[U-Boot] [U-Boot-Users]-compilation error
hi.. i am new to u-boot and for my practice i compiled arm720t impa7 source code using abacus-anurag-linux compiler. i am getting the following errors.. could you help me to clear the errors.
root@user-Invalid-entry-length-0-DMI-table-is-broken-Stop:/home/user/u-boot-1.1.6# ./exec make: arm-linux-gcc: Command not found find /home/user/u-boot-1.1.6 -type f \ ( -name 'core' -o -name '*.bak' -o -name '*~' \ -o -name '*.o' -o -name '*.a' ) -print \ | xargs rm -f rm -f examples/hello_world examples/timer \ examples/eepro100_eeprom examples/sched \ examples/mem_to_mem_idma2intr examples/82559_eeprom \ examples/smc91111_eeprom examples/interrupt \ examples/test_burst rm -f tools/img2srec tools/mkimage tools/envcrc \ tools/gen_eth_addr rm -f tools/mpc86x_clk tools/ncb rm -f tools/easylogo/easylogo tools/bmp_logo rm -f tools/gdb/astest tools/gdb/gdbcont tools/gdb/gdbsend rm -f tools/env/fw_printenv tools/env/fw_setenv rm -f board/cray/L1/bootscript.c board/cray/L1/bootscript.image rm -f board/netstar/eeprom board/netstar/crcek board/netstar/crcit rm -f board/netstar/*.srec board/netstar/*.bin rm -f board/trab/trab_fkt board/voiceblue/eeprom rm -f board/integratorap/u-boot.lds board/integratorcp/u-boot.lds rm -f include/bmp_logo.h rm -f nand_spl/u-boot-spl nand_spl/u-boot-spl.map find /home/user/u-boot-1.1.6 -type f ( -name .depend \ -o -name '*.srec' -o -name '*.bin' -o -name u-boot.img ) \ -print0 \ | xargs -0 rm -f rm -f cpu/arm720t/start.o *.bak ctags etags TAGS include/version_autogenerated.h rm -fr *.*~ rm -f u-boot u-boot.map u-boot.hex u-boot.srec u-boot.bin System.map rm -f tools/crc32.c tools/environment.c tools/env/crc32.c rm -f tools/inca-swap-bytes cpu/mpc824x/bedbug_603e.c rm -f include/asm/proc include/asm/arch include/asm [ ! -d /home/user/u-boot-1.1.6/nand_spl ] || find nand_spl -lname "*" -print | xargs rm -f Configuring for impa7 board... for dir in tools examples post post/cpu ; do make -C $dir _depend ; done make[1]: Entering directory `/home/user/u-boot-1.1.6/tools' ln -s ../common/environment.c environment.c ln -s ../lib_generic/crc32.c crc32.c make[1]: Leaving directory `/home/user/u-boot-1.1.6/tools' make[1]: Entering directory `/home/user/u-boot-1.1.6/tools' make[1]: Nothing to be done for `_depend'. make[1]: Leaving directory `/home/user/u-boot-1.1.6/tools' make[1]: Entering directory `/home/user/u-boot-1.1.6/examples' abacus-anurag-linux-gcc: hello_world.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: stubs.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' make[1]: *** No rule to make target `.depend', needed by `_depend'. Stop. make[1]: Leaving directory `/home/user/u-boot-1.1.6/examples' make[1]: Entering directory `/home/user/u-boot-1.1.6/post' abacus-anurag-linux-gcc: cache_8xx.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: cache.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: codec.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: cpu.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: dsp.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: ether.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: i2c.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: memory.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: post.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: rtc.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: spr.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: sysmon.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: tests.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: uart.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: usb.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: watchdog.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' make[1]: *** No rule to make target `.depend', needed by `_depend'. Stop. make[1]: Leaving directory `/home/user/u-boot-1.1.6/post' make[1]: Entering directory `/home/user/u-boot-1.1.6/post/cpu' abacus-anurag-linux-gcc: asm.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: cmp.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: cmpi.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: two.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: twox.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: three.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: threex.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: threei.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: andi.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: srawi.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: rlwnm.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: rlwinm.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: rlwimi.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: store.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: load.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: cr.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: b.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: multi.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: string.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' abacus-anurag-linux-gcc: complex.o: No such file or directory abacus-anurag-linux-gcc: unrecognized option `-MQ' make[1]: *** No rule to make target `.depend', needed by `_depend'. Stop. make[1]: Leaving directory `/home/user/u-boot-1.1.6/post/cpu' make: *** [depend] Error 2
On Fri, Jan 27, 2012 at 7:32 AM, periyasamy samy eceperiyasamy@gmail.com wrote:
I'm not familiar with abacus-anurag, but isn't that a different architecture? This is not ARM, right? So you try to build an ARM configuration with a non-ARM toolchain, right? This won't work.
I like your hostname :-D
Regards, Christian
Christian Riesch
periyasamy samy
