[U-Boot] [RFC PATCH] get_maintainer: fix perl 5.22/5.24 deprecated/incompatible "\C" use
from linux commit ce8155f7a3d5:
Perl 5.22 emits a deprecated message when "\C" is used in a regex. Perl 5.24 will disallow it altogether.
Fix it by using [A-Z] instead of \C.
From linux adapted to U-Boot by:
Signed-off-by: Heiko Schocher hs@denx.de --- running get_maintainer.pl drops warnings with PERL > 5.22 . In linux this is fixed though above commit.
With the original linux patch applied to u-boot, there is following warning:
^* matches null string many times in regex; marked by <-- HERE in m/^* <-- HERE / at ./scripts/get_maintainer.pl line 739. ^* matches null string many times in regex; marked by <-- HERE in m/^* <-- HERE // at ./scripts/get_maintainer.pl line 735.
The change in MAINTAINERS fixes this, but I get differences when running the python script: import os import subprocess
root_dir = '.'
for directory, subdirectories, files in os.walk(root_dir): for file in files: tmp=os.path.join(directory, file) print(tmp) ret = subprocess.call(["scripts/get_maintainer.pl", "-f", tmp])
and comparing the output from it, based on the original u-boot code and the code with this patch ...
I have no PERL experience, so made this patch as RFC, maybe someone with better PERL skills can fix it correct.
MAINTAINERS | 4 ++-- scripts/get_maintainer.pl | 22 +++++++++++----------- 2 files changed, 13 insertions(+), 13 deletions(-)
diff --git a/MAINTAINERS b/MAINTAINERS index 5b3c93a..a197cd0 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -417,5 +417,5 @@ L: u-boot@lists.denx.de Q: http://patchwork.ozlabs.org/project/uboot/list/ S: Maintained T: git git://git.denx.de/u-boot.git -F: * -F: */ +F: .* +F: .*/ diff --git a/scripts/get_maintainer.pl b/scripts/get_maintainer.pl index 4707dfd..308d7f0 100755 --- a/scripts/get_maintainer.pl +++ b/scripts/get_maintainer.pl @@ -298,7 +298,7 @@ sub read_maintainers { while (<$maint>) { my $line = $_;
- if ($line =~ m/^(\C):\s*(.*)/) { + if ($line =~ m/^([A-Z]):\s*(.*)/) { my $type = $1; my $value = $2;
@@ -533,7 +533,7 @@ sub range_is_maintained {
for (my $i = $start; $i < $end; $i++) { my $line = $typevalue[$i]; - if ($line =~ m/^(\C):\s*(.*)/) { + if ($line =~ m/^([A-Z]):\s*(.*)/) { my $type = $1; my $value = $2; if ($type eq 'S') { @@ -551,7 +551,7 @@ sub range_has_maintainer {
for (my $i = $start; $i < $end; $i++) { my $line = $typevalue[$i]; - if ($line =~ m/^(\C):\s*(.*)/) { + if ($line =~ m/^([A-Z]):\s*(.*)/) { my $type = $1; my $value = $2; if ($type eq 'M') { @@ -600,7 +600,7 @@ sub get_maintainers {
for ($i = $start; $i < $end; $i++) { my $line = $typevalue[$i]; - if ($line =~ m/^(\C):\s*(.*)/) { + if ($line =~ m/^([A-Z]):\s*(.*)/) { my $type = $1; my $value = $2; if ($type eq 'X') { @@ -615,7 +615,7 @@ sub get_maintainers { if (!$exclude) { for ($i = $start; $i < $end; $i++) { my $line = $typevalue[$i]; - if ($line =~ m/^(\C):\s*(.*)/) { + if ($line =~ m/^([A-Z]):\s*(.*)/) { my $type = $1; my $value = $2; if ($type eq 'F') { @@ -917,7 +917,7 @@ sub find_first_section {
while ($index < @typevalue) { my $tv = $typevalue[$index]; - if (($tv =~ m/^(\C):\s*(.*)/)) { + if (($tv =~ m/^([A-Z]):\s*(.*)/)) { last; } $index++; @@ -931,7 +931,7 @@ sub find_starting_index {
while ($index > 0) { my $tv = $typevalue[$index]; - if (!($tv =~ m/^(\C):\s*(.*)/)) { + if (!($tv =~ m/^([A-Z]):\s*(.*)/)) { last; } $index--; @@ -945,7 +945,7 @@ sub find_ending_index {
while ($index < @typevalue) { my $tv = $typevalue[$index]; - if (!($tv =~ m/^(\C):\s*(.*)/)) { + if (!($tv =~ m/^([A-Z]):\s*(.*)/)) { last; } $index++; @@ -971,7 +971,7 @@ sub get_maintainer_role {
for ($i = $start + 1; $i < $end; $i++) { my $tv = $typevalue[$i]; - if ($tv =~ m/^(\C):\s*(.*)/) { + if ($tv =~ m/^([A-Z]):\s*(.*)/) { my $ptype = $1; my $pvalue = $2; if ($ptype eq "S") { @@ -1030,7 +1030,7 @@ sub add_categories {
for ($i = $start + 1; $i < $end; $i++) { my $tv = $typevalue[$i]; - if ($tv =~ m/^(\C):\s*(.*)/) { + if ($tv =~ m/^([A-Z]):\s*(.*)/) { my $ptype = $1; my $pvalue = $2; if ($ptype eq "L") { @@ -1072,7 +1072,7 @@ sub add_categories { if ($name eq "") { if ($i > 0) { my $tv = $typevalue[$i - 1]; - if ($tv =~ m/^(\C):\s*(.*)/) { + if ($tv =~ m/^([A-Z]):\s*(.*)/) { if ($1 eq "P") { $name = $2; $pvalue = format_email($name, $address, $email_usename);
From linux adapted to U-Boot by: Signed-off-by: Heiko Schocher hs@denx.de
root_dir = '.'
- if ($line =~ m/^([A-Z]):\s*(.*)/) {
The backslash shouldn't be in here anymore, right?
Other than that, for the get_maintainer.pl part at least (since I was about sending out almost the same patch):
Reviewed-by: Andre Przywara andre.przywara@arm.com
Cheers, Andre.
- if ($line =~ m/^([A-Z]):\s*(.*)/) { my $type = $1; my $value = $2; if ($type eq 'S') {
- if ($line =~ m/^([A-Z]):\s*(.*)/) { my $type = $1; my $value = $2; if ($type eq 'M') {
my $type = $1; my $value = $2; if ($type eq 'X') {if ($line =~ m/^([A-Z]):\s*(.*)/) {
- if (($tv =~ m/^([A-Z]):\s*(.*)/)) { last; } $index++;
- if (!($tv =~ m/^([A-Z]):\s*(.*)/)) { last; } $index--;
- if (!($tv =~ m/^([A-Z]):\s*(.*)/)) { last; } $index++;
- if ($tv =~ m/^([A-Z]):\s*(.*)/) { my $ptype = $1; my $pvalue = $2; if ($ptype eq "S") {
- if ($tv =~ m/^([A-Z]):\s*(.*)/) { my $ptype = $1; my $pvalue = $2; if ($ptype eq "L") {
Andre Przywara
Heiko Schocher
