[U-Boot] [PATCH 3/3 V2] Add support for hawkboard
The patch adds basic board support for TI's OMAP-L138 based Hawkboard. This board is pretty similar to the da850 EVM. Support for nand and network access is added in this version.
The following bootup procedure is used.
At reset, the Rom Boot Loader(RBL), initialises the ddr and the nand controllers and copies the second stage bootloader(nand_spl) to RAM. The secondary bootloader then copies u-boot from a predefined location in the nand flash to the RAM, and passes control to the u-boot image.
Three config options are supported * hawkboard_config - Used to create the u-boot.bin. Tftp the u-boot.bin image to the RAM from u-boot, and flash to the nand flash at address 0xe0000.
* hawkboard_nand_config - Used to generate the secondary bootloader(nand_spl) image. This creates an elf file u-boot-spl under nand_spl/. Create an AIS signed image using this file, and flash it to the nand flash at address 0x20000. The ais file should fit in one block.
* hawkboard_uart_config - This is same as the first image, but with the TEXT_BASE as expected by the RBL(0xc1080000). Create the AIS Signed bin, as use the normal UART boot procedure to boot the image.
Signed-off-by: Sughosh Ganu urwithsughosh@gmail.com --- V2: Taken care of comments from Wolfgang.
MAINTAINERS | 5 + arch/arm/include/asm/arch-davinci/da8xx_common.h | 3 + arch/arm/include/asm/arch-davinci/hardware.h | 5 +- board/davinci/common/Makefile | 2 +- board/davinci/common/davinci_pinmux.c | 105 +++++++++++ board/davinci/common/misc.c | 75 -------- board/davinci/da8xxevm/Makefile | 2 + board/davinci/da8xxevm/hawkboard.c | 68 +++++++ board/davinci/da8xxevm/hawkboard_nand_spl.c | 163 +++++++++++++++++ boards.cfg | 3 + drivers/mtd/nand/davinci_nand.c | 1 + include/configs/hawkboard.h | 205 ++++++++++++++++++++++ nand_spl/board/davinci/da8xxevm/Makefile | 141 +++++++++++++++ nand_spl/board/davinci/da8xxevm/u-boot.lds | 75 ++++++++ 14 files changed, 776 insertions(+), 77 deletions(-) create mode 100644 board/davinci/common/davinci_pinmux.c create mode 100644 board/davinci/da8xxevm/hawkboard.c create mode 100644 board/davinci/da8xxevm/hawkboard_nand_spl.c create mode 100644 include/configs/hawkboard.h create mode 100644 nand_spl/board/davinci/da8xxevm/Makefile create mode 100644 nand_spl/board/davinci/da8xxevm/u-boot.lds
diff --git a/MAINTAINERS b/MAINTAINERS index b0da631..d7efc71 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -849,6 +849,11 @@ Alex Z lart SA1100 dnp1110 SA1110
+Syed Mohammed Khasim sm.khasim@gmail.com +Sughosh Ganu urwithsughosh@gmail.com + + hawkboard ARM926EJS (OMAP-L138) + -------------------------------------------------------------------------
Unknown / orphaned boards: diff --git a/arch/arm/include/asm/arch-davinci/da8xx_common.h b/arch/arm/include/asm/arch-davinci/da8xx_common.h index 7ae63a6..bc3092d 100644 --- a/arch/arm/include/asm/arch-davinci/da8xx_common.h +++ b/arch/arm/include/asm/arch-davinci/da8xx_common.h @@ -19,6 +19,9 @@ #ifndef __COMMON_H #define __COMMON_H
+#define HAWKBOARD_KICK0_UNLOCK 0x83e70b13 +#define HAWKBOARD_KICK1_UNLOCK 0x95a4f1e0 + struct lpsc_resource { const int lpsc_no; }; diff --git a/arch/arm/include/asm/arch-davinci/hardware.h b/arch/arm/include/asm/arch-davinci/hardware.h index 3520cf8..d006ac1 100644 --- a/arch/arm/include/asm/arch-davinci/hardware.h +++ b/arch/arm/include/asm/arch-davinci/hardware.h @@ -379,7 +379,10 @@ int clk_get(enum davinci_clk_ids id); /* Boot config */ struct davinci_syscfg_regs { dv_reg revid; - dv_reg rsvd[71]; + dv_reg rsvd[13]; + dv_reg kick0; + dv_reg kick1; + dv_reg rsvd1[56]; dv_reg pinmux[20]; dv_reg suspsrc; dv_reg chipsig; diff --git a/board/davinci/common/Makefile b/board/davinci/common/Makefile index 8d9ea00..dd022f6 100644 --- a/board/davinci/common/Makefile +++ b/board/davinci/common/Makefile @@ -29,7 +29,7 @@ endif
LIB = $(obj)lib$(VENDOR).a
-COBJS := misc.o +COBJS := misc.o davinci_pinmux.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/davinci/common/davinci_pinmux.c b/board/davinci/common/davinci_pinmux.c new file mode 100644 index 0000000..53a038e --- /dev/null +++ b/board/davinci/common/davinci_pinmux.c @@ -0,0 +1,105 @@ +/* + * DaVinci pinmux functions. + * + * Copyright (C) 2009 Nick Thompson, GE Fanuc Ltd, nick.thompson@gefanuc.com + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * Copyright (C) 2008 Lyrtech <www.lyrtech.com> + * Copyright (C) 2004 Texas Instruments. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#include <common.h> +#include <asm/arch/hardware.h> +#include <asm/io.h> +#include <davinci_misc.h> + +/* + * Change the setting of a pin multiplexer field. + * + * Takes an array of pinmux settings similar to: + * + * struct pinmux_config uart_pins[] = { + * { &davinci_syscfg_regs->pinmux[8], 2, 7 }, + * { &davinci_syscfg_regs->pinmux[9], 2, 0 } + * }; + * + * Stepping through the array, each pinmux[n] register has the given value + * set in the pin mux field specified. + * + * The number of pins in the array must be passed (ARRAY_SIZE can provide + * this value conveniently). + * + * Returns 0 if all field numbers and values are in the correct range, + * else returns -1. + */ +int davinci_configure_pin_mux(const struct pinmux_config *pins, + const int n_pins) +{ + int i; + + /* check for invalid pinmux values */ + for (i = 0; i < n_pins; i++) { + if (pins[i].field >= PIN_MUX_NUM_FIELDS || + (pins[i].value & ~PIN_MUX_FIELD_MASK) != 0) + return -1; + } + + /* configure the pinmuxes */ + for (i = 0; i < n_pins; i++) { + const int offset = pins[i].field * PIN_MUX_FIELD_SIZE; + const unsigned int value = pins[i].value << offset; + const unsigned int mask = PIN_MUX_FIELD_MASK << offset; + const dv_reg *mux = pins[i].mux; + + writel(value | (readl(mux) & (~mask)), mux); + } + + return 0; +} + +/* + * Configure multiple pinmux resources. + * + * Takes an pinmux_resource array of pinmux_config and pin counts: + * + * const struct pinmux_resource pinmuxes[] = { + * PINMUX_ITEM(uart_pins), + * PINMUX_ITEM(i2c_pins), + * }; + * + * The number of items in the array must be passed (ARRAY_SIZE can provide + * this value conveniently). + * + * Each item entry is configured in the defined order. If configuration + * of any item fails, -1 is returned and none of the following items are + * configured. On success, 0 is returned. + */ +int davinci_configure_pin_mux_items(const struct pinmux_resource *item, + const int n_items) +{ + int i; + + for (i = 0; i < n_items; i++) { + if (davinci_configure_pin_mux(item[i].pins, + item[i].n_pins) != 0) + return -1; + } + + return 0; +} diff --git a/board/davinci/common/misc.c b/board/davinci/common/misc.c index 71e7822..e97e61c 100644 --- a/board/davinci/common/misc.c +++ b/board/davinci/common/misc.c @@ -105,78 +105,3 @@ void davinci_sync_env_enetaddr(uint8_t *rom_enetaddr) }
#endif /* DAVINCI_EMAC */ - -/* - * Change the setting of a pin multiplexer field. - * - * Takes an array of pinmux settings similar to: - * - * struct pinmux_config uart_pins[] = { - * { &davinci_syscfg_regs->pinmux[8], 2, 7 }, - * { &davinci_syscfg_regs->pinmux[9], 2, 0 } - * }; - * - * Stepping through the array, each pinmux[n] register has the given value - * set in the pin mux field specified. - * - * The number of pins in the array must be passed (ARRAY_SIZE can provide - * this value conveniently). - * - * Returns 0 if all field numbers and values are in the correct range, - * else returns -1. - */ -int davinci_configure_pin_mux(const struct pinmux_config *pins, - const int n_pins) -{ - int i; - - /* check for invalid pinmux values */ - for (i = 0; i < n_pins; i++) { - if (pins[i].field >= PIN_MUX_NUM_FIELDS || - (pins[i].value & ~PIN_MUX_FIELD_MASK) != 0) - return -1; - } - - /* configure the pinmuxes */ - for (i = 0; i < n_pins; i++) { - const int offset = pins[i].field * PIN_MUX_FIELD_SIZE; - const unsigned int value = pins[i].value << offset; - const unsigned int mask = PIN_MUX_FIELD_MASK << offset; - const dv_reg *mux = pins[i].mux; - - writel(value | (readl(mux) & (~mask)), mux); - } - - return 0; -} - -/* - * Configure multiple pinmux resources. - * - * Takes an pinmux_resource array of pinmux_config and pin counts: - * - * const struct pinmux_resource pinmuxes[] = { - * PINMUX_ITEM(uart_pins), - * PINMUX_ITEM(i2c_pins), - * }; - * - * The number of items in the array must be passed (ARRAY_SIZE can provide - * this value conveniently). - * - * Each item entry is configured in the defined order. If configuration - * of any item fails, -1 is returned and none of the following items are - * configured. On success, 0 is returned. - */ -int davinci_configure_pin_mux_items(const struct pinmux_resource *item, - const int n_items) -{ - int i; - - for (i = 0; i < n_items; i++) { - if (davinci_configure_pin_mux(item[i].pins, - item[i].n_pins) != 0) - return -1; - } - - return 0; -} diff --git a/board/davinci/da8xxevm/Makefile b/board/davinci/da8xxevm/Makefile index 17cbe86..cbdb6cb 100644 --- a/board/davinci/da8xxevm/Makefile +++ b/board/davinci/da8xxevm/Makefile @@ -30,6 +30,8 @@ LIB = $(obj)lib$(BOARD).a COBJS-y += common.o COBJS-$(CONFIG_MACH_DAVINCI_DA830_EVM) += da830evm.o COBJS-$(CONFIG_MACH_DAVINCI_DA850_EVM) += da850evm.o +COBJS-$(CONFIG_MACH_DAVINCI_HAWK) += hawkboard.o +COBJS-$(CONFIG_NAND_SPL_HAWK) += hawkboard_nand_spl.o
COBJS := $(COBJS-y)
diff --git a/board/davinci/da8xxevm/hawkboard.c b/board/davinci/da8xxevm/hawkboard.c new file mode 100644 index 0000000..fdc4ffd --- /dev/null +++ b/board/davinci/da8xxevm/hawkboard.c @@ -0,0 +1,68 @@ +/* + * Modified for Hawkboard - Syed Mohammed Khasim khasim@beagleboard.org + * + * Copyright (C) 2008 Sekhar Nori, Texas Instruments, Inc. nsekhar@ti.com + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * Copyright (C) 2004 Texas Instruments. + * + * ---------------------------------------------------------------------------- + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + * ---------------------------------------------------------------------------- + */ + +#include <common.h> +#include <asm/errno.h> +#include <asm/arch/hardware.h> +#include <asm/io.h> +#include <asm/arch/davinci_misc.h> +#include <ns16550.h> +#include <asm/arch/da8xx_common.h> + +DECLARE_GLOBAL_DATA_PTR; + +int board_init(void) +{ + /* arch number of the board */ + gd->bd->bi_arch_number = MACH_TYPE_OMAPL138_HAWKBOARD; + + /* address of boot parameters */ + gd->bd->bi_boot_params = LINUX_BOOT_PARAM_ADDR; + + return 0; +} + +int board_early_init_f(void) +{ + /* + * Kick Registers need to be set to allow access to Pin Mux registers + */ + writel(HAWKBOARD_KICK0_UNLOCK, &davinci_syscfg_regs->kick0); + writel(HAWKBOARD_KICK1_UNLOCK, &davinci_syscfg_regs->kick1); + + /* set cfgchip3 to select mii */ + writel(readl(&davinci_syscfg_regs->cfgchip3) & + ~(1 << 8), &davinci_syscfg_regs->cfgchip3); + + return(0); +} + +int misc_init_r (void) +{ + char buf[32]; + + printf ("ARM Clock : %s MHz\n", strmhz(buf, clk_get(DAVINCI_ARM_CLKID))); + + return(0); +} diff --git a/board/davinci/da8xxevm/hawkboard_nand_spl.c b/board/davinci/da8xxevm/hawkboard_nand_spl.c new file mode 100644 index 0000000..21e6c91 --- /dev/null +++ b/board/davinci/da8xxevm/hawkboard_nand_spl.c @@ -0,0 +1,163 @@ +/* + * Modified for Hawkboard - Syed Mohammed Khasim khasim@beagleboard.org + * + * Copyright (C) 2008 Sekhar Nori, Texas Instruments, Inc. nsekhar@ti.com + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * Copyright (C) 2004 Texas Instruments. + * + * ---------------------------------------------------------------------------- + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + * ---------------------------------------------------------------------------- + */ + +#include <common.h> +#include <asm/errno.h> +#include <asm/arch/hardware.h> +#include <asm/io.h> +#include <davinci_misc.h> +#include <ns16550.h> +#include <da8xx_common.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define pinmux(x) (&davinci_syscfg_regs->pinmux[x]) + +static const struct pinmux_config mii_pins[] = { + { pinmux(2), 8, 1 }, + { pinmux(2), 8, 2 }, + { pinmux(2), 8, 3 }, + { pinmux(2), 8, 4 }, + { pinmux(2), 8, 5 }, + { pinmux(2), 8, 6 }, + { pinmux(2), 8, 7 } +}; + +static const struct pinmux_config mdio_pins[] = { + { pinmux(4), 8, 0 }, + { pinmux(4), 8, 1 } +}; + +static const struct pinmux_config nand_pins[] = { + { pinmux(7), 1, 1 }, + { pinmux(7), 1, 2 }, + { pinmux(7), 1, 4 }, + { pinmux(7), 1, 5 }, + { pinmux(9), 1, 0 }, + { pinmux(9), 1, 1 }, + { pinmux(9), 1, 2 }, + { pinmux(9), 1, 3 }, + { pinmux(9), 1, 4 }, + { pinmux(9), 1, 5 }, + { pinmux(9), 1, 6 }, + { pinmux(9), 1, 7 }, + { pinmux(12),1, 5 }, + { pinmux(12),1, 6 } +}; + +static const struct pinmux_config uart2_pins[] = { + { pinmux(0), 4, 6 }, + { pinmux(0), 4, 7 }, + { pinmux(4), 2, 4 }, + { pinmux(4), 2, 5 } +}; + +static const struct pinmux_config i2c_pins[] = { + { pinmux(4), 2, 4 }, + { pinmux(4), 2, 5 } +}; + +static const struct pinmux_resource pinmuxes[] = { + PINMUX_ITEM(mii_pins), + PINMUX_ITEM(mdio_pins), + PINMUX_ITEM(i2c_pins), + PINMUX_ITEM(nand_pins), + PINMUX_ITEM(uart2_pins), +}; + +static const struct lpsc_resource lpsc[] = { + { DAVINCI_LPSC_AEMIF }, /* NAND, NOR */ + { DAVINCI_LPSC_SPI1 }, /* Serial Flash */ + { DAVINCI_LPSC_EMAC }, /* image download */ + { DAVINCI_LPSC_UART2 }, /* console */ + { DAVINCI_LPSC_GPIO }, +}; + +void board_init_f (ulong bootflag) +{ + /* + * Kick Registers need to be set to allow access to Pin Mux registers + */ + writel(HAWKBOARD_KICK0_UNLOCK, &davinci_syscfg_regs->kick0); + writel(HAWKBOARD_KICK1_UNLOCK, &davinci_syscfg_regs->kick1); + + /* setup the SUSPSRC for ARM to control emulation suspend */ + writel(readl(&davinci_syscfg_regs->suspsrc) & + ~(DAVINCI_SYSCFG_SUSPSRC_EMAC | DAVINCI_SYSCFG_SUSPSRC_I2C | + DAVINCI_SYSCFG_SUSPSRC_SPI1 | DAVINCI_SYSCFG_SUSPSRC_TIMER0 | + DAVINCI_SYSCFG_SUSPSRC_UART2), &davinci_syscfg_regs->suspsrc); + + /* Power on required peripherals + * ARM does not have acess by default to PSC0 and PSC1 + * assuming here that the DSP bootloader has set the IOPU + * such that PSC access is available to ARM + */ + da8xx_configure_lpsc_items(lpsc, ARRAY_SIZE(lpsc)); + + /* configure pinmux settings */ + davinci_configure_pin_mux_items(pinmuxes, + ARRAY_SIZE(pinmuxes)); + + writel(readl(&davinci_uart2_ctrl_regs->pwremu_mgmt) | + (DAVINCI_UART_PWREMU_MGMT_FREE) | + (DAVINCI_UART_PWREMU_MGMT_URRST) | + (DAVINCI_UART_PWREMU_MGMT_UTRST), + &davinci_uart2_ctrl_regs->pwremu_mgmt); + + NS16550_init((NS16550_t)(DAVINCI_UART2_BASE), + CONFIG_SYS_NS16550_CLK / 16 / CONFIG_BAUDRATE); + + puts("Nand boot...\n"); + + relocate_code (CONFIG_SYS_NAND_U_BOOT_RELOC_SP, (gd_t *)gd, + CONFIG_SYS_NAND_U_BOOT_DST); +} + +void board_init_r(gd_t *gd, ulong dest_addr) +{ + nand_boot(); +} + +void puts(const char *str) +{ + while (*str) + putc(*str++); +} + +void putc(char c) +{ + if (gd->flags & GD_FLG_SILENT) + return; + + if (c == '\n') + NS16550_putc((NS16550_t)(DAVINCI_UART2_BASE), '\r'); + + NS16550_putc((NS16550_t)(DAVINCI_UART2_BASE), c); +} + +void hang (void) +{ + puts ("### ERROR ### Please RESET the board ###\n"); + for (;;); +} diff --git a/boards.cfg b/boards.cfg index 4efbff8..6d4a2b1 100644 --- a/boards.cfg +++ b/boards.cfg @@ -372,6 +372,9 @@ davinci_sffsdr arm arm926ejs sffsdr davinci davinci davinci_sonata arm arm926ejs sonata davinci davinci da830evm arm arm926ejs da8xxevm davinci davinci da850evm arm arm926ejs da8xxevm davinci davinci +hawkboard arm arm926ejs da8xxevm davinci davinci hawkboard:SYS_TEXT_BASE=0xc1180000 +hawkboard_nand arm arm926ejs da8xxevm davinci davinci hawkboard:SYS_TEXT_BASE=0xc1080000,NAND_U_BOOT +hawkboard_uart arm arm926ejs da8xxevm davinci davinci hawkboard:SYS_TEXT_BASE=0xc1080000 guruplug arm arm926ejs - Marvell kirkwood mv88f6281gtw_ge arm arm926ejs - Marvell kirkwood openrd_base arm arm926ejs - Marvell kirkwood diff --git a/drivers/mtd/nand/davinci_nand.c b/drivers/mtd/nand/davinci_nand.c index d41579c..ad70dd9 100644 --- a/drivers/mtd/nand/davinci_nand.c +++ b/drivers/mtd/nand/davinci_nand.c @@ -635,6 +635,7 @@ void davinci_nand_init(struct nand_chip *nand) nand->write_buf = nand_davinci_write_buf;
nand->dev_ready = nand_davinci_dev_ready; + nand->select_chip = NULL;
nand_flash_init(); } diff --git a/include/configs/hawkboard.h b/include/configs/hawkboard.h new file mode 100644 index 0000000..86fd9a5 --- /dev/null +++ b/include/configs/hawkboard.h @@ -0,0 +1,205 @@ +/* + * Copyright (C) 2010 Texas Instruments Incorporated - http://www.ti.com/ + * + * Based on davinci_dvevm.h. Original Copyrights follow: + * + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * Board + */ +#define CONFIG_SYS_USE_NAND 1 + +/* + * SoC Configuration + */ +#define CONFIG_MACH_DAVINCI_HAWK +#define CONFIG_ARM926EJS /* arm926ejs CPU core */ +#define CONFIG_SOC_DA8XX /* TI DA8xx SoC */ +#define CONFIG_SYS_CLK_FREQ clk_get(DAVINCI_ARM_CLKID) +#define CONFIG_SYS_OSCIN_FREQ 24000000 +#define CONFIG_SYS_TIMERBASE DAVINCI_TIMER0_BASE +#define CONFIG_SYS_HZ_CLOCK clk_get(DAVINCI_AUXCLK_CLKID) +#define CONFIG_SYS_HZ 1000 +#define CONFIG_SKIP_LOWLEVEL_INIT +#if defined CONFIG_NAND_SPL +#define CONFIG_SKIP_RELOCATE_UBOOT +#define CONFIG_NAND_SPL_HAWK +#endif +#define CONFIG_BOARD_EARLY_INIT_F + +/* + * Memory Info + */ +#define CONFIG_SYS_MALLOC_LEN (1*1024*1024) /* malloc() len */ +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* reserved for initial data */ +#define PHYS_SDRAM_1 DAVINCI_DDR_EMIF_DATA_BASE /* DDR Start */ +#define PHYS_SDRAM_1_SIZE (128 << 20) /* SDRAM size 128MB */ +#define CONFIG_SYS_SDRAM_BASE 0xc0000000 +#define CONFIG_MAX_RAM_BANK_SIZE (512 << 20) +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x1000 - \ + CONFIG_SYS_GBL_DATA_SIZE) + +/* memtest start addr */ +#define CONFIG_SYS_MEMTEST_START (PHYS_SDRAM_1) + +/* memtest will be run on 16MB */ +#define CONFIG_SYS_MEMTEST_END (PHYS_SDRAM_1 + 16*1024*1024) + +#define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of DRAM */ +#define CONFIG_STACKSIZE (256*1024) /* regular stack */ + +/* + * Serial Driver info + */ +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE -4 +#define CONFIG_SYS_NS16550_COM1 DAVINCI_UART2_BASE +#define CONFIG_SYS_NS16550_CLK clk_get(DAVINCI_UART2_CLKID) +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* + * Network & Ethernet Configuration + */ +#define CONFIG_EMAC_MDIO_PHY_NUM 0x7 +#if !defined(CONFIG_NAND_SPL) +#define CONFIG_DRIVER_TI_EMAC +#endif +#define CONFIG_MII +#define CONFIG_BOOTP_DEFAULT +#define CONFIG_BOOTP_DNS +#define CONFIG_BOOTP_DNS2 +#define CONFIG_BOOTP_SEND_HOSTNAME +#define CONFIG_NET_RETRY_COUNT 10 +#define CONFIG_NET_MULTI + +/* + * Nand Flash + */ +#ifdef CONFIG_SYS_USE_NAND +#define CONFIG_SYS_NO_FLASH +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_SIZE (128 << 10) +#define CONFIG_SYS_NAND_BASE DAVINCI_ASYNC_EMIF_DATA_CE3_BASE +#define CONFIG_CLE_MASK 0x10 +#define CONFIG_ALE_MASK 0x8 +#define CONFIG_SYS_NAND_USE_FLASH_BBT +#define CONFIG_NAND_DAVINCI +#define CONFIG_SYS_NAND_4BIT_HW_ECC_OOBFIRST +#define CFG_DAVINCI_STD_NAND_LAYOUT +#define CONFIG_SYS_NAND_CS 3 +#define CONFIG_SYS_NAND_PAGE_2K +#define CONFIG_SYS_64BIT_VSPRINTF /* needed for nand_util.c */ +/* Max number of NAND devices */ +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE_LIST { 0x62000000, } +#define NAND_MAX_CHIPS 1 +/* Block 0--not used by bootcode */ +#define CONFIG_ENV_OFFSET 0x0 + +#define CONFIG_SYS_NAND_PAGE_SIZE (2 << 10) +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 << 10) +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0xe0000 +#define CONFIG_SYS_NAND_U_BOOT_SIZE 0x40000 +#define CONFIG_SYS_NAND_U_BOOT_DST 0xc1180000 +#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_NAND_U_BOOT_DST +#define CONFIG_SYS_NAND_U_BOOT_RELOC_SP (CONFIG_SYS_NAND_U_BOOT_DST - \ + CONFIG_SYS_NAND_U_BOOT_SIZE - \ + CONFIG_SYS_MALLOC_LEN - \ + CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_NAND_ECCPOS { \ + 24, 25, 26, 27, 28, \ + 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, \ + 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, \ + 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, \ + 59, 60, 61, 62, 63 } +#define CONFIG_SYS_NAND_PAGE_COUNT 64 +#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0 +#define CONFIG_SYS_NAND_ECCSIZE 512 +#define CONFIG_SYS_NAND_ECCBYTES 10 +#define CONFIG_SYS_NAND_ECCSTEPS (CONFIG_SYS_NAND_PAGE_SIZE / \ + CONFIG_SYS_NAND_ECCSIZE) +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_ECCTOTAL (CONFIG_SYS_NAND_ECCBYTES * \ + CONFIG_SYS_NAND_ECCSTEPS) +#endif /* CONFIG_SYS_USE_NAND */ + +/* + * U-Boot general configuration + */ +#define CONFIG_MISC_INIT_R +#define CONFIG_BOOTFILE "uImage" /* Boot file name */ +#define CONFIG_SYS_PROMPT "hawkboard > " /* Command Prompt */ +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Args Buffer Size */ +#define CONFIG_SYS_LOAD_ADDR (PHYS_SDRAM_1 + 0x700000) +#define CONFIG_VERSION_VARIABLE +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_CMDLINE_EDITING +#define CONFIG_SYS_LONGHELP +#define CONFIG_CRC32_VERIFY +#define CONFIG_MX_CYCLIC + +/* + * Linux Information + */ +#define LINUX_BOOT_PARAM_ADDR (CONFIG_SYS_MEMTEST_START + 0x100) +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_BOOTARGS \ + "mem=128M console=ttyS2,115200n8 root=/dev/ram0 rw initrd=0xc1180000," \ + "4M ip=static" +#define CONFIG_BOOTDELAY 3 + +/* + * U-Boot commands + */ +#include <config_cmd_default.h> +#define CONFIG_CMD_ENV +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_DIAG +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +#define CONFIG_CMD_SAVES +#define CONFIG_CMD_MEMORY + +#ifdef CONFIG_SYS_USE_NAND +#undef CONFIG_CMD_FLASH +#undef CONFIG_CMD_IMLS +#define CONFIG_CMD_NAND +#endif + +#ifndef CONFIG_DRIVER_TI_EMAC +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_DHCP +#undef CONFIG_CMD_MII +#undef CONFIG_CMD_PING +#endif + +#endif /* __CONFIG_H */ diff --git a/nand_spl/board/davinci/da8xxevm/Makefile b/nand_spl/board/davinci/da8xxevm/Makefile new file mode 100644 index 0000000..6102675 --- /dev/null +++ b/nand_spl/board/davinci/da8xxevm/Makefile @@ -0,0 +1,141 @@ +# +# (C) Copyright 2006-2007 +# Stefan Roese, DENX Software Engineering, sr@denx.de. +# +# (C) Copyright 2008 +# Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +CONFIG_NAND_SPL = y + +include $(TOPDIR)/config.mk + +LDSCRIPT= $(TOPDIR)/nand_spl/board/$(BOARDDIR)/u-boot.lds +LDFLAGS = -Bstatic -T $(nandobj)u-boot.lds -Ttext $(CONFIG_SYS_TEXT_BASE) $(PLATFORM_LDFLAGS) +AFLAGS += -DCONFIG_PRELOADER -DCONFIG_NAND_SPL +CFLAGS += -DCONFIG_PRELOADER -DCONFIG_NAND_SPL + +SOBJS = start.o _udivsi3.o _divsi3.o +COBJS = cpu.o davinci_nand.o ns16550.o div0.o davinci_pinmux.o psc.o \ + common.o hawkboard_nand_spl.o nand_boot.o + +SRCS := $(addprefix $(obj),$(SOBJS:.o=.S) $(COBJS:.o=.c)) +OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) +__OBJS := $(SOBJS) $(COBJS) +LNDIR := $(OBJTREE)/nand_spl/board/$(BOARDDIR) + +nandobj := $(OBJTREE)/nand_spl/ + +ALL = $(nandobj)u-boot-spl $(nandobj)u-boot-spl.bin \ + $(nandobj)u-boot-spl-16k.bin + +all: $(ALL) + +$(nandobj)u-boot-spl-16k.bin: $(nandobj)u-boot-spl + $(OBJCOPY) ${OBJCFLAGS} --pad-to=$(PAD_TO) -O binary $< $@ + +$(nandobj)u-boot-spl.bin: $(nandobj)u-boot-spl + $(OBJCOPY) ${OBJCFLAGS} -O binary $< $@ + +$(nandobj)u-boot-spl: $(OBJS) $(nandobj)u-boot.lds + cd $(LNDIR) && $(LD) $(LDFLAGS) $(__OBJS) \ + -Map $(nandobj)u-boot-spl.map \ + -o $(nandobj)u-boot-spl + +$(nandobj)u-boot.lds: $(LDSCRIPT) + $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -ansi -D__ASSEMBLY__ -P - <$^ >$@ + +# create symbolic links for common files + +# from board directory +$(obj)davinci_pinmux.c: + @rm -f $@ + @ln -s $(TOPDIR)/board/davinci/common/davinci_pinmux.c $@ + +# from drivers/mtd/nand directory +$(obj)davinci_nand.c: + @rm -f $@ + @ln -s $(TOPDIR)/drivers/mtd/nand/davinci_nand.c $@ + +# from nand_spl directory +$(obj)nand_boot.c: + @rm -f $@ + @ln -s $(TOPDIR)/nand_spl/nand_boot.c $@ + +# from drivers/serial directory +$(obj)ns16550.c: + @rm -f $@ + @ln -sf $(TOPDIR)/drivers/serial/ns16550.c $@ + +# from cpu directory +$(obj)start.S: + @rm -f $@ + ln -s $(TOPDIR)/arch/arm/cpu/arm926ejs/start.S $@ + +# from lib directory +$(obj)_udivsi3.S: + @rm -f $@ + ln -s $(TOPDIR)/arch/arm/lib/_udivsi3.S $@ + +# from lib directory +$(obj)_divsi3.S: + @rm -f $@ + ln -s $(TOPDIR)/arch/arm/lib/_divsi3.S $@ + +# from lib directory +$(obj)div0.c: + @rm -f $@ + ln -s $(TOPDIR)/arch/arm/lib/div0.c $@ + +# from SoC directory +$(obj)cpu.c: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/arm926ejs/davinci/cpu.c $@ + +# from board directory +$(obj)hawkboard_nand_spl.c: + @rm -f $@ + ln -s $(TOPDIR)/board/davinci/da8xxevm/hawkboard_nand_spl.c $@ + +# from board directory +$(obj)common.c: + @rm -f $@ + ln -s $(TOPDIR)/board/davinci/da8xxevm/common.c $@ + +$(obj)psc.c: + @rm -f $@ + ln -s $(TOPDIR)/arch/arm/cpu/arm926ejs/davinci/psc.c $@ + + +######################################################################### + +$(obj)%.o: $(obj)%.S + $(CC) $(AFLAGS) -c -o $@ $< + +$(obj)%.o: $(obj)%.c + $(CC) $(CFLAGS) -c -o $@ $< + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/nand_spl/board/davinci/da8xxevm/u-boot.lds b/nand_spl/board/davinci/da8xxevm/u-boot.lds new file mode 100644 index 0000000..f6ccf08 --- /dev/null +++ b/nand_spl/board/davinci/da8xxevm/u-boot.lds @@ -0,0 +1,75 @@ +/* + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, garyj@denx.de + * + * (C) Copyright 2008 + * Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0xc1080000; + + . = ALIGN(4); + .text : + { + start.o (.text) + cpu.o (.text) + nand_boot.o (.text) + + *(.text) + } + + . = ALIGN(4); + .rodata : { *(.rodata) } + + . = ALIGN(4); + .data : { + *(.data) + __datarel_start = .; + *(.data.rel) + __datarelrolocal_start = .; + *(.data.rel.ro.local) + __datarellocal_start = .; + *(.data.rel.local) + __datarelro_start = .; + *(.data.rel.ro) + } + + . = ALIGN(4); + __rel_dyn_start = .; + __rel_dyn_end = .; + __dynsym_start = .; + + __got_start = .; + . = ALIGN(4); + .got : { *(.got) } + + __got_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss : { *(.bss) } + _end = .; +}
- hawkboard_config - Used to create the u-boot.bin. Tftp the
- hawkboard_nand_config - Used to generate the secondary
- hawkboard_uart_config - This is same as the first image, but with
Applies to c163f4478ca72f51b28b55f74addc8fe029d7b83 of git://git.denx.de/u-boot.git.
This patch has checkpatch.pl warnings and errors: ERROR: return is not a function, parentheses are not required#456: FILE: board/davinci/da8xxevm/hawkboard.c:58: + return(0);
WARNING: space prohibited between function name and open parenthesis '(' #459: FILE: board/davinci/da8xxevm/hawkboard.c:61: +int misc_init_r (void)
WARNING: line over 80 characters #463: FILE: board/davinci/da8xxevm/hawkboard.c:65: + printf ("ARM Clock : %s MHz\n", strmhz(buf, clk_get(DAVINCI_ARM_CLKID)));
WARNING: space prohibited between function name and open parenthesis '(' #463: FILE: board/davinci/da8xxevm/hawkboard.c:65: + printf ("ARM Clock : %s MHz\n", strmhz(buf, clk_get(DAVINCI_ARM_CLKID)));
ERROR: return is not a function, parentheses are not required #465: FILE: board/davinci/da8xxevm/hawkboard.c:67: + return(0);
ERROR: space required after that ',' (ctx:VxV) #537: FILE: board/davinci/da8xxevm/hawkboard_nand_spl.c:65: + { pinmux(12),1, 5 }, ^
ERROR: space required after that ',' (ctx:VxV) #538: FILE: board/davinci/da8xxevm/hawkboard_nand_spl.c:66: + { pinmux(12),1, 6 } ^
WARNING: space prohibited between function name and open parenthesis '(' #569: FILE: board/davinci/da8xxevm/hawkboard_nand_spl.c:97: +void board_init_f (ulong bootflag)
ERROR: code indent should use tabs where possible #601: FILE: board/davinci/da8xxevm/hawkboard_nand_spl.c:129: +^I CONFIG_SYS_NS16550_CLK / 16 / CONFIG_BAUDRATE);$
WARNING: space prohibited between function name and open parenthesis '(' #605: FILE: board/davinci/da8xxevm/hawkboard_nand_spl.c:133: + relocate_code (CONFIG_SYS_NAND_U_BOOT_RELOC_SP, (gd_t *)gd,
WARNING: space prohibited between function name and open parenthesis '(' #631: FILE: board/davinci/da8xxevm/hawkboard_nand_spl.c:159: +void hang (void)
WARNING: space prohibited between function name and open parenthesis '(' #633: FILE: board/davinci/da8xxevm/hawkboard_nand_spl.c:161: + puts ("### ERROR ### Please RESET the board ###\n");
ERROR: trailing statements should be on next line #634: FILE: board/davinci/da8xxevm/hawkboard_nand_spl.c:162: + for (;;); + for (;;); WARNING: line over 80 characters #721: FILE: include/configs/hawkboard.h:54: +#define PHYS_SDRAM_1 DAVINCI_DDR_EMIF_DATA_BASE /* DDR Start */
WARNING: line over 80 characters #725: FILE: include/configs/hawkboard.h:58: +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x1000 - \
WARNING: line over 80 characters #842: FILE: include/configs/hawkboard.h:175: + "mem=128M console=ttyS2,115200n8 root=/dev/ram0 rw initrd=0xc1180000," \
total: 6 errors, 10 warnings, 823 lines checked
../sugosh-da8xx-v2/3of3.patch has style problems, please review. If any of these errors are false positives report them to the maintainer, see CHECKPATCH in MAINTAINERS.
I was also unable to build the da850evm u-boot with this patch applied: $make mrproper ; make da850evm_config ; make -j9 all|grep -E '( error| warning)' awk '(NF && $1 !~ /^#/) { print $1 ": " $1 "_config; $(MAKE)" }' boards.cfg > .boards.depend Configuring for da850evm board... davinci_pinmux.c:30:26: error: davinci_misc.h: No such file or directory make[1]: *** No rule to make target `.depend', needed by `libdavinci.a'. Stop. make: *** [board/davinci/common/libdavinci.a] Error 2 make: *** Waiting for unfinished jobs.... make: *** wait: No child processes. Stop.
For your next patch submission, I recommend running checkpatch.pl (from a recent linux kernel scripts/ directory) on your patches and also using the ./MAKEALL script [1] to test that your changes haven't broken other boards.
Best Regards, Ben Gardiner
[1] http://www.denx.de/wiki/U-Boot/Patches
--- Nanometrics Inc. http://www.nanometrics.ca
hi Ben,
On Tue, Oct 26, 2010 at 6:41 PM, Ben Gardiner bengardiner@nanometrics.cawrote:
Thanks a lot for the testing. Will check the patches with checkpatch script while posting the next version.
-sughosh
Ben Gardiner
Sughosh Ganu
sughosh ganu
