[U-Boot] [PATCH v2] armv8: fsl-layerscape: reorder rgmii dpmacs' enablement
some dpmacs in armv8a based freescale layerscape SOCs can be configured via both serdes(sgmii, xfi, xlaui etc) bits and via EC*_PMUX(rgmii) bits in RCW. e.g. dpmac 17 and 18 in LX2160A can be configured as SGMII from serdes bits and as RGMII via EC1_PMUX/EC2_PMUX bits Now if a dpmac is enabled by serdes bits then it takes precedence over EC*_PMUX bits. i.e. in LX2160A if we select serdes protocol that configures dpmac17 as SGMII and set the EC1_PMUX as RGMII, then the dpmac is SGMII and not RGMII.
Therefore, move the fsl_rgmii_init after fsl_serdes_init. in fsl_rgmii_init function of SOC, we will check if the dpmac is enabled or not? if it is (fsl_serdes_init has already enabled the dpmac), then don't enable it.
Signed-off-by: Pankaj Bansal pankaj.bansal@nxp.com ---
Notes: V2: - as per review comments, add commit message as inline comments.
arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 22 ++++++++++++++++++---- 1 file changed, 18 insertions(+), 4 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index 052e0708d4..3fe7f885e8 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -553,15 +553,29 @@ int arch_early_init_r(void) printf("Did not wake secondary cores\n"); }
-#ifdef CONFIG_SYS_FSL_HAS_RGMII - fsl_rgmii_init(); -#endif - config_core_prefetch();
#ifdef CONFIG_SYS_HAS_SERDES fsl_serdes_init(); #endif +#ifdef CONFIG_SYS_FSL_HAS_RGMII + /* some dpmacs in armv8a based freescale layerscape SOCs can be + * configured via both serdes(sgmii, xfi, xlaui etc) bits and via + * EC*_PMUX(rgmii) bits in RCW. + * e.g. dpmac 17 and 18 in LX2160A can be configured as SGMII from + * serdes bits and as RGMII via EC1_PMUX/EC2_PMUX bits + * Now if a dpmac is enabled by serdes bits then it takes precedence + * over EC*_PMUX bits. i.e. in LX2160A if we select serdes protocol + * that configures dpmac17 as SGMII and set the EC1_PMUX as RGMII, + * then the dpmac is SGMII and not RGMII. + * + * Therefore, move the fsl_rgmii_init after fsl_serdes_init. in + * fsl_rgmii_init function of SOC, we will check if the dpmac is enabled + * or not? if it is (fsl_serdes_init has already enabled the dpmac), + * then don't enable it. + */ + fsl_rgmii_init(); +#endif #ifdef CONFIG_FMAN_ENET fman_enet_init(); #endif
Pankaj Bansal
