[U-Boot-Users] Re: AMD 29LV160DB wrong ID (Hurricane555)
For knowing that you must read the data sheet for this device. As far as I can remember it seems to be a bottom boot block type hence mostly the ID is 0x2249.
The data sheet specifies commands that need to be given for the device to reveal it's manufacturer's id (AMD in this case) and the exact part type.
Also you need to know the number of banks the hardware is organised as. No worries if you do a 32 bit cycle (there must be 2 x flash devices organised as 2 x 16 bit (seems 4 MB) on the hardware. U-BOOT already handles that.
If you need more info. I will provide you with the Spansion data sheet (AMD no longer manufacture this flash).
Cheers, Krishnan
thanks for you tip! I found the problem! The static memory controler was wrong configured! I reconfigered it and then it was no problem! -- View this message in context: http://www.nabble.com/Re%3A-AMD-29LV160DB-wrong-ID-%28Hurricane555%29-t14243... Sent from the Uboot - Users forum at Nabble.com.
Hurricane555
Krishnan
