[U-Boot-Users] [PATCH] Move conditional compilation of MPC8XXX SPI driver to Makefile
Signed-off-by: Ben Warren biggerbadderben@gmail.com --- drivers/spi/Makefile | 2 +- drivers/spi/mpc8xxx_spi.c | 2 -- 2 files changed, 1 insertions(+), 3 deletions(-)
diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index bc8a104..eab9d93 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -25,7 +25,7 @@ include $(TOPDIR)/config.mk
LIB := $(obj)libspi.a
-COBJS-y += mpc8xxx_spi.o +COBJS-$(CONFIG_MPC8XXX_SPI) += mpc8xxx_spi.o COBJS-$(CONFIG_MXC_SPI) += mxc_spi.o
COBJS := $(COBJS-y) diff --git a/drivers/spi/mpc8xxx_spi.c b/drivers/spi/mpc8xxx_spi.c index 2fe838c..5e2f67a 100644 --- a/drivers/spi/mpc8xxx_spi.c +++ b/drivers/spi/mpc8xxx_spi.c @@ -22,7 +22,6 @@ */
#include <common.h> -#if defined(CONFIG_MPC8XXX_SPI) && defined(CONFIG_HARD_SPI)
#include <spi.h> #include <asm/mpc8xxx_spi.h> @@ -140,4 +139,3 @@ int spi_xfer(spi_chipsel_type chipsel, int bitlen, uchar *dout, uchar *din)
return 0; } -#endif /* CONFIG_HARD_SPI */
Dear Ben,
in message 1211783488-30985-1-git-send-email-biggerbadderben@gmail.com you wrote:
i. e. we move CONFIG_MPC8XXX_SPI into the Makefile...
...but that would leave the "#ifded CONFIG_HARD_SPI" part still in place. Or am I missing something?
Wolfgang Denk wrote:
Dear Ben,
If CONFIG_MPC8XXX_SPI is defined but CONFIG_HARD_SPI is not, compilation will fail, since CONFIG_HARD_SPI activates the common SPI code on PowerPC. I guess I figured Kconfig would eventually manage the dependencies of these options, but I will put the #ifdef back in if you want.
regards, Ben
How would I configure a system to use CONFIG_SOFT_SPI on a MPC8XXX system?
At the moment it seems logical to me to leave this test as it was.
That's actually pretty easy:
1. #define CONFIG_SOFT_SPI in board config 2. define bit-bang parameters in board code 3. Call spi_init() from board code
The CONFIG_HARD_SPI define doesn't actually do anything hardware-related. The only place it's used is in lib_ppc/board.c to initialize a SPI controller, but the code could equally-well start a soft SPI controller. I would have used CONFIG_SPI, but that was already taken by SPI EEPROM stuff. Maybe it's time to refactor a bit more...
regards, Ben
This only makes a difference if a board config defines CONFIG_MPC8XXX_SPI without defining CONFIG_HARD_SPI, which is arguably a bug. I think it's better to get a compile error when this happens than having the CONFIG_MPC8XXX_SPI define be silently ignored (which most likely won't be detected until runtime.)
So I think the patch is fine as it is, for whatever that's worth.
Haavard
In message 20080527093432.3026cb15@hskinnemo-gx745.norway.atmel.com you wrote:
I can't really folow that logic.
If we define CONFIG_HARD_SPI, then I don't see why CONFIG_MPC8XXX_SPI is needed at all if we're on a MPC8XXX system - that seems redundant to me. On the other hand, if you want to use CONFIG_MPC8XXX_SPI and this implies that CONFIG_HARD_SPI must be set, too, then it should automatically set this variable instead of causing the compile to fail.
This assumes that we use only one SPI controller (built-in on the CPU/SOC). We should also keep in mind what happens when you use CONFIG_SOFT_SPI, eventually even simultaneously.
Sounds to me like you're asking for Kconfig. I can't think of any way to meet those requirements with the current infrastructure...
To be more specific: * Which part of the system is responsible for figuring out that when CONFIG_HARD_SPI is set _and_ we're on a MPC8XXX system, the mpx8xxx_spi driver should be compiled? * Which part of the system is responsible for automatically selecting CONFIG_HARD_SPI when CONFIG_MPC8XXX_SPI is set?
On the other hand, it looks like everyone but powerpc is getting away with not using CONFIG_HARD_SPI at all. Is it really necessary to have two defines for essentially the same thing?
The current infrastructure doesn't allow multiple SPI controllers.
The new infrastructure that I posted yesterday supports multiple SPI controllers of the same type, but not different ones. I asked whether supporting multiple different SPI controllers would be necessary but got no response, so I assumed no.
Haavard
In message 20080527100426.0f40544e@hskinnemo-gx745.norway.atmel.com you wrote:
No? Uuups... what's wrong with
#ifdef CONFIG_MPC8XXX_SPI # ifndef CONFIG_HARD_SPI # define CONFIG_HARD_SPI # endif #endif
Not exactly beautiful, but should work, shouldn't it?
- Which part of the system is responsible for figuring out that when CONFIG_HARD_SPI is set _and_ we're on a MPC8XXX system, the mpx8xxx_spi driver should be compiled?
The Makefile?
Yes, you ill have to use a conditional in the Makefile as long as you ask for separate CONFIG_ options. That's one reason why I'm asking why we need several.
- Which part of the system is responsible for automatically selecting CONFIG_HARD_SPI when CONFIG_MPC8XXX_SPI is set?
include/spi.h ?
Bingo! That was exactly my question.
Yes, I know. But we should keep in mind that one day such a system may have to be supported, and we should try not to make support for such systems more difficult than necessary.
I think that's a valid assumption, at least for now. I cannot imagine why multiple different SPI controllers might be needed, but then I'm surprised again and again what hardware designers can come up with. So we should try not to build barriers that can be avoided.
Sure, but I was mostly wondering about _where_ one would put something like that...which you answered below.
The Makefile?
Ah...but I'm _also_ wondering why we need several :-)
include/spi.h ?
Makes sense.
I guess I misunderstood then.
What I'm trying to say is that it makes sense to have one config symbol per driver so that the board config header can specify exactly what it wants instead of having something else try to figure it out automatically.
So maybe we should try to get rid of the CONFIG_HARD_SPI define? I don't think there's any fundamental difference between soft and hard SPI anymore, at least not at the interface level.
Agree.
Sure, and I think my SPI patches brings us closer to the goal of supporting multiple types of SPI hardware. But I don't want to take the final step before we know for certain that we want it because it makes the SPI layer more expensive in terms of code size and RAM usage.
I suspect that if we do want something like that, it will probably be about combining hardware and software SPI (i.e. we want more SPI busses than the chip can provide in hardware.)
Haavard
In message 20080527103245.565527ba@hskinnemo-gx745.norway.atmel.com you wrote:
Well, I think I'd rather get rid of CONFIG_MPC8XXX_SPI as this is redundant - it's what you atomatically get when using CONFIG_HARD_SPI on a MPC8XXX system. That would make this more in line with the I2C code. And we can use something like
#if defined(CONFIG_HARD_SPI) || defined (CONFIG_SOFT_SPI)
when we need to know if there is any SPI support at all (like we do with I2C).
Yes, I guess this is going to happen first. Hopefully not soon, though ;-)
Sorry I'm just re-joining this conversation. That's the fun of being 9 time zones apart...
Ideally, we'd be able to re-claim CONFIG_SPI from whatever perverse use it currently has (IIRC it CONFIG_BOOT_FROM_SPI_EEPROM), but that's pretty invasive. I don't think we want to take out CONFIG_MCP8XXX_SPI, because then somebody needs to keep track of what CPUs have it and maintain the header files appropriately. I can just imagine the mess:
#if (defined MPC834X) || (defined MPC857X) || (defined MPC9766) || \ . . . do your stuff #endif
Automatically generating CONFIG_HARD_SPI from it, though, makes sense, though, although I hate to see architecture-specific stuff go in spi.h. NBD, I guess.
Yeah, suggesting that something isn't necessary virtually assures that it will be.
I'll put together a new patch and re-send later today.
regards, Ben
Ben Warren
Haavard Skinnemoen
