[U-Boot] U-boot hangs on boot time
Hey all, my u-boot-1.1.1 hangs while booting, as follow is the message got from the serial: ------------------------------------------------------ U-Boot 1.1.6 (Jan 5 2009 - 18:37:55) DRAM: 8MB Flash: 2MB ------------------------------------------------------ after some tests by tracing the sequences of the funtions, I found that the u-boot hangs while comming to this funtion: device_register (&dev), which is a subfuntion of drv_system_init (); and I look into device_register(&dev): int device_register (device_t * dev) { ListInsertItem (devlist, dev, LIST_END); return 0; } as follow are two invoid funtions copy from the devices.c. int ListInsertItem (list_t list, void *ptrToItem, int itemPosition) { return ListInsertItems (list, ptrToItem, itemPosition, 1); } int ListInsertItems (list_t list, void *ptrToItems, int firstItemPosition, int numItemsToInsert) { int numItems = (*list)->numItems;
if (firstItemPosition == numItems + 1) firstItemPosition = LIST_END; else if (firstItemPosition > numItems) return 0;
if ((*list)->numItems >= (*list)->listSize) { if (!ExpandListSpace (list, -numItemsToInsert)) return 0; }
if (firstItemPosition == LIST_START) { if (numItems == 0) { /* special case for empty list */ firstItemPosition = LIST_END; } else { firstItemPosition = 1; } }
if (firstItemPosition == LIST_END) { /* add at the end of the list */ if (ptrToItems) memcpy (ITEMPTR (list, numItems), ptrToItems, (*list)->itemSize * numItemsToInsert); else memset (ITEMPTR (list, numItems), 0, (*list)->itemSize * numItemsToInsert);
(*list)->numItems += numItemsToInsert; } else { /* move part of list up to make room for new item */ memmove (ITEMPTR (list, firstItemPosition - 1 + numItemsToInsert), ITEMPTR (list, firstItemPosition - 1), (numItems + 1 - firstItemPosition) * (*list)->itemSize);
if (ptrToItems) memmove (ITEMPTR (list, firstItemPosition - 1), ptrToItems, (*list)->itemSize * numItemsToInsert); else memset (ITEMPTR (list, firstItemPosition - 1), 0, (*list)->itemSize * numItemsToInsert);
(*list)->numItems += numItemsToInsert; } return 1; }
Most strange thing is sometimes it runs very well. My board is S3C44B0... Any help is appreciated. John
1.1.1 is really really old please update to the last release or the current git
please also note that this code has been remove and rework
Best Regards; J.
Jean-Christophe PLAGNIOL-VILLARD
John Smith
