[U-Boot] [PATCH] video: exynos_fb: Add the missing #else clause
This patch fixes a bug introduced while adding DT support to Exynos FIMD driver:
commit c23f3157d69bbb6c044256870f745f195b12431e Author: Ajay Kumar ajaykumar.rs@samsung.com Date: Thu Feb 21 23:53:01 2013 +0000
video: exynos_fb: add DT support for FIMD driver
Even though this part of code was missing, things were working fine on Exynos5250 because, samsung_get_base_fimd() used to give the correct base address for Exynos5250 FIMD.
Signed-off-by: Ajay Kumar ajaykumar.rs@samsung.com --- drivers/video/exynos_fimd.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/video/exynos_fimd.c b/drivers/video/exynos_fimd.c index 3359949..7243ea3 100644 --- a/drivers/video/exynos_fimd.c +++ b/drivers/video/exynos_fimd.c @@ -280,8 +280,9 @@ void exynos_fimd_lcd_init(vidinfo_t *vid) node, "reg"); if (fimd_ctrl == NULL) debug("Can't get the FIMD base address\n"); -#endif +#else fimd_ctrl = (struct exynos_fb *)samsung_get_base_fimd(); +#endif
offset = exynos_fimd_get_base_offset();
ping.
commit c23f3157d69bbb6c044256870f745f195b12431e Author: Ajay Kumar <ajaykumar.rs@samsung.com> Date: Thu Feb 21 23:53:01 2013 +0000 video: exynos_fb: add DT support for FIMD driver
-- 1.8.0
It looks good to me.
Acked-by: Donghwa Lee dh09.lee@samsung.com
Thank you, Donghwa Lee
On Mon, Apr 22, 2013 at 02:03, Ajay kumar wrote:
ping.
On Thu, Apr 4, 2013 at 7:55 PM, Ajay Kumar <ajaykumar.rs@samsung.com mailto:ajaykumar.rs@samsung.com> wrote:
This patch fixes a bug introduced while adding DT support to Exynos FIMD driver: commit c23f3157d69bbb6c044256870f745f195b12431e Author: Ajay Kumar <ajaykumar.rs@samsung.com <mailto:ajaykumar.rs@samsung.com>> Date: Thu Feb 21 23:53:01 2013 +0000 video: exynos_fb: add DT support for FIMD driver Even though this part of code was missing, things were working fine on Exynos5250 because, samsung_get_base_fimd() used to give the correct base address for Exynos5250 FIMD. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com <mailto:ajaykumar.rs@samsung.com>> --- drivers/video/exynos_fimd.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-) diff --git a/drivers/video/exynos_fimd.c b/drivers/video/exynos_fimd.c index 3359949..7243ea3 100644 --- a/drivers/video/exynos_fimd.c +++ b/drivers/video/exynos_fimd.c @@ -280,8 +280,9 @@ void exynos_fimd_lcd_init(vidinfo_t *vid) node, "reg"); if (fimd_ctrl == NULL) debug("Can't get the FIMD base address\n"); -#endif +#else fimd_ctrl = (struct exynos_fb *)samsung_get_base_fimd(); +#endif offset = exynos_fimd_get_base_offset(); -- 1.8.0 _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de <mailto:U-Boot@lists.denx.de> http://lists.denx.de/mailman/listinfo/u-boot
ping.
applied to u-boot-samsung.
thanks, Minkyu Kang.
Ajay Kumar
Ajay kumar
Donghwa Lee
Minkyu Kang
