[U-Boot] [PATCH] pinctrl: uniphier: fix Ethernet (RMII) pin-mux setting for LD20
Fix the pin-mux values for the MDC, MDIO, MDIO_INTL, PHYRSTL pins.
Fixes: fc9da85c6059 ("pinctrl: uniphier: add Ethernet pin-mux settings") Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c index 4ca39e6..0c46450 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-ld20.c @@ -20,7 +20,7 @@ static const int ether_rgmii_muxvals[] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}; static const unsigned ether_rmii_pins[] = {30, 31, 32, 33, 34, 35, 36, 37, 39, 41, 42, 45}; -static const int ether_rmii_muxvals[] = {1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1}; +static const int ether_rmii_muxvals[] = {0, 0, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1}; static const unsigned i2c0_pins[] = {63, 64}; static const int i2c0_muxvals[] = {0, 0}; static const unsigned i2c1_pins[] = {65, 66};
2017-01-17 21:07 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Applied to u-boot-uniphier/master.
Masahiro Yamada
