPTYPE_ISO_IN (5 << 8) +#define AT91_UDP_EPTYPE_BULK_IN (6 << 8) +#define AT91_UDP_EPTYPE_INT_IN (7 << 8) +#define AT91_UDP_DTGLE (1 << 11) /* Data Toggle */ +#define AT91_UDP_EPEDS (1 << 15) /* Endpoint Enable/Disable */ +#define AT91_UDP_RXBYTECNT (0x7ff << 16) /* Number of bytes in FIFO */ + +#define AT91_UDP_FDR(n) (0x50+((n)*4)) /* Endpoint FIFO Data Registers 0-7 */ + +#define AT91_UDP_TXVC 0x74 /* Transceiver Control Register */ +#define AT91_UDP_TXVC_TXVDIS (1 << 8) /* Transceiver Disable */ +#define AT91_UDP_TXVC_PUON (1 << 9) /* PullUp On [AT91SAM9260 only] */ + +/*-------------------------------------------------------------------------*/ + +/* + * controller driver data structures + */ + +#define NUM_ENDPOINTS 6 + +/* + * hardware won't disable bus reset, or resume while the controller + * is suspended ... watching suspend helps keep the logic symmetric. + */ +#define MINIMUS_INTERRUPTUS \ + (AT91_UDP_ENDBUSRES | AT91_UDP_RXRSM | AT91_UDP_RXSUSP) + +struct at91_ep { + struct usb_ep ep; + struct list_head queue; + struct at91_udc *udc; + void __iomem *creg; + + unsigned maxpacket:16; + u8 int_mask; + unsigned is_pingpong:1; + + unsigned stopped:1; + unsigned is_in:1; + unsigned is_iso:1; + unsigned fifo_bank:1; +}; + +struct at91_udc_caps { + int (*init)(struct at91_udc *udc); + void (*pullup)(struct at91_udc *udc, int is_on); +}; + +/* + * driver is non-SMP, and just blocks IRQs whenever it needs + * access protection for chip registers or driver state + */ +struct at91_udc { + struct usb_gadget gadget; + struct at91_ep ep[NUM_ENDPOINTS]; + struct usb_gadget_driver *driver; + const struct at91_udc_caps *caps; + unsigned vbus:1; + unsigned enabled:1; + unsigned clocked:1; + unsigned suspended:1; + unsigned req_pending:1; + unsigned wait_for_addr_ack:1; + unsigned wait_for_config_ack:1; + unsigned active_suspend:1; + u8 addr; + struct at91_udc_data board; + struct clk *iclk, *fclk; + struct platform_device *pdev; + struct proc_dir_entry *pde; + void __iomem *udp_baseaddr; + int udp_irq; + spinlock_t lock; + struct timer_list vbus_timer; + struct work_struct vbus_timer_work; + struct regmap *matrix; +}; + +static inline struct at91_udc *to_udc(struct usb_gadget *g) +{ + return container_of(g, struct at91_udc, gadget); +} + +struct at91_request { + struct usb_request req; + struct list_head queue; +}; + +/*-------------------------------------------------------------------------*/ + +#ifdef VERBOSE_DEBUG +# define VDBG DBG +#else +# define VDBG(stuff...) do{}while(0) +#endif + +#ifdef PACKET_TRACE +# define PACKET VDBG +#else +# define PACKET(stuff...) do{}while(0) +#endif + +#define ERR(stuff...) pr_err("udc: " stuff) +#define WARNING(stuff...) pr_warning("udc: " stuff) +#define INFO(stuff...) pr_info("udc: " stuff) +#define DBG(stuff...) pr_debug("udc: " stuff) + +#endif +
add U-Boot specific changes to the at91_udc linux driver, so it works with U-Boot.
Changes in v4: None Changes in v3: - adapt changes for U-Boot, as newer linux version is used.
Changes in v2: - new in version 2, contains U-Boot changes
drivers/usb/gadget/Makefile | 1 + drivers/usb/gadget/at91_udc.c | 601 +++++++----------------------------------- drivers/usb/gadget/at91_udc.h | 16 +- include/linux/usb/at91_udc.h | 20 ++ 4 files changed, 122 insertions(+), 516 deletions(-) create mode 100644 include/linux/usb/at91_udc.h
diff --git a/drivers/usb/gadget/Makefile b/drivers/usb/gadget/Makefile index 4c11a7e..6288ecf 100644 --- a/drivers/usb/gadget/Makefile +++ b/drivers/usb/gadget/Makefile @@ -10,6 +10,7 @@ obj-$(CONFIG_USB_ETHER) += epautoconf.o config.o usbstring.o
# new USB gadget layer dependencies ifdef CONFIG_USB_GADGET +obj-$(CONFIG_USB_GADGET_AT91) += at91_udc.o obj-$(CONFIG_USB_GADGET_ATMEL_USBA) += atmel_usba_udc.o obj-$(CONFIG_USB_GADGET_BCM_UDC_OTG_PHY) += bcm_udc_otg_phy.o obj-$(CONFIG_USB_GADGET_S3C_UDC_OTG) += s3c_udc_otg.o diff --git a/drivers/usb/gadget/at91_udc.c b/drivers/usb/gadget/at91_udc.c index fc42264..3c3553a 100644 --- a/drivers/usb/gadget/at91_udc.c +++ b/drivers/usb/gadget/at91_udc.c @@ -1,43 +1,34 @@ /* + * from linux: + * c94e289f195e: usb: gadget: remove incorrect __init/__exit annotations + * * at91_udc -- driver for at91-series USB peripheral controller * * Copyright (C) 2004 by Thomas Rathbone * Copyright (C) 2005 by HP Labs * Copyright (C) 2005 by David Brownell * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. + * SPDX-License-Identifier: GPL-2.0+ */
#undef VERBOSE_DEBUG #undef PACKET_TRACE
-#include <linux/kernel.h> -#include <linux/module.h> -#include <linux/platform_device.h> -#include <linux/delay.h> -#include <linux/ioport.h> -#include <linux/slab.h> -#include <linux/errno.h> +#include <common.h> +#include <asm/errno.h> +#include <asm/io.h> +#include <asm/gpio.h> +#include <asm/hardware.h> +#include <mach/at91_matrix.h> #include <linux/list.h> -#include <linux/interrupt.h> -#include <linux/proc_fs.h> -#include <linux/prefetch.h> -#include <linux/clk.h> #include <linux/usb/ch9.h> #include <linux/usb/gadget.h> -#include <linux/of.h> -#include <linux/of_gpio.h> -#include <linux/platform_data/atmel.h> -#include <linux/regmap.h> -#include <linux/mfd/syscon.h> -#include <linux/mfd/syscon/atmel-matrix.h> +#include <linux/usb/at91_udc.h> +#include <malloc.h> +#include <usb/lin_gadget_compat.h>
- /* * This controller is simple and PIO-only. It's used in many AT91-series * full speed USB controllers, including the at91rm9200 (arm920T, with MMU), @@ -69,187 +60,12 @@ static const char * const ep_names[] = { }; #define ep0name ep_names[0]
-#define VBUS_POLL_TIMEOUT msecs_to_jiffies(1000) - #define at91_udp_read(udc, reg) \ __raw_readl((udc)->udp_baseaddr + (reg)) #define at91_udp_write(udc, reg, val) \ __raw_writel((val), (udc)->udp_baseaddr + (reg))
-/*-------------------------------------------------------------------------*/ - -#ifdef CONFIG_USB_GADGET_DEBUG_FILES - -#include <linux/seq_file.h> - -static const char debug_filename[] = "driver/udc"; - -#define FOURBITS "%s%s%s%s" -#define EIGHTBITS FOURBITS FOURBITS - -static void proc_ep_show(struct seq_file *s, struct at91_ep *ep) -{ - static char *types[] = { - "control", "out-iso", "out-bulk", "out-int", - "BOGUS", "in-iso", "in-bulk", "in-int"}; - - u32 csr; - struct at91_request *req; - unsigned long flags; - struct at91_udc *udc = ep->udc; - - spin_lock_irqsave(&udc->lock, flags); - - csr = __raw_readl(ep->creg); - - /* NOTE: not collecting per-endpoint irq statistics... */ - - seq_printf(s, "\n"); - seq_printf(s, "%s, maxpacket %d %s%s %s%s\n", - ep->ep.name, ep->ep.maxpacket, - ep->is_in ? "in" : "out", - ep->is_iso ? " iso" : "", - ep->is_pingpong - ? (ep->fifo_bank ? "pong" : "ping") - : "", - ep->stopped ? " stopped" : ""); - seq_printf(s, "csr %08x rxbytes=%d %s %s %s" EIGHTBITS "\n", - csr, - (csr & 0x07ff0000) >> 16, - (csr & (1 << 15)) ? "enabled" : "disabled", - (csr & (1 << 11)) ? "DATA1" : "DATA0", - types[(csr & 0x700) >> 8], - - /* iff type is control then print current direction */ - (!(csr & 0x700)) - ? ((csr & (1 << 7)) ? " IN" : " OUT") - : "", - (csr & (1 << 6)) ? " rxdatabk1" : "", - (csr & (1 << 5)) ? " forcestall" : "", - (csr & (1 << 4)) ? " txpktrdy" : "", - - (csr & (1 << 3)) ? " stallsent" : "", - (csr & (1 << 2)) ? " rxsetup" : "", - (csr & (1 << 1)) ? " rxdatabk0" : "", - (csr & (1 << 0)) ? " txcomp" : ""); - if (list_empty (&ep->queue)) - seq_printf(s, "\t(queue empty)\n"); - - else list_for_each_entry (req, &ep->queue, queue) { - unsigned length = req->req.actual; - - seq_printf(s, "\treq %p len %d/%d buf %p\n", - &req->req, length, - req->req.length, req->req.buf); - } - spin_unlock_irqrestore(&udc->lock, flags); -} - -static void proc_irq_show(struct seq_file *s, const char *label, u32 mask) -{ - int i; - - seq_printf(s, "%s %04x:%s%s" FOURBITS, label, mask, - (mask & (1 << 13)) ? " wakeup" : "", - (mask & (1 << 12)) ? " endbusres" : "", - - (mask & (1 << 11)) ? " sofint" : "", - (mask & (1 << 10)) ? " extrsm" : "", - (mask & (1 << 9)) ? " rxrsm" : "", - (mask & (1 << 8)) ? " rxsusp" : ""); - for (i = 0; i < 8; i++) { - if (mask & (1 << i)) - seq_printf(s, " ep%d", i); - } - seq_printf(s, "\n"); -} - -static int proc_udc_show(struct seq_file *s, void *unused) -{ - struct at91_udc *udc = s->private; - struct at91_ep *ep; - u32 tmp; - - seq_printf(s, "%s: version %s\n", driver_name, DRIVER_VERSION); - - seq_printf(s, "vbus %s, pullup %s, %s powered%s, gadget %s\n\n", - udc->vbus ? "present" : "off", - udc->enabled - ? (udc->vbus ? "active" : "enabled") - : "disabled", - udc->gadget.is_selfpowered ? "self" : "VBUS", - udc->suspended ? ", suspended" : "", - udc->driver ? udc->driver->driver.name : "(none)"); - - /* don't access registers when interface isn't clocked */ - if (!udc->clocked) { - seq_printf(s, "(not clocked)\n"); - return 0; - } - - tmp = at91_udp_read(udc, AT91_UDP_FRM_NUM); - seq_printf(s, "frame %05x:%s%s frame=%d\n", tmp, - (tmp & AT91_UDP_FRM_OK) ? " ok" : "", - (tmp & AT91_UDP_FRM_ERR) ? " err" : "", - (tmp & AT91_UDP_NUM)); - - tmp = at91_udp_read(udc, AT91_UDP_GLB_STAT); - seq_printf(s, "glbstate %02x:%s" FOURBITS "\n", tmp, - (tmp & AT91_UDP_RMWUPE) ? " rmwupe" : "", - (tmp & AT91_UDP_RSMINPR) ? " rsminpr" : "", - (tmp & AT91_UDP_ESR) ? " esr" : "", - (tmp & AT91_UDP_CONFG) ? " confg" : "", - (tmp & AT91_UDP_FADDEN) ? " fadden" : ""); - - tmp = at91_udp_read(udc, AT91_UDP_FADDR); - seq_printf(s, "faddr %03x:%s fadd=%d\n", tmp, - (tmp & AT91_UDP_FEN) ? " fen" : "", - (tmp & AT91_UDP_FADD)); - - proc_irq_show(s, "imr ", at91_udp_read(udc, AT91_UDP_IMR)); - proc_irq_show(s, "isr ", at91_udp_read(udc, AT91_UDP_ISR)); - - if (udc->enabled && udc->vbus) { - proc_ep_show(s, &udc->ep[0]); - list_for_each_entry (ep, &udc->gadget.ep_list, ep.ep_list) { - if (ep->ep.desc) - proc_ep_show(s, ep); - } - } - return 0; -} - -static int proc_udc_open(struct inode *inode, struct file *file) -{ - return single_open(file, proc_udc_show, PDE_DATA(inode)); -} - -static const struct file_operations proc_ops = { - .owner = THIS_MODULE, - .open = proc_udc_open, - .read = seq_read, - .llseek = seq_lseek, - .release = single_release, -}; - -static void create_debug_file(struct at91_udc *udc) -{ - udc->pde = proc_create_data(debug_filename, 0, NULL, &proc_ops, udc); -} - -static void remove_debug_file(struct at91_udc *udc) -{ - if (udc->pde) - remove_proc_entry(debug_filename, NULL); -} - -#else - -static inline void create_debug_file(struct at91_udc *udc) {} -static inline void remove_debug_file(struct at91_udc *udc) {} - -#endif - +static struct at91_udc *controller;
@@ -268,7 +84,7 @@ static void done(struct at91_ep *ep, struct at91_request *req, int status)
ep->stopped = 1; spin_unlock(&udc->lock); - usb_gadget_giveback_request(&ep->ep, &req->req); + req->req.complete(&ep->ep, &req->req); spin_lock(&udc->lock); ep->stopped = stopped;
@@ -332,7 +148,7 @@ rescan: req->req.status = -EOVERFLOW; count = bufferspace; } - __raw_readsb(dreg, buf, count); + __raw_readsb((unsigned long)dreg, buf, count);
/* release and swap pingpong mem bank */ csr |= CLR_FX; @@ -434,7 +250,7 @@ static int write_fifo(struct at91_ep *ep, struct at91_request *req) * recover when the actual bytecount matters (e.g. for USB Test * and Measurement Class devices). */ - __raw_writesb(dreg, buf, count); + __raw_writesb((unsigned long)dreg, buf, count); csr &= ~SET_FX; csr |= CLR_FX | AT91_UDP_TXPKTRDY; __raw_writel(csr, creg); @@ -703,14 +519,11 @@ static int at91_ep_dequeue(struct usb_ep *_ep, struct usb_request *_req) struct at91_ep *ep; struct at91_request *req; unsigned long flags; - struct at91_udc *udc;
ep = container_of(_ep, struct at91_ep, ep); if (!_ep || ep->ep.name == ep0name) return -EINVAL;
- udc = ep->udc; - spin_lock_irqsave(&udc->lock, flags);
/* make sure it's actually queued on this endpoint */ @@ -859,7 +672,7 @@ static void reset_gadget(struct at91_udc *udc) } if (driver) { spin_unlock(&udc->lock); - usb_gadget_udc_reset(&udc->gadget, driver); + udc->driver->disconnect(&udc->gadget); spin_lock(&udc->lock); }
@@ -895,9 +708,6 @@ static void clk_on(struct at91_udc *udc) if (udc->clocked) return; udc->clocked = 1; - - clk_enable(udc->iclk); - clk_enable(udc->fclk); }
static void clk_off(struct at91_udc *udc) @@ -906,8 +716,6 @@ static void clk_off(struct at91_udc *udc) return; udc->clocked = 0; udc->gadget.speed = USB_SPEED_UNKNOWN; - clk_disable(udc->fclk); - clk_disable(udc->iclk); }
/* @@ -970,7 +778,7 @@ static int at91_set_selfpowered(struct usb_gadget *gadget, int is_on) unsigned long flags;
spin_lock_irqsave(&udc->lock, flags); - gadget->is_selfpowered = (is_on != 0); + udc->selfpowered = (is_on != 0); spin_unlock_irqrestore(&udc->lock, flags); return 0; } @@ -1119,7 +927,7 @@ static void handle_setup(struct at91_udc *udc, struct at91_ep *ep, u32 csr) */ case ((USB_DIR_IN|USB_TYPE_STANDARD|USB_RECIP_DEVICE) << 8) | USB_REQ_GET_STATUS: - tmp = (udc->gadget.is_selfpowered << USB_DEVICE_SELF_POWERED); + tmp = (udc->selfpowered << USB_DEVICE_SELF_POWERED); if (at91_udp_read(udc, AT91_UDP_GLB_STAT) & AT91_UDP_ESR) tmp |= (1 << USB_DEVICE_REMOTE_WAKEUP); PACKET("get device status\n"); @@ -1388,9 +1196,8 @@ static void handle_ep0(struct at91_udc *udc) } }
-static irqreturn_t at91_udc_irq (int irq, void *_udc) +static irqreturn_t at91_udc_irq(struct at91_udc *udc) { - struct at91_udc *udc = _udc; u32 rescans = 5; int disable_clock = 0; unsigned long flags; @@ -1505,67 +1312,23 @@ static irqreturn_t at91_udc_irq (int irq, void *_udc)
-static void at91_vbus_update(struct at91_udc *udc, unsigned value) -{ - value ^= udc->board.vbus_active_low; - if (value != udc->vbus) - at91_vbus_session(&udc->gadget, value); -} - -static irqreturn_t at91_vbus_irq(int irq, void *_udc) -{ - struct at91_udc *udc = _udc; - - /* vbus needs at least brief debouncing */ - udelay(10); - at91_vbus_update(udc, gpio_get_value(udc->board.vbus_pin)); - - return IRQ_HANDLED; -} - -static void at91_vbus_timer_work(struct work_struct *work) -{ - struct at91_udc *udc = container_of(work, struct at91_udc, - vbus_timer_work); - - at91_vbus_update(udc, gpio_get_value_cansleep(udc->board.vbus_pin)); - - if (!timer_pending(&udc->vbus_timer)) - mod_timer(&udc->vbus_timer, jiffies + VBUS_POLL_TIMEOUT); -} - -static void at91_vbus_timer(unsigned long data) -{ - struct at91_udc *udc = (struct at91_udc *)data; - - /* - * If we are polling vbus it is likely that the gpio is on an - * bus such as i2c or spi which may sleep, so schedule some work - * to read the vbus gpio - */ - schedule_work(&udc->vbus_timer_work); -} - static int at91_start(struct usb_gadget *gadget, struct usb_gadget_driver *driver) { - struct at91_udc *udc; + struct at91_udc *udc = controller;
- udc = container_of(gadget, struct at91_udc, gadget); udc->driver = driver; - udc->gadget.dev.of_node = udc->pdev->dev.of_node; udc->enabled = 1; - udc->gadget.is_selfpowered = 1; + udc->selfpowered = 1;
return 0; }
static int at91_stop(struct usb_gadget *gadget) { - struct at91_udc *udc; + struct at91_udc *udc = controller; unsigned long flags;
- udc = container_of(gadget, struct at91_udc, gadget); spin_lock_irqsave(&udc->lock, flags); udc->enabled = 0; at91_udp_write(udc, AT91_UDP_IDR, ~0); @@ -1578,17 +1341,6 @@ static int at91_stop(struct usb_gadget *gadget)
-static void at91udc_shutdown(struct platform_device *dev) -{ - struct at91_udc *udc = platform_get_drvdata(dev); - unsigned long flags; - - /* force disconnect on reboot */ - spin_lock_irqsave(&udc->lock, flags); - pullup(platform_get_drvdata(dev), 0); - spin_unlock_irqrestore(&udc->lock, flags); -} - static int at91rm9200_udc_init(struct at91_udc *udc) { struct at91_ep *ep; @@ -1612,13 +1364,7 @@ static int at91rm9200_udc_init(struct at91_udc *udc) } }
- if (!gpio_is_valid(udc->board.pullup_pin)) { - DBG("no D+ pullup?\n"); - return -ENODEV; - } - - ret = devm_gpio_request(&udc->pdev->dev, udc->board.pullup_pin, - "udc_pullup"); + ret = gpio_request(udc->board.pullup_pin, "udc_pullup"); if (ret) { DBG("D+ pullup is busy\n"); return ret; @@ -1666,6 +1412,7 @@ static int at91sam9260_udc_init(struct at91_udc *udc) return 0; }
+#if defined(CONFIG_AT91SAM9260) || defined(CONFIG_AT91SAM9G20) static void at91sam9260_udc_pullup(struct at91_udc *udc, int is_on) { u32 txvc = at91_udp_read(udc, AT91_UDP_TXVC); @@ -1682,7 +1429,9 @@ static const struct at91_udc_caps at91sam9260_udc_caps = { .init = at91sam9260_udc_init, .pullup = at91sam9260_udc_pullup, }; +#endif
+#if defined(CONFIG_AT91SAM9261) static int at91sam9261_udc_init(struct at91_udc *udc) { struct at91_ep *ep; @@ -1704,8 +1453,8 @@ static int at91sam9261_udc_init(struct at91_udc *udc) } }
- udc->matrix = syscon_regmap_lookup_by_phandle(udc->pdev->dev.of_node, - "atmel,matrix"); + udc->matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX; + if (IS_ERR(udc->matrix)) return PTR_ERR(udc->matrix);
@@ -1716,17 +1465,18 @@ static void at91sam9261_udc_pullup(struct at91_udc *udc, int is_on) { u32 usbpucr = 0;
+ usbpucr = readl(&udc->matrix->pucr); if (is_on) - usbpucr = AT91_MATRIX_USBPUCR_PUON; + usbpucr |= AT91_MATRIX_USBPUCR_PUON;
- regmap_update_bits(udc->matrix, AT91SAM9261_MATRIX_USBPUCR, - AT91_MATRIX_USBPUCR_PUON, usbpucr); + writel(usbpucr, &udc->matrix->pucr); }
static const struct at91_udc_caps at91sam9261_udc_caps = { .init = at91sam9261_udc_init, .pullup = at91sam9261_udc_pullup, }; +#endif
static int at91sam9263_udc_init(struct at91_udc *udc) { @@ -1758,75 +1508,90 @@ static const struct at91_udc_caps at91sam9263_udc_caps = { .pullup = at91sam9260_udc_pullup, };
-static const struct of_device_id at91_udc_dt_ids[] = { - { - .compatible = "atmel,at91rm9200-udc", - .data = &at91rm9200_udc_caps, - }, - { - .compatible = "atmel,at91sam9260-udc", - .data = &at91sam9260_udc_caps, - }, - { - .compatible = "atmel,at91sam9261-udc", - .data = &at91sam9261_udc_caps, - }, - { - .compatible = "atmel,at91sam9263-udc", - .data = &at91sam9263_udc_caps, - }, - { /* sentinel */ } -}; -MODULE_DEVICE_TABLE(of, at91_udc_dt_ids); +int usb_gadget_handle_interrupts(int index) +{ + struct at91_udc *udc = controller;
-static void at91udc_of_init(struct at91_udc *udc, struct device_node *np) + return at91_udc_irq(udc); +} + +int usb_gadget_register_driver(struct usb_gadget_driver *driver) { - struct at91_udc_data *board = &udc->board; - const struct of_device_id *match; - enum of_gpio_flags flags; - u32 val; + struct at91_udc *udc = controller; + int ret;
- if (of_property_read_u32(np, "atmel,vbus-polled", &val) == 0) - board->vbus_polled = 1; + if (!driver || !driver->bind || !driver->setup) { + printf("bad paramter\n"); + return -EINVAL; + } + + if (udc->driver) { + printf("UDC already has a gadget driver\n"); + return -EBUSY; + }
- board->vbus_pin = of_get_named_gpio_flags(np, "atmel,vbus-gpio", 0, - &flags); - board->vbus_active_low = (flags & OF_GPIO_ACTIVE_LOW) ? 1 : 0; + at91_start(&udc->gadget, driver);
- board->pullup_pin = of_get_named_gpio_flags(np, "atmel,pullup-gpio", 0, - &flags); + udc->driver = driver;
- board->pullup_active_low = (flags & OF_GPIO_ACTIVE_LOW) ? 1 : 0; + ret = driver->bind(&udc->gadget); + if (ret) { + error("driver->bind() returned %d\n", ret); + udc->driver = NULL; + }
- match = of_match_node(at91_udc_dt_ids, np); - if (match) - udc->caps = match->data; + return ret; }
-static int at91udc_probe(struct platform_device *pdev) +int usb_gadget_unregister_driver(struct usb_gadget_driver *driver) +{ + struct at91_udc *udc = controller; + + if (!driver || !driver->unbind || !driver->disconnect) { + error("bad paramter\n"); + return -EINVAL; + } + + driver->disconnect(&udc->gadget); + driver->unbind(&udc->gadget); + udc->driver = NULL; + + at91_stop(&udc->gadget); + + return 0; +} + +int at91_udc_probe(struct at91_udc_data *pdata) { - struct device *dev = &pdev->dev; struct at91_udc *udc; int retval; - struct resource *res; struct at91_ep *ep; int i;
- udc = devm_kzalloc(dev, sizeof(*udc), GFP_KERNEL); + udc = kzalloc(sizeof(*udc), GFP_KERNEL); if (!udc) return -ENOMEM;
- /* init software state */ - udc->gadget.dev.parent = dev; - at91udc_of_init(udc, pdev->dev.of_node); - udc->pdev = pdev; + controller = udc; + memcpy(&udc->board, pdata, sizeof(struct at91_udc_data)); + if (udc->board.vbus_pin) { + printf("%s: gpio vbus pin not supported yet.\n", __func__); + return -ENXIO; + } else { + DBG("no VBUS detection, assuming always-on\n"); + udc->vbus = 1; + } + +#if defined(CONFIG_AT91SAM9260) || defined(CONFIG_AT91SAM9G20) + udc->caps = &at91sam9260_udc_caps; +#endif + udc->enabled = 0; spin_lock_init(&udc->lock);
udc->gadget.ops = &at91_udc_ops; udc->gadget.ep0 = &udc->ep[0].ep; udc->gadget.name = driver_name; - udc->gadget.dev.init_name = "gadget";
for (i = 0; i < NUM_ENDPOINTS; i++) { ep = &udc->ep[i]; @@ -1838,8 +1603,7 @@ static int at91udc_probe(struct platform_device *pdev) ep->is_pingpong = 1; }
- res = platform_get_resource(pdev, IORESOURCE_MEM, 0); - udc->udp_baseaddr = devm_ioremap_resource(dev, res); + udc->udp_baseaddr = (void *)udc->board.baseaddr; if (IS_ERR(udc->udp_baseaddr)) return PTR_ERR(udc->udp_baseaddr);
@@ -1851,186 +1615,11 @@ static int at91udc_probe(struct platform_device *pdev)
udc_reinit(udc);
- /* get interface and function clocks */ - udc->iclk = devm_clk_get(dev, "pclk"); - if (IS_ERR(udc->iclk)) - return PTR_ERR(udc->iclk); - - udc->fclk = devm_clk_get(dev, "hclk"); - if (IS_ERR(udc->fclk)) - return PTR_ERR(udc->fclk); - - /* don't do anything until we have both gadget driver and VBUS */ - clk_set_rate(udc->fclk, 48000000); - retval = clk_prepare(udc->fclk); - if (retval) - return retval; - - retval = clk_prepare_enable(udc->iclk); - if (retval) - goto err_unprepare_fclk; - at91_udp_write(udc, AT91_UDP_TXVC, AT91_UDP_TXVC_TXVDIS); at91_udp_write(udc, AT91_UDP_IDR, 0xffffffff); /* Clear all pending interrupts - UDP may be used by bootloader. */ at91_udp_write(udc, AT91_UDP_ICR, 0xffffffff); - clk_disable(udc->iclk); - - /* request UDC and maybe VBUS irqs */ - udc->udp_irq = platform_get_irq(pdev, 0); - retval = devm_request_irq(dev, udc->udp_irq, at91_udc_irq, 0, - driver_name, udc); - if (retval) { - DBG("request irq %d failed\n", udc->udp_irq); - goto err_unprepare_iclk; - } - - if (gpio_is_valid(udc->board.vbus_pin)) { - retval = devm_gpio_request(dev, udc->board.vbus_pin, - "udc_vbus"); - if (retval) { - DBG("request vbus pin failed\n"); - goto err_unprepare_iclk; - } - - gpio_direction_input(udc->board.vbus_pin); - - /* - * Get the initial state of VBUS - we cannot expect - * a pending interrupt. - */ - udc->vbus = gpio_get_value_cansleep(udc->board.vbus_pin) ^ - udc->board.vbus_active_low; - - if (udc->board.vbus_polled) { - INIT_WORK(&udc->vbus_timer_work, at91_vbus_timer_work); - setup_timer(&udc->vbus_timer, at91_vbus_timer, - (unsigned long)udc); - mod_timer(&udc->vbus_timer, - jiffies + VBUS_POLL_TIMEOUT); - } else { - retval = devm_request_irq(dev, - gpio_to_irq(udc->board.vbus_pin), - at91_vbus_irq, 0, driver_name, udc); - if (retval) { - DBG("request vbus irq %d failed\n", - udc->board.vbus_pin); - goto err_unprepare_iclk; - } - } - } else { - DBG("no VBUS detection, assuming always-on\n"); - udc->vbus = 1; - } - retval = usb_add_gadget_udc(dev, &udc->gadget); - if (retval) - goto err_unprepare_iclk; - dev_set_drvdata(dev, udc); - device_init_wakeup(dev, 1); - create_debug_file(udc);
INFO("%s version %s\n", driver_name, DRIVER_VERSION); return 0; - -err_unprepare_iclk: - clk_unprepare(udc->iclk); -err_unprepare_fclk: - clk_unprepare(udc->fclk); - - DBG("%s probe failed, %d\n", driver_name, retval); - - return retval; -} - -static int at91udc_remove(struct platform_device *pdev) -{ - struct at91_udc *udc = platform_get_drvdata(pdev); - unsigned long flags; - - DBG("remove\n"); - - usb_del_gadget_udc(&udc->gadget); - if (udc->driver) - return -EBUSY; - - spin_lock_irqsave(&udc->lock, flags); - pullup(udc, 0); - spin_unlock_irqrestore(&udc->lock, flags); - - device_init_wakeup(&pdev->dev, 0); - remove_debug_file(udc); - clk_unprepare(udc->fclk); - clk_unprepare(udc->iclk); - - return 0; } - -#ifdef CONFIG_PM -static int at91udc_suspend(struct platform_device *pdev, pm_message_t mesg) -{ - struct at91_udc *udc = platform_get_drvdata(pdev); - int wake = udc->driver && device_may_wakeup(&pdev->dev); - unsigned long flags; - - /* Unless we can act normally to the host (letting it wake us up - * whenever it has work for us) force disconnect. Wakeup requires - * PLLB for USB events (signaling for reset, wakeup, or incoming - * tokens) and VBUS irqs (on systems which support them). - */ - if ((!udc->suspended && udc->addr) - || !wake - || at91_suspend_entering_slow_clock()) { - spin_lock_irqsave(&udc->lock, flags); - pullup(udc, 0); - wake = 0; - spin_unlock_irqrestore(&udc->lock, flags); - } else - enable_irq_wake(udc->udp_irq); - - udc->active_suspend = wake; - if (gpio_is_valid(udc->board.vbus_pin) && !udc->board.vbus_polled && wake) - enable_irq_wake(udc->board.vbus_pin); - return 0; -} - -static int at91udc_resume(struct platform_device *pdev) -{ - struct at91_udc *udc = platform_get_drvdata(pdev); - unsigned long flags; - - if (gpio_is_valid(udc->board.vbus_pin) && !udc->board.vbus_polled && - udc->active_suspend) - disable_irq_wake(udc->board.vbus_pin); - - /* maybe reconnect to host; if so, clocks on */ - if (udc->active_suspend) - disable_irq_wake(udc->udp_irq); - else { - spin_lock_irqsave(&udc->lock, flags); - pullup(udc, 1); - spin_unlock_irqrestore(&udc->lock, flags); - } - return 0; -} -#else -#define at91udc_suspend NULL -#define at91udc_resume NULL -#endif - -static struct platform_driver at91_udc_driver = { - .remove = at91udc_remove, - .shutdown = at91udc_shutdown, - .suspend = at91udc_suspend, - .resume = at91udc_resume, - .driver = { - .name = (char *) driver_name, - .of_match_table = at91_udc_dt_ids, - }, -}; - -module_platform_driver_probe(at91_udc_driver, at91udc_probe); - -MODULE_DESCRIPTION("AT91 udc driver"); -MODULE_AUTHOR("Thomas Rathbone, David Brownell"); -MODULE_LICENSE("GPL"); -MODULE_ALIAS("platform:at91_udc"); diff --git a/drivers/usb/gadget/at91_udc.h b/drivers/usb/gadget/at91_udc.h index 2679c8b..3d8752e 100644 --- a/drivers/usb/gadget/at91_udc.h +++ b/drivers/usb/gadget/at91_udc.h @@ -128,18 +128,14 @@ struct at91_udc { unsigned req_pending:1; unsigned wait_for_addr_ack:1; unsigned wait_for_config_ack:1; + unsigned selfpowered:1; unsigned active_suspend:1; u8 addr; struct at91_udc_data board; - struct clk *iclk, *fclk; - struct platform_device *pdev; - struct proc_dir_entry *pde; void __iomem *udp_baseaddr; int udp_irq; spinlock_t lock; - struct timer_list vbus_timer; - struct work_struct vbus_timer_work; - struct regmap *matrix; + struct at91_matrix *matrix; };
static inline struct at91_udc *to_udc(struct usb_gadget *g) @@ -166,10 +162,10 @@ struct at91_request { # define PACKET(stuff...) do{}while(0) #endif
-#define ERR(stuff...) pr_err("udc: " stuff) -#define WARNING(stuff...) pr_warning("udc: " stuff) -#define INFO(stuff...) pr_info("udc: " stuff) -#define DBG(stuff...) pr_debug("udc: " stuff) +#define ERR(stuff...) debug("udc: " stuff) +#define WARNING(stuff...) debug("udc: " stuff) +#define INFO(stuff...) debug("udc: " stuff) +#define DBG(stuff...) debug("udc: " stuff)
#endif
diff --git a/include/linux/usb/at91_udc.h b/include/linux/usb/at91_udc.h new file mode 100644 index 0000000..cd0d00f --- /dev/null +++ b/include/linux/usb/at91_udc.h @@ -0,0 +1,20 @@ +/* + * Platform data definitions for Atmel USBA gadget driver + * pieces copied from linux:include/linux/platform_data/atmel.h + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#ifndef __LINUX_USB_AT91_UDC_H__ +#define __LINUX_USB_AT91_UDC_H__ + +struct at91_udc_data { + int vbus_pin; /* high == host powering us */ + u8 vbus_active_low; /* vbus polarity */ + u8 vbus_polled; /* Use polling, not interrupt */ + int pullup_pin; /* active == D+ pulled up */ + u8 pullup_active_low; /* true == pullup_pin is active low */ + unsigned long baseaddr; +}; + +int at91_udc_probe(struct at91_udc_data *pdata); +#endif /* __LINUX_USB_AT91_UDC_H__ */
[root@pollux dfu-util]# ./src/dfu-util -l dfu-util 0.8
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc. Copyright 2010-2014 Tormod Volden and Stefan Schmidt This program is Free Software and has ABSOLUTELY NO WARRANTY Please report bugs to dfu-util@lists.gnumonks.org
Found DFU: [0908:02d2] ver=0212, devnum=119, cfg=1, intf=0, alt=0, name="Linux", serial="UNKNOWN" [root@pollux dfu-util]#
Signed-off-by: Heiko Schocher hs@denx.de ---
Changes in v4: - rebase after taurus board changes
Changes in v3: None Changes in v2: - rebase to bd48c0617b5c7212e5bf22169e716da878842da4 - fix changes introduced through commit: 01acd6abbdd5: usb: USB download gadget and functions config options coherent naming - add comments from Lukasz Majewski l.majewski@samsung.com - use SZ_X defines
board/siemens/smartweb/smartweb.c | 29 +++++++++++++++++++++ board/siemens/taurus/taurus.c | 27 ++++++++++++++++++++ include/configs/smartweb.h | 53 +++++++++++++++++++++++++++++---------- include/configs/taurus.h | 30 ++++++++++++++++++++-- 4 files changed, 124 insertions(+), 15 deletions(-)
diff --git a/board/siemens/smartweb/smartweb.c b/board/siemens/smartweb/smartweb.c index cf8a7f5..2d42488 100644 --- a/board/siemens/smartweb/smartweb.c +++ b/board/siemens/smartweb/smartweb.c @@ -25,6 +25,7 @@ #include <asm/arch/at91_pmc.h> #include <asm/arch/at91_spi.h> #include <spi.h> +#include <asm/arch/clk.h> #include <asm/arch/gpio.h> #include <watchdog.h> #ifdef CONFIG_MACB @@ -108,6 +109,29 @@ static void smartweb_macb_hw_init(void) } #endif /* CONFIG_MACB */
+#ifdef CONFIG_USB_GADGET_AT91 +#include <linux/usb/at91_udc.h> + +void at91_udp_hw_init(void) +{ + at91_pmc_t *pmc = (at91_pmc_t *)ATMEL_BASE_PMC; + + /* Enable PLLB */ + writel(get_pllb_init(), &pmc->pllbr); + while ((readl(&pmc->sr) & AT91_PMC_LOCKB) != AT91_PMC_LOCKB) + ; + + /* Enable UDPCK clock, MCK is enabled in at91_clock_init() */ + at91_periph_clk_enable(ATMEL_ID_UDP); + + writel(AT91SAM926x_PMC_UDP, &pmc->scer); +} + +struct at91_udc_data board_udc_data = { + .baseaddr = ATMEL_BASE_UDP0, +}; +#endif + int board_early_init_f(void) { /* enable this here, as we have SPL without serial support */ @@ -134,6 +158,11 @@ int board_init(void) at91_set_gpio_output(AT91_PIN_PC10, 0); at91_set_gpio_output(AT91_PIN_PC11, 1);
+#ifdef CONFIG_USB_GADGET_AT91 + at91_udp_hw_init(); + at91_udc_probe(&board_udc_data); +#endif + return 0; }
diff --git a/board/siemens/taurus/taurus.c b/board/siemens/taurus/taurus.c index edeb15b..72c5e60 100644 --- a/board/siemens/taurus/taurus.c +++ b/board/siemens/taurus/taurus.c @@ -285,6 +285,29 @@ void spi_cs_deactivate(struct spi_slave *slave) at91_set_gpio_value(TAURUS_SPI_CS_PIN, 1); }
+#ifdef CONFIG_USB_GADGET_AT91 +#include <linux/usb/at91_udc.h> + +void at91_udp_hw_init(void) +{ + at91_pmc_t *pmc = (at91_pmc_t *)ATMEL_BASE_PMC; + + /* Enable PLLB */ + writel(get_pllb_init(), &pmc->pllbr); + while ((readl(&pmc->sr) & AT91_PMC_LOCKB) != AT91_PMC_LOCKB) + ; + + /* Enable UDPCK clock, MCK is enabled in at91_clock_init() */ + at91_periph_clk_enable(ATMEL_ID_UDP); + + writel(AT91SAM926x_PMC_UDP, &pmc->scer); +} + +struct at91_udc_data board_udc_data = { + .baseaddr = ATMEL_BASE_UDP0, +}; +#endif + int board_init(void) { /* adress of boot parameters */ @@ -297,6 +320,10 @@ int board_init(void) taurus_macb_hw_init(); #endif at91_spi0_hw_init(TAURUS_SPI_MASK); +#ifdef CONFIG_USB_GADGET_AT91 + at91_udp_hw_init(); + at91_udc_probe(&board_udc_data); +#endif
return 0; } diff --git a/include/configs/smartweb.h b/include/configs/smartweb.h index d696d4b..d189c3f 100644 --- a/include/configs/smartweb.h +++ b/include/configs/smartweb.h @@ -28,6 +28,7 @@ * In this case SoC is defined in boards.cfg. */ #include <asm/hardware.h> +#include <linux/sizes.h>
/* * Warning: changing CONFIG_SYS_TEXT_BASE requires adapting the initial boot @@ -64,7 +65,7 @@ */ #define CONFIG_NR_DRAM_BANKS 1 #define CONFIG_SYS_SDRAM_BASE ATMEL_BASE_CS1 -#define CONFIG_SYS_SDRAM_SIZE (64 << 20) +#define CONFIG_SYS_SDRAM_SIZE (64 * SZ_1M)
/* * Perform a SDRAM Memtest from the start of SDRAM @@ -75,7 +76,7 @@
/* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN \ - ROUND(3 * CONFIG_ENV_SIZE + (128 << 10), 0x1000) + ROUND(3 * CONFIG_ENV_SIZE + (4 * SZ_1M), 0x1000)
/* NAND flash settings */ #define CONFIG_NAND_ATMEL @@ -140,15 +141,42 @@
#if !defined(CONFIG_SPL_BUILD) /* USB configuration */ +#define CONFIG_CMD_USB #define CONFIG_USB_ATMEL #define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW -#define CONFIG_USB_STORAGE -#define CONFIG_DOS_PARTITION #define CONFIG_SYS_USB_OHCI_CPU_INIT #define CONFIG_SYS_USB_OHCI_REGS_BASE ATMEL_UHP_BASE #define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9260" #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 + +#define CONFIG_USB_HOST_ETHER +#define CONFIG_USB_ETHER_ASIX +#define CONFIG_USB_ETHER_MCS7830 + +/* USB DFU support */ +#define CONFIG_CMD_MTDPARTS +#define CONFIG_MTD_DEVICE +#define CONFIG_MTD_PARTITIONS + +#define CONFIG_USB_GADGET +#define CONFIG_USB_GADGET_AT91 + +/* DFU class support */ +#define CONFIG_CMD_DFU +#define CONFIG_USB_FUNCTION_DFU +#define CONFIG_DFU_NAND +#define CONFIG_USB_GADGET_DOWNLOAD +#define CONFIG_USB_GADGET_VBUS_DRAW 2 +#define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_1M +#define DFU_MANIFEST_POLL_TIMEOUT 25000 + +/* USB DFU IDs */ +#define CONFIG_G_DNL_VENDOR_NUM 0x0908 +#define CONFIG_G_DNL_PRODUCT_NUM 0x02d2 +#define CONFIG_G_DNL_MANUFACTURER "Siemens AG" + +#define CONFIG_SYS_CACHELINE_SIZE 0x2000 #endif
/* General Boot Parameter */ @@ -173,8 +201,8 @@ #define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET (0x100000) #define CONFIG_ENV_OFFSET_REDUND (0x180000) -#define CONFIG_ENV_RANGE (0x80000) -#define CONFIG_ENV_SIZE (0x20000) +#define CONFIG_ENV_RANGE (SZ_512K) +#define CONFIG_ENV_SIZE (SZ_128K)
/* * Predefined environment variables. @@ -193,7 +221,6 @@ #undef CONFIG_CMD_LOADS
#define CONFIG_CMD_NAND -#define CONFIG_CMD_USB #define CONFIG_CMD_FAT
#ifdef CONFIG_MACB @@ -230,10 +257,10 @@ /* Defines for SPL */ #define CONFIG_SPL_FRAMEWORK #define CONFIG_SPL_TEXT_BASE 0x0 -#define CONFIG_SPL_MAX_SIZE (4 * 1024) +#define CONFIG_SPL_MAX_SIZE (SZ_4K)
#define CONFIG_SPL_BSS_START_ADDR CONFIG_SYS_SDRAM_BASE -#define CONFIG_SPL_BSS_MAX_SIZE (16 * 1024) +#define CONFIG_SPL_BSS_MAX_SIZE (SZ_16K) #define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SPL_BSS_START_ADDR + \ CONFIG_SPL_BSS_MAX_SIZE) #define CONFIG_SYS_SPL_MALLOC_SIZE CONFIG_SYS_MALLOC_LEN @@ -253,14 +280,14 @@ #define CONFIG_SPL_NAND_RAW_ONLY #define CONFIG_SPL_NAND_SOFTECC #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x20000 -#define CONFIG_SYS_NAND_U_BOOT_SIZE 0x80000 +#define CONFIG_SYS_NAND_U_BOOT_SIZE SZ_512K #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_5_ADDR_CYCLE
-#define CONFIG_SYS_NAND_SIZE (256*1024*1024) -#define CONFIG_SYS_NAND_PAGE_SIZE 2048 -#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) +#define CONFIG_SYS_NAND_SIZE (SZ_256M) +#define CONFIG_SYS_NAND_PAGE_SIZE SZ_2K +#define CONFIG_SYS_NAND_BLOCK_SIZE (SZ_128K) #define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ CONFIG_SYS_NAND_PAGE_SIZE) #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS diff --git a/include/configs/taurus.h b/include/configs/taurus.h index c1fed9a..12994c8 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -121,12 +121,38 @@ /* USB */ #if defined(CONFIG_BOARD_TAURUS) #define CONFIG_USB_ATMEL +#define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW #define CONFIG_SYS_USB_OHCI_CPU_INIT #define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00500000 #define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9260" #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 #define CONFIG_USB_STORAGE + +/* USB DFU support */ +#define CONFIG_CMD_MTDPARTS +#define CONFIG_MTD_DEVICE +#define CONFIG_MTD_PARTITIONS + +#define CONFIG_USB_GADGET +#define CONFIG_USB_GADGET_AT91 + +/* DFU class support */ +#define CONFIG_CMD_USB +#define CONFIG_CMD_DFU +#define CONFIG_USB_FUNCTION_DFU +#define CONFIG_DFU_NAND +#define CONFIG_USB_GADGET_DOWNLOAD +#define CONFIG_USB_GADGET_VBUS_DRAW 2 +#define CONFIG_SYS_DFU_DATA_BUF_SIZE (SZ_1M) +#define DFU_MANIFEST_POLL_TIMEOUT 25000 + +/* USB DFU IDs */ +#define CONFIG_G_DNL_VENDOR_NUM 0x0908 +#define CONFIG_G_DNL_PRODUCT_NUM 0x02d2 +#define CONFIG_G_DNL_MANUFACTURER "Siemens AG" + +#define CONFIG_SYS_CACHELINE_SIZE SZ_8K #endif
/* SPI EEPROM */ @@ -242,7 +268,7 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN \ - ROUND(3 * CONFIG_ENV_SIZE + SZ_128K, 0x1000) + ROUND(3 * CONFIG_ENV_SIZE + SZ_4M, 0x1000)
/* Defines for SPL */ #define CONFIG_SPL_FRAMEWORK @@ -271,7 +297,7 @@ #define CONFIG_SPL_NAND_RAW_ONLY #define CONFIG_SPL_NAND_SOFTECC #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x20000 -#define CONFIG_SYS_NAND_U_BOOT_SIZE 0x80000 +#define CONFIG_SYS_NAND_U_BOOT_SIZE SZ_512K #define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_5_ADDR_CYCLE
participants (14)
Anatolij Gustschin
Andreas Bießmann
Andreas Bießmann
Heiko Schocher
Ivan Khoronzhuk
ivan.khoronzhuk
Jagan Teki
Michael Heimpold
Scott Wood
Stefan Roese
Tom Warren
