[PATCH 1/5] arm: lpc32xx: move SoC to mach-lpc32xx
Following the example of most other SoCs in arch/$(ARCH)/cpu/$(CPU)/$(SOC) move the lpc32xx code from arch/arm/cpu/arm926ejs/lpc32xx to arch/arm/mach-lpc32xx.
Following the checklist from commit 01f14456306c84f9bcd3945a10c98ae50e30542a: [1] move files from arch/arm/cpu/arm926ejs/lpc32xx to arch/arm/mach-lpx32xx [2] add machine entry to arch/arm/Makefile [3] remove "obj-y += ..." from arch/arm/cpu/arm926ejs/Makefile [4] fix the Kconfig file path in arch/arm/Kconfig [5] (no MAINTAINERS update)
Signed-off-by: Trevor Woerner twoerner@gmail.com --- arch/arm/Kconfig | 2 +- arch/arm/Makefile | 1 + arch/arm/cpu/arm926ejs/Makefile | 1 - arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/Kconfig | 0 arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/Makefile | 0 arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/clk.c | 0 arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/cpu.c | 0 arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/devices.c | 0 arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/dram.c | 0 .../arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/lowlevel_init.S | 0 arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/timer.c | 0 11 files changed, 2 insertions(+), 2 deletions(-) rename arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/Kconfig (100%) rename arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/Makefile (100%) rename arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/clk.c (100%) rename arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/cpu.c (100%) rename arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/devices.c (100%) rename arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/dram.c (100%) rename arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/lowlevel_init.S (100%) rename arch/arm/{cpu/arm926ejs/lpc32xx => mach-lpc32xx}/timer.c (100%)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index bbb1e2738b..3096b97c6f 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1732,7 +1732,7 @@ source "arch/arm/mach-keystone/Kconfig"
source "arch/arm/mach-kirkwood/Kconfig"
-source "arch/arm/cpu/arm926ejs/lpc32xx/Kconfig" +source "arch/arm/mach-lpc32xx/Kconfig"
source "arch/arm/mach-mvebu/Kconfig"
diff --git a/arch/arm/Makefile b/arch/arm/Makefile index e25bb0e594..33bb8923bf 100644 --- a/arch/arm/Makefile +++ b/arch/arm/Makefile @@ -62,6 +62,7 @@ machine-$(CONFIG_ARCH_K3) += k3 machine-$(CONFIG_ARCH_KEYSTONE) += keystone # TODO: rename CONFIG_KIRKWOOD -> CONFIG_ARCH_KIRKWOOD machine-$(CONFIG_KIRKWOOD) += kirkwood +machine-$(CONFIG_ARCH_LPC32XX) += lpc32xx machine-$(CONFIG_ARCH_MEDIATEK) += mediatek machine-$(CONFIG_ARCH_MESON) += meson machine-$(CONFIG_ARCH_MVEBU) += mvebu diff --git a/arch/arm/cpu/arm926ejs/Makefile b/arch/arm/cpu/arm926ejs/Makefile index b051025bb0..af63d5cc5e 100644 --- a/arch/arm/cpu/arm926ejs/Makefile +++ b/arch/arm/cpu/arm926ejs/Makefile @@ -13,7 +13,6 @@ endif endif
obj-$(CONFIG_ARMADA100) += armada100/ -obj-$(if $(filter lpc32xx,$(SOC)),y) += lpc32xx/ obj-$(CONFIG_MX25) += mx25/ obj-$(CONFIG_MX27) += mx27/ obj-$(if $(filter mxs,$(SOC)),y) += mxs/ diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/Kconfig b/arch/arm/mach-lpc32xx/Kconfig similarity index 100% rename from arch/arm/cpu/arm926ejs/lpc32xx/Kconfig rename to arch/arm/mach-lpc32xx/Kconfig diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/Makefile b/arch/arm/mach-lpc32xx/Makefile similarity index 100% rename from arch/arm/cpu/arm926ejs/lpc32xx/Makefile rename to arch/arm/mach-lpc32xx/Makefile diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/clk.c b/arch/arm/mach-lpc32xx/clk.c similarity index 100% rename from arch/arm/cpu/arm926ejs/lpc32xx/clk.c rename to arch/arm/mach-lpc32xx/clk.c diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/cpu.c b/arch/arm/mach-lpc32xx/cpu.c similarity index 100% rename from arch/arm/cpu/arm926ejs/lpc32xx/cpu.c rename to arch/arm/mach-lpc32xx/cpu.c diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/devices.c b/arch/arm/mach-lpc32xx/devices.c similarity index 100% rename from arch/arm/cpu/arm926ejs/lpc32xx/devices.c rename to arch/arm/mach-lpc32xx/devices.c diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/dram.c b/arch/arm/mach-lpc32xx/dram.c similarity index 100% rename from arch/arm/cpu/arm926ejs/lpc32xx/dram.c rename to arch/arm/mach-lpc32xx/dram.c diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/lowlevel_init.S b/arch/arm/mach-lpc32xx/lowlevel_init.S similarity index 100% rename from arch/arm/cpu/arm926ejs/lpc32xx/lowlevel_init.S rename to arch/arm/mach-lpc32xx/lowlevel_init.S diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/timer.c b/arch/arm/mach-lpc32xx/timer.c similarity index 100% rename from arch/arm/cpu/arm926ejs/lpc32xx/timer.c rename to arch/arm/mach-lpc32xx/timer.c
The comment hoped that people would keep the CONFIG_* macro names sorted, but this drifted over time. Put the list back in alphanumerical order.
Signed-off-by: Trevor Woerner twoerner@gmail.com --- arch/arm/Makefile | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/arch/arm/Makefile b/arch/arm/Makefile index 33bb8923bf..5d32dec29c 100644 --- a/arch/arm/Makefile +++ b/arch/arm/Makefile @@ -66,25 +66,25 @@ machine-$(CONFIG_ARCH_LPC32XX) += lpc32xx machine-$(CONFIG_ARCH_MEDIATEK) += mediatek machine-$(CONFIG_ARCH_MESON) += meson machine-$(CONFIG_ARCH_MVEBU) += mvebu -# TODO: rename CONFIG_TEGRA -> CONFIG_ARCH_TEGRA +machine-$(CONFIG_ARCH_OMAP2PLUS) += omap2 # TODO: rename CONFIG_ORION5X -> CONFIG_ARCH_ORION5X machine-$(CONFIG_ORION5X) += orion5x -machine-$(CONFIG_ARCH_OMAP2PLUS) += omap2 machine-$(CONFIG_ARCH_OWL) += owl +machine-$(CONFIG_ARCH_RMOBILE) += rmobile +machine-$(CONFIG_ARCH_ROCKCHIP) += rockchip machine-$(CONFIG_ARCH_S5PC1XX) += s5pc1xx -machine-$(CONFIG_ARCH_SUNXI) += sunxi machine-$(CONFIG_ARCH_SNAPDRAGON) += snapdragon machine-$(CONFIG_ARCH_SOCFPGA) += socfpga -machine-$(CONFIG_ARCH_RMOBILE) += rmobile -machine-$(CONFIG_ARCH_ROCKCHIP) += rockchip machine-$(CONFIG_STM32) += stm32 machine-$(CONFIG_ARCH_STM32MP) += stm32mp +machine-$(CONFIG_ARCH_SUNXI) += sunxi +# TODO: rename CONFIG_TEGRA -> CONFIG_ARCH_TEGRA machine-$(CONFIG_TEGRA) += tegra machine-$(CONFIG_ARCH_U8500) += u8500 machine-$(CONFIG_ARCH_UNIPHIER) += uniphier +machine-$(CONFIG_ARCH_VERSAL) += versal machine-$(CONFIG_ARCH_ZYNQ) += zynq machine-$(CONFIG_ARCH_ZYNQMP) += zynqmp -machine-$(CONFIG_ARCH_VERSAL) += versal machine-$(CONFIG_ARCH_ZYNQMP_R5) += zynqmp-r5
machdirs := $(patsubst %,arch/arm/mach-%/,$(machine-y))
Have this symbol follow the pattern of all other such symbols. This patch also removes a TODO from the code.
Signed-off-by: Trevor Woerner twoerner@gmail.com --- arch/arm/Kconfig | 2 +- arch/arm/Makefile | 3 +-- arch/arm/mach-orion5x/Kconfig | 4 ++-- configs/edminiv2_defconfig | 2 +- drivers/ata/mvsata_ide.c | 2 +- drivers/i2c/mvtwsi.c | 2 +- drivers/net/Kconfig | 2 +- drivers/net/mvgbe.c | 2 +- drivers/usb/host/Kconfig | 2 +- drivers/usb/host/ehci-marvell.c | 2 +- 10 files changed, 11 insertions(+), 12 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 3096b97c6f..d56f375c8b 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -547,7 +547,7 @@ config TARGET_APF27 select CPU_ARM926EJS select SUPPORT_SPL
-config ORION5X +config ARCH_ORION5X bool "Marvell Orion" select CPU_ARM926EJS
diff --git a/arch/arm/Makefile b/arch/arm/Makefile index 5d32dec29c..2b44ffb493 100644 --- a/arch/arm/Makefile +++ b/arch/arm/Makefile @@ -67,8 +67,7 @@ machine-$(CONFIG_ARCH_MEDIATEK) += mediatek machine-$(CONFIG_ARCH_MESON) += meson machine-$(CONFIG_ARCH_MVEBU) += mvebu machine-$(CONFIG_ARCH_OMAP2PLUS) += omap2 -# TODO: rename CONFIG_ORION5X -> CONFIG_ARCH_ORION5X -machine-$(CONFIG_ORION5X) += orion5x +machine-$(CONFIG_ARCH_ORION5X) += orion5x machine-$(CONFIG_ARCH_OWL) += owl machine-$(CONFIG_ARCH_RMOBILE) += rmobile machine-$(CONFIG_ARCH_ROCKCHIP) += rockchip diff --git a/arch/arm/mach-orion5x/Kconfig b/arch/arm/mach-orion5x/Kconfig index 2984a3edda..23c13e22f5 100644 --- a/arch/arm/mach-orion5x/Kconfig +++ b/arch/arm/mach-orion5x/Kconfig @@ -1,4 +1,4 @@ -if ORION5X +if ARCH_ORION5X
choice prompt "Marvell Orion board select" @@ -16,6 +16,6 @@ config SYS_SOC source "board/LaCie/edminiv2/Kconfig"
config SPL_LDSCRIPT - default "$(CPUDIR)/orion5x/u-boot-spl.lds" if ORION5X + default "$(CPUDIR)/orion5x/u-boot-spl.lds" if ARCH_ORION5X
endif diff --git a/configs/edminiv2_defconfig b/configs/edminiv2_defconfig index 2bbd6a783b..552b2d5b44 100644 --- a/configs/edminiv2_defconfig +++ b/configs/edminiv2_defconfig @@ -1,6 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y -CONFIG_ORION5X=y +CONFIG_ARCH_ORION5X=y CONFIG_SYS_TEXT_BASE=0x00800000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y diff --git a/drivers/ata/mvsata_ide.c b/drivers/ata/mvsata_ide.c index 38181235af..9ac16555d6 100644 --- a/drivers/ata/mvsata_ide.c +++ b/drivers/ata/mvsata_ide.c @@ -8,7 +8,7 @@ #include <common.h> #include <asm/io.h>
-#if defined(CONFIG_ORION5X) +#if defined(CONFIG_ARCH_ORION5X) #include <asm/arch/orion5x.h> #elif defined(CONFIG_KIRKWOOD) #include <asm/arch/soc.h> diff --git a/drivers/i2c/mvtwsi.c b/drivers/i2c/mvtwsi.c index 382cf4b304..77fe35a42b 100644 --- a/drivers/i2c/mvtwsi.c +++ b/drivers/i2c/mvtwsi.c @@ -25,7 +25,7 @@ DECLARE_GLOBAL_DATA_PTR; */
#ifndef CONFIG_DM_I2C -#if defined(CONFIG_ORION5X) +#if defined(CONFIG_ARCH_ORION5X) #include <asm/arch/orion5x.h> #elif (defined(CONFIG_KIRKWOOD) || defined(CONFIG_ARCH_MVEBU)) #include <asm/arch/soc.h> diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 4d1013c984..3fd3e72219 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -303,7 +303,7 @@ config FSLDMAFEC
config MVGBE bool "Marvell Orion5x/Kirkwood network interface support" - depends on KIRKWOOD || ORION5X + depends on KIRKWOOD || ARCH_ORION5X select PHYLIB if DM_ETH help This driver supports the network interface units in the diff --git a/drivers/net/mvgbe.c b/drivers/net/mvgbe.c index 037e59ec6e..b0b8d349a8 100644 --- a/drivers/net/mvgbe.c +++ b/drivers/net/mvgbe.c @@ -26,7 +26,7 @@
#if defined(CONFIG_KIRKWOOD) #include <asm/arch/soc.h> -#elif defined(CONFIG_ORION5X) +#elif defined(CONFIG_ARCH_ORION5X) #include <asm/arch/orion5x.h> #endif
diff --git a/drivers/usb/host/Kconfig b/drivers/usb/host/Kconfig index 0987ff25b1..5574e9f989 100644 --- a/drivers/usb/host/Kconfig +++ b/drivers/usb/host/Kconfig @@ -121,7 +121,7 @@ config USB_EHCI_ATMEL
config USB_EHCI_MARVELL bool "Support for Marvell on-chip EHCI USB controller" - depends on ARCH_MVEBU || KIRKWOOD || ORION5X + depends on ARCH_MVEBU || KIRKWOOD || ARCH_ORION5X default y ---help--- Enables support for the on-chip EHCI controller on MVEBU SoCs. diff --git a/drivers/usb/host/ehci-marvell.c b/drivers/usb/host/ehci-marvell.c index 8efe6b63b9..3b10cdfc58 100644 --- a/drivers/usb/host/ehci-marvell.c +++ b/drivers/usb/host/ehci-marvell.c @@ -15,7 +15,7 @@
The SPL linker script had been left in arch/$(ARCH)/cpu/$(CPU)/$(SOC) so move it to the already-established arch/$(ARCH)/mach-$(SOC) location.
Signed-off-by: Trevor Woerner twoerner@gmail.com --- arch/arm/mach-orion5x/Kconfig | 2 +- arch/arm/{cpu/arm926ejs/orion5x => mach-orion5x}/u-boot-spl.lds | 0 2 files changed, 1 insertion(+), 1 deletion(-) rename arch/arm/{cpu/arm926ejs/orion5x => mach-orion5x}/u-boot-spl.lds (100%)
diff --git a/arch/arm/mach-orion5x/Kconfig b/arch/arm/mach-orion5x/Kconfig index 23c13e22f5..5980e095ce 100644 --- a/arch/arm/mach-orion5x/Kconfig +++ b/arch/arm/mach-orion5x/Kconfig @@ -16,6 +16,6 @@ config SYS_SOC source "board/LaCie/edminiv2/Kconfig"
config SPL_LDSCRIPT - default "$(CPUDIR)/orion5x/u-boot-spl.lds" if ARCH_ORION5X + default "arch/arm/mach-orion5x/u-boot-spl.lds"
endif diff --git a/arch/arm/cpu/arm926ejs/orion5x/u-boot-spl.lds b/arch/arm/mach-orion5x/u-boot-spl.lds similarity index 100% rename from arch/arm/cpu/arm926ejs/orion5x/u-boot-spl.lds rename to arch/arm/mach-orion5x/u-boot-spl.lds
Trevor Woerner
