[PATCH v2 0/4] Add QOS support for J722S and AM62P
Add QOS support for DSS in TI K3 SoC to route the DSS traffic through RT queue by setting orderID as 15: - J722S - AM62P
Changelog v1->v2: - Rebased on the tip of next branch - Corrected the commit message in patch 2/4
v1: https://lore.kernel.org/all/20241106063930.59870-1-j-choudhary@ti.com/
Jayesh Choudhary (4): arm: mach-k3: j722s: Add QoS support for DSS arm: mach-k3: am62p: Add QoS support for DSS configs: j722s_evm_r5_defconfig: Enable CONFIG_K3_QOS configs: am62p_evm_r5_defconfig: Enable CONFIG_K3_QOS
arch/arm/mach-k3/am62px/am62p5_init.c | 2 + arch/arm/mach-k3/j722s/j722s_init.c | 1 + arch/arm/mach-k3/r5/am62px/Makefile | 1 + arch/arm/mach-k3/r5/am62px/am62p_qos.h | 42 ++++++++++++++ arch/arm/mach-k3/r5/am62px/am62p_qos_uboot.c | 58 ++++++++++++++++++++ arch/arm/mach-k3/r5/j722s/Makefile | 1 + arch/arm/mach-k3/r5/j722s/j722s_qos.h | 51 +++++++++++++++++ arch/arm/mach-k3/r5/j722s/j722s_qos_uboot.c | 58 ++++++++++++++++++++ configs/am62px_evm_r5_defconfig | 1 + configs/j722s_evm_r5_defconfig | 1 + 10 files changed, 216 insertions(+) create mode 100644 arch/arm/mach-k3/r5/am62px/am62p_qos.h create mode 100644 arch/arm/mach-k3/r5/am62px/am62p_qos_uboot.c create mode 100644 arch/arm/mach-k3/r5/j722s/j722s_qos.h create mode 100644 arch/arm/mach-k3/r5/j722s/j722s_qos_uboot.c
Enable Quality of Service (QoS) blocks for Display SubSystem (DSS), by servicing the DSS - DDR traffic from the Real-Time (RT) queue. This is done by setting the DSS DMA orderID to greater than 7.
The C7x and VPAC can overwhelm the DSS's access to the DDR because of their higher frequency DDR accesses. This can cause flickering in display with certain edgeAI models running parallely if the DSS traffic is being serviced through non-RT queue.
Signed-off-by: Jayesh Choudhary j-choudhary@ti.com --- arch/arm/mach-k3/j722s/j722s_init.c | 1 + arch/arm/mach-k3/r5/j722s/Makefile | 1 + arch/arm/mach-k3/r5/j722s/j722s_qos.h | 51 ++++++++++++++++++ arch/arm/mach-k3/r5/j722s/j722s_qos_uboot.c | 58 +++++++++++++++++++++ 4 files changed, 111 insertions(+) create mode 100644 arch/arm/mach-k3/r5/j722s/j722s_qos.h create mode 100644 arch/arm/mach-k3/r5/j722s/j722s_qos_uboot.c
diff --git a/arch/arm/mach-k3/j722s/j722s_init.c b/arch/arm/mach-k3/j722s/j722s_init.c index 01b00681f6..0313e1148b 100644 --- a/arch/arm/mach-k3/j722s/j722s_init.c +++ b/arch/arm/mach-k3/j722s/j722s_init.c @@ -165,6 +165,7 @@ void board_init_f(ulong dummy) { k3_spl_init(); k3_mem_init(); + setup_qos(); }
static u32 __get_backup_bootmedia(u32 devstat) diff --git a/arch/arm/mach-k3/r5/j722s/Makefile b/arch/arm/mach-k3/r5/j722s/Makefile index 2a0dbf5f5a..2f0b35a41e 100644 --- a/arch/arm/mach-k3/r5/j722s/Makefile +++ b/arch/arm/mach-k3/r5/j722s/Makefile @@ -4,3 +4,4 @@
obj-y += clk-data.o obj-y += dev-data.o +obj-y += j722s_qos_uboot.o diff --git a/arch/arm/mach-k3/r5/j722s/j722s_qos.h b/arch/arm/mach-k3/r5/j722s/j722s_qos.h new file mode 100644 index 0000000000..88fa208322 --- /dev/null +++ b/arch/arm/mach-k3/r5/j722s/j722s_qos.h @@ -0,0 +1,51 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Keystone3 Quality of service endpoint definitions + * Auto generated by K3 Resource Partitioning Tool + * + * Copyright (C) 2024 Texas Instruments Incorporated - https://www.ti.com/ + */ + +#define PULSAR_UL_WKUP_0_CPU0_RMST 0x45D14000 +#define PULSAR_UL_WKUP_0_CPU0_WMST 0x45D14400 +#define PULSAR_UL_WKUP_0_CPU0_PMST 0x45D14800 +#define PULSAR_UL_MAIN_0_CPU0_RMST 0x45D15000 +#define PULSAR_UL_MAIN_0_CPU0_WMST 0x45D15400 +#define PULSAR_UL_MAIN_0_CPU0_PMST 0x45D15800 +#define PULSAR_ULS_MCU_0_CPU0_RMST 0x45D18000 +#define PULSAR_ULS_MCU_0_CPU0_WMST 0x45D18400 +#define PULSAR_ULS_MCU_0_CPU0_PMST 0x45D18800 +#define SAM62A_A53_512KB_WRAP_MAIN_0_A53_QUAD_WRAP_CBA_AXI_R 0x45D20400 +#define SAM62A_A53_512KB_WRAP_MAIN_0_A53_QUAD_WRAP_CBA_AXI_W 0x45D20800 +#define DEBUGSS_K3_WRAP_CV0_MAIN_0_VBUSMW 0x45D21800 +#define DEBUGSS_K3_WRAP_CV0_MAIN_0_VBUSMR 0x45D21C00 +#define GIC500SS_1_4_MAIN_0_MEM_WR_VBUSM 0x45D22000 +#define GIC500SS_1_4_MAIN_0_MEM_RD_VBUSM 0x45D22400 +#define EMMCSD4SS_MAIN_0_EMMCSDSS_RD 0x45D23000 +#define EMMCSD4SS_MAIN_0_EMMCSDSS_WR 0x45D23400 +#define EMMCSD4SS_MAIN_1_EMMCSDSS_WR 0x45D23800 +#define EMMCSD4SS_MAIN_1_EMMCSDSS_RD 0x45D23C00 +#define USB3P0SS64_16FFC_MAIN_0_MSTR0 0x45D24800 +#define USB3P0SS64_16FFC_MAIN_0_MSTW0 0x45D24C00 +#define SA3SS_AM62A_MAIN_0_CTXCACH_EXT_DMA 0x45D25400 +#define K3_JPGENC_E5010_MAIN_0_M_VBUSM_W 0x45D25800 +#define K3_JPGENC_E5010_MAIN_0_M_VBUSM_R 0x45D25C00 +#define K3_VPU_WAVE521CL_MAIN_0_PRI_M_VBUSM_R_ASYNC 0x45D26800 +#define K3_VPU_WAVE521CL_MAIN_0_PRI_M_VBUSM_W_ASYNC 0x45D26C00 +#define K3_VPU_WAVE521CL_MAIN_0_SEC_M_VBUSM_R_ASYNC 0x45D27000 +#define K3_VPU_WAVE521CL_MAIN_0_SEC_M_VBUSM_W_ASYNC 0x45D27400 +#define SAM67_C7XV_WRAP_MAIN_0_C7XV_SOC 0x45D27800 +#define SAM67_VPAC_WRAP_MAIN_0_LDC0_M_MST 0x45D28000 +#define PCIE_G2X1_64_MAIN_0_PCIE_MST_RD 0x45D29000 +#define PCIE_G2X1_64_MAIN_0_PCIE_MST_WR 0x45D29400 +#define SAM67_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC 0x45D29800 +#define SAM67_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC 0x45D2A000 +#define SAM67_C7XV_WRAP_MAIN_1_C7XV_SOC 0x45D2C000 +#define K3_DSS_UL_MAIN_0_VBUSM_DMA 0x45D30000 +#define K3_DSS_UL_MAIN_1_VBUSM_DMA 0x45D30400 +#define USB2SS_16FFC_MAIN_0_MSTR0 0x45D34000 +#define USB2SS_16FFC_MAIN_0_MSTW0 0x45D34400 +#define EMMC8SS_16FFC_MAIN_0_EMMCSS_WR 0x45D34800 +#define EMMC8SS_16FFC_MAIN_0_EMMCSS_RD 0x45D34C00 +#define USB2SS_16FFC_MAIN_1_MSTR0 0x45D35000 +#define USB2SS_16FFC_MAIN_1_MSTW0 0x45D35400 diff --git a/arch/arm/mach-k3/r5/j722s/j722s_qos_uboot.c b/arch/arm/mach-k3/r5/j722s/j722s_qos_uboot.c new file mode 100644 index 0000000000..1d59f49252 --- /dev/null +++ b/arch/arm/mach-k3/r5/j722s/j722s_qos_uboot.c @@ -0,0 +1,58 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * j722s Quality of Service (QoS) Configuration Data + * + * Copyright (C) 2024 Texas Instruments Incorporated - https://www.ti.com/ + */ + +#include <asm/arch/k3-qos.h> +#include "j722s_qos.h" + +struct k3_qos_data qos_data[] = { + /* modules_qosConfig0 - 1 endpoints, 4 channels */ + { + .reg = K3_QOS_REG(K3_DSS_UL_MAIN_0_VBUSM_DMA, 0), + .val = K3_QOS_VAL(0, 15, 0, 0, 0, 0), + }, + { + .reg = K3_QOS_REG(K3_DSS_UL_MAIN_0_VBUSM_DMA, 1), + .val = K3_QOS_VAL(0, 15, 0, 0, 0, 0), + }, + { + .reg = K3_QOS_REG(K3_DSS_UL_MAIN_0_VBUSM_DMA, 2), + .val = K3_QOS_VAL(0, 15, 0, 0, 0, 0), + }, + { + .reg = K3_QOS_REG(K3_DSS_UL_MAIN_0_VBUSM_DMA, 3), + .val = K3_QOS_VAL(0, 15, 0, 0, 0, 0), + }, + + /* modules_qosConfig1 - 1 endpoints, 4 channels */ + { + .reg = K3_QOS_REG(K3_DSS_UL_MAIN_1_VBUSM_DMA, 0), + .val = K3_QOS_VAL(0, 15, 0, 0, 0, 0), + }, + { + .reg = K3_QOS_REG(K3_DSS_UL_MAIN_1_VBUSM_DMA, 1), + .val = K3_QOS_VAL(0, 15, 0, 0, 0, 0), + }, + { + .reg = K3_QOS_REG(K3_DSS_UL_MAIN_1_VBUSM_DMA, 2), + .val = K3_QOS_VAL(0, 15, 0, 0, 0, 0), + }, + { + .reg = K3_QOS_REG(K3_DSS_UL_MAIN_1_VBUSM_DMA, 3), + .val = K3_QOS_VAL(0, 15, 0, 0, 0, 0), + }, + + /* Following registers set 1:1 mapping for orderID MAP1/MAP2 + * remap registers. orderID x is remapped to orderID x again + * This is to ensure orderID from MAP register is unchanged + */ + + /* K3_DSS_UL_MAIN_0_VBUSM_DMA - 0 groups */ + + /* K3_DSS_UL_MAIN_1_VBUSM_DMA - 0 groups */ +}; + +u32 qos_count = ARRAY_SIZE(qos_data);
DDR intensive software applications can overwhelm the DSS's access to the DDR because of their higher frequency DDR accesses. This can cause flickering in display with certain applications running parallely if the DSS traffic is being serviced through non-RT queue.
Signed-off-by: Jayesh Choudhary j-choudhary@ti.com --- arch/arm/mach-k3/am62px/am62p5_init.c | 2 + arch/arm/mach-k3/r5/am62px/Makefile | 1 + arch/arm/mach-k3/r5/am62px/am62p_qos.h | 42 ++++++++++++++ arch/arm/mach-k3/r5/am62px/am62p_qos_uboot.c | 58 ++++++++++++++++++++ 4 files changed, 103 insertions(+) create mode 100644 arch/arm/mach-k3/r5/am62px/am62p_qos.h create mode 100644 arch/arm/mach-k3/r5/am62px/am62p_qos_uboot.c
diff --git a/arch/arm/mach-k3/am62px/am62p5_init.c b/arch/arm/mach-k3/am62px/am62p5_init.c index 34ed01cd78..2d35a7ce77 100644 --- a/arch/arm/mach-k3/am62px/am62p5_init.c +++ b/arch/arm/mach-k3/am62px/am62p5_init.c @@ -159,6 +159,8 @@ void board_init_f(ulong dummy) }
spl_enable_cache(); + + setup_qos(); debug("am62px_init: %s done\n", __func__); }
diff --git a/arch/arm/mach-k3/r5/am62px/Makefile b/arch/arm/mach-k3/r5/am62px/Makefile index 091d4fa5b4..066c3cef8d 100644 --- a/arch/arm/mach-k3/r5/am62px/Makefile +++ b/arch/arm/mach-k3/r5/am62px/Makefile @@ -4,3 +4,4 @@
obj-y += clk-data.o obj-y += dev-data.o +obj-y += am62p_qos_uboot.o diff --git a/arch/arm/mach-k3/r5/am62px/am62p_qos.h b/arch/arm/mach-k3/r5/am62px/am62p_qos.h new file mode 100644 index 0000000000..99e2ee4856 --- /dev/null +++ b/arch/arm/mach-k3/r5/am62px/am62p_qos.h @@ -0,0 +1,42 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Keystone3 Quality of service endpoint definitions + * Auto generated by K3 Resource Partitioning Tool + * + * Copyright (C) 2024 Texas Instruments Incorporated - https://www.ti.com/ + */ + +#define PULSAR_UL_WKUP_0_CPU0_RMST 0x45D14000 +#define PULSAR_UL_WKUP_0_CPU0_WMST 0x45D14400 +#define PULSAR_UL_WKUP_0_CPU0_PMST 0x45D14800 +#define PULSAR_UL_MAIN_0_CPU0_RMST 0x45D15000 +#define PULSAR_UL_MAIN_0_CPU0_WMST 0x45D15400 +#define PULSAR_UL_MAIN_0_CPU0_PMST 0x45D15800 +#define PULSAR_ULS_MCU_0_CPU0_RMST 0x45D18000 +#define PULSAR_ULS_MCU_0_CPU0_WMST 0x45D18400 +#define PULSAR_ULS_MCU_0_CPU0_PMST 0x45D18800 +#define SAM62A_A53_512KB_WRAP_MAIN_0_A53_QUAD_WRAP_CBA_AXI_R 0x45D20400 +#define SAM62A_A53_512KB_WRAP_MAIN_0_A53_QUAD_WRAP_CBA_AXI_W 0x45D20800 +#define DEBUGSS_K3_WRAP_CV0_MAIN_0_VBUSMW 0x45D21800 +#define DEBUGSS_K3_WRAP_CV0_MAIN_0_VBUSMR 0x45D21C00 +#define GIC500SS_1_4_MAIN_0_MEM_WR_VBUSM 0x45D22000 +#define GIC500SS_1_4_MAIN_0_MEM_RD_VBUSM 0x45D22400 +#define EMMCSD4SS_MAIN_0_EMMCSDSS_RD 0x45D23000 +#define EMMCSD4SS_MAIN_0_EMMCSDSS_WR 0x45D23400 +#define EMMCSD4SS_MAIN_1_EMMCSDSS_WR 0x45D23800 +#define EMMCSD4SS_MAIN_1_EMMCSDSS_RD 0x45D23C00 +#define SA3SS_AM62A_MAIN_0_CTXCACH_EXT_DMA 0x45D25400 +#define K3_VPU_WAVE521CL_MAIN_0_PRI_M_VBUSM_R_ASYNC 0x45D26800 +#define K3_VPU_WAVE521CL_MAIN_0_PRI_M_VBUSM_W_ASYNC 0x45D26C00 +#define K3_VPU_WAVE521CL_MAIN_0_SEC_M_VBUSM_R_ASYNC 0x45D27000 +#define K3_VPU_WAVE521CL_MAIN_0_SEC_M_VBUSM_W_ASYNC 0x45D27400 +#define SAM67_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_W_SYNC 0x45D29800 +#define SAM67_GPU_BXS464_WRAP_MAIN_0_M_VBUSM_R_SYNC 0x45D2A000 +#define K3_DSS_UL_MAIN_0_VBUSM_DMA 0x45D30000 +#define K3_DSS_UL_MAIN_1_VBUSM_DMA 0x45D30400 +#define USB2SS_16FFC_MAIN_0_MSTR0 0x45D34000 +#define USB2SS_16FFC_MAIN_0_MSTW0 0x45D34400 +#define EMMC8SS_16FFC_MAIN_0_EMMCSS_WR 0x45D34800 +#define EMMC8SS_16FFC_MAIN_0_EMMCSS_RD 0x45D34C00 +#define USB2SS_16FFC_MAIN_1_MSTR0 0x45D35000 +#define USB2SS_16FFC_MAIN_1_MSTW0 0x45D35400 diff --git a/arch/arm/mach-k3/r5/am62px/am62p_qos_uboot.c b/arch/arm/mach-k3/r5/am62px/am62p_qos_uboot.c new file mode 100644 index 0000000000..d25512a038 --- /dev/null +++ b/arch/arm/mach-k3/r5/am62px/am62p_qos_uboot.c @@ -0,0 +1,58 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * am62p Quality of Service (QoS) Configuration Data + * + * Copyright (C) 2024 Texas Instruments Incorporated - https://www.ti.com/ + */ + +#include <asm/arch/k3-qos.h> +#include "am62p_qos.h" + +struct k3_qos_data qos_data[] = { + /* modules_qosConfig0 - 1 endpoints, 4 channels */ + { + .reg = K3_QOS_REG(K3_DSS_UL_MAIN_0_VBUSM_DMA, 0), + .val = K3_QOS_VAL(0, 15, 0, 0, 0, 0), + }, + { + .reg = K3_QOS_REG(K3_DSS_UL_MAIN_0_VBUSM_DMA, 1), + .val = K3_QOS_VAL(0, 15, 0, 0, 0, 0), + }, + { + .reg = K3_QOS_REG(K3_DSS_UL_MAIN_0_VBUSM_DMA, 2), + .val = K3_QOS_VAL(0, 15, 0, 0, 0, 0), + }, + { + .reg = K3_QOS_REG(K3_DSS_UL_MAIN_0_VBUSM_DMA, 3), + .val = K3_QOS_VAL(0, 15, 0, 0, 0, 0), + }, + + /* modules_qosConfig1 - 1 endpoints, 4 channels */ + { + .reg = K3_QOS_REG(K3_DSS_UL_MAIN_1_VBUSM_DMA, 0), + .val = K3_QOS_VAL(0, 15, 0, 0, 0, 0), + }, + { + .reg = K3_QOS_REG(K3_DSS_UL_MAIN_1_VBUSM_DMA, 1), + .val = K3_QOS_VAL(0, 15, 0, 0, 0, 0), + }, + { + .reg = K3_QOS_REG(K3_DSS_UL_MAIN_1_VBUSM_DMA, 2), + .val = K3_QOS_VAL(0, 15, 0, 0, 0, 0), + }, + { + .reg = K3_QOS_REG(K3_DSS_UL_MAIN_1_VBUSM_DMA, 3), + .val = K3_QOS_VAL(0, 15, 0, 0, 0, 0), + }, + + /* Following registers set 1:1 mapping for orderID MAP1/MAP2 + * remap registers. orderID x is remapped to orderID x again + * This is to ensure orderID from MAP register is unchanged + */ + + /* K3_DSS_UL_MAIN_0_VBUSM_DMA - 0 groups */ + + /* K3_DSS_UL_MAIN_1_VBUSM_DMA - 0 groups */ +}; + +u32 qos_count = ARRAY_SIZE(qos_data);
Enable CONFIG_K3_QOS to set QoS registers in R5 boot stage.
Signed-off-by: Jayesh Choudhary j-choudhary@ti.com --- configs/j722s_evm_r5_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/j722s_evm_r5_defconfig b/configs/j722s_evm_r5_defconfig index a3c13fedef..0f7cd4bf37 100644 --- a/configs/j722s_evm_r5_defconfig +++ b/configs/j722s_evm_r5_defconfig @@ -89,6 +89,7 @@ CONFIG_TI_SCI_PROTOCOL=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_OMAP24XX=y CONFIG_DM_MAILBOX=y +CONFIG_K3_QOS=y CONFIG_K3_SEC_PROXY=y CONFIG_MMC_HS400_SUPPORT=y CONFIG_MMC_SDHCI=y
Signed-off-by: Jayesh Choudhary j-choudhary@ti.com --- configs/am62px_evm_r5_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/am62px_evm_r5_defconfig b/configs/am62px_evm_r5_defconfig index a93c33c1d9..a0eaa128f4 100644 --- a/configs/am62px_evm_r5_defconfig +++ b/configs/am62px_evm_r5_defconfig @@ -89,6 +89,7 @@ CONFIG_TI_SCI_PROTOCOL=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_OMAP24XX=y CONFIG_DM_MAILBOX=y +CONFIG_K3_QOS=y CONFIG_K3_SEC_PROXY=y CONFIG_MMC_HS400_SUPPORT=y CONFIG_MMC_SDHCI=y
- J722S
- AM62P
Changelog v1->v2:
For the series, Reviewed-by: Devarsh Thakkar devarsht@ti.com
Regards Devarsh
- J722S
- AM62P
Changelog v1->v2:
Devarsh Thakkar
Jayesh Choudhary
