[U-Boot-Users] [PATCH] Fix serial hangs when CONFIG_SERIAL_MULTI is defined
Hi
The following patch fixes the hangs in the serial port when outputting very early.
Testing for global vars early in the boot sequence has unintended consequences so just we check by the GD RELOC flag which is safe to do anytime.
Regards
Pantelis
* Patch by Pantelis Antoniou, 14 Sep 2004: Fix early serial hang when CONFIG_SERIAL_MULTI is defined.
serial.c | 55 ++++++++++++++++++++++++++----------------------------- 1 files changed, 26 insertions(+), 29 deletions(-)
Pantelis Antoniou panto@intracom.gr wrote:
--- u-boot/common/serial.c 2004-08-02 01:48:18.000000000 +0300 +++ u-boot-cvs-work/common/serial.c 2004-09-07 14:23:44.000000000 +0300 @@ -102,6 +102,8 @@ { struct serial_device *s;
- for (s = serial_devices; s; s = s->next) { if (strcmp(s->name, name) == 0)
is it intentional that you disable the body of that function? If yes, why not remove it entirely?
Cheers Anders
Cheers Anders
OBVIOUSLY IT IS WRONG.
Damn, good catch.
Remove the return 0 please.
Regards
Pantelis
Damn, good catch.
Please submit a fixed patch.
Damn, good catch.
Rediffed patch included.
Regards
Pantelis
In message 41469EE1.3040203@intracom.gr you wrote:
- Patch by Pantelis Antoniou, 14 Sep 2004: Fix early serial hang when CONFIG_SERIAL_MULTI is defined.
Added (slightly modified to keep the code readable).
Anders Larsen
Pantelis Antoniou
