[U-Boot] [PATCH] x86: qemu: Drop our own ACPI implementation
Our own ACPI implementation (when CONFIG_QEMU_ACPI_TABLE is not set) does not build anymore after x86 has been fully converted to DM PCI. Instead of trying to fix the build errors, given we now have the ACPI support via QEMU's fw_cfg interface, which is a more reliable way to generate correct ACPI tables then by ourselves, hence drop our own ACPI implementation.
Signed-off-by: Bin Meng bmeng.cn@gmail.com
arch/x86/cpu/qemu/Makefile | 3 - arch/x86/cpu/qemu/acpi.c | 176 -------------- arch/x86/cpu/qemu/acpi/cpu-hotplug.asl | 80 ------- arch/x86/cpu/qemu/acpi/dbug.asl | 25 -- arch/x86/cpu/qemu/acpi/hpet.asl | 31 --- arch/x86/cpu/qemu/acpi/isa.asl | 102 -------- arch/x86/cpu/qemu/acpi/pci-crs.asl | 61 ----- arch/x86/cpu/qemu/dsdt.asl | 412 --------------------------------- 8 files changed, 890 deletions(-) delete mode 100644 arch/x86/cpu/qemu/acpi.c delete mode 100644 arch/x86/cpu/qemu/acpi/cpu-hotplug.asl delete mode 100644 arch/x86/cpu/qemu/acpi/dbug.asl delete mode 100644 arch/x86/cpu/qemu/acpi/hpet.asl delete mode 100644 arch/x86/cpu/qemu/acpi/isa.asl delete mode 100644 arch/x86/cpu/qemu/acpi/pci-crs.asl delete mode 100644 arch/x86/cpu/qemu/dsdt.asl
diff --git a/arch/x86/cpu/qemu/Makefile b/arch/x86/cpu/qemu/Makefile index 801413a..6eeddf1 100644 --- a/arch/x86/cpu/qemu/Makefile +++ b/arch/x86/cpu/qemu/Makefile @@ -8,6 +8,3 @@ ifndef CONFIG_EFI_STUB obj-y += car.o dram.o endif obj-y += cpu.o fw_cfg.o qemu.o -ifndef CONFIG_QEMU_ACPI_TABLE -obj-$(CONFIG_GENERATE_ACPI_TABLE) += acpi.o dsdt.o -endif diff --git a/arch/x86/cpu/qemu/acpi.c b/arch/x86/cpu/qemu/acpi.c deleted file mode 100644 index 7752f80..0000000 --- a/arch/x86/cpu/qemu/acpi.c +++ /dev/null @@ -1,176 +0,0 @@ -/* - * Copyright (C) 2015, Saket Sinha saket.sinha89@gmail.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <asm/acpi_table.h> -#include <asm/ioapic.h> -#include <asm/tables.h> - -void acpi_create_fadt(struct acpi_fadt *fadt, struct acpi_facs *facs, - void *dsdt) -{ - acpi_header_t *header = &(fadt->header); - u16 pmbase; - - pci_dev_t bdf = PCI_BDF(0, 0x1f, 0); - pci_read_config_word(bdf, 0x40, &pmbase); - - /* - * TODO(saket.sinha89@gmail.com): wrong value - * of pmbase by above function. Hard-coding it to - * correct value. Since no PCI register is - * programmed Power Management Interface is - * not working - */ - pmbase = 0x0600; - - memset((void *)fadt, 0, sizeof(struct acpi_fadt)); - memcpy(header->signature, "FACP", 4); - header->length = sizeof(struct acpi_fadt); - header->revision = 3; - memcpy(header->oem_id, OEM_ID, 6); - memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); - memcpy(header->asl_compiler_id, ASLC, 4); - header->asl_compiler_revision = 0; - - fadt->firmware_ctrl = (unsigned long) facs; - fadt->dsdt = (unsigned long) dsdt; - fadt->model = 0x00; - fadt->preferred_pm_profile = PM_MOBILE; - fadt->sci_int = 0x9; - fadt->smi_cmd = 0; - fadt->acpi_enable = 0; - fadt->acpi_disable = 0; - fadt->s4bios_req = 0x0; - fadt->pstate_cnt = 0; - fadt->pm1a_evt_blk = pmbase; - fadt->pm1b_evt_blk = 0x0; - fadt->pm1a_cnt_blk = pmbase + 0x4; - fadt->pm1b_cnt_blk = 0x0; - fadt->pm2_cnt_blk = pmbase + 0x50; - fadt->pm_tmr_blk = pmbase + 0x8; - fadt->gpe0_blk = pmbase + 0x20; - fadt->gpe1_blk = 0; - fadt->pm1_evt_len = 4; - /* - * Upper word is reserved and - * Linux complains about 32 bit - */ - fadt->pm1_cnt_len = 2; - fadt->pm2_cnt_len = 1; - fadt->pm_tmr_len = 4; - fadt->gpe0_blk_len = 16; - fadt->gpe1_blk_len = 0; - fadt->gpe1_base = 0; - fadt->cst_cnt = 0; - fadt->p_lvl2_lat = 1; - fadt->p_lvl3_lat = 0x39; - fadt->flush_size = 0; - fadt->flush_stride = 0; - fadt->duty_offset = 1; - fadt->duty_width = 3; - fadt->day_alrm = 0xd; - fadt->mon_alrm = 0x00; - fadt->century = 0x32; - fadt->iapc_boot_arch = 0x00; - fadt->flags = ACPI_FADT_WBINVD | ACPI_FADT_C1_SUPPORTED | - ACPI_FADT_SLEEP_BUTTON | ACPI_FADT_S4_RTC_WAKE | - ACPI_FADT_DOCKING_SUPPORTED | ACPI_FADT_RESET_REGISTER | - ACPI_FADT_PLATFORM_CLOCK; - fadt->reset_reg.space_id = ACPI_ADDRESS_SPACE_IO; - fadt->reset_reg.bit_width = 8; - fadt->reset_reg.bit_offset = 0; - fadt->reset_reg.resv = 0; - fadt->reset_reg.addrl = 0xcf9; - fadt->reset_reg.addrh = 0; - fadt->reset_value = 0x06; - /* - * Set X_FIRMWARE_CTRL only if FACS is - * above 4GB. If X_FIRMWARE_CTRL is set, - * then FIRMWARE_CTRL must be zero - */ - fadt->x_firmware_ctl_l = 0; - fadt->x_firmware_ctl_h = 0; - fadt->x_dsdt_l = (unsigned long)dsdt; - fadt->x_dsdt_h = 0; - fadt->x_pm1a_evt_blk.space_id = 1; - fadt->x_pm1a_evt_blk.bit_width = 32; - fadt->x_pm1a_evt_blk.bit_offset = 0; - fadt->x_pm1a_evt_blk.resv = 0; - fadt->x_pm1a_evt_blk.addrl = pmbase; - fadt->x_pm1a_evt_blk.addrh = 0x0; - fadt->x_pm1b_evt_blk.space_id = 0; - fadt->x_pm1b_evt_blk.bit_width = 0; - fadt->x_pm1b_evt_blk.bit_offset = 0; - fadt->x_pm1b_evt_blk.resv = 0; - fadt->x_pm1b_evt_blk.addrl = 0x0; - fadt->x_pm1b_evt_blk.addrh = 0x0; - fadt->x_pm1a_cnt_blk.space_id = 1; - /* - * Upper word is reserved and - * Linux complains about 32 bit - */ - fadt->x_pm1a_cnt_blk.bit_width = 16; - fadt->x_pm1a_cnt_blk.bit_offset = 0; - fadt->x_pm1a_cnt_blk.resv = 0; - fadt->x_pm1a_cnt_blk.addrl = pmbase + 0x4; - fadt->x_pm1a_cnt_blk.addrh = 0x0; - fadt->x_pm1b_cnt_blk.space_id = 0; - fadt->x_pm1b_cnt_blk.bit_width = 0; - fadt->x_pm1b_cnt_blk.bit_offset = 0; - fadt->x_pm1b_cnt_blk.resv = 0; - fadt->x_pm1b_cnt_blk.addrl = 0x0; - fadt->x_pm1b_cnt_blk.addrh = 0x0; - fadt->x_pm2_cnt_blk.space_id = 1; - fadt->x_pm2_cnt_blk.bit_width = 8; - fadt->x_pm2_cnt_blk.bit_offset = 0; - fadt->x_pm2_cnt_blk.resv = 0; - fadt->x_pm2_cnt_blk.addrl = pmbase + 0x50; - fadt->x_pm2_cnt_blk.addrh = 0x0; - fadt->x_pm_tmr_blk.space_id = 1; - fadt->x_pm_tmr_blk.bit_width = 32; - fadt->x_pm_tmr_blk.bit_offset = 0; - fadt->x_pm_tmr_blk.resv = 0; - fadt->x_pm_tmr_blk.addrl = pmbase + 0x8; - fadt->x_pm_tmr_blk.addrh = 0x0; - fadt->x_gpe0_blk.space_id = 1; - fadt->x_gpe0_blk.bit_width = 128; - fadt->x_gpe0_blk.bit_offset = 0; - fadt->x_gpe0_blk.resv = 0; - fadt->x_gpe0_blk.addrl = pmbase + 0x20; - fadt->x_gpe0_blk.addrh = 0x0; - fadt->x_gpe1_blk.space_id = 0; - fadt->x_gpe1_blk.bit_width = 0; - fadt->x_gpe1_blk.bit_offset = 0; - fadt->x_gpe1_blk.resv = 0; - fadt->x_gpe1_blk.addrl = 0x0; - fadt->x_gpe1_blk.addrh = 0x0; - - header->checksum = table_compute_checksum((void *)fadt, header->length); -} - -unsigned long acpi_fill_madt(unsigned long current) -{ - /* create all subtables for processors */ - current = acpi_create_madt_lapics(current); - - /* - * TODO(saket.sinha89@gmail.com): get these - * IRQ values from device tree - */ - current += acpi_create_madt_ioapic((struct acpi_madt_ioapic *)current, - 2, IO_APIC_ADDR, 0); - current += acpi_create_madt_irqoverride( - (struct acpi_madt_irqoverride *)current, 0, 0, 2, 0); - current += acpi_create_madt_irqoverride( - (struct acpi_madt_irqoverride *)current, 0, 9, 9, 0xd); - current += acpi_create_madt_irqoverride( - (struct acpi_madt_irqoverride *)current, 0, 0xd, 0xd, 0xd); - acpi_create_madt_lapic_nmi( - (struct acpi_madt_lapic_nmi *)current, 0, 0, 0); - - return current; -} diff --git a/arch/x86/cpu/qemu/acpi/cpu-hotplug.asl b/arch/x86/cpu/qemu/acpi/cpu-hotplug.asl deleted file mode 100644 index a290a4c..0000000 --- a/arch/x86/cpu/qemu/acpi/cpu-hotplug.asl +++ /dev/null @@ -1,80 +0,0 @@ -/* CPU hotplug */ - -Scope(_SB) { - /* Objects filled in by run-time generated SSDT */ - External(NTFY, MethodObj) - External(CPON, PkgObj) - - /* Methods called by run-time generated SSDT Processor objects */ - Method(CPMA, 1, NotSerialized) { - /* - * _MAT method - create an madt apic buffer - * Arg0 = Processor ID = Local APIC ID - * Local0 = CPON flag for this cpu - */ - Store(DerefOf(Index(CPON, Arg0)), Local0) - /* Local1 = Buffer (in madt apic form) to return */ - Store(Buffer(8) {0x00, 0x08, 0x00, 0x00, 0x00, 0, 0, 0}, Local1) - /* Update the processor id, lapic id, and enable/disable status */ - Store(Arg0, Index(Local1, 2)) - Store(Arg0, Index(Local1, 3)) - Store(Local0, Index(Local1, 4)) - Return (Local1) - } - Method(CPST, 1, NotSerialized) { - /* - * _STA method - return ON status of cpu - * Arg0 = Processor ID = Local APIC ID - * Local0 = CPON flag for this cpu - */ - Store(DerefOf(Index(CPON, Arg0)), Local0) - If (Local0) { - Return (0xf) - } Else { - Return (0x0) - } - } - Method(CPEJ, 2, NotSerialized) { - /* _EJ0 method - eject callback */ - Sleep(200) - } - - /* CPU hotplug notify method */ - OperationRegion(PRST, SystemIO, 0xaf00, 32) - Field(PRST, ByteAcc, NoLock, Preserve) { - PRS, 256 - } - Method(PRSC, 0) { - /* Local5 = active cpu bitmap */ - Store(PRS, Local5) - /* Local2 = last read byte from bitmap */ - Store(Zero, Local2) - /* Local0 = Processor ID / APIC ID iterator */ - Store(Zero, Local0) - While (LLess(Local0, SizeOf(CPON))) { - /* Local1 = CPON flag for this cpu */ - Store(DerefOf(Index(CPON, Local0)), Local1) - If (And(Local0, 0x07)) { - /* Shift down previously read bitmap byte */ - ShiftRight(Local2, 1, Local2) - } Else { - /* Read next byte from cpu bitmap */ - Store(DerefOf(Index(Local5, ShiftRight(Local0, 3))), Local2) - } - /* Local3 = active state for this cpu */ - Store(And(Local2, 1), Local3) - - If (LNotEqual(Local1, Local3)) { - /* State change - update CPON with new state */ - Store(Local3, Index(CPON, Local0)) - /* Do CPU notify */ - If (LEqual(Local3, 1)) { - NTFY(Local0, 1) - } Else { - NTFY(Local0, 3) - } - } - Increment(Local0) - } - } -} diff --git a/arch/x86/cpu/qemu/acpi/dbug.asl b/arch/x86/cpu/qemu/acpi/dbug.asl deleted file mode 100644 index 38a6526..0000000 --- a/arch/x86/cpu/qemu/acpi/dbug.asl +++ /dev/null @@ -1,25 +0,0 @@ -/* Debugging */ - -Scope() { - /* Debug Output */ - OperationRegion(DBG, SystemIO, 0x0402, 0x01) - Field(DBG, ByteAcc, NoLock, Preserve) { - DBGB, 8, - } - /* - * Debug method - use this method to send output to the QEMU - * BIOS debug port. This method handles strings, integers, - * and buffers. For example: DBUG("abc") DBUG(0x123) - */ - Method(DBUG, 1) { - ToHexString(Arg0, Local0) - ToBuffer(Local0, Local0) - Subtract(SizeOf(Local0), 1, Local1) - Store(Zero, Local2) - While (LLess(Local2, Local1)) { - Store(DerefOf(Index(Local0, Local2)), DBGB) - Increment(Local2) - } - Store(0x0a, dbgb) - } -} diff --git a/arch/x86/cpu/qemu/acpi/hpet.asl b/arch/x86/cpu/qemu/acpi/hpet.asl deleted file mode 100644 index 983151e..0000000 --- a/arch/x86/cpu/qemu/acpi/hpet.asl +++ /dev/null @@ -1,31 +0,0 @@ -/* HPET */ - -Scope(_SB) { - Device(HPET) { - Name(_HID, EISAID("PNP0103")) - Name(_UID, 0) - OperationRegion(HPTM, SystemMemory, 0xfed00000, 0x400) - Field(HPTM, DWordAcc, Lock, Preserve) { - VEND, 32, - PRD, 32, - } - Method(_STA, 0, NotSerialized) { - Store(VEND, Local0) - Store(PRD, Local1) - ShiftRight(Local0, 16, Local0) - If (LOr(LEqual(Local0, 0), LEqual(Local0, 0xffff))) { - Return (0x0) - } - If (LOr(LEqual(Local1, 0), LGreater(Local1, 100000000))) { - Return (0x0) - } - Return (0x0f) - } - Name(_CRS, ResourceTemplate() { - Memory32Fixed(ReadOnly, - 0xfed00000, /* Address Base */ - 0x00000400, /* Address Length */ - ) - }) - } -} diff --git a/arch/x86/cpu/qemu/acpi/isa.asl b/arch/x86/cpu/qemu/acpi/isa.asl deleted file mode 100644 index d6b3d9b..0000000 --- a/arch/x86/cpu/qemu/acpi/isa.asl +++ /dev/null @@ -1,102 +0,0 @@ -/* Common legacy ISA style devices. */ -Scope(_SB.PCI0.ISA) { - - Device(RTC) { - Name(_HID, EisaId("PNP0B00")) - Name(_CRS, ResourceTemplate() { - IO(Decode16, 0x0070, 0x0070, 0x10, 0x02) - IRQNoFlags() { 8 } - IO(Decode16, 0x0072, 0x0072, 0x02, 0x06) - }) - } - - Device(KBD) { - Name(_HID, EisaId("PNP0303")) - Method(_STA, 0, NotSerialized) { - Return (0x0f) - } - Name(_CRS, ResourceTemplate() { - IO(Decode16, 0x0060, 0x0060, 0x01, 0x01) - IO(Decode16, 0x0064, 0x0064, 0x01, 0x01) - IRQNoFlags() { 1 } - }) - } - - Device(MOU) { - Name(_HID, EisaId("PNP0F13")) - Method(_STA, 0, NotSerialized) { - Return (0x0f) - } - Name(_CRS, ResourceTemplate() { - IRQNoFlags() { 12 } - }) - } - - Device(FDC0) { - Name(_HID, EisaId("PNP0700")) - Method(_STA, 0, NotSerialized) { - Store(FDEN, Local0) - If (LEqual(Local0, 0)) { - Return (0x00) - } Else { - Return (0x0f) - } - } - Name(_CRS, ResourceTemplate() { - IO(Decode16, 0x03f2, 0x03f2, 0x00, 0x04) - IO(Decode16, 0x03f7, 0x03f7, 0x00, 0x01) - IRQNoFlags() { 6 } - DMA(Compatibility, NotBusMaster, Transfer8) { 2 } - }) - } - - Device(LPT) { - Name(_HID, EisaId("PNP0400")) - Method(_STA, 0, NotSerialized) { - Store(LPEN, Local0) - If (LEqual(Local0, 0)) { - Return (0x00) - } Else { - Return (0x0f) - } - } - Name(_CRS, ResourceTemplate() { - IO(Decode16, 0x0378, 0x0378, 0x08, 0x08) - IRQNoFlags() { 7 } - }) - } - - Device(COM1) { - Name(_HID, EisaId("PNP0501")) - Name(_UID, 0x01) - Method(_STA, 0, NotSerialized) { - Store(CAEN, Local0) - If (LEqual(Local0, 0)) { - Return (0x00) - } Else { - Return (0x0f) - } - } - Name(_CRS, ResourceTemplate() { - IO(Decode16, 0x03f8, 0x03f8, 0x00, 0x08) - IRQNoFlags() { 4 } - }) - } - - Device(COM2) { - Name(_HID, EisaId("PNP0501")) - Name(_UID, 0x02) - Method(_STA, 0, NotSerialized) { - Store(CBEN, Local0) - If (LEqual(Local0, 0)) { - Return (0x00) - } Else { - Return (0x0f) - } - } - Name(_CRS, ResourceTemplate() { - IO(Decode16, 0x02f8, 0x02f8, 0x00, 0x08) - IRQNoFlags() { 3 } - }) - } -} diff --git a/arch/x86/cpu/qemu/acpi/pci-crs.asl b/arch/x86/cpu/qemu/acpi/pci-crs.asl deleted file mode 100644 index a336dce..0000000 --- a/arch/x86/cpu/qemu/acpi/pci-crs.asl +++ /dev/null @@ -1,61 +0,0 @@ -/* PCI CRS (current resources) definition. */ -Scope(_SB.PCI0) { - - Name(CRES, ResourceTemplate() { - WordBusNumber(ResourceProducer, MinFixed, MaxFixed, PosDecode, - 0x0000, /* Address Space Granularity */ - 0x0000, /* Address Range Minimum */ - 0x00ff, /* Address Range Maximum */ - 0x0000, /* Address Translation Offset */ - 0x0100, /* Address Length */ - ,, ) - IO(Decode16, - 0x0cf8, /* Address Range Minimum */ - 0x0cf8, /* Address Range Maximum */ - 0x01, /* Address Alignment */ - 0x08, /* Address Length */ - ) - WordIO(ResourceProducer, MinFixed, MaxFixed, PosDecode, EntireRange, - 0x0000, /* Address Space Granularity */ - 0x0000, /* Address Range Minimum */ - 0x0cf7, /* Address Range Maximum */ - 0x0000, /* Address Translation Offset */ - 0x0cf8, /* Address Length */ - ,, , TypeStatic) - WordIO(ResourceProducer, MinFixed, MaxFixed, PosDecode, EntireRange, - 0x0000, /* Address Space Granularity */ - 0x0d00, /* Address Range Minimum */ - 0xffff, /* Address Range Maximum */ - 0x0000, /* Address Translation Offset */ - 0xf300, /* Address Length */ - ,, , TypeStatic) - DWordMemory(ResourceProducer, PosDecode, MinFixed, MaxFixed, Cacheable, ReadWrite, - 0x00000000, /* Address Space Granularity */ - 0x000a0000, /* Address Range Minimum */ - 0x000bffff, /* Address Range Maximum */ - 0x00000000, /* Address Translation Offset */ - 0x00020000, /* Address Length */ - ,, , AddressRangeMemory, TypeStatic) - DWordMemory(ResourceProducer, PosDecode, MinFixed, MaxFixed, NonCacheable, ReadWrite, - 0x00000000, /* Address Space Granularity */ - 0xe0000000, /* Address Range Minimum */ - 0xfebfffff, /* Address Range Maximum */ - 0x00000000, /* Address Translation Offset */ - 0x1ec00000, /* Address Length */ - ,, PW32, AddressRangeMemory, TypeStatic) - }) - - Name(CR64, ResourceTemplate() { - QWordMemory(ResourceProducer, PosDecode, MinFixed, MaxFixed, Cacheable, ReadWrite, - 0x00000000, /* Address Space Granularity */ - 0x80000000, /* Address Range Minimum */ - 0xffffffff, /* Address Range Maximum */ - 0x00000000, /* Address Translation Offset */ - 0x80000000, /* Address Length */ - ,, PW64, AddressRangeMemory, TypeStatic) - }) - - Method(_CRS, 0) { - Return (CRES) - } -} diff --git a/arch/x86/cpu/qemu/dsdt.asl b/arch/x86/cpu/qemu/dsdt.asl deleted file mode 100644 index 2b10f90..0000000 --- a/arch/x86/cpu/qemu/dsdt.asl +++ /dev/null @@ -1,412 +0,0 @@ -/* - * QEMU ACPI DSDT ASL definition - * - * Copyright (c) 2006 Fabrice Bellard - * - * Copyright (c) 2010 Isaku Yamahata - * yamahata at valinux co jp - * Based on acpi-dsdt.dsl, but heavily modified for q35 chipset. - */ - -DefinitionBlock ( - "dsdt.aml", /* Output Filename */ - "DSDT", /* Signature */ - 0x01, /* DSDT Compliance Revision */ - "UBOO", /* OEMID */ - "UBOOT ", /* TABLE ID */ - 0x2 /* OEM Revision */ - ) -{ - -#include "acpi/dbug.asl" - - Scope(_SB) { - OperationRegion(PCST, SystemIO, 0xae00, 0x0c) - OperationRegion(PCSB, SystemIO, 0xae0c, 0x01) - Field(PCSB, AnyAcc, NoLock, WriteAsZeros) { - PCIB, 8, - } - } - - -/* PCI Bus definition */ - - Scope(_SB) { - Device(PCI0) { - Name(_HID, EisaId("PNP0A08")) - Name(_CID, EisaId("PNP0A03")) - Name(_ADR, 0x00) - Name(_UID, 1) - - /* _OSC: based on sample of ACPI3.0b spec */ - Name(SUPP, 0) /* PCI _OSC Support Field value */ - Name(CTRL, 0) /* PCI _OSC Control Field value */ - Method(_OSC, 4) { - /* Create DWORD-addressable fields from Capabilities Buffer */ - CreateDWordField(Arg3, 0, CDW1) - - /* Check for proper UUID */ - If (LEqual(Arg0, ToUUID("33DB4D5B-1FF7-401C-9657-7441C03DD766"))) - { - /* Create DWORD-addressable fields from Capabilities Buffer */ - CreateDWordField(Arg3, 4, CDW2) - CreateDWordField(Arg3, 8, CDW3) - - /* Save Capabilities DWORD2 & 3 */ - Store(CDW2, SUPP) - Store(CDW3, CTRL) - - /* - * Always allow native PME, AER (no dependencies) - * Never allow SHPC (no SHPC controller in this system) - */ - And(CTRL, 0x1d, CTRL) - - If (LNotEqual(Arg1, One)) { - /* Unknown revision */ - Or(CDW1, 0x08, CDW1) - } - If (LNotEqual(CDW3, CTRL)) { - /* Capabilities bits were masked */ - Or(CDW1, 0x10, CDW1) - } - /* Update DWORD3 in the buffer */ - Store(CTRL, CDW3) - } Else { - Or(CDW1, 4, CDW1) /* Unrecognized UUID */ - } - Return (Arg3) - } - } - } - -#include "acpi/pci-crs.asl" -#include "acpi/hpet.asl" - - -/* VGA */ - - Scope(_SB.PCI0) { - Device(VGA) { - Name(_ADR, 0x00010000) - Method(_S1D, 0, NotSerialized) { - Return (0x00) - } - Method(_S2D, 0, NotSerialized) { - Return (0x00) - } - Method(_S3D, 0, NotSerialized) { - Return (0x00) - } - } - } - - -/* LPC ISA bridge */ - - Scope(_SB.PCI0) { - /* PCI D31:f0 LPC ISA bridge */ - Device(ISA) { - /* PCI D31:f0 */ - Name(_ADR, 0x001f0000) - - /* ICH9 PCI to ISA irq remapping */ - OperationRegion(PIRQ, PCI_Config, 0x60, 0x0c) - - OperationRegion(LPCD, PCI_Config, 0x80, 0x2) - Field(LPCD, AnyAcc, NoLock, Preserve) { - COMA, 3, - , 1, - COMB, 3, - - Offset(0x01), - LPTD, 2, - , 2, - FDCD, 2 - } - OperationRegion(LPCE, PCI_Config, 0x82, 0x2) - Field(LPCE, AnyAcc, NoLock, Preserve) { - CAEN, 1, - CBEN, 1, - LPEN, 1, - FDEN, 1 - } - } - } - -#include "acpi/isa.asl" - - -/* PCI IRQs */ - - /* Zero => PIC mode, One => APIC Mode */ - Name(\PICF, Zero) - Method(_PIC, 1, NotSerialized) { - Store(Arg0, \PICF) - } - - Scope(_SB) { - Scope(PCI0) { -#define prt_slot_lnk(nr, lnk0, lnk1, lnk2, lnk3) \ - Package() { nr##ffff, 0, lnk0, 0 }, \ - Package() { nr##ffff, 1, lnk1, 0 }, \ - Package() { nr##ffff, 2, lnk2, 0 }, \ - Package() { nr##ffff, 3, lnk3, 0 } - -#define prt_slot_lnkA(nr) prt_slot_lnk(nr, LNKA, LNKB, LNKC, LNKD) -#define prt_slot_lnkB(nr) prt_slot_lnk(nr, LNKB, LNKC, LNKD, LNKA) -#define prt_slot_lnkC(nr) prt_slot_lnk(nr, LNKC, LNKD, LNKA, LNKB) -#define prt_slot_lnkD(nr) prt_slot_lnk(nr, LNKD, LNKA, LNKB, LNKC) - -#define prt_slot_lnkE(nr) prt_slot_lnk(nr, LNKE, LNKF, LNKG, LNKH) -#define prt_slot_lnkF(nr) prt_slot_lnk(nr, LNKF, LNKG, LNKH, LNKE) -#define prt_slot_lnkG(nr) prt_slot_lnk(nr, LNKG, LNKH, LNKE, LNKF) -#define prt_slot_lnkH(nr) prt_slot_lnk(nr, LNKH, LNKE, LNKF, LNKG) - - Name(PRTP, Package() { - prt_slot_lnkE(0x0000), - prt_slot_lnkF(0x0001), - prt_slot_lnkG(0x0002), - prt_slot_lnkH(0x0003), - prt_slot_lnkE(0x0004), - prt_slot_lnkF(0x0005), - prt_slot_lnkG(0x0006), - prt_slot_lnkH(0x0007), - prt_slot_lnkE(0x0008), - prt_slot_lnkF(0x0009), - prt_slot_lnkG(0x000a), - prt_slot_lnkH(0x000b), - prt_slot_lnkE(0x000c), - prt_slot_lnkF(0x000d), - prt_slot_lnkG(0x000e), - prt_slot_lnkH(0x000f), - prt_slot_lnkE(0x0010), - prt_slot_lnkF(0x0011), - prt_slot_lnkG(0x0012), - prt_slot_lnkH(0x0013), - prt_slot_lnkE(0x0014), - prt_slot_lnkF(0x0015), - prt_slot_lnkG(0x0016), - prt_slot_lnkH(0x0017), - prt_slot_lnkE(0x0018), - - /* INTA -> PIRQA for slot 25 - 31 - see the default value of D<N>IR */ - prt_slot_lnkA(0x0019), - prt_slot_lnkA(0x001a), - prt_slot_lnkA(0x001b), - prt_slot_lnkA(0x001c), - prt_slot_lnkA(0x001d), - - /* PCIe->PCI bridge. use PIRQ[E-H] */ - prt_slot_lnkE(0x001e), - - prt_slot_lnkA(0x001f) - }) - -#define prt_slot_gsi(nr, gsi0, gsi1, gsi2, gsi3) \ - Package() { nr##ffff, 0, gsi0, 0 }, \ - Package() { nr##ffff, 1, gsi1, 0 }, \ - Package() { nr##ffff, 2, gsi2, 0 }, \ - Package() { nr##ffff, 3, gsi3, 0 } - -#define prt_slot_gsiA(nr) prt_slot_gsi(nr, GSIA, GSIB, GSIC, GSID) -#define prt_slot_gsiB(nr) prt_slot_gsi(nr, GSIB, GSIC, GSID, GSIA) -#define prt_slot_gsiC(nr) prt_slot_gsi(nr, GSIC, GSID, GSIA, GSIB) -#define prt_slot_gsiD(nr) prt_slot_gsi(nr, GSID, GSIA, GSIB, GSIC) - -#define prt_slot_gsiE(nr) prt_slot_gsi(nr, GSIE, GSIF, GSIG, GSIH) -#define prt_slot_gsiF(nr) prt_slot_gsi(nr, GSIF, GSIG, GSIH, GSIE) -#define prt_slot_gsiG(nr) prt_slot_gsi(nr, GSIG, GSIH, GSIE, GSIF) -#define prt_slot_gsiH(nr) prt_slot_gsi(nr, GSIH, GSIE, GSIF, GSIG) - - Name(PRTA, Package() { - prt_slot_gsiE(0x0000), - prt_slot_gsiF(0x0001), - prt_slot_gsiG(0x0002), - prt_slot_gsiH(0x0003), - prt_slot_gsiE(0x0004), - prt_slot_gsiF(0x0005), - prt_slot_gsiG(0x0006), - prt_slot_gsiH(0x0007), - prt_slot_gsiE(0x0008), - prt_slot_gsiF(0x0009), - prt_slot_gsiG(0x000a), - prt_slot_gsiH(0x000b), - prt_slot_gsiE(0x000c), - prt_slot_gsiF(0x000d), - prt_slot_gsiG(0x000e), - prt_slot_gsiH(0x000f), - prt_slot_gsiE(0x0010), - prt_slot_gsiF(0x0011), - prt_slot_gsiG(0x0012), - prt_slot_gsiH(0x0013), - prt_slot_gsiE(0x0014), - prt_slot_gsiF(0x0015), - prt_slot_gsiG(0x0016), - prt_slot_gsiH(0x0017), - prt_slot_gsiE(0x0018), - - /* - * INTA -> PIRQA for slot 25 - 31, but 30 - * see the default value of D<N>IR - */ - prt_slot_gsiA(0x0019), - prt_slot_gsiA(0x001a), - prt_slot_gsiA(0x001b), - prt_slot_gsiA(0x001c), - prt_slot_gsiA(0x001d), - - /* PCIe->PCI bridge. use PIRQ[E-H] */ - prt_slot_gsiE(0x001e), - - prt_slot_gsiA(0x001f) - }) - - Method(_PRT, 0, NotSerialized) { - /* - * PCI IRQ routing table, - * example from ACPI 2.0a - * specification, section 6.2.8.1 - * Note: we provide the same info - * as the PCI routing table - * of the Bochs BIOS - */ - If (LEqual(\PICF, Zero)) { - Return (PRTP) - } Else { - Return (PRTA) - } - } - } - - Field(PCI0.ISA.PIRQ, ByteAcc, NoLock, Preserve) { - PRQA, 8, - PRQB, 8, - PRQC, 8, - PRQD, 8, - - Offset(0x08), - PRQE, 8, - PRQF, 8, - PRQG, 8, - PRQH, 8 - } - - Method(IQST, 1, NotSerialized) { - /* _STA method - get status */ - If (And(0x80, Arg0)) { - Return (0x09) - } - Return (0x0b) - } - Method(IQCR, 1, NotSerialized) { - /* _CRS method - get current settings */ - Name(PRR0, ResourceTemplate() { - Interrupt(, Level, ActiveHigh, Shared) { 0 } - }) - CreateDWordField(PRR0, 0x05, PRRI) - Store(And(Arg0, 0x0f), PRRI) - Return (PRR0) - } - -#define define_link(link, uid, reg) \ - Device(link) { \ - Name(_HID, EISAID("PNP0C0F")) \ - Name(_UID, uid) \ - Name(_PRS, ResourceTemplate() { \ - Interrupt(, Level, ActiveHigh, Shared) { \ - 5, 10, 11 \ - } \ - }) \ - Method(_STA, 0, NotSerialized) { \ - Return (IQST(reg)) \ - } \ - Method(_DIS, 0, NotSerialized) { \ - Or(reg, 0x80, reg) \ - } \ - Method(_CRS, 0, NotSerialized) { \ - Return (IQCR(reg)) \ - } \ - Method(_SRS, 1, NotSerialized) { \ - CreateDWordField(Arg0, 0x05, PRRI) \ - Store(PRRI, reg) \ - } \ - } - - define_link(LNKA, 0, PRQA) - define_link(LNKB, 1, PRQB) - define_link(LNKC, 2, PRQC) - define_link(LNKD, 3, PRQD) - define_link(LNKE, 4, PRQE) - define_link(LNKF, 5, PRQF) - define_link(LNKG, 6, PRQG) - define_link(LNKH, 7, PRQH) - -#define define_gsi_link(link, uid, gsi) \ - Device(link) { \ - Name(_HID, EISAID("PNP0C0F")) \ - Name(_UID, uid) \ - Name(_PRS, ResourceTemplate() { \ - Interrupt(, Level, ActiveHigh, Shared) { \ - gsi \ - } \ - }) \ - Name(_CRS, ResourceTemplate() { \ - Interrupt(, Level, ActiveHigh, Shared) { \ - gsi \ - } \ - }) \ - Method(_SRS, 1, NotSerialized) { \ - } \ - } - - define_gsi_link(GSIA, 0, 0x10) - define_gsi_link(GSIB, 0, 0x11) - define_gsi_link(GSIC, 0, 0x12) - define_gsi_link(GSID, 0, 0x13) - define_gsi_link(GSIE, 0, 0x14) - define_gsi_link(GSIF, 0, 0x15) - define_gsi_link(GSIG, 0, 0x16) - define_gsi_link(GSIH, 0, 0x17) - } - -/* General purpose events */ - - Scope(_GPE) { - Name(_HID, "ACPI0006") - - Method(_L00) { - } - Method(_L01) { - } - Method(_L02) { - } - Method(_L03) { - } - Method(_L04) { - } - Method(_L05) { - } - Method(_L06) { - } - Method(_L07) { - } - Method(_L08) { - } - Method(_L09) { - } - Method(_L0A) { - } - Method(_L0B) { - } - Method(_L0C) { - } - Method(_L0D) { - } - Method(_L0E) { - } - Method(_L0F) { - } - } -}
applied to u-boot-x86, thanks!
Hi Bin,
My only concern is that this was supposed to lead to ACPI support for real hardware. If you drop this, does it make it harder?
Hi Simon,
Do you want me to rework this with DM PCI ? Regards, Saket Sinha
On Wed, Apr 20, 2016 at 6:43 PM, Simon Glass sjg@chromium.org wrote:
Hi Bin,
Hi Simon,
On Wed, Apr 20, 2016 at 9:13 PM, Simon Glass sjg@chromium.org wrote:
Hi Bin,
No, the infrastructure is still there. Only the QEMU ASL (manual) part was removed. I am going to add ACPI support to BayTrail soon (hopefully).
Regards, Bin
Hi Bin,
On 20 April 2016 at 07:45, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
Hi Bin,
OK, that's fine.
Hi Bin,
Hi Bin,
Interesting. This is also on my to-do list. We should definitely coordinate our efforts here. So please keep me updated once you really start here. I'll do the same. :)
Thanks, Stefan
Hi Stefan,
On Wed, Apr 20, 2016 at 10:40 PM, Stefan Roese sr@denx.de wrote:
Hi Bin,
Hi Bin,
Definitely. I plan to ping you before I really start to write anything as I remember you did mention ACPI before. I don't want to see any duplicated effort :-)
Regards, Bin
Hi Stefan/Bin,
I am planning to resume my ACPI work for Minnowmax and have shared the Minnowmax ACPI patches (with some issues and which would now be broken due to DM PCI).
I would need some guidance for this so let me know how we can co-ordinate on the same.
Hi Bin,
Added the review tag, and applied to u-boot-x86, thanks!
Bin Meng
Saket Sinha
Stefan Roese
