[U-Boot] [PATCH v2 0/2] sunxi: Fix boot of Cubietruk and al.
Hi
Most featureful boards, such as the Cubietruck, have been broken since the release 2017.09 (the two variants of the Olinuxino-Lime2 and the cubietruck at least, possibly more since then).
This is due to a size increase of the binary that will trip us across the size we've been using in our default configuration since forever, and widely distributed through the u-boot-sunxi-with-spl.bin file.
We would have several ways to work around it. The first one would be to just increase the offset of the environment. However, since it would break all the environments of our users and possibly the custom partition scheme that they would have created, it doesn't really seem like a smart move.
The second one would be to move the environment to a filesystem file, which would also break all the existing users. This can be envisionned as a long term fix though.
Another one would be to start trimming down a bit our enabled options in order to reduce the size and to gain some extra space for users customisations. However, this will always result in pointless and endless discussions, so let's move away from that.
The final one that has been implemented would be to just build U-Boot using thumb2 to push back the issue until hopefully I'm no longer maintainer or the switch to the env filesystem would have been done.
I've also added a patch to make sure that the compilation breaks and that we can notice.
Maxime
Maxime Ripard (2): sunxi: binman: Add U-Boot binary size check sunxi: Enable THUMB build for the U-Boot binary
arch/arm/Kconfig | 1 + arch/arm/dts/sunxi-u-boot.dtsi | 11 +++++++++++ 2 files changed, 12 insertions(+)
The U-boot binary may trip over its actual allocated size in the storage. In such a case, the environment will not be readable anymore (because corrupted when the new image was flashed), and any attempt at using saveenv to reconstruct the environment will result in a corrupted U-boot binary.
Signed-off-by: Maxime Ripard maxime.ripard@free-electrons.com --- arch/arm/dts/sunxi-u-boot.dtsi | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/arch/arm/dts/sunxi-u-boot.dtsi b/arch/arm/dts/sunxi-u-boot.dtsi index 5adfd9bca2ec..b44660e8d37e 100644 --- a/arch/arm/dts/sunxi-u-boot.dtsi +++ b/arch/arm/dts/sunxi-u-boot.dtsi @@ -1,5 +1,13 @@ #include <config.h>
+/* + * This is the maximum size the U-boot binary can be, which is + * basically the start of the environment, minus the (padded) size of + * the SPL), minus the offset at which the generated file is supposed + * to be flashed in the MMC. + */ +#define UBOOT_MAX_SIZE (CONFIG_ENV_OFFSET - CONFIG_SPL_PAD_TO - (8 << 10)) + / { binman { filename = "u-boot-sunxi-with-spl.bin"; @@ -8,6 +16,9 @@ filename = "spl/sunxi-spl.bin"; }; u-boot-img { +#ifdef CONFIG_MMC + size = <UBOOT_MAX_SIZE>; +#endif pos = <CONFIG_SPL_PAD_TO>; }; };
On Thu, Oct 19, 2017 at 10:04 PM, Maxime Ripard maxime.ripard@free-electrons.com wrote:
nits: U-boot -> U-Boot
Please fix this globally in this commit.
- This is the maximum size the U-boot binary can be, which is
- basically the start of the environment, minus the (padded) size of
- the SPL), minus the offset at which the generated file is supposed
- to be flashed in the MMC.
+#endif pos = <CONFIG_SPL_PAD_TO>; }; }; --
Regards, Bin
Merci beaucoup for that v2 series!
Just bikeshedding: Can't we use: (CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR << 9) for the last two expressions?
But that's just a nit, so:
Reviewed-by: Andre Przywara andre.przywara@arm.com
Cheers, Andre.
Am Donnerstag, 19. Oktober 2017, 16:04:18 CET schrieb Maxime Ripard:
Hello,
I found that this patch causes the sunxi-fel tool to fail with:
sunxi-fel uboot u-boot-sunxi-with-spl.bin U-Boot image data size mismatch: expected 516032, got 389212
Is there a patch for the sunxi tools missing?
Br, Frank
Hi Frank,
No, because no one reported it so far.
Can you test with: http://code.bulix.org/mb0ic7-221765?raw
You'll need the zlib development files installed.
Maxime
Am Freitag, 3. November 2017, 09:42:44 CET schrieb Maxime Ripard:
Hi Frank,
That works.
Tested-by: Frank Kunz mailinglists@kunz-im-inter.net
Hi Frank,
That works.
I created a pull request for sunxi-tools to fix the issue. Thanks for the test, and sorry for the bug.
Maxime
We start to get to the limit of our main U-Boot binary size (with some boards even crossing it). Enable its build using thumb2 to get some extra room.
Suggested-by: Siarhei Siamashka siarhei.siamashka@gmail.com Signed-off-by: Maxime Ripard maxime.ripard@free-electrons.com --- arch/arm/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 64e0ee43f112..83b7aa51dc2c 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -698,6 +698,7 @@ config ARCH_SUNXI select SPL_SYS_MALLOC_SIMPLE if SPL select SYS_NS16550 select SPL_SYS_THUMB_BUILD if !ARM64 + select SYS_THUMB_BUILD if !ARM64 select USB if DISTRO_DEFAULTS select USB_STORAGE if DISTRO_DEFAULTS select USB_KEYBOARD if DISTRO_DEFAULTS
Hi Maxime,
Can you please swap the patches? So that we get the fix before we break the build? This looks better in bisecting and buildman.
Cheers, Andre.
Maxime
participants (5)
Andre Przywara
André Przywara
Bin Meng
Frank Kunz
Maxime Ripard
