[UNTESTED PATCH] Nokia RX-51: Convert to CONFIG_DM_SERIAL
For CONFIG_DM_SERIAL it is required to increase CONFIG_SYS_MALLOC_F_LEN as default value is not enough for memory hungry CONFIG_DM_SERIAL code.
Signed-off-by: Pali Rohár pali@kernel.org --- Who has serial console on the real device, please test this patch if serial console is still working. I do not have adapter for serial console so I tested this patch only in qemu. --- board/nokia/rx51/rx51.c | 12 ++++++++++++ configs/nokia_rx51_defconfig | 5 ++--- include/configs/nokia_rx51.h | 1 - 3 files changed, 14 insertions(+), 4 deletions(-)
diff --git a/board/nokia/rx51/rx51.c b/board/nokia/rx51/rx51.c index 621cff095619..460d248eaaeb 100644 --- a/board/nokia/rx51/rx51.c +++ b/board/nokia/rx51/rx51.c @@ -32,6 +32,7 @@ #include <i2c.h> #include <video.h> #include <keyboard.h> +#include <ns16550.h> #include <asm/global_data.h> #include <asm/io.h> #include <asm/setup.h> @@ -788,3 +789,14 @@ U_BOOT_DRVINFOS(rx51_video) = { U_BOOT_DRVINFOS(rx51_kp) = { { "rx51_kp" }, }; + +static const struct ns16550_plat rx51_serial = { + .base = CONFIG_SYS_NS16550_COM3, + .reg_shift = 2, + .clock = CONFIG_SYS_NS16550_CLK, + .fcr = UART_FCR_DEFVAL, +}; + +U_BOOT_DRVINFOS(rx51_uart) = { + { "omap_serial", &rx51_serial }, +}; diff --git a/configs/nokia_rx51_defconfig b/configs/nokia_rx51_defconfig index d5688c7a212b..68acf01e9aeb 100644 --- a/configs/nokia_rx51_defconfig +++ b/configs/nokia_rx51_defconfig @@ -11,12 +11,12 @@ CONFIG_STATIC_MACH_TYPE=y CONFIG_MACH_TYPE=1955 CONFIG_SYS_TEXT_BASE=0x80008000 CONFIG_SYS_MALLOC_LEN=0xc0000 +CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_NOKIA_RX51=y CONFIG_SYS_LOAD_ADDR=0x80000000 CONFIG_OPTIMIZE_INLINING=y CONFIG_LTO=y -# CONFIG_SYS_MALLOC_F is not set # CONFIG_FIT is not set CONFIG_BOOTDELAY=30 CONFIG_AUTOBOOT_KEYED=y @@ -70,8 +70,7 @@ CONFIG_DM_KEYBOARD=y # CONFIG_MMC_VERBOSE is not set CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y -CONFIG_CONS_INDEX=3 -CONFIG_SYS_NS16550=y +CONFIG_DM_SERIAL=y CONFIG_SPI=y CONFIG_USB=y CONFIG_USB_MUSB_UDC=y diff --git a/include/configs/nokia_rx51.h b/include/configs/nokia_rx51.h index e837b12b568f..f273e243e55d 100644 --- a/include/configs/nokia_rx51.h +++ b/include/configs/nokia_rx51.h @@ -43,7 +43,6 @@ #define V_NS16550_CLK 48000000 /* 48MHz (APLL96/2) */
#define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE (-4) #define CONFIG_SYS_NS16550_CLK V_NS16550_CLK
Hi Pali, Tom,
I can confirm this works on my serial adapter. The patch didn't apply on latest master (2ad8d0cb950da2233a2ec030533f4e54c6d04126), but I just updated it to apply without problems locally.
Regards, Merlijn
On Sat, May 07, 2022 at 05:16:57PM +0200, Merlijn Wajer wrote:
Hi Pali, Tom,
Thanks, can you please reply with a Tested-by?
Hi Pali, Tom,
Tested-by: Merlijn Wajer merlijn@wizzup.org
Regards, Merlijn
Signed-off-by: Pali Rohár pali@kernel.org Tested-by: Merlijn Wajer merlijn@wizzup.org
Merlijn Wajer
Pali Rohár
