[PATCH v3 0/2] upstream DT compatibility
This is a subset of [1]. With more platform maintainers switching to OF_UPSTREAM I didn't want to get in the way (it has also proven more difficult than I hoped to remove only the fully compatible header files).
This series removes only the dt-bindings headers which contain generic data like GPIO flags, input event codes, etc.
It then implements support for building all DTBs for a vendor with OF_UPSTREAM_BUILD_VENDOR. This removes the need to maintain a set list of DTBs that can be built by U-Boot and opens up the possibility of new boards becoming supported "by default" just by landing their DT upstream.
[1]: https://lore.kernel.org/u-boot/20240321-b4-upstream-dt-headers-v2-0-1eac0df8...
--- Caleb Connolly (2): dt-bindings: drop generic headers dts: support building all dtb files for a specific vendor
dts/Kconfig | 24 + include/dt-bindings/ata/ahci.h | 20 - include/dt-bindings/gpio/gpio.h | 42 -- include/dt-bindings/input/gpio-keys.h | 13 - include/dt-bindings/input/input.h | 17 - include/dt-bindings/input/linux-event-codes.h | 806 ------------------------- include/dt-bindings/interrupt-controller/irq.h | 19 - include/dt-bindings/leds/common.h | 106 ---- include/dt-bindings/mux/mux.h | 17 - include/dt-bindings/phy/phy.h | 26 - include/dt-bindings/pwm/pwm.h | 14 - include/dt-bindings/spmi/spmi.h | 10 - include/dt-bindings/thermal/thermal.h | 15 - include/dt-bindings/usb/pd.h | 88 --- scripts/Makefile.dts | 13 + 15 files changed, 37 insertions(+), 1193 deletions(-) --- change-id: 20240409-b4-of-upstream-build-vendor-dc74b4f72e9a base-commit: eb1aaf535683880a4ac3517fc568792fc20cfe3a
// Caleb (they/them)
Drop all the subsystem headers that are compatible with the headers in dts/upstream.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- include/dt-bindings/ata/ahci.h | 20 - include/dt-bindings/gpio/gpio.h | 42 -- include/dt-bindings/input/gpio-keys.h | 13 - include/dt-bindings/input/input.h | 17 - include/dt-bindings/input/linux-event-codes.h | 806 ------------------------- include/dt-bindings/interrupt-controller/irq.h | 19 - include/dt-bindings/leds/common.h | 106 ---- include/dt-bindings/mux/mux.h | 17 - include/dt-bindings/phy/phy.h | 26 - include/dt-bindings/pwm/pwm.h | 14 - include/dt-bindings/spmi/spmi.h | 10 - include/dt-bindings/thermal/thermal.h | 15 - include/dt-bindings/usb/pd.h | 88 --- 13 files changed, 1193 deletions(-)
diff --git a/include/dt-bindings/ata/ahci.h b/include/dt-bindings/ata/ahci.h deleted file mode 100644 index b3f3b7cf9af8..000000000000 --- a/include/dt-bindings/ata/ahci.h +++ /dev/null @@ -1,20 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only OR BSD-2-Clause */ -/* - * This header provides constants for most AHCI bindings. - */ - -#ifndef _DT_BINDINGS_ATA_AHCI_H -#define _DT_BINDINGS_ATA_AHCI_H - -/* Host Bus Adapter generic platform capabilities */ -#define HBA_SSS (1 << 27) -#define HBA_SMPS (1 << 28) - -/* Host Bus Adapter port-specific platform capabilities */ -#define HBA_PORT_HPCP (1 << 18) -#define HBA_PORT_MPSP (1 << 19) -#define HBA_PORT_CPD (1 << 20) -#define HBA_PORT_ESP (1 << 21) -#define HBA_PORT_FBSCP (1 << 22) - -#endif diff --git a/include/dt-bindings/gpio/gpio.h b/include/dt-bindings/gpio/gpio.h deleted file mode 100644 index c029467e828b..000000000000 --- a/include/dt-bindings/gpio/gpio.h +++ /dev/null @@ -1,42 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * This header provides constants for most GPIO bindings. - * - * Most GPIO bindings include a flags cell as part of the GPIO specifier. - * In most cases, the format of the flags cell uses the standard values - * defined in this header. - */ - -#ifndef _DT_BINDINGS_GPIO_GPIO_H -#define _DT_BINDINGS_GPIO_GPIO_H - -/* Bit 0 express polarity */ -#define GPIO_ACTIVE_HIGH 0 -#define GPIO_ACTIVE_LOW 1 - -/* Bit 1 express single-endedness */ -#define GPIO_PUSH_PULL 0 -#define GPIO_SINGLE_ENDED 2 - -/* Bit 2 express Open drain or open source */ -#define GPIO_LINE_OPEN_SOURCE 0 -#define GPIO_LINE_OPEN_DRAIN 4 - -/* - * Open Drain/Collector is the combination of single-ended open drain interface. - * Open Source/Emitter is the combination of single-ended open source interface. - */ -#define GPIO_OPEN_DRAIN (GPIO_SINGLE_ENDED | GPIO_LINE_OPEN_DRAIN) -#define GPIO_OPEN_SOURCE (GPIO_SINGLE_ENDED | GPIO_LINE_OPEN_SOURCE) - -/* Bit 3 express GPIO suspend/resume and reset persistence */ -#define GPIO_PERSISTENT 0 -#define GPIO_TRANSITORY 8 - -/* Bit 4 express pull up */ -#define GPIO_PULL_UP 16 - -/* Bit 5 express pull down */ -#define GPIO_PULL_DOWN 32 - -#endif diff --git a/include/dt-bindings/input/gpio-keys.h b/include/dt-bindings/input/gpio-keys.h deleted file mode 100644 index 8962df79e753..000000000000 --- a/include/dt-bindings/input/gpio-keys.h +++ /dev/null @@ -1,13 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * This header provides constants for gpio keys bindings. - */ - -#ifndef _DT_BINDINGS_GPIO_KEYS_H -#define _DT_BINDINGS_GPIO_KEYS_H - -#define EV_ACT_ANY 0x00 /* asserted or deasserted */ -#define EV_ACT_ASSERTED 0x01 /* asserted */ -#define EV_ACT_DEASSERTED 0x02 /* deasserted */ - -#endif /* _DT_BINDINGS_GPIO_KEYS_H */ diff --git a/include/dt-bindings/input/input.h b/include/dt-bindings/input/input.h deleted file mode 100644 index a21413324a3f..000000000000 --- a/include/dt-bindings/input/input.h +++ /dev/null @@ -1,17 +0,0 @@ -/* - * This header provides constants for most input bindings. - * - * Most input bindings include key code, matrix key code format. - * In most cases, key code and matrix key code format uses - * the standard values/macro defined in this header. - */ - -#ifndef _DT_BINDINGS_INPUT_INPUT_H -#define _DT_BINDINGS_INPUT_INPUT_H - -#include "linux-event-codes.h" - -#define MATRIX_KEY(row, col, code) \ - ((((row) & 0xFF) << 24) | (((col) & 0xFF) << 16) | ((code) & 0xFFFF)) - -#endif /* _DT_BINDINGS_INPUT_INPUT_H */ diff --git a/include/dt-bindings/input/linux-event-codes.h b/include/dt-bindings/input/linux-event-codes.h deleted file mode 100644 index 331458c0e710..000000000000 --- a/include/dt-bindings/input/linux-event-codes.h +++ /dev/null @@ -1,806 +0,0 @@ -/* - * Input event codes - * - * *** IMPORTANT *** - * This file is not only included from C-code but also from devicetree source - * files. As such this file MUST only contain comments and defines. - * - * Copyright (c) 1999-2002 Vojtech Pavlik - * Copyright (c) 2015 Hans de Goede hdegoede@redhat.com - * - * This program is free software; you can redistribute it and/or modify it - * under the terms of the GNU General Public License version 2 as published by - * the Free Software Foundation. - */ -#ifndef _UAPI_INPUT_EVENT_CODES_H -#define _UAPI_INPUT_EVENT_CODES_H - -/* - * Device properties and quirks - */ - -#define INPUT_PROP_POINTER 0x00 /* needs a pointer */ -#define INPUT_PROP_DIRECT 0x01 /* direct input devices */ -#define INPUT_PROP_BUTTONPAD 0x02 /* has button(s) under pad */ -#define INPUT_PROP_SEMI_MT 0x03 /* touch rectangle only */ -#define INPUT_PROP_TOPBUTTONPAD 0x04 /* softbuttons at top of pad */ -#define INPUT_PROP_POINTING_STICK 0x05 /* is a pointing stick */ -#define INPUT_PROP_ACCELEROMETER 0x06 /* has accelerometer */ - -#define INPUT_PROP_MAX 0x1f -#define INPUT_PROP_CNT (INPUT_PROP_MAX + 1) - -/* - * Event types - */ - -#define EV_SYN 0x00 -#define EV_KEY 0x01 -#define EV_REL 0x02 -#define EV_ABS 0x03 -#define EV_MSC 0x04 -#define EV_SW 0x05 -#define EV_LED 0x11 -#define EV_SND 0x12 -#define EV_REP 0x14 -#define EV_FF 0x15 -#define EV_PWR 0x16 -#define EV_FF_STATUS 0x17 -#define EV_MAX 0x1f -#define EV_CNT (EV_MAX+1) - -/* - * Synchronization events. - */ - -#define SYN_REPORT 0 -#define SYN_CONFIG 1 -#define SYN_MT_REPORT 2 -#define SYN_DROPPED 3 -#define SYN_MAX 0xf -#define SYN_CNT (SYN_MAX+1) - -/* - * Keys and buttons - * - * Most of the keys/buttons are modeled after USB HUT 1.12 - * (see http://www.usb.org/developers/hidpage). - * Abbreviations in the comments: - * AC - Application Control - * AL - Application Launch Button - * SC - System Control - */ - -#define KEY_RESERVED 0 -#define KEY_ESC 1 -#define KEY_1 2 -#define KEY_2 3 -#define KEY_3 4 -#define KEY_4 5 -#define KEY_5 6 -#define KEY_6 7 -#define KEY_7 8 -#define KEY_8 9 -#define KEY_9 10 -#define KEY_0 11 -#define KEY_MINUS 12 -#define KEY_EQUAL 13 -#define KEY_BACKSPACE 14 -#define KEY_TAB 15 -#define KEY_Q 16 -#define KEY_W 17 -#define KEY_E 18 -#define KEY_R 19 -#define KEY_T 20 -#define KEY_Y 21 -#define KEY_U 22 -#define KEY_I 23 -#define KEY_O 24 -#define KEY_P 25 -#define KEY_LEFTBRACE 26 -#define KEY_RIGHTBRACE 27 -#define KEY_ENTER 28 -#define KEY_LEFTCTRL 29 -#define KEY_A 30 -#define KEY_S 31 -#define KEY_D 32 -#define KEY_F 33 -#define KEY_G 34 -#define KEY_H 35 -#define KEY_J 36 -#define KEY_K 37 -#define KEY_L 38 -#define KEY_SEMICOLON 39 -#define KEY_APOSTROPHE 40 -#define KEY_GRAVE 41 -#define KEY_LEFTSHIFT 42 -#define KEY_BACKSLASH 43 -#define KEY_Z 44 -#define KEY_X 45 -#define KEY_C 46 -#define KEY_V 47 -#define KEY_B 48 -#define KEY_N 49 -#define KEY_M 50 -#define KEY_COMMA 51 -#define KEY_DOT 52 -#define KEY_SLASH 53 -#define KEY_RIGHTSHIFT 54 -#define KEY_KPASTERISK 55 -#define KEY_LEFTALT 56 -#define KEY_SPACE 57 -#define KEY_CAPSLOCK 58 -#define KEY_F1 59 -#define KEY_F2 60 -#define KEY_F3 61 -#define KEY_F4 62 -#define KEY_F5 63 -#define KEY_F6 64 -#define KEY_F7 65 -#define KEY_F8 66 -#define KEY_F9 67 -#define KEY_F10 68 -#define KEY_NUMLOCK 69 -#define KEY_SCROLLLOCK 70 -#define KEY_KP7 71 -#define KEY_KP8 72 -#define KEY_KP9 73 -#define KEY_KPMINUS 74 -#define KEY_KP4 75 -#define KEY_KP5 76 -#define KEY_KP6 77 -#define KEY_KPPLUS 78 -#define KEY_KP1 79 -#define KEY_KP2 80 -#define KEY_KP3 81 -#define KEY_KP0 82 -#define KEY_KPDOT 83 - -#define KEY_ZENKAKUHANKAKU 85 -#define KEY_102ND 86 -#define KEY_F11 87 -#define KEY_F12 88 -#define KEY_RO 89 -#define KEY_KATAKANA 90 -#define KEY_HIRAGANA 91 -#define KEY_HENKAN 92 -#define KEY_KATAKANAHIRAGANA 93 -#define KEY_MUHENKAN 94 -#define KEY_KPJPCOMMA 95 -#define KEY_KPENTER 96 -#define KEY_RIGHTCTRL 97 -#define KEY_KPSLASH 98 -#define KEY_SYSRQ 99 -#define KEY_RIGHTALT 100 -#define KEY_LINEFEED 101 -#define KEY_HOME 102 -#define KEY_UP 103 -#define KEY_PAGEUP 104 -#define KEY_LEFT 105 -#define KEY_RIGHT 106 -#define KEY_END 107 -#define KEY_DOWN 108 -#define KEY_PAGEDOWN 109 -#define KEY_INSERT 110 -#define KEY_DELETE 111 -#define KEY_MACRO 112 -#define KEY_MUTE 113 -#define KEY_VOLUMEDOWN 114 -#define KEY_VOLUMEUP 115 -#define KEY_POWER 116 /* SC System Power Down */ -#define KEY_KPEQUAL 117 -#define KEY_KPPLUSMINUS 118 -#define KEY_PAUSE 119 -#define KEY_SCALE 120 /* AL Compiz Scale (Expose) */ - -#define KEY_KPCOMMA 121 -#define KEY_HANGEUL 122 -#define KEY_HANGUEL KEY_HANGEUL -#define KEY_HANJA 123 -#define KEY_YEN 124 -#define KEY_LEFTMETA 125 -#define KEY_RIGHTMETA 126 -#define KEY_COMPOSE 127 - -#define KEY_STOP 128 /* AC Stop */ -#define KEY_AGAIN 129 -#define KEY_PROPS 130 /* AC Properties */ -#define KEY_UNDO 131 /* AC Undo */ -#define KEY_FRONT 132 -#define KEY_COPY 133 /* AC Copy */ -#define KEY_OPEN 134 /* AC Open */ -#define KEY_PASTE 135 /* AC Paste */ -#define KEY_FIND 136 /* AC Search */ -#define KEY_CUT 137 /* AC Cut */ -#define KEY_HELP 138 /* AL Integrated Help Center */ -#define KEY_MENU 139 /* Menu (show menu) */ -#define KEY_CALC 140 /* AL Calculator */ -#define KEY_SETUP 141 -#define KEY_SLEEP 142 /* SC System Sleep */ -#define KEY_WAKEUP 143 /* System Wake Up */ -#define KEY_FILE 144 /* AL Local Machine Browser */ -#define KEY_SENDFILE 145 -#define KEY_DELETEFILE 146 -#define KEY_XFER 147 -#define KEY_PROG1 148 -#define KEY_PROG2 149 -#define KEY_WWW 150 /* AL Internet Browser */ -#define KEY_MSDOS 151 -#define KEY_COFFEE 152 /* AL Terminal Lock/Screensaver */ -#define KEY_SCREENLOCK KEY_COFFEE -#define KEY_ROTATE_DISPLAY 153 /* Display orientation for e.g. tablets */ -#define KEY_DIRECTION KEY_ROTATE_DISPLAY -#define KEY_CYCLEWINDOWS 154 -#define KEY_MAIL 155 -#define KEY_BOOKMARKS 156 /* AC Bookmarks */ -#define KEY_COMPUTER 157 -#define KEY_BACK 158 /* AC Back */ -#define KEY_FORWARD 159 /* AC Forward */ -#define KEY_CLOSECD 160 -#define KEY_EJECTCD 161 -#define KEY_EJECTCLOSECD 162 -#define KEY_NEXTSONG 163 -#define KEY_PLAYPAUSE 164 -#define KEY_PREVIOUSSONG 165 -#define KEY_STOPCD 166 -#define KEY_RECORD 167 -#define KEY_REWIND 168 -#define KEY_PHONE 169 /* Media Select Telephone */ -#define KEY_ISO 170 -#define KEY_CONFIG 171 /* AL Consumer Control Configuration */ -#define KEY_HOMEPAGE 172 /* AC Home */ -#define KEY_REFRESH 173 /* AC Refresh */ -#define KEY_EXIT 174 /* AC Exit */ -#define KEY_MOVE 175 -#define KEY_EDIT 176 -#define KEY_SCROLLUP 177 -#define KEY_SCROLLDOWN 178 -#define KEY_KPLEFTPAREN 179 -#define KEY_KPRIGHTPAREN 180 -#define KEY_NEW 181 /* AC New */ -#define KEY_REDO 182 /* AC Redo/Repeat */ - -#define KEY_F13 183 -#define KEY_F14 184 -#define KEY_F15 185 -#define KEY_F16 186 -#define KEY_F17 187 -#define KEY_F18 188 -#define KEY_F19 189 -#define KEY_F20 190 -#define KEY_F21 191 -#define KEY_F22 192 -#define KEY_F23 193 -#define KEY_F24 194 - -#define KEY_PLAYCD 200 -#define KEY_PAUSECD 201 -#define KEY_PROG3 202 -#define KEY_PROG4 203 -#define KEY_DASHBOARD 204 /* AL Dashboard */ -#define KEY_SUSPEND 205 -#define KEY_CLOSE 206 /* AC Close */ -#define KEY_PLAY 207 -#define KEY_FASTFORWARD 208 -#define KEY_BASSBOOST 209 -#define KEY_PRINT 210 /* AC Print */ -#define KEY_HP 211 -#define KEY_CAMERA 212 -#define KEY_SOUND 213 -#define KEY_QUESTION 214 -#define KEY_EMAIL 215 -#define KEY_CHAT 216 -#define KEY_SEARCH 217 -#define KEY_CONNECT 218 -#define KEY_FINANCE 219 /* AL Checkbook/Finance */ -#define KEY_SPORT 220 -#define KEY_SHOP 221 -#define KEY_ALTERASE 222 -#define KEY_CANCEL 223 /* AC Cancel */ -#define KEY_BRIGHTNESSDOWN 224 -#define KEY_BRIGHTNESSUP 225 -#define KEY_MEDIA 226 - -#define KEY_SWITCHVIDEOMODE 227 /* Cycle between available video - outputs (Monitor/LCD/TV-out/etc) */ -#define KEY_KBDILLUMTOGGLE 228 -#define KEY_KBDILLUMDOWN 229 -#define KEY_KBDILLUMUP 230 - -#define KEY_SEND 231 /* AC Send */ -#define KEY_REPLY 232 /* AC Reply */ -#define KEY_FORWARDMAIL 233 /* AC Forward Msg */ -#define KEY_SAVE 234 /* AC Save */ -#define KEY_DOCUMENTS 235 - -#define KEY_BATTERY 236 - -#define KEY_BLUETOOTH 237 -#define KEY_WLAN 238 -#define KEY_UWB 239 - -#define KEY_UNKNOWN 240 - -#define KEY_VIDEO_NEXT 241 /* drive next video source */ -#define KEY_VIDEO_PREV 242 /* drive previous video source */ -#define KEY_BRIGHTNESS_CYCLE 243 /* brightness up, after max is min */ -#define KEY_BRIGHTNESS_AUTO 244 /* Set Auto Brightness: manual - brightness control is off, - rely on ambient */ -#define KEY_BRIGHTNESS_ZERO KEY_BRIGHTNESS_AUTO -#define KEY_DISPLAY_OFF 245 /* display device to off state */ - -#define KEY_WWAN 246 /* Wireless WAN (LTE, UMTS, GSM, etc.) */ -#define KEY_WIMAX KEY_WWAN -#define KEY_RFKILL 247 /* Key that controls all radios */ - -#define KEY_MICMUTE 248 /* Mute / unmute the microphone */ - -/* Code 255 is reserved for special needs of AT keyboard driver */ - -#define BTN_MISC 0x100 -#define BTN_0 0x100 -#define BTN_1 0x101 -#define BTN_2 0x102 -#define BTN_3 0x103 -#define BTN_4 0x104 -#define BTN_5 0x105 -#define BTN_6 0x106 -#define BTN_7 0x107 -#define BTN_8 0x108 -#define BTN_9 0x109 - -#define BTN_MOUSE 0x110 -#define BTN_LEFT 0x110 -#define BTN_RIGHT 0x111 -#define BTN_MIDDLE 0x112 -#define BTN_SIDE 0x113 -#define BTN_EXTRA 0x114 -#define BTN_FORWARD 0x115 -#define BTN_BACK 0x116 -#define BTN_TASK 0x117 - -#define BTN_JOYSTICK 0x120 -#define BTN_TRIGGER 0x120 -#define BTN_THUMB 0x121 -#define BTN_THUMB2 0x122 -#define BTN_TOP 0x123 -#define BTN_TOP2 0x124 -#define BTN_PINKIE 0x125 -#define BTN_BASE 0x126 -#define BTN_BASE2 0x127 -#define BTN_BASE3 0x128 -#define BTN_BASE4 0x129 -#define BTN_BASE5 0x12a -#define BTN_BASE6 0x12b -#define BTN_DEAD 0x12f - -#define BTN_GAMEPAD 0x130 -#define BTN_SOUTH 0x130 -#define BTN_A BTN_SOUTH -#define BTN_EAST 0x131 -#define BTN_B BTN_EAST -#define BTN_C 0x132 -#define BTN_NORTH 0x133 -#define BTN_X BTN_NORTH -#define BTN_WEST 0x134 -#define BTN_Y BTN_WEST -#define BTN_Z 0x135 -#define BTN_TL 0x136 -#define BTN_TR 0x137 -#define BTN_TL2 0x138 -#define BTN_TR2 0x139 -#define BTN_SELECT 0x13a -#define BTN_START 0x13b -#define BTN_MODE 0x13c -#define BTN_THUMBL 0x13d -#define BTN_THUMBR 0x13e - -#define BTN_DIGI 0x140 -#define BTN_TOOL_PEN 0x140 -#define BTN_TOOL_RUBBER 0x141 -#define BTN_TOOL_BRUSH 0x142 -#define BTN_TOOL_PENCIL 0x143 -#define BTN_TOOL_AIRBRUSH 0x144 -#define BTN_TOOL_FINGER 0x145 -#define BTN_TOOL_MOUSE 0x146 -#define BTN_TOOL_LENS 0x147 -#define BTN_TOOL_QUINTTAP 0x148 /* Five fingers on trackpad */ -#define BTN_TOUCH 0x14a -#define BTN_STYLUS 0x14b -#define BTN_STYLUS2 0x14c -#define BTN_TOOL_DOUBLETAP 0x14d -#define BTN_TOOL_TRIPLETAP 0x14e -#define BTN_TOOL_QUADTAP 0x14f /* Four fingers on trackpad */ - -#define BTN_WHEEL 0x150 -#define BTN_GEAR_DOWN 0x150 -#define BTN_GEAR_UP 0x151 - -#define KEY_OK 0x160 -#define KEY_SELECT 0x161 -#define KEY_GOTO 0x162 -#define KEY_CLEAR 0x163 -#define KEY_POWER2 0x164 -#define KEY_OPTION 0x165 -#define KEY_INFO 0x166 /* AL OEM Features/Tips/Tutorial */ -#define KEY_TIME 0x167 -#define KEY_VENDOR 0x168 -#define KEY_ARCHIVE 0x169 -#define KEY_PROGRAM 0x16a /* Media Select Program Guide */ -#define KEY_CHANNEL 0x16b -#define KEY_FAVORITES 0x16c -#define KEY_EPG 0x16d -#define KEY_PVR 0x16e /* Media Select Home */ -#define KEY_MHP 0x16f -#define KEY_LANGUAGE 0x170 -#define KEY_TITLE 0x171 -#define KEY_SUBTITLE 0x172 -#define KEY_ANGLE 0x173 -#define KEY_ZOOM 0x174 -#define KEY_MODE 0x175 -#define KEY_KEYBOARD 0x176 -#define KEY_SCREEN 0x177 -#define KEY_PC 0x178 /* Media Select Computer */ -#define KEY_TV 0x179 /* Media Select TV */ -#define KEY_TV2 0x17a /* Media Select Cable */ -#define KEY_VCR 0x17b /* Media Select VCR */ -#define KEY_VCR2 0x17c /* VCR Plus */ -#define KEY_SAT 0x17d /* Media Select Satellite */ -#define KEY_SAT2 0x17e -#define KEY_CD 0x17f /* Media Select CD */ -#define KEY_TAPE 0x180 /* Media Select Tape */ -#define KEY_RADIO 0x181 -#define KEY_TUNER 0x182 /* Media Select Tuner */ -#define KEY_PLAYER 0x183 -#define KEY_TEXT 0x184 -#define KEY_DVD 0x185 /* Media Select DVD */ -#define KEY_AUX 0x186 -#define KEY_MP3 0x187 -#define KEY_AUDIO 0x188 /* AL Audio Browser */ -#define KEY_VIDEO 0x189 /* AL Movie Browser */ -#define KEY_DIRECTORY 0x18a -#define KEY_LIST 0x18b -#define KEY_MEMO 0x18c /* Media Select Messages */ -#define KEY_CALENDAR 0x18d -#define KEY_RED 0x18e -#define KEY_GREEN 0x18f -#define KEY_YELLOW 0x190 -#define KEY_BLUE 0x191 -#define KEY_CHANNELUP 0x192 /* Channel Increment */ -#define KEY_CHANNELDOWN 0x193 /* Channel Decrement */ -#define KEY_FIRST 0x194 -#define KEY_LAST 0x195 /* Recall Last */ -#define KEY_AB 0x196 -#define KEY_NEXT 0x197 -#define KEY_RESTART 0x198 -#define KEY_SLOW 0x199 -#define KEY_SHUFFLE 0x19a -#define KEY_BREAK 0x19b -#define KEY_PREVIOUS 0x19c -#define KEY_DIGITS 0x19d -#define KEY_TEEN 0x19e -#define KEY_TWEN 0x19f -#define KEY_VIDEOPHONE 0x1a0 /* Media Select Video Phone */ -#define KEY_GAMES 0x1a1 /* Media Select Games */ -#define KEY_ZOOMIN 0x1a2 /* AC Zoom In */ -#define KEY_ZOOMOUT 0x1a3 /* AC Zoom Out */ -#define KEY_ZOOMRESET 0x1a4 /* AC Zoom */ -#define KEY_WORDPROCESSOR 0x1a5 /* AL Word Processor */ -#define KEY_EDITOR 0x1a6 /* AL Text Editor */ -#define KEY_SPREADSHEET 0x1a7 /* AL Spreadsheet */ -#define KEY_GRAPHICSEDITOR 0x1a8 /* AL Graphics Editor */ -#define KEY_PRESENTATION 0x1a9 /* AL Presentation App */ -#define KEY_DATABASE 0x1aa /* AL Database App */ -#define KEY_NEWS 0x1ab /* AL Newsreader */ -#define KEY_VOICEMAIL 0x1ac /* AL Voicemail */ -#define KEY_ADDRESSBOOK 0x1ad /* AL Contacts/Address Book */ -#define KEY_MESSENGER 0x1ae /* AL Instant Messaging */ -#define KEY_DISPLAYTOGGLE 0x1af /* Turn display (LCD) on and off */ -#define KEY_BRIGHTNESS_TOGGLE KEY_DISPLAYTOGGLE -#define KEY_SPELLCHECK 0x1b0 /* AL Spell Check */ -#define KEY_LOGOFF 0x1b1 /* AL Logoff */ - -#define KEY_DOLLAR 0x1b2 -#define KEY_EURO 0x1b3 - -#define KEY_FRAMEBACK 0x1b4 /* Consumer - transport controls */ -#define KEY_FRAMEFORWARD 0x1b5 -#define KEY_CONTEXT_MENU 0x1b6 /* GenDesc - system context menu */ -#define KEY_MEDIA_REPEAT 0x1b7 /* Consumer - transport control */ -#define KEY_10CHANNELSUP 0x1b8 /* 10 channels up (10+) */ -#define KEY_10CHANNELSDOWN 0x1b9 /* 10 channels down (10-) */ -#define KEY_IMAGES 0x1ba /* AL Image Browser */ - -#define KEY_DEL_EOL 0x1c0 -#define KEY_DEL_EOS 0x1c1 -#define KEY_INS_LINE 0x1c2 -#define KEY_DEL_LINE 0x1c3 - -#define KEY_FN 0x1d0 -#define KEY_FN_ESC 0x1d1 -#define KEY_FN_F1 0x1d2 -#define KEY_FN_F2 0x1d3 -#define KEY_FN_F3 0x1d4 -#define KEY_FN_F4 0x1d5 -#define KEY_FN_F5 0x1d6 -#define KEY_FN_F6 0x1d7 -#define KEY_FN_F7 0x1d8 -#define KEY_FN_F8 0x1d9 -#define KEY_FN_F9 0x1da -#define KEY_FN_F10 0x1db -#define KEY_FN_F11 0x1dc -#define KEY_FN_F12 0x1dd -#define KEY_FN_1 0x1de -#define KEY_FN_2 0x1df -#define KEY_FN_D 0x1e0 -#define KEY_FN_E 0x1e1 -#define KEY_FN_F 0x1e2 -#define KEY_FN_S 0x1e3 -#define KEY_FN_B 0x1e4 - -#define KEY_BRL_DOT1 0x1f1 -#define KEY_BRL_DOT2 0x1f2 -#define KEY_BRL_DOT3 0x1f3 -#define KEY_BRL_DOT4 0x1f4 -#define KEY_BRL_DOT5 0x1f5 -#define KEY_BRL_DOT6 0x1f6 -#define KEY_BRL_DOT7 0x1f7 -#define KEY_BRL_DOT8 0x1f8 -#define KEY_BRL_DOT9 0x1f9 -#define KEY_BRL_DOT10 0x1fa - -#define KEY_NUMERIC_0 0x200 /* used by phones, remote controls, */ -#define KEY_NUMERIC_1 0x201 /* and other keypads */ -#define KEY_NUMERIC_2 0x202 -#define KEY_NUMERIC_3 0x203 -#define KEY_NUMERIC_4 0x204 -#define KEY_NUMERIC_5 0x205 -#define KEY_NUMERIC_6 0x206 -#define KEY_NUMERIC_7 0x207 -#define KEY_NUMERIC_8 0x208 -#define KEY_NUMERIC_9 0x209 -#define KEY_NUMERIC_STAR 0x20a -#define KEY_NUMERIC_POUND 0x20b -#define KEY_NUMERIC_A 0x20c /* Phone key A - HUT Telephony 0xb9 */ -#define KEY_NUMERIC_B 0x20d -#define KEY_NUMERIC_C 0x20e -#define KEY_NUMERIC_D 0x20f - -#define KEY_CAMERA_FOCUS 0x210 -#define KEY_WPS_BUTTON 0x211 /* WiFi Protected Setup key */ - -#define KEY_TOUCHPAD_TOGGLE 0x212 /* Request switch touchpad on or off */ -#define KEY_TOUCHPAD_ON 0x213 -#define KEY_TOUCHPAD_OFF 0x214 - -#define KEY_CAMERA_ZOOMIN 0x215 -#define KEY_CAMERA_ZOOMOUT 0x216 -#define KEY_CAMERA_UP 0x217 -#define KEY_CAMERA_DOWN 0x218 -#define KEY_CAMERA_LEFT 0x219 -#define KEY_CAMERA_RIGHT 0x21a - -#define KEY_ATTENDANT_ON 0x21b -#define KEY_ATTENDANT_OFF 0x21c -#define KEY_ATTENDANT_TOGGLE 0x21d /* Attendant call on or off */ -#define KEY_LIGHTS_TOGGLE 0x21e /* Reading light on or off */ - -#define BTN_DPAD_UP 0x220 -#define BTN_DPAD_DOWN 0x221 -#define BTN_DPAD_LEFT 0x222 -#define BTN_DPAD_RIGHT 0x223 - -#define KEY_ALS_TOGGLE 0x230 /* Ambient light sensor */ - -#define KEY_BUTTONCONFIG 0x240 /* AL Button Configuration */ -#define KEY_TASKMANAGER 0x241 /* AL Task/Project Manager */ -#define KEY_JOURNAL 0x242 /* AL Log/Journal/Timecard */ -#define KEY_CONTROLPANEL 0x243 /* AL Control Panel */ -#define KEY_APPSELECT 0x244 /* AL Select Task/Application */ -#define KEY_SCREENSAVER 0x245 /* AL Screen Saver */ -#define KEY_VOICECOMMAND 0x246 /* Listening Voice Command */ - -#define KEY_BRIGHTNESS_MIN 0x250 /* Set Brightness to Minimum */ -#define KEY_BRIGHTNESS_MAX 0x251 /* Set Brightness to Maximum */ - -#define KEY_KBDINPUTASSIST_PREV 0x260 -#define KEY_KBDINPUTASSIST_NEXT 0x261 -#define KEY_KBDINPUTASSIST_PREVGROUP 0x262 -#define KEY_KBDINPUTASSIST_NEXTGROUP 0x263 -#define KEY_KBDINPUTASSIST_ACCEPT 0x264 -#define KEY_KBDINPUTASSIST_CANCEL 0x265 - -#define BTN_TRIGGER_HAPPY 0x2c0 -#define BTN_TRIGGER_HAPPY1 0x2c0 -#define BTN_TRIGGER_HAPPY2 0x2c1 -#define BTN_TRIGGER_HAPPY3 0x2c2 -#define BTN_TRIGGER_HAPPY4 0x2c3 -#define BTN_TRIGGER_HAPPY5 0x2c4 -#define BTN_TRIGGER_HAPPY6 0x2c5 -#define BTN_TRIGGER_HAPPY7 0x2c6 -#define BTN_TRIGGER_HAPPY8 0x2c7 -#define BTN_TRIGGER_HAPPY9 0x2c8 -#define BTN_TRIGGER_HAPPY10 0x2c9 -#define BTN_TRIGGER_HAPPY11 0x2ca -#define BTN_TRIGGER_HAPPY12 0x2cb -#define BTN_TRIGGER_HAPPY13 0x2cc -#define BTN_TRIGGER_HAPPY14 0x2cd -#define BTN_TRIGGER_HAPPY15 0x2ce -#define BTN_TRIGGER_HAPPY16 0x2cf -#define BTN_TRIGGER_HAPPY17 0x2d0 -#define BTN_TRIGGER_HAPPY18 0x2d1 -#define BTN_TRIGGER_HAPPY19 0x2d2 -#define BTN_TRIGGER_HAPPY20 0x2d3 -#define BTN_TRIGGER_HAPPY21 0x2d4 -#define BTN_TRIGGER_HAPPY22 0x2d5 -#define BTN_TRIGGER_HAPPY23 0x2d6 -#define BTN_TRIGGER_HAPPY24 0x2d7 -#define BTN_TRIGGER_HAPPY25 0x2d8 -#define BTN_TRIGGER_HAPPY26 0x2d9 -#define BTN_TRIGGER_HAPPY27 0x2da -#define BTN_TRIGGER_HAPPY28 0x2db -#define BTN_TRIGGER_HAPPY29 0x2dc -#define BTN_TRIGGER_HAPPY30 0x2dd -#define BTN_TRIGGER_HAPPY31 0x2de -#define BTN_TRIGGER_HAPPY32 0x2df -#define BTN_TRIGGER_HAPPY33 0x2e0 -#define BTN_TRIGGER_HAPPY34 0x2e1 -#define BTN_TRIGGER_HAPPY35 0x2e2 -#define BTN_TRIGGER_HAPPY36 0x2e3 -#define BTN_TRIGGER_HAPPY37 0x2e4 -#define BTN_TRIGGER_HAPPY38 0x2e5 -#define BTN_TRIGGER_HAPPY39 0x2e6 -#define BTN_TRIGGER_HAPPY40 0x2e7 - -/* We avoid low common keys in module aliases so they don't get huge. */ -#define KEY_MIN_INTERESTING KEY_MUTE -#define KEY_MAX 0x2ff -#define KEY_CNT (KEY_MAX+1) - -/* - * Relative axes - */ - -#define REL_X 0x00 -#define REL_Y 0x01 -#define REL_Z 0x02 -#define REL_RX 0x03 -#define REL_RY 0x04 -#define REL_RZ 0x05 -#define REL_HWHEEL 0x06 -#define REL_DIAL 0x07 -#define REL_WHEEL 0x08 -#define REL_MISC 0x09 -#define REL_MAX 0x0f -#define REL_CNT (REL_MAX+1) - -/* - * Absolute axes - */ - -#define ABS_X 0x00 -#define ABS_Y 0x01 -#define ABS_Z 0x02 -#define ABS_RX 0x03 -#define ABS_RY 0x04 -#define ABS_RZ 0x05 -#define ABS_THROTTLE 0x06 -#define ABS_RUDDER 0x07 -#define ABS_WHEEL 0x08 -#define ABS_GAS 0x09 -#define ABS_BRAKE 0x0a -#define ABS_HAT0X 0x10 -#define ABS_HAT0Y 0x11 -#define ABS_HAT1X 0x12 -#define ABS_HAT1Y 0x13 -#define ABS_HAT2X 0x14 -#define ABS_HAT2Y 0x15 -#define ABS_HAT3X 0x16 -#define ABS_HAT3Y 0x17 -#define ABS_PRESSURE 0x18 -#define ABS_DISTANCE 0x19 -#define ABS_TILT_X 0x1a -#define ABS_TILT_Y 0x1b -#define ABS_TOOL_WIDTH 0x1c - -#define ABS_VOLUME 0x20 - -#define ABS_MISC 0x28 - -#define ABS_MT_SLOT 0x2f /* MT slot being modified */ -#define ABS_MT_TOUCH_MAJOR 0x30 /* Major axis of touching ellipse */ -#define ABS_MT_TOUCH_MINOR 0x31 /* Minor axis (omit if circular) */ -#define ABS_MT_WIDTH_MAJOR 0x32 /* Major axis of approaching ellipse */ -#define ABS_MT_WIDTH_MINOR 0x33 /* Minor axis (omit if circular) */ -#define ABS_MT_ORIENTATION 0x34 /* Ellipse orientation */ -#define ABS_MT_POSITION_X 0x35 /* Center X touch position */ -#define ABS_MT_POSITION_Y 0x36 /* Center Y touch position */ -#define ABS_MT_TOOL_TYPE 0x37 /* Type of touching device */ -#define ABS_MT_BLOB_ID 0x38 /* Group a set of packets as a blob */ -#define ABS_MT_TRACKING_ID 0x39 /* Unique ID of initiated contact */ -#define ABS_MT_PRESSURE 0x3a /* Pressure on contact area */ -#define ABS_MT_DISTANCE 0x3b /* Contact hover distance */ -#define ABS_MT_TOOL_X 0x3c /* Center X tool position */ -#define ABS_MT_TOOL_Y 0x3d /* Center Y tool position */ - - -#define ABS_MAX 0x3f -#define ABS_CNT (ABS_MAX+1) - -/* - * Switch events - */ - -#define SW_LID 0x00 /* set = lid shut */ -#define SW_TABLET_MODE 0x01 /* set = tablet mode */ -#define SW_HEADPHONE_INSERT 0x02 /* set = inserted */ -#define SW_RFKILL_ALL 0x03 /* rfkill master switch, type "any" - set = radio enabled */ -#define SW_RADIO SW_RFKILL_ALL /* deprecated */ -#define SW_MICROPHONE_INSERT 0x04 /* set = inserted */ -#define SW_DOCK 0x05 /* set = plugged into dock */ -#define SW_LINEOUT_INSERT 0x06 /* set = inserted */ -#define SW_JACK_PHYSICAL_INSERT 0x07 /* set = mechanical switch set */ -#define SW_VIDEOOUT_INSERT 0x08 /* set = inserted */ -#define SW_CAMERA_LENS_COVER 0x09 /* set = lens covered */ -#define SW_KEYPAD_SLIDE 0x0a /* set = keypad slide out */ -#define SW_FRONT_PROXIMITY 0x0b /* set = front proximity sensor active */ -#define SW_ROTATE_LOCK 0x0c /* set = rotate locked/disabled */ -#define SW_LINEIN_INSERT 0x0d /* set = inserted */ -#define SW_MUTE_DEVICE 0x0e /* set = device disabled */ -#define SW_PEN_INSERTED 0x0f /* set = pen inserted */ -#define SW_MAX 0x10 -#define SW_CNT (SW_MAX+1) - -/* - * Misc events - */ - -#define MSC_SERIAL 0x00 -#define MSC_PULSELED 0x01 -#define MSC_GESTURE 0x02 -#define MSC_RAW 0x03 -#define MSC_SCAN 0x04 -#define MSC_TIMESTAMP 0x05 -#define MSC_MAX 0x07 -#define MSC_CNT (MSC_MAX+1) - -/* - * LEDs - */ - -#define LED_NUML 0x00 -#define LED_CAPSL 0x01 -#define LED_SCROLLL 0x02 -#define LED_COMPOSE 0x03 -#define LED_KANA 0x04 -#define LED_SLEEP 0x05 -#define LED_SUSPEND 0x06 -#define LED_MUTE 0x07 -#define LED_MISC 0x08 -#define LED_MAIL 0x09 -#define LED_CHARGING 0x0a -#define LED_MAX 0x0f -#define LED_CNT (LED_MAX+1) - -/* - * Autorepeat values - */ - -#define REP_DELAY 0x00 -#define REP_PERIOD 0x01 -#define REP_MAX 0x01 -#define REP_CNT (REP_MAX+1) - -/* - * Sounds - */ - -#define SND_CLICK 0x00 -#define SND_BELL 0x01 -#define SND_TONE 0x02 -#define SND_MAX 0x07 -#define SND_CNT (SND_MAX+1) - -#endif diff --git a/include/dt-bindings/interrupt-controller/irq.h b/include/dt-bindings/interrupt-controller/irq.h deleted file mode 100644 index 33a1003c55aa..000000000000 --- a/include/dt-bindings/interrupt-controller/irq.h +++ /dev/null @@ -1,19 +0,0 @@ -/* - * This header provides constants for most IRQ bindings. - * - * Most IRQ bindings include a flags cell as part of the IRQ specifier. - * In most cases, the format of the flags cell uses the standard values - * defined in this header. - */ - -#ifndef _DT_BINDINGS_INTERRUPT_CONTROLLER_IRQ_H -#define _DT_BINDINGS_INTERRUPT_CONTROLLER_IRQ_H - -#define IRQ_TYPE_NONE 0 -#define IRQ_TYPE_EDGE_RISING 1 -#define IRQ_TYPE_EDGE_FALLING 2 -#define IRQ_TYPE_EDGE_BOTH (IRQ_TYPE_EDGE_FALLING | IRQ_TYPE_EDGE_RISING) -#define IRQ_TYPE_LEVEL_HIGH 4 -#define IRQ_TYPE_LEVEL_LOW 8 - -#endif diff --git a/include/dt-bindings/leds/common.h b/include/dt-bindings/leds/common.h deleted file mode 100644 index 9a0d33d027ff..000000000000 --- a/include/dt-bindings/leds/common.h +++ /dev/null @@ -1,106 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * This header provides macros for the common LEDs device tree bindings. - * - * Copyright (C) 2015, Samsung Electronics Co., Ltd. - * Author: Jacek Anaszewski j.anaszewski@samsung.com - * - * Copyright (C) 2019 Jacek Anaszewski jacek.anaszewski@gmail.com - * Copyright (C) 2020 Pavel Machek pavel@ucw.cz - */ - -#ifndef __DT_BINDINGS_LEDS_H -#define __DT_BINDINGS_LEDS_H - -/* External trigger type */ -#define LEDS_TRIG_TYPE_EDGE 0 -#define LEDS_TRIG_TYPE_LEVEL 1 - -/* Boost modes */ -#define LEDS_BOOST_OFF 0 -#define LEDS_BOOST_ADAPTIVE 1 -#define LEDS_BOOST_FIXED 2 - -/* Standard LED colors */ -#define LED_COLOR_ID_WHITE 0 -#define LED_COLOR_ID_RED 1 -#define LED_COLOR_ID_GREEN 2 -#define LED_COLOR_ID_BLUE 3 -#define LED_COLOR_ID_AMBER 4 -#define LED_COLOR_ID_VIOLET 5 -#define LED_COLOR_ID_YELLOW 6 -#define LED_COLOR_ID_IR 7 -#define LED_COLOR_ID_MULTI 8 /* For multicolor LEDs */ -#define LED_COLOR_ID_RGB 9 /* For multicolor LEDs that can do arbitrary color, - so this would include RGBW and similar */ -#define LED_COLOR_ID_PURPLE 10 -#define LED_COLOR_ID_ORANGE 11 -#define LED_COLOR_ID_PINK 12 -#define LED_COLOR_ID_CYAN 13 -#define LED_COLOR_ID_LIME 14 -#define LED_COLOR_ID_MAX 15 - -/* Standard LED functions */ -/* Keyboard LEDs, usually it would be input4::capslock etc. */ -/* Obsolete equivalent: "shift-key-light" */ -#define LED_FUNCTION_CAPSLOCK "capslock" -#define LED_FUNCTION_SCROLLLOCK "scrolllock" -#define LED_FUNCTION_NUMLOCK "numlock" -/* Obsolete equivalents: "tpacpi::thinklight" (IBM/Lenovo Thinkpads), - "lp5523:kb{1,2,3,4,5,6}" (Nokia N900) */ -#define LED_FUNCTION_KBD_BACKLIGHT "kbd_backlight" - -/* System LEDs, usually found on system body. - platform::mute (etc) is sometimes seen, :mute would be better */ -#define LED_FUNCTION_POWER "power" -#define LED_FUNCTION_DISK "disk" - -/* Obsolete: "platform:*:charging" (allwinner sun50i) */ -#define LED_FUNCTION_CHARGING "charging" -/* Used RGB notification LEDs common on phones. - Obsolete equivalents: "status-led:{red,green,blue}" (Motorola Droid 4), - "lp5523:{r,g,b}" (Nokia N900) */ -#define LED_FUNCTION_STATUS "status" - -#define LED_FUNCTION_MICMUTE "micmute" -#define LED_FUNCTION_MUTE "mute" - -/* Used for player LEDs as found on game controllers from e.g. Nintendo, Sony. */ -#define LED_FUNCTION_PLAYER1 "player-1" -#define LED_FUNCTION_PLAYER2 "player-2" -#define LED_FUNCTION_PLAYER3 "player-3" -#define LED_FUNCTION_PLAYER4 "player-4" -#define LED_FUNCTION_PLAYER5 "player-5" - -/* Miscelleaus functions. Use functions above if you can. */ -#define LED_FUNCTION_ACTIVITY "activity" -#define LED_FUNCTION_ALARM "alarm" -#define LED_FUNCTION_BACKLIGHT "backlight" -#define LED_FUNCTION_BLUETOOTH "bluetooth" -#define LED_FUNCTION_BOOT "boot" -#define LED_FUNCTION_CPU "cpu" -#define LED_FUNCTION_DEBUG "debug" -#define LED_FUNCTION_DISK_ACTIVITY "disk-activity" -#define LED_FUNCTION_DISK_ERR "disk-err" -#define LED_FUNCTION_DISK_READ "disk-read" -#define LED_FUNCTION_DISK_WRITE "disk-write" -#define LED_FUNCTION_FAULT "fault" -#define LED_FUNCTION_FLASH "flash" -#define LED_FUNCTION_HEARTBEAT "heartbeat" -#define LED_FUNCTION_INDICATOR "indicator" -#define LED_FUNCTION_LAN "lan" -#define LED_FUNCTION_MAIL "mail" -#define LED_FUNCTION_MTD "mtd" -#define LED_FUNCTION_PANIC "panic" -#define LED_FUNCTION_PROGRAMMING "programming" -#define LED_FUNCTION_RX "rx" -#define LED_FUNCTION_SD "sd" -#define LED_FUNCTION_STANDBY "standby" -#define LED_FUNCTION_TORCH "torch" -#define LED_FUNCTION_TX "tx" -#define LED_FUNCTION_USB "usb" -#define LED_FUNCTION_WAN "wan" -#define LED_FUNCTION_WLAN "wlan" -#define LED_FUNCTION_WPS "wps" - -#endif /* __DT_BINDINGS_LEDS_H */ diff --git a/include/dt-bindings/mux/mux.h b/include/dt-bindings/mux/mux.h deleted file mode 100644 index 042719218dbf..000000000000 --- a/include/dt-bindings/mux/mux.h +++ /dev/null @@ -1,17 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * This header provides constants for most Multiplexer bindings. - * - * Most Multiplexer bindings specify an idle state. In most cases, the - * the multiplexer can be left as is when idle, and in some cases it can - * disconnect the input/output and leave the multiplexer in a high - * impedance state. - */ - -#ifndef _DT_BINDINGS_MUX_MUX_H -#define _DT_BINDINGS_MUX_MUX_H - -#define MUX_IDLE_AS_IS (-1) -#define MUX_IDLE_DISCONNECT (-2) - -#endif diff --git a/include/dt-bindings/phy/phy.h b/include/dt-bindings/phy/phy.h deleted file mode 100644 index f48c9acf251e..000000000000 --- a/include/dt-bindings/phy/phy.h +++ /dev/null @@ -1,26 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ -/* - * - * This header provides constants for the phy framework - * - * Copyright (C) 2014 STMicroelectronics - * Author: Gabriel Fernandez gabriel.fernandez@st.com - */ - -#ifndef _DT_BINDINGS_PHY -#define _DT_BINDINGS_PHY - -#define PHY_NONE 0 -#define PHY_TYPE_SATA 1 -#define PHY_TYPE_PCIE 2 -#define PHY_TYPE_USB2 3 -#define PHY_TYPE_USB3 4 -#define PHY_TYPE_UFS 5 -#define PHY_TYPE_DP 6 -#define PHY_TYPE_XPCS 7 -#define PHY_TYPE_SGMII 8 -#define PHY_TYPE_QSGMII 9 -#define PHY_TYPE_DPHY 10 -#define PHY_TYPE_CPHY 11 - -#endif /* _DT_BINDINGS_PHY */ diff --git a/include/dt-bindings/pwm/pwm.h b/include/dt-bindings/pwm/pwm.h deleted file mode 100644 index 96f49e82253e..000000000000 --- a/include/dt-bindings/pwm/pwm.h +++ /dev/null @@ -1,14 +0,0 @@ -/* - * This header provides constants for most PWM bindings. - * - * Most PWM bindings can include a flags cell as part of the PWM specifier. - * In most cases, the format of the flags cell uses the standard values - * defined in this header. - */ - -#ifndef _DT_BINDINGS_PWM_PWM_H -#define _DT_BINDINGS_PWM_PWM_H - -#define PWM_POLARITY_INVERTED (1 << 0) - -#endif diff --git a/include/dt-bindings/spmi/spmi.h b/include/dt-bindings/spmi/spmi.h deleted file mode 100644 index ad4a43481de4..000000000000 --- a/include/dt-bindings/spmi/spmi.h +++ /dev/null @@ -1,10 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ -/* Copyright (c) 2013, The Linux Foundation. All rights reserved. - */ -#ifndef __DT_BINDINGS_SPMI_H -#define __DT_BINDINGS_SPMI_H - -#define SPMI_USID 0 -#define SPMI_GSID 1 - -#endif diff --git a/include/dt-bindings/thermal/thermal.h b/include/dt-bindings/thermal/thermal.h deleted file mode 100644 index 7871e5f52b1c..000000000000 --- a/include/dt-bindings/thermal/thermal.h +++ /dev/null @@ -1,15 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ -/* - * This header provides constants for most thermal bindings. - * - * Copyright (C) 2013 Texas Instruments - * Eduardo Valentin eduardo.valentin@ti.com - */ - -#ifndef _DT_BINDINGS_THERMAL_THERMAL_H -#define _DT_BINDINGS_THERMAL_THERMAL_H - -/* On cooling devices upper and lower limits */ -#define THERMAL_NO_LIMIT (~0) - -#endif diff --git a/include/dt-bindings/usb/pd.h b/include/dt-bindings/usb/pd.h deleted file mode 100644 index 985f2bbd4d24..000000000000 --- a/include/dt-bindings/usb/pd.h +++ /dev/null @@ -1,88 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -#ifndef __DT_POWER_DELIVERY_H -#define __DT_POWER_DELIVERY_H - -/* Power delivery Power Data Object definitions */ -#define PDO_TYPE_FIXED 0 -#define PDO_TYPE_BATT 1 -#define PDO_TYPE_VAR 2 -#define PDO_TYPE_APDO 3 - -#define PDO_TYPE_SHIFT 30 -#define PDO_TYPE_MASK 0x3 - -#define PDO_TYPE(t) ((t) << PDO_TYPE_SHIFT) - -#define PDO_VOLT_MASK 0x3ff -#define PDO_CURR_MASK 0x3ff -#define PDO_PWR_MASK 0x3ff - -#define PDO_FIXED_DUAL_ROLE (1 << 29) /* Power role swap supported */ -#define PDO_FIXED_SUSPEND (1 << 28) /* USB Suspend supported (Source) */ -#define PDO_FIXED_HIGHER_CAP (1 << 28) /* Requires more than vSafe5V (Sink) */ -#define PDO_FIXED_EXTPOWER (1 << 27) /* Externally powered */ -#define PDO_FIXED_USB_COMM (1 << 26) /* USB communications capable */ -#define PDO_FIXED_DATA_SWAP (1 << 25) /* Data role swap supported */ -#define PDO_FIXED_VOLT_SHIFT 10 /* 50mV units */ -#define PDO_FIXED_CURR_SHIFT 0 /* 10mA units */ - -#define PDO_FIXED_VOLT(mv) ((((mv) / 50) & PDO_VOLT_MASK) << PDO_FIXED_VOLT_SHIFT) -#define PDO_FIXED_CURR(ma) ((((ma) / 10) & PDO_CURR_MASK) << PDO_FIXED_CURR_SHIFT) - -#define PDO_FIXED(mv, ma, flags) \ - (PDO_TYPE(PDO_TYPE_FIXED) | (flags) | \ - PDO_FIXED_VOLT(mv) | PDO_FIXED_CURR(ma)) - -#define VSAFE5V 5000 /* mv units */ - -#define PDO_BATT_MAX_VOLT_SHIFT 20 /* 50mV units */ -#define PDO_BATT_MIN_VOLT_SHIFT 10 /* 50mV units */ -#define PDO_BATT_MAX_PWR_SHIFT 0 /* 250mW units */ - -#define PDO_BATT_MIN_VOLT(mv) ((((mv) / 50) & PDO_VOLT_MASK) << PDO_BATT_MIN_VOLT_SHIFT) -#define PDO_BATT_MAX_VOLT(mv) ((((mv) / 50) & PDO_VOLT_MASK) << PDO_BATT_MAX_VOLT_SHIFT) -#define PDO_BATT_MAX_POWER(mw) ((((mw) / 250) & PDO_PWR_MASK) << PDO_BATT_MAX_PWR_SHIFT) - -#define PDO_BATT(min_mv, max_mv, max_mw) \ - (PDO_TYPE(PDO_TYPE_BATT) | PDO_BATT_MIN_VOLT(min_mv) | \ - PDO_BATT_MAX_VOLT(max_mv) | PDO_BATT_MAX_POWER(max_mw)) - -#define PDO_VAR_MAX_VOLT_SHIFT 20 /* 50mV units */ -#define PDO_VAR_MIN_VOLT_SHIFT 10 /* 50mV units */ -#define PDO_VAR_MAX_CURR_SHIFT 0 /* 10mA units */ - -#define PDO_VAR_MIN_VOLT(mv) ((((mv) / 50) & PDO_VOLT_MASK) << PDO_VAR_MIN_VOLT_SHIFT) -#define PDO_VAR_MAX_VOLT(mv) ((((mv) / 50) & PDO_VOLT_MASK) << PDO_VAR_MAX_VOLT_SHIFT) -#define PDO_VAR_MAX_CURR(ma) ((((ma) / 10) & PDO_CURR_MASK) << PDO_VAR_MAX_CURR_SHIFT) - -#define PDO_VAR(min_mv, max_mv, max_ma) \ - (PDO_TYPE(PDO_TYPE_VAR) | PDO_VAR_MIN_VOLT(min_mv) | \ - PDO_VAR_MAX_VOLT(max_mv) | PDO_VAR_MAX_CURR(max_ma)) - -#define APDO_TYPE_PPS 0 - -#define PDO_APDO_TYPE_SHIFT 28 /* Only valid value currently is 0x0 - PPS */ -#define PDO_APDO_TYPE_MASK 0x3 - -#define PDO_APDO_TYPE(t) ((t) << PDO_APDO_TYPE_SHIFT) - -#define PDO_PPS_APDO_MAX_VOLT_SHIFT 17 /* 100mV units */ -#define PDO_PPS_APDO_MIN_VOLT_SHIFT 8 /* 100mV units */ -#define PDO_PPS_APDO_MAX_CURR_SHIFT 0 /* 50mA units */ - -#define PDO_PPS_APDO_VOLT_MASK 0xff -#define PDO_PPS_APDO_CURR_MASK 0x7f - -#define PDO_PPS_APDO_MIN_VOLT(mv) \ - ((((mv) / 100) & PDO_PPS_APDO_VOLT_MASK) << PDO_PPS_APDO_MIN_VOLT_SHIFT) -#define PDO_PPS_APDO_MAX_VOLT(mv) \ - ((((mv) / 100) & PDO_PPS_APDO_VOLT_MASK) << PDO_PPS_APDO_MAX_VOLT_SHIFT) -#define PDO_PPS_APDO_MAX_CURR(ma) \ - ((((ma) / 50) & PDO_PPS_APDO_CURR_MASK) << PDO_PPS_APDO_MAX_CURR_SHIFT) - -#define PDO_PPS_APDO(min_mv, max_mv, max_ma) \ - (PDO_TYPE(PDO_TYPE_APDO) | PDO_APDO_TYPE(APDO_TYPE_PPS) | \ - PDO_PPS_APDO_MIN_VOLT(min_mv) | PDO_PPS_APDO_MAX_VOLT(max_mv) | \ - PDO_PPS_APDO_MAX_CURR(max_ma)) - - #endif /* __DT_POWER_DELIVERY_H */
This adjusts OF_UPSTREAM to behave more like the kernel by allowing for all the devicetree files for a given vendor to be compiled. This is useful for Qualcomm in particular as most boards are supported by a single U-Boot build just provided with a different DT.
Signed-off-by: Caleb Connolly caleb.connolly@linaro.org --- dts/Kconfig | 24 ++++++++++++++++++++++++ scripts/Makefile.dts | 13 +++++++++++++ 2 files changed, 37 insertions(+)
diff --git a/dts/Kconfig b/dts/Kconfig index b9b6367154ef..6883a000a052 100644 --- a/dts/Kconfig +++ b/dts/Kconfig @@ -100,8 +100,32 @@ config OF_UPSTREAM However, newer boards whose devicetree source files haven't landed in the dts/upstream subtree, they can override this option to have the DT build from existing U-Boot tree location instead.
+config OF_UPSTREAM_BUILD_VENDOR + bool "Build all devicetree files for a particular vendor" + depends on OF_UPSTREAM + help + Enable building all devicetree files for a particular vendor. This + is useful for generic U-Boot configurations where many boards can + be supported with a single binary. + + This is only available for platforms using upstream devicetree. + +config OF_UPSTREAM_VENDOR + string "Vendor to build all upstream devicetree files for" + depends on OF_UPSTREAM_BUILD_VENDOR + default "qcom" if ARCH_SNAPDRAGON + default "rockchip" if ARCH_ROCKCHIP + default "amlogic" if ARCH_MESON + default "allwinner" if ARCH_SUNXI + default "mediatek" if ARCH_MEDIATEK + default "marvell" if ARCH_MVEBU || ARCH_KIRKWOOD + default "xilinx" if ARCH_VERSAL || ARCH_ZYNQ + default "nvidia" if ARCH_TEGRA + help + Select the vendor to build all devicetree files for. + choice prompt "Provider of DTB for DT control" depends on OF_CONTROL
diff --git a/scripts/Makefile.dts b/scripts/Makefile.dts index 5e2429c6170c..790f3c508f19 100644 --- a/scripts/Makefile.dts +++ b/scripts/Makefile.dts @@ -1,3 +1,16 @@ # SPDX-License-Identifier: GPL-2.0+
dtb-y += $(patsubst %,%.dtb,$(subst ",,$(CONFIG_DEFAULT_DEVICE_TREE) $(CONFIG_OF_LIST) $(CONFIG_SPL_OF_LIST))) + +ifeq ($(CONFIG_OF_UPSTREAM_BUILD_VENDOR),y) +ifeq ($(CONFIG_ARM64),y) +dt_dir := $(srctree)/dts/upstream/src/arm64 +else +dt_dir := $(srctree)/dts/upstream/src/$(ARCH) +endif + +dtb-vendor_dts := $(patsubst %.dts,%.dtb,$(wildcard $(dt_dir)/$(subst ",,$(CONFIG_OF_UPSTREAM_VENDOR))/*.dts)) + +dtb-y += $(subst $(dt_dir)/,,$(dtb-vendor_dts)) + +endif
Currently this breaks a number of imx6 platforms starting with aristainetos2c.
Caleb Connolly
