[resent][PATCH 0/3] mkimage: allow to specify signing algorithm
[resent as requested by Simon]
Another step to decouple the FIT image specification from the actual signing: With these changes, the signature nodes can leave out an algo property, mkimage will initialize that as well while signing. This way, in-tree FIT source files can be prepared for gaining signatures without defining the key type or size upfront, forcing users to patch the code to change that.
Patch 1 is preparatory for this, patch 2 a drive-by cleanup.
A better solution would actually be if the algorithm was derived from the provided key. But the underlying crypto layer seems to be rather unprepared for that.
Jan
Jan Kiszka (3): image-fit: Make string of algo parameter constant mkimage: Drop unused OPT_STRING constant mkimage: Allow to specify the signature algorithm on the command line
boot/image-fit-sig.c | 2 +- boot/image-fit.c | 8 +++---- doc/mkimage.1 | 5 +++++ include/image.h | 5 +++-- tools/fit_image.c | 3 ++- tools/image-host.c | 50 +++++++++++++++++++++++++------------------- tools/imagetool.h | 1 + tools/mkimage.c | 6 ++++-- 8 files changed, 49 insertions(+), 31 deletions(-)
Modifications would be invalid.
Signed-off-by: Jan Kiszka jan.kiszka@siemens.com --- boot/image-fit-sig.c | 2 +- boot/image-fit.c | 8 ++++---- include/image.h | 2 +- tools/image-host.c | 4 ++-- 4 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/boot/image-fit-sig.c b/boot/image-fit-sig.c index 63e5423c92..47d7633568 100644 --- a/boot/image-fit-sig.c +++ b/boot/image-fit-sig.c @@ -67,7 +67,7 @@ static int fit_image_setup_verify(struct image_sign_info *info, const void *fit, int noffset, int required_keynode, char **err_msgp) { - char *algo_name; + const char *algo_name; const char *padding_name;
if (fdt_totalsize(fit) > CONFIG_VAL(FIT_SIGNATURE_MAX_SIZE)) { diff --git a/boot/image-fit.c b/boot/image-fit.c index b629339f4e..d06a68c025 100644 --- a/boot/image-fit.c +++ b/boot/image-fit.c @@ -191,7 +191,7 @@ static void fit_image_print_data(const void *fit, int noffset, const char *p, const char *keyname; uint8_t *value; int value_len; - char *algo; + const char *algo; const char *padding; bool required; int ret, i; @@ -1063,11 +1063,11 @@ int fit_image_get_data_and_size(const void *fit, int noffset, * 0, on success * -1, on failure */ -int fit_image_hash_get_algo(const void *fit, int noffset, char **algo) +int fit_image_hash_get_algo(const void *fit, int noffset, const char **algo) { int len;
- *algo = (char *)fdt_getprop(fit, noffset, FIT_ALGO_PROP, &len); + *algo = (const char *)fdt_getprop(fit, noffset, FIT_ALGO_PROP, &len); if (*algo == NULL) { fit_get_debug(fit, noffset, FIT_ALGO_PROP, len); return -1; @@ -1265,7 +1265,7 @@ static int fit_image_check_hash(const void *fit, int noffset, const void *data, { uint8_t value[FIT_MAX_HASH_LEN]; int value_len; - char *algo; + const char *algo; uint8_t *fit_value; int fit_value_len; int ignore; diff --git a/include/image.h b/include/image.h index fd662e74b4..16ccc5b10f 100644 --- a/include/image.h +++ b/include/image.h @@ -1011,7 +1011,7 @@ int fit_image_get_data_size_unciphered(const void *fit, int noffset, int fit_image_get_data_and_size(const void *fit, int noffset, const void **data, size_t *size);
-int fit_image_hash_get_algo(const void *fit, int noffset, char **algo); +int fit_image_hash_get_algo(const void *fit, int noffset, const char **algo); int fit_image_hash_get_value(const void *fit, int noffset, uint8_t **value, int *value_len);
diff --git a/tools/image-host.c b/tools/image-host.c index a6b0a94420..a027155f3c 100644 --- a/tools/image-host.c +++ b/tools/image-host.c @@ -63,7 +63,7 @@ static int fit_image_process_hash(void *fit, const char *image_name, uint8_t value[FIT_MAX_HASH_LEN]; const char *node_name; int value_len; - char *algo; + const char *algo; int ret;
node_name = fit_get_name(fit, noffset, NULL); @@ -160,7 +160,7 @@ static int fit_image_setup_sig(struct image_sign_info *info, const char *engine_id) { const char *node_name; - char *algo_name; + const char *algo_name; const char *padding_name;
Signed-off-by: Jan Kiszka jan.kiszka@siemens.com Reviewed-by: Simon Glass sjg@chromium.org
The actual opt string is inlined - and different. Seems this was a left-over from older versions of 603e26f76346.
Signed-off-by: Jan Kiszka jan.kiszka@siemens.com --- tools/mkimage.c | 1 - 1 file changed, 1 deletion(-)
diff --git a/tools/mkimage.c b/tools/mkimage.c index fbe883ce36..a4844d0f18 100644 --- a/tools/mkimage.c +++ b/tools/mkimage.c @@ -146,7 +146,6 @@ static int add_content(int type, const char *fname) return 0; }
-#define OPT_STRING "a:A:b:B:c:C:d:D:e:Ef:Fk:i:K:ln:N:p:O:rR:qstT:vVx" static void process_args(int argc, char **argv) { char *ptr;
This permits to prepare FIT image description that do not hard-code the final choice of the signature algorithm, possibly requiring the user to patch the sources.
When -o <algo> is specified, this information is used in favor of the 'algo' property in the signature node. Furthermore, that property is set accordingly when writing the image.
Signed-off-by: Jan Kiszka jan.kiszka@siemens.com --- doc/mkimage.1 | 5 +++++ include/image.h | 3 ++- tools/fit_image.c | 3 ++- tools/image-host.c | 48 +++++++++++++++++++++++++++------------------- tools/imagetool.h | 1 + tools/mkimage.c | 5 ++++- 6 files changed, 42 insertions(+), 23 deletions(-)
diff --git a/doc/mkimage.1 b/doc/mkimage.1 index fea5288784..0734bd36a1 100644 --- a/doc/mkimage.1 +++ b/doc/mkimage.1 @@ -155,6 +155,11 @@ the corresponding public key is written into this file for for run-time verification. Typically the file here is the device tree binary used by CONFIG_OF_CONTROL in U-Boot.
+.TP +.BI "-o [" "signing algorithm" "]" +Specifies the algorithm to be used for signing a FIT image. The default is +taken from the target signature nodes 'algo' properties. + .TP .BI "-p [" "external position" "]" Place external data at a static external position. See -E. Instead of writing diff --git a/include/image.h b/include/image.h index 16ccc5b10f..4a7e9bc9a1 100644 --- a/include/image.h +++ b/include/image.h @@ -1031,6 +1031,7 @@ int fit_cipher_data(const char *keydir, void *keydest, void *fit, * @require_keys: Mark all keys as 'required' * @engine_id: Engine to use for signing * @cmdname: Command name used when reporting errors + * @algo_name: Algorithm name, or NULL if to be read from FIT * * Adds hash values for all component images in the FIT blob. * Hashes are calculated for all component images which have hash subnodes @@ -1045,7 +1046,7 @@ int fit_cipher_data(const char *keydir, void *keydest, void *fit, int fit_add_verification_data(const char *keydir, const char *keyfile, void *keydest, void *fit, const char *comment, int require_keys, const char *engine_id, - const char *cmdname); + const char *cmdname, const char *algo_name);
int fit_image_verify_with_data(const void *fit, int image_noffset, const void *data, size_t size); diff --git a/tools/fit_image.c b/tools/fit_image.c index f4f372ba62..428ddcf881 100644 --- a/tools/fit_image.c +++ b/tools/fit_image.c @@ -73,7 +73,8 @@ static int fit_add_file_data(struct image_tool_params *params, size_t size_inc, params->comment, params->require_keys, params->engine_id, - params->cmdname); + params->cmdname, + params->algo_name); }
if (dest_blob) { diff --git a/tools/image-host.c b/tools/image-host.c index a027155f3c..d2e67a06aa 100644 --- a/tools/image-host.c +++ b/tools/image-host.c @@ -107,7 +107,7 @@ static int fit_image_process_hash(void *fit, const char *image_name, */ static int fit_image_write_sig(void *fit, int noffset, uint8_t *value, int value_len, const char *comment, const char *region_prop, - int region_proplen, const char *cmdname) + int region_proplen, const char *cmdname, const char *algo_name) { int string_size; int ret; @@ -150,6 +150,8 @@ static int fit_image_write_sig(void *fit, int noffset, uint8_t *value, strdata, sizeof(strdata)); } } + if (algo_name && !ret) + ret = fdt_setprop_string(fit, noffset, "algo", algo_name);
return ret; } @@ -157,17 +159,18 @@ static int fit_image_write_sig(void *fit, int noffset, uint8_t *value, static int fit_image_setup_sig(struct image_sign_info *info, const char *keydir, const char *keyfile, void *fit, const char *image_name, int noffset, const char *require_keys, - const char *engine_id) + const char *engine_id, const char *algo_name) { const char *node_name; - const char *algo_name; const char *padding_name;
node_name = fit_get_name(fit, noffset, NULL); - if (fit_image_hash_get_algo(fit, noffset, &algo_name)) { - printf("Can't get algo property for '%s' signature node in '%s' image node\n", - node_name, image_name); - return -1; + if (!algo_name) { + if (fit_image_hash_get_algo(fit, noffset, &algo_name)) { + printf("Can't get algo property for '%s' signature node in '%s' image node\n", + node_name, image_name); + return -1; + } }
padding_name = fdt_getprop(fit, noffset, "padding", NULL); @@ -215,7 +218,7 @@ static int fit_image_process_sig(const char *keydir, const char *keyfile, void *keydest, void *fit, const char *image_name, int noffset, const void *data, size_t size, const char *comment, int require_keys, const char *engine_id, - const char *cmdname) + const char *cmdname, const char *algo_name) { struct image_sign_info info; struct image_region region; @@ -226,7 +229,7 @@ static int fit_image_process_sig(const char *keydir, const char *keyfile,
if (fit_image_setup_sig(&info, keydir, keyfile, fit, image_name, noffset, require_keys ? "image" : NULL, - engine_id)) + engine_id, algo_name)) return -1;
node_name = fit_get_name(fit, noffset, NULL); @@ -244,7 +247,7 @@ static int fit_image_process_sig(const char *keydir, const char *keyfile, }
ret = fit_image_write_sig(fit, noffset, value, value_len, comment, - NULL, 0, cmdname); + NULL, 0, cmdname, algo_name); if (ret) { if (ret == -FDT_ERR_NOSPACE) return -ENOSPC; @@ -606,7 +609,7 @@ int fit_image_cipher_data(const char *keydir, void *keydest, int fit_image_add_verification_data(const char *keydir, const char *keyfile, void *keydest, void *fit, int image_noffset, const char *comment, int require_keys, const char *engine_id, - const char *cmdname) + const char *cmdname, const char* algo_name) { const char *image_name; const void *data; @@ -643,7 +646,8 @@ int fit_image_add_verification_data(const char *keydir, const char *keyfile, strlen(FIT_SIG_NODENAME))) { ret = fit_image_process_sig(keydir, keyfile, keydest, fit, image_name, noffset, data, size, - comment, require_keys, engine_id, cmdname); + comment, require_keys, engine_id, cmdname, + algo_name); } if (ret) return ret; @@ -927,7 +931,8 @@ static int fit_config_get_data(void *fit, int conf_noffset, int noffset, static int fit_config_process_sig(const char *keydir, const char *keyfile, void *keydest, void *fit, const char *conf_name, int conf_noffset, int noffset, const char *comment, - int require_keys, const char *engine_id, const char *cmdname) + int require_keys, const char *engine_id, const char *cmdname, + const char *algo_name) { struct image_sign_info info; const char *node_name; @@ -945,7 +950,8 @@ static int fit_config_process_sig(const char *keydir, const char *keyfile, return -1;
if (fit_image_setup_sig(&info, keydir, keyfile, fit, conf_name, noffset, - require_keys ? "conf" : NULL, engine_id)) + require_keys ? "conf" : NULL, engine_id, + algo_name)) return -1;
ret = info.crypto->sign(&info, region, region_count, &value, @@ -962,7 +968,8 @@ static int fit_config_process_sig(const char *keydir, const char *keyfile, }
ret = fit_image_write_sig(fit, noffset, value, value_len, comment, - region_prop, region_proplen, cmdname); + region_prop, region_proplen, cmdname, + algo_name); if (ret) { if (ret == -FDT_ERR_NOSPACE) return -ENOSPC; @@ -992,7 +999,7 @@ static int fit_config_process_sig(const char *keydir, const char *keyfile, static int fit_config_add_verification_data(const char *keydir, const char *keyfile, void *keydest, void *fit, int conf_noffset, const char *comment, int require_keys, const char *engine_id, - const char *cmdname) + const char *cmdname, const char *algo_name) { const char *conf_name; int noffset; @@ -1011,7 +1018,7 @@ static int fit_config_add_verification_data(const char *keydir, strlen(FIT_SIG_NODENAME))) { ret = fit_config_process_sig(keydir, keyfile, keydest, fit, conf_name, conf_noffset, noffset, comment, - require_keys, engine_id, cmdname); + require_keys, engine_id, cmdname, algo_name); } if (ret) return ret; @@ -1058,7 +1065,7 @@ int fit_cipher_data(const char *keydir, void *keydest, void *fit, int fit_add_verification_data(const char *keydir, const char *keyfile, void *keydest, void *fit, const char *comment, int require_keys, const char *engine_id, - const char *cmdname) + const char *cmdname, const char *algo_name) { int images_noffset, confs_noffset; int noffset; @@ -1082,7 +1089,7 @@ int fit_add_verification_data(const char *keydir, const char *keyfile, */ ret = fit_image_add_verification_data(keydir, keyfile, keydest, fit, noffset, comment, require_keys, engine_id, - cmdname); + cmdname, algo_name); if (ret) return ret; } @@ -1106,7 +1113,8 @@ int fit_add_verification_data(const char *keydir, const char *keyfile, ret = fit_config_add_verification_data(keydir, keyfile, keydest, fit, noffset, comment, require_keys, - engine_id, cmdname); + engine_id, cmdname, + algo_name); if (ret) return ret; } diff --git a/tools/imagetool.h b/tools/imagetool.h index e229a34ffc..d71027317f 100644 --- a/tools/imagetool.h +++ b/tools/imagetool.h @@ -69,6 +69,7 @@ struct image_tool_params { const char *keydest; /* Destination .dtb for public key */ const char *keyfile; /* Filename of private or public key */ const char *comment; /* Comment to add to signature node */ + const char *algo_name; /* Algorithm name to use hashing/signing */ int require_keys; /* 1 to mark signing keys as 'required' */ int file_size; /* Total size of output file */ int orig_file_size; /* Original size for file before padding */ diff --git a/tools/mkimage.c b/tools/mkimage.c index a4844d0f18..ddb79331a6 100644 --- a/tools/mkimage.c +++ b/tools/mkimage.c @@ -154,7 +154,7 @@ static void process_args(int argc, char **argv) int opt;
while ((opt = getopt(argc, argv, - "a:A:b:B:c:C:d:D:e:Ef:FG:k:i:K:ln:N:p:O:rR:qstT:vVx")) != -1) { + "a:A:b:B:c:C:d:D:e:Ef:FG:k:i:K:ln:N:p:o:O:rR:qstT:vVx")) != -1) { switch (opt) { case 'a': params.addr = strtoull(optarg, &ptr, 16); @@ -250,6 +250,9 @@ static void process_args(int argc, char **argv) case 'N': params.engine_id = optarg; break; + case 'o': + params.algo_name = optarg; + break; case 'O': params.os = genimg_get_os_id(optarg); if (params.os < 0) {
Hi Jan,
Please add a test to test_vboot for this case.
What does 'target' mean in this case?
Perhaps 'taken from the signature node's 'algo' properties' ?
- @require_keys: Mark all keys as 'required'
- @engine_id: Engine to use for signing
- @cmdname: Command name used when reporting errors
- @algo_name: Algorithm name, or NULL if to be read from FIT
- Adds hash values for all component images in the FIT blob.
- Hashes are calculated for all component images which have hash subnodes
params->cmdname);
params->cmdname,
params->algo_name); } if (dest_blob) {
ret = fdt_setprop_string(fit, noffset, "algo", algo_name); return ret;
const char *algo_name; const char *padding_name; node_name = fit_get_name(fit, noffset, NULL);
return -1;
if (!algo_name) {
return -1;
} } padding_name = fdt_getprop(fit, noffset, "padding", NULL);
engine_id))
engine_id, algo_name)) return -1; node_name = fit_get_name(fit, noffset, NULL);
NULL, 0, cmdname);
algo_name)) return -1; ret = info.crypto->sign(&info, region, region_count, &value,
cmdname);
engine_id, cmdname,
NULL to use the one in the .its ?
case 'o':
-- 2.31.1
Jan Kiszka
