[PATCH] board: mt7629: enable compression of u-boot to reduce the size of final image
This patch makes use of the decompression mechanism implemented for mt7628 previously to reduce the total image size. Binman will be also removed.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- Makefile | 3 +++ arch/arm/dts/mt7629-rfb-u-boot.dtsi | 18 ------------------ arch/arm/mach-mediatek/Kconfig | 1 - configs/mt7629_rfb_defconfig | 6 ++++++ 4 files changed, 9 insertions(+), 19 deletions(-)
diff --git a/Makefile b/Makefile index 68ce5195b2..c15d0e1048 100644 --- a/Makefile +++ b/Makefile @@ -1732,6 +1732,9 @@ u-boot-elf.lds: arch/u-boot-elf.lds prepare FORCE
ifeq ($(CONFIG_SPL),y) spl/u-boot-spl-mtk.bin: spl/u-boot-spl + +u-boot-mtk.bin: u-boot-with-spl.bin + $(call if_changed,copy) else MKIMAGEFLAGS_u-boot-mtk.bin = -T mtk_image \ -a $(CONFIG_SYS_TEXT_BASE) -e $(CONFIG_SYS_TEXT_BASE) \ diff --git a/arch/arm/dts/mt7629-rfb-u-boot.dtsi b/arch/arm/dts/mt7629-rfb-u-boot.dtsi index 164afd633b..c17e82ace7 100644 --- a/arch/arm/dts/mt7629-rfb-u-boot.dtsi +++ b/arch/arm/dts/mt7629-rfb-u-boot.dtsi @@ -5,24 +5,6 @@ * Author: Weijie Gao weijie.gao@mediatek.com */
-#include <config.h> -/ { - binman { - filename = "u-boot-mtk.bin"; - pad-byte = <0xff>; - -#ifdef CONFIG_SPL - blob { - filename = "spl/u-boot-spl-mtk.bin"; - size = <CONFIG_SPL_PAD_TO>; - }; - - u-boot-img { - }; -#endif - }; -}; - &infracfg { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/mach-mediatek/Kconfig b/arch/arm/mach-mediatek/Kconfig index 7f40ba9319..6ba873035d 100644 --- a/arch/arm/mach-mediatek/Kconfig +++ b/arch/arm/mach-mediatek/Kconfig @@ -36,7 +36,6 @@ config TARGET_MT7629 bool "MediaTek MT7629 SoC" select CPU_V7A select SPL - select BINMAN help The MediaTek MT7629 is a ARM-based SoC with a dual-core Cortex-A7 including DDR3, crypto engine, 3x3 11n/ac Wi-Fi, Gigabit Ethernet, diff --git a/configs/mt7629_rfb_defconfig b/configs/mt7629_rfb_defconfig index 2e94f974a1..cd9f7aaa06 100644 --- a/configs/mt7629_rfb_defconfig +++ b/configs/mt7629_rfb_defconfig @@ -10,7 +10,11 @@ CONFIG_SPL_TEXT_BASE=0x201000 CONFIG_TARGET_MT7629=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_SPL_STACK_R_ADDR=0x40800000 +CONFIG_SPL_PAYLOAD="u-boot-lzma.img" +CONFIG_BUILD_TARGET="u-boot-mtk.bin" CONFIG_DEFAULT_DEVICE_TREE="mt7629-rfb" +CONFIG_SPL_IMAGE="spl/u-boot-spl-mtk.bin" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_BOOTDELAY=3 @@ -18,6 +22,7 @@ CONFIG_DEFAULT_FDT_FILE="mt7629-rfb" CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_STACK_R=y CONFIG_SPL_NOR_SUPPORT=y CONFIG_SPL_WATCHDOG_SUPPORT=y CONFIG_HUSH_PARSER=y @@ -87,4 +92,5 @@ CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_WDT_MTK=y CONFIG_LZMA=y +CONFIG_SPL_LZMA=y # CONFIG_EFI_LOADER is not set
Weijie Gao
